02-Multicast VLAN Commands | 65.43 KB |
display multicast-vlan
display multicast-vlan [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: VLAN ID of a multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all multicast VLANs will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case-sensitive string of 1 to 256 characters.
Use the display multicast-vlan command to display the information about the specified multicast VLAN.
# Display the information about all multicast VLANs.
<Sysname> display multicast-vlan
Total 1 multicast-vlan(s)
Multicast vlan 200
port list:
GE1/0/1 GE1/0/2
Table 1 Output description
Total 1 multicast-vlan(s) |
Total number of multicast VLANs |
Multicast vlan |
A multicast VLAN |
port list |
Port list of the multicast VLAN |
multicast-vlan
multicast-vlan vlan-id
undo multicast-vlan { all | vlan-id }
View
Default level
2: System level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
all: Deletes all multicast VLANs.
Use the multicast-vlan command to configure the specified VLAN as a multicast VLAN and enter multicast VLAN view.
Use the undo multicast-vlan command to remove the specified VLAN as a multicast VLAN.
The VLAN to be configured is not a multicast VLAN by default.
The specified VLAN to be configured as a multicast VLAN must exist.
You need to enable IGMP snooping in both the multicast VLAN and all the user VLANs.
Related commands: igmp-snooping enable.
# Enable IGMP snooping in VLAN 100. Configure it as a multicast VLAN and enter multicast VLAN view.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] igmp-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan 100
[Sysname-mvlan-100]
port (multicast VLAN view)
port interface-list
undo port { all | interface-list }
View
Multicast VLAN view
Default level
2: System level
interface-list: Specifies a port in the form of interface-type interface-number, or a port range in the form of interface-type start-interface-number to interface-type end-interface-number, where the end interface number must be greater than the start interface number.
all: Deletes all the ports in the current multicast VLAN.
Use the port command to assign the specified port or ports to the current multicast VLAN.
Use the undo port command to delete the specified port or ports or all ports from the current multicast VLAN.
By default, a multicast VLAN has no ports.
A port can belong to only one multicast VLAN.
Only the following types of interfaces can be configured as multicast VLAN ports: Ethernet or Layer 2 aggregate interfaces.
# Assign ports GigabitEthernet1/0/1 through GigabitEthernet1/0/5 to multicast VLAN 100.
[Sysname-mvlan-100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/5
port multicast-vlan
port multicast-vlan vlan-id
undo port multicast-vlan
View
Ethernet interface view, Layer 2 aggregate interface view, port group view.
Default level
2: System level
vlan-id: VLAN ID of the multicast VLAN you want to assign the current port or ports to, in the range of 1 to 4094.
Use the port multicast-vlan command to assign the current port or ports to the specified multicast VLAN.
Use the undo port multicast-vlan command to restore the system default.
By default, a port does not belong to any multicast VLAN.
# Assign GigabitEthernet 1/0/1 to multicast VLAN 100.
[Sysname- GigabitEthernet1/0/1] port multicast-vlan 100
