| 00-Preface | 84.97 KB |
Preface
The H3C WX3000E documentation set includes eight configuration guides, which describe the software features for the H3C WX3000E Series Wireless Switches Switching Engine and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The ACL and QoS Configuration Guide describes the fundamentals and configuration of ACL, priority mapping, line rate, congestion management, traffic filtering, and priority marking.
· Audience
Audience
· Field technical support and servicing engineers
· Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access controller, an access controller module, or a switching engine on a wireless switch. |
Represents an access point. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Documentation feedback
We appreciate your comments.
