07-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR810 2600 3600 Routers Command References(V7)-R0707-6W30107-Layer 3—IP Services Command Reference
16-Tunneling commands
16-Tunneling commands 167.08 KB
Tunneling commands
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) is the interface maximum rate divided by 1000.
Tunnel interface view
bandwidth-value: Specifies the expected bandwidth, in the range of 1 to 400000000 kbps.
The expected bandwidth for an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for Tunnel 1 to 100 kbps.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] bandwidth 100
default
Use default to restore the default settings for a tunnel interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of Tunnel 1.
[Sysname-Tunnel1] default
description
The description of a tunnel interface is Tunnelnumber Interface, for example, Tunnel1 Interface.
Configure descriptions for different interfaces for identification and management purposes.
You can use the display interface command to display the configured interface description.
# Configure the description of Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
display interface tunnel
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to restore the default.
destination { ipv4-address | ipv6-address | dhcp-alloc interface-type interface-number }
undo destination
No tunnel destination address is configured.
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
dhcp-alloc interface-type interface-number: Specifies an interface by its type and number to obtain AFTR's IPv6 address from DHCPv6 packets.
For a manual tunnel interface, you must configure the destination address. For an automatic tunnel interface, you do not need to configure the destination address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface. The source address of the local tunnel interface must be the destination address of the peer tunnel interface.
Do not specify the same tunnel source and destination addresses for the tunnel interfaces on the same device.
For a B4 router to automatically establish a DS-Lite tunnel with an AFTR, configure DHCPv6 client, IPv6 DNS client, and the destination dhcp-alloc command on the B4 router. In addition, make sure a DHCPv6 server and an IPv6 DNS server (for dynamic DNS) exist in the network.
After receiving a DHCPv6 packet from the interface specified by the destination dhcp-alloc command, the B4 router performs the following operations:
1.     Obtains the domain name of the AFTR from the packet.
2.     Sends a name query to the IPv6 DNS server to obtain the AFTR's IPv6 address.
The server resolves the domain name to the IPv6 address of AFTR.
For more information about DHCPv6 server, DHCPv6 client, and IPv6 DNS, see Layer 3—IP Services Configuration Guide.
# The interface GigabitEthernet 1/0/1 on Sysname 1 uses the IP address 193.101.1.1 and the interface GigabitEthernet 1/0/1 on Sysname 2 uses the IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode gre
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode gre
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
interface tunnel
ipv6 address dhcp-alloc
source
display 6rd
Use display 6rd to display 6RD tunnel interface information.
display 6rd [ interface tunnel number ]
interface tunnel number: Specifies an existing tunnel interface by its number. If you do not specify a 6RD tunnel interface, this command displays information about all existing 6RD tunnel interfaces.
# Display information about 6RD tunnel interface Tunnel 1.
<Sysname> display 6rd interface tunnel 1
Interface           : Tunnel1
  Tunnel source     : 10.11.12.13
  6RD status        : Operational
    IPv6 prefix     : 2001:1000::/32
    IPv4 prefix     : 10.0.0.0/8
    IPv4 suffix     : 0.0.0.0/0
    BR address      : 10.11.12.1
    Delegated prefix: 2001:1000:B0C:D00::/56
# Display information about all 6RD tunnel interfaces.
Interface           : Tunnel0
  Tunnel source     : 0.0.0.0
  6RD status        : Not operational
    IPv6 prefix     : 2002:1000::/32
Interface           : Tunnel1
Tunnel interface.
Tunnel source
Source address of the tunnel.
If a source interface is specified for the tunnel interface, this field displays the IP address of the source interface.
If no source address or source interface is specified for the tunnel interface, or the specified source interface has no IP address, this field displays 0.0.0.0.
6RD status
6RD configuration status:
·     Operational—6RD configuration is available.
·     Not operational—6RD configuration is not available.
This field displays Operational when the tunnel source address and 6RD prefix are configured.
IPv6 prefix
6RD prefix and its length. If no 6RD prefix is configured, this field displays Not configured.
IPv4 prefix
IPv4 prefix and its length. If the prefix length is not configured, this field displays 0.0.0.0/0.
IPv4 suffix
IPv4 suffix and its length. If the suffix length is not configured, this field displays 0.0.0.0/0.
BR address
IP address of the BR router. If no BR address is configured, this field displays Not configured.
Delegated prefix
6RD delegated prefix calculated based on the 6RD configuration. This field is empty if the 6RD status is Not operational.
tunnel 6rd br
tunnel 6rd ipv4
tunnel 6rd prefix
display 6rd destination
Use display 6rd destination to display a 6RD tunnel destination address.
display 6rd destination prefix ipv6-prefix interface tunnel number
prefix ipv6-prefix: Specifies a 6RD delegated prefix.
After this command is executed, the system displays the 6RD tunnel destination address calculated by the specified 6RD delegated prefix and 6RD configuration on the tunnel interface. The 6RD configuration includes the 6RD prefix/prefix length, IPv4 prefix/prefix length, and IPv4 suffix/suffix length.
# Display the 6RD tunnel destination address calculated by the 6RD delegated prefix 2001:1000:0101:0100:: and 6RD configuration on Tunnel 1.
<Sysname> display 6rd destination prefix 2001:1000:0101:0100:: interface tunnel 1
Interface       : Tunnel1
Delegated prefix: 2001:1000:101:100::
Destination     : 10.1.1.1
Tunnel interface.
Delegated prefix
Destination
Tunnel destination address.
display 6rd prefix
display 6rd prefix
Use display 6rd prefix to display a 6RD delegated prefix.
display 6rd prefix destination ipv4-address interface tunnel number
destination ipv4-address: Specifies a 6RD tunnel destination address.
After this command is executed, the system displays the 6RD delegated prefix calculated by the specified 6RD tunnel destination address and 6RD configuration on the tunnel interface. The 6RD configuration includes the 6RD prefix/prefix length, IPv4 prefix/prefix length, and IPv4 suffix/suffix length. The 6RD delegated prefix calculated on the peer tunnel interface must be the same as the 6RD delegated prefix configured on the local device.
# Display the 6RD delegated prefix calculated by the 6RD tunnel destination address 10.1.1.1 and 6RD configuration on Tunnel 1.
<Sysname> display 6rd prefix destination 10.1.1.1 interface tunnel 1
Interface       : Tunnel1
Delegated Prefix: 2001:1000:101:100::
Tunnel interface.
Destination
Delegated Prefix
display ds-lite b4 information
Use display ds-lite b4 information to display information about the connected B4 routers on the AFTR, including the IPv6 addresses of the B4 routers, and the assigned tunnel IDs.
# (In standalone mode.) Display information about the connected B4 routers.
<Sysname> display ds-lite b4 information
 B4 address                                     Tunnel ID  Tunnel interface  Idle time
 1234:5678:1234:5678:abcd:abcd:efff:1234        0x00000023       1              12
 2000::100:1                                    0x80000013       2              13
 3000::2                                        0x00000015       3              8
 3001::2                                        0x00000032       --             15
Total B4 addresses: 4
# (In IRF mode.) Display information about the connected B4 routers.
Slot 0 Cpu 0:
 3000::2                                        0x00000015       3              2
 3001::2                                        0x00000032       --             --
Slot 1 Cpu 0:
 1234:5678:1234:5678:abcd:abcd:efff:ffff        0x00000125       1              12
 5000::100:1                                    0x80000010       5              13
Total B4 addresses: 2
B4 address
IPv6 address of the B4 router.
Tunnel ID
Tunnel ID that the IPv6 address of the B4 router maps to.
Tunnel interface
ID of the tunnel interface on the DS-Lite tunnel to which the mapping belongs.
When the tunnel to which the mapping belongs is removed or a tunnel with the same ID but different mode is created, this field displays hyphens (--).
Idle time
Remaining time in minutes for the mapping between the IPv6 address of the B4 router and tunnel ID.
When the mapping ages out but is still used by a session, this field displays hyphens (--).
Total B4 addresses
Number of IPv6 addresses of the B4 routers.
Use display interface tunnel to display tunnel interface information.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. The specified tunnel interface must have been created. If you do not specify the tunnel keyword, this command displays information about all interfaces except VA interfaces on the device. For information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide. If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1476
Tunnel source 2002::1:1 (Vlan-interface10), destination 2001::2:1
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
    GRE key disabled
    Checksumming of GRE packets disabled
Table 5 Command output
Tunnel1
Information about the tunnel interface Tunnel 1.
Current state
Physical link state of the tunnel interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description of the tunnel interface.
Bandwidth
Expected bandwidth of the tunnel interface.
MTU of the tunnel interface.
The tunnel interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-AllocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     Cellular-Allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2WAN Access Configuration Guide.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
Tunnel source
Source address of the tunnel. If a source interface is specified for the tunnel interface, this field also displays the source interface in parentheses.
destination
Destination address of the tunnel.
Tunnel keepalive enabled, Period(50 s), Retries(3)
GRE keepalive is enabled. In this example, the keepalive interval is 50 seconds and the keepalive number is 3.
Tunnel TOS
ToS of tunneled packets.
Tunnel TTL
TTL of tunneled packets.
Tunnel mode and transport protocol:
·     CR_LSP—MPLS TE tunnel mode.
·     GRE/IP—GRE/IPv4 tunnel mode.
·     GRE/IPv6—GRE/IPv6 tunnel mode.
·     GRE P2MP—GRE/IPv4 P2MP tunnel mode.
·     GRE P2MP/IPv6—GRE/IPv6 P2MP tunnel mode.
·     GRE_ADVPN/IP—GRE-encapsulated IPv4 ADVPN tunnel mode.
·     GRE_ADVPN/IPv6—GRE-encapsulated IPv6 ADVPN tunnel mode.
·     UDP_ADVPN/IP—UDP-encapsulated IPv4 ADVPN tunnel mode.
·     UDP_ADVPN/IPv6—UDP-encapsulated IPv6 ADVPN tunnel mode.
·     IP/IP—IPv4 over IPv4 tunnel mode.
·     IP/IPv6—IPv4 over IPv6 tunnel mode.
·     IPv6—IPv6 tunnel mode.
·     IPv6/IP—IPv6 over IPv4 manual tunnel mode.
·     IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode.
·     IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode.
·     IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode.
·     IPv6/IPv6—IPv6 over IPv6 tunnel mode.
·     DSLITE—DS-Lite tunnel mode on the AFTR.
·     UDP_VXLAN/IP—UDP-encapsulated IPv4 VXLAN tunnel mode.
·     NVE/IP—IPv4 NVE tunnel mode.
GRE key disabled
No GRE tunnel interface key is configured.
The GRE packet checksum feature is disabled.
Source port number is 18001
The source port number is 18001 in ADVPN packets sent by the UDP-encapsulated ADVPN tunnel interface.
Urgent output queue statistics:
Number of packets in the queue/maximum number of packets that the queue can contain/number of packets discarded in the queue.
Protocol output queue statistics:
FIFO output queue statistics:
When a CBQ or WFQ queue is configured, this field displays statistics for the CBQ or WFQ queue.
Last time when counters were cleared.
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
Total input packets, total input bytes, and total input packets dropped.
Total output packets, total output bytes, and total output packets dropped.
# Display brief information about Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP     Description
Tun1                 UP   UP       1.1.1.1        Tunnel1
# Display brief information about Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Tun0                  DOWN Not connected
Tun1                  DOWN Not connected
Table 6 Command output
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The tunnel is not established.
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the tunnel interface belongs has been shut down by using the shutdown command.
destination
interface tunnel
source
ds-lite enable
Use ds-lite enable to enable DS-Lite tunneling on an interface.
Use undo ds-lite enable to disable DS-Lite tunneling on an interface.
ds-lite enable
undo ds-lite enable
DS-Lite tunneling is disabled on an interface.
Interface view
Use this command on the AFTR's interface connected to the public IPv4 network, so the AFTR can forward IPv4 packets to the B4 router through the DS-Lite tunnel.
You cannot enable DS-Lite tunneling on a DS-Lite tunnel interface on the AFTR.
# Enable DS-Lite tunneling on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ds-lite enable
encapsulation-limit
Use encapsulation-limit to set the maximum number of nested encapsulations of a packet allowed on a tunnel interface.
Use undo encapsulation-limit to restore the default.
encapsulation-limit number
There is no limit to the nested encapsulations of a packet.
number: Specifies the number of nested encapsulations, in the range of 0 to 10.
A packet added with excessive headers becomes oversized. If it exceeds the MTU, it must be fragmented. The fragmentation decreases forwarding rate and increases processing complexity. To avoid this situation, use this command to limit the number of encapsulations.
This command is applicable only to IPv6 over IPv6 tunnels.
# Set the maximum number of nested encapsulations to 3 on Tunnel 1.
[Sysname] interface tunnel 1 mode ipv6
[Sysname-Tunnel1] encapsulation-limit 3
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view, or enter the view of an existing tunnel interface.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode { advpn { gre | udp } [ ipv6 ] | ds-lite-aftr | gre [ ipv6 ] | gre-p2mp [ ipv6 ] | ipsec [ ipv6 ] | ipv4-ipv4 | ipv6 | ipv6-ipv4 [ 6rd | 6to4 | auto-tunnel | isatap ] | mgre | mpls-te | nve | vxlan } ]
undo interface tunnel number
No tunnel interfaces exist.
number: Specifies the number of the tunnel interface. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
The following compatibility matrix shows the value ranges for the tunnel interface number:
Hardware
Value range
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
0 to 10239
MSR810-LMS, MSR810-LUS
0 to 1023
MSR2600-6-X1, MSR2600-10-X1
0 to 10239
MSR 2630
0 to 10239
MSR3600-28, MSR3600-51
0 to 10239
MSR3600-28-SI, MSR3600-51-SI
0 to 10239
0 to 10239
MSR3610-I-DP, MSR3610-IE-DP
0 to 10239
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
0 to 10239
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
0 to 10239
MSR3610-G, MSR3620-G
0 to 10239
mode advpn gre: Specifies the GRE-encapsulated IPv4 ADVPN tunnel mode.
The following compatibility matrix shows the support of hardware platforms for this keyword:
Hardware
Parameter compatibility
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode advpn udp: Specifies the UDP-encapsulated IPv4 ADVPN tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode advpn gre ipv6: Specifies the GRE-encapsulated IPv6 ADVPN tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode advpn udp ipv6: Specifies the UDP-encapsulated IPv6 ADVPN tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode ds-lite-aftr: Specifies the DS-Lite tunnel mode on the AFTR.
mode gre: Specifies the GRE/IPv4 tunnel mode.
mode gre ipv6: Specifies the GRE/IPv6 tunnel mode.
mode gre-p2mp: Specifies the GRE/IPv4 P2MP tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode gre-p2mp ipv6: Specifies the GRE/IPv6 P2MP tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode ipsec: Specifies the IPsec/IPv4 tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode ipsec ipv6: Specifies the IPsec/IPv6 tunnel mode.
Hardware
Yes
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode ipv4-ipv4: Specifies the IPv4 over IPv4 tunnel mode.
mode ipv6: Specifies the IPv6 tunnel mode. Set this mode for IPv4 over IPv6 manual and IPv6 over IPv6 tunnels.
mode ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
mode ipv6-ipv4 6rd: Specifies the 6RD tunnel mode.
mode ipv6-ipv4 6to4: Specifies the 6to4 tunnel mode.
mode ipv6-ipv4 auto-tunnel: Specifies the IPv4-compatible IPv6 automatic tunnel mode.
mode ipv6-ipv4 isatap: Specifies the ISATAP tunnel mode.
mode mgre: Specifies the mGRE tunnel mode.
Hardware
Yes
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode mpls-te: Specifies the MPLS TE tunnel mode.
Hardware
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK: Yes
MSR810-LMS-EA: No
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode nve: Specifies the NVE tunnel mode.
Hardware
Yes
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
mode vxlan: Specifies the VXLAN tunnel mode.
Hardware
Yes
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create GRE/IPv4 tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
destination
source
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU is 64000 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU, in the range of 100 to 64000 bytes.
After you configure an MTU for a tunnel interface, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on Tunnel 1 to 1000 bytes.
[Sysname-Tunnel1] mtu 1000
reset counters interface tunnel
Use reset counters interface tunnel to clear tunnel interface statistics.
reset counters interface [ tunnel [ number ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. If you do not specify the tunnel keyword, this command clears statistics for all interfaces except VA interfaces. If you specify the tunnel keyword without the number argument, this command clears statistics for all tunnel interfaces.
Use this command to clear old statistics so you can observe new traffic statistics on a tunnel interface.
# Clear statistics for Tunnel 1.
<Sysname> reset counters interface tunnel 1
service
Use service to specify a primary traffic processing slot for a tunnel interface.
Use undo service to restore the default.
service slot slot-number
undo service slot
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware
Command compatibility
No
No
No
MSR 2630
Yes
Yes
No
Yes
No
Yes
Yes
Yes
No primary traffic processing slot is specified for a tunnel interface.
slot slot-number: Specifies an IRF member device by its member ID.
CAUTION
CAUTION:
The following operations might cause a tunnel interface in up state to be down and then up:
·     Specifying a primary or backup traffic processing slot for the tunnel interface.
·     Rebooting or hot-swapping the primary or backup traffic processing slot of the tunnel interface.
Make sure you understand the potential impact of the operations on your network.
This command is supported only in IRF mode.
Specify a traffic processing slot if a feature (for example, IPsec antireplay) requires that all traffic on a tunnel interface be processed on the same slot.
For high availability, you can specify one primary and one backup traffic processing slot by using the service command and the service standby command, respectively.
To avoid processing slot switchover, specify the primary slot before specifying the backup slot. If you specify the backup slot before specifying the primary slot, traffic is switched over to the primary slot immediately after you specify the primary slot.
If you specify both primary and backup slots for an interface, traffic on that interface is processed as follows:
·     The backup slot takes over when the primary slot becomes unavailable. The backup slot continues to process traffic for the interface after the primary slot becomes available again. The switchover will not occur until the backup slot becomes unavailable.
·     When no specified traffic processing slots are available, the traffic is processed on the slot at which it arrives. Then, the processing slot that first becomes available again takes over.
If you do not specify a primary or a backup traffic processing slot for an interface, traffic on that interface is processed on the slot at which the traffic arrives.
# Specify a primary traffic processing slot for Tunnel 200.
[Sysname] interface tunnel 200
[Sysname-Tunnel200] service slot 1
service standby
service standby
Use service standby to specify a backup traffic processing slot for an interface.
Use undo service standby to restore the default.
service standby slot slot-number
undo service standby slot
Hardware
No
No
No
MSR 2630
Yes
Yes
No
Yes
No
Yes
Yes
Yes
No backup traffic processing slot is specified for an interface.
CAUTION
CAUTION:
This command is supported on IRF-capable devices.
# Specify a primary and a backup traffic processing slot for Tunnel 200.
[Sysname-Tunnel200] service slot 2
[Sysname-Tunnel200] service standby slot 3
service
shutdown
Use shutdown to shut down a tunnel interface.
Use undo shutdown to bring up a tunnel interface.
shutdown
A tunnel interface is down.
This command disconnects all links set up on the interface. Make sure you fully understand the impact of the command on your network.
# Shut down Tunnel 1.
[Sysname-Tunnel1] shutdown
source
Use source to specify the source address or source interface for a tunnel interface.
Use undo source to restore the default.
source { ipv4-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel interface.
ipv4-address: Specifies the tunnel source IPv4 address.
ipv6-address: Specifies the tunnel source IPv6 address.
interface-type interface-number: Specifies the source interface by its type and number. The interface must be up and must have an IP address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
You cannot specify the tunnel interface of the DS-Lite tunnel on the AFTR as the source interface.
# Specify GigabitEthernet 1/0/1 as the source interface of Tunnel 1.
[Sysname-Tunnel1] source gigabitethernet 1/0/1
# Specify 192.100.1.1 as the source address of Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
destination
interface tunnel
tunnel 6rd br
Use tunnel 6rd br to specify a BR address for a 6RD tunnel.
Use undo tunnel 6rd br to restore the default.
tunnel 6rd br ipv4-address
undo tunnel 6rd br
No BR address is specified for a 6RD tunnel.
ipv4-address: Specifies the BR address (IPv4 address of a 6RD BR router), in dotted decimal notation.
Use this command on a 6RD CE. For a 6RD network to communicate with a non-6RD network over a 6RD tunnel, you must specify the BR address on the 6RD CE.
All the 6RD CEs and 6RD BR routers in a 6RD network must have the same IPv4 prefix and suffix. Make sure the BR address and the tunnel source address have the same IPv4 prefix and suffix.
# Specify the BR address as 10.11.12.13 on Tunnel 1.
[Sysname] interface tunnel 1 mode ipv6-ipv4 6rd
[Sysname-Tunnel1] tunnel 6rd br 10.11.12.13
display 6rd
tunnel 6rd ipv4
Use tunnel 6rd ipv4 to specify a prefix length and a suffix length for a 6RD tunnel source address.
Use undo tunnel 6rd ipv4 to restore the default.
tunnel 6rd ipv4 { prefix-length length | suffix-length length } *
All 32 bits of the IPv4 tunnel source address are used to create the 6RD delegated prefix.
prefix-length length: Specifies the prefix length in the range of 0 to 31.
suffix-length length: Specifies the suffix length in the range of 0 to 31.
All 6RD tunnel interfaces in a 6RD network must be configured with the same IPv4 prefix length and suffix length.
You can specify a prefix length, a suffix length, both prefix and suffix lengths, or neither. The device will remove the prefix and suffix bits from the tunnel source address and embed the left bits of the address to the 6RD delegated prefix. If neither a prefix length nor a suffix length is specified, all 32 bits of the IPv4 tunnel source address will be embedded in the 6RD delegated prefix.
# Specify both the prefix length and suffix length as 8 on Tunnel 1.
[Sysname-Tunnel1] tunnel 6rd ipv4 prefix-length 8 suffix-length 8
display 6rd
display 6rd prefix
tunnel 6rd prefix
Use tunnel 6rd prefix to configure the 6RD prefix for a 6RD tunnel.
Use undo tunnel 6rd prefix to restore the default.
tunnel 6rd prefix ipv6-prefix/prefix-length
No 6RD prefix is configured for a 6RD tunnel.
ipv6-prefix/prefix-length: Specifies the IPv6 prefix and its length. The value range for the prefix length is 1 to 127.
A 6RD delegated prefix contains a 6RD prefix and all or part of the bits in the IPv4 tunnel source address.
All tunnels in a 6RD network must have the same 6RD prefix.
# Configure the 6RD prefix as 2001:1000::/32 on Tunnel 1.
[Sysname-Tunnel1] tunnel 6rd prefix 2001:1000::/32
display 6rd
display 6rd prefix
tunnel dfbit enable
Use tunnel dfbit enable to set the Don't Fragment (DF) bit for tunneled packets.
Use undo tunnel dfbit enable to restore the default.
tunnel dfbit enable
The DF bit is not set for tunneled packets.
To avoid fragmentation and delay, set the DF bit for tunneled packets. Make sure the path MTU is larger than the tunneled packet length. To avoid discarding tunneled packets whose length is larger than the path MTU, do not set the DF bit.
This command is not supported on a GRE/IPv6 tunnel interface and an IPv6 tunnel interface.
# Set the DF bit for tunneled packets on Tunnel 1.
[Sysname-Tunnel1] tunnel dfbit enable
tunnel discard ipv4-compatible-packet
Use tunnel discard ipv4-compatible-packet to enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
Use undo tunnel discard ipv4-compatible-packet to restore the default.
Hardware
Yes
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
IPv6 packets that use IPv4-compatible IPv6 addresses are not dropped.
This command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from a tunnel. If a packet uses an IPv4-compatible IPv6 address as the source or destination address, the device discards the packet.
# Enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos { copy-inner-tos | tos-value }
undo tunnel tos
For VXLAN tunneled packets, the ToS is 0.
For non-VXLAN tunneled packets, the ToS is the same as the ToS of the original packets.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
copy-inner-tos: Configures tunneled packets to use the ToS of the original packets. This keyword is supported only by VXLAN tunnels.
Hardware
Yes
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
After you execute this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see ACL and QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
# Configure VXLAN tunnel interface Tunnel 2 to use the ToS of the original packets as the ToS of tunneled packets.
[Sysname] interface tunnel 2 mode vxlan
[Sysname-Tunnel2] tunnel tos copy-inner-tos
tunnel ttl
Use tunnel ttl to set the Time to Live (TTL) of tunneled packets.
Use undo tunnel ttl to restore the default.
tunnel ttl ttl-value
undo tunnel ttl
The TTL of tunneled packets is 255.
ttl-value: Specifies the TTL of tunneled packets, in the range of 1 to 255.
The TTL determines the maximum number of hops that the tunneled packets can pass. When the TTL expires, the tunneled packets are discarded to avoid loops.
# Set the TTL of tunneled packets to 100 on Tunnel 1.
[Sysname-Tunnel1] tunnel ttl 100
tunnel vpn-instance
Use tunnel vpn-instance to specify a VPN instance for the destination address of a tunnel interface.
Use undo tunnel vpn-instance to restore the default.
tunnel vpn-instance vpn-instance-name
The destination address of a tunnel interface belongs to the public network.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After this command is executed, the device looks up the routing table of the specified VPN instance to forward tunneled packets on the tunnel interface.
For a tunnel interface to come up, the tunnel source and destination must belong to the same VPN instance. To specify a VPN instance for the tunnel source, use the ip binding vpn-instance command on the tunnel source interface.
# Specify VPN instance vpn10 for the tunnel destination on Tunnel 1.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 1:1
[Sysname-vpn-instance-vpn10] vpn-target 1:1
[Sysname-vpn-instance-vpn10] quit
[Sysname-GigabitEthernet1/0/1] ip binding vpn-instance vpn10
[Sysname-GigabitEthernet1/0/1] ip address 1.1.1.1 24
[Sysname-Tunnel1] destination 1.1.1.2
[Sysname-Tunnel1] tunnel vpn-instance vpn10
ip binding vpn-instance (MPLS Command Reference)
