HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R320x)-6W10001-Fundamentals Configuration Guide
07-Software upgrade configuration
07-Software upgrade configuration 89.81 KB
Upgrading software
About software upgrade
Software upgrade enables you to upgrade a software version, add new features, and fix software bugs. This chapter describes software types and release forms, compares software upgrade methods, and provides the procedures for upgrading software from the CLI.
Software types
The following software types are available:
·     BootWare image—Also called the Boot ROM image. This image contains a basic segment and an extended segment.
¡     The basic segment is the minimum code that bootstraps the system.
¡     The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
Typically, the BootWare image is integrated into the Boot image to avoid software compatibility errors.
·     Comware image—Includes the following image subcategories:
¡     Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, and file system management.
¡     System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡     Feature image—A .bin file that contains advanced or customized software features. You can purchase feature images as needed.
¡     Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
Patch images have the following types:
-     Incremental patch images—A new patch image can cover all, part, or none of the functions provided by an old patch image. A new patch image can coexist with an old patch image on the device only when the former covers none of the functions provided by the latter.
-     Non-incremental patch images—A new non-incremental patch image covers all functions provided by an old non-incremental patch image. Each boot, system, or feature image can have one non-incremental patch image, and these patch images can coexist on the device. The device uninstalls the old non-incremental patch image before installing a new non-incremental patch image.
An incremental patch image and a non-incremental patch image can coexist on the device.
Comware images that have been loaded are called current software images. Comware images specified to load at the next startup are called startup software images.
BootWare image, boot image, and system image are required for the device to operate.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature and patch image files.
Software release forms
Software images are released in one of the following forms:
·     Separate .bin files. You must verify compatibility between software images.
·     As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Software image file names use the model-comware version-image type-release format. This document uses boot.bin and system.bin as boot and system image file names.
Software image loading
Startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the devices loads the backup startup software images.
Image loading process at startup
At startup, the device performs the following operations after loading and initializing BootWare:
1.     Loads main images.
2.     If any main image does not exist or is invalid, loads the backup images.
3.     If any backup image does not exist or is invalid, the device cannot start up.
Restrictions and guidelines: Software upgrade
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
Upgrading device software by using the boot loader method
When you upgrade software, you do not need to upgrade interface cards separately. The software images for interface cards are integrated in the software images for MPUs. The interface cards are upgraded automatically when you upgrade MPUs.
Software upgrade tasks at a glance
To upgrade software, perform one of the following tasks:
1.     (Optional.) Preloading the BootWare image to BootWare.
¡     Preloading the BootWare image to BootWare (in standalone mode)
¡     Preloading the BootWare image to BootWare (in IRF mode)
If a BootWare upgrade is required, you can perform this task to shorten the subsequent upgrade time. This task helps reduce upgrade problems caused by unexpected power failure. If you skip this task, the device upgrades the BootWare automatically when it upgrades the startup software images.
2.     Specifying startup images and completing the upgrade
1.     Use the display version command to verify the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the dir command to verify that all MPUs have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
4.     Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. For more information about FTP and TFTP, see "Configuring FTP" or "Configuring TFTP." For more information about file systems, see "Managing file systems."
2.     (Optional.) Enable BootWare image validity check.
bootrom-update security-check enable
By default, this feature is enabled.
This feature examines BootWare images for file type errors, file corruption, and hardware incompatibility. As a best practice, enable it to ensure a successful upgrade.
3.     Return to user view.
4.     (Optional.) Back up the current BootWare image.
¡     Back up the image to the Backup area of BootWare:
bootrom backup slot slot-number-list
Use either command to back up the BootWare image for a future version rollback or image restoration.
5.     Load the upgrade BootWare image to the Normal area of BootWare.
bootrom update file file slot slot-number-list
Specify the downloaded software image file for the file argument.
The new BootWare image takes effect at a reboot.
This feature examines the image for wrong file type, file corruption, and hardware incompatibility. As a best practice, enable it to ensure a successful upgrade.
bootrom backup chassis chassis-number slot slot-number-list
Use one of the commands to back up the BootWare image for a future version rollback or image restoration, depending on the backup location and device operating mode.
bootrom update file file chassis chassis-number slot slot-number-list
Perform the following steps in user view:
1.     Specify main or backup startup images for all MPUs.
In standalone mode:
¡     Use an .ipe file:
boot-loader file ipe-filename [ patch filename&<1-16> ] all { backup | main }
¡     Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-16> ] { all | slot slot-number } { backup | main }
In IRF mode:
¡     boot-loader file ipe-filename [ patch filename&<1-16> ] all { backup | main }
¡     boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-16> ] { all | chassis chassis-number slot slot-number } { backup | main }
The command copies the specified startup images to the root directory of the default file system on each MPU.
As a best practice in a multichassis IRF fabric, specify the all keyword for the command. If you use the slot slot-number option to upgrade member devices one by one, version inconsistencies occur among the member devices during the upgrade.
2.     Save the running configuration.
save
This step ensures that any configuration you have made can survive a reboot.
3.     Reboot the device.
reboot
4.     (Optional.) Verify the software image settings.
display boot-loader [ slot slot-number ]
Verify that the current software images are the same as the startup software images.
Synchronizing startup images from the active MPU to the standby MPU (in standalone mode)
About startup image synchronization
Perform this task when the startup images on the standby MPU are not the same version as those on the active MPU.
This task synchronizes startup images that are running on the active MPU to the standby MPU. If any of the startup images does not exist or is invalid, the synchronization fails.
The startup images synchronized to the standby MPU are set as main startup images, regardless of whether the source startup images are main or backup.
1.     Synchronize startup images from the active MPU to the standby MPU.
boot-loader update { all | slot slot-number }
The command execution results are the same, regardless of whether you specify the all keyword or the slot slot-number option.
2.     Reboot the standby MPU.
reboot slot slot-number [ force ]
Synchronizing startup images from the global active MPU to global standby MPUs (in IRF mode)
Perform this task when the startup images on a global standby MPU are not the same version as those on the global active MPU.
This task synchronizes startup images that are running on the global active MPU to standby MPUs. If any of the startup images does not exist or is invalid, the synchronization fails.
The startup images synchronized to the standby MPUs are set as main startup images, regardless of whether the source startup images are main or backup.
If a patch installation has been performed on the global active MPU, use the install commit command to update the set of main startup images on the global active MPU before software synchronization. This command ensures startup image consistency between the global active MPU and standby MPUs.
1.     Synchronize startup images from the global active MPU to global standby MPUs.
boot-loader update { all | chassis chassis-number slot slot-number }
2.     Reboot a global standby MPU.
Restoring the BootWare image
About restoring the BootWare image
Use this task to restore the BootWare image when the BootWare image in the Normal area is corrupted or a version rollback is required.
Make sure you have used the bootrom backup command to back up the image to the BootWare Backup area.
1.     Restore the BootWare image in the Normal area of BootWare.
In standalone mode:
bootrom restore slot slot-number-list
In IRF mode:
bootrom restore chassis chassis-number slot slot-number-list
2.     Reboot the device.
reboot
At startup, the system runs the new BootWare image to complete the restoration.
Software upgrade examples
Example: Upgrading device software (in standalone mode)
As shown in Figure 1, the device has two MPUs: one active MPU in slot 0 and one standby MPU in slot 1.
Use the file startup-a2105.ipe to upgrade software images for the device.
Figure 1 Network diagram
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
# Configure IP addresses and routes. Make sure the device and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the device and the TFTP server. (Details not shown.)
# Display information about the current software images.
<Sysname> display version
# Back up the current software images.
<Sysname> copy boot.bin boot_backup.bin
<Sysname> copy system.bin system_backup.bin
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for both MPUs.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 0 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 1 backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory on the active MPU.
<Sysname> tftp 2.2.2.2 get startup-a2105.ipe
# Specify startup-a2105.ipe as the main startup image file for both MPUs.
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 0 main
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 1 main
# Verify the startup image settings.
<Sysname> display boot-loader
# Reboot the device to complete the upgrade.
<Sysname> reboot
# Verify that the device is running the correct software.
Example: Upgrading device software (in IRF mode)
As shown in Figure 2, use the file startup-a2105.ipe to upgrade software images for the IRF fabric.
Each IRF member device has two MPUs: one in slot 0 and one in slot 1. The global active MPU is in slot 0 on the master device.
Figure 2 Network diagram
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for all MPUs.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin chassis 1 slot 0 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin chassis 1 slot 1 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin chassis 2 slot 0 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin chassis 2 slot 1 backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory on the global active MPU.
# Specify startup-a2105.ipe as the main startup image file for all MPUs.
<Sysname> boot-loader file flash:/startup-a2105.ipe chassis 1 slot 0 main
<Sysname> boot-loader file flash:/startup-a2105.ipe chassis 1 slot 1 main
<Sysname> boot-loader file flash:/startup-a2105.ipe chassis 2 slot 0 main
<Sysname> boot-loader file flash:/startup-a2105.ipe chassis 2 slot 1 main
# Reboot the IRF fabric to complete the upgrade.
<Sysname> reboot
# Verify that the IRF fabric is running the correct software.
