HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release757X-6W10001-Fundamentals Configuration Guide
06-Configuration file management configuration
06-Configuration file management configuration 133.60 KB
Managing configuration files
Overview
You can manage configuration files from the CLI or the BootWare menu. The following information explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
Initial configuration
Initial configuration is the collection of initial default settings for the configuration commands in software.
The device starts up with the initial configuration if you access the BootWare menu and select the Skip Current System Configuration option. In this situation, the device might also be described as starting up with empty configuration.
No commands are available to display the initial configuration. To view the initial default settings for the configuration commands, see the Default sections in the command references.
Factory defaults
Factory defaults are custom basic settings that came with the device. Factory defaults vary by device models and might differ from the initial default settings for the commands.
The device starts up with the factory defaults if no next-startup configuration files are available.
To display the factory defaults, use the display default-configuration command.
Startup configuration
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
You can display the startup configuration by using one of the following methods:
·          To display the contents of the current startup configuration file, execute the display current-configuration command before changing the configuration after the device reboots.
·          To display the contents of the next-startup configuration file, use the display saved-configuration command.
·          Use the display startup command to display names of the current startup configuration file and next-startup configuration files. Then, you can use the more command to display the contents of the specified startup configuration file.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
Next-startup configuration file redundancy
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to select the .cfg startup configuration in the following order:
1.        The main next-startup configuration file.
2.        The backup next-startup configuration file if the main next-startup configuration file is unavailable.
If no next-startup configuration files are available, the device starts up with the factory defaults.
Configuration file formats
Configuration files you specify for saving configuration must use the .cfg extension. A .cfg configuration file is a human-readable text file and its contents can be displayed by using the more command. When you save configuration to a .cfg file, the device automatically saves the configuration to an .mdb user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
Startup configuration file selection
At startup, the device uses the following procedure to identify the configuration file to load:
1.        The device searches for a valid .cfg next-startup configuration file. For more information about the file selection rules, see "Next-startup configuration file redundancy."
2.        If a valid .cfg next-startup configuration file is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3.        If a matching .mdb file is found, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
If no .cfg next-startup configuration files are available, the device starts up with the factory defaults.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
Configuration file content organization and format
IMPORTANT:
To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load, rollback, or restoration, use a configuration file created on the device. If you edit the configuration file, make sure all edits are compliant with the requirements.
A configuration file must meet the following requirements:
·          All commands are saved in their complete form.
·          No command lines contain invalid characters.
IMPORTANT
IMPORTANT:
Some command lines (for example, the sysname command) cannot contain question marks (?) or horizontal tabs (\t). If the system loads a configuration file that contains the sysname abc?? command line at startup, the system will ignore the command line and use the default system name. If the system uses that configuration file to roll back or restore the configuration, the system name will not be rolled back or restored.
·          Commands are sorted into sections by different command views, including system view, interface view, protocol view, and user line view.
·          Two adjacent sections are separated by a pound sign (#).
·          The configuration file ends with the word return.
The following is a sample configuration file excerpt:
local-user root class manage
 password hash $h$6$Twd73mLrN8O2vvD5$Cz1vgdpR4KoTiRQNE9pg33gU14Br2p1VguczLSVyJLO2huV5Syx/LfDIf8ROLtVErJ/C31oq2rFtmNuyZf4STw==
interface Vlan-interface1
 ip address 192.168.1.84 255.255.255.0
FIPS compliance
Enabling configuration encryption
IMPORTANT
IMPORTANT:
Any devices running Comware 7 software can decrypt the encrypted configuration files. To prevent an encrypted file from being decoded by unauthorized users, make sure the file is accessible only to authorized users.
Configuration encryption enables the device to encrypt a startup configuration file automatically when it saves the running configuration. All devices running Comware 7 software use the same method to encrypt configuration files.
You cannot use the more command to view the contents of an encrypted configuration file.
You cannot compare an encrypted configuration file with any configuration for their differences.
To enable configuration encryption:
Step
Remarks
1.       Enter system view.
N/A
2.       Enable configuration encryption.
configuration encrypt { private-key | public-key }
By default, configuration encryption is disabled. Configuration is saved unencrypted.
Comparing configurations for their differences
You can compare configuration files or compare a configuration file with the running configuration for their differences.
If you specify the next-startup configuration for a comparison, the system selects the next-startup configuration file to be compared with in the following order:
If both configuration files are unavailable, the system displays a message indicating that no next-startup configuration files exist.
To compare configurations for their differences in any view:
Display the differences that a configuration file, the running configuration, or the next-startup configuration has as compared with the specified source configuration file.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
Display the differences that a configuration file or the next-startup configuration has as compared with the running configuration.
display diff current-configuration { configfile file-name-d | startup-configuration }
Display the differences that a configuration file has as compared with the next-startup configuration.
display diff startup-configuration configfile file-name-d
Display the differences that the running configuration has as compared with the next-startup configuration.
·         Method 1:
display diff startup-configuration current-configuration
·         Method 2:
display current-configuration diff
Disabling automatic system-wide next-startup configuration file operations
By default, the system performs the following operations on all MPUs:
·          Saves the running configuration to the next startup file on each MPU when you execute the save [ safely ] [ backup | main ] [ force ] [ mdc-all | changed ] command.
·          Deletes the next-startup configuration file on each MPU when you execute the reset saved-configuration command.
To have the system save the running configuration or delete the next-startup configuration file only on the active MPU (in standalone mode) or the global active MPU (in IRF mode), perform this task.
To disable automatic system-wide next-startup configuration file operations:
Step
Remarks
N/A
2.       Disable automatic system-wide next-startup configuration file operations.
undo standby auto-update config
By default, next-startup configuration file operations are automatically synchronized across the entire system.
Saving the running configuration
When an IRF member device splits from the IRF fabric, its settings are retained in memory but removed from the running configuration on the IRF fabric. Saving the running configuration before the IRF fabric recovers will remove the member device's settings from the next-startup configuration file.
If you have saved the running configuration before the member device rejoins the IRF fabric, perform the following steps to restore the member device settings to the next-startup configuration file:
1.        Resolve the split issue.
2.        Reboot the member device to rejoin the IRF fabric.
3.        After the member device rejoins the IRF fabric, execute the display current-configuration command to verify that the member device's settings have been restored from memory to the running configuration.
4.        Save the running configuration to the next-startup configuration file on the IRF fabric.
IMPORTANT
IMPORTANT:
To ensure a successful configuration restoration, make sure the IRF fabric has not rebooted after the member device left.
When a card is removed from the system, its settings are retained in memory but removed from the running configuration on the device. Saving the running configuration before installing the replacement card will remove the card's settings from the next-startup configuration file.
If you have saved the running configuration after removing a card, perform the following steps to restore the card settings to the next-startup configuration file:
1.        Install the replacement card.
2.        After the replacement card comes online, execute the display current-configuration command to verify that the card's settings have been automatically restored from memory to the running configuration.
3.        Save the running configuration to the next-startup configuration file.
IMPORTANT
IMPORTANT:
To ensure a successful configuration restoration, make sure the system has not rebooted after the card was removed.
Using different methods to save the running configuration
When you save the running configuration to a configuration file, you can specify the file as the next-startup configuration file.
If you are specifying the file as the next-startup configuration file, use one of the following methods to save the configuration:
·          Fast mode—Use the save command without the safely keyword. In this mode, the device directly overwrites the target next-startup configuration file. If a reboot or power failure occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots (see "Specifying a next-startup configuration file").
·          Safe mode—Use the save command with the safely keyword. Safe mode is slower than fast mode, but more secure. In safe mode, the system saves the configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot or power failure occurs during the save operation, the next-startup configuration file is still retained.
Use the safe mode if the power source is not reliable or you are remotely configuring the device.
(In standalone mode.) To save the running configuration, perform one of the following tasks in any view:
Remarks
Save the running configuration to a configuration file without specifying the file as a next-startup configuration file.
N/A
Save the running configuration to a configuration file and specify the file as a next-startup configuration file.
Make sure you save the configuration to a file in the root directory of the storage medium.
By default, this command saves the configuration to both active and standby MPUs. To save the configuration only to the active MPU, disable automatic system-wide next-startup configuration file operations.
As a best practice, specify the safely keyword for reliable configuration saving.
If you specify only the safely keyword, the command saves the configuration to the main startup configuration file for the MDC where you are logged in.
If the force keyword is specified, the command saves the configuration to the existing next-startup configuration file.
If the force keyword is not specified, the command allows you to specify a new next-startup configuration file.
(In IRF mode.) To save the running configuration, perform one of the following tasks in any view:
Remarks
save file-url [ all | chassis chassis-number slot slot-number ]
N/A
Save the running configuration to a configuration file and specify the file as a startup configuration file.
By default, this command saves the configuration to all MPUs in the IRF fabric. To save the configuration only to the global active MPU, disable automatic system-wide next-startup configuration file operations.
Configuring configuration rollback
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback feature. This feature helps you revert to a previous configuration state or adapt the running configuration to different network environments.
The configuration rollback feature compares the running configuration against the specified replacement configuration file and handles configuration differences as follows:
·          If a command in the running configuration is not in the replacement file, the rollback feature executes the undo form of the command.
·          If a command in the replacement file is not in the running configuration, the rollback feature adds the command to the running configuration.
·          If a command has different settings in the running configuration and the configuration file, the rollback feature replaces the running command setting with the setting in the configuration file.
To facilitate configuration rollback, the configuration archive feature was developed. This feature enables the system to save the running configuration automatically at regular intervals.
Configuration task list
Tasks at a glance
(Required.) Setting configuration archive parameters
(Required.) Perform one of the following tasks:
·         Enabling automatic configuration archiving
·         Manually archiving the running configuration
(Required.) Rolling back configuration
About setting configuration archive parameters
Before archiving the running configuration, either manually or automatically, you must set a file directory and file name prefix for configuration archives.
The archive directory can be located on the local device or on a remote SCP server.
If you use local archiving, configuration archives are named in the format of prefix_serial number.cfg, for example, archive_1.cfg and archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
If you change the file directory or file name prefix on the local device, or reboot the device, the following events occur:
·          The old configuration archives change to common configuration files.
·          The configuration archive counter is reset.
·          The display archive configuration command no longer displays the old configuration archives.
·          The serial number for new configuration archives starts at 1.
If you archive the running configuration to a remote SCP server, configuration archives are named in the format of prefix_YYYYMMDD_HHMMSS.cfg, for example, archive_20170526_203430.cfg.
If you change the file directory or file name prefix on the remote SCP server, the display archive configuration command no longer displays the old configuration archives saved before the change.
Local archiving (the archive configuration location command) and remote archiving (the archive configuration server command) are mutually exclusive. You cannot use the two features at the same time.
IMPORTANT
IMPORTANT:
In FIPS mode, the device does not support archiving the running configuration to a remote SCP server.
For local configuration archiving, after the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
The maximum number of configuration archives on a remote SCP server depends on the SCP server setting and is not restricted by the archive configuration max command.
The undo archive configuration location command removes the local configuration archive directory and file name prefix settings, but it does not delete the configuration archives on the device. The command also performs the following operations:
·          Disables both the manual and automatic configuration archiving features.
·          Restores the default settings for the archive configuration interval and archive configuration max commands.
·          Clears the configuration archive information displayed by using the display archive configuration command.
The undo archive configuration server command removes the remote configuration archive directory and file name prefix settings, but it does not delete the configuration archives on the server. The command also performs the following operations:
·          Restores the default setting for the archive configuration interval command.
Setting local configuration archive parameters
To set the configuration archive parameters for archiving the running configuration to the local device:
Step
Remarks
N/A
2.       Set the directory and file name prefix for archiving the running configuration.
archive configuration location directory filename-prefix filename-prefix
By default, no path or file name prefix is set for configuration archives on the device, and the system does not regularly save configuration.
(In standalone mode.) The configuration archive directory must already exist on the active MPU and cannot include a slot number.
(In IRF mode.) The configuration archive directory must already exist on the global active MPU and cannot include a chassis or slot number.
3.       (Optional.) Set the maximum number of configuration archives.
archive configuration max file-number
The default number is 5.
Change the setting depending on the amount of storage available on the device.
Setting remote configuration archive parameters
To set the configuration archive parameters for archiving the running configuration to a remote SCP server:
Step
Remarks
N/A
2.       Set the directory and file name prefix for archiving the running configuration to a remote SCP server.
archive configuration server scp { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] filename-prefix filename-prefix
By default, no path or file name prefix is set for archiving the running configuration to a remote SCP server.
3.       Configure the username for logging in to the SCP server.
archive configuration server user user-name
By default, no username is configured for logging in to the SCP server.
4.       Configure the password for logging in to the SCP server.
archive configuration server password { cipher | simple } string
By default, no password is configured for logging in to the SCP server.
Make sure you have set an archive path and file name prefix before performing this task.
To enable automatic configuration archiving:
Step
Remarks
N/A
2.       Enable automatic configuration archiving and set the archiving interval.
archive configuration interval interval
By default, automatic configuration archiving is disabled.
To display configuration archive names and their archiving time, use the display archive configuration command.
To save system resources, disable automatic configuration archiving and manually archive the configuration if the configuration will not be changed very often. You can also manually archive configuration before performing complicated configuration tasks. Then, you can use the archive for configuration recovery if the configuration attempt fails.
Perform the following task in user view:
Manually archive the running configuration.
CAUTION
CAUTION:
To ensure a successful rollback, do not perform the following operations while the system is rolling back the configuration:
·      Install or remove modules.
·      Perform an active/standby MPU switchover.
·      Perform a master/subordinate switchover.
Make sure the replacement configuration file is created by using the configuration archive feature or the save command on the local device. If the configuration file is not created on the local device, make sure the command lines in the configuration file are fully compatible with the local device.
To perform a configuration rollback:
Step
Remarks
N/A
2.       Roll the running configuration back to the configuration defined by a configuration file.
The specified configuration file must not be encrypted and must be saved on the local device.
The configuration rollback feature might fail to reconfigure some commands in the running configuration for one of the following reasons:
·          A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback feature cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
·          A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
·          The commands in different views are dependent on each other.
·          Commands or command settings that the device does not support cannot be added to the running configuration.
Configuring configuration commit delay
This feature enables the system to automatically remove the settings you made during a configuration commit delay interval if you have not manually committed them.
You specify the configuration commit delay interval by using the configuration commit delay timer. The system creates a rollback point to record the configuration status when you start the configuration commit delay timer. The settings you made during the configuration commit delay interval takes effect immediately. However, these settings will be removed automatically if you have not manually committed them before the configuration commit delay timer expires. Then, the system returns to the configuration status when the configuration commit delay timer started.
This feature prevents a misconfiguration from causing the inability to access the device and is especially useful when you configure the device remotely.
When you use this feature, follow these restrictions and guidelines:
·          In a multi-user context, make sure no one else is configuring the device.
·          To avoid unexpected errors, do not perform any operations during the configuration rollback.
·          You can reconfigure the configuration commit delay timer before it expires to shorten or extend the commit delay interval. However, the rollback point will not change.
·          The configuration commit delay feature is a one-time setting. The feature is disabled with the rollback point removed when the commit delay timer expires or after a manual commit operation is performed. To use this feature again, you must restart the timer.
To configure the configuration commit delay feature:
Step
2.       Start the commit delay timer.
configuration commit delay delay-time
3.       (Optional.) Commit the settings configured after the commit delay timer started.
CAUTION:
Using the undo startup saved-configuration command can cause an IRF split after the IRF fabric or an IRF member reboots. When you execute this command, make sure you understand its impact on your network.
You can specify a .cfg file as a next-startup configuration file when you execute the save [ safely ] [ backup | main ] [ force ] command.
Alternatively, you can execute the startup saved-configuration cfgfile [ backup | main ] command to specify a .cfg configuration file as the main or backup next-startup configuration file.
When you perform this task, follow these restrictions and guidelines:
·          (In standalone mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on both the active and standby MPUs.
·          (In IRF mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on each MPU in the IRF fabric.
·          Make sure you save the file on the same type of storage medium across all MPUs.
·          As a best practice, specify different files as the main and backup next-startup configuration files.
·          The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file.
To specify a next-startup configuration file, perform the following task in user view:
Remarks
Specify a next-startup configuration file.
By default, no next-startup configuration files are specified.
If you do not specify the backup or main keyword, this command specifies the configuration file as the main next-startup configuration file.
Use the display startup command and the display saved-configuration command in any view to verify the configuration.
Backing up the main next-startup configuration file to a TFTP server
Before performing this task, make sure the following requirements are met:
·          The server is reachable.
·          The server is enabled with TFTP service.
·          You have read and write permissions to the server.
To back up the main next-startup configuration file to a TFTP server:
Step
Remarks
1.       (Optional.) Verify that a next-startup configuration file has been specified in user view.
display startup
If no next-startup configuration file has been specified or the specified configuration file does not exist, the backup operation will fail.
2.       Back up the next-startup configuration file to a TFTP server in user view.
backup startup-configuration to { ipv4-server | ipv6 ipv6-server } [ dest-filename ] [ vpn-instance vpn-instance-name ]
This command is not supported in FIPS mode.
Restoring the main next-startup configuration file from a TFTP server
Perform this task to download a configuration file to the device from a TFTP server and specify the file as the main next-startup configuration file.
Before restoring the main next-startup configuration file, make sure the following requirements are met:
To restore the main next-startup configuration file from a TFTP server:
Step
Remarks
1.       Restore the main next-startup configuration file from a TFTP server in user view.
restore startup-configuration from { ipv4-server | ipv6 ipv6-server } src-filename [ vpn-instance vpn-instance-name ]
2.       (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file.
display startup
N/A
Deleting a next-startup configuration file
CAUTION:
By default, this task permanently deletes a next-startup configuration file from all MPUs. To delete the configuration file only from the active MPU (in standalone mode) or the global active MPU (in IRF mode), disable automatic system-wide next-startup configuration file operations.
You can perform this task to delete a next-startup configuration file.
If both the main and backup next-startup configuration files are deleted, the device uses the factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
Remarks
Delete a next-startup configuration file.
If you do not specify the backup or main keyword, this command deletes the main next-startup configuration file.
Displaying and maintaining configuration files
Display configuration archive information.
(In standalone mode.) Display the running configuration.
display current-configuration [ configuration [ module-name ] | exclude-provision | interface [ interface-type [ interface-number ] ] ] [ all ]
(In IRF mode.) Display the running configuration.
display current-configuration [ [ configuration [ module-name ] | exclude-provision | interface [ interface-type [ interface-number ] ] ] [ all ] | chassis chassis-number ]
Display the factory defaults.
Display the differences between configurations.
·         display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
·         display diff current-configuration { configfile file-name-d | startup-configuration }
·         display diff startup-configuration { configfile file-name-d | current-configuration }
Display the contents of the configuration file for the next system startup.
Display the names of the configuration files for this startup and the next startup.
display startup
Display the valid configuration in the current view.
display this [ all ]
