09-Security Command Reference
HomeSupportSwitchesS12500X-AF SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R320x)-6W10009-Security Command Reference
20-Crypto engine commands
20-Crypto engine commands 32.49 KB
display crypto-engine
Use display crypto-engine to display crypto engine information.
# Display crypto engine information.
<Sysname> display crypto-engine
  Crypto engine name: Software crypto engine
  Crypto engine state: Enabled
  Crypto engine type: Software
  Slot ID: 1
  CPU ID:0
  Crypto engine ID: 0
  Symmetric algorithms:  des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac
  Asymmetric algorithms:
  Random number generation function: Supported
Crypto engine state
This field always displays Enabled for software crypto engines.
Crypto engine type
The value is Software for this field.
CPU ID
ID of the CPU on the card.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
In standalone mode:
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
In IRF mode:
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
engine-id engine-id: Specifies a crypto engine by its ID. The switch supports only one software crypto engine, and the engine ID can only be 0.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
(In standalone mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
# (In standalone mode.) Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
In standalone mode:
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
In IRF mode:
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
(In standalone mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
