05-ACL and QoS Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10205-ACL and QoS Configuration Guide
02-QoS Configuration
02-QoS Configuration 560.53 KB
QoS overview·· 1
Introduction to QoS· 1
QoS service models 1
Best-effort service model 1
IntServ model 2
DiffServ model 2
QoS techniques overview·· 2
Applying QoS techniques in a network· 2
QoS configuration approaches· 4
QoS configuration approach overview·· 4
Non-policy approach· 4
Policy approach· 4
Configuring a QoS policy· 4
Defining a class 5
Defining a traffic behavior 6
Defining a policy· 6
Applying the QoS policy· 6
Displaying and maintaining QoS policies 8
Priority mapping configuration· 10
Priority mapping overview·· 10
Introduction to priority mapping· 10
Introduction to priorities 10
Priority mapping tables 11
Priority mapping configuration tasks 11
Configuring priority mapping· 11
Configuring a priority mapping table· 11
Configuring a port to trust packet priority for priority mapping· 12
Changing the port priority of an interface· 12
Configuring primap· 13
Displaying and maintaining priority mapping· 13
Priority mapping configuration examples 14
Priority mapping table configuration example· 14
Primap configuration example· 16
Priority mapping table and priority marking configuration example· 17
Line rate configuration· 21
Line rate overview·· 21
Configuring the line rate· 22
Displaying and maintaining line rate· 23
Line rate configuration example· 23
Congestion management configuration· 24
Congestion management overview·· 24
Causes, impacts, and countermeasures 24
Congestion management techniques 25
Congestion management configuration approaches 27
Congestion management 27
Configuring SP queuing· 27
Configure WRR queuing· 28
Configuring SP+WRR queuing· 29
Traffic filtering configuration· 31
Traffic filtering overview·· 31
Configuring traffic filtering· 31
Traffic filtering configuration example· 32
Priority marking configuration· 34
Priority marking overview·· 34
Configuring priority marking· 34
Priority marking configuration example· 35
Traffic redirecting configuration· 38
Traffic redirecting overview·· 38
Configuring traffic redirecting· 38
Burst configuration· 40
Burst overview·· 40
Configuring burst 40
Burst configuration example· 41
Network requirements 41
Configuration procedure· 41
Appendix· 42
Appendix A Default priority mapping tables 42
Uncolored priority mapping tables 42
Appendix B Introduction to packet precedences 43
IP precedence and DSCP values 43
802.1p priority· 44
This chapter includes these sections:
·          QoS overview
·          QoS service models
·          QoS techniques overview
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wired-wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wired-wireless switches.
·      The port numbers in this chapter are for illustration only.
Introduction to QoS
In data communications, Quality of Service (QoS) is the ability of a network to provide differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate.
Network resources are scarce. The contention for resources requires that QoS prioritize important traffic flows over trivial ones. For example, in the case of fixed bandwidth, if a traffic flow gets more bandwidth, the other traffic flows will get less bandwidth and may be affected. When making a QoS scheme, you must consider the characteristics of various applications to balance the interests of diversified users and to utilize network resources.
The following section describes some typical QoS service models and widely used, mature QoS techniques.
QoS service models
This section covers three typical QoS service models:
·          Best-effort service model
·          IntServ model
·          DiffServ model
Best effort is a single-service model and also the simplest service model. In the best-effort service model, the network does its best to deliver packets, but does not guarantee delay or reliability.
The best-effort service model is the default model in the Internet and applies to most network applications. It uses the first in first out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. It provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the Resource Reservation Protocol (RSVP). All nodes receiving the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. The model is suitable for small-sized or edge networks, but not large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can satisfy diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
All QoS techniques in this document are based on the DiffServ model.
The QoS techniques include traffic classification, traffic policing, traffic shaping, line rate, congestion management, and congestion avoidance. The following sections briefly introduce these QoS techniques.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
·          Traffic classification uses certain match criteria to assign packets with the same characteristics to a class. Based on classes, you can provide differentiated services.
·          Traffic policing polices flows entering or leaving a device, and imposes penalties on traffic flows that exceed the pre-set threshold to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
·          Traffic shaping proactively adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
·          Congestion management provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
·          Congestion avoidance monitors the network resource usage, and is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
·          QoS configuration approach overview
·          Configuring a QoS policy
The following approaches are available for configuring QoS: Non-policy approach and Policy approach.
Some features support both approaches, but some support only one.
Non-policy approach
In non-policy approach, you can configure QoS service parameters without using a QoS policy. For example, you can use the line rate feature to set a rate limit on an interface without using a QoS policy.
Policy approach
In policy approach, you configure QoS service parameters by using QoS policies. A QoS policy defines the shaping, policing, or other QoS actions to take on different classes of traffic. It is a set of class-behavior associations.
A class is a set of match criteria for identifying traffic, and it uses the AND or OR operator:
·          If the operator is AND, a packet must match all the criteria to match the class.
·          If the operator is OR, a packet matches the class if it matches any of the criteria in the class.
A traffic behavior defines a set of QoS actions to take on packets, such as priority marking and redirect.
By associating a traffic behavior with a class in a QoS policy, you apply the specific set of QoS actions to the class of traffic.
Figure 2 shows how to configure a QoS policy.
Figure 2 QoS policy configuration procedure
Defining a class
To define a class, specify its name and then configure the match criteria in class view.
Follow these steps to define a class:
To do…
Use the command…
Remarks
Enter system view
Create a class and enter class view
traffic classifier tcl-name [ operator { and | or } ]
Required
By default, the operator of a class is AND.
The operator of a class can be AND or OR.
·      AND: A packet is assigned to a class only when the packet matches all the criteria in the class.
·      OR: A packet is assigned to a class if it matches any of the criteria in the class.
Configure match criteria
if-match match-criteria
Required
Repeat this step to configure multiple match criteria for the class.
For more information, see the if-match command in the ACL and QoS Command Reference.
A traffic behavior is a set of QoS actions (such as traffic filtering, shaping, policing, and priority marking) to take on a class of traffic. To define a traffic behavior, first create it and then configure QoS actions, such as priority marking and traffic redirecting, in traffic behavior view.
Follow these steps to define a traffic behavior:
To do…
Use the command…
Remarks
Enter system view
Create a traffic behavior and enter traffic behavior view
Required
Configure actions in the traffic behavior
See the subsequent chapters, depending on the purpose of the traffic behavior: traffic policing, traffic filtering, traffic redirecting, priority marking, traffic accounting, and so on.
Defining a policy
You associate a behavior with a class in a QoS policy to perform the actions defined in the behavior for the class of packets.
You cannot name a user-defined QoS policy the same as the system-defined QoS policy.
Follow these steps to associate a class with a behavior in a policy:
To do…
Use the command…
Remarks
Enter system view
Create a policy and enter policy view
qos policy policy-name
Required
Associate a class with a behavior in the policy
classifier tcl-name behavior behavior-name
Required
·      If an ACL is referenced by a QoS policy for defining traffic match criteria, packets matching the ACL are organized as a class and the behavior defined in the QoS policy applies to the class regardless of whether the match mode of the if-match clause is deny or permit.
·      In a QoS policy with multiple class-to-traffic-behavior associations, if the action of creating an outer VLAN tag is configured in a traffic behavior, do not configure any other action in this traffic behavior; otherwise, the QoS policy may not function as expected after it is applied.
You can apply a QoS policy to the following occasions:
·          An interface—The policy takes effect on the traffic sent or received on the interface.
·          A user profile—The policy takes effect on the traffic sent or received by the online users of the user profile.
·          A VLAN—The policy takes effect on the traffic sent or received on all ports in the VLAN.
·          Globally—The policy takes effect on the traffic sent or received on all ports.
You can modify classes, behaviors, and class-behavior associations in a QoS policy even after it is applied. If a class references an ACL for traffic classification, you can delete or modify the ACL (such as add rules to, delete rules from, and modify rules of the ACL).
Applying the QoS policy to an interface
A policy can be applied to multiple interfaces, but only one policy can be applied in one direction (inbound or outbound) of an interface.
Follow these steps to apply the QoS policy to an interface:
To do…
Use the command…
Remarks
Enter system view
Enter interface view or port group vie,
Use either command.
Settings in interface view take effect on the current interface. Settings in port group view take effect on all ports in the port group
Enter port group view
port-group manual port-group-name
Apply the policy to the interface or port group
qos apply policy policy-name  inbound
Required
The QoS policy applied to the outgoing traffic on an interface does not regulate local packets, which are critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, routing (IS-IS, BGP, and OSPF for example), RIP, LDP, RSVP, and SSH packets.
Applying the QoS policy to online users
A QoS policy can be applied to multiple online users. In one direction of each online user, only one policy can be applied. To modify a QoS policy already applied in a certain direction, remove the QoS policy application first.
Follow these steps to apply the QoS policy to online users:
To do…
Use the command…
Remarks
Enter system view
Enter user profile view
user-profile profile-name
Required
The configuration made in user profile view takes effect when the user-profile is activated and the users of the user profile are online.
For more information about user profiles, see the Security Configuration Guide.
Apply the QoS policy
Required
Use the inbound keyword to apply the QoS policy to the incoming traffic of the device (traffic sent by the online users).
Return to system view
Activate the user profile
user-profile profile-name enable
Required
Inactive by default.
·      You cannot modify or remove the QoS policy used by an active user profile. However, you can edit any ACL referenced by the QoS policy when the user profile has no online users.
·      The QoS policy applied to a user profile supports only the remark, and filter actions.
·      Do not apply a null policy to a user profile. The user profile using a null policy cannot be activated.
·      The authentication methods available for online users include 802.1X.
Applying the QoS policy to a VLAN
You can apply a QoS policy to a VLAN to regulate traffic of the VLAN.
Follow these steps to apply the QoS policy to a VLAN:
To do…
Use the command…
Remarks
Enter system view
Apply the QoS policy to VLANs
qos vlan-policy policy-name vlan vlan-id-list{ inbound
Required
QoS policies cannot be applied to dynamic VLANs, for example, VLANs created by GVRP.
Applying the QoS policy globally
You can apply a QoS policy globally to the inbound or outbound direction of all ports.
Follow these steps to apply the QoS policy globally:
To do…
Use the command…
Remarks
Enter system view
Apply the QoS policy globally
qos apply policy policy-name global  inbound
Required
To do…
Use the command…
Remarks
Display traffic class configuration
display traffic classifier  user-defined [ tcl-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display traffic behavior configuration
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
Display user-defined QoS policy configuration
display qos policy user-defined [ policy-name [ classifier tcl-name ] ] [ | { begin | exclude | include } regular-expression ]
Display QoS policy configuration on the specified or all interfaces
display qos policy interface [ interface-type interface-number ] [ inbound ] [ | { begin | exclude | include } regular-expression ]
Display VLAN QoS policy configuration
display qos vlan-policy { name policy-name | vlan vlan-id } [ slot slot-number ] [ inbound ] [ | { begin | exclude | include } regular-expression ]
Display information about QoS policies applied globally
display qos policy global [ slot slot-number ] [ inbound ] [ | { begin | exclude | include } regular-expression ]
Clear VLAN QoS policy statistics
reset qos vlan-policy [ vlan vlan-id ] [ inbound ]
Available in user view
Clear the statistics for a QoS policy applied globally
reset qos policy global [ inbound ]
·          Priority mapping overview
·          Priority mapping configuration tasks
·          Configuring priority mapping
·          Displaying and maintaining priority mapping
·          Priority mapping configuration examples
·      For information about packet precedences, Appendix B Introduction to packet precedences.
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on a certain priority field carried in the packet or the port priority of the incoming port, depending on your configuration. This process is called “priority mapping”. During this process, the device may modify the priority of the packet depending on device status. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority mapping tables and involves priorities such as 802.11e priority, 802.1p priority, DSCP, EXP, IP precedence, local precedence, and drop precedence.
Priorities fall into the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
The packet carried priorities include 802.1p priority, DSCP precedence, IP precedence, EXP, and so on. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see the chapter “Appendix.”
The locally assigned priorities have only local significance. They are assigned by the device for scheduling only. These priorities include the local precedence, drop precedence, and user precedence, as follows.
·          Local precedence is used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
·          Drop precedence is used for making packet drop decisions. Packets with the highest drop precedence are dropped preferentially.
·          User precedence is the precedence that the device automatically extracts from a certain priority field of the packet according to its forwarding path. The user precedence represents the 802.1p precedence for Layer-2 packets and the IP precedence for Layer-3 packets.
The device provides various types of priority mapping tables, or rather, priority mappings. By looking up a priority mapping table, the device decides which priority value is to assign to a packet for subsequent packet processing.
The default priority mapping tables (as shown in Appendix A Default priority mapping tables) are available for priority mapping. They are adequate in most cases. If a default priority mapping table cannot meet your requirements, you can modify the priority mapping table as required.
You can configure priority mapping in any of the following approaches:
·          Configuring priority mapping tables.
·          Configuring priority trust mode. In this approach, you can configure a port to look up a certain priority, 802.1p for example, in incoming packets, in the priority mapping tables. If no packet priority is trusted, the port priority of the incoming port is used.
·          Changing port priority. By default, all ports are assigned the port priority of zero. By changing the port priority of a port, you change the priority of the incoming packets on the port.
·          Configuring a QoS policy containing the priority mapping (simply called “primap”) action with the primap command.
Perform these tasks to configure priority mapping:
Remarks
Optional
Optional
Optional
Configuring primap
Optional
The device provides the following types of uncolored priority mapping table.
·          dot1p-dot1p: 802.1p-to-802.1p mapping table.
·          dot1p-dscp: 802.1p-to-DSCP mapping table.
·          dot1p-lp: 802.1p-to-local mapping table.
·          dscp-dot1p: DSCP-to-802.1p mapping table, which applies to only IP packets.
·          dscp-dscp: DSCP-to-DSCP mapping table, which applies to only IP packets.
·          dscp-lp: DSCP-to-local mapping table, which applies to only IP packets.
Follow these steps to configure an uncolored priority mapping table:
To do
Use the command
Remarks
Enter system view
Enter priority mapping table view
qos map-table  { dot1p-dot1p | dot1p-dscp | dot1p-lp | dscp-dot1p | dscp-dscp | dscp-lp | }
Required
Configure the priority mapping table
Required
Newly configured mappings overwrite the old ones.
When configuring the trusted packet priority type on an interface or port group, use the following available keywords:
·          dot1p: Uses the 802.1p priority of received packets for priority mapping.
·          dscp: Uses the DSCP precedence of received IP packets for priority mapping.
·          untrust: Uses the port priority for priority mapping.
Follow these steps to configure the trusted packet priority type on an interface or port group:
To do…
Use the command…
Remarks
Enter system view
Enter interface view or port group view
Use either command.
Settings in interface view take effect on the current interface. Settings in port group view take effect on all ports in the port group.
Configure the trusted packet priority type for the interface
qos trust { dot1p | dscp  }
Required
Follow these steps to change the port priority of an interface:
To do
Use the command
Remarks
Enter system view
Use either command.
Set the port priority of the interface
qos priority priority-value
Required
The default is 0
Configuring primap
By configuring a primap behavior and associating it with a traffic class, you can re-assign priority parameters for the traffic class according to the specified priority mapping table.
Configuring uncolored primap
Follow these steps to configure primap:
To do…
Use the command…
Remarks
Enter system view
If-match match-criteria
Configure the action of assigning priority values to packets using a specified priority mapping table
primap pre-defined { dscp-dot1p | dscp-dp | dscp-dscp | dscp-lp }
Required
Associate the traffic behavior with the class
To an interface
To online users
To a VLAN
Globally
To do…
Use the command…
Remarks
Display priority mapping table configuration
display qos map-table  [dot1p-dot1p | dot1p-dscp | dot1p-lp | dscp-dot1p | dscp-dscp | dscp-lp ] [ | { begin | exclude | include } regular-expression ]
Display the trusted packet priority type on a port
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
As shown in Figure 5, the enterprise network of a company interconnects all departments through Device. The network is described as follows:
·          The marketing department connects to GigabitEthernet 1/0/1 of Device, which sets the 802.1p priority of traffic from the marketing department to 3.
·          The R&D department connects to GigabitEthernet 1/0/2 of Device, which sets the 802.1p priority of traffic from the R&D department to 4.
·          The management department connects to GigabitEthernet 1/0/3 of Device, which sets the 802.1p priority of traffic from the management department to 5.
Configure port priority and 802.1p-to-local mapping table to implement the plan as described in Table 1.
Table 1 Configuration plan
Traffic destination
Traffic priority order
Queuing plan
Traffic source
Output queue
Queue priority
Public servers
R&D department > management department > marketing department
R&D department
6
High
Management department
4
Medium
Marketing department
2
Low
Figure 3 Network diagram for priority mapping configuration
1.        Configure trust port priority
# Set the port priority of GigabitEthernet 1/0/1 to 3.
[Device-GigabitEthernet1/0/1] qos priority 3
# Set the port priority of GigabitEthernet 1/0/2 to 4.
[Device-GigabitEthernet1/0/2] qos priority 4
# Set the port priority of GigabitEthernet 1/0/3 to 5.
 [Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] qos priority 5
[Device-GigabitEthernet1/0/3] quit
2.        Configure the priority mapping table
# Configure the 802.1p-to-local mapping table to map 802.1p priority values 3, 4, and 5 to local precedence values 2, 6, and 4. This guarantees the R&D department, management department, and marketing department decreased priorities to access the public server.
[Device-maptbl-dot1p-lp] quit
As shown in Figure 4, Device A is connected through its GigabitEthernet 1/0/1 port to Device C. The DSCP value of traffic sent out the port is 11. Device B is connected through its GigabitEthernet 1/0/2 port to Device C. The DSCP value of traffic sent out the port is 13.
Configure priority mapping to satisfy requirements 1 as follows:
·          Mark packets from Device A with DSCP 50 and packets from Device B with DSCP 30.
·          When Ethernet 1/3 of Device C is congested, Device C schedules the packets according to their priority prior to priority mapping, and allows Device B to preferentially access Server.
Configure priority mapping to satisfy requirements 2 as follows:
·          When GigabitEthernet 1/0/3 of Device C is congested, Device C schedules the packets according to their priority after priority mapping, and allows Device A to preferentially access Server.
Figure 4 Network diagram for primap configuration
1.        Configurations for requirements 1
# Configure the DSCP-to-DSCP mapping table.
<DeviceC> system-view
[DeviceC] qos map-table dscp-dscp
[DeviceC-maptbl-dscp-dscp] import 11 export 50
[DeviceC-maptbl-dscp-dscp] import 13 export 30
[DeviceC-maptbl-dscp-dscp] quit
# Create basic ACL 2001, and configure a rule to match packets with source IP address 192.168.0.1.
 [DeviceC] acl number 2001
[DeviceC-acl-basic-2001] rule permit source 192.168.0.1 0
[DeviceC-acl-basic-2001] quit
# Create basic ACL 2002, and configure a rule to match packets with source IP address 192.168.0.2.
 [DeviceC] acl number 2002
[DeviceC-acl-basic-2002] rule permit source 192.168.0.2 0
[DeviceC-acl-basic-2002] quit
# Create a class named classifier_devicea, and use basic ACL 2001 as the match criterion in the class.
 [DeviceC] traffic classifier classifier_devicea
[DeviceC-classifier-classifier_devicea] if-match acl 2001
[DeviceC-classifier-classifier_devicea] quit
# Create a class named classifier_deviceb, and use basic ACL 2002 as the match criterion in the class.
 [DeviceC] traffic classifier classifier_deviceb
[DeviceC-classifier-classifier_deviceb] if-match acl 2002
[DeviceC-classifier-classifier_deviceb] quit
# Create a behavior named behavior_devicea, and configure the primap action.
 [DeviceC] traffic behavior behavior_devicea
[DeviceC-behavior-behavior_devicea] primap pre-defined dscp-dscp
[DeviceC-behavior-behavior_devicea] quit
# Create a behavior named behavior_deviceb, and configure the primap action.
 [DeviceC] traffic behavior behavior_deviceb
[DeviceC-behavior-behavior_deviceb] primap pre-defined dscp-dscp
[DeviceC-behavior-behavior_deviceb] quit
# Create a policy named policy_server1, and associate the classes with the behaviors in the policy.
 [DeviceC] qos policy policy_server1
[DeviceC-qospolicy-policy_server1] classifier classifier_devicea behavior behavior_devicea
[DeviceC-qospolicy-policy_server1] quit
# Create a policy named policy_server2, and associate the classes with the behaviors in the policy.
 [DeviceC] qos policy policy_server2
[DeviceC-qospolicy-policy_server2] classifier classifier_deviceb behavior behavior_deviceb
[DeviceC-qospolicy-policy_server2] quit
# Apply the policy named policy_server1 to the incoming traffic of GigabitEthernet 1/0/1.
[DeviceC-GigabitEthernet1/0/1] qos apply policy policy_server1 inbound
# Apply the policy named policy_server2 to the incoming traffic of GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/2] qos apply policy policy_server2 inbound
For information about priority marking, see the chapter “Priority marking configuration.”
Configure port priority, 802.1p-to-local mapping table, and priority marking to implement the plan as described in Table 2.
Table 2 Configuration plan
Traffic destination
Queuing plan
Traffic source
Output queue
Queue priority
Public servers
R&D department
6
High
4
Medium
2
Low
Internet
Management department > marketing department > R&D department
R&D department
2
Low
6
High
4
Medium
Figure 5 Network diagram for priority mapping table and priority marking configuration
1.        Configure trusting port priority
3.        Configure priority marking
Mark the HTTP packets from the management department, marketing department, and R&D department with 802.1p priority values 4, 5, and 3, respectively, which will be mapped to local precedence values 6, 4, and 2 according to the 802.1p-to-local mapping table configured above.
# Configure ACL 3000 to match HTTP packets.
[Device] acl number 3000
[Device-acl-adv-3000] quit
# Create a class named http, and use ACL 3000 as the match criterion.
[Device-classifier-http] quit
# Configure a QoS to mark the traffic from the management department with 802.1p priority 4, and apply the policy to the incoming traffic of the GigabitEthernet 1/0/3.
[Device-behavior-admin] remark dot1p 4
[Device-behavior-admin] quit
[Device] qos policy admin
[Device-qospolicy-admin] quit
[Device-GigabitEthernet1/0/3] qos apply policy admin inbound
# Configure a QoS to mark the traffic from the marketing department with 802.1p priority 5, and apply the policy to the incoming traffic of the GigabitEthernet 1/0/1.
[Device-behavior-market] remark dot1p 5
[Device-behavior-market] quit
[Device] qos policy market
[Device-qospolicy-market] classifier http behavior market
[Device-GigabitEthernet1/0/1] qos apply policy market inbound
# Configure a QoS to mark the traffic from the R&D department with 802.1p priority 3, and apply the policy to the incoming traffic of the GigabitEthernet 1/0/2.
 [Device] traffic behavior rd
[Device-behavior-rd] remark dot1p 3
[Device-behavior-rd] quit
[Device] qos policy rd
[Device-qospolicy-rd] classifier http behavior rd
[Device-qospolicy-rd] quit
[Device-GigabitEthernet1/0/2] qos apply policy rd inbound
·          Line rate overview
·          Configuring the line rate
·          Displaying and maintaining line rate
·          Line rate configuration example
Line rate overview
Line rate supports rate-limiting the inbound traffic and the outbound traffic. The outbound traffic is taken for example.
The line rate of a physical interface specifies the maximum rate for forwarding packets (including critical packets).
Line rate also uses token buckets for traffic control. With line rate configured on an interface, all packets to be sent through the interface are handled by the token bucket at line rate. If enough tokens are in the token bucket, packets can be forwarded. Otherwise, packets are put into QoS queues for congestion management. In this way, the traffic passing the physical interface is controlled.
Figure 6 Line rate implementation
The token bucket mechanism limits traffic rate when accommodating bursts. It allows bursty traffic to be transmitted if enough tokens are available. If tokens are inadequate, packets cannot be transmitted until efficient tokens are generated in the token bucket. It restricts the traffic rate to the rate for generating tokens.
Line rate limits the total rate of all packets on a physical interface. It is easier to use than traffic policing in controlling the total traffic rate on a physical interface.
The line rate of a physical interface specifies the maximum rate of incoming packets or outgoing packets.
Follow these steps to configure the line rate:
To do…
Use the command…
Remarks
Enter system view
Use either command.
Configure the line rate for the interface or port group
qos lr { inbound | outbound } cir committed-information-rate
Required
To do
Use the command
Remarks
Display interface line rate configuration information
display qos lr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Configure line rate on GigabitEthernet 1/0/1 to limit the outgoing traffic rat to 1280 kbps.
# Enter system view.
# Enter interface view.
# Configure line rate on GigabitEthernet 1/0/1 to limit the outgoing traffic rat to 1280 kbps.
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 1280
·          Congestion management overview
·          Congestion management configuration approaches
Network congestion degrades service quality on a traditional network. Congestion is a situation where the forwarding rate decreases due to insufficient resources, resulting in extra delay.
Congestion is more likely to occur in complex packet switching circumstances. Figure 7 shows two common cases:
Figure 7 Traffic congestion causes
Congestion can bring the following negative results:
·          Increased delay and jitter during packet transmission
·          Decreased network throughput and resource use efficiency
·          Network resource (memory in particular) exhaustion and even system breakdown
Congestion is unavoidable in switched networks and multi-user application environments. To improve the service performance of your network, you must take some proper measures to address the congestion issues.
The key to congestion management is how to define a dispatching policy for resources to decide the order of forwarding packets when congestion occurs.
Congestion management uses queuing and scheduling algorithms to classify and sort traffic leaving a port. Each queuing algorithm addresses a particular network traffic problem, and has a different impact on bandwidth resource assignment, delay, and jitter. A port of the switching engine on a WX3000E wired-wireless switch provides four queues numbered 3, 2, 1, and 0, which accommodate the packets with local precedence values 6 and 7, 4 and 5, 2 and 3, and 0 and 1, respectively.
Queue scheduling processes packets by their priorities, preferentially forwarding high-priority packets. This section describes in detail Strict Priority (SP) queuing, Weighted Round Robin (WRR) queuing, and SP+WRR queuing.
SP queuing
SP queuing is designed for mission-critical applications, which require preferential service to reduce the response delay when congestion occurs.
Figure 8 Schematic diagram for SP queuing
As shown in Figure 8, SP queuing classifies eight queues on a port into four classes, numbered 3 to 0 in descending priority order.
SP queuing schedules the eight queues in the descending order of priority. It sends packets in the queue with the highest priority first. When the queue with the highest priority is empty, it sends packets in the queue with the second highest priority, and so on. You can assign mission-critical packets to the high priority queue to ensure that they are always served first and common service packets to the low priority queues and transmitted when the high priority queues are empty.
The disadvantage of SP queuing is that packets in the lower priority queues cannot be transmitted if packets exist in the higher priority queues. This may cause lower priority traffic to starve to death.
WRR queuing
WRR queuing schedules all the queues in turn to ensure every queue is be served for a certain time, as shown in Figure 9.
Figure 9 Schematic diagram for WRR queuing
Assume a port provides four output queues. WRR assigns each queue a weight value (represented by w3, w2, w1, or w0) to decide the proportion of resources assigned to the queue. On a 100 Mbps port, you can configure the weight values of WRR queuing to 50, 30, 10, and 10 (corresponding to w3, w2, w1, and w0, respectively). In this way, the queue with the lowest priority can get a minimum of 20 Mbps of bandwidth. WRR avoids the disadvantage of SP queuing that packets in low-priority queues may fail to be served for a long time.
Another advantage of WRR queuing is that when the queues are scheduled in turn, the service time for each queue is not fixed. If a queue is empty, the next queue will be scheduled immediately. This improves bandwidth resource use efficiency.
The switching engine on a WX3000E wired-wireless switch supports group-based WRR queuing. You can organize WRR queues into WRR scheduling groups 1 and 2. During queue scheduling, WRR is performed in each group, and then the dequeued packets are scheduled by using SP queuing.
For example, assign queues 0 and 1 to WRR scheduling group 1, with the weight of 1 and 2, respectively; assign queues 2 and 3 to WRR scheduling group 2, with the weight of 1 and 3, respectively. The following figure shows how these queues are scheduled.
Figure 10 Queue scheduling for the two WRR scheduling groups
SP+WRR queuing
To implement SP+WRR queuing, assign some queues to the SP scheduling group, some to WRR scheduling group 1, and the others to WRR scheduling group 2. During queue scheduling, queues in each WRR scheduling group are scheduled by using WRR according to their weights, and then the dequeued packets together with the packets in the SP scheduling group are scheduled by using SP queuing.
For example, suppose you assign queues 0 and 1 to WRR scheduling group 1, with their weights 1 and 2, assign queue 3 to WRR scheduling group 2, with its weight 1, and assign queue 2 to the SP scheduling group. The scheduling process is as shown in Figure 11.
Figure 11 SP+WRR queuing
Complete the following tasks to achieve hardware congestion management:
Remarks
Optional
SP queuing comprises basic SP queuing and multi-mode SP queuing. Support for SP queuing modes depends on your device model.
Follow these steps to configure SP queuing:
To do…
Use the command…
Remarks
Enter system view
Use either command.
Configure SP queuing
undo qos wrr
Required
By default, an interface uses the SP queuing.
Configuration example
1.        Network requirements
Configure GigabitEthernet 1/0/1 to use SP queuing.
2.        Configuration procedure
# Enter system view
# Configure GigabitEthernet1/0/1 to use SP queuing.
[Sysname-GigabitEthernet1/0/1] undo qos wrr
1.        Configuring WRR queuing
Follow these steps to configure basic WRR queuing:
To do…
Use the command…
Remarks
Enter system view
Use either command.
Configure a basic WRR queue
qos wrr queue-id group group-id weight schedule-value
Required
Display WRR queuing configuration information on interfaces
display qos wrr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Optional
·      Support for queue scheduling types depends on your device model.
·      Interface types supporting queue scheduling profiles depends on your device model.
·      Only one queue scheduling profile can be applied to an interface.
·          Enable WRR queuing on interface GigabitEthernet 1/0/1.
·          Assign queues 0 and 1 to WRR scheduling group 1, with the weight of 10 and 20, respectively.
·          Assign queues 2 and 3 to WRR scheduling group 2, with the weight of 30 and 50, respectively.
# Configure WRR queuing on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
[Sysname-GigabitEthernet1/0/1] qos wrr 1 group 1 weight 20
[Sysname-GigabitEthernet1/0/1] qos wrr 2 group 2 weight 30
[Sysname-GigabitEthernet1/0/1] qos wrr 3 group 2 weight 50
Follow these steps to configure basic SP+WRR queuing:
To do…
Use the command…
Remarks
Enter system view
Use either command.
Assign a queue to the SP scheduling group
qos wrr queue-id group sp
Required
Assign a queue to the specified WRR scheduling group, and specify a weight for the queue
Required
To guarantee that WRR queues are scheduled according to their weights, assign queues with continuous numbers to the same WRR scheduling group when configuring SP+WRR queuing.
Configure SP+WRR queuing on interface GigabitEthernet 1/0/1 as follows:
·          Assign queue 0 to the SP scheduling group.
·          Assign queue 1 to WRR scheduling group 1, with the weight of 20.
·          Assign queues 2 and 3 to WRR scheduling group 2, with the weight of 10 and 50.
# Configure SP+WRR queuing on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
[Sysname-GigabitEthernet1/0/1] qos wrr 2 group 2 weight 10
·          Traffic filtering overview
·          Configuring traffic filtering
·          Traffic filtering configuration example
You can filter in or filter out a class of traffic by associating the class with a traffic filtering action. For example, you can filter packets sourced from a specific IP address or MAC address, and use time ranges to implement periodical traffic filtering.
You can apply an ACL to a port to implement traffic filtering. For more information, see the chapter “ACL configuration.”
Follow these steps to configure traffic filtering:
To do…
Use the command…
Remarks
Enter system view
Create a behavior and enter behavior view
Configure the traffic filtering action
filter { deny | permit }
Required
·      deny: Drops packets.
·      permit: Permits packets to pass through.
Associate the class with the traffic behavior in the QoS policy
To an interface
To online users
To a VLAN
Globally
Display the traffic filtering configuration
Optional
With filter deny configured for a traffic behavior, the other actions (except class-based accounting) in the traffic behavior do not take effect. Whether traffic filtering can work with class-based accounting depends on your device model.
As shown in Figure 12, Host is connected to GigabitEthernet 1/0/1 of Device.
Configure traffic filtering to filter the packets with source port not being 21 and received on GigabitEthernet 1/0/1.
Figure 12 Network diagram for traffic filtering configuration
# Create advanced ACL 3000, and configure a rule to match packets whose source port number is 21.
[DeviceA] acl number 3000
[DeviceA-acl-adv-3000] rule 0 permit tcp source-port eq 21
[DeviceA-acl-adv-3000] quit
# Create a class named classifier_1, and use ACL 3000 as the match criterion in the class.
[DeviceA] traffic classifier classifier_1
[DeviceA-classifier-classifier_1] if-match acl 3000
[DeviceA-classifier-classifier_1] quit
# Create a behavior named behavior_1, and configure the traffic filtering action to drop packets.
[DeviceA] traffic behavior behavior_1
[DeviceA-behavior-behavior_1] filter deny
[DeviceA-behavior-behavior_1] quit
# Create a policy named policy, and associate class classifier_1 with behavior behavior_1 in the policy.
[DeviceA] qos policy policy
[DeviceA-qospolicy-policy] classifier classifier_1 behavior behavior_1
[DeviceA-qospolicy-policy] quit
# Apply the policy named policy to the incoming traffic of GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] qos apply policy policy inbound
·          Priority marking overview
·          Configuring priority marking
·          Priority marking configuration example
Priority marking can be used together with priority mapping. For more information, see the chapter “Priority mapping configuration.”
Priority marking sets the priority fields or flag bits of packets to modify the priority of traffic. For example, you can use priority marking to set IP precedence or DSCP for a class of IP traffic to change its transmission priority in the network.
To configure priority marking, you can associate a class with a behavior configured with the priority marking action to set the priority fields or flag bits of the class of packets.
Follow these steps to configure priority marking:
To do…
Use the command…
Remarks
Enter system view
Set the DSCP value for packets
remark dscp dscp-value
Optional
Set the 802.1p priority for packets or configure the inner-to-outer tag priority copying function
remark dot1p 8021p
Optional
Set the IP precedence for packets
remark ip-precedence ip-precedence-value
Optional
Set the local precedence for packets
remark local-precedence local-precedence
Optional
Set the SVLAN ID for packets
Optional
To an interface
To online users
To a VLAN
Globally
Display the priority marking configuration
Optional
As shown in Figure 13, the enterprise network of a company interconnects hosts with servers through Device. The network is described as follows:
·          Host A and Host B are connected to GigabitEthernet 1/0/1 of Device.
·          The data server, mail server, and file server are connected to GigabitEthernet 1/0/2 of Device.
Configure priority marking on Device to satisfy the following requirements:
Traffic source
Destination
Processing priority
Host A, B
Data server
High
Host A, B
Mail server
Medium
Host A, B
File server
Low
Figure 13 Network diagram for priority marking configuration
# Create advanced ACL 3000, and configure a rule to match packets with destination IP address 192.168.0.1.
[Device-acl-adv-3000] rule permit ip destination 192.168.0.1 0
# Create advanced ACL 3001, and configure a rule to match packets with destination IP address 192.168.0.2.
[Device] acl number 3001
[Device-acl-adv-3001] rule permit ip destination 192.168.0.2 0
[Device-acl-adv-3001] quit
# Create advanced ACL 3002, and configure a rule to match packets with destination IP address 192.168.0.3.
[Device] acl number 3002
[Device-acl-adv-3002] rule permit ip destination 192.168.0.3 0
[Device-acl-adv-3002] quit
# Create a class named classifier_dbserver, and use ACL 3000 as the match criterion in the class.
[Device] traffic classifier classifier_dbserver
[Device-classifier-classifier_dbserver] if-match acl 3000
[Device-classifier-classifier_dbserver] quit
# Create a class named classifier_mserver, and use ACL 3001 as the match criterion in the class.
[Device] traffic classifier classifier_mserver
[Device-classifier-classifier_mserver] if-match acl 3001
[Device-classifier-classifier_mserver] quit
# Create a class named classifier_fserver, and use ACL 3002 as the match criterion in the class.
[Device] traffic classifier classifier_fserver
[Device-classifier-classifier_fserver] if-match acl 3002
[Device-classifier-classifier_fserver] quit
# Create a behavior named behavior_dbserver, and configure the action of setting the local precedence value to 4.
[Device] traffic behavior behavior_dbserver
[Device-behavior-behavior_dbserver] remark local-precedence 4
[Device-behavior-behavior_dbserver] quit
# Create a behavior named behavior_mserver, and configure the action of setting the local precedence value to 3.
[Device] traffic behavior behavior_mserver
[Device-behavior-behavior_mserver] remark local-precedence 3
[Device-behavior-behavior_mserver] quit
# Create a behavior named behavior_fserver, and configure the action of setting the local precedence value to 2.
[Device] traffic behavior behavior_fserver
[Device-behavior-behavior_fserver] remark local-precedence 2
[Device-behavior-behavior_fserver] quit
# Create a policy named policy_server, and associate classes with behaviors in the policy.
[Device] qos policy policy_server
[Device-qospolicy-policy_server] classifier classifier_dbserver behavior behavior_dbserver
[Device-qospolicy-policy_server] classifier classifier_mserver behavior behavior_mserver
[Device-qospolicy-policy_server] classifier classifier_fserver behavior behavior_fserver
[Device-qospolicy-policy_server] quit
# Apply the policy named policy_server to the incoming traffic of GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] qos apply policy policy_server inbound
·          Traffic redirecting overview
·          Configuring traffic redirecting
Traffic redirecting is the action of redirecting the packets matching the specific match criteria to a certain location for processing.
The switching engine on a WX3000E wired-wireless switch supports redirecting traffic to an interface. When the switch receives packets to be processed by a specific interface, you can configure redirecting traffic to the interface. Traffic redirecting applies to only Layer 2 packets.
Follow these steps to configure traffic redirecting:
To do…
Use the command…
Remarks
Enter system view
Required
Configure a traffic redirecting action
redirect  interface interface-type interface-number
Optional
You can specify the traffic redirecting destination as needed.
To an interface
To a VLAN
Globally
Burst configuration
·          Burst overview
·          Configuring burst
·          Burst configuration example
Burst overview
The burst function improves packet buffering and forwarding performance in the following scenarios:
·          Dense broadcast or multicast traffic and massive burst traffic are present.
·          High-speed traffic is forwarded over a low-speed link or traffic received from multiple interfaces at the same speed is forwarded through an interface at the same speed.
By enabling the burst function on your device, you can improve the processing performance of the device operating in these scenarios to reduce packet loss.
Make sure that you are fully aware of the impacts when enabling the burst function, because the burst function may affect the QoS performance of your device.
Configuring burst
Configuration prerequisites
Make sure that the burst function is necessary for addressing your problem.
Follow these steps to enable the burst function:
To do…
Use the command…
Remarks
Enter system view
Enable the burst function
burst-mode enable
Required
Disabled by default.
In the customer network shown in Figure 14, a server connects to the switch through a 1000 Mbps Ethernet interface. The server sends dense broadcast or multicast traffic to the hosts irregularly. Each host connects to the switch through a 100 Mbps network adapter.
Configure the switch to process dense traffic from the server to guarantee that packets can reach the hosts.
Figure 14 Network diagram for burst configuration
<Switch> system-view
# Enable the burst function.
[Switch] burst-mode enable
·          Appendix A Default priority mapping tables
·          Appendix B Introduction to packet precedences
For the default dot1p-dot1p and dscp-dscp priority mapping tables, an input value yields a target value equal to it.
Table 3 Default dot1p-lp and dot1p-dscp priority mapping tables
Input priority value
dot1p-lp mapping
dot1p-dscp mapping
802.1p priority (dot1p)
Local precedence
(lp)
dscp
0
2
0
1
0
8
2
1
16
3
3
24
4
4
32
5
5
40
6
6
48
7
7
56
Table 4 Default dscp-lp, dscp-dp, dscp-dot1p, and dscp-exp priority mapping tables
dscp-lp mapping
dscp-dot1p mapping
DSCP
Local precedence (lp)
0 to 7
0
0
8 to 15
1
1
16 to 23
2
2
24 to 31
3
3
32 to 39
4
4
40 to 47
5
5
48 to 55
6
6
56 to 63
7
7
Figure 15 ToS and DS fields
As shown in Figure 15, the ToS field in the IP header contains eight bits. The first three bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field, where a DSCP value is represented by the first six bits (0 to 5) and is in the range 0 to 63. The remaining two bits (6 and 7) are reserved.
Table 5 Description on IP precedence
IP precedence (decimal)
IP precedence (binary)
0
000
Routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
Table 6 Description on DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
be (default)
802.1p priority
802.1p priority lies in the Layer 2 header and applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 16 An Ethernet frame with an 802.1Q tag header
As shown in Figure 16, the four-byte 802.1Q tag header consists of the tag protocol identifier (TPID, two bytes in length), whose value is 0x8100, and the tag control information (TCI, two bytes in length). Figure 17 presents the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called the “802.1p priority”, because its use is defined in IEEE 802.1p. Table 7 presents the values for 802.1p priority.
Figure 17 802.1Q tag header
Table 7 Description on 802.1p priority
802.1p priority (decimal)
802.1p priority (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
