| 01-AAA Commands | 440.60 KB |
General AAA configuration commands
session-time include-idle-time
Local user configuration commands
data-flow-format (RADIUS scheme view)
display stop-accounting-buffer (for RADIUS)
primary accounting (RADIUS scheme view)
primary authentication (RADIUS scheme view)
reset stop-accounting-buffer (for RADIUS)
retry stop-accounting (RADIUS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
timer quiet (RADIUS scheme view)
timer response-timeout (RADIUS scheme view)
user-name-format (RADIUS scheme view)
HWTACACS configuration commands
data-flow-format (HWTACACS scheme view)
display stop-accounting-buffer (for HWTACACS)
primary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
secondary accounting (HWTACACS scheme view)
secondary authentication (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
timer quiet (HWTACACS scheme view)
timer response-timeout (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
access-limit enable
Use access-limit enable to set the maximum number of online users in an ISP domain. After the number of online users reaches the allowed maximum number, no more users are accepted.
Use undo access-limit enable to restore the default.
access-limit enable max-user-number
There is no limit to the number of online users in an ISP domain.
ISP domain view
Default command level
2: System level
max-user-number: Maximum number of online users that the ISP domain can accommodate. The value range for this argument is 1 to 2147483646.
System resources are limited, and user connections may compete for network resources when there are many users. Setting a proper limit to the number of online users helps provide reliable system performance.
# Set a limit of 500 user connections for ISP domain test.
[Sysname] domain test
[Sysname-isp-test] access-limit enable 500
display domain
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting method for the ISP domain is used for command line accounting.
ISP domain view
2: System level
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The specified HWTACACS scheme must have been configured.
Command line accounting can use only an HWTACACS scheme.
# In the ISP domain test, perform command line accounting based on the HWTACACS scheme hwtac.
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
· accounting default
· hwtacacs scheme
accounting default
Use accounting default to configure the default accounting method for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default accounting method of an ISP domain is local.
ISP domain view
2: System level
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The specified RADIUS or HWTACACS scheme must have been configured.
The default accounting method is used for all users who support the specified accounting method and have no specific accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
# Configure the default accounting method for ISP domain test to use RADIUS accounting scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting lan-access
Use accounting lan-access to configure the accounting method for LAN users.
Use undo accounting lan-access to restore the default.
accounting lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
The default accounting method for the ISP domain is used for LAN users.
ISP domain view
2: System level
The specified RADIUS scheme must have been configured.
# In the ISP domain test, perform local accounting for LAN users.
[Sysname-isp-test] accounting lan-access local
# In the ISP domain test, perform RADIUS accounting for LAN users based on the scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access radius-scheme rd local
· local-user
· radius scheme
accounting login
Use accounting login to configure the accounting method for login users through the console port or through Telnet.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default accounting method for the ISP domain is used for login users.
ISP domain view
2: System level
Accounting is not supported for login users who use FTP.
# In the ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In the ISP domain test, perform RADIUS accounting for login users based on the scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting optional
Use accounting optional to enable the accounting optional feature.
Use undo accounting optional to disable the feature.
accounting optional
The feature is disabled.
ISP domain view
2: System level
After you configure the accounting optional command for a domain, a user who would otherwise be disconnected can continue to use the network resources when no accounting server is available or when communication with the current accounting server fails. However, the device no longer sends real-time accounting updates for the user. The accounting optional feature applies to scenarios where accounting is not important.
After you configure the accounting optional command, the setting configured by the access-limit command in local user view has no effect.
# Enable the accounting optional feature for users in the domain test.
[Sysname-isp-test] accounting optional
accounting portal
Use accounting portal to configure the accounting method for portal users.
Use undo accounting portal to restore the default.
accounting portal { local | none | radius-scheme radius-scheme-name [ local ] }
The default accounting method for the ISP domain is used for portal users.
ISP domain view
2: System level
# In the ISP domain test, perform local accounting for portal users.
[Sysname-isp-test] accounting portal local
# In the ISP domain test, perform RADIUS accounting for portal users based on the scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting portal radius-scheme rd local
· local-user
· radius scheme
accounting ppp
Use accounting ppp to configure the accounting method for PPP users.
Use undo accounting ppp to restore the default.
accounting ppp { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting ppp
The default accounting method for the ISP domain is used for PPP users.
ISP domain view
2: System level
# In the ISP domain test, perform local accounting for PPP users.
[Sysname-isp-test] accounting ppp local
# In the ISP domain test, perform RADIUS accounting for PPP users based on the scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ppp radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authentication default
Use authentication default to configure the default authentication method for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authentication method of an ISP domain is local.
ISP domain view
2: System level
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users who support the specified authentication method and have no specific authentication method configured.
# Configure the default authentication method for ISP domain test to use RADIUS authentication scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authentication lan-access
Use authentication lan-access to configure the authentication method for LAN users.
Use undo authentication lan-access to restore the default.
authentication lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
The default authentication method for the ISP domain is used for LAN users.
ISP domain view
2: System level
# In the ISP domain test, perform local authentication for LAN users.
[Sysname-isp-test] authentication lan-access local
# In the ISP domain test, perform RADIUS authentication for LAN users based on the scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication lan-access radius-scheme rd local
· authentication default
· local-user
· radius scheme
authentication login
Use authentication login to configure the authentication method for login users through the console port, Telnet, or FTP.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authentication method for the ISP domain is used for login users.
ISP domain view
2: System level
# In the ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In the ISP domain test, perform RADIUS authentication for login users based on the scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authentication portal
Use authentication portal to configure the authentication method for portal users.
Use undo authentication portal to restore the default.
authentication portal { local | none | radius-scheme radius-scheme-name [ local ] }
The default authentication method for the ISP domain is used for portal users.
ISP domain view
2: System level
# In the ISP domain test, perform local authentication for portal users.
[Sysname-isp-test] authentication portal local
# In the ISP domain test, perform RADIUS authentication for portal users based on the scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication portal radius-scheme rd local
· local-user
· radius scheme
authentication ppp
Use authentication ppp to configure the authentication method for PPP users.
Use undo authentication ppp to restore the default.
authentication ppp { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authentication method for the ISP domain is used for PPP users.
ISP domain view
2: System level
# In the ISP domain test, perform local authentication for PPP users.
[Sysname-isp-test] authentication ppp local
# In the ISP domain test, perform RADIUS authentication for PPP users based on the scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ppp radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authentication super
Use authentication super to configure the authentication method for user privilege level switching.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name }
The default authentication method for the ISP domain is used for user privilege level switching authentication.
ISP domain view
2: System level
The specified RADIUS or HWTACACS authentication scheme must have been configured.
# In the ISP domain test, perform user privilege level switching authentication based on the HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-domain-test] authentication super hwtacacs-scheme tac
· hwtacacs scheme
· radius scheme
· super authentication-mode (Fundamentals Command Reference)
authorization command
Use authorization command to configure the command line authorization method.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local | none ] | local | none }
The default authorization method for the ISP domain is used for command line authorization.
ISP domain view
2: System level
local: Performs local authorization.
none: Does not perform authorization. In this case, an authenticated user can access only commands of Level 0.
With command line authorization configured, a user who has logged in to the device can execute only the commands with a level lower than or equal to that of the local user.
# In the ISP domain test, configure the device to perform local command line authorization.
[Sysname-isp-test] authorization command local
# In the ISP domain test, perform command line authorization based on the HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
· authorization default
· hwtacacs scheme
· local-user
Use authorization default to configure the default authorization method for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authorization method for the ISP domain of an ISP domain is local.
ISP domain view
2: System level
none: Does not perform authorization. After passing authentication, non-login users can access the network, FTP users can access the root directory of the device, and other login users can access only the commands of Level 0.
The default authorization method is used for all users who support the specified authorization method and have no specific authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
# Configure the default authorization method for ISP domain test to use RADIUS authorization scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization lan-access
Use authorization lan-access to configure the authorization method for LAN users.
Use undo authorization lan-access to restore the default.
authorization lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
The default authorization method for the ISP domain is used for LAN users.
ISP domain view
2: System level
none: Does not perform authorization. In this case, an authenticated LAN user can access the network directly.
# In the ISP domain test, perform local authorization for LAN users.
[Sysname-isp-test] authorization lan-access local
# In the ISP domain test, perform RADIUS authorization for LAN users based on the scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization lan-access radius-scheme rd local
· local-user
· radius scheme
authorization login
Use authorization login to configure the authorization method for login users through the console port, Telnet, or FTP.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authorization method for the ISP domain is used for login users.
ISP domain view
2: System level
none: Does not perform authorization. After passing authentication, FTP users can access the root directory of the device, and other login users can access only the commands of Level 0.
# In the ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In the ISP domain test, perform RADIUS authorization for login users based on the scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization portal
Use authorization portal to configure the authorization method for portal users.
Use undo authorization portal to restore the default.
authorization portal { local | none | radius-scheme radius-scheme-name [ local ] }
The default authorization method for the ISP domain is used for portal users.
ISP domain view
2: System level
none: Does not perform authorization. In this case, an authenticated portal user can access the network directly.
# In the ISP domain test, perform local authorization for portal users.
[Sysname-isp-test] authorization portal local
# In the ISP domain test, perform RADIUS authorization for portal users based on the scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization portal radius-scheme rd local
· local-user
· radius scheme
authorization ppp
Use authorization ppp to configure the authorization method for PPP users.
Use undo authorization ppp to restore the default.
authorization ppp { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
The default authorization method for the ISP domain is used for PPP users.
ISP domain view
2: System level
none: Does not perform authorization. In this case, an authenticated PPP user can access the network directly.
# In the ISP domain test, perform local authorization for PPP users.
[Sysname-isp-test] authorization ppp local
# In the ISP domain test, perform RADIUS authorization for PPP users based on the scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ppp radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
cut connection
Use cut connection to tear down the specified user connections forcibly.
cut connection { access-type { dot1x | mac-authentication | portal } | all | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id }
2: System level
access-type: Specifies the user connections of the specified access type.
· dot1x: Indicates 802.1X authentication.
· mac-authentication: Indicates MAC address authentication.
· portal: Indicates portal authentication.
all: Specifies all user connections.
domain isp-name: Specifies the user connections of an ISP domain. The isp-name argument represents the name of an existing ISP domain and is a string of 1 to 24 characters.
interface interface-type interface-number: Specifies the user connections on an interface. Only Layer 2 Ethernet interfaces and WLAN virtual interfaces are supported.
ip ip-address: Specifies the user connections for an IP address.
mac mac-address: Specifies the user connections for a MAC address, with mac-address in the format H-H-H.
ucibindex ucib-index: Specifies the user connection that uses the connection index. The value range for the ucib-index argument is 0 to 4294967295.
user-name user-name: Specifies the user connections that use the username. The user-name argument is a case-sensitive string of 1 to 80 characters. For a username entered without a domain name, the system assumes that the user is in the default domain or the mandatory authentication domain.
vlan vlan-id: Specifies the user connections of a VLAN, where vlan-id ranges from 1 to 4094.
This command applies to LAN, portal, and PPP user connections.
For 802.1X users whose usernames carry the version number or contain spaces, you cannot cut the connections by username.
For 802.1X users whose usernames use a slash (/) or backslash (\) as the domain name delimiter, you cannot cut their connections by username. For example, the cut connection user-name aaa\bbb command cannot cut the connections of the user aaa\bbb.
An interface that is configured with a mandatory authentication domain treats users of the corresponding access type as users in the mandatory authentication domain. For example, if you configure an 802.1X mandatory authentication domain on an interface, the interface uses the domain's AAA methods for all its 802.1X users. To cut connections of such users, use the cut connection domain isp-name command, and specify the mandatory authentication domain.
# Tear down all connections of ISP domain test.
[Sysname] cut connection domain test
· display connection
· service-type
display connection
Use display connection to display information about AAA user connections.
display connection [ access-type { dot1x | mac-authentication I portal } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
domain isp-name: Specifies the user connections of an ISP domain. The isp-name argument represents the name of an existing ISP domain and is a case-insensitive string of 1 to 24 characters.
ip ip-address: Specifies the user connections of an IP address.
mac mac-address: Specifies the user connections of a MAC address, with mac-address in the format H-H-H.
user-name user-name: Specifies the user connections that use the username. The user-name argument is a case-sensitive string of 1 to 80 characters. For a username entered without a domain name, the system assumes that the user is in the default domain name or the mandatory authentication domain.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
This command does not display information about FTP user connections.
With no parameter specified, this command displays brief information about all AAA user connections.
If you specify the ucibindex ucib-index option, this command displays detailed information. Otherwise, this command displays brief information.
If an interface is configured with a mandatory authentication domain (for example, an 802.1X mandatory authentication domain), the device uses the mandatory authentication domain to perform authentication, authorization, and accounting for users who access the interface through the specified access type. To display connections of such users, use the display connection domain isp-name command and specify the mandatory authentication domain.
How the device displays the username of a user on an interface configured with a mandatory authentication domain depends on the format of the username entered by the user at login:
· If the username does not contain the at sign (@), the device displays the username in the format username@mandatory authentication domain name.
· If the username contains the at sign (@), the device displays the entered username. For example, if a user entered the username aaa@123 at login and the name of the mandatory authentication domain is dom, the device displays the username aaa@123, rather than aaa@123@dom.
For 802.1X users whose usernames use a slash (/) or backslash (\) as the domain name delimiter, you cannot query the connections by username. For example, the display connection user-name aaa\bbb command cannot display the connections of the user aaa\bbb.
# Display information about all AAA user connections.
<Sysname> display connection
Index=0 ,Username=telnet@system
IP=10.0.0.1
IPv6=N/A
Total 1 connection(s) matched.
# Display information about AAA user connections using the index of 0.
<Sysname> display connection ucibindex 0
Index=0 , Username=telnet@system
IP=10.0.0.1
IPv6=N/A
Access=Admin ,AuthMethod=PAP
Port Type=Virtual ,Port Name=N/A
Initial VLAN=999, Authorized VLAN=20
ACL Group=Disable
User Profile=N/A
CAR=Disable
Priority=Disable
SessionTimeout=60(s), Terminate-Action=Radius-Request
Start=2009-07-16 10:53:03 ,Current=2009-07-16 10:57:06 ,Online=00h04m03s
Total 1 connection matched.
Username |
Username of the connection, in the format username@domain. |
MAC |
MAC address of the user. |
IP |
IPv4 address of the user. |
IPv6 |
IPv6 address of the user. |
Access |
User access type. |
ACL Group |
Authorization ACL group. When no authorization ACL group is assigned, this field displays Disable. |
User Profile |
Authorization user profile. The device does not support authorization user profiles in the current version. |
CAR(kbps) |
Authorized CAR parameters. |
UpPeakRate |
Uplink peak rate. |
DnPeakRate |
Downlink peak rate. |
UpAverageRate |
Uplink average rate. |
DnAverageRate |
Downlink average rate. |
SessionTimeout |
Session timeout value received from the server, in seconds. The value indicates: · The remaining online time of the user if Terminate-Action is Default. · The re-authentication interval for the user if Terminate-Action is Radius-Request. |
Terminate-Action |
Action to take when the session timeout expires. The action can be: · Default—Cuts off the user. · Radius-Request—Re-authenticates the user. |
cut connection
display domain
Use display domain to display the configuration of ISP domains.
display domain [ isp-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
isp-name: Name of an existing ISP domain, a string of 1 to 24 characters.
If you do not specify any ISP domain, the command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
0 Domain : system
State : Active
Access-limit : Disabled
Accounting method : Required
Default authentication scheme : local
Default authorization scheme : local
Default accounting scheme : local
Domain User Template:
Idle-cut : Disabled
Self-service : Disabled
Authorization attributes :
1 Domain : test
State : Active
Lan-access authentication scheme : radius:test, local
Lan-access authorization scheme : hwtacacs:hw, local
Lan-access accounting scheme : local
Idle-cut : Disabled
Session-time : exclude-idle-time
User-profile : profile1
Default Domain Name: system
Total 2 domain(s).
Domain |
ISP domain name. |
State |
Status of the ISP domain: active or blocked. Users in an active ISP domain can request network services, and users in a blocked ISP domain cannot. |
Access-limit |
Limit on the number of user connections. If there is no limit on the number, this field displays Disabled. |
Accounting method |
Indicates whether accounting is required. If accounting is required, when no accounting server is available or when communication with the accounting server fails, user connections are torn down. Otherwise, users can continue to use network services. |
Default authentication scheme |
Default authentication method. |
Default authorization scheme |
Default authorization method. |
Default accounting scheme |
Default accounting method. |
Lan-access authentication scheme |
Authentication method for LAN users. |
Lan-access authorization scheme |
Authorization method for LAN users. |
Lan-access accounting scheme |
Accounting method for LAN users. |
Domain User Template |
Indicates some functions and attributes set for users in the domain. |
Idle-cut |
Indicates whether the idle cut function is enabled. With the idle cut function enabled for a domain, the system logs out any user in the domain whose traffic is less than the specified minimum traffic during the idle timeout period. |
Session-time |
Indicates whether the idle cut time is included in the user online time to be uploaded to the server. Options include: · Exclude-idle-time—The idle cut time is excluded from the user online time. · Include-idle-time—The idle cut time is included in the user online time. |
Self-service |
Indicates whether the self-service function is enabled. With the self-service function enabled, users can launch a browser and enter the self-service URL in the address bar to access the self-service pages and perform self-service operations. |
Authorization attributes |
Default authorization attributes for the ISP domain. |
User-profile |
Default authorization user profile. The device does not support authorization user profiles in the current version. |
· access-limit enable
· domain
· state
domain
Use domain to create an ISP domain and enter ISP domain view.
Use undo domain to remove an ISP domain.
domain isp-name
undo domain isp-name
There is a system predefined ISP domain named system in the system.
3: Manage level
isp-name: Specifies an ISP domain name, a case-insensitive string of 1 to 24 characters that cannot contain the slash (/), backslash (\), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), quotation marks ("), vertical bar (|), or at sign (@).
All ISP domains are in active state when they are created.
The system predefined ISP domain system cannot be deleted, but you can modify its configuration.
To delete the ISP domain that is used as the default ISP domain, you must first change it to a non-default ISP domain by using the undo domain default enable command.
# Create ISP domain test, and enter ISP domain view.
[Sysname-isp-test]
· state
· display domain
Use domain default enable to specify the default ISP domain. Users without any domain name carried in the usernames are considered to be in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system predefined ISP domain system.
3: Manage level
isp-name: Name of the ISP domain, a case-insensitive string of 1 to 24 characters.
There can be only one default ISP domain.
The specified domain must already exist. Otherwise, users without a domain name in the username cannot pass authentication.
# Create a new ISP domain named test, and configure it as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
· domain
· state
· display domain
domain if-unknown
Use domain if-unknown to specify an ISP domain for users with unknown domain names.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified for users with unknown domain names.
3: Manage level
isp-name: Specifies an ISP domain name, a case-insensitive string of 1 to 24 characters that cannot contain the slash (/), backslash (\), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), quotation marks ("), or at sign (@).
The device chooses an authentication domain for each user in the following order:
· The authentication domain specified for the access module
· The ISP domain in the username
· The default ISP domain of the device
· The ISP domain specified for users with unknown domain names
If all the domains are unavailable, user authentication fails.
NOTE: Support for the authentication domain configuration depends on the access module. You can specify an authentication domain for 802.1X or MAC address authentication. |
# Specify the ISP domain test for users with unknown domain names.
[Sysname] domain if-unknown test
idle-cut enable
Use idle-cut enable to enable the idle cut function and set the relevant parameters.
Use undo idle-cut enable to restore the default.
idle-cut enable minute [ flow ]
The function is disabled.
ISP domain view
2: System level
minute: Idle timeout period, ranging from 1 to 129600 minutes.
flow: Minimum traffic during the idle timeout period in bytes. It ranges from 1 to 10240000 and defaults to 10240.
With the idle cut function enabled for a domain, the device checks the traffic of each online user in the domain at the idle timeout interval, and it logs out any user in the domain whose traffic during the idle timeout period is less than the specified minimum traffic.
You can also set the idle timeout period on the server to make the server log out users whose traffic during the idle timeout period is less than 10240 bytes. However, your setting on the server takes effect only when you disable the idle cut function on the device.
# Enable the idle cut function and set the idle timeout period to 50 minutes and the traffic threshold to 1024 bytes for ISP domain test.
[Sysname-isp-test] idle-cut enable 50 1024
domain
self-service-url enable
Use self-service-url enable to enable the self-service server location function and specify the URL of the self-service server.
Use undo self-service-url enable to restore the default.
self-service-url enable url-string
The self-service server location function is disabled.
ISP domain view
2: System level
url-string: URL of the self-service server, a string of 1 to 64 characters that starts with http:// and contains no question mark. This URL was specified by the RADIUS server administrator during RADIUS server installation.
With the self-service function, users can manage and control their accounts and passwords. Only the RADIUS server systems provided by IMC support the self-service function.
# For ISP domain test, enable the self-service server location function, and specify the URL of the self-service server for changing user password to http://10.153.89.94/selfservice.
[Sysname-isp-test] self-service-url enable http://10.153.89.94/selfservice
Use session-time include-idle-time to include the idle cut time in the user online time to be uploaded to the server.
Use undo session-time include-idle-time to restore the default.
The user online time uploaded to the server excludes the idle cut time.
ISP domain view
2: System level
The device uploads to the server the online user time when a user is logged off. However, the online user time of an abnormally logged-off user can contain an idle timeout interval when the idle cut function is enabled. You can configure the device to include or exclude the idle cut time before the device uploads the online user time to the server according to your accounting policy.
# Configure the device to include the idle cut time in the user online time uploaded to the server for ISP domain test.
[Sysname-isp-test] session-time include-idle-time
idle-cut enable
state (ISP domain view)
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block }
undo state
An ISP domain is in active state.
ISP domain view
2: System level
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services.
By blocking an ISP domain, you disable offline users of the domain from requesting network services. The online users are not affected.
# Place the ISP domain test to the blocked state.
[Sysname-isp-test] state block
access-limit
Use access-limit to limit the number of concurrent users of the same local user account.
Use undo access-limit to remove the limitation.
access-limit max-user-number
undo access-limit
There is no limit to the number of users who concurrently use the same local user account.
Local user view
3: Manage level
max-user-number: Maximum number of concurrent users of the same local user account, ranging from 1 to 1024.
This command takes effect only when local accounting is used for the user account.
This limit has no effect on FTP users because accounting is not available for FTP users.
# Limit the maximum number of concurrent users of local user account abc to 5.
[Sysname] local-user abc
[Sysname-luser-abc] access-limit 5
display local-user
authorization-attribute
Use authorization-attribute to configure authorization attributes for the local user or user group. After the local user or a local user of the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to remove authorization attributes and restore the defaults.
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minute | level level | user-role { guest | guest-manager | security-audit } | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | level | user-role | vlan | work-directory } *
No authorization attribute is configured for a local user or user group.
Local user view, user group view
3: Manage level
acl acl-number: Specifies the authorization ACL. The ACL number must range from 2000 to 5999. After passing authentication, a local user is authorized to access the network resources specified by this ACL.
callback-number callback-number: Specifies the authorized PPP callback number. The callback-number argument is a case-sensitive string of 1 to 64 characters. After a local user passes authentication, the device uses this number to call the user.
idle-cut minute: Sets the idle timeout period. With the idle cut function enabled, an online user whose idle period exceeds the specified idle timeout period is logged out. The minute argument indicates the idle timeout period, ranging from 1 to 129600 minutes.
level level: Specifies the user level, which can be 0 for visit level, 1 for monitor level, 2 for system level, and 3 for manage level. A smaller number means a lower level. This parameter determines the command level for login users whose user interfaces perform AAA authentication. By default, the user level is 0, and users can use only commands of level 0 after login.
user-role: Specifies the role for the local user. This keyword is available in only local user view. Users playing different roles can access different levels of commands. If you specify no role for a local user, the access right of the user after login depends on other authorization attributes. Supported roles include:
· guest: A guest user account is usually created through the Web interface.
· guest-manager: An authenticated guest manager can manage guest user accounts on Web pages.
· security-audit: An authenticated security log administrator can manage security log files. The commands that a security log administrator can use are described in the information center commands. For more information, see Network Management and Monitoring Command Reference.
vlan vlan-id: Specifies the authorized VLAN, where vlan-id ranges from 1 to 4094. After passing authentication, a local user can access the resources in this VLAN.
work-directory directory-name: Specifies the work directory, if the user or users use the FTP or SFTP service. The directory-name argument is a case-insensitive string of 1 to 135 characters. The directory must already exist. By default, an FTP or SFTP user can access the root directory of the device.
Every configurable authorization attribute has its definite application environments and purposes. Consider the service types of users when assigning authorization attributes.
Authorization attributes configured for a user group are effective for all local users in the group. You can group local users to improve configuration and management efficiency.
An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view. If an authorization attribute is configured in user group view but not in local user view, the setting in user group view takes effect.
If only one user is playing the role of security log administrator in the system, you cannot delete the user account or remove or change the user's role, unless you first configure another user as a security log administrator.
A local user can play only one role at a time. If you perform the role configuration repeatedly, only the last role configuration takes effect.
# Configure the authorized VLAN of local user abc as VLAN 2.
[Sysname-luser-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
bind-attribute
Use bind-attribute to configure binding attributes for a local user.
Use undo bind-attribute to remove binding attributes of a local user.
bind-attribute { call-number call-number [ : subcall-number ] | ip ip-address | location port slot-number subslot-number port-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number | ip | location | mac | vlan } *
No binding attribute is configured for a local user.
Local user view
3: Manage level
call-number call-number: Specifies a calling number for ISDN user authentication. The call-number argument is a string of 1 to 64 characters. This option applies only to PPP users.
subcall-number: Specifies the sub-calling number. The total length of the calling number and the sub-calling number cannot be more than 62 characters.
ip ip-address: Specifies the IP address of the user. This option applies to Telnet, SSH, FTP, and 802.1X users.
location port slot-number subslot-number port-number: Specifies the port to which the user is bound. The slot-number argument ranges from 0 to 255, the subslot-number argument ranges from 0 to 15, and the port-number argument ranges from 0 to 255. This option applies only to LAN users.
mac mac-address: Specifies the MAC address of the user in the format H-H-H. This option applies only to LAN users.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument ranges from 1 to 4094. This option applies only to LAN users.
Binding attributes are checked upon authentication of a local user. If the binding attributes of a local user do not match the configured ones, the user fails checking and authentication.
Binding attribute checking does not take the service types of users into account. A configured binding attribute is effective for all types of users. Configure binding attributes for different types of local users with caution. For example, an IP address binding applies only to 802.1X authentication that supports IP address upload. If the authentication method such as MAC authentication does not support IP address upload, do not configure an IP address binding for the authentication method. Otherwise, local authentication fails.
# Configure the bound IP of local user abc as 3.3.3.3.
[Sysname-luser-abc] bind-attribute ip 3.3.3.3
display local-user
Use display local-user to display configuration and statistics information about local users.
display local-user [ idle-cut { disable | enable } | service-type { ftp | lan-access | portal | ppp | ssh | telnet | terminal | web } | state { active | block } | user-name user-name | vlan vlan-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
idle-cut { disable | enable }: Specifies local users with the idle cut function disabled or enabled.
service-type: Specifies the local users who use a specified type of service.
· ftp: FTP users.
· lan-access: Users accessing the network through Ethernet, such as 802.1X users.
· portal: Portal users.
· ppp: PPP users.
· ssh: SSH users.
· telnet: Telnet users.
· terminal: Users logging in through the console port.
· web: Web users.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username. The username is a case-sensitive string of 1 to 55 characters, and it does not contain the domain name.
vlan vlan-id: Specifies all local users in a VLAN. The VLAN ID ranges from 1 to 4094.
If you do not specify any parameter, the command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
The contents of local user abc:
State: Active
ServiceType: lan-access
Access-limit: Enabled Current AccessNum: 0
Max AccessNum: 300
User-group: system
Bind attributes:
IP address: 1.2.3.4
Bind location: 0/4/1 (SLOT/SUBSLOT/PORT)
MAC address: 00-01-00-02-00-03
Vlan ID: 100
Authorization attributes:
Idle TimeOut: 10(min)
Work Directory: flash:/
User Privilege: 3
Acl ID: 2000
Vlan ID: 100
Expiration date: 12:12:12-2018/09/16
Total 1 local user(s) matched.
State |
Status of the local user: active or blocked. |
ServiceType |
Service types that the local user can use, including FTP, LAN access, portal, PPP, SSH, Telnet, terminal, and Web. |
Access-limit |
Whether or not to limit the number of concurrent connections of the username. |
Current AccessNum |
Number of connections that currently use the username. |
Max AccessNum |
Maximum number of concurrent connections of the username. |
Bind attributes |
Binding attributes of the local user. |
VLAN ID |
VLAN to which the user is bound. |
Calling Number |
Calling number bound for the ISDN user. |
Authorization attributes of the local user. |
Idle TimeOut |
Idle timeout period of the user, in minutes. |
Callback-number |
Authorized PPP callback number of the local user. |
Work Directory |
Directory that the FTP user can access. |
VLAN ID |
Authorized VLAN of the local user. |
Expiration date |
Expiration time of the local user. |
local-user
display user-group
Use display user-group to display the configuration of user groups.
display user-group [ group-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
group-name: Specifies a user group name, a case-insensitive string of 1 to 32 characters.
If you do not specify any user group name, the command displays the configuration of all user groups.
# Display the configuration of user group abc.
<Sysname> display user-group abc
The contents of user group abc:
Idle-cut: 120(min)
Work Directory: FLASH:
Level: 1
Acl Number: 2000
Vlan ID: 1
Callback-number: 1
Total 1 user group(s) matched.
Idle-cut |
Idle timeout interval, in minutes. |
Work Directory |
Directory that FTP/SFTP users in the group can access. |
Level |
Level of the local users in the group. |
ACL Number |
Authorization ACL for the local users in the group. |
VLAN ID |
Authorized VLAN for the local users in the group. |
Callback-number |
Authorized PPP callback number for the local users in the group. |
user-group
expiration-date
Use expiration-date to set the expiration time of a local user.
Use undo expiration-date to remove the configuration.
expiration-date time
A local user has no expiration time, and no time validity checking is performed.
Local user view
3: Manage level
time: Expiration time of the local user, in the format HH:MM:SS-MM/DD/YYYY, HH:MM:SS-YYYY/MM/DD, MM/DD/YYYY-HH:MM:SS, or YYYY/MM/DD-HH:MM:SS. HH:MM:SS indicates the time, where HH ranges from 0 to 23, and MM and SS range from 0 to 59. MM/DD/YYYY or YYYY/MM/DD indicates the date, where YYYY ranges from 2000 to 2035, MM ranges from 1 to 12, and the range of DD depends on the month. Except for the zeros in 00:00:00, leading zeros can be omitted. For example, 2:2:0-2008/2/2 equals 02:02:00-2008/02/02.
For temporary network access requirements, create a guest account, and specify a validity time and an expiration time for the account to control the validity of the account. When a user uses the guest account for local authentication and passes the authentication, the access device checks whether the current system time is between the validity time and the expiration time. If it is, the device permits the user to access the network. Otherwise, the device denies the access request of the user.
# Set the expiration time of user abc to 12:10:20 on May 31, 2008.
[Sysname-luser-abc] expiration-date 12:10:20-2008/05/31
validity-date
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to the system default user group system.
Local user view
3: Manage level
group-name: User group name, a case-insensitive string of 1 to 32 characters.
# Assign local user 111 to user group abc.
[Sysname] local-user 111
[Sysname-luser-111] group abc
group-attribute allow-guest
Use group-attribute allow-guest to set the guest attribute for a user group so that guest users created by a guest manager through the Web interface can join the group.
Use undo group-attribute allow-guest to restore the default.
The guest attribute is not set for a user group, and guest users created by a guest manager through the Web interface cannot join the group.
User group view
3: Manage level
The guest attribute is set for the system predefined user group system and you cannot remove the attribute for the user group.
# Set the guest attribute for user group test.
[Sysname] user-group test
[Sysname-ugroup-test] group-attribute allow-guest
local-user
Use local-user to add a local user and enter local user view.
Use undo local-user to remove the specified local users.
local-user user-name
undo local-user { user-name | all [ service-type { ftp | lan-access | portal | ppp | ssh | telnet | terminal | web } ] }
A local user named admin exists on the device.
3: Manage level
user-name: Name for the local user, a case-sensitive string of 1 to 55 characters that does not contain the domain name. It cannot contain any slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@), and cannot be a, al, or all.
all: Specifies all users.
service-type: Specifies the users of a type.
· ftp: FTP users.
· lan-access: Users accessing the network through an Ethernet, such as 802.1X users.
· ppp: PPP users.
· ssh: SSH users.
· web: Web users.
# Add a local user named user1.
[Sysname] local-user user1
[Sysname-luser-user1]
· display local-user
· service-type
password
Use password to configure a password for a local user.
Use undo password to delete the password of a local user.
password [ { hash simple | cipher | simple } password ]
undo password
Local user view
2: System level
hash simple: Specifies a plaintext password encrypted by the hash algorithm.
cipher: Specifies a ciphertext password.
simple: Specifies a plaintext password.
password: Specifies the password string. This argument is case sensitive.
· A plaintext password is a string of 1 to 63 characters.
· A hashed password is a string of 1 to 110 characters.
· A ciphertext password is a string of 1 to 117 characters.
If you do not specify the hash keyword, all passwords, including passwords configured in plain text, are saved and displayed in cipher text.
# Set the password to 123456 in plain text for the local user user1 without using the hash algorithm.
[Sysname-luser-user1] password simple 123456
display local-user
service-type
Use service-type to specify the service types that a user can use.
Use undo service-type to delete one or all service types configured for a user.
service-type { ftp | lan-access | { ssh | telnet | terminal } * | portal | ppp | web }
undo service-type { ftp | lan-access | { ssh | telnet | terminal } * | portal | ppp | web }
A user is authorized with no service.
Local user view
3: Manage level
ftp: Authorizes the user to use the FTP service. The user can use the root directory of the FTP server by default.
lan-access: Authorizes the user to use the LAN access service. The users are mainly Ethernet users such as 802.1X users.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service, allowing the user to log in from the console port.
portal: Authorizes the user to use the portal service.
ppp: Authorizes the user to use the PPP service.
web: Authorizes the user to use the Web service.
You can execute the service-type command repeatedly to specify multiple service types for a user.
# Authorize user user1 to use the Telnet service.
[Sysname-luser-user1] service-type telnet
state (local user view)
Use state to set the status of a local user.
undo state
A local user is in active state.
Local user view
2: System level
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
By blocking a user, you disable the user from requesting network services. No other users are affected.
# Place local user user1 to the blocked state.
[Sysname-luser-user1] state block
local-user
user-group
Use user-group to create a user group and enter its view.
Use undo user-group to remove a user group.
user-group group-name
undo user-group group-name
3: Manage level
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group. Configurable user attributes include authorization attributes.
A user group with one or more local users cannot be removed.
The system predefined user group system cannot be removed, but you can modify its configuration.
# Create a user group named abc, and enter its view.
display user-group
validity-date
Use validity-date to set the validity time of a local user.
Use undo validity-date to remove the configuration.
validity-date time
undo validity-date
A local user has no validity time and no time validity checking is performed.
Local user view
3: Manage level
time: Validity time of the local user, in the format HH:MM:SS-MM/DD/YYYY, HH:MM:SS-YYYY/MM/DD, MM/DD/YYYY-HH:MM:SS, or YYYY/MM/DD-HH:MM:SS. HH:MM:SS indicates the time, where HH ranges from 0 to 23, and MM and SS range from 0 to 59. MM/DD/YYYY or YYYY/MM/DD indicates the date, where YYYY ranges from 2000 to 2035, MM ranges from 1 to 12, and the range of DD depends on the month. Except for the zeros in 00:00:00, leading zeros can be omitted. For example, 2:2:0-2008/2/2 equals 02:02:00-2008/02/02.
# Set the validity time of user abc to 12:10:20 on April 30, 2008, and set the expiration time to 12:10:20 on May 31, 2008.
[Sysname-luser-abc] validity-date 12:10:20-2008/04/30
expiration-date
RADIUS configuration commands
accounting-on enable
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval seconds | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
2: System level
seconds: Time interval for retransmitting an accounting-on packet in seconds, ranging from 1 to 15. The default is 3 seconds.
send-times: Maximum number of accounting-on packet transmission attempts, ranging from 1 to 255. The default is 50.
The accounting-on feature enables the device, after rebooting, to automatically send an accounting-on message to the RADIUS accounting server indicated by the RADIUS scheme to stop accounting for and log out online users.
Parameters set with the accounting-on enable command take effect immediately.
After executing the accounting-on enable command, issue the save command to make sure that the command takes effect after the device reboots.
# Enable the accounting-on feature for RADIUS authentication scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
radius scheme
Use data-flow-format to set the traffic statistics unit for data flows or packets.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
The unit for data flows is byte and that for data packets is one-packet.
RADIUS scheme view
2: System level
data { byte | giga-byte | kilo-byte | mega-byte }: Specifies the unit for data flows, which can be byte, kilobyte, megabyte, or gigabyte.
packet { giga-packet | kilo-packet | mega-packet | one-packet }: Specifies the unit for data packets, which can be one-packet, kilo-packet, mega-packet, or giga-packet.
The unit for data flows and that for packets must be consistent with those on the RADIUS server. Otherwise, accounting cannot be performed correctly.
# Set the traffic statistics unit for data flows and that for packets to kilobytes and kilo-packets, respectively, in RADIUS scheme radius1.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius scheme
Use display radius scheme to display the configuration of RADIUS schemes.
display radius scheme [ radius-scheme-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
radius-scheme-name: RADIUS scheme name.
If you do not specify any RADIUS scheme, the command displays the configuration of all RADIUS schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
SchemeName : radius1
Index : 0 Type : extended
Primary Auth Server:
IP: 1.1.1.1 Port: 1812 State: active
Encryption Key : ******
Probe username : test
Probe interval : 60 min
Primary Acct Server:
IP: 1.1.1.1 Port: 1813 State: active
Second Auth Server:
IP: 1.1.2.1 Port: 1812 State: active
Encryption Key : N/A
IP: 1.1.3.1 Port: 1812 State: active
Probe username : N/A
Probe interval : N/A
Second Acct Server:
IP: 1.1.2.1 Port: 1813 State: block
Auth Server Encryption Key : ******
Acct Server Encryption Key : N/A
Accounting-On packet disable, send times : 50 , interval : 3s
Interval for timeout(second) : 3
Retransmission times for timeout : 3
Interval for realtime accounting(minute) : 12
Retransmission times of realtime-accounting packet : 5
Retransmission times of stop-accounting packet : 500
Quiet-interval(min) : 5
Username format : without-domain
Data flow unit : Byte
Packet unit : one
NAS-IP address : 1.1.1.1
Attribute 25 : car
Total 1 RADIUS scheme(s).
Table 5 Command output
SchemeName |
Name of the RADIUS scheme. |
Index |
Index number of the RADIUS scheme. |
Type |
Type of the RADIUS server that the device supports. Options include: · Extended—The RADIUS server uses the proprietary RADIUS protocol of H3C for packet exchange. · Standard—The RADIUS server uses the standard RADIUS protocol for packet exchange. The protocol is compliant to RFC 2865 and RFC 2866 or later. |
Primary Auth Server |
Information about the primary authentication server. |
Primary Acct Server |
Information about the primary accounting server. |
Second Auth Server |
Information about the secondary authentication server. |
Second Acct Server |
Information about the secondary accounting server. |
IP |
IP address of the server. |
Port |
Service port of the server. If no port configuration is performed, the default port number is displayed. |
State |
Status of the server: active or blocked. |
Encryption Key |
Shared key for secure authentication or accounting communication, displayed as a series of asterisks (******). If no shared key is configured, this field displays N/A. |
Probe username |
Username used for server status detection. |
Probe interval |
Server status detection interval, in minutes. |
Auth Server Encryption Key |
Shared key for secure authentication communication, displayed as a series of asterisks (******). If no shared key is configured, this field displays N/A. |
Acct Server Encryption Key |
Shared key for secure accounting communication, displayed as a series of asterisks (******). If no shared key is configured, this field displays N/A. |
Accounting-On packet disable |
The accounting-on feature is disabled. |
send times |
Retransmission times of accounting-on packets. |
interval |
Interval at which the device retransmits accounting-on packets. |
Interval for timeout(second) |
RADIUS server response timeout period, in seconds. |
Retransmission times for timeout |
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server. |
Interval for realtime accounting(minute) |
Interval for real-time accounting, in minutes. |
Retransmission times of realtime-accounting packet |
Maximum number of accounting attempts. |
Retransmission times of stop-accounting packet |
Maximum number of stop-accounting attempts. |
Quiet-interval(min) |
Quiet interval for the primary server. |
Username format |
Format of the usernames to be sent to the RADIUS server. |
Data flow unit |
Unit for data flows sent to the RADIUS server. |
Packet unit |
Unit for packets sent to the RADIUS server. |
NAS-IP address |
Source IP address for RADIUS packets to be sent. |
Attribute 25 |
Interprets RADIUS attribute 25 as the CAR parameters. The device cannot interpret RADIUS attribute 25 as the CAR parameters in the current version. |
radius scheme
display radius statistics
Use display radius statistics to display statistics about RADIUS packets.
display radius statistics [ | { begin | exclude | include } regular-expression ]
Default command level
2: System level
# Display statistics about RADIUS packets.
<Sysname> display radius statistics
state statistic(total=128):
DEAD = 128 AuthProc = 0 AuthSucc = 0
AcctStart = 0 RLTSend = 0 RLTWait = 0
AcctStop = 0 OnLine = 0 Stop = 0
Received and Sent packets statistic:
Sent PKT total = 1547 Received PKT total = 23
Resend Times Resend total
1 508
2 508
Total 1016
RADIUS received packets statistic:
Code = 2 Num = 15 Err = 0
Code = 3 Num = 4 Err = 0
Code = 5 Num = 4 Err = 0
Code = 11 Num = 0 Err = 0
Running statistic:
RADIUS received messages statistic:
Auth request Num = 24 Err = 0 Succ = 24
Account request Num = 4 Err = 0 Succ = 4
Account off request Num = 503 Err = 0 Succ = 503
PKT auth timeout Num = 15 Err = 5 Succ = 10
PKT acct_timeout Num = 1509 Err = 503 Succ = 1006
Realtime Account timer Num = 0 Err = 0 Succ = 0
PKT response Num = 23 Err = 0 Succ = 23
Session ctrl pkt Num = 0 Err = 0 Succ = 0
Normal author request Num = 0 Err = 0 Succ = 0
Set policy result Num = 0 Err = 0 Succ = 0
Accounting on request Num = 0 Err = 0 Succ = 0
Accounting on response Num = 0 Err = 0 Succ = 0
Dynamic Author Ext request Num = 0 Err = 0 Succ = 0
RADIUS sent messages statistic:
Auth accept Num = 10
Auth reject Num = 14
EAP auth replying Num = 0
Account success Num = 4
Account failure Num = 3
Server ctrl req Num = 0
RecError_MSG_sum = 0
SndMSG_Fail_sum = 0
Timer_Err = 0
Alloc_Mem_Err = 0
State Mismatch = 0
Other_Error = 0
No-response-acct-stop packet = 1
Discarded No-response-acct-stop packet for buffer overflow = 0
Table 6 Command output
state statistic |
User statistics, by state. |
DEAD |
Number of idle users. |
AuthProc |
Number of users waiting for authentication. |
AuthSucc |
Number of users who have passed authentication. |
AcctStart |
Number of users for whom accounting has been started. |
RLTSend |
Number of users for whom the system sends real-time accounting packets. |
RLTWait |
Number of users waiting for real-time accounting. |
AcctStop |
Number of users in the state of accounting waiting stopped. |
OnLine |
Number of online users. |
Stop |
Number of users in the state of stop. |
Received and Sent packets statistic |
Statistics for packets received and sent by the RADIUS module. |
Sent PKT total |
Number of packets sent. |
Received PKT total |
Number of packets received. |
Resend Times |
Number of transmission attempts. |
Resend total |
Number of packets retransmitted. |
Total |
Total number of packets retransmitted. |
RADIUS received packets statistic |
Statistics for packets received by the RADIUS module. |
Code |
Packet type. |
Num |
Total number of packets. |
Err |
Number of packets that the device failed to process. |
Succ |
Number of messages that the device successfully processed. |
Running statistic |
Statistics for RADIUS messages received and sent by the RADIUS module. |
RADIUS received messages statistic |
Statistics for received RADIUS messages. |
Auth request |
Counts of normal authentication requests. |
Account request |
Counts of accounting requests. |
Account off request |
Counts of stop-accounting requests. |
PKT auth timeout |
Counts of authentication timeout messages. |
PKT acct_timeout |
Counts of accounting timeout messages. |
Realtime Account timer |
Counts of real-time accounting requests. |
PKT response |
Counts of responses from servers. |
Session ctrl pkt |
Counts of session control messages. |
Normal author request |
Counts of normal authorization requests. |
Set policy result |
Counts of responses to the Set policy packets. |
Accounting on request |
Counts of accounting-on requests. |
Accounting on response |
Counts of accounting-on responses. |
Dynamic Author Ext request |
Counts of dynamic authorization extension requests. |
RADIUS sent messages statistic |
Statistics for sent RADIUS messages. |
Auth accept |
Number of accepted authentication packets. |
Auth reject |
Number of rejected authentication packets. |
EAP auth replying |
Number of replying packets of EAP authentication. |
Account success |
Number of accounting succeeded packets. |
Account failure |
Number of accounting failed packets. |
Server ctrl req |
Number of server control requests. |
RecError_MSG_sum |
Number of received packets in error. |
SndMSG_Fail_sum |
Number of packets that failed to be sent out. |
Timer_Err |
Number of packets for indicating timer startup failures. |
Alloc_Mem_Err |
Number of packets for indicating memory allocation failures. |
State Mismatch |
Number of packets for indicating mismatching status. |
Other_Error |
Number of packets for indicating other types of errors. |
No-response-acct-stop packet |
Number of times that no response was received for stop-accounting packets. |
Discarded No-response-acct-stop packet for buffer overflow |
Number of stop-accounting packets that were buffered but then discarded due to full memory. |
radius scheme
display stop-accounting-buffer (for RADIUS)
Use display stop-accounting-buffer to display information about buffered stop-accounting requests.
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ | { begin | exclude | include } regular-expression ]
2: System level
radius-scheme radius-scheme-name: Specifies buffered stop-accounting requests that are destined for the accounting server defined in a RADIUS scheme. The RADIUS scheme name is a case-insensitive string of 1 to 32 characters.
session-id session-id: Specifies the stop-accounting requests buffered for a session. The session ID is a string of 1 to 50 characters.
time-range start-time stop-time: Specifies the stop-accounting requests buffered in a time range. The start time and end time must be in the format HH:MM:SS-MM/DD/YYYY or HH:MM:SS-YYYY/MM/DD.
user-name user-name: Specifies the stop-accounting requests buffered for a user. The username is a case-sensitive string of 1 to 80 characters. Whether the user-name argument should include the domain name depends on the setting configured by the user-name-format command for the RADIUS scheme.
If the device sends a stop-accounting request to a RADIUS server but receives no response, it retransmits it up to a certain number of times (defined by the retry command). If the device still receives no response, it considers the stop-accounting attempt a failure, buffers the request, and makes another stop-accounting attempt. The maximum number of the stop-accounting attempts is defined by the retry stop-accounting command. If all attempts fail, the device discards the request.
# Display information about the stop-accounting requests buffered for user abc.
<Sysname> display stop-accounting-buffer user-name abc
RDIdx Session-ID user name Happened time
1 1000326232325010 abc 23:27:16-08/31/2006
1 1000326232326010 abc 23:33:01-08/31/2006
Total 2 record(s) Matched
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication/authorization or accounting communication.
Use undo key to remove the configuration.
key { accounting | authentication } [ cipher | simple ] key
undo key { accounting | authentication }
No shared key is configured.
RADIUS scheme view
2: System level
accounting: Sets the shared key for secure RADIUS accounting communication.
authentication: Sets the shared key for secure RADIUS authentication/authorization communication.
cipher: Sets a cipher text shared key.
simple: Sets a plain text shared key.
key: Specifies the shared key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 64 characters. If cipher is specified, it must be a ciphertext string of 1 to 117 characters. If neither cipher nor simple is specified, you set a plaintext shared key string.
For secrecy, all shared keys, including keys configured in plain text, are saved in cipher text.
The shared keys specified during the configuration of the RADIUS servers take precedence.
The shared keys configured on the device must match those configured on the RADIUS servers.
# For RADIUS scheme radius1, set the shared key for secure accounting communication to ok in plain text.
[Sysname-radius-radius1] key accounting simple ok
[Sysname-radius-radius1] key accounting ok
# For RADIUS scheme radius1, set the shared key for secure authentication/authorization communication to $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B in cipher text.
[Sysname-radius-radius1] key authentication cipher $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B
nas-ip (RADIUS scheme view)
Use nas-ip to specify a source IP address for outgoing RADIUS packets.
Use undo nas-ip to restore the default.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip
The source IP address of an outgoing RADIUS packet is that configured by the radius nas-ip command in system view. If the radius nas-ip command is not configured, the source IP address is the IP address of the outbound interface.
RADIUS scheme view
2: System level
ipv4-address: IPv4 address in dotted decimal notation. It must be an address of the device and cannot be 0.0.0.0, 255.255.255.255, a class D address, or a class E address.
ipv6 ipv6-address: Specifies an IPv6 address. It must be a unicast address of the device and cannot be a link-local address.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks whether the source IP address of the packet is the IP address of any managed NAS. If it is, the server processes the packet. If it is not, the server drops the packet.
The source IP address specified for outgoing RADIUS packets must be of the same IP version as the IP addresses of the RADIUS servers in the RADIUS scheme. Otherwise, the source IP address configuration does not take effect.
A RADIUS scheme can have only one source IP address for outgoing RADIUS packets. If you specify a new source IP address for the same RADIUS scheme, the new one overwrites the old one.
The setting configured by the nas-ip command in RADIUS scheme view is only for the RADIUS scheme, whereas that configured by the radius nas-ip command in system view is for all RADIUS schemes. The setting in RADIUS scheme view takes precedence.
# Set the source IP address for outgoing RADIUS packets to 10.1.1.1.
[Sysname-radius-radius1] nas-ip 10.1.1.1
radius nas-ip
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to remove the configuration.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | probe username name [ interval interval ] ] *
No primary RADIUS accounting server is specified.
RADIUS scheme view
2: System level
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server, which must be a valid global unicast address.
port-number: Specifies the service port number of the primary RADIUS accounting server, a UDP port number ranging from 1 to 65535. The default setting is 1813.
key [ cipher | simple ] key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
· cipher key: Specifies a ciphertext shared key, a case-sensitive ciphertext string of 1 to 117 characters.
· simple key: Specifies a plaintext shared key, a case-sensitive string of 1 to 64 characters.
· If neither cipher nor simple is specified, you set a plaintext shared key string.
probe: Enables the device to detect the status of the primary RADIUS accounting server.
username name: Specifies the username in the accounting request for server status detection.
interval interval: Specifies the detection interval. The value range for the interval argument is 1 to 3600, in minutes. The default setting is 10 minutes.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
The IP addresses of the accounting servers and those of the authentication/authorization servers must be of the same IP version.
The IP addresses of the primary and secondary accounting servers must be different from each other. Otherwise, the configuration fails.
The shared key configured by this command takes precedence over that configured by using the key accounting [ cipher | simple ] key command.
If you change the primary accounting server when the device has already sent a start-accounting request to the server, the communication with the primary server times out, and the device looks for a server in active state from the new primary server on.
If you remove an accounting server being used by users, the device can no longer send real-time accounting requests or stop-accounting requests for the users, and it does not buffer the stop-accounting requests.
With the server status detection feature enabled, the device sends an accounting request that carries the specified username to the primary server at the specified interval. If the device receives no response from the server within the time interval specified by the timer response-timeout command, the device sends the request again.
If the maximum number of retries (specified by the retry command) is reached and the device still receives no response from the server, the device considers the server as unreachable. If the device receives a response from the server before the maximum number of retries is reached, the device considers the server as reachable. The device sets the status of the server to block or active according to the status detection result, regardless of the current status of the server.
To ensure that the device can set the server to its actual status, set a longer quiet timer for the primary server by using the timer quiet command.
# For RADIUS scheme radius1, set the IP address of the primary accounting server to 10.110.1.2, the UDP port to 1813, and the shared key to hello in plain text.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple hello
key
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication/authorization server.
Use undo primary authentication to remove the configuration.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | probe username name [ interval interval ] ] *
No primary RADIUS authentication/authorization server is specified.
RADIUS scheme view
2: System level
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication/authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication/authorization server, which must be a valid global unicast address.
port-number: Specifies the service port number of the primary RADIUS authentication/authorization server, a UDP port number ranging from 1 to 65535. The default setting is 1812.
key [ cipher | simple ] key: Specifies the shared key for secure communication with the primary RADIUS authentication/authorization server.
probe: Enables the device to detect the status of the primary RADIUS authentication/authorization server.
username name: Specifies the username in the authentication request for server status detection.
interval interval: Specifies the detection interval. The value ranges from 1 to 3600, in minutes. The default setting is 10 minutes.
Make sure the port number and shared key settings of the primary RADIUS authentication/authorization server are the same as those configured on the server.
The shared key configured by this command takes precedence over that configured by using the key authentication [ cipher | simple ] key command.
The IP addresses of the authentication/authorization servers and those of the accounting servers must be of the same IP version.
The IP addresses of the primary and secondary authentication/authorization servers must be different from each other. Otherwise, the configuration fails.
If you remove the primary authentication server when an authentication process is in progress, the communication with the primary server times out, and the device looks for a server in active state from the new primary server on.
With the server status detection feature enabled, the device sends an authentication request that carries the specified username to the primary server at the specified interval. If the device receives no response from the server within the time interval specified by the timer response-timeout command, the device sends the authentication request again.
To ensure that the device can set the server to its actual status, set a longer quiet timer for the primary server with the timer quiet command.
# For RADIUS scheme radius1, set the IP address of the primary authentication/authorization server to 10.110.1.1, the UDP port to 1812, and the shared key to hello in plain text.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key hello
# In RADIUS scheme radius1, set the username used for status detection of the primary authentication/authorization server to test, and set the server status detection interval to 120 minutes.
[Sysname-radius-radius1] primary authentication 10.110.1.1 probe username test interval 120
key
radius client
Use radius client enable to enable the RADIUS client service.
Use undo radius client to disable the RADIUS client service.
undo radius client
The RADIUS client service is enabled.
2: System level
When the RADIUS client service is disabled, the following events occur:
· No more stop-accounting requests of online users can be sent out or buffered, and the RADIUS server can no longer receive logoff requests from online users. After a user goes offline, the RADIUS server still has the user's record during a certain period of time.
· The buffered accounting packets cannot be sent out and are deleted from the buffer when the configured maximum number of attempts is reached, affecting the precision of user accounting.
· If local authentication, authorization, or accounting is configured as the backup, the device performs local authentication, authorization, or accounting instead after the RADIUS request fails. Local accounting is only for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
# Enable the RADIUS client service.
[Sysname] radius client enable
radius nas-ip
Use radius nas-ip to specify a source address for outgoing RADIUS packets.
Use undo radius nas-ip to remove the configuration.
radius nas-ip { ipv4-address | ipv6 ipv6-address }
undo radius nas-ip { ipv4-address | ipv6 ipv6-address }
The source IP address of an outgoing RADIUS packet is the IP address of the outbound interface.
2: System level
You can specify only one public-network source IP address. A newly specified public-network source IP address overwrites the previous one.
# Set the IP address for the device to use as the source address of the RADIUS packets to 129.10.10.1.
[Sysname] radius nas-ip 129.10.10.1
nas-ip
radius scheme
Use radius scheme to create a RADIUS scheme and enter RADIUS scheme view.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS scheme is defined.
3: Manage level
radius-scheme-name: RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be referenced by more than one ISP domain at the same time.
A RADIUS scheme referenced by ISP domains cannot be removed.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
radius trap
Use radius trap to enable the trap function for RADIUS.
Use undo radius trap to disable the trap function for RADIUS.
radius trap { accounting-server-down | authentication-error-threshold | authentication-server-down }
undo radius trap { accounting-server-down | authentication-error-threshold | authentication-server-down }
The trap function is disabled for RADIUS.
2: System level
accounting-server-down: Sends traps when the reachability of the accounting server changes.
authentication-error-threshold: Sends traps when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the number of failed request transmission attempts to the total number of transmission attempts. It ranges from 1 to 100 and defaults to 30. This threshold can only be configured through the MIB.
authentication-server-down: Sends traps when the reachability of the authentication server changes.
With the trap function for RADIUS, a NAS sends a trap message in the following cases:
· When the status of a RADIUS server changes. If a NAS sends a request but receives no response before the maximum number of attempts is exceeded, it places the server to the blocked state and sends a trap message. If a NAS receives a response from a RADIUS server it considered unreachable, it considers that the RADIUS server is reachable again and also sends a trap message.
· When the ratio of the number of failed transmission attempts to the total number of authentication request transmission attempts reaches the threshold.
# Enable the device to send traps in response to accounting server reachability changes.
[Sysname] radius trap accounting-server-down
reset radius statistics
Use reset radius statistics to clear RADIUS statistics.
2: System level
# Clear RADIUS statistics.
<Sysname> reset radius statistics
reset stop-accounting-buffer (for RADIUS)
Use reset stop-accounting-buffer to clear buffered stop-accounting requests for which no responses have been received.
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
2: System level
# Clear the stop-accounting requests buffered for user user0001@test.
<Sysname> reset stop-accounting-buffer user-name user0001@test
# Clear the stop-accounting requests buffered in the time range from 0:0:0 to 23:59:59 on August 31, 2006.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-08/31/2006 23:59:59-08/31/2006
· stop-accounting-buffer enable
· display stop-accounting-buffer
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retry-times
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
2: System level
retry-times: Maximum number of RADIUS packet transmission attempts, ranging from 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable. If the device does not receive a response to its request from the RADIUS server within the response timeout period, it retransmits the RADIUS request. If the number of transmission attempts exceeds the limit but the device still receives no response from the RADIUS server, the device considers the request a failure.
The maximum number of packet transmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
# Set the maximum number of RADIUS request transmission attempts to 5 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry 5
· radius scheme
· timer response-timeout
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retry-times
The maximum number of accounting attempts is 5.
RADIUS scheme view
2: System level
retry-times: Maximum number of accounting attempts, ranging from 1 to 255.
A RADIUS server usually checks whether a user is online by using a timeout timer. If it receives no real-time accounting request for a user in the timeout period from the NAS, it considers that there may be line or device failures and stops accounting for the user. This may happen when some unexpected failure occurs. To cooperate with this feature of the RADIUS server, the NAS must keep pace with the server in disconnecting the user. The maximum number of accounting attempts, together with some other parameters, enables the NAS to promptly disconnect the user.
The maximum number of accounting attempts, together with some other parameters, controls how the NAS sends accounting request packets.
Suppose that the RADIUS server response timeout period is 3 seconds (set with the timer response-timeout command), the maximum number of RADIUS packet transmission attempts is 3 (set with the retry command), the real-time accounting interval is 12 minutes (set with the timer realtime-accounting command), and the maximum number of accounting attempts is five (set with the retry realtime-accounting command). In this case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request three times, it considers the accounting attempt a failure, and it makes another accounting attempt. If five consecutive accounting attempts fail, the device cuts the user connection.
# Set the maximum number of accounting attempts to 10 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry realtime-accounting 10
· retry
· timer realtime-accounting
retry stop-accounting (RADIUS scheme view)
Use retry stop-accounting to set the maximum number of stop-accounting request transmission attempts.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retry-times
The maximum number of stop-accounting request transmission attempts is 500.
RADIUS scheme view
2: System level
retry-times: Maximum number of stop-accounting request transmission attempts, ranging from 10 to 65535.
The maximum number of stop-accounting request transmission attempts, together with some other parameters, controls how the NAS deals with stop-accounting request packets.
Suppose that the RADIUS server response timeout period is 3 seconds (set with the timer response-timeout command), the maximum number of transmission attempts is five (set with the retry command), and the maximum number of stop-accounting request transmission attempts is 20 (set with the retry stop-accounting command). For each stop-accounting request, if the device receives no response within 3 seconds, it retransmits the request. If it receives no responses after retransmitting the request five times, it considers the attempt a failure, buffers the request, and makes another attempt. If 20 consecutive attempts fail, the device discards the request.
# Set the maximum number of stop-accounting request transmission attempts to 1000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
· retry
· retry stop-accounting
secondary accounting (RADIUS scheme view)
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove the configuration.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | probe username name [ interval interval ] ] *
undo secondary accounting [ ipv4-address | ipv6 ipv6-address ]
No secondary RADIUS accounting server is specified.
RADIUS scheme view
2: System level
ipv4-address: Specifies the IPv4 address of the secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS accounting server, which must be a valid global unicast address.
port-number: Specifies the service port number of the secondary RADIUS accounting server, a UDP port number ranging from 1 to 65535. The default setting is 1813.
key [ cipher | simple ] key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
probe: Enables the device to detect the status of the secondary RADIUS accounting server.
Make sure the port number and shared key settings of the secondary RADIUS accounting server are the same as those configured on the server.
You can configure up to 16 secondary RADIUS accounting servers for a RADIUS scheme by executing this command repeatedly. After the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary RADIUS accounting server configured earlier has a higher priority) and tries to communicate with it.
If you remove a secondary accounting server when the device has already sent a start-accounting request to the server, the communication with the secondary server times out, and the device looks for a server in active state from the primary server on.
If you remove an accounting server being used by online users, the device can no longer send real-time accounting requests or stop-accounting requests for the users, and it does not buffer the stop-accounting requests.
With the server status detection feature enabled, the device sends an accounting request that carries the specified username to the secondary server at the specified interval. If the device receives no response from the server within the time interval specified by the timer response-timeout command, the device sends the request again.
To ensure that the device can set the server to its actual status, set a longer quiet timer for the secondary server by using the timer quiet command.
# For RADIUS scheme radius1, specify two secondary accounting servers with the server IP addresses of 10.110.1.1 and 10.110.1.2 and the UDP port number of 1813. Set the shared keys to hello in plain text.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813 key hello
[Sysname-radius-radius1] secondary accounting 10.110.1.2 1813 key hello
# For RADIUS scheme radius2, set the IP address of the secondary accounting server to 10.110.1.1, the UDP port to 1813, and the shared key to $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B in cipher text.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813 key cipher $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B
· key
· state
secondary authentication (RADIUS scheme view)
Use secondary authentication to specify a secondary RADIUS authentication/authorization server.
Use undo secondary authentication to remove the configuration.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | probe username name [ interval interval ] ] *
undo secondary authentication [ ipv4-address | ipv6 ipv6-address ]
No secondary RADIUS authentication/authorization server is specified.
RADIUS scheme view
2: System level
ipv4-address: Specifies the IPv4 address of the secondary RADIUS authentication/authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS authentication/authorization server, which must be a valid global unicast address.
port-number: Specifies the service port number of the secondary RADIUS authentication/authorization server, a UDP port number ranging from 1 to 65535. The default setting is 1812.
key [ cipher | simple ] key: Specifies the shared key for secure communication with the secondary RADIUS authentication/authorization server.
probe: Enables the device to detect the status of the secondary RADIUS authentication/authorization server.
Make sure the port number and shared key settings of the secondary RADIUS authentication/authorization server are the same as those configured on the server.
You can configure up to 16 secondary RADIUS authentication/authorization servers for a RADIUS scheme by executing this command repeatedly. After the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary RADIUS authentication/authorization server configured earlier has a higher priority) and tries to communicate with it.
If you remove a secondary authentication server in use in the authentication process, the communication with the secondary server times out, and the device looks for a server in active state from the primary server on.
With the server status detection feature enabled, the device sends an authentication request that carries the specified username to the secondary server at the specified interval. If the device receives no response from the server within the time interval specified by the timer response-timeout command, the device sends the authentication request again.
To ensure that the device can set the server to its actual status, set a longer quiet timer for the secondary server with the timer quiet command.
# Specify two secondary authentication/authorization servers for RADIUS scheme radius1, with the server IP addresses of 10.110.1.1 and 10.110.1.2 and the UDP port number of 1813. Set the shared keys to hello in plain text.
[Sysname-radius-radius1] secondary authentication 10.110.1.1 1812 key simple hello
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812 key simple hello
# For RADIUS scheme radius2, set the IP address of the secondary authentication/authorization server to 10.110.1.2, the UDP port to 1812, and the shared key to $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B in cipher text.
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812 key cipher $c$3$NMCbVjyIutaV6csCOGp4zsKRTlg2eT3B
# In RADIUS scheme radius1, set the username used for status detection of the secondary authentication/authorization server to test, and set the server status detection interval to 120 minutes.
[Sysname-radius-radius1] secondary authentication 10.110.1.1 probe username test interval 120
· key
· state
security-policy-server
Use security-policy-server to specify a security policy server for a RADIUS scheme.
Use undo security-policy-server to remove one or all security policy servers for a RADIUS scheme.
security-policy-server ip-address
undo security-policy-server { ip-address | all }
No security policy server is specified for a RADIUS scheme.
RADIUS scheme view
2: System level
ip-address: Specifies a security policy server by its IP address.
all: Specifies all security policy servers.
You can specify up to eight security policy servers for a RADIUS scheme.
You can change security policy servers for a RADIUS scheme only when no user is using the scheme.
# Specify security policy server 10.110.1.2 for RADIUS scheme radius1.
[Sysname-radius-radius1] security-policy-server 10.110.1.2
server-type
Use server-type to specify the RADIUS server type.
Use undo server-type to restore the default.
server-type { extended | standard }
undo server-type
The supported RADIUS server type is standard.
RADIUS scheme view
2: System level
extended: Specifies the extended RADIUS server (generally running on IMC), which requires the RADIUS client and RADIUS server to interact according to the procedures and packet formats provisioned by the proprietary RADIUS protocol.
standard: Specifies the standard RADIUS server, which requires the RADIUS client and RADIUS server to interact according to the procedures and packet format of the standard RADIUS protocol (RFC 2865 and 2866 or their successors).
# Configure the RADIUS server type of RADIUS scheme radius1 as standard.
[Sysname-radius-radius1] server-type standard
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
The primary RADIUS server specified for a RADIUS scheme is in active state.
RADIUS scheme view
2: System level
accounting: Sets the status of the primary RADIUS accounting server.
authentication: Sets the status of the primary RADIUS authentication/authorization server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
During an authentication or accounting process, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device changes the status of the primary server to blocked, starts a quiet timer for the server, and then tries to communicate with a secondary server in active state (a secondary RADIUS server configured earlier has a higher priority). When the quiet timer of the primary server times out, the status of the server changes to active automatically. If you set the status of the server to blocked before the quiet timer times out, the status of the server cannot change back to active automatically unless you set the status to active manually.
When the primary server and secondary servers are both in blocked state, the device communicates with the primary server.
# Set the status of the primary server in RADIUS scheme radius1 to blocked.
[Sysname-radius-radius1] state primary authentication block
· display radius scheme
· state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ ip ipv4-address | ipv6 ipv6-address ] { active | block }
Every secondary RADIUS server specified in a RADIUS scheme is in active state.
RADIUS scheme view
2: System level
accounting: Sets the status of the secondary RADIUS accounting server.
authentication: Sets the status of the secondary RADIUS authentication/authorization server.
ip ipv4-address: Specifies the IPv4 address of the secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS server.
If no IP address is specified, this command changes the status of all configured secondary servers for authentication/authorization or accounting.
If the device finds that a secondary server in active state is unreachable, the device changes the status of the secondary server to blocked, starts a quiet timer for the server, and continues to try to communicate with the next secondary server in active state (a secondary RADIUS server configured earlier has a higher priority). When the quiet timer of a server times out, the status of the server changes to active automatically. If you set the status of the server to blocked before the quiet timer times out, the status of the server cannot change back to active automatically unless you set the status to active manually. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
# Set the status of all secondary servers in RADIUS scheme radius1 to blocked.
[Sysname-radius-radius1] state secondary authentication block
· state primary
stop-accounting-buffer enable (RADIUS scheme view)
Use stop-accounting-buffer enable to enable the device to buffer stop-accounting requests to which no responses are received.
Use undo stop-accounting-buffer enable to disable the buffering function.
The device buffers stop-accounting requests to which no responses are received.
RADIUS scheme view
2: System level
Stop-accounting requests affect the charge to users. A NAS must make its best effort to send every stop-accounting request to the RADIUS accounting servers. For each stop-accounting request that receives no response in the specified period of time, the NAS buffers and resends the packet until it receives a response or the number of transmission attempts reaches the configured limit. In the latter case, the NAS discards the packet. However, if you have removed the accounting server, stop-accounting messages are not buffered.
# Enable the device to buffer the stop-accounting requests to which no responses are received.
[Sysname-radius-radius1] stop-accounting-buffer enable
· reset stop-accounting-buffer
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for servers.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
RADIUS scheme view
2: System level
minutes: Server quiet period in minutes, ranging from 0 to 255. If you set this argument to 0, when the device attempts to send an authentication or accounting request but the current server is unreachable, the device sends the request to the next server in active state, without changing the current server's status. As a result, when the device attempts to send a request of the same type for another user, it still tries to send the request to the current server because the current server is in active state.
The quiet timer controls whether the device changes the status of an unreachable server from active to blocked and how long the device keeps an unreachable server in blocked state.
If you determine that the primary server is unreachable because the device's port connected to the server is out of service temporarily or the server is busy, you can set the server quiet period to 0 so that the device uses the primary server whenever possible.
Be sure to set the server quiet timer properly. Too short a quiet timer may result in frequent authentication or accounting failures because the device has to repeatedly try to communicate with an unreachable server that is in active state.
# Set the quiet timer for the servers to 10 minutes.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting minutes
The real-time accounting interval is 12 minutes.
RADIUS scheme view
2: System level
minutes: Real-time accounting interval in minutes. The value can be 0 or a multiple of 3, ranging from 3 to 60.
For real-time accounting, a NAS must transmit the accounting information of online users to the RADIUS accounting server periodically. This command sets the interval.
When the real-time accounting interval on the device is 0, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server, or does not send online user accounting information.
Different real-time accounting intervals impose different performance requirements on the NAS and the RADIUS server. A shorter interval helps achieve higher accounting precision but requires higher performance. Use a longer interval when there are a large number of users (1000 or more).
Table 7 Recommended real-time accounting intervals
Number of users |
Real-time accounting interval (in minutes) |
1 to 99 |
3 |
100 to 499 |
6 |
500 to 999 |
12 |
1000 or more |
15 or longer |
# Set the real-time accounting interval to 51 minutes for RADIUS scheme radius1.
[Sysname-radius-radius1] timer realtime-accounting 51
timer response-timeout (RADIUS scheme view)
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
2: System level
seconds: RADIUS server response timeout period in seconds, ranging from 1 to 10.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request (authentication/authorization or accounting request), it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
The maximum number of RADIUS packet transmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
# Set the RADIUS server response timeout timer to 5 seconds for RADIUS scheme radius1.
[Sysname-radius-radius1] timer response-timeout 5
retry
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the username.
RADIUS scheme view
2: System level
keep-original: Sends the username to the RADIUS server as it is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the format userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username including an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the RADIUS scheme to more than one ISP domain, avoiding the confused situation where the RADIUS server regards two users in different ISP domains but with the same userid as one.
For 802.1X users using EAP authentication, the user-name-format command configured for a RADIUS scheme does not take effect and the device does not change the usernames from clients before forwarding them to the RADIUS server.
If the RADIUS scheme is used for roaming wireless users, specify the keep-original keyword. Otherwise, authentication of the wireless users may fail.
# Specify the device to remove the domain name in the username sent to the RADIUS servers for the RADIUS scheme radius1.
[Sysname-radius-radius1] user-name-format without-domain
radius scheme
HWTACACS configuration commands
data-flow-format (HWTACACS scheme view)
2: System level
The unit for data flows and that for packets must be consistent with those on the HWTACACS server. Otherwise, accounting cannot be performed correctly.
# Set the traffic statistics unit for data flows and that for packets to kilobytes and kilo-packets, respectively, in HWTACACS scheme hwt1.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs
display hwtacacs
Use display hwtacacs to display the configuration of HWTACACS schemes or the statistics for the HWTACACS servers specified in HWTACACS schemes.
display hwtacacs [ hwtacacs-scheme-name [ statistics ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
hwtacacs-scheme-name: HWTACACS scheme name.
statistics: Displays the statistics for the HWTACACS servers specified in the HWTACACS scheme. Without this keyword, the command displays the configuration of the HWTACACS scheme.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no HWTACACS scheme is specified, the command displays the configuration of all HWTACACS schemes.
# Display the configuration of HWTACACS scheme gy.
<Sysname> display hwtacacs gy
HWTACACS-server template name : gy
Primary-authentication-server : 172.31.1.11:49
Primary-authorization-server : 172.31.1.11:49
Primary-accounting-server : 172.31.1.11:49
Secondary-authentication-server : 0.0.0.0:0
Secondary-authorization-server : 0.0.0.0:0
Secondary-accounting-server : 0.0.0.0:0
Current-authentication-server : 172.31.1.11:49
Current-authorization-server : 172.31.1.11:49
Current-accounting-server : 172.31.1.11:49
NAS-IP-address : 0.0.0.0
key authentication : ******
key authorization : ******
key accounting : ******
Realtime-accounting-interval(min) : 12
Response-timeout-interval(sec) : 5
Acct-stop-PKT retransmit times : 100
Username format : with-domain
Data traffic-unit : B
Packet traffic-unit : one-packet
HWTACACS-server template name |
Name of the HWTACACS scheme. |
Primary-authentication-server |
IP address and port number of the primary authentication server. If no primary authentication server is specified, this field displays 0.0.0.0:0. This rule also applies to the following eight fields. |
Primary-authorization-server |
IP address and port number of the primary authorization server. |
Primary-accounting-server |
IP address and port number of the primary accounting server. |
Secondary-authentication-server |
IP address and port number of the secondary authentication server. |
Secondary-authorization-server |
IP address and port number of the secondary authorization server. |
Secondary-accounting-server |
IP address and port number of the secondary accounting server. |
Current-authentication-server |
IP address and port number of the currently used authentication server. |
Current-authorization-server |
IP address and port number of the currently used authorization server. |
Current-accounting-server |
IP address and port number of the currently used accounting server. |
NAS-IP-address |
IP address of the NAS. If no NAS is specified, this field displays 0.0.0.0. |
key authentication |
Key for authentication, displayed as a series of asterisks (******). If no key is configured, this field displays N/A. |
key authorization |
Key for authorization, displayed as a series of asterisks (******). If no key is configured, this field displays N/A. |
key accounting |
Key for accounting, displayed as a series of asterisks (******). If no key is configured, this field displays N/A. |
Realtime-accounting-interval |
Realtime accounting interval. The device does not support HWTACACS realtime accounting in the current version. |
Acct-stop-PKT retransmit times |
Number of stop-accounting packet transmission attempts. |
Data traffic-unit |
Unit for data flows. |
Packet traffic-unit |
Unit for data packets. |
# Display the statistics for the servers specified in HWTACACS scheme gy.
<Sysname> display hwtacacs gy statistics
---[HWTACACS template gy primary authentication]---
HWTACACS server open number: 10
HWTACACS server close number: 10
HWTACACS authen client access request packet number: 10
HWTACACS authen client access response packet number: 6
HWTACACS authen client unknown type number: 0
HWTACACS authen client timeout number: 4
HWTACACS authen client packet dropped number: 4
HWTACACS authen client access request change password number: 0
HWTACACS authen client access request login number: 5
HWTACACS authen client access request send authentication number: 0
HWTACACS authen client access request send password number: 0
HWTACACS authen client access connect abort number: 0
HWTACACS authen client access connect packet number: 5
HWTACACS authen client access response error number: 0
HWTACACS authen client access response failure number: 0
HWTACACS authen client access response follow number: 0
HWTACACS authen client access response getdata number: 0
HWTACACS authen client access response getpassword number: 5
HWTACACS authen client access response getuser number: 0
HWTACACS authen client access response pass number: 1
HWTACACS authen client access response restart number: 0
HWTACACS authen client malformed access response number: 0
HWTACACS authen client round trip time(s): 5
---[HWTACACS template gy primary authorization]---
HWTACACS author client request packet number: 1
HWTACACS author client response packet number: 1
HWTACACS author client timeout number: 0
HWTACACS author client packet dropped number: 0
HWTACACS author client unknown type number: 0
HWTACACS author client request EXEC number: 1
HWTACACS author client request PPP number: 0
HWTACACS author client request VPDN number: 0
HWTACACS author client response error number: 0
HWTACACS author client response EXEC number: 1
HWTACACS author client response PPP number: 0
HWTACACS author client response VPDN number: 0
HWTACACS author client round trip time(s): 3
---[HWTACACS template gy primary accounting]---
HWTACACS server open number: 0
HWTACACS server close number: 0
HWTACACS account client request packet number: 0
HWTACACS account client response packet number: 0
HWTACACS account client unknown type number: 0
HWTACACS account client timeout number: 0
HWTACACS account client packet dropped number: 0
HWTACACS account client request command level number: 0
HWTACACS account client request connection number: 0
HWTACACS account client request EXEC number: 0
HWTACACS account client request network number: 0
HWTACACS account client request system event number: 0
HWTACACS account client request update number: 0
HWTACACS account client response error number: 0
HWTACACS account client round trip time(s): 0
hwtacacs scheme
display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ | { begin | exclude | include } regular-expression ]
2: System level
hwtacacs-scheme hwtacacs-scheme-name: Specifies buffered stop-accounting requests that are destined for the accounting server defined in an HWTACACS scheme. The HWTACACS scheme name is a case-insensitive string of 1 to 32 characters.
# Display information about stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total 0 record(s) Matched
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to remove the configuration.
hwtacacs nas-ip ip-address
undo hwtacacs nas-ip ip-address
The source IP address of a packet sent to the server is the IP address of the outbound interface.
2: System level
ip-address: IP address in dotted decimal notation. It must be an address of the device and cannot be 0.0.0.0, 255.255.255.255, a class D address, or a class E address.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, an HWTACACS server checks whether the source IP address of the packet is the IP address of any managed NAS. If it is, the server processes the packet. If it is not, the server drops the packet.
The setting configured by the nas-ip command in HWTACACS scheme view is only for the HWTACACS scheme, whereas that configured by the hwtacacs nas-ip command in system view is for all HWTACACS schemes. The setting in HWTACACS scheme view takes precedence.
# Set the IP address for the device to use as the source address of the HWTACACS packets to 129.10.10.1.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter HWTACACS scheme view.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS scheme exists.
3: Manage level
hwtacacs-scheme-name: HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be referenced by more than one ISP domain at the same time.
An HWTACACS scheme referenced by ISP domains cannot be removed.
# Create an HWTACACS scheme named hwt1, and enter HWTACACS scheme view.
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } [ cipher | simple ] key
undo key { accounting | authentication | authorization }
2: System level
accounting: Sets the shared key for secure HWTACACS accounting communication.
authentication: Sets the shared key for secure HWTACACS authentication communication.
authorization: Sets the shared key for secure HWTACACS authorization communication.
cipher: Sets a ciphertext shared key.
simple: Sets a plaintext shared key.
key: Specifies the shared key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 255 characters. If cipher is specified, it must be a ciphertext string of 1 to 373 characters. If neither cipher nor simple is specified, you set a plaintext shared key string.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# Set the shared key for secure HWTACACS accounting communication to hello in plain text for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] key accounting simple hello
[Sysname-hwtacacs-hwt1] key accounting hello
# Set the shared key for secure HWTACACS accounting communication to $c$3$jaeN0ej15fjuHKeuVh8mqicHzaHdMw== in cipher text for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] key accounting cipher $c$3$jaeN0ej15fjuHKeuVh8mqicHzaHdMw==
display hwtacacs
nas-ip (HWTACACS scheme view)
Use nas-ip to specify a source IP address for outgoing HWTACACS packets.
nas-ip ip-address
undo nas-ip
The source IP address of an outgoing HWTACACS packet is configured by the hwtacacs nas-ip command in system view. If the hwtacacs nas-ip command is not configured, the source IP address is the IP address of the outbound interface.
2: System level
If you configure the command repeatedly, only the last configuration takes effect.
# Set the source address for outgoing HWTACACS packets to 10.1.1.1.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
primary accounting ip-address [ port-number ]
No primary HWTACACS accounting server is specified.
2: System level
ip-address: IP address of the primary HWTACACS accounting server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the primary HWTACACS accounting server. It ranges from 1 to 65535 and defaults to 49.
The IP addresses of the primary and secondary accounting servers must be different. Otherwise, the configuration fails.
You can remove an accounting server only when it is not used by any active TCP connection to send accounting packets. Removing an accounting server only affects accounting processes that occur after the remove operation.
# Specify the IP address and port number of the primary accounting server for HWTACACS scheme test1 as 10.163.155.12 and 49.
[Sysname] hwtacacs scheme test1
[Sysname-hwtacacs-test1] primary accounting 10.163.155.12 49
display hwtacacs
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
primary authentication ip-address [ port-number ]
No primary HWTACACS authentication server is specified.
Default command level
2: System level
ip-address: IP address of the primary HWTACACS authentication server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the primary HWTACACS authentication server. It ranges from 1 to 65535 and defaults to 49.
The IP addresses of the primary and secondary authentication servers must be different. Otherwise, the configuration fails.
You can remove an authentication server only when it is not used by any active TCP connection to send authentication packets. Removing an authentication server only affects authentication processes that occur after the remove operation.
# Specify the IP address and port number of the primary authentication server for HWTACACS scheme hwt1 as 10.163.155.13 and 49.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49
display hwtacacs
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to remove the configuration.
primary authorization ip-address [ port-number ]
No primary HWTACACS authorization server is specified.
2: System level
ip-address: IP address of the primary HWTACACS authorization server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the primary HWTACACS authorization server. It ranges from 1 to 65535 and defaults to 49.
The IP addresses of the primary and secondary authorization servers must be different. Otherwise, the configuration fails.
You can remove an authorization server only when it is not used by any active TCP connection to send authorization packets. Removing an authorization server only affects authorization processes that occur after the remove operation.
# Configure the IP address and port number of the primary authorization server for HWTACACS scheme hwt1 as 10.163.155.13 and 49.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49
display hwtacacs
reset hwtacacs statistics
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
1: Monitor level
accounting: Specifies the HWTACACS accounting statistics.
all: Specifies all HWTACACS statistics.
authentication: Specifies the HWTACACS authentication statistics.
authorization: Specifies the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
display hwtacacs
reset stop-accounting-buffer (for HWTACACS)
Use reset stop-accounting-buffer to clear the buffered stop-accounting requests for which no responses have been received.
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
2: System level
# Clear the stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
retry stop-accounting (HWTACACS scheme view)
The maximum number of stop-accounting request transmission attempts is 100.
2: System level
retry-times: Maximum number of stop-accounting request transmission attempts, ranging from 1 to 300.
# Set the maximum number of stop-accounting request transmission attempts to 50 for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] retry stop-accounting 50
secondary accounting (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
secondary accounting ip-address [ port-number ]
No secondary HWTACACS accounting server is specified.
2: System level
ip-address: IP address of the secondary HWTACACS accounting server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the secondary HWTACACS accounting server. It ranges from 1 to 65535 and defaults to 49.
# Specify the IP address and port number of the secondary accounting server for HWTACACS scheme hwt1 as 10.163.155.12 with TCP port number 49.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49
display hwtacacs
secondary authentication (HWTACACS scheme view)
Use secondary authentication to specify a secondary HWTACACS authentication server.
secondary authentication ip-address [ port-number ]
No secondary HWTACACS authentication server is specified.
2: System level
ip-address: IP address of the secondary HWTACACS authentication server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the secondary HWTACACS authentication server. It ranges from 1 to 65535 and defaults to 49.
You can remove an authentication server only when it is not used by any active TCP connection to send authentication packets is using it. Removing an authentication server only affects authentication processes that occur after the remove operation.
# Specify the IP address and port number of the secondary authentication server for HWTACACS scheme hwt1 as 10.163.155.13 with TCP port number 49.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49
display hwtacacs
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove the configuration.
secondary authorization ip-address [ port-number ]
No secondary HWTACACS authorization server is specified.
2: System level
ip-address: IP address of the secondary HWTACACS authorization server in dotted decimal notation. The default is 0.0.0.0.
port-number: Service port number of the secondary HWTACACS authorization server. It ranges from 1 to 65535 and defaults to 49.
The IP addresses of the primary and secondary authorization servers cannot be the same. Otherwise, the configuration fails.
# Configure the secondary authorization server 10.163.155.13 with TCP port number 49.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49
display hwtacacs
stop-accounting-buffer enable (HWTACACS scheme view)
2: System level
Stop-accounting requests affect the charge to users. A NAS must make its best effort to send every stop-accounting request to the HWTACACS accounting servers. For each stop-accounting request that receives no response in the specified period of time, the NAS buffers and resends the packet until it receives a response or until the number of transmission attempts reaches the configured limit. In the latter case, the NAS discards the packet.
# In HWTACACS scheme hwt1, enable the device to buffer the stop-accounting requests that receive no responses.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the primary server.
timer quiet minutes
undo timer quiet
The primary server quiet period is 5 minutes.
2: System level
minutes: Primary server quiet period. The value ranges from 1 to 255, in minutes.
When the primary server is found unreachable, the device changes the status of the server from active to blocked and keeps the server in blocked state until the quiet timer expires.
# Set the quiet timer for the primary server to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
display hwtacacs
timer response-timeout (HWTACACS scheme view)
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
2: System level
seconds: HWTACACS server response timeout period in seconds, ranging from 1 to 300.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
# Set the HWTACACS server response timeout timer to 30 seconds for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
display hwtacacs
user-name-format (HWTACACS scheme view)
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
2: System level
keep-original: Sends the username to the HWTACACS server as it is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the format userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. Some earlier HWTACACS servers, however, cannot recognize a username that includes an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the HWTACACS scheme to more than one ISP domain. This avoids the confusing situation in which the HWTACACS server regards two users in different ISP domains but with the same userid as one.
If the HWTACACS scheme is used for wireless users, specify the keep-original keyword. Otherwise, authentication of the wireless users may fail.
# Specify the device to remove the ISP domain name in the username sent to the HWTACACS servers for the HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
