HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release757X-6W10001-Fundamentals Configuration Guide
03-Login management configuration
03-Login management configuration 350.90 KB
Login overview· 1
Using the console port for the first device access· 3
Configuring CLI login· 4
CLI overview·· 4
User lines· 4
Login authentication modes· 5
User roles· 5
FIPS compliance· 5
Configuring console or USB console login· 6
Disabling authentication for console or USB console login· 6
Configuring password authentication for console or USB console login· 7
Configuring scheme authentication for console or USB console login· 8
Configuring common AUX or console line settings· 8
Configuring Telnet login· 10
Configuring the device as a Telnet server 10
Using the device to log in to a Telnet server 15
Configuring SSH login· 16
Configuring the device as an SSH server 16
Using the device to log in to an SSH server 18
Displaying and maintaining CLI login· 18
Configuring Web login· 20
FIPS compliance· 20
Configuring HTTP login· 20
Configuring HTTPS login· 21
Displaying and maintaining Web login· 23
Web login configuration examples· 24
HTTP login configuration example· 24
HTTPS login configuration example· 24
Accessing the device through SNMP· 27
Configuring RESTful access· 28
FIPS compliance· 28
Configuring RESTful access over HTTP· 28
Configuring RESTful access over HTTPS· 28
Controlling user access to the device· 30
FIPS compliance· 30
Controlling Telnet and SSH logins· 30
Configuration procedures· 30
Configuration example· 31
Controlling Web logins· 31
Configuring source IP-based Web login control 32
Logging off online Web users· 32
Configuration example· 32
Controlling SNMP access· 33
Configuration procedure· 33
Configuration example· 34
Configuring command authorization· 35
Configuration procedure· 35
Configuration example· 36
Configuring command accounting· 37
Configuration procedure· 38
Configuration example· 38
Login overview
The first time you access the device, you can only log in to the CLI of the default MDC through the console port. After login, you can create non-default MDCs, change console login parameters, or configure other access methods. Table 1 describes the supported login methods, the default login settings, and the minimum configuration requirements.
Non-default MDCs do not have any console ports or USB console ports. To log in to a non-default MDC for the first time, you must perform the following tasks:
·          Log in to the default MDC.
·          Switch to the non-default MDC by using the switchto mdc command.
After you log in to a non-default MDC, you can configure Telnet login, SSH login, Web, SNMP access, or RESTful access. Then, administrators of the default MDC and those of the non-default MDC can access the non-default MDC through Telnet, SSH, SNMP, Web, or the RESTful API. For more information about MDC, see Virtual Technologies Configuration Guide.
Telnet, HTTP-based Web login, and HTTP-based RESTful access are not supported in FIPS mode.
Table 1 Login methods at a glance
Login method
Default settings and minimum configuration requirements
Login configuration
CLI login:
·         Console login
By default, console login is enabled and does not require authentication. The default user role is network-admin. To improve device security, configure password or scheme authentication for the AUX line immediately after you log in to the device for the first time.
·         Telnet login
By default, Telnet login is disabled.
To enable Telnet login, perform the following tasks:
·         Enable the Telnet server feature.
·         Assign an IP address to a Layer 3 interface and make sure the interface and the Telnet client can reach each other.
·         Configure an authentication mode for VTY login users. By default, password authentication is used but no password is configured.
·         Assign a user role to VTY login users. By default, a VTY login user is assigned the network-operator user role.
·         SSH login
By default, SSH login is disabled.
To enable SSH login, perform the following tasks:
·         Enable the SSH server feature and configure SSH attributes.
·         Assign an IP address to a Layer 3 interface. Make sure the interface and the SSH client can reach each other.
·         Configure scheme authentication for VTY login users. By default, password authentication is used.
Web login
By default, Web login is disabled.
To enable Web login, perform the following tasks:
·         Assign an IP address to a Layer 3 interface. Make sure the interface and the Web user's host can reach each other.
·         Configure a local user account for Web login and assign a user role to the account. By default, the network-operator user role is assigned to the account.
·         Assign HTTP or HTTPS service to the user. By default, no service type is assigned to a local user.
SNMP access
By default, SNMP access is disabled.
To enable SNMP access, perform the following tasks:
·         Assign an IP address to a Layer 3 interface. Make sure the interface and the NMS can reach each other.
·         Configure SNMP basic parameters.
RESTful access
By default, RESTful access is disabled.
To enable RESTful access, perform the following tasks:
·         Assign an IP address to a Layer 3 interface. Make sure the interface and the RESTful access user's host can reach each other.
·         Enable RESTful access over HTTP or RESTful access over HTTPS.
·         Configure a local user account for RESTful access and assign a user role to the account. By default, the network-operator user role is assigned to the account.
The first time you access the device, you can only log in to the CLI through the console port.
To log in through the console port, prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
To log in through the console port:
1.        Connect the DB-9 female connector of the console cable to the serial port of the PC.
2.        Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a terminal to the console port
3.        If the PC is off, turn on the PC.
4.        On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
¡  Bits per second—9600 bps.
¡  Flow control—None.
¡  Parity—None.
¡  Stop bits—1.
¡  Data bits—8.
5.        Power on the device and press Enter as prompted.
The user view prompt appears. You can enter commands to configure or manage the device. To get help, enter ?.
By default, you can log in to the CLI through the console port. After you log in, you can configure other CLI login methods, including Telnet and SSH.
To prevent illegal access to the CLI and control user behavior, perform the following tasks as required:
·          Configure login authentication.
·          Assign user roles.
·          Configure command authorization and command accounting.
·          Use ACLs to filter unauthorized logins.
This chapter describes how to configure and use CLI login methods, including login authentication, user roles, and common user line settings. For more information about command authorization, command accounting, and unauthorized access filtering, see "Controlling user access to the device."
CLI overview
User lines
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
The device supports the user lines listed in Table 2. Different user lines require different login methods.
Table 2 CLI login method and user line matrix
User line
Login method
Console line
Console port on the LSUM1SUPD0 MPU.
AUX line
USB console port on the LSUM1SUPD0 MPU.
Console port on other MPUs.
Virtual type terminal (VTY) line
Telnet or SSH.
User line numbering
Every user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence of console, AUX, and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. User lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods, as shown in Table 2. When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, four VTY lines (0 to 3) are configured, of which VTY 0 and VTY 3 are idle. When a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
You can configure login authentication to prevent illegal access to the device CLI.
In non-FIPS mode, the device supports the following login authentication modes:
·          None—Disables authentication. This mode allows access without authentication and is insecure.
·          Password—Requires password authentication. A user must provide the correct password at login.
·          Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
In FIPS mode, the device supports only the scheme authentication mode.
Different login authentication modes require different user line configurations, as shown in Table 3.
Table 3 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.       Set the authentication mode to password.
2.       Set a password.
Scheme
1.       Set the authentication mode to scheme.
2.       Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·          In none or password authentication mode, the device assigns the user roles specified for the user line.
·          In scheme authentication mode, the device uses the following rules to assign user roles:
¡  For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
¡  For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
FIPS compliance
Telnet login is not supported in FIPS mode.
You can connect a terminal to the console port or USB console port of the device to log in and manage the device, as shown in Figure 2. For the login procedure, see "Using the console port for the first device access."
Figure 2 Logging in through the console port
By default, USB console login is enabled and password authentication is required, but no password is set. To log in to the device through the USB console port, you must first log in through console port and configure USB console login.
To configure console or USB console login, perform the following tasks:
Tasks at a glance
Remarks
(Required.) Perform one of the following tasks:
·         Disabling authentication for console or USB console login
·         Configuring password authentication for console or USB console login
·         Configuring scheme authentication for console or USB console login
In FIPS mode, only the scheme authentication mode is supported.
(Optional.) Configuring common AUX or console line settings
N/A
Console or USB console login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
1.       Enter system view.
N/A
2.       Enter console/AUX line view or class view.
·         Enter console or AUX line view:
line { aux | console } first-number [ last-number ]
·         Enter console or AUX line class view:
line class { aux | console }
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
A setting in user line class view does not take effect for current online users. It takes effect only for new login users.
3.       Disable authentication.
authentication-mode none
In non-FIPS mode, authentication is disabled for the console line and password authentication is enabled for the AUX line by default.
In FIPS mode, scheme authentication is enabled by default.
4.       Assign a user role.
user-role role-name
By default, a console user of the default MDC is assigned the network-admin user role. Non-default MDCs do not support console or USB console login.
After you finish this configuration task, a user can log in through the console or USB console port without authentication.
Step
Remarks
N/A
3.       Enable password authentication.
authentication-mode password
4.       Set a password.
set authentication password { hash | simple } password
By default, no password is set.
5.       Assign a user role.
user-role role-name
After you finish this configuration task, a user must provide the configured password when logging in through the console or USB console port.
Step
Remarks
N/A
3.       Enable scheme authentication.
authentication-mode scheme
To use scheme authentication, you must also perform the following tasks:
·          Configure login authentication methods in ISP domain view.
·          For remote authentication, configure a RADIUS, HWTACACS, or LDAP scheme.
·          For local authentication, create a local user account and configure the relevant attributes.
After you finish this configuration task, a user must provide the configured username and password when logging in through the console or USB console port.
Some common settings for an AUX or console line take effect immediately and can interrupt the current session. Use a login method different from console login to log in to the device before you change AUX or console line settings.
After you change AUX or console line settings, adjust the settings on the configuration terminal accordingly for a successful login.
To configure common settings for an AUX or console line:
Step
Remarks
N/A
3.       Set the transmission rate.
speed speed-value
By default, the transmission rate is 9600 bps.
This command is not available in AUX or console line class view.
4.       Specify the parity.
By default, a user line does not use parity.
5.       Specify the number of stop bits for a character.
stopbits { 1 | 1.5 | 2 }
The default is 1.
Stop bits indicate the end of a character. The more the stop bits, the slower the transmission.
6.       Specify the number of data bits for a character.
databits { 5 | 6 | 7 | 8 }
The default is 8.
Configure this command depending on the character coding type. For example, set the number of data bits to 7 for standard ASCII characters. Set the number of data bits to 8 for extended ASCII characters.
Keywords 5 and 6 are not supported in the current software version.
7.       Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
8.       Specify the escape key.
escape-key { character | default }
By default, pressing Ctrl+C terminates a command.
9.       Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
10.     Configure the flow control mode.
By default, flow control is disabled.
11.     Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports ANSI and VT100 terminal display types. As a best practice, specify VT100 type on both the device and the configuration terminal. If either side uses the ANSI type, a display problem might occur when a command line has more than 80 characters. For example, a cursor positioning error might occur.
12.     Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends up to 24 lines to the terminal at a time when pausing between screens of output is enabled.
To disable pausing between screens of output, set the value to 0.
13.     Set the size for the command history buffer.
history-command max-size value
By default, the buffer saves up to 10 history commands.
14.     Set the CLI connection idle-timeout timer.
By default, the CLI connection idle-timeout timer is 10 minutes.
If no interaction occurs between the device and the user within the idle-timeout interval, the system automatically terminates the user connection on the user line.
If you set the timeout timer to 0, the connection will not be aged out.
15.     Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The undo shell command is not supported in console line view.
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
By default, Telnet login is disabled on the device. To configure Telnet login, you must first log in to the device through any other method.
Tasks at a glance
(Required.) Enabling Telnet server
·         Disabling authentication for Telnet login
·         Configuring password authentication for Telnet login
·         Configuring scheme authentication for Telnet login
(Optional.) Setting the maximum number of concurrent Telnet users
(Optional.) Setting the DSCP value for outgoing Telnet packets
(Optional.) Specifying the Telnet service port number
(Optional.) Configuring common VTY line settings
Telnet login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
N/A
2.       Enable the Telnet server.
telnet server enable
By default, the Telnet server is disabled.
Step
Remarks
N/A
2.       Enter VTY line view or class view.
·         Enter VTY line view:
line vty first-number [ last-number ]
·         Enter VTY line class view:
line class vty
In non-FIPS mode, password authentication is enabled for VTY lines by default.
In VTY line view, this command is associated with the protocol inbound command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
4.       (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user of the default MDC is assigned the network-operator user role. A VTY line user of a non-default MDC is assigned the mdc-operator user role.
After you finish this configuration task, a user can Telnet to the device without authentication, as shown in the following example:
<H3C>
If the maximum number of login users has been reached, the login attempt fails and the message "All user lines are used, please try later!" appears.
Step
Remarks
N/A
line class vty
4.       Set a password.
5.       (Optional.) Assign a user role.
user-role role-name
After you finish this configuration task, a user must provide the configured password when Telnetting to the device, as shown in the following example:
Password:
<H3C>
Step
Remarks
N/A
line class vty
After you finish this configuration task, a user must provide the configured username and password when Telnetting to the device, as shown in the following example:
login: admin
Password:
<H3C>
If the maximum number of login users has been reached, the login attempt fails and the message "All lines are used, please try later!" appears.
Step
Remarks
N/A
2.       Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
The default is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
The DSCP value is carried in the ToS or Traffic class field of an IP or IPv6 packet to indicate the transmission priority of the packet.
To set the DSCP value for outgoing Telnet packets:
Step
Remarks
N/A
2.       Set the DSCP value for outgoing Telnet packets.
·         For a Telnet server running IPv4:
telnet server dscp dscp-value
·         For a Telnet server running IPv6:
By default, the DSCP value is 48.
You can use this feature to change the Telnet service port number.
To specify the Telnet service port number:
Step
Remarks
N/A
2.       Specify the Telnet service port number.
·         In an IPv4 network:
·         In an IPv6 network:
By default, the Telnet service port number is 23.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command, the system automatically disconnects the Telnet session. Typically, you configure the auto-execute command telnet X.X.X.X command on the device so the device redirects a Telnet user to the host at X.X.X.X. The connection to the current device is closed when the user terminates the Telnet connection to X.X.X.X.
To configure common settings for VTY lines:
Step
Remarks
N/A
line class vty
3.       Enable the terminal service.
shell
By default, the terminal service is enabled on all user lines.
4.       Specify the supported protocols.
By default, Telnet and SSH are supported.
A protocol change does not take effect for current online users. It takes effect only for new login users.
In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
5.       Specify the shortcut key for terminating a task.
The default setting is Ctrl+C.
6.       Set the user line locking key.
lock-key key-string
7.       Specify the terminal display type.
The default terminal display type is ANSI.
8.       Set the maximum number of lines of command output to send to the terminal at a time.
9.       Set the size for the command history buffer.
The default size is 10 history commands.
10.     Set the CLI connection idle-timeout timer.
11.     Specify the command to be automatically executed for login users on the user lines.
auto-execute command command
By default, no command is specified for auto execution.
IMPORTANT IMPORTANT:
Before you configure this command and save the configuration, make sure you can access the CLI to modify the configuration through other VTY user lines or AUX user lines.
You can use the device as a Telnet client to log in to a Telnet server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 3 Telnetting from the device to a Telnet server
To use the device to log in to a Telnet server:
Step
Remarks
N/A
2.       (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.       Exit to user view.
N/A
4.       Use the device to log in to a Telnet server.
·         Log in to an IPv4 Telnet server:
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } | dscp dscp-value ] *
·         Log in to an IPv6 Telnet server:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } | dscp dscp-value ] *
N/A
SSH offers a secure method to remote login. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
By default, SSH login is disabled on the device. To configure SSH login, you must first log in to the device through any other method.
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
To configure the device as an SSH server:
Step
Remarks
N/A
2.       Create local key pairs.
·         In non-FIPS mode:
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 ] | rsa } [ name key-name ]
·         In FIPS mode:
public-key local create { dsa | ecdsa [ secp256r1 | secp384r1 ] | rsa } [ name key-name ]
By default, no local key pairs are created.
3.       Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
4.       (Optional.) Create an SSH user and specify the authentication mode.
·         In non-FIPS mode:
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
·         In FIPS mode:
ssh user username service-type stelnet authentication-type { password | password-publickey assign publickey keyname }
By default, no SSH user is configured on the device.
5.       Enter VTY line view or class view.
line class vty
6.       Enable scheme authentication.
In FIPS mode, scheme authentication is enabled for VTY lines by default.
7.       (Optional.) Specify the protocols for the user lines to support.
·         In non-FIPS mode:
·         In FIPS mode:
protocol inbound ssh
In non-FIPS mode, Telnet and SSH are supported by default.
In FIPS mode, SSH is supported by default.
8.       (Optional.) Set the maximum number of concurrent SSH users.
The default is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
9.       Exit to system view.
N/A
10.     (Optional.) Configure common settings for VTY lines.
See "Configuring common VTY line settings."
N/A
You can use the device as an SSH client to log in to an SSH server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 4 Logging in to an SSH server from the device
Perform the following tasks in user view:
Log in to an IPv4 SSH server.
ssh2 server
Log in to an IPv6 SSH server.
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Remarks
Display online CLI users.
display users [ all ]
N/A
Display user line information.
display line [ num1 | { aux | console | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Release a user line.
free line { num1 | { aux | console | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { aux | console | vty } num2 }
The device provides a built-in Web server that supports HTTP (1.0 and 1.1) and HTTPS. You can use a Web browser to log in to and configure the device.
HTTPS uses SSL to ensure the integrity and security of data exchanged between the client and the server, and is more secure than HTTP. You can define a certificate-based access control policy to allow only legal clients to access the Web interface.
Web login is disabled by default. To configure Web login, you must first log in through the console port.
FIPS compliance
HTTP is not supported in FIPS mode.
Step
Remarks
1.       (Optional.) Specify a fixed verification code for Web login.
web captcha verification-code
By default, no fixed verification code is configured. A Web user must enter the verification code displayed on the login page at login.
2.       Enter system view.
N/A
3.       Enable the HTTP service.
ip http enable
By default, the HTTP service is disabled.
4.       (Optional.) Specify the HTTP service port number.
ip http port port-number
The default HTTP service port number is 80.
5.       (Optional.) Set the Web connection idle-timeout timer.
web idle-timeout minutes
N/A
6.       (Optional.) Specify the maximum number of online HTTP users.
aaa session-limit http max-sessions
The default is 32.
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTP users, no additional HTTP users can log in until the number drops below the new limit.
7.       (Optional.) Enable Web operation logging.
webui log enable
By default, Web operation logging is disabled.
8.       Create a local user and enter local user view.
By default, no local user is configured.
9.       Configure a password for the local user.
·         In non-FIPS mode:
·         In FIPS mode:
password
A password is saved in hashed form.
By default, no password is configured for a local user.
·         In non-FIPS mode, the local user can pass authentication after entering the correct username and passing attribute checks.
·         In FIPS mode, the local user cannot pass authentication.
For security purposes, configure a password for the local user.
10.     Assign a user role to the local user.
The default user role is network-operator for a Web user.
11.     Specify the HTTP service for the local user.
service-type http
By default, no service type is specified for a local user.
The device supports the following HTTPS login modes:
·          Simplified mode—The device uses a self-signed certificate (a certificate that is generated and signed by the device itself) and the default SSL settings. The device operates in simplified mode after you enable HTTPS service on the device.
·          Secure mode—The device uses a certificate signed by a CA and a set of user-defined security protection settings to ensure security. For the device to operate in secure mode, you must perform the following tasks:
¡  Enable HTTPS service on the device.
¡  Specify an SSL server policy for the service.
¡  Configure PKI domain-related parameters.
Simplified mode is simple to configure but has potential security risks. Secure mode is more complicated to configure but provides a higher level of security.
For more information about SSL and PKI, see Security Configuration Guide.
Follow these guidelines when you configure HTTPS login:
·          If the HTTPS service and the SSL VPN service use the same port number, they must use the same SSL server policy. If they use different SSL server policies, only one of them can be enabled.
·          If the HTTPS service and the SSL VPN service use the same port number and the same SSL server policy, perform the following tasks:
¡  Disable the two services before you modify the SSL server policy.
¡  Enable the two services again after the modification.
If you do not do so, the SSL server policy will not take effect.
To configure HTTPS login:
Step
Remarks
N/A
3.       (Optional.) Apply an SSL server policy to control HTTPS access.
By default, no SSL server policy is applied. The HTTP service uses a self-signed certificate.
Disabling the HTTPS service removes the SSL service policy application. To enable the HTTPS service again, you must reconfigure this command again.
If the HTTPS service has been enabled, any changes to the associated SSL server policy do not take effect. For the changes to take effect, you must disable HTTP and HTTPS, and then apply the policy and enable HTTP and HTTPS again.
4.       Enable the HTTPS service.
ip https enable
By default, HTTPS is disabled.
Enabling the HTTPS service triggers the SSL handshake negotiation process.
·         If the device has a local certificate, the SSL handshake negotiation succeeds and the HTTPS service starts up.
·         If the device does not have a local certificate, the certificate application process starts. Because the certificate application process takes a long time, the SSL handshake negotiation might fail and the HTTPS service might not be started. To solve the problem, execute this command again until the HTTPS service is enabled.
5.       (Optional.) Apply a certificate-based access control policy to control HTTPS access.
By default, no certificate-based access control policy is applied for HTTPS access control.
For clients to log in through HTTPS, you must configure the client-verify enable command and a minimum of one permit rule in the associated SSL server policy.
For more information about certificate-based access control policies, see the chapter on PKI in Security Configuration Guide.
6.       (Optional.) Specify the HTTPS service port number.
ip https port port-number
The default HTTPS service port number is 443.
7.       (Optional.) Set the HTTPS login authentication mode.
By default, manual authentication mode is used for HTTPS login.
8.       (Optional.) Set the Web connection idle-timeout timer.
N/A
9.       (Optional.) Specify the maximum number of online HTTPS users.
aaa session-limit https max-sessions
The default is 32.
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTPS users, no additional HTTPS users can log in until the number drops below the new limit.
10.     (Optional.) Enable Web operation logging.
webui log enable
11.     Create a local user and enter local user view.
12.     Configure a password for the local user.
·         In non-FIPS mode:
·         In FIPS mode:
password
The password is saved in hashed form.
13.     Assign a user role to the local user.
14.     Specify the HTTPS service for the local user.
service-type https
Execute display commands in any view and the free web users command in user view.
Display online Web users.
display web users
Display Web interface navigation tree information.
display web menu [ chinese ]
Display HTTP service configuration and status information.
display ip http
Display HTTPS service configuration and status information.
display ip https
Log off online Web users.
Network requirements
As shown in Figure 5, the PC and the device can communicate over the IP network.
Configure the device to allow the PC to log in by using HTTP.
Figure 5 Network diagram
# Create a local user named admin. Set the password to admin, the service type to HTTP, and the user role to network-admin.
[Sysname] local-user admin
[Sysname-luser-manage-admin] service-type http
[Sysname-luser-manage-admin] authorization-attribute user-role network-admin
[Sysname-luser-manage-admin] password simple admin
[Sysname-luser-manage-admin] quit
# Enable HTTP.
[Sysname] ip http enable
1.        On the PC, run the IE browser and enter the IP address of the device in the address bar.
2.        On the login page, enter the username, password, and verification code. Select English and click Login.
After you pass authentication, the homepage appears and you can configure the device.
As shown in Figure 6, the host, device, and CA can communicate over the IP network.
Perform the following tasks to allow only authorized users to access the device's Web interface:
·          Configure the device as the HTTPS server and request a certificate for the device.
·          Configure the host as the HTTPS client and request a certificate for the host.
Figure 6 Network diagram
In this example, the CA runs Windows Server and has the SCEP add-on installed.
1.        Configure the device (HTTPS server):
# Create PKI entity en and set entity parameters.
[Device] pki entity en
[Device-pki-entity-en] common-name http-server1
[Device-pki-entity-en] fqdn ssl.security.com
[Device-pki-entity-en] quit
# Create PKI domain 1 and set domain parameters.
[Device] pki domain 1
[Device-pki-domain-1] ca identifier new-ca
[Device-pki-domain-1] certificate request url http://10.1.2.2/certsrv/mscep/mscep.dll
[Device-pki-domain-1] certificate request from ra
[Device-pki-domain-1] certificate request entity en
# Configure the PKI domain to use the 1024-bit long RSA key pair hostkey for both signing and encryption.
[Device-pki-domain-1] public-key rsa general name hostkey length 1024
[Device-pki-domain-1] quit
# Create RSA local key pairs.
[Device] public-key local create rsa
# Retrieve the CA certificate.
[Device] pki retrieve-certificate domain 1 ca
# Configure the device to request a local certificate through SCEP.
[Device] pki request-certificate domain 1
# Create SSL server policy myssl. Specify PKI domain 1 for the SSL server policy, and enable certificate-based SSL client authentication.
[Device] ssl server-policy myssl
[Device-ssl-server-policy-myssl] pki-domain 1
[Device-ssl-server-policy-myssl] client-verify enable
[Device-ssl-server-policy-myssl] quit
# Create certificate attribute group mygroup1. Configure a certificate attribute rule that matches statements with the new-ca string in the distinguished name of the subject name.
[Device] pki certificate attribute-group mygroup1
[Device-pki-cert-attribute-group-mygroup1] attribute 1 issuer-name dn ctn new-ca
[Device-pki-cert-attribute-group-mygroup1] quit
# Create certificate-based access control policy myacp. Configure a certificate access control rule that uses the matching criteria in certificate attribute group mygroup1.
[Device] pki certificate access-control-policy myacp
[Device-pki-cert-acp-myacp] rule 1 permit mygroup1
[Device-pki-cert-acp-myacp] quit
# Associate SSL server policy myssl with the HTTPS service.
[Device] ip https ssl-server-policy myssl
# Use certificate-based access control policy myacp to control HTTPS access.
[Device] ip https certificate access-control-policy myacp
# Enable the HTTPS service.
[Device] ip https enable
# Create local user usera. Set the password to 123, the service type to HTTPS, and the user role to network-admin.
[Device] local-user usera
[Device-luser-usera] password simple 123
[Device-luser-usera] service-type https
[Device-luser-usera] authorization-attribute user-role network-admin
2.        Configure the host (HTTPS client):
# On the host, run the IE browser and enter http://10.1.2.2/certsrv in the address bar.
# Request a certificate for the host as prompted.
1.        On the host, enter https://10.1.1.1 in the browser's address bar, and select the certificate issued by new-ca.
2.        When the Web login page appears, enter the username usera and password 123 to log in to the Web interface.
For more information about PKI and SSL configuration commands and the public-key local create rsa command, see Security Command Reference.
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to manage and monitor the device.
Figure 7 SNMP access diagram
The device supports SNMPv1, SNMPv2c, and SNMPv3, and can cooperate with various network management software products. However, the device and the NMS must use the same SNMP version.
By default, SNMP access is disabled. To configure SNMP access, you must first log in to the device through any other method.
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
·          Send RESTful requests to the device to pass authentication.
·          Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
RESTful access is disabled by default. To configure RESTful access, you must first log in through the console port.
FIPS compliance
RESTful access over HTTP is not supported in FIPS mode.
Step
Remarks
N/A
2.       Enable RESTful access over HTTP.
restful http enable
By default, RESTful access over HTTP is disabled.
3.       Create a local user and enter local user view.
4.       Configure a password for the local user.
5.       (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful access user.
6.       Specify the HTTP service for the local user.
service-type http
Step
Remarks
N/A
2.       Enable RESTful access over HTTPS.
restful https enable
By default, RESTful access over HTTPS is disabled.
·         In non-FIPS mode:
·         In FIPS mode:
password
6.       Specify the HTTPS service for the local user.
service-type https
Use ACLs to prevent unauthorized access, and configure command authorization and accounting to monitor and control user behavior. For more information about ACLs, see ACL and QoS Configuration Guide.
FIPS compliance
Telnet and HTTP are not supported in FIPS mode.
Use different types of ACLs to filter Telnet and SSH logins by different match criteria:
·          Basic ACL (2000 to 2999)—Source IP address.
·          Advanced ACL (3000 to 3999)—Source IP address and destination IP address.
·          Ethernet frame header ACL (4000 to 4999)—Source MAC address.
If an applied ACL does not exist or does not have any rules, no user login restriction is applied. If the ACL exists and has rules, only users permitted by the ACL can access the device through Telnet or SSH.
To control Telnet logins:
Step
Remarks
N/A
2.       Apply an ACL to filter Telnet logins.
·         telnet server acl [ mac ] acl-number
·         telnet server ipv6 acl { ipv6 | mac } acl-number
By default, no ACL is used to filter Telnet logins.
3.       (Optional.) Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
telnet server acl-deny-log enable
By default, logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
To control SSH logins:
Step
Remarks
N/A
2.       Apply an ACL to filter SSH logins.
·         ssh server acl [ mac ] acl-number
·         ssh server ipv6 acl { ipv6 | mac } acl-number
By default, no ACL is used to filter SSH logins.
For more information about these two commands, see Security Command Reference.
3.       (Optional.) Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for SSH login attempts that are denied by the SSH login control ACL.
As shown in Figure 8, the device is a Telnet server.
Configure the device to permit only Telnet packets sourced from Host A and Host B.
Figure 8 Network diagram
# Configure an ACL to permit packets sourced from Host A and Host B.
[Sysname] acl basic 2000 match-order config
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
Use a basic ACL (2000 to 2999) to filter HTTP and HTTPS traffic by source IP address. Only Web users whose IP addresses are permitted by the ACL can access the device. If the ACL does not exist or does not have any rules, no user login restriction is applied.
You can also log off suspicious Web users.
Web login requests contain usernames and passwords. For security purposes, the device always uses HTTPS to transfer Web login requests. Only users that are permitted by the following ACLs can access the device through HTTP:
·          ACL applied to the HTTPS service.
·          ACL applied to the HTTP service.
To configure source IP-based Web login control:
Step
Remarks
N/A
2.       Apply a basic ACL for Web access control.
·         ip http acl { acl-number | name acl-name }
·         ip https acl { acl-number | name acl-name }
By default, no ACL is applied to the HTTP or HTTPS service.
To log off online Web users, execute the following command in user view:
free web-users { all | user-id user-id | user-name user-name }
As shown in Figure 9, the device is an HTTP server.
Configure the device to provide HTTP service only to Host B.
Figure 9 Network diagram
# Create an ACL and configure rule 1 to permit packets sourced from Host B.
[Sysname] acl basic 2030 match-order config
[Sysname-acl-ipv4-basic-2030] rule 1 permit source 10.110.100.52 0
# Apply the ACL to the HTTP service so only a Web user on Host B can access the device.
[Sysname] ip http acl 2030
Use a basic ACL (2000 to 2999) to control SNMP access by source IP address. To access the requested MIB view, an NMS must use a source IP address permitted by the ACL. If the ACL does not exist or does not have any rules, no user login restriction is applied.
To control SNMPv1 or SNMPv2c access:
Step
Remarks
N/A
2.       Configure the SNMP access right.
·         (Method 1.) Create an SNMP community and specify ACLs for the community:
¡  In VACM mode:
snmp-agent community { read | write } [ simple | cipher ] community-name [ mib-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
¡  In RBAC mode:
snmp-agent community [ simple | cipher ] community-name user-role role-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·         (Method 2.) Create an SNMPv1/v2c group and add a user to the group, specifying ACLs for the group and user:
a.    snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
b.    snmp-agent usm-user { v1 | v2c } user-name group-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
To control SNMPv3 access:
Step
Remarks
N/A
2.       Create an SNMPv3 group, specifying ACLs for the group.
In non-FIPS mode:
snmp-agent
group v3 group-name [ authentication | privacy ] [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
In FIPS mode:
snmp-agent
group v3 group-name { authentication | privacy } [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
N/A
3.       Create an SNMPv3 user, specifying ACLs for the user.
In non-FIPS mode:
·         In VACM mode:
snmp-agent
usm-user v3 user-name group-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·         In RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
In FIPS mode:
·         In VACM mode:
snmp-agent
usm-user v3 user-name group-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·         In RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
As shown in Figure 10, the device is running SNMP.
Configure the device to allow Host A and Host B to access the device through SNMP.
Figure 10 Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
# Associate the ACL with the SNMP community and the SNMP group.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands.
After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
The command authorization method can be different from the user login authorization method.
This section provides the procedure for configuring command authorization. To make the command authorization feature take effect, you must configure a command authorization method in ISP domain view. For more information, see Security Configuration Guide.
To configure command authorization:
Step
Remarks
N/A
2.       Enter user line view or user line class view.
·         Enter user line view:
line { first-number1 [ last-number1 ] | { aux | console | vty } first-number2 [ last-number2 ] }
·         Enter user line class view:
line class { aux | console | vty }
In non-FIPS mode, authentication is disabled for console lines and password authentication is enabled for AUX and VTY lines by default.
4.       Enable command authorization.
By default, command authorization is disabled, and the commands available for a user only depend on the user role.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
As shown in Figure 11, Host A needs to log in to the device to manage the device.
Configure the device to perform the following operations:
·          Allow Host A to Telnet in after authentication.
·          Use the HWTACACS server to control the commands that the user can execute.
·          If the HWTACACS server is not available, use local authorization.
Figure 11 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other. Make sure the device and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
[Device] telnet server enable
# Enable scheme authentication for user lines VTY 0 through VTY 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
# Enable command authorization for the user lines.
[Device-line-vty0-63] command authorization
[Device-line-vty0-63] quit
# Create HWTACACS scheme tac.
[Device] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[Device-hwtacacs-tac] primary authentication 192.168.2.20 49
[Device-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[Device-hwtacacs-tac] key authentication simple expert
[Device-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Device-hwtacacs-tac] user-name-format without-domain
[Device-hwtacacs-tac] quit
# Configure the system-defined domain (system).
[Device] domain system
# Use HWTACACS scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[Device-isp-system] authentication login hwtacacs-scheme tac local
[Device-isp-system] authorization command hwtacacs-scheme tac local
[Device-isp-system] quit
# Create local user monitor. Set the simple password to 123, the service type to Telnet, and the default user role to level-1.
[Device] local-user monitor
[Device-luser-manage-monitor] password simple 123
[Device-luser-manage-monitor] service-type telnet
[Device-luser-manage-monitor] authorization-attribute user-role level-1
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
This section provides only the procedure for configuring command accounting. To make the command accounting feature take effect, you must configure a command accounting method in ISP domain view. For more information, see Security Configuration Guide.
To configure command accounting:
Step
Remarks
N/A
4.       Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
As shown in Figure 12, users need to log in to the device to manage the device.
Configure the device to send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 12 Network diagram
# Enable command accounting for user line AUX 0.
[Device] line aux 0
[Device-line-aux0] command accounting
[Device-line-aux0] quit
# Enable command accounting for user lines VTY 0 through VTY 63.
[Device-line-vty0-63] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[Device-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[Device-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain (system) to use the HWTACACS scheme for command accounting.
[Device-isp-system] accounting command hwtacacs-scheme tac
