12-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR810 2600 3600 Routers Command References(V7)-R0707-6W30112-Security Command Reference
13-Group domain VPN commands
13-Group domain VPN commands 92.91 KB
The following compatibility matrix shows the support of hardware platforms for group domain VPN:
Hardware
Group domain VPN compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
Yes
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3610-I-DP, MSR3610-IE-DP
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
client anti-replay window
Use client anti-replay window to set the anti-replay window size for a GDOI GM group.
Use undo client anti-replay window to restore the default.
client anti-replay window { sec seconds | msec milliseconds }
The anti-replay window size is not set for a GDOI GM group.
GDOI GM group view
sec seconds: Specifies the anti-replay window size in seconds in the range of 1 to 100.
msec milliseconds: Specifies the anti-replay window size in milliseconds in the range of 100 to 10000.
The anti-replay window size set in this command takes precedence over the anti-replay window size obtained from the KS.
This command must be used together with the Cisco IP-D3P feature.
# Set the anti-replay window size to 50 seconds for GDOI GM group group1.
[Sysname] gdoi gm group group1
[Sysname-gdoi-gm-group-group1] client anti-replay window sec 50
display gdoi gm anti-replay
client registration
Use client registration to specify a registration interface for a GM in a GDOI GM group. The GM uses the registration interface to send packets to the KS.
Use undo client registration to restore the default.
client registration interface interface-type interface-number
undo client registration interface
A GM uses the output interface of the route to the KS as the registration interface.
GDOI GM group view
interface interface-type interface-number: Specifies a registration interface by its type and number.
The default registration interface of a GM is the output interface of the route from the GM to the KS. The interface might also be used for traffic forwarding. When a lot of traffic travels through the interface, packet exchange between the GM and the KS is affected. To resolve the problem, specify an interface that is not used for traffic forwarding as the registration interface.
A GM uses the primary IPv4 address of the registration interface as the source address to register with the KS.
For a successful GM registration, make sure the registration interface and a KS in the GDOI GM group belong to the same VRF.
# In GDOI GM group abc, specify GigabitEthernet 1/0/1 as the registration interface for the GM.
[Sysname] gdoi gm group abc
[Sysname-gdoi-gm-group-abc] client registration interface gigabitethernet 1/0/1
gdoi gm group
client rekey encryption
Use client rekey encryption to specify KEK encryption algorithms supported by a GM.
Use undo client rekey encryption to restore the default.
In non-FIPS mode:
client rekey encryption { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | des-cbc } *
In FIPS mode:
client rekey encryption { aes-cbc-128 | aes-cbc-192 | aes-cbc-256 } *
In non-FIPS mode:
A GM supports DES-CBC, 3DES-CBC, AES-CBC-128, AES-CBC-192, and AES-CBC-256.
In FIPS mode:
A GM supports AES-CBC-128, AES-CBC-192, and AES-CBC-256.
GDOI GM group view
des-cbc: Specifies the DES algorithm in CBC mode, which uses a 64-bit key.
3des-cbc: Specifies the 3DES algorithm in CBC mode, which uses a 168-bit key.
aes-cbc-128: Specifies the AES algorithm in CBC mode that uses a 128-bit key.
aes-cbc-192: Specifies the AES algorithm in CBC mode that uses a 192-bit key.
aes-cbc-256: Specifies the AES algorithm in CBC mode that uses a 256-bit key.
This command specifies the KEK encryption algorithms supported in registration and rekey processes.
·     During GM registration, a GM terminates the negotiation with the KS if the KEK encryption algorithm sent by the KS is not supported, and the registration fails.
·     During rekey, the GM discards rekey messages received from the KS if the KEK encryption algorithm sent by the KS is not supported.
# Specify the supported KEK encryption algorithm as AES-CBC-128 for GDOI GM group abc.
[Sysname-gdoi-gm-group-abc] client rekey encryption aes-cbc-128
gdoi gm group
client transform-sets
Use client transform-sets to specify IPsec transform sets supported by a GM.
Use undo client transform-sets to restore the default.
client transform-sets transform-set-name&<1-6>
A GM supports the IPsec transform set configured with the following security parameters:
·     The ESP security protocol.
·     The tunnel or transport encapsulation mode.
·     The DES-CBC, 3DES-CBC, AES-CBC-128, AES-CBC-192, or AES-CBC-256 encryption algorithm.
·     The MD5 or SHA1 authentication algorithm.
GDOI GM group view
transform-set-name&<1-6>: Specifies a space-separated list of up to six IPsec transform sets by their names. An IPsec transform set name is a case-insensitive string of 1 to 63 characters.
This command specifies the IPsec transform sets supported in registration and rekey processes.
·     During GM registration, a GM terminates the negotiation with the KS if the IPsec transform set sent by the KS is not supported, and the registration fails.
·     During rekey, the GM discards rekey messages received from the KS if the IPsec transform set sent by the KS is not supported.
GMs support only the ESP security protocol. For a successful registration, do not specify an IPsec transform set that uses the AH security protocol for GMs.
# Specify the supported IPsec transform set as gdoi-esp-aes for GDOI GM group abc.
[Sysname-gdoi-gm-group-abc] client transform-sets gdoi-esp-aes
gdoi gm group
display gdoi gm
Use display gdoi gm to display GDOI GM group information, including GDOI configuration parameters, negotiation parameters, and the IPsec information obtained after successful registrations.
display gdoi gm [ group group-name ]
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays information about all GDOI GM groups.
# Display information about all GDOI GM groups.
<Sysname> display gdoi gm
Group name: GDOI-GROUP1
  Group identity             : 12345
  Address family             : IPv4
  Rekeys received            : 1
  Group server               : 90.1.1.1
    VRF name                 : vrf1
  Group server               : 90.1.1.2
  Group member               : 80.1.1.1
    VRF name                 : vrf1
    Registration status      : Registered
    Registered with          : 90.1.1.1
    Re-register in           : 346 sec
    Succeeded registrations  : 1125
    Attempted registrations  : 1133
    Last rekey from          : 90.1.1.1
    Last rekey seq num       : 3
    Multicast rekeys received: 1
  Allowable rekey cipher     : Any
  Allowable rekey hash       : Any
  Allowable transform        : Any
  Rekeys cumulative:
    Total received                  : 5
    Rekeys after latest registration: 3
    Last rekey received for         : 00hr 02min 11sec
  ACL downloaded from KS 90.1.1.1:
    rule 0 deny udp source-port eq 848 destination-port eq 848
    rule 1 deny ospf
    rule 2 permit icmp
  KEK:
    Rekey transport type       : Multicast
    Remaining key lifetime     : 159 sec
    Encryption algorithm       : AES-CBC
    Key size                   : 128
    Signature algorithm        : RSA
    Signature hash algorithm   : SHA1
    Signature key length       : 1024 bits
  TEK:
    SPI                        : 0x9AE5951E(2598737182)
    Transform                  : ESP-ENCRYPT-AES-128 ESP-AUTH-SHA1
    Remaining key lifetime     : 190 sec
    SPI                        : 0x12C55CFF(314924287)
    Remaining key lifetime     : 402 sec
# Display information about GDOI GM group GDOI-GROUP2.
<Sysname> display gdoi gm group GDOI-GROUP2
Group name: GDOI-GROUP2
  Rekeys received            : 52
    VRF name                 : vrf1
  Group server               : keyserver
    VRF name                 : vrf1
    Registered with          : keyserver(90.1.1.2)
    Re-register in           : 143 sec
    Succeeded registrations  : 10
    Attempted registrations  : 15
    Last rekey from          : 90.1.1.2
    Last rekey seq num       : 13
    Unicast rekeys received  : 10
    Rekey ACKs sent          : 10
  Rekeys cumulative:
    Total received                  : 52
    Total rekey ACKs sent           : 23
  ACL downloaded from KS 90.1.1.2:
    rule 1 deny ospf
    rule 2 permit icmp
  KEK:
    Rekey transport type       : Unicast
    Key size                   : 128
  TEK:
Group name
GDOI GM group name.
Group identity
GDOI GM group ID (a number or an IPv4 address).
N/A indicates that the group is not configured with an ID.
Address family
Address family of data flows protected by the GDOI GM group, IPv4 or IPv6.
Rekeys received
Number of rekey messages received.
Group server
IP addresses or host names of KSs in the GDOI GM group. A group supports a maximum of 16 KS IP addresses or host names.
VRF name
Name of the VRF to which the KS belongs. If the KS belongs to the public network, this field is not displayed.
Group member
IP address of the GM.
VRF name
Name of the VRF to which the GM belongs. If the GM belongs to the public network, this field is not displayed.
Registration status
Registration status: Registered, Registering, or Not registered.
Registered with
IP address or host name of the KS with which the GM registers.
If a host name is displayed, this field also displays the IP address of the host in brackets.
Re-register in
Period of time after which the GM re-registers with a KS.
N/A indicates that the GM does not re-register with a KS.
Number of successful registrations.
Number of registration attempts.
Last rekey from
KS from which the GM receives the last rekey message.
N/A indicates that the GM does not receive any rekey messages.
Last rekey seq num
Sequence number of the last received rekey message.
Number of multicast rekeys received. This field is displayed only when the GDOI GM group is a multicast group.
Number of unicast rekeys received. This field is displayed only when the GDOI GM group is a unicast group.
Rekey ACKs sent
Number of rekey ACK messages sent. This field is displayed only when the GDOI GM group is a unicast group.
Rekey encryption algorithms that the GM allows. Any indicates that the GM allows all encryption algorithms.
Rekey hash algorithms that the GM allows. Any indicates that the GM allows all hash algorithms.
Allowable transform
Rekey transform modes that the GM allows. Any indicates that the GM allows all transform modes.
Rekeys cumulative
Rekey statistics.
Total received
Total number of rekeys that the GM has received.
Number of rekeys that the GM has received after the last successful registration.
Period of time for which the key has existed after the last rekey operation. N/A indicates that no rekey message is received. This field is displayed only in multicast mode.
Number of rekey ACK messages sent. This field is displayed only in unicast mode.
ACL information downloaded from the KS at 90.1.1.1.
UDP packets whose source and destination port numbers are both 848 do not need to be protected by IPsec.
rule 1 deny ospf
OSPF protocol packets do not need to be protected by IPsec.
rule 2 permit icmp
All ICMP packets need to be protected by IPsec.
KEK
KEK information.
Transport type of rekey messages: Multicast or Unicast.
KEK lifetime in seconds.
Encrypt algorithm
KEK encryption algorithm.
Key size
KEK key length.
Signature algorithm
KEK signature algorithm.
KEK signature hash algorithm.
KEK signature key length in bits.
TEK
TEK information.
SPI
SPI of the IPsec SA.
Transform
Transform set list.
IPsec SA remaining lifetime in seconds.
display gdoi gm acl
Use display gdoi gm acl to display ACL information for the GM.
display gdoi gm acl [ download | local ] [ group group-name ]
download: Displays the ACL information that the GM downloaded from the KS.
local: Displays the ACL information locally configured on the GM.
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays ACL information for all GM groups.
If you do not specify any parameters, this command displays information about all ACLs for all GM groups, including the downloaded ACLs and the locally configured ACLs. A locally configured ACL refers to the ACL used by the GDOI IPsec policy.
# Display information about all ACLs for all GM groups.
<Sysname> display gdoi gm acl
Group name: abc
  ACL downloaded from KS 12.1.1.100:
    rule 0 permit ip
    rule 1 permit ip source 12.1.1.0 0.0.0.255 destination 12.1.1.0 0.0.0.255
  ACL configured locally:
    IPsec policy name: gdoi-group1
      ACL identifier: 3001
        rule 0 deny ip source 10.1.1.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
Group Name: 123
rule 1 permit ip source 13.1.1.0 0.0.0.255 destination 13.1.2.0 0.0.0.255
Group name: ipv6
      IPv6 ACL identifier: 3001
        rule 0 permit ipv6 source 1::/64 destination 2::/64
# Display information about ACLs that the GM downloaded from the KS.
<Sysname> display gdoi gm acl download
Group name: abc
    rule 0 permit ip
# Display information about ACLs that are locally configured on the GM.
<Sysname> display gdoi gm acl local
Group name: abc
Group name
GDOI GM group name.
rule 0 permit ip
IPsec protects any IP packets.
IPsec protects IP packets whose source and destination addresses are within subnet 12.1.1.0/24.
IPsec does not protect IP packets whose source and destination addresses are within subnet 10.1.1.0/24.
Use display gdoi gm anti-replay to display anti-replay information for GDOI GM groups.
display gdoi gm anti-replay [ group group-name ]
group group-name: Specifies a GDOI GM group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays anti-replay information for all GDOI GM groups.
# Display anti-replay information for all GDOI GM groups.
<Sysname> display gdoi gm anti-replay
Group name: abc
  Anti-replay timestamp type         : POSIX-TIME
  Anti-replay window                 : 200.16 ms
display gdoi gm ipsec sa
Use display gdoi gm ipsec sa to display IPsec SA information obtained by the GM.
display gdoi gm ipsec sa [ group group-name ]
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays IPsec SA information obtained by all GM groups.
# Display IPsec SA information obtained by all GM groups.
<Sysname> display gdoi gm ipsec sa
SA created for group abc:
  SPI                    : 0x9AE5951F(2598737183)
  Remaining key lifetime : 3600 sec
SA created for group hh:
  SPI                    : 0xDCC66F7B(3703992187)
  Remaining key lifetime : 280 sec
IPsec SAs created for the GDOI GM group abc.
SPI
Transform
Transform set.
Remaining lifetime of the IPsec SA, in seconds.
display gdoi gm members
Use display gdoi gm members to display brief information about the GM.
display gdoi gm members [ group group-name ]
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays brief information about all GM groups.
# Display brief information about all GM groups.
<Sysname> display gdoi gm members
Group member information for group GDOI-GROUP1:
    VRF name                 : vrf1
    Re-register in           : 308 sec
    Succeeded registrations  : 1131
    Attempted registrations  : 1139
Brief information about GMs of the GDOI GM group GDOI-GROUP1.
Group member
VRF name
Registration status
Registered with
If the host name is displayed, this field also displays the IP address of the host in brackets.
Re-register in
Last rekey from
Last rekey seq num
Rekey ACKs sent
display gdoi gm pubkey
Use display gdoi gm pubkey to display public key information received by the GM.
display gdoi gm pubkey [ group group-name ]
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays the public key information received by all GM groups.
# Display public key information received by all GM groups.
<Sysname> display gdoi gm pubkey
  KS address: 90.1.1.1
  Conn-ID: 2044    My cookie: 7C9CB398    His cookie: 4E54C7EA
  Key data:
    30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00BB0F5B
    6B5788E7 6220C0C1 C4BCAAD7 D81322FF 7DB9436E 46E308DA D589243B 64946D2D
    FC502F64 7F38DDF5 E999F8F7 4A247508 9AF7765B F0B080AC 11CC08E4 B48A976F
    D3721818 B66201F0 BD1987BE DD28D533 C38E7D42 939D2B71 3FAAA17A 128DF862
    E45C531D A0C8593E D7D602E9 7A7E675A 94AF6B25 2972CF85 94E601BD 19020301
    0001
Table 5 Command output
Group name
GDOI GM group name.
KS address
IPv4 or IPv6 address of the KS.
Conn-ID
ID of the rekey SA.
My cookie
Local cookie of the rekey SA.
His cookie
Peer cookie of the rekey SA.
Key data
Public key data.
display gdoi gm rekey
Use display gdoi gm rekey to display rekey information for the GM.
display gdoi gm rekey [ verbose ] [ group group-name ]
verbose: Displays detailed rekey information for the GM. If you do not specify this keyword, the command displays brief rekey information for the GM.
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command displays rekey information for all GM groups.
# Display brief rekey information for all GM groups.
<Sysname> display gdoi gm rekey
Group name: abc (Unicast)
  Number of rekeys received (cumulative)       : 9
  Number of rekeys received after registration : 9
  Number of rekey ACKs sent                    : 105
Group name: 123 (Multicast)
  Multicast destination address                : 239.192.1.190
# Display detailed rekey information for all GM groups.
<Sysname> display gdoi gm rekey verbose
Group name: GDOI-GROUP1 (Multicast)
  Number of rekeys received (cumulative)       : 1904
  Number of rekeys received after registration : 889
Rekey (KEK) SA information:
            Destination     Source            Conn-ID  My cookie  His cookie
New       : 239.192.1.190   90.1.1.1          9646     14406D26   8C58E504
Current   : 239.192.1.190   90.1.1.1          9646     14406D26   8C58E504
Previous  : ---             ---               ---      ---        ---
Table 6 Command output
Group name
GDOI GM group name.
Unicast
Unicast rekey transport type.
Multicast
Multicast rekey transport type.
Multicast destination address of the rekey messages.
SA that protects the rekey messages.
Destination
Destination IP address of the rekey SA.
Source
Source IP address of the rekey SA.
Conn-ID
ID of the rekey SA.
My cookie
His cookie
New
Information about the new rekey SA.
Current
Information about the currently used rekey SA.
Previous
Information about the most recently used rekey SA.
gdoi gm group
Use gdoi gm group to create a GDOI GM group and enter its view, or enter the view of an existing GDOI GM group.
Use undo gdoi gm group to delete a GDOI GM group.
gdoi gm group [ ipv6 ] group-name
undo gdoi gm group [ ipv6 ] group-name
No GDOI GM groups exist.
ipv6: Specifies an IPv6 GDOI GM group. If you do not specify this keyword, the command creates an IPv4 GDOI GM group.
group-name: Specifies a name for the GDOI GM group, a case-insensitive string of 1 to 63 characters.
IPv4 GDOI GM groups and IPv6 GDOI GM groups share the same namespace. You cannot specify the same name for an IPv4 GDOI GM group and an IPv6 GDOI GM group.
# Create a GDOI GM group named abc, and enter its view.
group
Use group to specify a GDOI GM group for a GDOI IPsec policy.
Use undo group to restore the default.
group group-name
undo group
No GDOI GM group is specified for a GDOI IPsec policy.
GDOI IPsec policy view
group-name: Specifies the name of a GDOI GM group, a case-insensitive string of 1 to 63 characters.
You can specify only one GDOI GM group for a GDOI IPsec policy. If you execute this command multiple times, the most recent configuration takes effect.
A GDOI GM group can be specified for entries of different GDOI IPsec policies, but it cannot be specified for entries of the same GDOI IPsec policy.
An IPv6 GDOI GM group can be specified only for an IPv6 GDOI IPsec policy. An IPv4 GDOI GM group can be specified only for an IPv4 GDOI IPsec policy.
# Create a GDOI IPsec policy entry, and specify the IPsec policy name as map and the sequence number as 1.
[Sysname] ipsec policy map 1 gdoi
# Specify GDOI GM group abc for the GDOI IPsec policy.
[Sysname-ipsec-policy-gdoi-map-1] group abc
gdoi gm group
ipsec { ipv6-policy | policy }
identity
Use identity to configure an ID for a GDOI GM group.
Use undo identity to restore the default.
identity { address ip-address | number number }
undo identity
No ID is configured for a GDOI GM group.
GDOI GM group view
address ip-address: Specifies any valid IPv4 address to identify the GDOI GM group.
number number: Specifies a number in the range of 0 to 2147483647 to identify the GDOI GM group.
Only GMs in the same GDOI GM group can communicate with each other.
# Configure the ID for GDOI GM group abc as 123456.
[Sysname-gdoi-gm-group-abc] identity number 123456
# Configure the ID for GDOI GM group def as 202.202.202.10.
[Sysname] gdoi group def
[Sysname-gdoi-gm-group-def] identity address 202.202.202.10
reset gdoi gm
Use reset gdoi gm to clear GDOI information that the GM downloaded from a KS, and trigger the GM to re-register with the KS.
reset gdoi gm [ group group-name ]
group group-name: Specifies a GDOI GM group by its name. A GDOI GM group name is a case-insensitive string of 1 to 63 characters. If you do not specify a group, this command clears GDOI information for all GM groups.
The downloaded GDOI information includes the IKE SA, rekey SA, IPsec SA, and ACL.
# Clear GDOI information for all GM groups, and trigger the GM to re-register with the KS.
<Sysname> reset gdoi gm
# Clear GDOI information for GDOI GM group abc, and trigger the GM to re-register with the KS.
<Sysname> reset gdoi gm group abc
server address
Use server address to specify the IP address of a key server (KS).
Use undo server address to delete a KS IP address.
server address host [ vrf vrf-name ]
undo server address host [ vrf vrf-name ]
No KS IP address is specified.
GDOI GM group view
host: Specifies a KS IP address, a case-sensitive string of 1 to 253 characters.
vrf vrf-name: Specifies the VRF to which the KS IP address belongs. The vrf-name argument represents the VRF name, a case-sensitive string of 1 to 31 characters. If you do not specify a VRF, the KS IP address belongs to the public network.
You must specify KSs for GMs in a GDOI GM group.
A GDOI GM group can have a maximum of 16 KS addresses. A GM first sends a registration request to the first-specified KS. If the registration fails before the registration timer expires, the GM registers with other KSs one by one in the order they are configured until the registration succeeds. If all registration attempts fail, the GM repeats the registration process.
# Specify two KS addresses, 3.3.3.3 and 3.3.3.4, for GDOI GM group abc.
[Sysname-gdoi-gm-group-abc] server address 3.3.3.3
[Sysname-gdoi-gm-group-abc] server address 3.3.3.4
