H3C WA4320i-ACN Access Point Installation Guide-6W101
HomeSupportWirelessH3C WA4300 Series Access PointsInstall & UpgradeInstallation GuidesH3C WA4320i-ACN Access Point Installation Guide-6W101
00-Preface
00-Preface 102.89 KB
Preface
The H3C WA4320i-ACN Access Point Installation Guide guides you through the installation of your AP. It covers product overview, preparing for installation, installing the AP, logging in to the AP, and LEDs and ports.
·          Audience.
·          Conventions.
·          Obtaining documentation.
·          Technical support
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the WA4320i-ACN APs.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
To access the most up-to-date H3C product documentation, go to the H3C website at http://www.h3c.com.hk.
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
You can email your comments about product documentation to [email protected].
We appreciate your comments.
