11-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S12500X-AF Switch SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R320x)-6W10011-Network Management and Monitoring Command Reference
14-NetStream commands
14-NetStream commands 111.19 KB
NetStream commands
display ip netstream cache
Use display ip netstream cache to display NetStream entry information.
In standalone mode:
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 } ] [ destination destination-ip | interface interface-type interface-number | source source-ip ] * [ slot slot-number ]
In IRF mode:
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 } ] [ destination destination-ip | interface interface-type interface-number | source source-ip ] * [ chassis chassis-number slot slot-number ]
verbose: Displays detailed information about NetStream entries. If you do not specify this keyword, this command displays brief information about NetStream entries.
type: Specifies the NetStream entry type. If you do not specify this keyword, this commands displays information about all types of NetStream entries.
ip: Specifies Layer 3 NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 NetStream entries.
l2: Specifies Layer 2 NetStream entries.
destination destination-ip: Specifies a destination IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
source source-ip: Specifies a source IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about NetStream entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about NetStream entries for all cards. (In IRF mode.)
The types of NetStream entries for flow packets vary by the export template version and whether the flow packets contain IP headers.
·     If the version 9 or version 10 template is used:
¡     The type of the NetStream entry is ipl2 (Layer 2 and Layer 3) for flow packets containing IP headers.
¡     The type of the Netstream entry is l2 (Layer 2) for flow packets without IP headers.
·     If the version 5 template is used:
¡     The type of the NetStream entry is ip (Layer 3) for flow packets containing IP headers.
¡     The type of the NetStream entry is l2 (Layer 2) for flow packets without IP headers.
# Display detailed information about NetStream entries.
<Sysname> display ip netstream cache verbose
IP NetStream cache information:
  Active flow timeout             : 60 min
  Inactive flow timeout           : 10 sec
  Max number of entries           : 1000
  IP active flow entries          : 1
  MPLS active flow entries        : 2
  L2 active flow entries          : 1
  IPL2 active flow entries        : 1
  IP flow entries counted         : 10
  MPLS flow entries counted       : 20
  L2 flow entries counted         : 10
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 01/01/2000 at 00:01:02
IP packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
 512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86          49        27
TCP-FTP         5900082      86        9        9          11        33
TCP-FTPD        3200453    1006        5      193          45        33
TCP-WWW       546778274   11170      887       12           8        32
TCP-other      49148540    3752       79       47          30        32
UDP-DNS       117240379     570      190        3           7        34
UDP-other      45502422    2272       73       30           8        37
ICMP           14837957     125       24        5          12        34
IP-other          77406       5        0       47          52        27
Type DstIP(Port)         SrcIP(Port)            Pro ToS VNI   If(Direct)  Pkts
     DstMAC(VLAN)        SrcMAC(VLAN)
     TopLblType(IP/Mask) Lbl-Exp-S-List
IP   11.1.1.1(1024)      11.1.1.2(21)           6   128 10    HGE1/0/1(I) 42996
     TCPFlag:      27
     DstMask:      24       SrcMask:      24       NextHop:      0.0.0.0
     DstAS:         0       SrcAS:         0       BGPNextHop:   0.0.0.0
     InVRF:        10
     SamplerMode:   2       SamplerInt:  256
     Active:  120.600       Bytes/Pkt:   152
     First packet arrived: 10/28/2013, 14:10:03
     Last packet arrived:  10/28/2013, 14:21:03
L2   0012-3f86-e94c(10)     0012-3f86-e86a(0)                 HGE1/0/1(I) 1253
     SamplerMode:   2       SamplerInt:   64
     Active:    5.510       Bytes/Pkt:   210
     First packet arrived: 10/28/2013, 14:10:00
IP&  192.168.123.1(2048) 192.168.1.1(0)         1    0   N/A   HGE1/0/2(O) 10
L2   0012-3f86-e95d(0)      0012-3f86-e116(1008)
     TCPFlag:      27
     DstMask:      24       SrcMask:      24       NextHop:    192.168.1.2
     OutVRF:        0       TCPFlag:    0
     SamplerMode:   0       SamplerInt:    0
     Active:   12.030       Bytes/Pkt:    86
     First packet arrived: 10/28/2013, 14:10:04
IP&  172.16.1.1(68)      172.16.2.1(67)         17  64   N/A   HGE1/0/3(I) 1848
Active flow timeout
Aging timer for active flows, in minutes.
Aging timer for inactive flows, in seconds.
Maximum number of flows allowed in the cache.
Number of active IP flows in the cache.
Number of active MPLS flows in the cache.
Number of active Layer 2 flows in the cache.
Number of active Layer 2 and Layer 3 flows in the cache.
Number of IP flows that have been counted.
Number of MPLS flows that have been counted.
Number of Layer 2 flows that have been counted.
Number of Layer 2 and Layer 3 flows that have been counted.
Last time the reset ip netstream statistics command was executed. This field displays Never if you have never executed this command.
Distribution of IP packets by packet size, and the bracketed number is the total number of IP packets.
The value is displayed in the proportion of the number of IP packets of the specified sizes to the total number of IP packets, and the value is displayed with 3 decimal places.
320  352  384  416  448  480 512  544  576
Range of IP packet length (excluding data link layer header) in bytes.
·     For the values in the range of 1 to 576, the range increases in the step of 32. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes.
·     For the values greater than 1024, the range increases in the step of 512. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes.
·     Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry.
Protocol     Total Flows     Packets /sec
Flows/sec   Packets/flow
Active(sec)/flow     Idle(sec)/flow
Statistics of packets by protocol type:
·     Protocol type.
·     Total number of flows.
·     Number of packets per second.
·     Number of flows per second.
·     Number of packets per flow.
·     Active time (in seconds) of each flow.
·     Inactive time (in seconds) of each flow.
Statistics of the active flows in the current cache:
·     Flow type. Flows are classified into the following types:
¡     Layer 3 flows.
¡     Layer 2 flows.
¡     Layer 2 and Layer 3 flows.
¡     MPLS flows without IP options. This field is not supported in the current software version.
¡     MPLS flows with IP options.
·     Destination IP address (destination port).
·     Source IP address (source port).
·     Protocol number.
·     ToS.
·     VXLAN ID.
·     Interface name (direction).
·     Number of packets.
ICMP packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields:
·     The highest 8 bits represent the type field.
·     The lowest 8 bits represent the code field.
The value for the source port is set to 0 and does not indicate any statistics.
Layer 2 information of the active flows in the current cache:
·     Destination MAC address, followed by the destination VLAN ID in parenthesis.
·     Source MAC address, followed by the source VLAN ID in parenthesis.
Information about the active MPLS flows in the current cache:
·     Type of the labels at the top of the label stack:
¡     IP address associated with the label.
¡     Mask associated with the label.
·     Label list.
Up to three labels can be listed in one label list.
TCPFlag:
DstMask:      SrcMask:             NextHop:
DstAS:           SrcAS:            BGPNextHop:
OutVRF:       InVRF:
SamplerMode:                     SamplerInt:
Active:       Bytes/Pkt:
Other information about the active flows in the cache:
·     TCP tag.
·     Destination mask.
·     Source mask.
·     Routing next hop.
·     Destination AS.
·     Source AS.
·     BGP next hop.
·     VPN instance to which the outbound packets belong.
·     VPN instance to which the inbound packets belong.
·     Sampling mode. Supported sampling modes are:
¡     0—No sampling.
¡     2—Random sampling.
·     Sampling interval.
·     Flow's active time.
·     Number of bytes per packet.
·     Arrival time of the first packet of the flow.
·     Arrival time of the last packet of the flow.
display ip netstream export
Use display ip netstream export to display information about the NetStream data export.
IP NetStream export information varies by aggregation mode. This command displays IP NetStream export information for all the configured aggregation modes.
# Display information about the NetStream data export.
<Sysname> display ip netstream export
IP export information:
  Flow source interface                              : HundredGigE1/0/1
  Flow destination VPN instance                      : VPN1
  Flow destination IP address (UDP)                  : 10.10.0.10 (30000)
  Version  5 exported flow number                    : 16
  Version  5 exported UDP datagram number (failed)   : 16 (0)
  Version  9 exported flow number                    : 20
  Version  9 exported UDP datagram number (failed)   : 2 (0)
  Version 10 exported flow number                    : 0
  Version 10 exported UDP datagram number (failed)   : 0 (0)
protocol-port aggregation export information:
  Version  8 exported flow number                    : 16
  Version  8 exported UDP datagram number (failed)   : 2 (0)
  Version  9 exported flow number                    : 16
NetStream data export information.
Source interface from which the NetStream data is exported.
VPN to which the destination address of the NetStream data export belongs.
Destination IP address and UDP port number of the NetStream data export.
Number of flows that are exported in version 5 format.
Number of UDP packets that are sent in version 5 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
Number of flows that are exported in version 9 format.
Number of UDP packets that are sent in version 9 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
L2 export information
Statistics of the Layer 2 data export.
Statistics of NetStream protocol-port aggregation in version 8 format.
Number of flows that are exported in version 8 format.
Number of UDP packets that are sent in version 8 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
Number of flows that are exported in version 10 format.
Number of UDP packets that are sent in version 10 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
display ip netstream template
Use display ip netstream template to display NetStream template information.
In standalone mode:
display ip netstream template [ slot slot-number ]
In IRF mode:
display ip netstream template [ chassis chassis-number slot slot-number  ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays NetStream template information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NetStream template information for the global active MPU. (In IRF mode.)
IP NetStream templates vary by aggregation mode. This command displays IP NetStream template information for all the configured aggregation modes.
# Display NetStream template information.
<Sysname> display ip netstream template
 Flow template refresh frequency            : 20
 Flow template refresh interval             : 30 min
 Active flow templates                      : 2
 Created flow templates                     : 2
Protocol-port outbound template:
 Template ID                : 3258
 Field count                : 14
 Field type                   Field length (bytes)
 Flows                        4
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 PAD                          1
 L4 source port               2
 L4 destination port          2
 Sampling algorithm           1
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
Protocol-port inbound template:
 Template ID                : 3257
 Field count                : 14
 Flows                        4
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 PAD                          1
 L4 source port               2
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
Refresh frequency at which the templates are sent, in packets.
Refresh interval at which the templates are sent, in minutes.
Number of active NetStream templates.
Number of templates that have been created.
Information of the protocol-port template in the outbound direction.
Information of the protocol-port template in the inbound direction.
Packets
Number of packets sent by using the template.
Last template export time
Time when the template was last exported.
Field count
Total number of fields in a template.
Field type
Type of a field in the template.
Flows
Number of aggregate flows.
Out packets
Number of sent packets.
In packets
Number of received packets.
Out bytes
Size of sent packets, in bytes.
In bytes
Size of received packets, in bytes.
First forwarded
System time when the first packet was forwarded, accurate to milliseconds.
Last forwarded
System time when the last packet was forwarded, accurate to milliseconds.
L4 source port
Source UDP or TCP port.
L4 destination port
Destination UDP or TCP port.
PAD
Padding string.
Sampling interval
Sampling rate.
enable
Use enable to enable a NetStream aggregation mode.
Use undo enable to disable a NetStream aggregation mode.
enable
undo enable
No NetStream aggregation mode is enabled.
NetStream aggregation mode view
# Enable NetStream destination-prefix aggregation mode.
[Sysname] ip netstream aggregation destination-prefix
[Sysname-ns-aggregation-dstpre] enable
ip netstream (interface view)
Use ip netstream to enable NetStream on an interface.
Use undo ip netstream to disable NetStream on an interface.
ip netstream [ inbound | outbound ]
undo ip netstream [ inbound | outbound ]
NetStream is disabled on an interface.
Interface view
inbound: Enables NetStream for incoming traffic.
outbound: Enables NetStream for outgoing traffic.
If you configure this command without specifying a traffic direction, NetStream is enabled on the interface for both incoming and outgoing traffic.
# Enable NetStream for incoming traffic on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ip netstream inbound
Use ip netstream aggregation to specify a NetStream aggregation mode and enter its view.
Use undo ip netstream aggregation to remove the configuration for a NetStream aggregation mode.
ip netstream aggregation { destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
undo ip netstream aggregation { destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
No NetStream aggregation mode is specified.
destination-prefix: Specifies the destination-prefix aggregation by destination AS number, destination address mask length, destination prefix, and outbound interface index.
prefix: Specifies the source and destination prefix aggregation by the following criteria:
·     Source AS number.
·     Destination AS number.
·     Source address mask length.
·     Destination address mask length.
·     Source prefix.
·     Destination prefix.
·     Inbound interface index.
·     Outbound interface index.
prefix-port: Specifies the prefix-port aggregation by the following criteria:
·     Source prefix.
·     ToS.
·     Protocol number.
·     Source port.
·     Destination port.
protocol-port: Specifies the protocol-port aggregation by protocol number, source port, and destination port.
source-prefix: Specifies the source-prefix aggregation by source AS number, source address mask length, source prefix, and inbound interface index.
tos-destination-prefix: Specifies the ToS-destination-prefix aggregation by ToS, destination AS number, destination address mask length, destination prefix, and outbound interface index.
tos-prefix: Specifies the ToS-prefix aggregation by the following criteria:
·     ToS.
·     Source AS number.
·     Source prefix.
tos-protocol-port: Specifies the ToS-protocol-port aggregation by ToS, protocol number, source port, destination port, inbound interface index, and outbound interface index.
tos-source-prefix: Specifies the ToS-source-prefix aggregation by ToS, source AS number, source prefix, source address mask length, and inbound interface index.
In NetStream aggregation mode view, you can perform the following tasks:
·     Enable or disable the specified NetStream aggregation mode.
·     Configure source interface, destination IP address, and destination port for the NetStream data export.
A flow matching multiple aggregation modes is counted as multiple aggregate flows.
# Set the NetStream aggregation mode to destination-prefix, and enter NetStream destination-prefix aggregation mode view.
enable
ip netstream export host
ip netstream export source
ip netstream aggregation advanced
Use ip netstream aggregation advanced to enable NetStream hardware aggregation.
Use undo ip netstream aggregation advanced to disable NetStream hardware aggregation.
NetStream hardware aggregation is disabled.
The hardware aggregation does not take effect if the destination host is configured for NetStream traditional data export.
The NetStream hardware aggregation entries are stored in the same cache as NetStream traditional data entries and are exportable.
# Enable NetStream hardware aggregation.
[Sysname] ip netstream aggregation advanced
ip netstream aging
Use ip netstream aging command to enable periodical aging and TCP FIN- and RST-triggered aging.
Use undo ip netstream aging to disable periodical aging and TCP FIN- and RST-triggered aging.
ip netstream aging
Periodical aging and TCP FIN- and RST-triggered aging are enabled.
# Disable periodical aging and TCP FIN- and RST-triggered aging.
[Sysname] undo ip netstream aging
Use ip netstream export host to specify a destination host for NetStream data export.
Use undo ip netstream export host to remove the specified destination host or all destination hosts that are configured in the current view.
ip netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
undo ip netstream export host [ ip-address [ vpn-instance vpn-instance-name ] ]
No destination host is specified for NetStream data export.
ip-address: Specifies the destination IP address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
You can specify the same destination IP address and UDP port in different NetStream aggregation mode views. If an aggregation mode is not enabled, the display ip netstream export command cannot display the destination host configuration for the mode.
If no destination host is specified in a NetStream aggregation mode view, the destination host in system view applies. If destination hosts are specified in a NetStream aggregation view and system view, the destination hosts in aggregation view take effect.
You can specify a maximum of four destination hosts in system view or a NetStream aggregation mode view. If you specify a destination host with the same IP address but different UDP ports in the same view, the most recent configuration takes effect. You can specify destination hosts with the same IP address and UDP port but different VPN instances.
NetStream traditional data is exported to all destination hosts in system view. NetStream aggregation data is exported to all destination hosts in the related NetStream aggregation mode view. If you expect only the aggregation data, specify destination hosts only in the NetStream aggregation mode view. Aggregation data export reduces bandwidth usage.
# In system view, specify 172.16.105.48 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Sysname] ip netstream export host 172.16.105.48 5000
ip netstream export rate
Use ip netstream export rate to limit the NetStream data export rate.
Use undo ip netstream export rate to restore the default.
ip netstream export rate rate
The export rate of NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has space for new packets.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ip netstream export rate 10
Use ip netstream export source to specify the source interface for data packets sent to NetStream servers.
Use undo ip netstream export source to restore the default.
ip netstream export source interface interface-type interface-number
The packets take the IP address of the output interface as the source IP address.
interface-type interface-number: Specifies a source interface by its type and number.
The IP address of the specified source interface is used as the source IP address for packets sent to NetStream servers.
You can configure different source interfaces in different NetStream aggregation mode views.
If no source interface is configured in a NetStream aggregation mode view, the source interface in system view applies.
# In system view, specify HundredGigE 1/0/1 as the source interface for NetStream traditional data packets.
[Sysname] ip netstream export source interface hundredgige 1/0/1
# In AS aggregation mode view, specify HundredGigE 1/0/2 as the source interface for NetStream aggregation data packets.
[Sysname] ip netstream aggregation as
[Sysname-ns-aggregation-as] ip netstream export source interface hundredgige 1/0/2
ip netstream export template refresh-rate
Use ip netstream export template refresh-rate to set the refresh rate for the NetStream version 9 or version 10 template.
Use undo ip netstream export template refresh-rate to restore the default.
ip netstream export template refresh-rate { packet packets | time minutes }
undo ip netstream export template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 and version 10 are template-based and support user-defined formats. A NetStream device must send the version 9 or version 10 template to NetStream servers regularly, because the servers do not permanently save the templates.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the Netstream version 9 or version 10 template to NetStream servers every 100 packets.
[Sysname] ip netstream export template refresh-rate packet 100
ip netstream export version
Use ip netstream export version 5 to export NetStream data in the version 5 format and choose whether to record AS information.
Use ip netstream export version 9 to export NetStream data in the version 9 format and choose whether to record AS and BGP next hop information.
Use ip netstream export version 10 to export NetStream data in the version 10 format and choose whether to record AS and BGP next hop information.
Use undo ip netstream export version to restore the default.
ip netstream export version 5 { origin-as | peer-as }
ip netstream export version { 9 | 10 } { origin-as | peer-as } [ bgp-nexthop ]
NetStream traditional data export uses the version 9 format. The peer AS numbers are exported. The BGP next hop is not recorded.
origin-as: Records the source AS of the source address and the destination AS of the destination address.
peer-as: Records the ASs before and after the AS where the NetStream device resides as the source AS and destination AS, respectively.
bgp-nexthop: Records BGP next hops.
A NetStream entry records the source IP address and destination IP address, and two AS numbers for each IP address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
Only version 9 and version 10 formats support recoding BGP next hop data.
Only one version format can take effect on the device. If you execute the command multiple times, the most recent configuration takes effect.
If the version 5 format is configured, the NetStream aggregation data export uses the version 8 format.
If the version 9 format is configured, the NetStream aggregation data export uses the version 9 format.
If the version 10 format is configured, the NetStream aggregation data export uses the version 10 format.
# Configure the device to export NetStream data in the version 5 format and specify the NetStream data to include the source AS and destination AS.
[Sysname] ip netstream export version 5 origin-as
ip netstream filter
Use ip netstream filter to enable NetStream filtering on an interface.
Use undo ip netstream filter to disable NetStream filtering on an interface.
ip netstream inbound filter acl ipv4-acl-number
undo ip netstream inbound filter
NetStream filtering is disabled. NetStream collects statistics about all IPv4 packets passing through an interface.
Interface view
inbound: Filters incoming traffic.
acl ipv4-acl-number: Specifies an IPv4 ACL by its number. The value range is 2000 to 2999 for basic ACLs, 3000 to 3999 for advanced ACLs, and 4000 to 4999 for Layer 2 ACLs.
NetStream filtering uses an ACL to identify intended packets.
·     If you want to collect data for specific flows, use the ACL permit statements to identify the flows. NetStream collects data only for these flows.
·     If you do not want to collect data for specific flows, use the ACL deny statements to identify the flows. NetStream does not collect data for these flows.
If you use NetStream filtering on the interface where IPv4 and IPv6 NetStream are enabled in the same direction, make sure NetStream filtering is enabled for both IPv4 and IPv6 in this direction. For more information about IPv6 NetStream, see Network Management and Monitoring Configuration Guide.
# Use ACL 2003 for inbound NetStream filtering on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ip netstream inbound filter acl 2003
ip netstream max-entry
Use ip netstream max-entry to set the upper limit for NetStream entries.
Use undo ip netstream max-entry to restore the default.
ip netstream max-entry max-entries
A maximum of 1048576 NetStream entries can be cached.
max-entries: Specifies the upper limit for NetStream entries that the cache can accommodate.The value range for this argument is 1000 to 1048576.
The max-entries argument takes effect on each card.
If you execute the ip netstream max-entry max-entries command multiple times, the most recent configuration takes effect.
After you execute this command, the device deploys it to all cards on the device but takes effect only on cards that support NetStream. If a card does not support NetStream, a message will be sent back to the device.
# Set the upper limit to 5000 for NetStream entries.
[Sysname] ip netstream max-entry 5000
ip netstream sampler
Use ip netstream sampler to enable NetStream sampling.
Use undo ip netstream sampler to disable NetStream sampling.
ip netstream { inbound | outbound } sampler sampler-name
undo ip netstream { inbound | outbound } sampler
NetStream sampling is disabled.
Interface view
inbound: Enables NetStream sampling in the inbound direction.
outbound: Enables NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
This command enables both IPv4 and IPv6 NetStream sampling.
# Use sampler abc for inbound NetStream sampling on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ip netstream inbound sampler abc
ip netstream timeout active
Use ip netstream timeout active to set the aging timer for active flows.
Use undo ip netstream timeout active to restore the default.
ip netstream timeout active minutes
The aging timer is 5 minutes for active flows.
minutes: Sets the aging timer for active flows, in the range of 1 to 5 minutes.
A flow is considered active if packets for the NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 60 minutes for active flows.
[Sysname] ip netstream timeout active 60
ip netstream timeout inactive
Use ip netstream timeout inactive to set the aging timer for inactive flows.
Use undo ip netstream timeout inactive to restore the default.
ip netstream timeout inactive seconds
The aging timer is 300 seconds for inactive flows.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 320 seconds.
A flow is considered inactive if no packet for the NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ip netstream timeout inactive 60
netstream key
Use netstream key to set the NetStream flow classification key fields.
Use netstream key to restore the default.
netstream key [ destination-ip | destination-mac | destination-port | flow-lable | ip-tos | mpls-experimental1 | mpls-experimental2 | mpls-experimental3 | mpls-label1 | mpls-label2 | mpls-label3 | protocol | source-ip | source-mac | source-port | vxlan-destination-ip | vxlan-destination-mac | vxlan-destination-port | vxlan-flow-lable | vxlan-ip-tos | vxlan-protocol | vxlan-source-ip | vxlan-source-mac | vxlan-source-port ] *
undo netstream key
No key fields are specified for NetStream flow classification.
destination-ip: Uses the destination IP address as a flow classification key field.
destination-mac: Uses the destination MAC address as a flow classification key field.
destination-port: Uses the destination port number as a flow classification key field.
flow-lable: Uses the flow label of the IPv6 packet as a flow classification key field.
ip-tos: Uses the ToS value in the IP header as a flow classification key field.
mpls-experimental1: Uses the EXP value in the second label of the MPLS packet as a flow classification key field.
mpls-experimental2: Uses the EXP value in the first (topmost) label of the MPLS packet as a flow classification key field.
mpls-experimental3: Uses the EXP value in the third label of the MPLS packet as a flow classification key field.
mpls-label1: Uses the first (topmost) label of the MPLS packet as a flow classification key field.
mpls-label2: Uses the second label of the MPLS packet as a flow classification key field.
mpls-label3: Uses the third label of the MPLS packet as a flow classification key field.
protocol: Uses the protocol type as a flow classification key field.
source-ip: Uses the source IP address as a flow classification key field.
source-mac: Uses the source MAC address as a flow classification key field.
source-port: Uses the source port number as a flow classification key field.
vxlan-destination-ip: Uses the destination IP address in the VXLAN inner packet as a flow classification key field.
vxlan-destination-mac: Uses the destination MAC address in the VXLAN inner packet as a flow classification key field.
vxlan-destination-port: Uses the destination port number in the VXLAN inner packet as a flow classification key field.
vxlan-flow-lable: Uses the IPv6 flow label in the VXLAN inner packet as a flow classification key field.
vxlan-ip-tos: Uses the IP ToS value in the VXLAN inner packet as a flow classification key field.
vxlan-protocol: Uses the protocol in the VXLAN inner packet as a flow classification key field.
vxlan-source-ip: Uses the source IP address in the VXLAN inner packet as a flow classification key field.
vxlan-source-mac: Uses the source MAC address in the VXLAN inner packet as a flow classification key field.
vxlan-source-port: Uses the source port number in the VXLAN inner packet as a flow classification key field.
By default, the hardware classifies packets into NetStream flows based on these key fields: source and destination IP addresses, source and destination MAC addresses, and protocol. Packets matching the same key fields are grouped into one flow and sent to NetStream regularly for further tracking.
You can set the flow classification key fields to suit specific traffic monitoring requirements. For example, if you are concerned with only the traffic destination, you can set the destination IP address as the flow classification key field. All packets destined for the same IP address are classified into one flow.
After you set the NetStream flow classification key fields, statistics about the non-key fields are no longer collected.
To collect MPLS traffic flows, make sure one or more of the following fields are set as the key fields (choose the key fields according to the MPLS packet structure):
·     mpls-experimental1.
·     mpls-experimental2.
·     mpls-experimental3.
·     mpls-label1.
·     mpls-label2.
·     mpls-label3.
To collect VXLAN traffic flows, make sure the following fields are set as the key fields:
·     source-port.
·     destination-port.
·     protocol.
·     One or more of the following fields:
¡     vxlan-destination-ip.
¡     vxlan-destination-mac.
¡     vxlan-destination-port.
¡     vxlan-flow-lable.
¡     vxlan-ip-tos.
¡     vxlan-protocol.
¡     vxlan-source-ip.
¡     vxlan-source-mac.
¡     vxlan-source-port.
# Set the source IP address, destination IP address, source port number, destination port number, protocol, and ToS value as the NetStream flow classification key fields.
<Sysname>system-view
[Sysname] netstream key source-ip destination-ip source-port destination-port protocol ip-tos
ip netstream mpls
ip netstream vxlan udp-port
Use reset ip netstream statistics to clear the NetStream cache and export the cached entries to NetStream servers.
It takes the system several minutes to execute the command. During this period, the system does not collect NetStream data.
# Clear the NetStream cache and export the cached data to NetStream servers.
<Sysname> reset ip netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
