09-User Isolation Commands
| 09-User Isolation Commands | 41.42 KB |
wlan-client-isolation enable
Use wlan-client-isolation enable to enable WLAN client isolation.
Use undowlan-client-isolation enable to disable WLAN client isolation.
undo wlan-client-isolation enable
WLAN client isolation is enabled.
Default command level
2: System level
# Disable WLAN client isolation.
[Sysname] undo wlan-client-isolation enable
