02-Layer 2 Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10202-Layer 2 Configuration Guide
05-Port Isolation Configuration
05-Port Isolation Configuration 73.81 KB
This chapter includes these sections:
·          Introduction to port isolation
·          Configuring an isolation group
·          Displaying and maintaining isolation groups
·          Port isolation configuration example
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wireless switches.
·      The port numbers in this chapter are for illustration only.
Assigning ports to different VLANs is a typical way to isolate Layer 2 traffic for data privacy and security, but this way is VLAN resource demanding. To save VLAN resources, you can use the port isolation feature, which can isolate ports without using VLANs and allows for great flexibility and security.
The switching engine on the WX3000E series wireless switches supports multiple isolation groups which can be configured manually.
The number of ports assigned to an isolation group is not limited.
Within the same VLAN, traffic can be forwarded bidirectionally between isolated ports and ports outside isolation groups.
Adding a port to an isolation group
Follow these steps to configure an isolation group for a multiple-isolation-group device:
To do…
Use the command…
Remarks
Enter system view
Create an isolation group
port-isolate group group-number
Required
Enter interface view, or port group view
Enter Ethernet interface view
Required
Use one of the commands.
·      In Ethernet interface view, the subsequent configurations apply to the current port
·      In Layer 2 aggregate interface view, the subsequent configurations apply to the Layer 2 aggregate interface and all its member ports.
·      In port group view, the subsequent configurations apply to all ports in the port group.
Enter Layer 2 aggregate interface view
Enter port group view
port-group manual port-group-name
Add the port/ports to an isolation group as an isolated port/isolated ports
port-isolate enable group group-number
Required
No ports are added to an isolation group by default.
To do…
Use the command…
Remarks
Display the isolation group information
display port-isolate group [ group-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Networking requirements
As shown in Figure 1, Host A, Host B, and Host C are connected to ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 of Device, which are assigned to the same VLAN. Device provides access to the Internet through port GigabitEthernet 1/0/4 for Host A, B and C.
Configure port isolation to isolate GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to prevent the hosts from communicating with one another at Layer 2 but allowing them to access the Internet.
Figure 1 Networking diagram for port isolation configuration
Configuration procedure
# Create isolation group 2.
[Device] port-isolate group 2
# Assign GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to isolation group 2 as isolated ports.
[Device-GigabitEthernet1/0/1] port-isolate enable group 2
[Device-GigabitEthernet1/0/2] port-isolate enable group 2
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] port-isolate enable group 2
# Display information of isolation group 2.
<Device> display port-isolate group 2
 Port-isolate group information:
 Uplink port support: NO
 Group ID: 2
 Group members:
   GigabitEthernet1/0/1     GigabitEthernet1/0/2     GigabitEthernet1/0/3
