07-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR810 2600 3600 Routers Command References(V7)-R0707-6W30107-Layer 3—IP Services Command Reference
08-Multi-CPU packet distribution commands
08-Multi-CPU packet distribution commands 29.95 KB
The following compatibility matrix shows the support of hardware platforms for multi-CPU packet distribution:
Hardware
Multi-CPU packet distribution compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
No
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
No
MSR 2630
No
MSR3600-28, MSR3600-51
No
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3610-I-DP, MSR3610-IE-DP
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow | per-packet }
The device uses the flow-based policy.
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. This policy takes the first-in first-out rule.
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
