01-Fundamentals Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10201-Fundamentals Command Reference
02-Logging In to the Switching Engine Commands
02-Logging In to the Switching Engine Commands 227.47 KB
acl (user interface view)
·           To use a basic or advanced ACL:
acl [ ipv6 ] acl-number { inbound | outbound }
undo acl [ ipv6 ] acl-number { inbound | outbound }
·           To use an Ethernet frame header ACL:
acl acl-number inbound
undo acl acl-number inbound
View
VTY user interface view
Default level
2: System level
ipv6: When this keyword is present, the command supports IPv6; otherwise, it supports IPv4.
acl-number: Number of the access control list (ACL), which takes the following values:
·           Basic ACL: 2000 to 2999
·           Advanced ACL: 3000 to 3999
·           Ethernet frame header ACL: 4000 to 4999
inbound: Restricts Telnet connections established in the inbound direction through the VTY user interface. If the received packets for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet server, this keyword is used to control access of Telnet clients.
outbound: Restricts Telnet connections established in the outbound direction through the VTY user interface. If the packets sent for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet client, this keyword is used to define Telnet servers accessible to the client.
Use the acl command to reference ACLs to control access to the VTY user interface.
Use the undo acl command to cancel the ACL application. For more information about ACL, see the ACL and QoS Command Reference.
By default, access to the VTY user interface is not restricted.
·           If no ACL is referenced in VTY user interface view, the VTY user interface has no access control over establishing a Telnet or SSH connection.
·           If an ACL is referenced in VTY user interface view, the connection is permitted to be established only when packets for establishing a Telnet connection match a permit statement in the ACL.
The system regards the basic/advanced ACL with the inbound keyword, the basic/advanced ACL with the outbound keyword, and Ethernet frame header ACL as different types of ACLs, which can coexist in one VTY user interface. The match order is basic/advanced ACL, Ethernet frame header ACL. At most one ACL of each type can be referenced in the same VTY user interface, and the last configured one takes effect.
# Allow only the user with the IP address of 192.168.1.26 to access the device through Telnet.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.1.26 0
[Sysname-acl-basic-2001] quit
[Sysname] user-interface vty 0
[Sysname-ui-vty0] acl 2001 inbound
After your configuration, user A (with IP address 192.168.1.26) can telnet to the device while user B (with IP address 192.168.1.60) cannot telnet to the device. Upon a connection failure, a message appears, saying "%connection closed by remote host!"
# Allow the device to only telnet to the Telnet server with IP address 192.168.1.41.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination 192.168.1.41 0
[Sysname-acl-adv-3001] quit
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 3001 outbound
[Sysname-ui-vty0-4] return
<Sysname>
After your configuration, if you telnet to 192.168.1.46, your operation fails.
<Sysname> telnet 192.168.1.46
%Can't access the host from this terminal!
But you can telnet to 192.168.1.41.
<Sysname> telnet 192.168.1.41
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
activation-key
activation-key character
undo activation-key
View
User interface view
Default level
3: Manage level
character: Shortcut key for starting a terminal session, a single character (or its corresponding ASCII code value that ranges from 0 to 127) or a string of 1 to 3 characters. However, only the first character functions as the shortcut key. For example, if you input an ASCII code value of 97, the system uses its corresponding character a as the shortcut key. If you input string b@c, the system uses the first character b as the shortcut key.
Use the activation-key command to define a shortcut key for starting a terminal session.
Use the undo activation-key command to restore the default.
By default, pressing the Enter key starts a terminal session. However, if a new shortcut key is defined with the activation-key command, the Enter key no longer functions. To display the shortcut key you have defined, use the display current-configuration command.
The activation-key command is not supported by the VTY user interface.
# Configure character s as the shortcut key for starting a terminal session on the AUX port.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] activation-key s
To verify the configuration:
·           Exit the terminal session on the AUX port.
[Sysname-ui-aux0] return
<Sysname> quit
·           Log in to the AUX port again. The following message appears.
* Copyright (c) 2004-2011 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
User interface aux0 is available.
Please press ENTER.
·           At this moment, pressing Enter does not start a session. To start the terminal session, enter s instead.
<Sysname>
%Mar  2 18:40:27:981 2005 Sysname SHELL/5/LOGIN: Console login from aux0
auto-execute command
auto-execute command command
undo auto-execute command
View
User interface view
Default level
3: Manage level
command: Specifies a command to be automatically executed.
Use the auto-execute command command to specify a command to be automatically executed when a user logs in to the current user interface.
Use the undo auto-execute command command to remove the configuration.
By default, command auto-execution is disabled.
The auto-execute command command is not supported by the AUX user interface.
The system automatically executes the specified command when a user logs in to the user interface, and tears down the user connection after the command is executed. If the command triggers another task, the system does not tear down the user connection until the task is completed.
Typically, you can use the auto-execute command telnet command in user interface view to enable a user to automatically telnet to the specified host when the user logs in to the device.
CAUTION
CAUTION:
The auto-execute command command may disable you from configuring the system through the user interface to which the command is applied. Before configuring the command and saving the configuration (by using the save command), make sure that you can access the device through VTY or AUX interfaces to remove the configuration when a problem occurs.
# Configure the device to automatically telnet to 192.168.1.41 after a user logs in to user interface VTY 0.
[Sysname -ui-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through ui-vty0. Are you sure?
[Y/N]:y
[Sysname-ui-vty0]
Telnet to 192.168.1.40. The device automatically telnets to 192.168.1.41. The following output is displayed:
C:\> telnet 192.168.1.40
<Sysname>
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41. If the telnet connection to 192.168.1.41 is broken down, the telnet connection to 192.168.1.40 breaks down at the same time.
authentication-mode
authentication-mode { none | password | scheme }
undo authentication-mode
View
User interface view
Default level
3: Manage level
none: Performs no authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see the Security Configuration Guide.
Use the authentication-mode command to set the authentication mode for the user interface.
Use the undo authentication-mode command to restore the default.
By default, the authentication mode for VTY user interfaces is password, and for the AUX user interface is none.
Related commands: set authentication password.
# Specify that no authentication is needed for VTY 0. (This mode is insecure.)
[Sysname-ui-vty0] authentication-mode none
# Use password authentication when users log in to the device through VTY 0, and set the authentication password to 321.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password cipher 321
# Authenticate users by username and password for VTY 0. Set the username to 123 and the password to 321.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
[Sysname] local-user 123
[Sysname-luser-123] password cipher 321
[Sysname-luser-123] service-type telnet
[Sysname-luser-123] authorization-attribute level 3
command accounting
command accounting
undo command accounting
View
User interface view
Default level
3: Manage level
None
Use the command accounting command to enable command accounting.
Use the undo command accounting command to restore the default.
By default, command accounting is disabled. The accounting server does not record the commands that users have executed.
When command accounting is enabled and command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only the authorized and executed commands are recorded on the HWTACACS server.
# Enable command accounting on VTY 0. Then the HWTACACS server records the commands executed by users that have logged in through VTY 0.
[Sysname-ui-vty0] command accounting
undo command authorization
View
User interface view
Default level
3: Manage level
None
Use the command authorization command to enable command authorization.
Use the undo command authorization command to restore the default.
By default, command authorization is disabled. Logged-in users can execute commands without authorization.
With command authorization enabled, users can perform only commands authorized by the server.
# Enable command accounting for VTY 0 so that users logging in from VTY 0 can perform only the commands authorized by the HWTACACS server.
[Sysname-ui-vty0] command authorization
databits
databits { 5 | 6 | 7 | 8 }
undo databits
View
User interface view
Default level
2: System level
5: Sets 5 data bits for each character.
6: Sets 6 data bits for each character.
7: Sets 7 data bits for each character.
8: Sets 8 data bits for each character.
Use the databits command to set data bits for each character.
Use the undo databits command to restore the default.
By default, 8 data bits are set for each character.
For the switching engine, the data bits must be set to 8.
·       The command is only applicable to the AUX port.
·       The data bits setting must be the same for the user interfaces of the connecting ports on the device and the terminal device for communication.
# Specify 8 data bits for each character.
[Sysname-ui-aux0] databits 8
display ip http
display ip http [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display ip http command to display HTTP information.
# Display information about HTTP..
<Sysname> display ip http
HTTP port: 80
Basic ACL: 2222
Current connection: 0
Operation status: Running
Table 1 Output description
HTTP port
Port number used by the HTTP service
Basic ACL
Basic ACL number associated with the HTTP service
Current connection
Number of current connections
Operation status
Operation status, which takes the following values:
·       Running—The HTTP service is enabled.
·       Stopped—The HTTP service is disabled.
display ip https
display ip https [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ip https command to display information about HTTPS.
# Display information about HTTPS.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy:
Basic ACL: 2222
Table 2 Output description
HTTPS port
Port number used by the HTTPS service
SSL server policy
The SSL server policy associated with the HTTPS service
The certificate attribute access control policy associated with the HTTPS service
Basic ACL
The basic ACL number associated with the HTTPS service
Operation status
·       Running—The HTTPS service is enabled.
·       Stopped—The HTTPS service is disabled.
display telnet client configuration
display telnet client configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display telnet client configuration command to display the configuration of the device when it serves as a telnet client.
# Display the configuration of the device when it serves as a telnet client.
<Sysname> display telnet client configuration
 The source IP address is 1.1.1.1.
The output shows that when the device serves as a client, the source IPv4 address for sending telnet packets is 1.1.1.1.
display user-interface
display user-interface [ aux | vty ] first-number [ last-number ] [ summary ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
aux: Specifies the AUX user interface.
vty: Specifies the VTY user interface.
first-number: Relative or absolute number of a user interface.
·           If the aux or vty keyword is specified, first-number represents the relative number of the specified user interface. It takes the value of 0 for the AUX user interface, and ranges from 0 to 15 for the VTY user interface.
·           If the aux or vty keyword is not specified, first-number represents the absolute number of a user interface. It ranges from 0 to 32.
last-number: The last user interface to be configured, which must be greater than first-number.
summary: Displays summary about user interfaces.
Use the display user-interface command to display information about the specified or all user interfaces.
If the summary keyword is not included, the command displays the type of the user interface, the absolute or relative number, the transmission rate, the user privilege level, the authentication mode, and the access port.
If the summary keyword is included, the command displays all user interface numbers and types.
# Display information about user interface 0.
<Sysname> display user-interface 0
  Idx  Type     Tx/Rx      Modem Privi Auth  Int
+ 0    AUX 0    9600       -     3     N     -
  +    : Current user-interface is active.
  F    : Current user-interface is active and work in async mode.
  Idx  : Absolute index of user-interface.
  Type : Type and relative index of user-interface.
  Privi: The privilege of user-interface.
  Auth : The authentication mode of user-interface.
  Int  : The physical location of UIs.
  A    : Authentication use AAA.
  L    : Authentication use local database.
  N    : Current UI need not authentication.
  P    : Authentication use current UI's password.
Table 3 Output description
The current user interface is active.
F
The current user interface is active and works in asynchronous mode.
Idx
Absolute number of the user interface.
Type and relative number of the user interface.
Tx/Rx
Transmission/Receive rate of the user interface
Modem
Whether the modem is allowed to dial in (in), dial out (out), or both (inout)
By default, the character - is displayed to indicate that this function is disabled.
Privi
Indicates the command level of a user under that user interface
Auth
Authentication mode for the users, which can be A, P, L, and N.
Int
The physical port that corresponds to the user interface.
A
AAA authentication
L
Local authentication (not supported)
N
No authentication
P
Password authentication
# Display summary about all user interfaces.
<Sysname> display user-interface summary
  User interface type : [AUX]
            0:X
  User interface type : [VTY]
            1:UXXX XXXX XXXX XXXX
    1 character mode users.    (U)
   16 UI never used.        (X)
    1 total UI in use
Table 4 Output description
User interface type
Type of user interface (AUX/VTY)
0:X
0 represents the absolute number of the user interface. X means this user interface is not used;  U means this user interface is in use.
Number of users, or, the total number of character U.
UI never used.             (X)
Number of user interfaces not used, or, the total number of character X.
total UI in use
Total number of user interfaces in use
display users
display users [ all ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about all user interfaces that the device supports.
Use the display users command to display information about the user interfaces that are being used.
Use the display users all command to display information about all user interfaces supported by the device.
# Display information about the user interfaces that are being used.
<Sysname> display users
The user application information of the user interface(s):
  Idx UI      Delay    Type Userlevel
  0   AUX 0   00:02:29      3
+ 1   VTY 0   00:00:00 TEL  3
  2   VTY 1   00:00:00 TEL  3
Following are more details.
VTY 0   :
VTY 1   :
 +    : Current operation user.
 F    : Current operation user work in async mode.
The output shows that two users have logged in to the device. The one with IP address 192.168.0.5 uses VTY 0, and the other with IP address 192.168.0.18 uses VTY 1.
Table 5 Output description
Idx
UI
Relative number of the user interface. For example, with VTY, the first column represents user interface type, and the second column represents the relative number of the user interface.
Delay
Time elapsed since the user's last input, in the format of hh:mm:ss.
User type, such as Telnet
Userlevel
User level: 0 for visit, 1 for monitor, 2 for system, and 3 for manage.
Current user
Location
IP address of the user
F
The current user works in asynchronous mode
display web users
display web users [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display web users command to display information about the web users.
# Display information about the web users.
<Sysname> display web users
UserID    Name       Language  Level      State    LinkCount LoginTime LastTime
ab890000  admin      Chinese   Management Enable      0      14:13:46  14:14:18
Table 6 Output description
UserID
Web user ID
Name
Web username
Language
Language used in web login
Level
Web user level
Web user status
LinkCount
Number of tasks running for the web user
LoginTime
Login time
LastTime
Last time when the web user accessed the device
escape-key
escape-key { default | character }
undo escape-key
View
User interface view
Default level
3: Manage level
character: Specifies the shortcut key for terminating a task, a single character (or its corresponding ASCII code value in the range 0 to 127) or a string of 1 to 3 characters. Only the first character of a string functions as the shortcut key. For example, if you enter an ASCII code value of 113, the system uses its corresponding character q as the shortcut key. If you enter the string q@c, the system uses the first character q as the shortcut key.
default: Restores the default escape key combination of Ctrl+C.
Use the escape-key command to define a shortcut key for terminating a task.
Use the undo escape-key command to disable the shortcut key for terminating tasks.
By default, a task is terminated by pressing Ctrl+C.
After you define a new shortcut key by using the escape-key command, the new shortcut key is used to terminate a task. To display the shortcut key you have defined, use the display current-configuration command.
If you set the character argument in a user interface of a device, when you use the user interface to log in to the device and then telnet to another device, the character argument can be used as a control character to terminate a task rather than used as a common character. For example, if you specify character e in VTY 0 user interface of Device A, when you log in to Device A by using VTY 0 from a PC (Hyper Terminal), you can input e as a common character on the PC, and you can also use e to terminate the task running on Device A. If you telnet to Device B from Device A, you can only use e to terminate the task running on Device B, rather than use e as a common character, so specify character as a key combination.
# Define key a as the shortcut key for terminating a task.
[Sysname-ui-aux0] escape-key a
# Ping the IP address of 192.168.1.49 and use the -c keyword to specify the number of ICMP echo packets to be sent as 20.
<Sysname> ping -c 20 192.168.1.49
  PING 192.168.1.49: 56  data bytes, press a to break
    Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
    Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
# Enter a. The task terminates immediately and the system returns to system view.
  --- 192.168.1.49 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
<Sysname>
free user-interface
free user-interface [ aux | vty ] first-number [ last-number ]
View
Default level
3: Manage level
Use the free user-interface command to release the connection(s) established on the specified user interface.
This command cannot release the connection that you are using.
# Display the connection established on user interface VTY 1.
·           Display the users that are operating the device.
  2   VTY 1   00:07:22 TEL  3
  3   VTY 2   00:03:00 TEL  3
VTY 0   :
VTY 1   :
VTY 2   :
·           If the operations of the user using VTY 1 affect the operations of the administrator, log out the user.
<Sysname> free user-interface vty 1
Are you sure to free user-interface vty1? [Y/N]:y
free web-users
free web-users { all | user-id user-id | user-name user-name }
View
Default level
2: System level
all: Specifies all web users.
user-id: Web user ID, which is a hexadecimal number of eight digits.
user-name: Web user name, which is a string of 1 to 80 characters.
Use the free web-users command to log out web users.
Related commands: display web users.
# Log out all web users.
<Sysname> free web-users all
history-command max-size
history-command max-size size-value
undo history-command max-size
View
User interface view
Default level
2: System level
size-value: Specifies the maximum number of history commands that the buffer can store. The value ranges from 0 to 256.
Use the history-command max-size command to set the size of the history command buffer of the current user interface.
Use the undo history-command max-size command to restore the default.
By default, the buffer saves 10 history commands.
The history command buffer saves executed history commands per user interface and buffers for different user interfaces do not affect each other. To display the commands that are stored in the history buffer, use the display history-command command. To view the recently executed commands, press the upper arrow or lower arrow key. For more information about the display history-command command, see the Fundamentals Command Reference.
After you terminate the current session, the system automatically removes the commands saved in the corresponding history buffer.
# Set the buffer to store 20 history commands at most.
[Sysname-ui-aux0] history-command max-size 20
idle-timeout
undo idle-timeout
View
User interface view
Default level
2: System level
minutes: Specifies the timeout time in minutes, which ranges from 0 to 35791, and defaults to 10 minutes.
seconds: Specifies timeout time in seconds, which ranges from 0 to 59, and defaults to 0 seconds.
Use the idle-timeout command to set the idle-timeout timer.
Use the undo idle-timeout command to restore the default.
The default idle-timeout is 10 minutes.
·       The system automatically terminates the user’s connection(s) if there is no information interaction between the device and the users within the idle timeout time.
·       Setting idle-timeout to zero disables the timer. In this case, connections are maintained unless you terminate them.
# Set the idle-timeout timer to 1 minute and 30 seconds.
[Sysname-ui-aux0] idle-timeout 1 30
ip http acl
ip http acl acl-number
undo ip http acl
View
Default level
2: System level
acl-number: ACL number, which ranges from 2000 to 2999.
Use the ip http acl command to associate the HTTP service with an ACL.
Use the undo ip http acl command to remove the association.
By default, the HTTP service is not associated with any ACL.
After the HTTP service is associated with an ACL, only the clients permitted by the ACL can access the device through HTTP.
Related commands: display ip http (in Logging in to the device commands in the Fundamentals Command Reference) and acl number in ACL configuration commands in the ACL and QoS Command Reference.
# Associate the HTTP service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network to access the device through HTTP.
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] ip http acl 2001
ip http enable
ip http enable
undo ip http enable
View
Default level
2: System level
None
Use the ip http enable command to enable the HTTP service.
Use the undo ip http enable command to disable the HTTP service.
The device can act as the HTTP server that can be accessed only after the HTTP service is enabled.
Related commands: display ip http.
# Enable the HTTP service.
[Sysname] ip http enable
# Disable the HTTP service.
[Sysname] undo ip http enable
ip http port
ip http port port-number
undo ip http port
View
Default level
3: Manage level
port-number: Port number of the HTTP service, which ranges from 1 to 65535.
Use the ip http port command to configure the port number of the HTTP service.
Use the undo ip http port command to restore the default.
By default, the port number of the HTTP service is 80.
Verify that the port number is not used by another service, because this command does not check for conflicts with configured port numbers.
# Configure the port number of the HTTP service as 8080.
[Sysname] ip http port 8080
ip https acl
ip https acl acl-number
undo ip https acl
View
Default level
3: Manage level
Use the ip https acl command to associate the HTTPS service with an ACL.
Use the undo ip https acl command to remove the association.
By default, the HTTPS service is not associated with any ACL.
After the HTTPS service is associated with an ACL, only the clients permitted by the ACL can access the device.
Related commands: display ip https (in Logging in to the device commands in the Fundamentals Command Reference) and acl number (in ACL configuration commands in the ACL and QoS Command Reference).
# Associate the HTTPS service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server through HTTP.
[Sysname] ip https acl 2001
ip https certificate access-control-policy
undo ip https certificate access-control-policy
View
Default level
3: Manage level
policy-name: Name of the certificate attribute access control policy, a string of 1 to 16 characters.
Use the ip https certificate access-control-policy command to associate the HTTPS service with a certificate attribute access control policy.
Use the undo ip https certificate access-control-policy command to remove the association.
By default, the HTTPS service is not associated with any certificate attribute access control policy.
Association of the HTTPS service with a certificate attribute access control policy can control the access rights of clients.
Related commands: display ip https (in Logging in to the device commands in the Fundamentals Command Reference) and pki certificate access-control-policy (in PKI configuration commands in the Security Command Reference).
# Associate the HTTPS server to certificate attribute access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
ip https enable
ip https enable
undo ip https enable
View
Default level
3: Manage level
None
Use the ip https enable command to enable the HTTPS service.
Use the undo ip https enable command to disable the HTTPS service.
By default, the HTTPS service is disabled.
Enabling the HTTPS service triggers an SSL handshake negotiation process.
·           If the local certificate of the device exists, the SSL negotiation succeeds, and the HTTPS service can be started.
·           If no local certificate exists, the SSL negotiation triggers a certificate application process that often fails because it times out. If that happens, execute the ip https enable command multiple times to start the HTTPS service.
Related commands: display ip https.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
ip https port port-number
undo ip https port
View
Default level
3: Manage level
port-number: Port number of the HTTPS service, which ranges from 1 to 65535.
Use the ip https port command to configure the port number of the HTTPS service.
Use the undo ip https port command to restore the default.
By default, the port number of the HTTPS service is 443.
# Configure the port number of the HTTPS service as 6000.
[Sysname] ip https port 6000
ip https ssl-server-policy
undo ip https ssl-server-policy
View
Default level
3: Manage level
policy-name: Name of an SSL server policy, which is a string of 1 to 16 characters.
Use the ip https ssl-server-policy command to associate the HTTPS service with an SSL server-end policy.
Use the undo ip https ssl-server-policy to remove the association.
By default, the HTTPS service is not associated with any SSL server-end policy.
The HTTPS service can be enabled only after this command is configured successfully.
With the HTTPS service enabled, you cannot modify the associated SSL server-end policy or remove the association between the HTTPS service and the SSL server-end policy after the HTTPS service is enabled.
Related commands: display ip https (in Logging in to the device commands in the Fundamentals Command Reference) and ssl server-policy (in SSL configuration commands in the Security Command Reference).
# Associate the HTTPS service with SSL server-end policy myssl.
[Sysname] ip https ssl-server-policy myssl
lock
lock
View
Default level
3: Manage level
None
Use the lock command to lock the user interface. This method prevents unauthorized users from using the user interface.
When entering the lock command, you are asked to input a password (up to 16 characters) and then confirm it by inputting the password again. After locking the user interface, you must press Enter and input the correct password next time you enter this user interface.
By default, this function is disabled.
# Lock the current user interface.
<Sysname> lock
Please input password<1 to 16> to lock current user terminal interface:
Password:
Again:
                   locked !
Password:
<Sysname>
parity
undo parity
View
User interface view
Default level
2: System level
even: Performs an even parity check.
mark: Performs a mark parity check.
none: Performs no parity check.
odd: Performs an odd parity check.
space: Performs a space parity check.
Use the parity command to set a parity check method.
Use the undo parity command to restore the default.
By default, no parity check is performed.
The wireless switch supports only even, none, and odd parity check methods. You must make the corresponding configuration of the terminal running on the PC the same as the configuration on the switch.
# Configure the AUX port to perform odd parity check.
[Sysname-ui-aux0] parity odd
protocol inbound
undo protocol inbound
View
VTY interface view
Default level
3: Manage level
all: Supports both protocols: Telnet and SSH.
ssh: Supports SSH only.
telnet: Supports Telnet only.
Use the protocol inbound command to enable the current user interface to support either Telnet, SSH, or both. The configuration takes effect next time you log in.
Use the undo protocol inbound command to restore the default.
By default, all the three protocols are supported.
·       Before configuring a user interface to support SSH, set the authentication mode to scheme for the user interface; otherwise, the protocol inbound ssh command fails. For more information, see authentication-mode.
·       By default, the authentication mode of the Telnet protocol is password.
# Enable the VTYs 0 through 4 to support SSH only.
[Sysname-ui-vty0-4] authentication-mode scheme
[Sysname-ui-vty0-4] protocol inbound ssh
screen-length
screen-length screen-length
undo screen-length
View
User interface view
Default level
2: System level
screen-length: Number of lines to be displayed on a screen, which ranges from 0 to 512. The value of 0 disables pausing between screens of output.
Use the screen-length command to set the number of lines to be displayed on a screen.
Use the undo screen-length command to restore the default.
By default, a screen displays 24 lines.
When screen output pauses, press the Space key to display the next screen. Not all terminals support this command setting. For example, assume that you set screen-length to 40, but the terminal can display 24 lines in one screen at most. When you press Space, the device sends 40 lines to the terminal, but the next screen displays only lines 18 through 40. To view the first 17 lines, you must press the page up or page down key.
To disable multiple-screen output of the current user interface, use the screen-length disable command. For more information about the screen-length disable command, see the chapter “CLI commands.”
# Set the next screen of the user interface of AUX port 0 to display 30 lines.
[Sysname-ui-aux0] screen-length 30
send
send { all | [ aux | vty ] first-number [ last-number ] }
View
Default level
1: Monitor level
all: Sends messages to all user interfaces.
Use the send command to send messages to the specified user interfaces.
To end message input, press Ctrl+Z. To cancel message input and return to user view, press Ctrl+C.
# Send message hello abc to the user interface of AUX 0.
<Sysname> send aux 0
Enter message, end with CTRL+Z or Enter; abort with CTRL+C:
hello abc^Z
Send message? [Y/N]:y
<Sysname>
***Message from aux0 to aux0
hello abc
<Sysname>
set authentication password { cipher | simple } password
undo set authentication password
View
User interface view
Default level
3: Manage level
cipher: Cipher text password.
simple: Plain text password.
password: A case sensitive string. If the password format is simple, the password argument must be in plain text, and the configuration file saves the password in plain text. If the format is cipher, password can be either in cipher text or in plain text, and the configuration file always saves the password in cipher text. A plain text password can be a string of no more than 16 characters, 1234567 for example. A cipher text password or the encrypted version of the plain text password comprises 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the set authentication password command to set an authentication password.
Use the undo set authentication password command to remove the local authentication password.
By default, no local authentication password is set.
No matter whether the password format is plain text or cipher text, you must type the password in plain text during authentication.
A plain text password easily gets cracked. Therefore, a cipher text password is recommended.
Related commands: authentication-mode.
# Set the local authentication password for the user interface of AUX 0 to hello.
[Sysname-ui-aux0] authentication-mode password
[Sysname-ui-aux0] set authentication password cipher hello
Next time you enter the system, the password is required.
shell
shell
undo shell
View
User interface view
Default level
3: Manage level
None
Use the shell command to enable terminal services on the current user interface.
Use the undo shell command to disable terminal services on the current user interface.
·           The AUX user interface does not support the undo shell command.
·           You cannot disable the terminal services on the user interface through which you are logged in.
By default, terminal services are enabled on all user interfaces.
# Disable terminal services on VTYs 0 through 4, which means you cannot log in to the device through VTYs 0 through 4.
[Sysname-ui-vty0-4] undo shell
% Disable ui-vty0-4 , are you sure? [Y/N]:y
[Sysname-ui-vty0-4]
The following message appears when a terminal tries to telnet to the device:
The connection was closed by the remote host!
speed (user interface view)
speed speed-value
undo speed
View
User interface view
Default level
2: System level
speed-value: Transmission rate in bps.
The transmission rates available with asynchronous serial interfaces include:
·           300 bps
·           600 bps
·           1200 bps
·           2400 bps
·           4800 bps
·           9600 bps
·           19200 bps
·           38400 bps
·           57600 bps
·           115200 bps
The transmission rate varies with devices and configuration environment.
Use the speed command to set the transmission rate on the user interface.
Use the undo speed command to restore the default transmission rate.
By default, the transmission rate is 9600 bps.
·       The command is only applicable to AUX port.
·       The transmission rate setting must be identical for the user interfaces of the connecting ports on the device and the target terminal device for communication.
# Set the transmission rate on the user interface AUX 0 to 19200 bps.
[Sysname-ui-aux0] speed 19200
stopbits
stopbits { 1 | 1.5 | 2 }
undo stopbits
View
User interface view
Default level
2: System level
1: One stop bit.
1.5: One and a half stop bits.
2: Two stop bits.
Use the stopbits command to set the number of stop bits transmitted per byte.
Use the undo stopbits command to restore the default.
By default, the stop bit is one.
Related commands: stopbit-error intolerance.
·       The stop bits setting must be the identical for the user interfaces of the connecting ports on the device and the target device for communication.
# Set the stop bits on the user interface AUX 0 to 1.5.
[Sysname-ui-aux0] stopbits 1.5
telnet
telnet remote-host [ service-port ] [ source { interface interface-type interface-number | ip ip-address } ]
View
Default level
0: Visit level
remote-host: IPv4 address or host name of a remote host, which is a case insensitive string of 1 to 20 characters.
service-port: TCP port number of the Telnet service on the remote host. It ranges from 0 to 65535 and defaults to 23.
source: Specifies the source interface or source IPv4 address of Telnet packets.
interface interface-type interface-number: Specifies the source interface. The source IPv4 address of the Telnet packets sent is the IPv4 address of the specified interface. interface-type interface-number represents the interface type and number.
ip ip-address: Specifies the source IPv4 address of Telnet packets.
Use the telnet command to telnet to a remote host.
To terminate the current Telnet connection, press Ctrl+K or use the quit command.
The source IPv4 address or source interface specified by this command is applicable to the current Telnet connection only.
# Telnet to the remote host 1.1.1.2, specifying the source IP address of Telnet packets as 1.1.1.1.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
telnet client source
undo telnet client source
View
Default level
2: System level
Use the telnet client source command to specify the source IPv4 address or source interface for sending telnet packets when the device serves as a telnet client.
Use the undo telnet client source command to remove the source IPv4 address or source interface for sending telnet packets.
By default, no source IPv4 address or source interface for sending telnet packets is specified. The source IPv4 address is selected by routing.
The source IPv4 address or source interface specified by this command is applicable all Telnet connections.
If you use both this command and the telnet command to specify the source IPv4 address or source interface, the source IPv4 address or interface specified by the telnet command takes effect.
Related commands: display telnet client configuration.
# Specify the source IPv4 address for sending telnet packets when the device serves as a telnet client as 1.1.1.1.
[Sysname] telnet client source ip 1.1.1.1
telnet ipv6
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ]
View
Default level
0: Visit level
remote-host: IP address or host name of a remote host, which is a case insensitive string of 1 to 46 characters.
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets, where interface-type interface-number represents the interface type and number. If the destination address is a link-local address, provide the –i interface-type interface-number argument.
port-number: TCP port number for the remote host to provide the Telnet service. It ranges from 0 to 65535 and defaults to 23.
Use the telnet ipv6 command to telnet to a remote host in an IPv6 network. To terminate the current Telnet connection, press Ctrl+K or use the quit command.
# Telnet to the remote host with the IPv6 address 5000::1.
<Sysname> telnet ipv6 5000::1
telnet server enable
undo telnet server enable
View
Default level
3: Manage level
None
Use the telnet server enable command to enable the Telnet server.
Use the undo telnet server enable command to disable the Telnet server.
The Telnet server is enabled by default.
# Enable the Telnet server.
terminal type
undo terminal type
View
User interface view
Default level
2: System level
ansi: Specifies the terminal display type as ANSI.
vt100: Specifies the terminal display type as VT100.
Use the terminal type command to configure the type of terminal display of the current user interface.
Use the undo terminal type command to restore the default.
By default, the terminal display type is ANSI.
The device supports two types of terminal display: ANSI and VT100. H3C recommends you to set the display type of both the device and the client to VT100. If the device and the client use different display types (for example, hyper terminal or Telnet terminal) or both are set to ANSI, when the total number of characters of the currently edited command line exceeds 80, an anomaly such as cursor corruption or abnormal display of the terminal display may occur on the client.
# Set the terminal display type to VT100.
[Sysname-ui-vty0] terminal type vt100
user privilege level level
undo user privilege level
View
User interface view
Default level
3: Manage level
level: Specifies a user privilege level, which ranges from 0 to 3.
User privilege levels include visit, monitor, system, and manage, represented by the number 0, 1, 2 and 3 respectively. The administrator can change the user privilege level when necessary.
Use the user privilege level command to configure the user privilege level. Users logging into the user interface are assigned a user privilege level.
Use the undo user privilege level command to restore the default.
By default, the default command level is 3 for the AUX user interface and 0 for other user interfaces.
# Set the command level for users logging in through VTY 0 to 0.
[Sysname-ui-vty0] user privilege level 0
After you telnet to the device through VTY 0, the terminal only displays commands of level 0 in the help information:
<Sysname> ?
User view commands:
  cluster  Run cluster command
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  rsh      Establish one RSH connection
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
user-interface
View
Default level
2: System level
Use the user-interface command to enter a single or multiple user interface views.
In a single user interface view, the configuration takes effect in the user view only.
In multiple user interface views, the configuration takes effect in these user views.
# Enter the AUX user interface view.
[Sysname-ui-aux0]
# Enter the user interface views of VTYs 0 to 4.
[Sysname-ui-vty0-4]
