01-Fundamentals Command Reference
HomeSupportSwitchesS6300 SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10001-Fundamentals Command Reference
00-Preface
00-Preface 84.69 KB
Preface
This command reference describes the commands that help you get started with the switch, including:
·     CLI.
·     RBAC, switch login, and switch access control.
·     Management of the switch, file system, configuration files, and licenses.
·     FTP and TFTP.
·     Tcl and Python.
·     ISSU and common software upgrade.
·     Audience
·     Conventions
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the S6300 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
To access the most up-to-date H3C product documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
We appreciate your comments.
