H3C WA4320i-X Access Point Installation Guide-6W101
HomeSupportWirelessH3C WA4300 Series Access PointsInstall & UpgradeInstallation GuidesH3C WA4320i-X Access Point Installation Guide-6W101
01-Text
01-Text 1.22 MB
Product overview
An H3C WA4320i-X AP can act as a fit AP to cooperate with wireless switches or access controllers to provide wireless access for WLAN users. The network settings are configured on the wireless switches or access controllers. The WA4320i-X can also act as a fat AP to provide wireless access for WLAN users.
Table 1 H3C WA4320i-X specifications
Item
Specification
Protocol
·         IEEE 802.11a/b/g/n/ac
·         Dual-radio
Antennas
External antennas
Power consumption
3.95 to 12.95 W
Dimensions (H × W × D)
54 × 220 × 220 mm (2.13 × 8.66 × 8.66 in)
Weight
0.75 kg (1.65 lb)
Preparing for installation
Safety recommendations
WARNING
WARNING!
Only qualified personnel can install and remove the AP and its accessories. You must read all safety instructions supplied with the AP before installation and operation.
To avoid possible bodily injury and equipment damage, read the following safety recommendations before installing the AP. Note that the recommendations do not cover every possible hazardous condition.
·          Take adequate safety measures to avoid injury and AP damage.
·          Place the AP in a dry and flat location and take anti-slip measures.
·          Keep the AP clean and dust-free.
·          Do not place the AP in a moist area and avoid liquid surrounding the AP.
·          Keep the AP and installation tools away from walkways.
Temperature and humidity requirements
Item
Specification
Operating temperature (indoor)
–10°C to +55°C (14°F to 131°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity (noncondensing)
5% to 95%
Accessories provided with the AP
Mounting kit
Three sets of M4 × 30 pan head screw, washer, and nut
Three sets of wall anchor kit
MAC address label
Console cable
(for fat AP only)
One M4 × 10 pan head screw
Installation tools and equipment
When installing the AP, you may need the following tools. Prepare these tools and equipment yourself.
Needle-nose pliers
Wire-stripping pliers
Diagonal pliers
Marker
Percussion drill with matching drills
Rubber hammer
Phillips screwdriver
Installing the AP
IMPORTANT
IMPORTANT:
The AP is typically installed on a high position. As a best practice, log in to and configure the AP before the installation. For more information about logging in to the AP, see “Logging in to the AP.”
Figure 1 Installation flowchart
Check before installation
Before installing an AP, perform the following tasks:
·          Connect the AP to the power supply and the network. Examine the LEDs to verify that the AP can operate correctly. For more information about AP LEDs, see "Appendix LEDs and ports."
·          Verify that cabling on the installation site has been completed.
·          To ensure the PoE performance, use GE interfaces for PoE power supply as a best practice.
·          Record the AP MAC address and serial number marked on the rear of the AP for future use.
Determining the installation position
You can mount the AP to a wall or ceiling. Determine the installation position by observing the following principles:
·          Few obstacles such as wall and ceiling exist between AP and clients.
·          The AP is far away from electronic devices (such as microwave oven) that may generate radio frequency (RF) noise.
·          The AP does not hinder people’s daily work and life.
·          The place is not water seeping, water soaking, and condensing.
·          A lightning arrester (user supplied) is installed on the AP for cabling outdoors.
·          Install the AP more than 5 m (16.40 ft) away from 3G/4G base stations and antennas.
Installing the AP
Mounting the AP on a wall
1.        Align the screw hole in the AP bracket with the screw hole in the AP rear. Use the M4 × 10 screw to secure the AP bracket to the AP.
Figure 2 Attaching the AP bracket to the AP rear
2.        Mark the installation holes on the wall by using the mounting bracket, as shown in Figure 3.
Figure 3 Mounting holes in the mounting bracket
Figure 4 Marking installation holes on the wall
3.        Drill holes with a diameter of 5 mm (0.197 in) and a depth of 30 mm (1.18 in) in the marked locations, as shown in Figure 5.
Figure 5 Drilling holes in the wall
4.        Insert a wall anchor into each hole, and tap the wall anchor with a rubber hammer until it is all flush with the wall surface, as shown in Figure 6.
Figure 6 Hammering the anchor
5.        Align the mounting holes in the mounting bracket with the anchors and insert screws through the mounting holes into the wall anchors. Adjust the position of the mounting bracket and tighten the screws.
Figure 7 Attaching the mounting bracket to the wall
6.        Connect the AP to the LAN by using Ethernet cables.
7.        Align the AP at a 45 degree angle with the mounting bracket, and rotate the AP clockwise until it clicks into place, as shown in Figure 8.
Figure 8 Attaching the AP to the wall mounting bracket
Installing the AP on a ceiling
CAUTION
CAUTION:
The ceiling for installing the AP must be less than 18 mm (0.71 in) in thickness, and can bear a load of 5 kg (11.02 lb). As a best practice, reinforce the ceiling by using boards if the ceiling is not strong enough.
To install the AP on a ceiling:
Figure 9 Attaching the AP bracket to the AP rear
2.        Mark the installation holes on the ceiling by using the mounting bracket.
3.        Drill holes with a diameter of 5 mm (0.197 in) in the marked positions, as shown in Figure 10.
Figure 10 Drilling holes in the ceiling
4.        Insert the M4 × 30 pan head screws through the mounting holes in the mounting bracket and the holes in the ceiling. Fasten washers and nuts at the other side of the ceiling to attach the mounting bracket to the ceiling, as shown in Figure 11.
Figure 11 Attaching the mounting bracket to the ceiling
5.        Connect the AP to the LAN by using Ethernet cables.
6.        Align the AP with the mounting bracket and rotate the AP clockwise until it clicks into place, as shown in Figure 12.
Figure 12 Attaching the AP to the ceiling mounting bracket
7.        Verify that the AP is securely installed to prevent it from falling off.
Connecting the external antennas
The AP provides eight antenna connectors. Connect external antennas to the connectors through feeder lines to achieve best wireless coverage.
To provide wireless services for eight separate rooms, connect feeder lines and external antennas as shown in Figure 13.
Figure 13 Connecting the external antennas (1)
For the best wireless performance, use 2 × 2 MIMO antennas and two-wire feeder lines to provide wireless services for four rooms as shown in Figure 14.
Figure 14 Connecting the external antennas (2)
Connecting the AP to a power supply
CAUTION
CAUTION:
Before powering on the AP, make sure the power supply is reliably grounded.
You can power the AP with a local power or by using 802.3af PoE.
Connecting a PoE power supply
Use an Ethernet cable to connect the Ethernet interface that supports PoE on the AP to a PoE switch.
Figure 15 Connecting a PoE power supply
(1) Ethernet interface
(2) Ethernet cable
(3) PoE switch
Connecting the local power supply
No AC/DC adapter and power cord are provided with the AP. Prepare them yourself if required.
Table 2 AC/DC adapter specifications
Item
Specification
Input
100 VAC to 240 VAC
Output
+48V at 0.52 A
You can power the AP by using an AC/DC adapter. Use the AC/DC adapter to connect the power port of the AP to the local power source.
Figure 16 Connecting the local power supply
(1) Power port
(2) AC/DC adapter
(3) Power source
Check after power-on
Verify that the AP is powered on and operating correctly by examining the AP status LED. For more information about AP LEDs, see "Appendix LEDs and ports."
Connecting the AP to the network
Connect an Ethernet port of the AP to an Ethernet port of an Ethernet switch for Internet or MAN access.
Verifying network connection for the fit AP
All settings of the fit AP are configured on the AC. Use the display wlan ap all command on the AC that connects to the fit AP. If the AP status is R/M, the AP is connected to the network.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3070
Total AP licenses: 128
Remaining AP licenses: 127
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID                        State                        Model                        Serial ID
ap1                                 1                             R                             WA4320i-X                  210235A1GSB139000435
Verifying network connection for the fat AP
Use the ping command on the fat AP to ping the uplink network device. If the ping operation succeeds, the AP is connected to the network successfully.
IMPORTANT
IMPORTANT:
This section applies only when the AP acts as a fat AP. When the AP acts as a fat AP, you can log in to the AP through the console port, or through Telnet or Web to configure it. Login through the console port is the prerequisite to configuring other login methods. Before you log in to the fat AP through Telnet or Web, obtain the IP address of the AP first.
Logging in through the console port
Prepare the following items before logging in through the console port:
·          An 8-core console cable, with a crimped RJ-45 connector at one end, and a DB-9 connector at the other end.
·          A configuration terminal with a serial port, such as a laptop or PC.
Setting up the configuration environment
CAUTION
CAUTION:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Connecting the console cable
1.        Connect the DB-9 connector to the serial port of the PC.
2.        Connect the RJ-45 connector to the console port of the AP.
Figure 17 Connecting the console cable
Setting terminal parameters
1.        Start the PC and run the terminal emulation program such as the HyperTerminal of Windows 95/98/NT/2000/XP.
2.        Select Start > All Programs > Accessories > Communications > HyperTerminal, and in the Connection Description dialog box that appears, type the name of the new connection in the Name text box and click OK.
Figure 18 Connection description
3.        Select the serial port to be used from the Connect using drop-down list, and click OK.
Figure 19 Selecting the serial port used by the HyperTerminal connection
4.        Set Bits per second to 9600, Data bits to 8, Parity to None, Stop bits to 1, and Flow control to None, and click OK.
Figure 20 Setting the serial port parameters
To use the default settings, click Restore Defaults.
5.        Click OK and the system displays the HyperTerminal window.
Figure 21 HyperTerminal window
Power on the AP, and you can see the following information:
System is starting...
Booting Normal Extend BootWare.
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
Logging in through Telnet or Web
By default, Telnet login and Web login are enabled. You can log in to the AP by using the following default login information:
·          Usernameadmin.
·          Passwordh3capadmin.
·          IP address of VLAN-interface 1 of the AP192.168.0.50 with subnet mask 255.255.255.0.
If the default IP address is changed, perform either of the following tasks:
¡  Contact the administrator to get the new IP address.
¡  Log in to the AP from the console port and execute the display vlan 1 command to view the IP address.
A
accessories for AP installation, 2
antenna
AP, 10
AP
ceiling-mounting, 7
connecting console cable, 14
console port access, 14, 16
installation, 4, 5
installation accessories, 2
logging, 14
setting configuration environment, 14
setting terminal parameters, 15
Telnet access, 17
wall-mounting, 5
Web access, 17
B
bits per second (parameter), 15
C
cable
connecting console, 14
ceiling-mounting
AP, 7
check after power-on, 12
check before installation, 4
configuring
AP, 14
connecting
console cable, 14
external antenna, 10
local power supply, 11
network, 12
PoE power supply, 11
power supply, 11
console
connecting cable, 14
D
data bits (parameter), 15
determining installation position, 4
E
electrical
connecting local power supply, 11
connecting PoE power supply, 11
connecting power supply, 11
emulation (parameter), 15
environment
site humidity, 2
site temperature, 2
equipment needed for installation, 3
F
flow control (parameter), 15
H
hardware
AP installation, 4, 5
humidity (installation site), 2
I
determining, 4
installing
AP, 4, 5
equipment, 3
safety recommendations, 2
site humidity, 2
site temperature, 2
tools, 3
L
local power supply
AP, 11
logging
AP, 14
logging through console port
AP, 14, 16
logging through Telnet
AP, 17
logging through Web
AP, 17
login
AP, 14
N
network connection verification
fat AP, 13
fit AP, 12
networking
AP, 12
P
parity (parameter), 15
PoE power supply
AP, 11
post-power-on
check, 12
power supply
AP, 11
pre-installation
check, 4
preparing for installation, 2
procedure
connecting AP to network, 12
connecting external antenna, 10
installing AP, 4, 5
installing the AP on a ceiling, 7
mounting the AP on a wall, 5
verifying network connection for the fat AP, 13
verifying network connection for the fit AP, 12
product overview, 1
S
safety
installation site humidity, 2
installation site temperature, 2
recommendations, 2
setting
AP configuration environment, 14
site
humidity, 2
temperature, 2
stop bits (parameter), 15
T
temperature
installation site requirements, 2
tools needed for installation, 3
V
verifying
VT100, 15
W
wall-mounting
AP, 5
