06 Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release757X-6W10006 Layer 3 - IP Routing Command Reference
01-Basic IP routing commands
01-Basic IP routing commands 201.56 KB
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table
Use display ip routing-table to display routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table [ all-routes ]
all-vpn-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
all-routes: Displays routing table information for the public network and all VPN instances.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
If you do not specify any parameters, the command displays routing table information for the public network.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Destinations : 12        Routes : 12
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
192.168.1.0/24      Direct 0    0            192.168.1.40    Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.40    Vlan11
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.40    Vlan11
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Display brief information about active routes in the routing table for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes
VPN instance: public instance
Destinations : 10        Routes : 10
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan11
VPN instance: vpn1
1.1.2.0/24          Static 60   0            2.2.1.1         Vlan11
3.3.1.0/24          BGP    255  0            55.1.1.2        Vlan12
# Display information about IPv4 routes for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
VPN instance: vpn2
Destinations : 9        Routes : 9
1.1.3.0/24          Static 60   0            3.3.1.1         Vlan13
VPN instance
Public network or VPN instance that the routing table belongs to. For the public network, this field displays public instance. For a VPN instance, this field displays the VPN instance name.
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that installed the route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
Summary count
Number of routes.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destinations : 2        Routes : 2
Destination: 0.0.0.0/32
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h34m37s
       Cost: 0               Preference: 0
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active NoAdv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x10000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1000c        OrigNextHop: 127.0.0.1
      Label: NULL           RealNextHop: 127.0.0.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: InLoopBack0
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
Destination: 1.1.1.0/24
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
      NibID: 0x10000003          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 192.168.47.4
      Label: NULL           RealNextHop: 192.168.47.4
  Tunnel ID: Invalid          Interface: Vlan-interface11
# Display detailed information about all routes in the routing table for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
   Protocol: Direct
 Process ID: 0
  OrigTblID: 0x0                OrigVrf: vpn1
VPN instance: vpn2
   Protocol: Static
 Process ID: 0
  OrigTblID: 0x0                OrigVrf: vpn2
VPN instance
Destinations
Routes
Number of routes.
Destination
Protocol
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Route tag.
Route status:
·         Active—Active unicast route.
·         Adv—Route that can be advertised.
·         Inactive—Inactive route.
·         NoAdv—Route that the router must not advertise.
·         Vrrp—Routes generated by VRRP.
·         Nat—Routes generated by NAT.
·         TunE—Tunnel.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN instance that the route belongs to. This field displays default-vrf if the route is on the IPv4 public network.
TableID
ID of the routing table.
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
Tunnel ID
Tunnel ID.
BkTunnel ID
Backup tunnel ID.
BkInterface
Backup output interface.
FtnIndex
Index of the FTN entry.
TrafficIndex
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid.
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported.
Summary count
Number of routes.
PathID
Add-Path ID of the BGP route.
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing information for the public network.
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.111   Vlan11
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   Vlan11
For command output, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 04h20m37s
      Flags: 0x10080        OrigNextHop: 192.168.1.111
      Label: NULL           RealNextHop: 192.168.1.111
Destination: 192.168.1.0/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 192.168.1.111
Destination: 192.168.1.111/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x10004        OrigNextHop: 127.0.0.1
Destination: 192.168.1.255/32
   Protocol: Direct
 Process ID: 0
For command output, see Table 2.
display ip routing-table ip-address
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entry with the longest mask.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
·          display ip routing-table ip-address
¡  The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡  The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
·          display ip routing-table ip-address mask
¡  The system ANDs the entered destination IP address with the entered subnet mask.
¡  The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
·          display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest mask length is displayed.
·          display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask not greater than the entered subnet mask, the entry with the longest mask length is displayed.
·          display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the most specific route to the destination address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 1
# Display brief information about the most specific route to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
   Protocol: O_INTRA
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m37s
       Cost: 0               Preference: 255
    TableID: 0x2                 OrigAs: 200
      NibID: 0x15000000          LastAs: 200
     AttrID: 0x0               Neighbor: 192.168.47.2
      Flags: 0x10060        OrigNextHop: 192.168.47.2
      Label: NULL           RealNextHop: 192.168.47.2
display ip routing-table prefix-list
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         Vlan11
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 1.1.1.2
      Label: NULL           RealNextHop: 1.1.1.2
display ip routing-table protocol
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing Table Status : <Active>
Summary count : 9
2.2.2.0/32          Direct 0    0            2.2.2.1         Vlan2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.255/32        Direct 0    0            2.2.2.1         Vlan2
Direct Routing Table Status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing Table Status : <Active>
Summary count : 0
Static Routing Table Status : <Inactive>
Summary count : 1
1.2.3.0/24          Static 60   0            1.2.4.5        Vlan10
# Display detailed information about OSPF routes.
<Sysname> display ip routing-table protocol ospf verbose
Summary count : 1
Destination: 1.1.1.2/32
   Protocol: O_INTRA
 Process ID: 0
  SubProtID: 0x6                    Age: 00h03m54s
      NibID: 0x16000000          LastAs: 200
display ip routing-table statistics
Use display ip routing-table statistics to display IPv4 route statistics, including numbers of total routes, routes installed by the protocol, routes marked as deleted, and active routes.
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
all-routes: Displays IPv4 route statistics for the public network and all VPN instances.
If you do not specify any parameters, the command displays IPv4 route statistics for the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
# Display IPv4 route statistics for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
Proto
Routes
Number of routes installed by the protocol.
Active
Number of active routes.
Added
Number of routes added to the routing table after the router started up or the routing table was cleared most recently.
Deleted
Number of routes marked as deleted, which will be cleared after a period.
Total
Total number of routes.
display ip routing-table summary
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ip routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief routing table information for the public network.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value of active routes alert: 65100
Max ECMP
Maximum number of ECMP routes supported by the system.
Max Active Route
Maximum number of supported routes.
Remain Active Route
Number of the remaining inactive routes.
Alarm threshold of active routes specified by using the routing-table limit command in a VPN instance:
·         Threshold value of active routes alert—This field is displayed when the alarm threshold is specified by using the routing-table limit number simply-alert command. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes.
·         Threshold value percentage of max active routes—This field is displayed when the alarm threshold is specified by using the routing-table limit number warn-threshold command, in the range of 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance, and multiplied by 100.
display ipv6 rib attribute
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
attribute-id: Specifies a route attribute by its ID, a hexadecimal string in the range of 0 to ffffffff.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
For command output, see Table 9.
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT     480      29   End      No/No
 2    STATIC     480      32   End      No/No
 3    ISISV6     480      30   End      No/No
For command output, see Table 10.
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 0 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
   TopoNthp: Invalid
      NibID: 0x20000001        Sequence: 1
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
   TopoNthp: Invalid
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
   TopoNthp: Invalid
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0
   TopoNthp: Invalid
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
     Weight: 0
      NibID: 0x26000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 121::2
   TopoNthp: Invalid
   Instance: default
      NibID: 0x26000002        Sequence: 1
   UserKey1: 0x0                Nexthop: 122::2
   TopoNthp: Invalid
   Instance: abc
For command output, see Table 11 and Table 12.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
   TopoNthp: Invalid
   TopoNthp: Invalid
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
 1 nexthop(s):
     Weight: 0
 1 nexthop(s):
     Weight: 0
For command output, see Table 13 and Table 14.
display ipv6 routing-table
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table [ all-routes ]
all-routes: Displays IPv6 routing table information for the ‌public network and all VPN instances.
If you do not specify any parameters, the command displays IPv6 routing table information for the public network.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
# Display brief information about active routes in the IPv6 routing table for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128                                Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
# Display IPv6 routing table information for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Table 5 Command output
VPN instance
Public network or VPN instance that the IPv6 routing table belongs to. For the public network, this field displays public instance. For a VPN instance, this field displays the VPN instance name.
Destinations
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Preference
Protocol
Cost
Cost of the route.
Summary count
Number of routes.
# Display detailed information about all routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table verbose
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h23m02s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x20000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10004        OrigNextHop: ::1
      Label: NULL           RealNextHop: ::1
Destination: 12::/96
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m47s
      NibID: 0x20000003          LastAs: 0
      Flags: 0x10080        OrigNextHop: ::
# Display detailed information about all routes in the IPv6 routing table for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
   Protocol: Direct
 Process ID: 0
Destination: 12::1/128
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m45s
Table 6 Command output
VPN instance
Destination
Protocol
SubProtID
Age
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route status:
·         TunE—Tunnel.
OrigTblID
OrigVrf
Original VPN instance that the route belongs to. This field displays default-vrf if the route is on an IPv6 network.
TableID
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Flags
Flags of the route.
OrigNextHop
RealNextHop
BkLabel
Backup label.
BkNexthop
Backup next hop.
Tunnel ID
Tunnel ID.
BkTunnel ID
Backup tunnel ID.
BkInterface
FtnIndex
TrafficIndex
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported.
Summary count
Number of routes.
PathID
display ipv6 routing-table acl
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : Vlan11                                      Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: 11::1/128                                   Protocol  : O_INTER
NextHop    : FE80::A1F:3FFF:FE45:206                     Preference: 10
Interface  : Vlan11                                      Cost      : 2
Destination: FF00::/8                                    Protocol  : Direct
For command output, see Table 5.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h29m12s
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m57s
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m55s
   Protocol: O_INTER
 Process ID: 1
  SubProtID: 0x2                    Age: 00h06m43s
       Cost: 2               Preference: 10
      NibID: 0x23000003          LastAs: 0
     AttrID: 0x ffffffff       Neighbor: ::
      Flags: 0x10041        OrigNextHop: FE80::A1F:3FFF:FE45:206
      Label: NULL           RealNextHop: FE80::A1F:3FFF:FE45:206
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000002          LastAs: 0
      Flags: 0x10084        OrigNextHop: ::
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000001          LastAs: 0
      Flags: 0x10014        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: NULL0
For command output, see Table 6.
display ipv6 routing-table ipv6-address
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the route entry with the longest prefix.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
·          display ipv6 routing-table ipv6-address
¡  The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡  The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
·          display ipv6 routing-table ipv6-address prefix-length
¡  The system ANDs the entered destination IPv6 address with the entered prefix length.
¡  The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
·          display ipv6 routing-table ipv6-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest prefix length is displayed.
·          display ipv6 routing-table ipv6-address prefix-length longer-match
If the two operations yield the same result for multiple entries with a prefix length not greater than the entered prefix length, the entry with the longest prefix length is displayed.
·          display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the most specific route to the destination IPv6 address 10::1 and prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
   Protocol: O_INTRA
 Process ID: 1
  SubProtID: 0x1                    Age: 00h01m14s
       Cost: 1               Preference: 10
      NibID: 0x23000002          LastAs: 0
display ipv6 routing-table prefix-list
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h57m19s
display ipv6 routing-table protocol
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Static Routing table Status : <Active>
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
Interface  : Vlan12                                      Cost      : 0
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Static Routing table Status : <Inactive>
Summary count : 0
# Display detailed information about OSPFv3 routes.
<Sysname> display ipv6 routing-table protocol ospfv3 verbose
Summary count : 1
Destination: 22::22/128
   Protocol: O_INTER
 Process ID: 0
  SubProtID: 0x6                    Age: 00h04m15s
    TableID: 0xa                 OrigAs: 200
      NibID: 0x25000001          LastAs: 200
     AttrID: 0x3               Neighbor: 121::2
      Flags: 0x10060        OrigNextHop: 121::2
      Label: NULL           RealNextHop: 121::2
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route statistics, including numbers of total routes, routes installed and deleted by the protocol, and active routes.
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics
all-routes: Displays IPv6 route statistics for the public network and all VPN instances.
If you do not specify any parameters, the command displays IPv6 route statistics for the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
# Display IPv6 route statistics for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      6           6           8           2
# Display IPv6 route statistics for VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
# Display IPv6 route statistics for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
Table 7 Command output
Proto
Routes
Active
Added
Deleted
Total
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief IPv6 routing table information for the public network.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# Display brief IPv6 routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
For command output, see Table 4.
display max-ecmp-num
Use display max-ecmp-num to display the maximum number of IPv4 ECMP routes.
This command is supported only on the default MDC.
# Display the maximum number of IPv4 ECMP routes.
<Sysname> display max-ecmp-num
  Max-ECMP-Num in use: 6
  Max-ECMP-Num at the next reboot: 10
Table 8 Command output
Max-ECMP-Num in use
Maximum number of current IPv4 ECMP routes in use.
Maximum number of IPv4 ECMP routes at the next reboot of the device.
display rib attribute
Use display rib attribute to display route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
              Protocol: BGP instance default
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
Table 9 Command output
Protocol
Protocol that generates the attribute.
Reference count of the attribute by active routes.
Flush flag
Indicates whether the route attribute has been flushed to the FIB.
·         0—The route attribute has not been flushed to the FIB.
·         1—The route attribute has been flushed to the FIB.
Number of the extended community attribute values.
Values of the extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Communities number
Number of the COMMUNITY attribute values.
Communities value
Values of the COMMUNITY attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
AS-path number
Number of ASs in the AS_PATH attribute.
AS-path value
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Length of the SFlow AS-path attribute.
SFlow AS-path value
Values of the SFlow AS-path attribute. This field displays N/A when no values exist, and it can display a maximum of 80 values.
display rib graceful-restart
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     100      30   End      No/No
 2    STATIC     480      34   End      No/No
 3    OSPF       480      36   End      No/No
 4    ISIS       480      32   End      No/No
 5    LDP        480      35   End      No/No
 6    SLSP       480      29   End      No/No
Table 10 Command output
RIB GR state
RIB GR status:
·         Start—GR starts.
·         IGP end—All IGP protocols complete GR.
·         VPN-triggering end—Optimal route selection triggered by VPN routes completes.
·         VPN-calculation end—Optimal VPN route selection completes.
·         Routing protocol end—All routing protocols complete GR.
·         NSR-calculation unfinished—NSR has not finished optimal route selection.
·         Triggering start—All triggered optimal route selection starts.
·         Triggering end—All triggered optimal route selection completes.
·         Phase1-calculation end—Optimal route selection phase 1 completes.
·         All end—All protocols complete GR.
·         Phase2-calculation end—Optimal route selection phase 2 completes.
RCOM GR state
RCOM GR status:
·         Start—GR starts.
·         VPN-notification end—VPN routes have been delivered to the route management module.
·         Notification end—All routes have been delivered to the route management module.
·         Flush start—Starts to flush routes to the FIB.
·         Flush end—Completes flushing routes to the FIB.
No.
Protocol number.
Lifetime
Lifetime (in seconds) of routes/labels in the RIB during GR.
FD
Handle between the protocol and the RIB.
Protocol GR state:
·         Init—Initialization state.
·         Listen—Listening state.
·         Idle.
·         Active.
·         Start—GR starts.
·         End—GR completes.
Start/End
Message sending state:
·         No—The message has not been sent.
·         Yes—The message has been sent.
display rib nib
Use display rib nib to display next hop information in the RIB.
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
   TopoNthp: 0
      NibID: 0x10000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
   TopoNthp: 0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
   TopoNthp: 0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
   TopoNthp: 0
   Instance: abc
Table 11 Command output
NibID
ID of the next hop.
Sequence
Sequence number of the next hop.
Type of the next hop.
Flushed
Indicates whether the route with the next hop has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the IPv4 public network or an IPv6 network.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface address.
TopoNthp
Index of the topology that contains the next hop. This field displays 0 if the next hop is on the IPv4 public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support multiple IPv6 topologies.
Instance
BGP instance name.
SubNibID
ID of the sub-next hop.
SubSeq
Sequence number of the sub-next hop.
NthpCnt
Number of sub-next hops.
Samed
Number of the same sub-next hops.
NthpType
Type of the sub-next hop:
·         IP—IP forwarding.
·         MPLS—MPLS forwarding.
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
   TopoNthp: 0
     RefCnt: 6              FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
     Weight: 0
   TopoNthp: 0
     RefCnt: 11             FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
     Weight: 0
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
   TopoNthp: 0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: Vlan11           LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
     Weight: 0
Table 12 Command output
Policy
Tunnel policy name.
x nexthop (s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For the IPv4 public network or an IPv6 network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
LocalAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
‌This field is not supported in the current software version.
Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support multiple topologies.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
Instance
BGP instance name.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
   TopoNthp: 0
   TopoNthp: 0
Table 13 Command output
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface IP address.
TopoNthp
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
     RefCnt: 2              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
     RefCnt: 5              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
Table 14 Command output
x nexthop(s)
PrefixIndex
Vrf
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
Topology
Weight
RefCnt
FlushRefCnt
Flag
Version
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR or NSR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute
Use flush route-attribute to enable the RIB to flush route attribute information to the FIB.
Use undo flush route-attribute to restore the default.
flush route-attribute protocol
undo flush route-attribute protocol
The RIB does not flush route attribute information to the FIB.
protocol: Specifies a routing protocol. Only BGP is supported in the current software version.
# Enable the RIB to flush route attribute information to the FIB.
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol fast-reroute
Use inter-protocol fast-reroute to enable IPv4 or IPv6 RIB inter-protocol FRR.
Use undo inter-protocol fast-reroute to disable IPv4 or IPv6 RIB inter-protocol FRR.
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
Inter-protocol FRR is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables IPv4 or IPv6 RIB inter-protocol FRR for the public network.
This command allows a device to perform fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
This command uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops.
Inter-protocol FRR cannot select a backup next hop from routes in the RIB that have the same next hop, output interface, and destination as those of the faulty route.
# Enable IPv4 RIB inter-protocol FRR for the public network.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ip route fast-switchover enable
Use ip route fast-switchover enable to enable IPv4 route fast switchover.
Use undo ip route fast-switchover enable to disable IPv4 route fast switchover.
IPv4 route fast switchover is disabled.
This command applies to a device that provides the same physical output interface for large numbers of routes, including ECMP routes and primary/secondary routes. When a link failure occurs on the interface, the device must perform the following tasks before switching the traffic to another route:
1.        Deletes all ARP entries for the link.
2.        Instructs the FIB to delete the associated FIB entries.
This procedure is time consuming and interrupts traffic for a long time. To resolve this problem, you can enable route fast switchover. This feature allows the device to instruct the FIB to delete the invalid FIB entries for route switchover first.
# Enable IPv4 route fast switchover.
[Sysname] ip route fast-switchover enable
ipv6 route fast-switchover enable
Use ipv6 route fast-switchover enable to enable IPv6 route fast switchover.
Use undo ipv6 route fast-switchover enable to disable IPv6 route fast switchover.
IPv6 route fast switchover is disabled.
1.        Deletes all ND entries for the link.
# Enable IPv6 route fast switchover.
[Sysname] ipv6 route fast-switchover enable
max-ecmp-num
Use max-ecmp-num to set the maximum number of IPv4 ECMP routes.
max-ecmp-num number
The maximum number of ECMP routes is not set.
number: Specifies the maximum number of IPv4 ECMP routes. The value range for this argument is 1 to 128.
# Set the maximum number of IPv4 ECMP routes to 10.
[Sysname] max-ecmp-num 10
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
After reboot, the maximum number of IPv4 ECMP routes is 10.
non-stop-routing
Use non-stop-routing to enable RIB NSR.
Use undo non-stop-routing to disable RIB NSR.
non-stop-routing
RIB NSR is disabled.
# Enable NSR for the RIB IPv4 address family.
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
undo protocol protocol [ instance instance-name ] lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 480 seconds.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. This argument applies only to the BGP protocol. If you do not specify a BGP instance, this command sets the maximum lifetime for all BGP routes and labels in the RIB.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for RIP routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
protocol nexthop recursive-lookup
Use protocol nexthop recursive-lookup to configure routing policy-based recursive lookup.
Use undo protocol nexthop recursive-lookup to remove the configuration.
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
Routing policy-based recursive lookup is not configured.
protocol: Specifies a routing protocol, which can be bgp or static in RIB IPv4 address family view or bgp4+ in RIB IPv6 address family view.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Configure routing policy-based recursive lookup to control route recursion results. For example, when a route changes, the routing protocol has to perform a route recursion if the next hop is indirectly connected. The routing protocol might select an incorrect path, which can cause traffic loss. To prevent this problem, you can use a routing policy to filter out incorrect routes. The routes that pass the filtering of the routing policy will be used for route recursion.
The apply clauses in the specified routing policy cannot take effect.
Make sure a minimum of one related route can match the routing policy for correct traffic forwarding.
# Configure recursive lookup based on routing policy policy1 for static routes.
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
all-routes: Clears route statistics for the public network and all VPN instances.
all-vpn-instance: Clears route statistics for all VPN instances.
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears IPv4 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
This command clears IPv6 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
routing-table limit
Use routing-table limit to set the maximum number of active IPv4/IPv6 routes supported by the device.
Use undo routing-table limit to restore the default.
The maximum number of active IPv4/IPv6 routes is not set for the device.
number: Specifies the maximum number of active IPv4/IPv6 routes supported by the device, in the range of 1 to 4294967295.
simply-alert: Enables the device to still accept active routes but generate a log message when the number of active IPv4/IPv6 routes exceeds the maximum number.
Configuration in RIB IPv4 address family view limits the number of active IPv4 routes for the public network and all VPN instances.
Configuration in RIB IPv6 address family view limits the number of active IPv6 routes for the public network and all VPN instances.
# In RIB IPv4 address family view, set the maximum number of active IPv4 routes to 1000 for the public network and all VPN instances. The device still accepts new active routes but generates a system log message when the maximum number of active routes is exceeded.
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
