| 01-Probe Commands | 858.71 KB |
debugging system internal arp event
debugging system internal arp features
debugging system internal arp notify
debugging system internal arp sync
debugging system internal fsim
debugging system internal fsim fpga
debugging system internal fsim packet
debugging system internal fsim packet filter
debugging system internal ike detail
debugging system internal ikev2 detail
debugging system internal ipsec packet detail
debugging system internal ipv6 fib prefix
debugging system internal nd sub-features
debugging system internal vlan
debugging system internal wlan forward packet
diag temperature display status
diag tmpr-alarm display threshold
display fastforward session table
display hardware internal transceiver register interface
display system internal arp ifcb
display system internal arp ip-address
display system internal arp machash
display system internal arp probe
display system internal arp rbhash
display system internal arp reload
display system internal arp rule
display system internal arp source-suppression cache
display system internal arp statistics
display system internal arp vlan
display system internal aspf statistics
display system internal attack-defense scan stat-nodes ip
display system internal attack-defense scan stat-nodes ipv6
display system internal cloud-management state
display system internal customlog host
display system internal customlog mbuf dump
display system internal customlog mbuf usage
display system internal customlog test
display system internal dot11 characteristics
display system internal dot11 verbose
display system internal ethernet character
display system internal ethernet controlblock
display system internal fsim packet filter
display system internal fsim statistics
display system internal ha service
display system internal ha service-group
display system internal ha statistics
display system internal ifmgr brief
display system internal ifmgr down
display system internal ifmgr entry
display system internal ifmgr event
display system internal ifmgr hotplug
display system internal ifmgr index
display system internal ifmgr list
display system internal ifmgr name
display system internal ifmgr type
display system internal ike phase2-sa count
display system internal ike phase2-sa verbose
display system internal ike received-message count
display system internal ike sent-message count
display system internal ikev2 child-sa count
display system internal ip address
display system internal ip routing-table
display system internal ip routing-table acl
display system internal ip routing-table ip-address
display system internal ip routing-table prefix-list
display system internal ip routing-table protocol
display system internal ip routing-table statistics
display system internal ipsec block-flow
display system internal ipsec received-message
display system internal ipsec sent-message
display system internal ipsec sp
display system internal ipv6 address
display system internal ipv6 fib prefix
display system internal ipv6 fib prefix entry-status
display system internal ipv6 fib prefix ipv6
display system internal ipv6 l2-multicast ip forwarding verbose
display system internal ipv6 l2-multicast ip verbose
display system internal ipv6 l2-multicast ipc statistics
display system internal ipv6 l2-multicast mac forwarding verbose
display system internal ipv6 l2-multicast mac verbose
display system internal ipv6 multicast forwarding vlan reference
display system internal ipv6 multicast forwarding-table dummy
display system internal ipv6 pathmtu
display system internal ipv6 rawip
display system internal ipv6 rib event attribute
display system internal ipv6 rib event policy
display system internal ipv6 rib event protocol
display system internal ipv6 rib event statistics
display system internal ipv6 rib instance
display system internal ipv6 rib log
display system internal ipv6 rib memory
display system internal ipv6 rib nib
display system internal ipv6 rib nib log
display system internal ipv6 rib prefix
display system internal ipv6 rib summary
display system internal ipv6 route-direct interface
display system internal ipv6 route-static nib log
display system internal ipv6 routing-table
display system internal ipv6 routing-table acl
display system internal ipv6 routing-table ipv6-address
display system internal ipv6 routing-table prefix-list
display system internal ipv6 routing-table protocol
display system internal ipv6 routing-table statistics
display system internal ipv6 tcp
display system internal ipv6 tcp port-info
display system internal ipv6 tcp-proxy verbose
display system internal ipv6 udp
display system internal ipv6 udp port-info
display system internal kernel memory dump
display system internal kernel memory pool
display system internal l2-multicast ip forwarding verbose
display system internal l2-multicast ip verbose
display system internal l2-multicast ipc statistics
display system internal l2-multicast mac forwarding verbose
display system internal l2-multicast mac verbose
display system internal license buffer-data
display system internal license feature-set
display system internal license fifo
display system internal license lipc
display system internal license lipc hash
display system internal license lmi-paa
display system internal link-aggregation global
display system internal link-aggregation interface
display system internal lipc dump
display system internal lipc dump configuration
display system internal lipc history
display system internal lipc lcmp statistics
display system internal lipc lgmp group
display system internal lipc lgmp group-list
display system internal lipc lgmp physical-group
display system internal lipc lgmp physical-group-list
display system internal lipc lgmp statistics
display system internal lipc lip statistics
display system internal lipc loop statistics
display system internal lipc mtcp group
display system internal lipc mtcp group all
display system internal lipc mtcp performance
display system internal lipc mtcp statistics
display system internal lipc pcb mbuf statistics
display system internal lipc pcb statistics
display system internal lipc physical
display system internal lipc publish global-cb
display system internal lipc publish statistics
display system internal lipc stcp event
display system internal lipc stcp global-server
display system internal lipc stcp links
display system internal lipc stcp performance
display system internal lipc stcp port
display system internal lipc stcp statistics
display system internal lipc stcp status
display system internal lipc stream
display system internal lipc sudp pcb-info
display system internal lipc sudp statistics
display system internal lipc sudp { global-port | local-port }
display system internal lipc topology history
display system internal lipc topology link
display system internal lipc topology node
display system internal lipc topology process-time
display system internal lipc topology statistics
display system internal lipc topology status
display system internal mac-address configuration
display system internal mac-address learned
display system internal mac-address protocol
display system internal mac-address statistics
display system internal mac-forwarding cache ip verbose
display system internal mac-forwarding cache ipv6 verbose
display system internal mac-forwarding controlblock
display system internal mbuf relay statistics
display system internal multicast capability
display system internal multicast forwarding vlan reference
display system internal multicast forwarding-table dummy
display system internal multicast record
display system internal nat aging-queue
display system internal nat statistics
display system internal nd dad
display system internal nd entry
display system internal nd ifcb
display system internal nd machash
display system internal nd probe
display system internal nd rbhash
display system internal nd reload
display system internal nd rule
display system internal nd static
display system internal nd statistics
display system internal portal ap-statistics
display system internal portal process
display system internal portal statistics
display system internal ppp statistics
display system internal pppoe-server statistics
display system internal process state
display system internal rib event attribute
display system internal rib event policy
display system internal rib event prefix
display system internal rib event protocol
display system internal rib event statistics
display system internal rib instance
display system internal rib log
display system internal rib memory
display system internal rib nib
display system internal rib nib log
display system internal rib prefix
display system internal rib summary
display system internal route-direct interface
display system internal route-static nib log
display system internal session
display system internal session aging-queue
display system internal session alg-exception
display system internal session relation-table ipv4
display system internal session relation-table ipv6
display system internal session statistics
display system internal session table ipv4
display system internal session table ipv6
display system internal startup cache
display system internal stp bridge-info
display system internal stp port-info
display system internal tcp port-info
display system internal tcp-proxy statistics
display system internal tcp-proxy verbose
display system internal udp port-info
display system internal userlog mbuf dump
display system internal userlog statistic
display system internal userlog test
display system internal wips statistics
display system internal wlan ac capability
display system internal wlan adapter-asyncinfo
display system internal wlan ap message
display system internal wlan ap name
display system internal wlan ap radio drv-info
display system internal wlan ap-group-configuration
display system internal wlan ap-libinfo
display system internal wlan ap-model-configuration
display system internal wlan apdb
display system internal wlan band-navigation
display system internal wlan client ip
display system internal wlan command-cache
display system internal wlan ctrl-ap
display system internal wlan history bandwidth
display system internal wlan history radiostate
display system internal wlan history wlanid
display system internal wlan history-error
display system internal wlan kernel-ap
display system internal wlan link-info
display system internal wlan load-balance neighbor-list ap
display system internal wlan load-balance neighbor-list client
display system internal wlan load-status
display system internal wlan logbuffer ha
display system internal wlan logbuffer memory
display system internal wlan response-timeout event
display system internal wlan statistics
display system internal wlan virtual ap
display system internal wlan virtual client
display system internal wlan { aplb | kernel-aplb }
display transceiver information
display transceiver moduleinfo
reset system internal arp statistics
reset system internal aspf statistics
reset system internal fsim statistics
reset system internal ip routing-table statistics protocol
reset system internal ipv6 rib log
reset system internal ipv6 rib nib log
reset system internal ipv6 rib summary
reset system internal ipv6 route-static nib log
reset system internal ipv6 routing-table statistics protocol
reset system internal lipc dump buffer
reset system internal mac-address statistics
reset system internal mbuf relay statistics
reset system internal multicast record
reset system internal nat statistics
reset system internal nd statistics
reset system internal portal ap-statistics
reset system internal portal statistics
reset system internal ppp statistics
reset system internal pppoe-server statistics
reset system internal rib nib log
reset system internal rib summary
reset system internal route-static nib log
reset system internal session alg statistics
reset system internal session statistics
reset system internal tcp-proxy statistics
reset system internal wlan history bandwidth
reset system internal wlan history radiostate
reset system internal wlan history-error
reset system internal wlan response-timeout event
wlan ap-execute exec-console enable
wlan system internal ap adjust reboot enable
wlan system internal offline-restrain
wlan system internal reboot-restrain
Probe commands
The commands in this book are designed only for developers to debug software.
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
C
cloud-management local-port
Use cloud-management local-port to specify the TCP port number used to establish cloud connections.
Use undo cloud-management local-port to restore the default.
cloud-management local-port port-number
TCP port number 443 is used to establish cloud connections.
Probe view
port-number: Specifies a TCP port number in the range of 1 to 65535.
This command is used for communication with the test server and commissioning.
The device does not save the port number configuration. After the device restarts, it uses the default port number to establish cloud connections.
D
debug
Use debug to enable debugging and set the output destination for the debugging information.
debug {on | off | switch-save | out-to-ic | out-to-console }
Probe view
on: Enables debugging.
off: Disables debugging.
switch-save: Saves the debugging switch.
out-to-ic: Outputs the debugging information to the information center.
out-to-console: Outputs the debugging information to the console port.
debug from-device clear
Use debug from-device clear to clear the debugging information.
Probe view
debug from-device display
Use debug from-device display to display the device abnormality information.
debug from-device display { all | error }
Probe view
all: Displays all device abnormality information.
error: Displays the device error information.
debug level
Use debug level to enable or disable debugging for the specified level.
debug level { all | debug | error | info | print-fileline | print-modulename } { on | off }
Probe view
all: Specifies all debugging levels.
debug: Specifies the debug level debugging.
error: Specifies the error level debugging.
info: Specifies the info level debugging.
print-fileline: Specifies the output file line count debugging.
print-modulename: Specifies the output module name debugging.
debug module
Use debug module to enable or disable debugging for the specified module.
debug module { adp | all-module | btrm | cf | cfm | conf | cpld | cpu | dev | devm | dim | drv-mod1 | drv-mod2 | drv-mod3 | ec | eeprom | fan | fe | flash| fshe | fwd | ge | ht | i2c | ibc | init | intf | led | lic | lipc | lpu | lpum | mbuf-relay | mbus | mcore | mm | mon | np | nvram | oem | optic | other | pci | per | plat | port | relinfo | rtc | sae | stm | tcam | tmpr | u2f | uart | usb | xge } {on | off }
Probe view
debugging ha
Use debugging ha to enable HA debugging.
Use undo debugging ha to disable HA debugging.
debugging ha { all | config | fsm | policy | standby | sync }
undo debugging ha { all | config | fsm | policy | standby | sync }
all: Enables debugging for all HA submodules.
config: Enables debugging for the config submodule.
fsm: Enables debugging for the FSM submodule.
policy: Enables debugging for the policy submodule.
standby: Enables debugging for the standby HA module.
sync: Enables debugging for the sync submodule.
# Enable debugging for the FSM submodule.
<Sysname> debugging ha fsm
debugging lipc
Use debugging lipc to enable debugging for LIPC.
Use undo debugging lipc to disable debugging for LIPC.
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
Probe view
detail: Enables detailed debugging.
dump port: Specifies a port number in the range of 0 to 65535.
lgmp: Enables debugging for the LIPC LGMP module.
mbuf: Enables debugging for the LIPC MBUF module.
mtcp: Enables debugging for the LIPC MTCP module.
pub: Enables debugging for the LIPC PUB module.
stcp: Enables debugging for the LIPC STCP module.
stream: Enables debugging for the LIPC STREAM module.
topo: Enables debugging for the LIPC TOPO module.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command enables LIPC debugging for the node where the global active MPU resides.
debugging lipc mtcp
Use debugging lipc mtcp to enable debugging for the LIPC MTCP module.
Use undo debugging lipc mtcp to disable debugging for the LIPC MTCP module.
debugging lipc mtcp [ group group-id ] [ lip lip ]
undo debugging lipc mtcp [ group group-id ] [ lip lip ]
Debugging is disabled for the LIPC MTCP module.
Probe view
group group-id: Specifies a multicast group by its group port in the range of 0 to 65535. If you do not specify a multicast group, the command enables LIPC MTCP debugging for all multicast groups.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command enables LIPC MTCP debugging for the node where the global active MPU resides.
debugging lipc stcp
Use debugging lipc stcp to enable debugging for the LIPC STCP module.
Use undo debugging lipc stcp to disable debugging for the LIPC STCP module.
debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
undo debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
Debugging is disabled for the LIPC STCP module.
Probe view
port port1 [ port port2 ]: Specifies one or multiple LIPC connections. The port1 and port2 arguments represent the local port and the remote port of an LIPC connection, respectively. The value range for the two arguments is 0 to 65535, and the default is 0.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command enables LIPC STCP debugging for the node where the global active MPU resides.
Use debugging system internal arp event to enable ARP event debugging.
Use undo debugging system internal arp event to disable ARP event debugging.
ARP event debugging is disabled.
Probe view
Use debugging system internal arp features to enable ARP features debugging.
Use undo debugging system internal arp features to disable ARP features debugging.
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP features debugging is disabled.
Probe view
notify: Enables notification debugging for ARP features.
packet: Enables packet debugging for ARP features.
Use debugging system internal arp notify to enable ARP notification debugging.
Use undo debugging system internal arp notify to disable ARP notification debugging.
ARP notification debugging is disabled.
Probe view
Use debugging system internal arp sync to enable ARP synchronization debugging.
Use undo debugging system internal arp sync to disable ARP synchronization debugging.
ARP synchronization debugging is disabled.
Probe view
Use debugging system internal fsim to enable FSIM control plane debugging features.
Use undo debugging system internal fsim to disable FSIM control plane debugging features.
debugging system internal fsim { cache | common | ip | ipc | mac-address | pcie | port | portal | qos | vlan | wlan } { all | error | event | info } slot slot-number
undo debugging system internal fsim { cache | common | ip | ipc | mac-address | pcie | port | portal | qos | vlan | wlan } { all | error | event | info } slot slot-number
FSIM control module debugging is disabled.
Probe view
cache: Specifies debugging for the caching module.
common: Specifies debugging for the common module.
ip: Specifies debugging for the IP module.
ipc: Specifies debugging for the IPC module.
mac-address: Specifies debugging for the MAC address module.
pcie: Specifies debugging for the PCIE module.
port: Specifies debugging for the port module.
portal: Specifies debugging for the portal module.
qos: Specifies debugging for the QoS module.
vlan: Specifies debugging for the VLAN module.
wlan: Specifies debugging for the WLAN module.
all: Specifies all levels of debugging.
error: Specifies error debugging.
event: Specifies event debugging.
info: Specifies information debugging.
slot slot-number: Specifies an IRF member device by its member ID.
Use debugging system internal fsim fpga to enable FSIM FPGA debugging features.
Use undo debugging system internal fsim fpga to disable FSIM FPGA debugging features.
debugging system internal fsim fpga { cache | common | ip | mac-address | port | portal | qos | vlan | wlan } { all | error | event | info } slot slot-number
undo debugging system internal fsim { cache | common | ip | mac-address | port | portal | qos | vlan | wlan } { all | error | event | info } slot slot-number
FSIM FPGA debugging is disabled.
Probe view
Use debugging system internal fsim packet to enable FSIM packet debugging features.
Use undo debugging system internal fsim packet to disable FSIM packet debugging features.
debugging system internal fsim packet { all | parse | forward | encap } { all | error | event | info } slot slot-number
undo debugging system internal fsim packet { all | parse | forward | encap } { all | error | event | info } slot slot-number
FSIM packet debugging is disabled.
Probe view
all: Specifies all FSIM packet debugging features.
parse: Specifies packet parsing debugging.
forward: Specifies packet forwarding debugging.
encap: Specifies packet encapsulation debugging.
Use debugging system internal fsim packet filter to set FSIM packet filtering criteria.
Use undo debugging system inter fsim packet filter to remove FSIM packet filtering criteria.
debugging system internal fsim packet filter [ source-mac source-address | destination-mac dest-mac | [ [ source-ipv4 ip-address | destination-ipv4 ip-address ] * | [ source-ipv6 ipv6-address | destination-ipv6 ipv6-address ] * ] | source-port port-number | destination-port port-number | source-interface index | vlan vlan-id | protocol protocol-type | cpu { all | cpu-id } | content packet-content | result result-type ]* slot slot-number
undo debugging system internal fsim packet filter [ source-mac | destination-mac | [ [ source-ipv4 | destination-ipv4 ] * | [ source-ipv6 | destination-ipv6 ] * ] | source-port | destination-port | source-interface | vlan | protocol | cpu { all | cpu-id } | content | result ]* slot slot-number
No FSIM packet filtering criterion is set. After you use the debugging system internal fsim packet command to enable FSIM packet debugging, the system outputs debugging information about all FSIM packets.
Probe view
source-mac source-address: Specifies a MAC address (in the H-H-H format) to set a source MAC address criterion.
destination-mac dest-mac: Specifies a MAC address (in the H-H-H format) to set a destination MAC address criterion.
source-ipv4 ip-address: Specifies an IPv4 address to set a source IPv4 address criterion.
destination-ipv4 ip-address: Specifies an IPv4 address to set a destination IPv4 address criterion.
source-ipv6 ipv6-address: Specifies an IPv6 address to set a source IPv6 address criterion.
destination-ipv6 ipv6-address: Specifies an IPv6 address to set a destination IPv6 address criterion.
source-port port-number: Specifies a port number in the range of 0 to 65535 to set a source port criterion.
destination-port port-number: Specifies a port number in the range of 0 to 65535 to set a destination port criterion.
source-interface index: Specifies a Layer 2 physical interface index to set a source Layer 2 physical interface criterion. To view the indexes of interfaces, use the display system internal ifmgr list command.
vlan vlan-id: Specifies a VLAN ID to set a VLAN criterion.
protocol protocol-type: Specifies a protocol number in the range of 0 to 255 to set a protocol criterion.
cpu all: Specifies all CPUs.
cpu cpu-id: Specifies a space-separated list of up to 10 CPU items. An item specifies a CPU by its ID or specifies a range of CPUs in the form of start-CPU-ID to end-CPU-ID. The end CPU ID must be equal to or greater than the start CPU ID.
content packet-content: Specifies the packet content to be used as a criterion.
result result-type: Specifies the packet processing result to be used as a criterion.
You can use this command to configure multiple criteria. If a new criterion conflicts with an existing criterion, the new criterion overwrites the existing criterion.
To view configured criteria, use the display system internal fsim packet filter command.
Use debugging system internal ike detail to enable detailed IKE debugging.
Use undo debugging system internal ike detail to disable detailed IKE debugging.
debugging system internal ike detail { event | packet [ remote-address { ipv4-address | ipv6 ipv6-address } [ local-address { ipv4-address | ipv6 ipv6-address } | remote-port port-number ] * ] }
undo debugging system internal ike detail { event | packet }
Detailed IKE debugging is disabled.
Probe view
packet: Specifies packet debugging.
remote-address: Displays debugging information for a remote IP address.
local-address: Displays debugging information for a local IP address.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
remote-port remote-port: Displays debugging information for a remote port number. The value range for the port-number argument is 0 to 65535.
Use debugging system internal ikev2 detail to enable detailed IKEv2 debugging.
Use undo debugging system internal ikev2 detail to disable detailed IKEv2 debugging.
debugging system internal ikev2 detail [ { event | packet | remote-address } { { ipv4-address | ipv6 ipv6-address } [ remote-port port-number | local-address { ipv4-address | ipv6 ipv6-address } ]* ]
undo debugging system interval ikev2 detail [ packet | event ]
Probe view
Use debugging system internal ipsec packet detail to enable IPsec forwarding debugging.
Use undo debugging system internal ipsec packet detail to disable IPsec forwarding debugging.
debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi ]
undo debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
Probe view
acl: Displays debugging information permitted by an ACL.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the specified ACL is an IPv4 ACL.
acl-number: Specifies an ACL number in the range of 3000 to 3999.
{ ipv6-policy | policy } policy-name [ policy-sequence-number ]: Displays debugging information for an IPsec policy.
· ipv6-policy: Specifies an IPv6 IPsec policy.
· policy: Specifies an IPv4 IPsec policy.
· policy-name: Specifies the name of the IPsec policy, a case-insensitive string of 1 to 63 characters.
· policy-sequence-number: Specifies the sequence number of an IPsec policy entry, in the range of 1 to 65535. If you do not specify this argument, the command displays debugging information for all the entries in the IPsec policy.
profile profile-name: Displays debugging information for an IPsec profile. The profile-name argument specifies the profile name, a case-insensitive string of 1 to 63 characters.
remote { ipv4-address | ipv6 ipv6-address }: Displays debugging information for IPsec SAs with the specified remote address.
· ipv4-address: Specifies a remote IPv4 address.
· ipv6 ipv6-address: Specifies a remote IPv6 address.
spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]: Displays debugging information for IPsec SAs matching the specified SA triplet: remote address, security protocol, and SPI.
· ah: Specifies the AH protocol.
· esp: Specifies the ESP protocol.
· spi-number: Specifies a security parameter index in the range of 256 to 4294967295.
After enabling IPsec forwarding debugging, you can view detailed IPsec forwarding information, including:
· Packet information before encryption.
· Detailed packet information after encryption.
· Detailed packet information before decryption.
· Detailed packet information after decryption.
Use debugging system internal ipv6 fib prefix to enable IPv6 FIB prefix debugging.
Use undo debugging system internal ipv6 fib prefix to disable IPv6 FIB prefix debugging.
debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
IPv6 FIB prefix debugging is disabled.
Probe view
all: Enables all types of IPv6 FIB prefix debugging.
message: Enables IPv6 FIB prefix message debugging. If you specify this keyword, the system displays the IPv6 FIB prefix obtained from the routing table or synchronized from other cards or devices.
hardware: Enables IPv6 FIB prefix hardware debugging. If you specify this keyword, the system displays the FIB6 information issued to the driver, and the returned FIB6 information from the driver.
Use debugging system internal nd to enable ND debugging.
Use undo debugging system internal nd to disable ND debugging.
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
ND debugging is disabled.
Probe view
notify: Enables ND notification debugging.
sync: Enables ND synchronization debugging.
Use undo debugging system internal nd sub-features to disable ND sub-feature debugging.
debugging system internal nd sub-features { all | event | packet }
ND sub-feature debugging is disabled.
Probe view
all: Enables all types of ND sub-feature debugging.
event: Enables ND sub-feature event debugging.
packet: Enables ND sub-feature packet debugging.
debugging system internal stg
Use debugging system internal stg to enable outputting STG debugging information.
Use undo debugging system internal stg to disable outputting STG debugging information.
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
Outputting STG debugging information is disabled.
Probe view
all: Specifies all STG debugging information.
bind: Specifies STG VLAN mapping debugging information.
error: Specifies STG error debugging information.
map: Specifies STG-to-STI mapping debugging information.
state: Specifies STG status debugging information.
tc: Specifies TC event debugging information.
debugging system internal stp
Use debugging system internal stp to enable outputting IPC debugging information for STP.
Use undo debugging system internal stp to disable outputting IPC debugging information for STP.
debugging system internal stp ipc
undo debugging system internal stp ipc
Outputting IPC debugging information for STP is disabled.
Probe view
ipc: Specifies IPC debugging information for STP.
Use debugging system internal vlan to enable debugging for VLANs.
Use undo debugging system internal vlan to disable debugging for VLANs.
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
Debugging for VLANs is disabled.
Probe view
all: Enables all types of debugging for VLANs.
error: Enables error debugging for VLANs.
event: Enables event debugging for VLANs.
execution: Enables execution debugging for VLANs.
hardware: Enables hardware debugging for VLANs.
Use debugging system internal wlan forward packet to enable WLAN forwarding packet debugging and set rules for filtering debugging information.
Use undo debugging system internal wlan forward packet to disable WLAN forwarding packet debugging and delete all rules for filtering debugging information.
debugging system internal wlan forward packet content content-hex [ offset bytes ]
WLAN forwarding packet debugging is disabled.
Probe view
packet: Enables WLAN forwarding packet debugging.
content content-hex: Specifies the content used for filtering WLAN forwarding packet debugging information. The content-hex argument is in the H:H:H format, where H represents a byte in the debugging information. The number of Hs is in the range of 1 to 256. You can specify multiple content-hex arguments separated by the ampersand (&) character. The system displays WLAN forwarding packet debugging information only when all contents are matched.
offset bytes: Specifies the offset to start for matching debugging information. The bytes argument is in the range of 0 to 127 bytes. The default value is 0 bytes. If you specify multiple content-hex arguments, do not specify this option or set the offset value to 0.
debugging transceiver
Use debugging transceiver to enable or disable debugging for transceiver functions.
debugging transceiver { mibcache | moduleinfo | read_write_retry } { disable | enable } interface [ interface-type interface-number ]
Debugging is disabled for all transceiver functions.
Probe view
mibcache: Specifies debugging for the transceiver MIB node information retrieving function. In debugging mode, upper-layer modules must obtain data from the transceiver and calculate MIB node values by themselves. In non-debugging mode, the system periodically retrieves data from the transceiver in the background to calculate MIB node values, and saves the values in memory. Upper-layer modules use the values saved in memory.
moduleinfo: Specifies debugging for the transceiver parameters retrieving function. In debugging mode, upper-layer modules must obtain transceiver information from the transceiver. In non-debugging mode, the system retrieves transceiver information from a transceiver when it detects a transceiver, and saves the information in memory. Upper-layer modules use the information saved in memory.
The following matrix shows the command and hardware compatibility:
Hardware series |
Model |
Command compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
No |
WX2500H series |
WX2510H |
No |
WX2540H WX2560H |
Yes |
WX3000H series |
WX3010H WX3010H-L WX3010H-X WX3024H WX3024H-L |
Yes |
WX3500H series |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
Yes |
Access controller modules |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
No |
debugging wlan ap app
Use debugging wlan ap app to enable app debugging.
Use undo debugging wlan ap app to disable app debugging.
debugging wlan ap app { app-id | all }
undo debugging wlan ap app { app-id | all }
App debugging is disabled.
Probe view
app-id: Specifies an app by its ID in the range of 0 to 277.
all: Specifies all apps.
debugging wlan radio
Use debugging wlan radio to enable radio debugging.
Use undo debugging wlan radio to disable radio debugging.
debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
undo debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
Radio debugging is disabled.
Probe view
all: Specifies all types of radio debugging.
error: Specifies radio error debugging.
event: Specifies radio event debugging.
all: Specifies all scenarios.
bandwidth: Specifies bandwidth-related scenarios.
channel: Specifies working channel-related scenarios.
channellist: Specifies channel list-related scenarios.
power: Specifies transmit power-related scenarios.
preamble: Specifies preamble-related scenarios.
radiobkp: Specifies radio backup-related scenarios.
radiostate: Specifies radio state-related scenarios.
rate: Specifies rate negotiation-related scenarios.
scanconfig: Specifies scanning configuration-related scenarios.
statis: Specifies statistics reporting-related scenarios.
type: Specifies radio mode-related scenarios.
wlanid: Specifies WLAN ID-related scenarios.
debugging wlan rfid-tracking
Use debugging wlan rfid-tracking to enable wireless location debugging.
Use undo debugging wlan rfid-tracking to disable wireless location debugging.
debugging wlan rfid-tracking { all | error | event | packet }
undo debugging wlan rfid-tracking { all | error | event | packet }
Wireless location debugging is disabled.
Probe view
all: Enables all debugging functions.
error: Enables error debugging.
event: Enables event debugging.
packet: Enables packet debugging.
diag app display filename
Use diag app display filename to display information about an application package file.
diag app display filename string
Probe view
string: Specifies a file by its name, a case-insensitive string of 1 to 128 characters. The file name contains a file path.
diag boot-info display
Use diag boot-info display to display device boot information.
Probe view
diag dev-table display
Use diag dev-table display to display device management information.
Probe view
diag drvflag display
Use diag drvflag display to display the storage area information for the specified storage module.
diag drvflag { apmode | art | bf | bm | capwap | debug | dm | fanmi | lic | log | mac | mi | mon | netcfg | powmi | rel | stm | target | tr } display
Probe view
apmode: Specifies the AP mode flag area information.
art: Specifies the radio frequency flag area information.
bf: Specifies the BootWare segment flag area information.
bm: Specifies the main and backup startup files and configuration files.
capwap: Specifies the CAPWAP tunnel statistics.
debug: Specifies the number and the start position of debugging entries stored in the system.
dm: Specifies the dm segment flag area information, including flash erasing times, boot times, reboot type, and debugging flag.
fanmi: Specifies the fan manufacturer flag area information. Support for this keyword depends on the device model.
lic: Specifies the license flag area information. Support for this keyword depends on the device model.
log: Specifies the start position and the maximum number of storage logs.
mac: Specifies the MAC flag area information.
mi: Specifies the electronic label field information.
mon: Specifies the monitoring information type and the start position of logs.
netcfg: Specifies the network parameters of the BootWare.
powmi: Specifies the power supply manufacturer information. Support for this keyword depends on the device model.
rel: Specifies the reliability, air inlet, air outlet, CPU, and temperature.
stm: Specifies the stm flag area information.
target: Specifies the monitoring information type of the radio drive and the start position of logs.
tr: Specifies the test results of storage modules.
diag environment display
Use diag environment display to display information about the temperatures on a device.
Probe view
diag fan display speed
Use diag fan display speed to display the fan speed.
Probe view
diag hasa display
Use diag hasa display to display information about the hasa flag.
diag hasa display
Probe view
diag if display
Use diag if display to display the system interface specifications.
diag if display
Probe view
diag led display
Use diag led display to display the LED light status of a device.
diag led display
Probe view
diag lipc display
Use diag lipc display to display the product IPC information, including the EINTF information for IPC user registration on the FEL layer, the multicast group information, and the IPC packet information.
diag lipc display
Probe view
diag log display
Use diag log display to display information about logs on a device.
diag log display { all | last }
Probe view
all: Specifies all logs.
last: Specifies the latest logs.
diag mbuf-relay display
Use diag mbuf-relay display to display the product mbuf-relay information, including the EINTF information for mbuf-relay user registration, the mbuf-relay packet receiving information, and the mbuf-relay packet sending information.
Probe view
diag mbus display
Use diag mbus display to display the mbus debugging information, the EINTF information for mbus user registration, and the mbus packet information.
diag mbus display
Probe view
diag mem-assign display
Use diag mem-assign display to display information about the space allocation of memory modules.
Probe view
diag module display content
Use diag module display content to display designated address storage information for the specified module.
diag module slot/subslot { btrm | cf | cpld | cpu | dimm | eeprom | fan | nandflash | norflash | | nvram | pci | power | rtc | tmpr | usb } chip-no display content offset-value len-value
Probe view
slot/subslot: Specifies a slot or a subslot by its number.
chip-no: Specifies a chip by its number.
offset-value: Specifies the starting address.
len-value: Specifies the offset length value.
btrm: Specifies the BootROM module.
cf: Specifies the CF card module.
cpld: Specifies the CPLD module.
cpu: Specifies the CPU module.
dimm: Specifies the memory module.
eeprom: Specifies the EEPROM module.
fan: Specifies the fan module.
nandflash: Specifies the NAND flash module.
norflash: Specifies the NOR flash module.
nvram: Specifies the NVRAM module.
pci: Specifies the PCI module.
power: Specifies the power module.
rtc: Specifies the hardware clock module.
tempr: Specifies the temperature module.
usb: Specifies the USB module.
Use diag module display content to display information for the specified interfaces of the MAC or PHY module.
diag module slot/subslot { mac | phy } { aux | console | ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | ten-gigabitethernet | wlan-radio } chip-no display content offset-value len-value
Probe view
NOTE: Support for interfaces depends on the device model. |
mac: Specifies the MAC module.
phy: Specifies the PHY module.
aux: Specifies the AUX interfaces.
console: Specifies the console interfaces.
ethernet: Specifies the Ethernet interfaces.
gigabitethernet: Specifies the GigabitEthernet interfaces.
i-gigabitethernet: Specifies the internal GigabitEthernet interfaces.
inasync: Specifies the internal asynchronous interfaces.
inner-ethernet: Specifies the internal Ethernet interfaces.
m-ethernet: Specifies the management Ethernet interfaces.
m-gigabitethernet: Specifies the management GigabitEthernet interfaces.
ten-gigabitethernet: Specifies the 10 GigabitEthernet interfaces.
wlan-radio: Specifies the WLAN radio interfaces.
diag poe
Use diag poe to set the PoE function status of the ultra-fit AP and acquire the PoE operating status for the specified port.
diag poe slot/subslot { port-no | all } { disable | enable | status }
Probe view
port-no: Specifies a port by its number.
all: Specifies all ports.
disable: Disables PoE.
enable: Enables PoE.
status: Displays the PoE status.
diag port display statistics
Use diag port display statistics to display statistics for the specified interfaces.
diag port { aux | console | Ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | wlan-radio } display statistics
Probe view
diag port-list display
Use diag port-list display to display the list of all interfaces.
Probe view
diag port-table display
Use diag port-table display to display the list of interfaces.
Probe view
diag price display
Use diag price display to display the PCIE status.
diag pcie slot/subslot display chip-no bus-id device-id function-id offset width
Probe view
bus-id: Specifies a bus by its ID.
device-id: Specifies a device by its ID.
function-id: Specifies a function by its ID.
offset: Specifies the offset.
width: Specifies the width.
diag stm display
Use diag stm display to display the stack debugging information, including support for stacking, box stacking, and distributed stacking, and the ability to acquire stacking.
diag stm display
Probe view
diag stm statistic display
Use diag stm statistic display to display stack sending and receiving statistics.
Probe view
Use diag temperature display status to display information about the temperature.
Probe view
Use diag tmpr-alarm display threshold to display the lowest and highest temperatures on the air inlet.
Probe view
display debug-info
Use display debug-info to display the debugging settings.
display debug-info
Probe view
Use display fastforward session table to display information about session entries that match specific criteria. The session entries are entries that are not processed by security services.
Probe view
ipv4: Displays IPv4 session entries.
ipv6: Displays IPv6 session entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
source-ip source-ip: Specifies a source IP address. The source-ip argument specifies the source IP address of sessions from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IP address. The destination-ip argument specifies the destination IP address of sessions from the initiator to the responder.
verbose: Displays detailed information about session entries. If you do not specify this keyword, the command displays brief information about session entries.
If you do not specify any parameters except ipv4 or ipv6, this command displays all IPv4 or IPv6 session entries that are not processed by security services.
Use display hardware internal transceiver register interface to display the content of a register area on a transceiver module.
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe view
device device-index: Specifies the index of an internal register in hexadecimal notation. The value range is 0 to FF.
address start-address: Specifies the offset of the register area to the beginning of the register, in hexadecimal notation. The value range is 0 to FFFF.
length region-length: Specifies the length of the register area in bytes, in decimal notation. The value range is 1 to 256.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H |
No |
WX2540H WX2560H |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
No |
display system internal acl
Use display system internal acl to display ACL configuration and match statistics.
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name } slot slot-number
Probe view
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type. To specify the IPv4 ACL type, do not specify the ipv6 or mac keyword.
acl-number: Specifies an ACL by its number. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
· 4000 to 4999 for Layer 2 ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
Use display system internal arp to display ARP entries that are not synchronized from other devices.
display system internal arp { all | static | dynamic } slot slot-number [ count ]
Probe view
all: Displays all ARP entries that are not synchronized from other devices.
static: Displays static ARP entries that are not synchronized from other devices.
dynamic: Displays dynamic ARP entries that are not synchronized from other devices.
count: Displays the total number of ARP entries that are not synchronized from other devices.
Use display system internal arp ifcb to display ARP control block information for a Layer 2 or Layer 3 interface.
display system internal arp ifcb interface interface-type interface-number slot slot-number
Probe view
Use display system internal arp ip-address to display the ARP entry for the specified IP address.
display system internal arp ip-address slot slot-number
Probe view
ip-address: Displays the ARP entry for the specified IP address.
Use display system internal arp machash to display machash entries.
display system internal arp machash vlan vlan-id ip ip-address slot slot-number
Probe view
vlan vlan-id: Specifies a VLAN by its ID.
ip ip-address: Specifies an IP address.
Use display system internal arp probe to display ARP probe link entries.
display system internal arp probe slot slot-number
Probe view
Use display system internal arp rbhash to display rbhash entries.
display system internal arp rbhash vlan vlan-id ip ip-address slot slot-number
Probe view
vlan vlan-id: Displays ARP rbhash entries for the specified VLAN.
ip ip-address: Displays ARP rbhash entries for the specified IP address.
Use display system internal arp reload to display ARP reload link entries.
display system internal arp reload slot slot-number
Probe view
Use display system internal arp rule to display ARP rules.
Probe view
ip ip-address: Displays the ARP rule for the specified IP address.
Use display system internal arp source-suppression cache to display ARP source suppression entries.
display system internal arp source-suppression cache slot slot-number
Probe view
Use display system internal arp statistics to display ARP statistics.
display system internal arp statistics slot slot-number
Probe view
Use display system internal arp vlan to display ARP entries for a specific VLAN.
display system internal arp vlan vlan-id slot slot-number [ count ]
Probe view
vlan vlan-id: Displays ARP entries for the specified VLAN.
count: Displays the total number of ARP entries.
Use display system internal aspf statistics to display statistics about packets dropped by ASPF and filter.
display system internal aspf statistics interface { ipv4 | ipv6 } [ slot slot-number ]
Probe view
interface: Displays dropped packet statistics for interfaces.
ipv4: Specifies IPv4 packets.
ipv6: Specifies IPv6 packets.
slot slot-number: Specifies an IRF member device by its ID. If you do not specify a member device, this command displays dropped packet statistics for all member devices.
Use display system internal attack-defense scan stat-nodes ip to display statistics of an IPv4 statistics node for scanning attack detection and prevention.
display system internal attack-defense scan stat-nodes ip [ { source | destination } [ ipv4-address [ vpn vpn-instance-name ] ] ] [ interface interface-type interface-number | local ] [ slot slot-number ] [ count ]
Probe view
source: Specifies an IPv4 statistics node based on source IPv4 address.
destination: Specifies an IPv4 statistics node based on destination IPv4 address.
ipv4-address: Specifies an IPv4 address. The IPv4 address cannot be a broadcast address, an address on subnet 127.0.0.0/8, a D-class address, or an E-class address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv4 address belongs. The MPLS L3VPN instance name is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv4 address belongs to the public network.
local: Specifies the device.
slot slot-number: Specifies an IRF member device by its member ID. This option is available only when you specify a global interface, such as a VLAN interface or tunnel interface. If you do not specify a member device, this command displays information for all member devices.
count: Displays the number of matching statistics nodes.
Use display system internal attack-defense scan stat-nodes ipv6 to display statistics of an IPv6 statistics node for scanning attack detection and prevention.
display system internal attack-defense scan stat-nodes ipv6 [ { source | destination } [ ipv6-address [ vpn vpn-instance-name ] ] ] [ interface interface-type interface-number | local ] [ slot slot-number ] [ count ]
Probe view
source: Specifies an IPv6 statistics node based on source IPv6 address.
destination: Specifies an IPv6 statistics node based on destination IPv6 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv6 address belongs. The MPLS L3VPN instance name is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv6 address belongs to the public network.
Use display system internal cloud-management state to display cloud connection state information for a module.
display system internal cloud-management state [ module module-name ]
Probe view
module module-name: Specifies a module by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a module, the command displays cloud connection state information for all modules.
Use display system internal customlog host to display kernel information about logs sent to a log host.
Probe view
index: Specifies a log host by its index in the range of 0 to 3.
cmccPortA: Specifies the port creation logs for China Mobile.
cmccPortF: Specifies the port resource insufficiency logs for China Mobile.
cmccPortW: Specifies the port deletion logs for China Mobile.
cmccSessionA: Specifies the session creation logs for China Mobile.
cmccSessionW: Specifies the session deletion logs for China Mobile.
PortA: Specifies the port creation logs for China Unicom.
PortW: Specifies the port deletion logs for China Unicom.
SessionA: Specifies the session creation logs for China Unicom.
SessionW: Specifies the session deletion logs for China Unicom.
sessionbasedA: Specifies the session creation logs for China Telecom.
sessionbasedW: Specifies the session deletion logs for China Telecom.
userbasedA: Specifies the port creation logs for China Telecom.
userbasedF: Specifies the port resource insufficiency logs for China Telecom.
userbasedW: Specifies the port deletion logs for China Telecom.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for the master device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H WX2540H WX2560H |
No |
WX3000H series |
WX3010H |
No |
WX3010H-L |
Yes |
WX3010H-X |
Yes |
WX3024H |
No |
WX3024H-L |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
Use display system internal customlog mbuf dump to display the contents of custom log packets.
display system internal customlog mbuf dump count number [ slot slot-number [ cpu cpu-number ] ]
Probe view
number: Specifies the number of customlog packets to be displayed. The value range for the number argument is 1 to 100.
slot slot-number: Specifies an IRF member ID. If you do not specify a card, this command displays the contents for the master device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
WX3010H |
No |
WX3010H-L |
Yes |
WX3010H-X |
Yes |
WX3024H |
No |
WX3024H-L |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
Use display system internal customlog mbuf usage to display the memory buffer information about the CPUs on the specified log host.
Probe view
slot slot-number: Specifies an IRF member ID. If you do not specify a card, this command displays information for the master device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
WX3010H |
No |
WX3010H-L |
Yes |
WX3010H-X |
Yes |
WX3024H |
No |
WX3024H-L |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
Use display system internal customlog test to test the custom log module and display the test results.
Probe view
number: Specifies the number of test packets to be sent. The value range for the number argument is 1 to 100.
slot slot-number: Specifies an IRF member ID. If you do not specify a card, the test is performed on the master device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
WX3010H |
No |
WX3010H-L |
Yes |
WX3010H-X |
Yes |
WX3024H |
No |
WX3024H-L |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal dbm
Use display system internal dbm to display database information.
display system internal dbm { all | name dbname [ key keyname ] } [ slot slot-number ]
Probe view
all: Specifies all databases.
name dbname: Specifies a database name.
key keyname: Specifies the name of the key for the database.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays database information for the master.
Use display system internal dot11 characteristics to display detected 802.11 characteristics information.
display system internal dot11 characteristics bss bssid slot slot-number
Probe view
bss bssid: Displays the 802.11 characteristics information detected on a BSS in both inbound and outbound directions.
Use display system internal dot11 verbose to display detailed 802.11 socket information.
display system internal dot11 verbose slot slot-number
Probe view
Use display system internal ethernet character to display the statistics and details of characteristics monitored by the Ethernet module.
display system internal ethernet character { global | interface interface-type interface-number } slot slot-number
Probe view
global: Displays the global Ethernet characteristics. The global Ethernet characteristics match all packets on a device.
The Ethernet module receives, decapsulates, sends, and encapsulates link layer packets. When an upper-layer application module (for example, STP or LLDP) needs to monitor and process protocol packets, the module performs the following operations:
· Specifies the monitoring scope (for example, packets on the specified interface or all packets on the device).
· Specifies the characteristics (for example, the specified Ethernet protocol type and the specified MAC) of the protocol packets to be monitored.
· Applies the characteristics to the Ethernet module.
The Ethernet module can match packets against the registered characteristics base during the specified phase (for example, RCV-MAC phase, RCV-LLC phase, and SND-L3IF phase). Packets matching the characteristics are processed by the current phase. Packets not matching the characteristics are processed by the next phase.
Use display system internal ethernet controlblock to display the control block information of an interface, including the link layer parameter values.
display system internal ethernet controlblock interface { interface-type interface-number } slot slot-number
Probe view
Use display system internal fsim packet filter to display FSIM packet filtering criteria.
display system internal fsim packet filter slot slot-number
Probe view
display system internal fsim statistics
Use display system internal fsim statistics to display FPGA simulator (FSIM) statistics.
display system internal fsim statistics slot slot-number
display system internal ha service
Use display system internal ha service to display HA statistics for the specified service process, including basic service registration information, control message processing statistics, and data sending and receiving statistics.
display system internal ha service socket
Probe view
socket: Specifies a service process by its socket ID. You can obtain socket IDs in the Socket field from the output of the display system internal ha service-group sg-name command.
Use display system internal ha service-group to display information about SGs registered with the HA module, including SG name, SG status, and number of SUs.
display system internal ha service-group [ name [ instance ] ]
Probe view
name: Specifies an SG by its name. If this argument is not specified, the command displays information about all SGs.
instance: Specifies an SG instance (if any).
display system internal ha statistics
Use display system internal ha statistics to display HA submodule statistics.
display system internal ha statistics { submodule { fsm | service } | summary }
Probe view
submodule: Specifies an HA submodule.
fsm: Specifies the FSM submodule.
service: Specifies the service submodule.
summary: Displays the global statistics.
display system internal ifmgr brief
Use display system internal ifmgr brief to display brief information about an interface.
display system internal ifmgr brief { para slot slot-number | help }
Probe view
para: Specifies an interface index.
help: Displays help information for valid parameters that you can specify.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L |
No |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ifmgr down
Use display system internal ifmgr down to display the down types that have been registered.
display system internal ifmgr down [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the registered down types for the master device.
display system internal ifmgr entry
Use display system internal ifmgr entry to display data structure information for an interface.
display system internal ifmgr entry { para [ slot slot-number ] | help }
Probe view
para: Specifies an interface name or index in the format of 1*Interface index or 2*Interface name.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays data structure information for interfaces on the master device.
display system internal ifmgr event
Use display system internal ifmgr event to display register information for an interface event, including the modules that have registered the event, and the types of the interfaces on which the modules have registered the event.
display system internal ifmgr event { para [ slot slot-number ] | help }
Probe view
para: Specifies an event type or interface type. If you specify both an event type and an interface type, connect them by using an asterisk (*) in the form of event*type.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays interface event register information for the master device.
display system internal ifmgr hotplug
Use display system internal ifmgr hotplug to display hotplug information for a card or subcard.
display system internal ifmgr hotplug [ [ para ] [ slot slot-number ] | help ]
Probe view
para: Specifies a slot number or both a slot number and subslot number in the form of slot-number*subslot-number. If you do not specify this argument and the help keyword, the command displays hotplug information for all cards.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays card or subcard hotplug information for the master device.
display system internal ifmgr index
Use display system internal ifmgr index to display interface index information.
display system internal ifmgr index { para [ slot slot-number ] | help }
Probe view
para: Specifies an interface index in decimal format.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays interface index information for the master device.
Use display system internal ifmgr list to display a tree structure for interfaces. The tree structure displays interfaces and subinterfaces as tree nodes, and displays the name and index of each node.
display system internal ifmgr list [ [ para ] [ slot slot-number ] | help ]
Probe view
para: Specifies an interface type. To view valid interface type values, specify the help keyword. If you do not specify this argument and the help keyword, the command displays a tree structure for all interface types.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays a tree structure of interfaces for the master device.
display system internal ifmgr name
Use display system internal ifmgr name to display a tree structure for parsing an interface name and obtaining help information. Tree structures include information such as interface indexes, interface numbers, and help information.
display system internal ifmgr name { para [ slot slot-number ] | help }
Probe view
para: Specifies the full name or abbreviated name of an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays tree structures for interfaces on the master device.
display system internal ifmgr type
Use display system internal ifmgr type to display interface type information.
display system internal ifmgr type { para [ slot slot-number | help }
Probe view
para: Specifies an interface type, a string of 1 to 127 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays interface type information for interfaces on the master device.
display system internal ike phase2-sa count
Use display system internal ike phase2-sa count to display count information about IKE phase-2 SAs.
display system internal ike phase2-sa count [ phase1-connection-id connection-id ]
Probe view
phase1-connection-id connection-id: Specifies an IKE phase-1 connection ID in the range of 1 to 2000000000.
Use the display ike sa command to display the IKE phase-1 connection IDs.
display system internal ike phase2-sa verbose
Use display system internal ike phase2-sa verbose to display detailed information about IKE phase-2 SAs.
Probe view
display system internal ike received-message count
Use display system internal ike received-message count to display count information about messages received by IKE.
display system internal ike received-message count [ verbose ipsec-doi ]
Probe view
verbose: Displays message count details.
ipsec-doi: Displays count details for messages received from the IPsec DOI.
display system internal ike sent-message count
Use display system internal ike sent-message count to display count information about messages sent by IKE.
display system internal ike sent-message count [ verbose ipsec-doi ]
Probe view
ipsec-doi: Displays count details for messages sent to the IPsec DOI.
display system internal ikev2 child-sa count
Use display system internal ikev2 child-sa count to display count information about Child SAs.
display system internal ikev2 child-sa count [ tunnel-id tunnel-id ]
Probe view
tunnel-id tunnel-id: Specifies a tunnel ID in the range of 1 to 2000000000.
Use the display ikev2 sa command to display tunnel IDs.
display system internal ip address
Use display system internal ip address to display detailed IP address information.
display system internal ip address [ ip-address | interface interface-type interface-number ] [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays detailed IP address information on the master device.
If you do not specify any parameters, this command displays detailed information about all IPv4 addresses.
display system internal ip routing-table
Use display system internal ip routing-table to display routing table information.
display system internal ip routing-table [ verbose ] standby slot slot-number
Probe view
standby slot slot-number: Displays backup routing table information for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ip routing-table acl
Use display system internal ip routing-table acl to display information about routes permitted by a basic ACL.
display system internal ip routing-table acl acl-number [ verbose ] standby slot slot-number
Probe view
acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ip routing-table ip-address
Use display system internal ip routing-table ip-address to display information about routes to a specific destination address.
Use display system internal ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
Probe view
ip-address: Specifies a destination IP address in dotted decimal notation.
mask: Specifies the subnet mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
longer-match: Displays the route entry with the longest mask.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
standby slot slot-number: Displays backup information about routes for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ip routing-table prefix-list
Use display system internal ip routing-table prefix-list to display routes permitted by an IP prefix list.
Probe view
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ip routing-table protocol
Use display system internal ip routing-table protocol to display information about routes installed by a protocol.
Probe view
protocol: Specifies a routing protocol. It can be direct or static.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
standby slot slot-number: Displays backup information about routes installed by the protocol for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ip routing-table statistics
Use display system internal ip routing-table statistics to display IPv4 route statistics.
display system internal ip routing-table statistics standby slot slot-number
Probe view
standby slot slot-number: Displays backup IPv4 route statistics for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipsec block-flow
Use display system internal ipsec block-flow to display blocked-flows table information.
display system internal ipsec block-flow slot slot-number
Probe view
The blocked-flows table helps preventing a flow from triggering a second IPsec negotiation before the triggered negotiation is complete. A table entry is deleted after the negotiation for the entry is finished, whether succeeded or failed.
display system internal ipsec received-message
Use display system internal ipsec received-message count to display the number of messages that IPsec has received from IKE.
display ipsec system internal ipsec received-message count
Probe view
display system internal ipsec sent-message
Use display system internal ipsec sent-message count to display the number of messages that IPsec has sent to IKE.
display ipsec system internal ipsec sent-message count
Probe view
display system internal ipsec sp
Use display system internal ipsec sp to display IPsec SP information.
display system internal ipsec sp { brief | sp-id sp-id slot slot-number }
Probe view
brief: Displays summary information.
sp-id sp-id: Specifies an IPsec SP its ID in the range of 0 to 4294967295.
SP information is dynamically generated by an IPsec policy.
display system internal ipv6 address
Use display system internal ipv6 address to display IPv6 address detailed information.
display system internal ipv6 address [ interface interface-type interface-number [ gateway | multicast | prefix | unicast ] ] [ ipv6-address ] [ slot slot-number ]
Probe view
gateway: Displays gateway information for the specified interface.
multicast: Displays multicast address information for the specified interface.
prefix: Displays IPv6 prefix information for the specified interface.
unicast: Displays unicast address information for the specified interface.
ipv6-address: Displays detailed information about the specified IPv6 address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 address detailed information for all member devices.
display system internal ipv6 fib prefix
Use display system internal ipv6 fib prefix to display basic information about IPv6 FIB prefixes.
display system internal ipv6 fib prefix slot slot-number
Probe view
display system internal ipv6 fib prefix entry-status
Use display system internal ipv6 fib prefix entry-status to display IPv6 FIB entries that fail to be set to the driver or that are aging.
display system internal ipv6 fib prefix entry-status status slot slot-number
Probe view
entry-status status: Specifies the status of IPv6 FIB entries. The value of the status argument can be A or F. A indicates aging FIB entries, and F indicates the FIB entries that fail to be set to the driver.
display system internal ipv6 fib prefix ipv6
Use display system internal ipv6 fib prefix to display detailed information the IPv6 FIB prefix for a specific IPv6 address.
display system internal ipv6 fib prefix ipv6 [ prefix-length ] slot slot-number
Probe view
ipv6: Specifies an IPv6 address.
prefix-length: Specifies the length of an IPv6 FIB prefix, in the range of 0 to 128.
display system internal ipv6 l2-multicast ip forwarding verbose
Use display system internal ipv6 l2-multicast ip forwarding verbose to display detailed information about IPv6 forwarding entries for Layer 2 IPv6 multicast.
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, this command displays detailed information about IPv6 forwarding entries for all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays detailed information about IPv6 forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about IPv6 forwarding entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IPv6 forwarding entries for the MPU.
display system internal ipv6 l2-multicast ip verbose
Use display system internal ipv6 l2-multicast ip verbose to display detailed information about IPv6 multicast groups for Layer 2 IPv6 multicast.
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, this command displays detailed information about all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays detailed information about IPv6 multicast groups with all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about IPv6 multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IPv6 multicast groups for the MPU.
display system internal ipv6 l2-multicast ipc statistics
Use display system internal ipv6 l2-multicast ipc statistics to display inter-process communication (IPC) statistics for Layer 2 IPv6 multicast.
display system internal ipv6 l2-multicast ipc statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPC statistics for the MPU.
display system internal ipv6 l2-multicast mac forwarding verbose
Use display system internal ipv6 l2-multicast mac forwarding verbose to display detailed information about MAC forwarding entries for Layer 2 IPv6 multicast.
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
Probe view
mac-address: Specifies a MAC multicast group. If you do not specify a MAC multicast group, this command displays detailed information about MAC forwarding entries for all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about MAC forwarding entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about MAC forwarding entries for the MPU.
display system internal ipv6 l2-multicast mac verbose
Use display system internal ipv6 l2-multicast mac verbose to display detailed information about MAC multicast groups for Layer 2 IPv6 multicast.
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
Probe view
mac-address: Specifies an IPv6 multicast MAC address. If you do not specify an IPv6 MAC multicast group, this command displays detailed information about all IPv6 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about MAC multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about MAC multicast groups for the MPU.
display system internal ipv6 multicast forwarding vlan reference
Use display system internal ipv6 multicast forwarding vlan reference to display mappings between outgoing VLAN interfaces and Layer 2 IPv6 multicast entries.
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, this command displays mappings between outgoing VLAN interfaces and Layer 2 IPv6 multicast entries for all multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays mappings between outgoing VLAN interfaces and Layer 2 IPv6 multicast entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays mappings between outgoing VLAN interfaces and Layer 2 IPv6 multicast entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays mappings between outgoing VLAN interfaces and Layer 2 IPv6 multicast entries for the MPU.
display system internal ipv6 multicast forwarding-table dummy
Use display system internal ipv6 multicast forwarding-table dummy to display temporary IPv6 multicast forwarding entries.
display system internal ipv6 multicast forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | statistics | slot slot-number ] *
Probe view
ipv6-source-address: Specifies an IPv6 multicast source address. If you do not specify an IPv6 multicast source, this command displays temporary IPv6 multicast forwarding entries for all IPv6 multicast sources.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays temporary IPv6 multicast forwarding entries for all IPv6 multicast groups.
prefix-length: Specifies an address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
statistics: Displays statistics for temporary IPv6 multicast forwarding entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays temporary IPv6 multicast forwarding entries for the MPU.
display system internal ipv6 pathmtu
Use display system internal ipv6 pathmtu to display IPv6 Path MTU information.
display system internal ipv6 pathmtu { ipv6-address | { all | dynamic | static } [ count ] } [ slot slot-number ]
Probe view
ipv6-address: Specifies an IPv6 address.
all: Displays all Path MTU information for the public network.
dynamic: Displays all dynamic Path MTU information.
static: Displays all static Path MTU information.
count: Displays the total number of Path MTU entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 Path MTU information for all member devices.
display system internal ipv6 rawip
Use display system internal ipv6 rawip to display brief information about IPv6 RawIP connections.
display system internal ipv6 rawip slot slot-number
Probe view
display system internal ipv6 rib event attribute
Use display system internal ipv6 rib event attribute to display IPv6 RIB attribute events.
Probe view
display system internal ipv6 rib event policy
Use display system internal ipv6 rib event policy to display IPv6 RIB policy events.
Probe view
display system internal ipv6 rib event protocol
Use display system internal ipv6 rib event protocol to display IPv6 RIB protocol events.
Probe view
display system internal ipv6 rib event statistics
Use display system internal ipv6 rib event statistics to display IPv6 RIB event statistics.
Probe view
display system internal ipv6 rib instance
Use display system internal ipv6 rib instance to display IPv6 RIB process information.
Probe view
display system internal ipv6 rib log
Use display system internal ipv6 rib log to display IPv6 RIB logs.
display system internal ipv6 rib log [ reverse ] [ standby slot slot-number ]
display system internal ipv6 rib event log [ standby slot slot-number ]
Probe view
rib: Displays IPv6 RIB logs.
event: Displays logs about IPv6 RIB routing changes.
reverse: Displays logs in reverse chronological order.
standby slot slot-number: Displays backup IPv6 RIB logs for an IRF member device. If you do not specify this option, the command displays IPv6 RIB logs.
display system internal ipv6 rib memory
Use display system internal ipv6 rib memory to display IPv6 RIB memory information.
Probe view
display system internal ipv6 rib nib
Use display system internal ipv6 rib nib to display next hop information in the IPv6 RIB.
display system internal ipv6 rib nib protocol protocol-name [ verbose ] standby slot slot-number
Probe view
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
nib-id: Specifies a NIB by its ID in the range of 1 to FFFFFFFF.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol-name: Specifies a protocol by its name, which can be direct6 or static6.
standby slot slot-number: Displays backup next hop information in the IPv6 RIB for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 rib nib log
Use display system internal ipv6 rib nib log to display IPv6 next hop logs.
display system internal ipv6 rib nib log [ reverse ] [ standby slot slot-number ]
Probe view
nib: Displays IPv6 next hop logs.
standby slot slot-number: Displays backup IPv6 next hop logs for an IRF member device. If you do not specify this option, the command displays IPv6 next hop logs.
display system internal ipv6 rib prefix
Use display system internal ipv6 rib prefix to display IPv6 RIB prefix information.
display system internal ipv6 rib prefix ipv6-address prefix-length [ standby slot slot-number ]
Probe view
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length of the destination IPv6 address, in the range of 0 to 128.
standby slot slot-number: Displays backup IPv6 RIB prefix information for an IRF member device. If you do not specify this option, the command displays IPv6 RIB prefix information.
display system internal ipv6 rib summary
Use display system internal ipv6 rib summary to display IPv6 RIB statistics.
display system internal ipv6 rib summary [ standby slot slot-number ]
Probe view
standby slot slot-number: Displays backup IPv6 RIB statistics of an IRF member device. If you do not specify this option, the command displays IPv6 RIB statistics.
display system internal ipv6 route-direct interface
Use display system internal ipv6 route-direct interface to display IPv6 interface information.
display system internal ipv6 route-direct interface [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
prefix-length: Specifies the prefix length of the IPv6 address, in the range of 0 to 128.
display system internal ipv6 route-static nib log
Use display system internal ipv6 route-static nib log to display IPv6 static route NIB logs.
display system internal ipv6 route-static nib log [ reverse ]
Probe view
display system internal ipv6 routing-table
Use display system internal ipv6 routing-table to display IPv6 routing table information.
display system internal ipv6 routing-table [ verbose ] standby slot slot-number
Probe view
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
standby slot slot-number: Displays backup IPv6 routing table information for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 routing-table acl
Use display system internal ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display system internal ipv6 routing-table acl acl-number [ verbose ] standby slot slot-number
Probe view
acl6-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
standby slot slot-number: Displays backup information permitted by the IPv6 basic ACL for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 routing-table ipv6-address
Use display system internal ipv6 routing-table ipv6-address to display information about routes to a specific IPv6 destination address.
Use display system internal ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
Probe view
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the route entry with the longest prefix.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
standby slot slot-number: Displays backup information about IPv6 routes for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 routing-table prefix-list
Use display system internal ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
Probe view
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
standby slot slot-number: Displays backup information about IPv6 routes permitted by the IPv6 prefix list for an IRF member device.
The following matrix shows the command and hardware compatibility:
Hardware series |
Model |
Command compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
Yes |
Access controller modules |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
Yes |
display system internal ipv6 routing-table protocol
Use display system internal ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
Probe view
protocol: Specifies a routing protocol. It can be direct6 or static6.
standby slot slot-number: Displays backup information about IPv6 routes installed by the protocol for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 routing-table statistics
Use display system internal ipv6 routing-table statistics to display IPv6 route statistics.
display system internal ipv6 routing-table statistics standby slot slot-number
Probe view
standby slot slot-number: Displays backup IPv6 route statistics for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal ipv6 tcp
Use display system internal ipv6 tcp to display brief information about IPv6 TCP connections.
display system internal ipv6 tcp slot slot-number
Probe view
display system internal ipv6 tcp port-info
Use display system internal ipv6 tcp port-info to display non-well known TCP port usage in IPv6.
display system internal ipv6 tcp port-info [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays non-well known TCP port usage for all member devices.
display system internal ipv6 tcp-proxy verbose
Use display system internal ipv6 tcp-proxy verbose to display detailed information about IPv6 TCP proxy.
display system internal ipv6 tcp-proxy verbose slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3010H WX3010H-L WX3010H-X WX3024H WX3024H-L |
Yes: · WX3010H · WX3024H No: · WX3010H-L · WX3010H-X · WX3024H-L |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes: WX5510E No: WX5540E |
WX5500H series |
No |
No |
display system internal ipv6 udp
Use display system internal ipv6 udp to display brief information about IPv6 UDP connections.
display system internal ipv6 udp slot slot-number
Probe view
display system internal ipv6 udp port-info
Use display system internal ipv6 udp port-info to display non-well known UDP port usage in IPv6.
display system internal ipv6 udp port-info [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays non-well known UDP port usage for all member devices.
display system internal kernel memory dump
Use display system internal kernel memory dump to display contents for the specified kernel memory.
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number [ cpu cpu-number ] ]
Probe view
address address-hex: Specifies the start address.
length memory-length: Specifies the memory length in bytes from the start address. The value range is 1 to 1024.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel memory contents for the master device.
cpu cpu-number: Specifies a CPU by its number.
display system internal kernel memory pool
Use display system internal kernel memory pool to display usage information for kernel memory pools.
display system internal kernel memory pool [ name name-string ] [ slot slot-number [ cpu cpu-number ] ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number [ cpu cpu-number ] ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number [ cpu cpu-number ] ]
Probe view
name name-string: Specifies a kernel memory pool by its name. If you specify only a kernel memory pool, this command displays brief usage information for the specified kernel memory pool.
tag tag-value: Specifies a kernel memory pool or kernel memory pools by a tag. If you specify only the tag keyword, this command displays brief usage information for all tagged kernel memory pools. If you specify only the tag tag-value option, this command displays brief usage information for the kernel memory pools with the specified tag.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel memory pool usage information for the master device.
If you specify neither the name option nor the tag option, this command displays brief usage information for all kernel memory pools.
If you specify both the name name-string option and the tag tag-value option, this command displays usage information for the specified kernel memory pool with the specified tag.
display system internal l2-multicast ip forwarding verbose
Use display system internal l2-multicast ip forwarding verbose to display detailed information about IP forwarding entries for Layer 2 multicast.
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays detailed information about IP multicast forwarding entries for all multicast groups.
source source-address: Specifies a multicast source address by its IP address. If you do not specify a multicast source, this command displays detailed information about IP multicast forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about IP multicast forwarding entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IP multicast forwarding entries for the MPU.
display system internal l2-multicast ip verbose
Use display system internal l2-multicast ip verbose to display detailed information about IP multicast groups for Layer 2 multicast.
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays detailed information about all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays detailed information about multicast groups with all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays detailed information about multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about multicast groups for the MPU.
display system internal l2-multicast ipc statistics
Use display system internal l2-multicast ipc statistics to display IPC statistics for Layer 2 multicast.
display system internal l2-multicast ipc statistics [ slot slot-number ]
Probe view
display system internal l2-multicast mac forwarding verbose
Use display system internal l2-multicast mac forwarding verbose to display detailed information about MAC forwarding entries for Layer 2 multicast.
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
Probe view
mac-address: Specifies a multicast MAC address. If you do not specify a MAC multicast group, this command displays detailed information about MAC forwarding entries for all MAC multicast groups.
display system internal l2-multicast mac verbose
Use display system internal l2-multicast mac verbose to display detailed information about MAC multicast groups for Layer 2 multicast.
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
Probe view
mac-address: Specifies a multicast MAC address. If you do not specify a MAC multicast group, this command displays detailed information about all MAC multicast groups.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about the MAC multicast groups for the MPU.
display system internal license buffer-data
Use display system internal license buffer-data to display buffered license data.
display system internal license buffer-data slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal license feature-set
Use display system internal license feature-set to display information about supported feature sets.
display system internal license feature-set slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal license fifo
Use display system internal license fifo to display information about FIFO pipes used by licenses.
display system internal license fifo slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal license lipc
Use display system internal license lipc to display LIPC information for license registration. License LIPC is used for the communication between the license module and the LIPC module.
display system internal license lipc slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal license lipc hash
Use display system internal license lipc hash to display LIPC information in the hash list for license registration.
display system internal license lipc hash slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal license lmi-paa
Use display system internal license lmi-paa to display license manage item (LMI) information and product ability aggregate (PAA) information.
display system internal license lmi-paa slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
display system internal link-aggregation global
Use display system internal link-aggregation global to display the global information about the Ethernet link aggregation module.
display system internal link-aggregation slot slot-number global
Probe view
display system internal link-aggregation interface
Use display system internal link-aggregation interface to display aggregate interface information.
display system internal link-aggregation slot slot-number interface bridge-aggregation interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe view
bridge-aggregation: Displays information about Layer 2 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
kernel: Displays kernel information.
statistics: Displays statistic information.
ipv4: Displays IPv4 packet statistics.
ipv6: Displays IPv6 packet statistics.
lacp: Displays dynamic aggregation information.
lacppdu: Displays statistics for LACPDUs.
If you do not specify any of the kernel, lacp, lacppdu, and statistics keywords, the command displays the interface information in the main thread.
If you specify the statistics keyword without specifying the ipv4 or ipv6 keyword, the command displays statistics about all packets.
Part of the information that is displayed overlaps because the information is saved in separate threads. You can use the overlapping information for problem location and analysis.
display system internal lipc dump
Use display system internal lipc dump to display LIPC dumps.
display system internal lipc dump [ lip lip ]
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays LIPC dumps for the node where the global active MPU resides.
display system internal lipc dump configuration
Use display system internal lipc dump configuration to display LIPC dumping rules.
display system internal lipc dump configuration [ lip lip ]
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays LIPC dumping rules for the node where the global active MPU resides.
display system internal lipc history
Use display system internal lipc history to display LIPC history traffic statistics in chart.
Probe view
mtcp: Specifies the LIPC MTCP module.
publish: Specifies the LIPC publish module.
stcp: Specifies the LIPC STCP module.
recv: Specifies received packets.
send: Specifies sent packets.
by-min: Displays LIPC history traffic statistics for last 30 minutes.
by-sec: Displays LIPC history traffic statistics for last 30 seconds.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify any remote node, the command displays LIPC history traffic statistics for the node where the global active MPU resides.
If you do not specify the mtcp, publish, or stcp keyword, the command displays LIPC history traffic statistics for the MTCP, publish, and STCP modules.
display system internal lipc lcmp statistics
Use display system internal lipc lcmp statistics to display global statistics for the LIPC LCMP module, including the count of sent and received packets and the count of errors.
display system internal lipc lcmp statistics [ lip lip ]
This command displays global statistics for the LIPC LCMP module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for the LIPC LCMP module on the node where the global active MPU resides.
display system internal lipc lgmp group
Use display system internal lipc lgmp group to display information about a multicast group, including member host information and related statistics.
display system internal lipc lgmp group groupID [ lip lip ]
This command displays information about a multicast group at the local node.
Probe view
group groupID: Specifies a multicast group by its ID in the range of 0 to 4294967295.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about a multicast group for the node where the global active MPU resides.
display system internal lipc lgmp group-list
Use display system internal lipc lgmp group-list to display the total number of created multicast groups, numbers of multicast member ports, and HASH information.
display system internal lipc lgmp group-list [ lip lip ]
This command displays the total number of created multicast groups, numbers of multicast member ports, and HASH information at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command applies to the node where the global active MPU resides.
display system internal lipc lgmp physical-group
Use display system internal lipc lgmp physical-group to display information about a hardware multicast group.
display system internal lipc lgmp physical-group phyID [ lip lip ]
This command displays information about a hardware multicast group at the local node.
Probe view
physical-group phyID: Specifies a hardware multicast group by its ID in the range of 0 to 4294967295.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about a hardware multicast group for the node where the global active MPU resides.
display system internal lipc lgmp physical-group-list
Use display system internal lipc lgmp physical-group-list to display information about all hardware multicast groups.
display system internal lipc lgmp physical-group-list [ lip lip ]
This command displays information about all hardware multicast groups at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about all hardware multicast groups for the node where the global active MPU resides.
display system internal lipc lgmp statistics
Use display system internal lipc lgmp statistics to display statistics for the LIPC LGMP module.
display system internal lipc lgmp statistics [ lip lip ]
This command displays statistics for the LIPC LGMP module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays statistics for the LIPC LGMP module on the node where the global active MPU resides.
display system internal lipc lip statistics
Use display system internal lipc lip statistics to display global statistics for the LIPC LIP module, including the count of sent and received LIP packets and the count of errors.
display system internal lipc lip statistics [ lip lip ]
This command displays global statistics for the LIPC LIP module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for the LIPC LIP module on the node where the global active MPU resides.
display system internal lipc loop statistics
Use display system internal lipc loop statistics to display statistics for local loops.
display system internal lipc loop statistics [ lip lip ]
This command display statistics for local loops.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays local loop statistics for the node where the global active MPU resides.
display system internal lipc mtcp group
Use display system internal lipc mtcp group to display member information, statistics, or state machine history for an LIPC multicast group.
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
This command displays member information, statistics, or state machine history for an LIPC multicast group at the local node.
Probe view
portID: Specifies a multicast group by its port ID in the range of 0 to 4294967295.
history: Specifies state machine history.
member: Specifies member information.
statistics: Specifies statistics.
display system internal lipc mtcp group all
Use display system internal lipc mtcp group all to display statistics for the multicast groups that contain a node.
display system internal lipc mtcp group all [ lip lip ]
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays statistics for the multicast groups that contain the node where the global active MPU resides.
display system internal lipc mtcp performance
Use display system internal lipc mtcp performance to display information about LIPC multicast performance.
display system internal lipc mtcp performance [ lip lip ]
This command displays information about LIPC multicast performance at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about LIPC multicast performance for the node where the global active MPU resides.
Before you use this command, you must first enable performance statistics for LIPC multicast connections by using the lipc performance command.
display system internal lipc mtcp statistics
Use display system internal lipc mtcp statistics to display global statistics for LIPC multicast connections.
display system internal lipc mtcp statistics [ lip lip ]
This command displays global statistics for LIPC multicast connections at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for LIPC multicast connections on the node where the global active MPU resides.
display system internal lipc pcb mbuf statistics
display system internal lipc pcb mbuf statistics [ lip lip ]
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify any remote node, the command displays MBUF usage information for the LIPC PCB module at the local node. If you do not specify a remote node, the command displays MBUF usage information for the LIPC PCB module on the node where the global active MPU resides.
display system internal lipc pcb statistics
Use display system internal lipc pcb statistics to display global statistics for the LIPC PCB module.
display system internal lipc pcb statistics [ lip lip ]
This command displays global statistics for the LIPC PCB module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for the LIPC PCB module on the node where the global active MPU resides.
display system internal lipc physical
Use display system internal lipc physical to display global statistics for the driver adaptation layer.
display system internal lipc physical [ lip lip ]
This command displays global statistics for the driver adaptation layer at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays statistics for the driver adaptation layer on the node where the global active MPU resides.
Usage guideline
This command collects information exchanged between the LIPC module and the driver. The information includes the count of sent and received packets, the count of driver errors, and the count of events reported by the driver.
display system internal lipc publish global-cb
Use display system internal lipc publish global-cb to display information about the global control block of the LIPC PUBLISH module.
display system internal lipc publish global-cb [ lip lip ]
This command displays information about the global control block of the LIPC publish module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global control block information for the LIPC publish module on the node where the global active MPU resides.
You can use this command to examine whether the publish module at a node encounters an out-of-order problem.
display system internal lipc publish statistics
Use display system internal lipc publish statistics to display statistics for the LIPC publish module.
display system internal lipc publish statistics [ lip lip ]
This command displays statistics for the LIPC publish module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays statistics for the LIPC publish module on the node where the global active MPU resides.
display system internal lipc stcp event
Use display system internal lipc stcp event to display information about LIPC unicast events.
display system internal lipc stcp event { sync | trans } [ lip lip ]
This command displays information about LIPC unicast events for the local node.
Probe view
sync: Specifies LIPC unicast control packet events.
trans: Specifies LIPC unicast data packet events.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about LIPC unicast events for the node where the global active MPU resides.
This command displays information about LIPC unicast events, including connection, DACK, destruction, and time sequence exchange. If the number of records reaches 512, the oldest records are replaced by new ones. For this reason, when you find a problem with LIPC unicast, use this command as early as possible.
display system internal lipc stcp global-server
Use display system internal lipc stcp global-server to display information about the global well-known ports for LIPC unicast.
display system internal lipc stcp global-server [ lip lip ]
This command displays information about the global well-known ports for LIPC unicast at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global well-known port information for LIPC unicast on the node where the global active MPU resides.
display system internal lipc stcp links
Use display system internal lipc stcp links to display information about LIPC unicast connections, including received and transmitted packet information, state information, and buffer information.
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
This command displays information about LIPC unicast connections at the local node.
Probe view
all: Specifies all unicast connections.
detail port: Specifies a port by its number in the range of 0 to 65535.
global gport: Specifies a global well-known port by its number in the range of 100 to 8100.
listening: Specifies the connections in listening state.
local lport: Specifies a local port by its number in the range of 10100 to 65535.
singledetail lport rport: Specifies a local port number and a remote port number. The value range for the port numbers is 0 to 65535.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about LIPC unicast connections for the node where the global active MPU resides.
display system internal lipc stcp performance
Use display system internal lipc stcp performance to display information about LIPC unicast performance.
display system internal lipc stcp performance [ lip lip ]
This command displays information about LIPC unicast performance for the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays LIPC unicast performance information for the node where the global active MPU resides.
Before you use this command, you must first enable performance statistics for LIPC unicast or multicast by using the lipc performance command.
lipc performance
display system internal lipc stcp port
Use display system internal lipc stcp port to display operation statistics for LIPC unicast well-known ports.
Probe view
close: Specifies operations of closing links.
connect: Specifies operations of establishing links.
get-port: Specifies operations of requesting global well-known port information.
half-close: Specifies operations of half-closing links.
recv-get-port: Specifies operations of receiving requests for global well-known port information.
resend: Specifies operations of resending packets.
send: Specifies operations of sending packets.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays operation statistics for LIPC unicast well-known ports on the node where the global active MPU resides.
display system internal lipc stcp statistics
Use display system internal lipc stcp statistics to display global statistics for LIPC unicast connections.
display system internal lipc stcp statistics [ lip lip ]
This command displays statistics for LIPC unicast at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for LIPC unicast connections on the node where the global active MPU resides.
You can use this command to analyze LIPC unicast operations.
display system internal lipc stcp status
Use display system internal lipc stcp status to display unicast transmission state information.
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe view
recv: Specifies the receiving end.
send: Specifies the sending end.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays unicast transmission state information for the node where the global active MPU resides.
This command records the sequence numbers, ACK sequence numbers, send flags, and receive flags of the unicast packets. You can use this command to analyze transmission reliability of unicast packets.
display system internal lipc stream
Use display system internal lipc stream to display information about LIPC unicast streams.
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
This command displays information about LIPC unicast streams at the local node.
Probe view
ack: Specifies the received ACK messages.
reass: Specifies the reassembled streams.
send: Specifies the sent streams.
port portID: Specifies a port by its port number in the range of 0 to 65535.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about LIPC unicast streams for the node where the global active MPU resides.
display system internal lipc sudp pcb-info
Use display system internal lipc sudp pcb-info to display the detailed PCB information for the SUDP module.
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
This command displays the detailed PCB information of the SUDP module at the local node.
Probe view
all-port: Specifies all ports.
global-port: Specifies all global well-known ports.
local-port: Specifies the local well-known ports.
specific-port portID: Specifies a port number in the range of 0 to 65535.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays the detailed PCB information for the SUDP module on the node where the global active MPU resides.
display system internal lipc sudp statistics
Use display system internal lipc sudp statistics to display global statistics for the LIPC SUDP module.
display system internal lipc sudp statistics [ lip lip ]
This command displays global statistics for the LIPC SUDP module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for the LIPC SUDP module on the node where the global active MPU resides.
display system internal lipc sudp { global-port | local-port }
Use display system internal lipc sudp to display information about all SUDP global well-known ports or local ports.
display system internal lipc sudp { global-port | local-port } [ lip lip ]
This command display information about all SUDP global well-known ports or local ports at the local node.
Probe view
global-port: Specifies all SUDP global well-known ports.
local-port: Specifies all SUDP local ports.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about all SUDP global well-known ports or local ports for the node where the global active MPU resides.
display system internal lipc topology history
Use display system internal lipc topology history to display the change history of LIPC topology links.
display system internal lipc topology history [ lip lip ]
This command displays the change history of LIPC topology links at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays the change history of LIPC topology links for the node where the global active MPU resides.
display system internal lipc topology link
Use display system internal lipc topology link to display information about LIPC topology links.
display system internal lipc topology link [ lip lip ]
This command displays information about LIPC topology links at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays information about LIPC topology links for the node where the global active MPU resides.
display system internal lipc topology node
Use display system internal lipc topology node to display statistics for LIPC topology nodes.
display system internal lipc topology node nodeID [ lip lip ]
This command displays statistics for topology nodes related to the local node.
Probe view
node nodeID: Specifies a node by its ID in the range of 0 to 65535.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays statistics for LIPC topology nodes on the node where the global active MPU resides.
This command records the total number of topology events that occurred on the specified node, and the time that latest six events took place (with a precision to 0.1 milliseconds).
display system internal lipc topology process-time
Use display system internal lipc topology process-time to display the time spent in notifying each module when topology events occur.
display system internal lipc topology process-time [ lip lip ]
This command displays the time spent in notifying each module when topology events occur at the local node.
Probe view
display system internal lipc topology statistics
Use display system internal lipc topology statistics to display global statistics for the LIPC topology.
display system internal lipc topology statistics [ lip lip ]
This command displays global statistics about topology at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays global statistics for the LIPC topology on the node where the global active MPU resides.
This command records the total number of global topology events, and the time that latest six events took place (with a precision to 0.1 milliseconds).
display system internal lipc topology status
Use display system internal lipc topology status to display topology status.
display system internal lipc topology status [ lip lip ]
This command displays topology status at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays topology status for the node where the global active MPU resides.
display system internal lps
Use display system internal lps to display Linux Packet Socket (LPS) information.
display system internal lps [ slot slot-number ]
Probe view
lps: Displays LPS information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays LPS information for all member devices.
display system internal mac-address configuration
Use display system internal mac-address configuration to display MAC address table configuration information.
display system internal mac-address configuration { blackhole | static } [ count ] slot slot-number
Probe view
blackhole: Displays blackhole MAC address entries.
static: Displays static MAC address entries.
count: Displays the total number of MAC address entries that match all entry attributes you specify in the command. If you do not specify an entry attribute, the command displays the total number of entries in the MAC address table. If you do not specify this keyword, the command displays detailed information about specified MAC address entries.
display system internal mac-address learned
Use display system internal mac-address learned to display dynamic MAC address entries.
Probe view
mac-address: Specifies a MAC address in the format of H-H-H. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
count: Displays only the number of dynamic MAC address entries that match all entry attributes you specify in the command. Detailed information about dynamic MAC address entries is not displayed. If you do not specify this keyword, the command displays detailed information about the specified dynamic MAC address entries.
display system internal mac-address protocol
Use display system internal mac-address protocol to display feature-specific MAC address entries or VLAN interface-based MAC address entries.
Probe view
auth: Displays MAC address entries for MAC authentication.
client: Displays MAC address entries for online users. In the current software version, this command displays MAC address entries only for wireless online users.
dot1x: Displays MAC address entries for 802.1X.
security: Displays secure MAC address entries for port security.
vlan-interface: Displays MAC address entries on VLAN interfaces.
count: Displays only the number of MAC address entries that match all entry attributes you specify in the command. Detailed information about MAC address entries is not displayed. If you do not specify this keyword, the command displays detailed information about the specified MAC address entries.
display system internal mac-address statistics
Use display system internal mac-address statistics to display MAC address table statistics.
display system internal mac-address statistics slot slot-number
Probe view
display system internal mac-forwarding cache ip verbose
display system internal mac-forwarding cache ip [ ip-address ] verbose [ slot slot-number ]
Probe view
display system internal mac-forwarding cache ipv6 verbose
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose [ slot slot-number ]
Probe view
display system internal mac-forwarding controlblock
Use display system internal mac-forwarding controlblock to display the interface control information of Layer 2 forwarding.
display system internal mac-forwarding controlblock interface interface-type interface-number slot slot-number
Probe view
display system internal mbuf relay statistics
Use display system internal mbuf relay statistics to display MBUF Relay statistics.
display system internal mbuf relay statistics slot slot-number [ vcpu vcpu-number ] [ rcv receiver-id ]
Probe view
vcpu vcpu-number: Specifies a vCPU by its number. If you do not specify a vCPU, this command displays MBUF Relay statistics for all vCPUs on the card.
The following matrix shows the value ranges for the vcpu vcpu-number option:
Hardware series |
Model |
Value range |
WX1800H series |
0 |
WX2500H series |
WX2510H WX2540H WX2560H |
0 |
WX3000H series |
0 |
WX3500H series |
· 0 to 7 for the WX3508H · 0 to 15 for the WX3510H/WX3520H/WX3520H-F/WX3540H |
WX5500E series |
WX5510E WX5540E |
0 to 31 |
WX5500H series |
0 to 31 |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX20RT LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX40RT |
0 to 31 |
rcv received-id: Specifies the MBUF Relay receiver by its ID. The value is in the range of 0 t o 127. If you do not specify an MBUF Relay receiver, this command displays MBUF Relay statistics for all the receivers on the CPU.
display system internal multicast capability
Use display system internal multicast capability to display multicast capability.
display system internal multicast capability [ slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays multicast capability for the MPU.
display system internal multicast forwarding vlan reference
Use display system internal multicast forwarding vlan reference to display mappings between outgoing VLAN interfaces and Layer 2 multicast entries.
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
Probe view
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays mappings between outgoing VLAN interfaces and all multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for the MPU.
display system internal multicast forwarding-table dummy
Use display system internal multicast forwarding-table dummy to display temporary multicast forwarding entries.
display system internal multicast forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | statistics | slot slot-number ] *
Probe view
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays temporary multicast forwarding entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays temporary multicast forwarding entries for all multicast sources.
mask-length: Specifies an address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
statistics: Displays statistics for temporary multicast forwarding entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays temporary multicast forwarding entries for the MPU.
display system internal multicast record
Use display system internal multicast record to display operation records about multicast entries.
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-data-group | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ slot slot-number ]
Probe view
statistics: Displays statistics for operation records.
all: Specifies all operation records.
fail: Specifies failed operation records.
group-address: Specifies a multicast group address.
ipv6-group-address: Specifies an IPv6 multicast group address.
source-address: Specifies a multicast source address.
item item-list: Specifies one or more records. To display one record, set the value of the item-list argument to 1. To display more records, use the form start-item [ to end-item ]. The value ranges for the start-item argument and the end-item argument are 1 to 500000.
filter: Specifies the operation records in the specified filtering mode.
exclude: Specifies the operation records that do not meet the specified criteria.
include: Specifies the operation records that meet the specified criteria.
add-l2-ip: Specifies the operation records of adding Layer 2 IP multicast entries.
add-l2-ip-port: Specifies the operation records of adding ports to Layer 2 IP multicast entries.
add-l2-ip-slot: Specifies the operation records of adding cards to Layer 2 IP multicast entries.
add-l2-mac: Specifies the operation records of adding Layer 2 MAC multicast entries.
add-l2-mac-port: Specifies the operation records of adding ports to Layer 2 MAC multicast entries.
add-l2-mac-slot: Specifies the operation records of adding cards to Layer 2 MAC multicast entries.
add-l3-ipm: Specifies the operation records of adding Layer 3 multicast entries.
add-l3-oif: Specifies the operation records of adding outgoing interfaces to Layer 3 multicast entries.
add-l3-port: Specifies the operation records of adding outgoing ports to Layer 3 multicast entries.
add-l3-slot: Specifies the operation records of adding distributed forwarding cards where outgoing interfaces reside to Layer 3 multicast entries.
del-l2-ip: Specifies the operation records of deleting Layer 2 IP multicast entries.
del-l2-ip-port: Specifies the operation records of deleting ports from Layer 2 IP multicast entries.
del-l2-ip-slot: Specifies the operation records of deleting cards from Layer 2 IP entries.
del-l2-mac: Specifies the operation records of deleting Layer 2 MAC multicast entries.
del-l2-mac-port: Specifies the operation records of deleting ports from Layer 2 MAC multicast entries.
del-l2-mac-slot: Specifies the operation records of deleting cards from Layer 2 MAC entries.
del-l3-ipm: Specifies the operation records of deleting Layer 3 IP multicast entries.
del-l3-oif: Specifies the operation records of deleting outgoing interfaces from Layer 3 multicast entries.
del-l3-port: Specifies the operation records of deleting outgoing ports from Layer 3 multicast entries.
del-l3-slot: Specifies the operation records of removing distributed forwarding cards where outgoing interfaces reside from Layer 3 multicast entries.
set-l3-data-group: Specifies the operation records of setting data-group addresses for Layer 3 multicast entries.
set-l3-iif: Specifies the operation records of setting incoming interfaces for Layer 3 multicast entries.
ipmc-type-all: Specifies all types of operation records.
verbose: Displays detailed information. If the outgoing interface and outgoing port in the record are not complete, you need to specify this keyword.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays operation records about multicast entries for the MPU.
display system internal nat
Use display system internal nat to display the NAT configuration in the kernel.
display system internal nat slot slot-number
Probe view
display system internal nat aging-queue
Use display system internal nat aging-queue to display NAT aging queue statistics.
display system internal nat aging-queue { nopat | portblock } [ slot slot-number ] [ verbose ]
Probe view
nopat: Displays aging queue statistics about NO-PAT entries.
portblock: Displyas statistics for the backup port block entries cached in the aging queue when the configuration for port block entires does not exist.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays NAT aging queue statistics for all cards.
verbose: Displays detailed information about NAT aging queue statistics. If you do not specify this keyword, the command displays the number of NAT entries in the aging queue.
display system internal nat statistics
Use display system internal nat statistics to display NAT statistics.
display system internal nat statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays NAT statistics for all member devices.
When packet loss occurs in your network where NAT service is configured, you can use this command to check if the packet loss is caused by NAT service.
display system internal nd dad
Use display system internal nd dad to display DAD link information.
display system internal nd dad slot slot-number
Probe view
display system internal nd entry
Use display system internal nd entry to display ND entries.
display system internal nd entry slot slot-number
Probe view
display system internal nd ifcb
Use display system internal nd ifcb to display ND control block information for an interface.
display system internal nd ifcb interface interface-type interface-number slot slot-number
Probe view
display system internal nd machash
Use display system internal nd machash to display ND machash entries.
display system internal nd machash vlan vlan-id ipv6-address slot slot-number
Probe view
vlan vlan-id: Displays ND machash entries for the specified VLAN.
ip-address: Displays ND machash entries for the specified IP address.
display system internal nd probe
Use display system internal nd probe to display ND probe link information.
display system internal nd probe slot slot-number
Probe view
display system internal nd rbhash
Use display system internal nd rbhash to display information about the rbhash entries on a card.
display system internal nd rbhash vlan vlan-id ipv6-address slot slot-number
Probe view
vlan vlan-id: Specifies a VLAN by its ID.
ipv6-address: Specifies an IPv6 address.
display system internal nd reload
Use display system internal nd reload to display ND reload link information.
display system internal nd reload slot slot-number
Probe view
display system internal nd rule
Use display system internal nd rule to display ND rule information.
Probe view
all: Displays information about all ND rules.
display system internal nd static
Use display system internal nd static to display static ND entries.
display system internal nd static ipv6-address interface interface-type interface-number
Probe view
ipv6-address: Displays static ND entries for a specified IPv6 address.
display system internal nd statistics
Use display system internal nd statistics to display ND statistics.
display system internal nd statistics slot slot-number
Probe view
display system internal portal ap-statistics
Use display system internal portal ap-statistics to display statistics for portal-related messages between the AC and APs in local forwarding mode.
Probe view
display system internal portal process
Use display system internal portal process to display information about the portal process.
Probe view
display system internal portal statistics
Use display system internal portal statistics to display dynamic statistics for the portal process.
Probe view
display system internal ppp statistics
Use display system internal ppp statistics to display PPP statistics.
display system internal ppp statistics { aggregation | all | interface-event } [ slot slot-number ]
Probe view
aggregation: Displays PPP aggregation statistics.
all: Displays all PPP statistics.
interface-event: Displays PPP interface event statistics.
slot slot-number: Specifies an IRF member device by its ID.
You can use this command on both the master and the backup devices.
display system internal pppoe-server statistics
Use display system internal pppoe-server statistics to display PPPoE server statistics.
display system internal pppoe-server statistics aggregation [ slot slot-number ]
Probe view
aggregation: Displays PPPoE server aggregation statistics.
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
No |
WX3000H series |
WX3010H-X WX3010H-L WX3024H-L |
No |
WX3500H series |
No |
WX5000E series |
WX5510E WX5540E |
No |
WX5500H series |
No |
Yes |
display system internal process state
Use display system internal process state to display service operating status information.
display system internal process state [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for the master device.
display system internal rawip
Use display system internal rawip to display brief information about RawIP connections.
display system internal rawip slot slot-number
Probe view
display system internal rib event attribute
Use display system internal rib event attribute to display IPv4 RIB attribute events.
Probe view
display system internal rib event policy
Use display system internal rib event policy to display IPv4 RIB policy events.
Probe view
display system internal rib event prefix
Use display system internal rib event prefix to display IPv4 RIB prefix events.
Probe view
display system internal rib event protocol
Use display system internal rib event protocol to display IPv4 RIB protocol events.
Probe view
display system internal rib event statistics
Use display system internal rib event statistics to display RIB event statistics.
Probe view
display system internal rib instance
Use display system internal rib instance to display RIB process information.
Probe view
display system internal rib log
Use display system internal rib log to display RIB logs.
Distributed devices–Centralized IRF devices–In standalone mode:
display system internal rib log [ reverse ] [ standby slot slot-number ]
display system internal rib event log [ standby slot slot-number ]
Probe view
rib: Displays RIB logs.
event: Displays logs about RIB routing changes.
reverse: Displays logs in reverse chronological order.
standby slot slot-number: Displays backup RIB logs for an IRF member device. If you do not specify this option, the command displays RIB logs.
display system internal rib memory
Use display system internal rib memory to display RIB memory information.
Probe view
display system internal rib nib
Use display system internal rib nib to display next hop information in the RIB.
display system internal rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number
display system internal rib nib protocol protocol-name [ verbose ] standby slot slot-number
Probe view
self-originated: Displays information about next hops of self-originated routes in the RIB.
nib-id: Specifies a NIB by its ID in the range of 1 to FFFFFFFF.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
protocol protocol-name: Specifies a protocol by its name, which can be direct or static.
standby slot slot-number: Displays backup next hop information in the RIB for an IRF member device.
display system internal rib nib log
Use display system internal rib nib log to display next hop logs.
display system internal rib nib log [ reverse ] [ standby slot slot-number ]
Probe view
nib: Displays next hop logs.
standby slot slot-number: Displays backup next hop logs for an IRF member device. If you do not specify this option, the command displays next hop logs.
display system internal rib prefix
Use display system internal rib prefix to display RIB prefix information.
display system internal rib prefix ip-address mask-length [ standby slot slot-number ]
Probe view
ip-address: Specifies the destination IP address.
mask-length: Specifies the mask length of the IP address, in the range of 0 to 32.
standby slot slot-number: Displays backup RIB prefix information for an IRF member device. If you do not specify this option, the command displays RIB prefix information.
display system internal rib summary
Use display system internal rib summary to display RIB statistics.
display system internal rib summary [ standby slot slot-number ]
Probe view
standby slot slot-number: Displays backup RIB statistics of an IRF member device. If you do not specify this option, the command displays RIB statistics.
display system internal route-direct interface
Use display system internal route-direct interface to display interface information.
display system internal route-direct interface [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe view
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies the subnet mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
display system internal route-static nib log
Use display system internal route-static nib log to display static route NIB logs.
display system internal route-static nib log [ reverse ]
Probe view
display system internal session
Use display system internal session to display session configuration information.
display system internal session [ slot slot-number ] [ verbose | interface [ interface-type interface-number ] ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays session configuration information for all member devices.
verbose: Displays detailed information about session configuration. If you do not specify this keyword, the command displays brief information about session configuration.
interface interface-type interface-number: Specifies a port by its number and type. If you do not specify a port, this command displays session configuration information for all ports.
display system internal session aging-queue
Use display system internal session aging-queue to display session aging queue statistics.
display system internal session aging-queue [ { ipv4 | ipv6 } hot-backup-relation | relation ] [ slot slot-number [ core core-number ] ] [ verbose ]
Probe view
ipv4: Specifies IPv4 hot-backup relation entries.
ipv6: Specifies IPv6 hot-backup relation entries.
hotback-relation: Specifies hot-backup relation entries.
relation: Specifies relation entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays session aging queue statistics for all member devices.
core core-number: Specifies a CPU core by its core number.
verbose: Displays detailed information about session aging queue statistics. If you do not specify this keyword, the command displays only the number of relation entries of the session aging queue.
If you do not specify any parameters, this command displays aging queue statistics for session entries.
display system internal session alg-exception
Use display system internal session alg-exception to display ALG statistics about abnormal packets.
display system internal session alg-exception [ slot slot-number ] [ acl acl-number ] [ application { ftp | gtp | h225 | h245 | ils | mgcp | nbdgm | nbns | nbss | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ALG statistics about abnormal packets for all member devices.
acl acl-number: Specifies an ACL by its number in the range of 2000 and 3999.
ftp: Specifies the FTP protocol.
gtp: Specifies the GPRS Tunneling Protocol (GTP) protocol.
h225: Specifies the H.225 protocol.
h245: Specifies the H.245 protocol.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP) protocol.
nbns: Specifies the NetBIOS over TCP/IP (nbns/NBT) protocol.
nbss: Specifies the NetBIOS over TCP/IP (nbss/NBT) protocol.
ngdgm: Specifies the NetBIOS over TCP/IP (nbdgm/NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP) protocol.
ras: Specifies the RAS protocol.
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP) protocol.
sccp: Specifies the Skinny Client Control Protocol (SCCP) protocol.
sip: Specifies the Session Initiation Protocol (SIP) protocol.
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP) protocol.
display system internal session relation-table ipv4
Use display system internal session relation-table ipv4 to display information about IPv4 relation entries that match specific criteria.
display system internal session relation-table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
source-ip source-ip: Specifies a source IPv4 address from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address from the initiator to the responder.
display system internal session relation-table ipv6
Use display system internal session relation-table ipv6 to display information about IPv6 relation entries that match specific criteria.
display system internal session relation-table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe view
source-ip source-ip: Specifies a source IPv6 address from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address from the initiator to the responder.
display system internal session statistics
Use display system internal session statistics to display abnormal packet statistics for sessions.
display system internal session statistics { ipv4 | ipv6 } [ slot slot-number ]
Probe view
ipv4: Displays abnormal packet statistics for IPv4 sessions.
ipv6: Displays abnormal packet statistics for IPv6 sessions.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays abnormal packet statistics for all member devices.
display system internal session table ipv4
Use display system internal session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
display system internal session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe view
source-ip source-ip: Specifies a source IPv4 address for a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session from the initiator to the responder.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
display system internal session table ipv6
Use display system internal session table ipv6 to display information about IPv6 unicast session entries that match specific criteria.
display system internal session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe view
source-ip source-ip: Specifies a source IPv6 address for a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session from the initiator to the responder.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
display system internal startup cache
Use display system internal startup cache to display the file path of the .mdb binary configuration file used at the current startup.
Probe view
When you use the save command to save the running configuration, the device automatically saves the running configuration to both an .mdb binary file and a .cfg text file. The two files use the same file name.
At startup, the device uses the following workflow to identify and load a configuration file:
1. The device searches for a valid .cfg next-startup configuration file.
2. If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3. If a matching .mdb file is found, the device starts up with the .mdb file. If this file does not exist, the device starts up with the .cfg file.
The device loads an .mdb file faster than it loads a .cfg file.
This command displays None if the loaded configuration file is a .cfg file.
display system internal stp bridge-info
Use display system internal stp bridge-info to display bridge configuration for an instance.
display system internal stp bridge-info instance instance-id slot slot-number
Probe view
instance instance-id: Specifies an MSTI ID in the range of 0 to 4094, where 0 represents the common root bridge (CIST).
display system internal stp port-info
Use display system internal stp port-info to display the configuration and running status of an interface in the specified instance.
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe view
instance instance-id: Specifies an MSTI ID in the range of 0 to 4094, where 0 represents the CIST.
interface interface-type interface-number: Specifies an interface. The interface-type argument represents the interface type. The interface-number argument represents the interface number.
display system internal tcp
Use display system internal tcp to display brief information about TCP connections.
display system internal tcp slot slot-number
Probe view
display system internal tcp port-info
Use display system internal tcp port-info to display non-well known TCP port usage.
display system internal tcp port-info [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays non-well known TCP port usage for all member devices.
display system internal tcp-proxy statistics
Use display system internal tcp-proxy statistics to display TCP proxy statistics about IPv4 and IPv6 TCP connections.
Probe view
all: Displays all TCP proxy statistics.
api: Displays statistics about API calls.
error: Displays statistics about error packets.
fsm: Displays statistics about finite state machine (FSM) packets.
packet: Displays statistics about input and output TCP packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays TCP proxy statistics for all member devices.
The following matrix shows the command and hardware compatibility:
Hardware series |
Model |
Command compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3010H WX3010H-L WX3010H-X WX3024H WX3024H-L |
Yes: · WX3010H · WX3024H No: · WX3010H-L · WX3010H-X · WX3024H-L |
WX3500H |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes: WX5510E No: WX5540E |
WX5500H series |
WX5540H WX5560H WX5580H |
No |
Access controller modules |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
No |
display system internal tcp-proxy statistics { all | api | error | fsm | packet } [ slot slot-number ]
Probe view
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes: WX5540H No: · WX5560H · WX5580H |
Yes: · EWPXM1WCME0 · LSUM1WCME0 No: · EWPXM1MAC0F · EWPXM2WCMD0F · LSQM1WCMX20 · LSQM1WCMX40 · LSUM1WCMX20RT · LSUM1WCMX40RT |
display system internal tcp-proxy verbose
Use display system internal tcp-proxy verbose to display detailed information about TCP proxy.
display system internal tcp-proxy verbose slot slot-number
Probe view
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
display system internal udp
Use display system internal udp to display brief information about UDP connections.
display system internal udp slot slot-number
Probe view
display system internal udp port-info
Use display system internal udp port-info to display non-well known UDP port usage.
display system internal udp port-info [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays non-well known UDP port usage for all member devices.
display system internal userlog mbuf dump
Use display system internal userlog mbuf dump to display the contents of flow log UDP packets.
display system internal userlog mbuf dump count number [ slot slot-number [ cpu cpu-number ] ]
Probe view
count number: Specifies the number of UDP packets to be displayed. The value range for the number argument is 1 to 100.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the contents for the master device.
cpu cpu-number: Specifies a CPU by its number, which is fixed at 0.
display system internal userlog statistic
Use display system internal userlog statistic to display running statistics for the flow log module (USERLOG).
display system internal userlog statistic [ slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the statistics for the module on the active MPU. (Distributed devices–In standalone mode.)
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays the statistics for the module on the master device.
display system internal userlog test
Use display system internal userlog test to test the flow log module and display the test result.
display system internal userlog test count number [ slot slot-number [ cpu cpu-number ] ]
Probe view
count number: Specifies the number of test packets to be sent. The value range for the number argument is 1 to 3000.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the test is performed on the master device.
display system internal vlan
Use display system internal vlan to display the internal information of the VLAN module.
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number
Probe view
instance vlan-id: Displays the VLAN module information of the VLAN specified by its VLAN ID in the range of 1 to 4094.
interface interface-type interface-number: Displays the VLAN module information of an interface specified by its type and number.
summary: Displays the summary VLAN module information.
display system internal wips statistics
Use display system internal wips statistics to display WIPS statistics.
Probe view
display system internal wlan ac capability
Use display system internal wlan ac capability to display AC capacity information.
display system internal wlan ac capability [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays AC capacity information for the current device.
display system internal wlan adapter-asyncinfo
Use display system internal wlan adapter-asyncinfo to display asynchronous information at the adaptation layer.
display system internal wlan adapter-asyncinfo { all | thread thread-number } [ slot slot-number ]
Probe view
all: Specifies all threads.
thread thread-number: Specifies a thread by its thread number.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays asynchronous information at the adaptation layer on the current device.
display system internal wlan ap message
Use display system internal wlan ap message to display statistics about messages sent and received by APMGR.
display system internal wlan ap message statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays statistics about messages sent and received by APMGR on the current device.
display system internal wlan ap name
Use display system internal wlan ap name ap-name apcb to display APCB information for an AP.
Use display system internal wlan ap name ap-name capwap-context to display CAPWAP context information for an AP.
Use display system internal wlan ap name ap-name radio radio-id to display interface information for a radio on an AP.
Use display system internal wlan all radio-all to display radio interface information for all APs.
display system internal wlan { all radio-all | ap name ap-name { apcb | capwap-context | radio radio-id } [ slot slot-number ] }
Probe view
ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays the specified information on all IRF member devices.
display system internal wlan ap radio drv-info
Use display system internal wlan ap ap-name radio drv-info to display drive information for all radios on an AP.
Probe view
display system internal wlan ap-group-configuration
Use display system internal wlan ap-group-configuration to display AP group configuration for an AP group.
display system internal wlan ap-group-configuration group-name group-name
Probe view
ap-group group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
display system internal wlan ap-libinfo
Use display system internal wlan ap-libinfo to display AP lib information or basic radio configuration lib information.
display system internal wlan ap-libinfo app-id app-id { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ] [ slot slot-number ]
Probe view
app-id app-id: Specifies an app by its ID. The value range for the app-id argument varies by device model.
ap-id ap-id: Specifies an AP by its ID in the range of 1 to 65535.
ap-name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio-id radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command displays AP lib information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AP lib information or basic radio configuration lib information for the specified app of the current device.
Use this command to display AP or basic radio configuration information for a specific app when APMGR fails to synchronize information with other apps.
display system internal wlan ap-model-configuration
Use display system internal wlan ap-model-configuration to display configuration information about APs with the specified AP model in an AP group.
display system internal wlan ap-model-configuration group-name group-name model-name model-name [ radio radio-id ]
Probe view
group-name group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
model-name model-name: Specifies an AP model by its name.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command displays information for all radios.
display system internal wlan apdb
Use display system internal wlan apdb to display AP model information in APDB.
display system internal wlan apdb ap-model name ap-model [ radio radio-id ]
Probe view
ap-model: Specifies an AP model by its name.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command displays AP model information in APDB for all radios.
display system internal wlan band-navigation
Use display system internal wlan band-navigation to display band navigation information about clients detected by an AP.
display system internal wlan band-navigation ap ap-id [ client mac-address ]
Probe view
client mac-address: Specifies a client by its MAC address in H-H-H format. If you do not specify this option, the command displays band navigation information about all clients detected by the AP.
display system internal wlan client ip
Use display system internal wlan client ip to display client IP information.
display system internal wlan client ip [ mac-address mac-address ]
Probe view
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays IP information for all clients.
display system internal wlan command-cache
Use display system internal wlan command-cache to display command line information in the cache queue.
Probe view
display system internal wlan ctrl-ap
Use display system internal wlan ctrl-ap to display control AP information.
display system internal wlan ctrl-ap [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays control AP information for the current device.
Control APs are APs that are managed by the master AC but come online on the subordinate ACs.
display system internal wlan history bandwidth
Use display system internal wlan history bandwidth to display the history radio bandwidth configuration.
display system internal wlan history bandwidth ap { all | { name ap-name | id ap-id } radio radio-id }
Probe view
all: Specifies all APs.
display system internal wlan history radiostate
Use display system internal wlan history radiostate to display the radio state debugging history.
display system internal wlan history radiostate ap { id ap-id | name ap-name } radio radio-id
Probe view
radio radio-id: Specifies a radio by its ID. The value range for this argument varies by AP model.
display system internal wlan history wlanid
Use display system internal wlan history wlanid to display history records for WLAN ID request and release.
display system internal wlan history wlanid { ap-name ap-name | ap-id ap-id } radio-id radio-id
Probe view
display system internal wlan history-error
Use display system internal wlan history-error to display history records about message processing failures of APMGR.
display system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ] [ slot slot-number ]
Probe view
radio-id radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command displays history records about message processing failures of APMGR for all radios.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays history records about message processing failures of APMGR on the current device.
display system internal wlan kernel-ap
Use display system internal wlan kernel-ap to display AP kernel information.
display system internal wlan kernel-ap { name ap-name | all } [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays AP kernel information for all IRF members.
display system internal wlan link-info
Use display system internal wlan link-info to display link information.
display system internal wlan link-info [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays link information for all IRF member devices.
display system internal wlan load-balance neighbor-list ap
Use display system internal wlan load-balance neighbor-list ap to display radio-based load balancing information and client list information.
display system internal wlan load-balance neighbor-list ap ap-id radio radio-id
Probe view
This command is available only for radio-based load balancing.
display system internal wlan load-balance neighbor-list client
Use display system internal wlan load-balance neighbor-list client to display information about radios that detect a client.
display system internal wlan load-balance neighbor-list client mac-address
Probe view
display system internal wlan load-status
Use display system internal wlan load-status to display load status information.
Probe view
The command output includes the following information:
· Number of online APs on an AC.
· Whether the AC is enabled with AP backup.
· Whether the AC is active.
display system internal wlan logbuffer ha
Use display system internal wlan logbuffer ha to display log information generated during HA active/standby switchover.
Probe view
display system internal wlan logbuffer memory
Use display system internal wlan logbuffer memory to display memory usage information.
Probe view
display system internal wlan response-timeout event
Use display system internal wlan response-timeout event to display information about response-timeout events.
Probe view
Use this command to locate the reason that causes slow responses. The response-timeout time is 1 second.
display system internal wlan statistics
Use display system internal wlan statistics to display AP statistics.
display system internal wlan statistics { ap-interface name ap-name | ap-radio name ap-name radio radio-id }
Probe view
ap-interface: Displays interface statistics on an AP.
ap-radio: Displays WLAN radio statistics on an AP.
display system internal wlan virtual ap
Use display system internal wlan virtual ap to display virtual AP information.
display system internal wlan virtual ap { all | bssid bssid }
Probe view
all: Specifies all virtual APs.
bssid bssid: Specifies a virtual AP by its BSSID.
display system internal wlan virtual client
Use display system internal wlan virtual client to display virtual client information.
display system internal wlan virtual client { all | bssid bssid [ offset offset-value ] }
Probe view
all: Specifies all virtual clients.
bssid bssid: Specifies a virtual AP by the BSSID.
offset offset-value: Specifies a BSSID offset in the range of 0 to 511. If you do not specify this option, the command displays virtual client information for a BSSID without offsets.
display system internal wlan { aplb | kernel-aplb }
Use display system internal wlan { aplb | kernel-aplb } to display AP load balancing (LB) information.
Probe view
aplb: Displays AP LB information in user mode.
kernel-aplb: Displays AP LB information in kernel mode.
ip ipv4-address: Specifies the IPv4 address of an AP. The ipv4-address argument represents the IPv4 address used to establish a CAPWAP tunnel with the AC.
ipv6 ipv6-address: Specifies the IPv6 address of an AP. The ipv6-address argument represents the IPv6 address used to establish a CAPWAP tunnel with the AC.
port port-number: Specifies the port number of an AP in the range of 100 to 65535. The port-number argument represents the port number used to establish a CAPWAP tunnel with the AC.
load-slot slot-number1: Displays LB information for APs that come online on the specified AC.
slot slot-number2: Displays AP LB information stored on the specified AC.
display transceiver information
Use display transceiver information to display detailed transceiver information.
display transceiver information interface [ interface-type interface-name ]
Probe view
interface [ interface-type interface-name ]: Specifies an interface by its type and name. If you do not specify this option, the command displays detailed information about transceivers on all interfaces.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H |
No |
WX2540H WX2560H |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
No |
display transceiver moduleinfo
Use display transceiver moduleinfo to display core transceiver data structure information used in the software.
display transceiver moduleinfo interface [ interface-type interface-number ]
Probe view
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type interface-number argument, the command displays information about transceivers on all interfaces.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H |
No |
WX2540H WX2560H |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
No |
display transceiver register
Use display transceiver register to display transceiver register information.
display transceiver register interface [ interface-type interface-number ]
Probe view
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H |
No |
WX2540H WX2560H |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
No |
F
follow
Use follow to display the stack information for a process or a thread.
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number [ cpu cpu-number ] ]
Probe view
job job-id: Specifies a job by its ID in the range of 1 to 2147483647. A job ID uniquely identifies a process, and it does not change after the process restarts.
process pid: Specifies a process by its ID in the range of 1 to 2147483647. The process ID might change after the process restarts.
thread thread-id: Specifies a thread by its ID in the range of 1 to 2147483647. If you do not specify this option, all threads for the specified process are specified.
delay seconds: Specifies the interval between follow operations in seconds, in the range of 0 to 255. The default value is 5.
iteration count: Specifies the number of follow operations, in the range of 0 to 255. The default value is 5.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays process or thread stack information for the master device.
cpu cpu-number: Specifies a CPU by its number.
For a user process, this command displays the following information:
· The user stack information (starting from the user stack prompt).
· The kernel stack information (starting from the kernel stack prompt).
For a kernel process, this command displays only the kernel stack information.
fpl-diag
Use fpl-diag to execute the specified debugging command.
fpl-diag { cmd-string | slot slot-number cmd-string }
Probe view
slot slot-number: Specifies a slot by its number.
cmd-string: Specifies a debugging command. This argument is only used for product debugging. It might cause system crash or make the device unavailable. It can only be used by H3C support.
L
license check-timer
Use license check-timer to set a check timer for license validity.
license check-timer interval-value slot slot-number
The check timer is 86400 seconds (24 hours).
Probe view
interval-value: Sets the check timer for license validity, in seconds. The value range is 10 to 864000. H3C recommends that you set a value larger than 60 seconds. A timer shorter than 60 seconds might degrade system performance.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
A license is valid for a time period in days. The device checks the license for validity at the check interval. If the license does not expire, the device decreases the validity period by 1 day. If the license has expired, the device marks the license as expired.
The setting cannot survive a reboot because it is not saved to the configuration file.
Use this command only for internal tests. By default, the timer is set to the highest value. Changing the setting will cause your license to expire before the expiration date.
license file-timer
Use license check-timer to set a check timer for license file availability.
license file-timer interval-value slot slot-number
The check timer is 1800 seconds (30 minutes).
Probe view
interval-value: Set the check timer for license file availability, in seconds. The value range is 10 to 864000. H3C recommends that you set a value larger than 60 seconds. A short checker might degrade system performance.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
Yes |
WX3000H series |
Yes |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
After the device starts up, the system automatically starts the license processes and checks the availability of license files. If a license file is not available, its license file check timer starts. The device periodically checks the file for file recovery. When the license file is recovered, the system deletes the timer.
lipc connection detect
Use lipc connection detect to detect node connectivity.
Probe view
This command enables the current node to continuously send five echo requests to all connected remote nodes. If the current node receives an echo reply from a remote node, it means that the remote node is reachable. Otherwise, the remote node is unreachable.
lipc dump
Use lipc dump to configure a protocol-based LIPC dumping rule.
Use undo lipc dump to delete a protocol-based LIPC dumping rule.
lipc dump lgmp [ port port ] [ recv | send ] [ lip lip ]
undo lipc dump [ lgmp [ port port ] [ recv | send ] ] [ lip lip ]
lipc dump { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] [ lip lip ]
lipc dump { publish | topology } [ recv | send ] [ lip lip ]
undo lipc dump [ { publish | topology } [ recv | send ] ] [ lip lip ]
No protocol-based LIPC dumping rule exists.
Probe view
lgmp: Specifies the LGMP protocol.
mtcp: Specifies the MTCP protocol.
stcp: : Specifies the STCP protocol.
sudp: Specifies the SUDP protocol.
publish: Specifies the publish protocol.
topology: Specifies the topology protocol.
port port: Specifies a port by its number. If you do not specify a port, the command dumps packets on all ports.
ack: Dumps acknowledgment packets.
ctrl: Dumps control packets.
data: Dumps data packets.
recv: Dumps received packets.
send: Dumps sent packets.
lip lip: Specifies a remote node by its ID in the range if 0 to 65535. If you do not specify a remote node, the command dumps packets on the node where the global active MPU resides.
If you do not specify the ack, ctrl, or data keyword, the command dumps acknowledgment, control, and data packets.
If you do not specify the recv or send keyword, the command dumps received and sent packets.
You can repeat this command to configure a maximum of five protocol-based LIPC dumping rules by specifying different parameters. To view all the configured LIPC dumping rules, use the display system internal lipc dump configuration command.
If a packet matches multiple protocol-based LIPC dumping rules, the system generates only one dumping record. If a packet matches both a protocol-based dumping rule and a content-based dumping rule, the system generates two dump records. To view all dumped packets, use the display system internal lipc dump command.
lipc dump buffer
Use lipc dump buffer to allocate or release an LIPC dumping buffer.
lipc dump buffer { alloc [ max-record num ] | free } [ lip lip ]
Probe view
alloc: Allocates an LIPC dumping buffer.
free: Releases an LIPC dumping buffer.
max-record num: Specifies the capacity of the dumping buffer, in the range of 1 to 10000 KB. The default is 10 KB.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the configuration applies to the node where the global active MPU resides.
To dump a large number of packets, use this command to allocate a large dumping buffer before you enable LIPC dumping.
lipc dump enable
Use lipc dump enable to enable LIPC dumping.
Use undo lipc dump enable to disable LIPC dumping.
lipc dump enable [ loop] [ lip lip ]
undo lipc dump enable [ lip lip ]
LIPC dumping is disabled.
Probe view
loop: Specifies the loop dumping mode. If you do not specify this keyword, the command does not dump packets when the dumping buffer is full.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command enables LIPC dumping for the node where the global active MPU resides.
If you have not allocated a dumping buffer, the system automatically allocates a dumping buffer with a capacity of 10 KB when you execute this command.
The undo lipc dump enable command does not delete LIPC dumping rules or release the dumping buffer.
lipc dump offset
Use lipc dump offset to configure a content-based LIPC dumping rule.
Use undo lipc dump to delete a content-based LIPC dumping rule.
lipc dump offset offset length length value value [ recv | send ] [ lip lip ]
undo lipc dump [ offset offset length length value value [ recv | send ] ] [ lip lip ]
No content-based LIPC dumping rule exists.
Probe view
offset: Specifies the matching content offset from the LIP packet header, in the range of 0 to 65535 bytes.
length length: Specifies the length of matching contents for dumping, in bytes. The value for the length argument is 1, 2, 4, or 8.
value value: Specifies the value of matching contents for dumping, in hexadecimal. The value range for the value argument is related to the length argument, as shown in the following table.
Value of the length argument |
Value range for the value argument |
1 |
0 to 0xFF |
2 |
0 to 0xFFFF |
4 |
0 to 0xFFFFFFFF |
8 |
0 to FFFFFFFFFFFFFFFF |
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command dumps packets for the node where the global active MPU resides.
If you do not specify the recv or send keyword, the command dumps both received and sent packets.
After receiving a packet at the driver layer, the system compares length bytes after the offset byte in the packet with value. If the bytes match value, the system dumps the first 48 bytes of the packet to the dumping buffer. Packets dumped on a protocol basis and those on a content basis are stored in the same dumping buffer. To view all dumped packets, use the display system internal lipc dump command.
You can repeat this command to configure a maximum of five content-based LIPC dumping rules by specifying different parameters. To view all the configured LIPC dumping rules, use the display system internal lipc dump configuration command.
To delete a content-based LIPC dumping rule, you must specify the same offset, length, and value as those in an existing rule.
If a packet matches multiple content-based LIPC dumping rules, the system generates only one dumping record. If a packet matches both a content-based dumping rule and a protocol-based dumping rule, the system generates two dumping records.
lipc performance
Use lipc performance to configure performance statistics for LIPC unicast or multicast connections and enable the LIPC transmission performance evaluation.
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
Performance statistics is disabled.
Probe view
mtcp: Specifies the LIPC MTCP module.
stcp: Specifies the LIPC STCP module.
clear: Clears performance statistics.
off: Disables performance statistics.
on: Enables performance statistics.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command applies to the node where the global active MPU resides.
lipc ping
Use lipc ping to ping a node.
lipc ping lip lip [ length length ] [ times times ] [ summary ]
Probe view
lip lip: Specifies a node by its ID in the range of 0 to 32767.
length length: Specifies the length of an echo request packet (excluding the LIPC packet header), in the range of 0 to 32767 bytes. The default is 100 bytes.
times times: Specifies the number of times for sending echo request packets, in the range of 0 to 65535. The default is 3.
summary: Displays summary information. If you do not specify the keyword, the system displays detailed information and summary information.
You can use this command to examine whether the LIPC connection between the local node and the specified node is operating correctly.
lipc timeout
Use lipc timeout to set the timeout time for LIPC topology links.
lipc timeout time [ lip lip ]
The setting is 60 seconds.
Probe view
timeout time: Specifies a timeout time in the range of 3 to 65535 seconds.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command sets the timeout time for LIPC topology links on the node where the global active MPU resides.
If the topology module at the local node does not receive the heartbeat packets from a node in up state when the timeout time expires, it tears down all unicast and multicast connections with the node.
The timeout time needs to be modified only when you use the KDB or KGDB to debug the kernel. H3C recommends that you set a larger timeout time to avoid the other nodes from tearing down the connections with the node whose kernel is being debugged.
list
Use list to display subdirectory or file information in the /proc/, /sys/, or /var/ directory.
list file-path [ slot slot-number ]
Probe view
file-path: Specifies a subdirectory path or file path, which is case sensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays the subdirectory or file information for the master device.
The file or subdirectory path specified cannot contain file links.
M
memory boundary-check enable
Use memory boundary-check enable to enable memory boundary check.
Use undo memory boundary-check enable to disable memory boundary check.
memory boundary-check enable job job-id [ slot slot-number [ cpu cpu-number ] ]
undo memory boundary-check enable job job-id [ slot slot-number [ cpu cpu-number ] ]
Memory boundary check is disabled.
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables memory boundary check for the master device.
This command enables the system to perform memory boundary check before each memory deallocation to ensure the correct memory allocation and deallocation.
If a memory overwrite occurs, the system stores the memory overwrite information in a memory file. The system stores all memory overwrite information in the same memory file.
memory boundary-check scan
Use memory boundary-check scan to trigger a memory boundary check and display the check result.
memory boundary-check scan job job-id [ slot slot-number [ cpu cpu-number ] ]
Probe view
job job-id: Specifies a job by its job ID in the range of 1 to 2147483647. A job ID uniquely identifies a process, and it does not change after the process restarts.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command triggers a memory boundary check and displays the check result for the master device.
This command takes effect only when memory boundary check has been enabled.
If a memory overwrite is detected, the system displays 128-byte memory contents starting from the 16th byte preceding the detected memory address.
When more than one memory overwrite is detected, the system only records and displays 128-byte memory contents with the lowest memory address detected.
monitor lipc
Use monitor lipc to display realtime statistics for LIPC in interactive mode.
monitor lipc { mtcp | stcp | sudp } { recv | send } [ lip lip ]
Probe view
mtcp: Specifies the MTCP module.
stcp: Specifies the STCP module.
sudp Specifies the SUDP module.
recv: Specifies received packets.
mtcp: Specifies sent packets.
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command displays realtime statistics for the node where the global active MPU resides.
The command displays statistics (including information about received and transmitted packets, state information, and buffer information) in descending order. The system refreshes statistics every five seconds, and it can display a maximum of 10 statistics items each time.
You can enter the letter q or Q to quit the display and return to probe view.
multicast record limit
Use multicast record limit to set the maximum number of operation records for multicast entries.
Use undo multicast record limit to restore the default.
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
The maximum number is 0. The device does not keep operation records for multicast entries.
Probe view
fail: Specifies records of failed operations on multicast entries.
limit-value: Specifies the maximum number of operation records for multicast entries, in the range of 0 to 500000.
P
probe
Use probe to enter probe view.
probe
In probe view, you can use commands to view system status and information and diagnose system faults.
R
reset system internal arp statistics
Use reset system internal arp statistics to clear ARP statistics.
reset system internal arp statistics slot slot-number
Probe view
reset system internal aspf statistics
Use reset system internal aspf statistics to clear statistics about packets dropped by ASPF and filter.
reset system internal aspf statistics interface { ipv4 | ipv6 } [ slot slot-number ]
Probe view
interface: Clears dropped packet statistics for interfaces.
ipv4: Specifies IPv4 packets.
ipv6: Specifies IPv6 packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears dropped packet statistics for all member devices.
reset system internal fsim statistics
Use reset system internal fsim statistics to clear FSIM statistics.
reset system internal fsim statistics slot slot-number
Probe view
reset system internal ip routing-table statistics protocol
Use reset system internal ip routing-table statistics protocol to clear IPv4 route statistics.
Probe view
protocol: Clears statistics about IPv4 routes installed by a protocol. The protocol argument specifies a routing protocol, which can be direct or static.
all: Clears all IPv4 route statistics.
standby slot slot-number: Clears backup IPv4 route statistics for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
WX2510H WX2540H WX2560H |
No |
WX3000H series |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
reset system internal ipv6 rib log
Use reset system internal ipv6 rib log to clear IPv6 RIB logs.
reset system internal ipv6 rib [ event ] log [ standby slot slot-number ]
Probe view
event: Clears logs about IPv6 RIB route changes.
standby slot slot-number: Clears backup IPv6 RIB logs for an IRF member device. If you do not specify this option, the command clears IPv6 RIB logs.
reset system internal ipv6 rib nib log
Use reset system internal ipv6 rib nib log to clear IPv6 next hop logs.
reset system internal ipv6 rib nib log [ standby slot slot-number ]
Probe view
standby slot slot-number: Clears backup IPv6 next hop logs for an IRF member device. If you do not specify this option, the command clears IPv6 next hop logs.
reset system internal ipv6 rib summary
Use reset system internal ipv6 rib summary to clear IPv6 RIB statistics.
reset system internal ipv6 rib summary [ standby slot slot-number ]
Probe view
standby slot slot-number: Clears backup IPv6 RIB statistics of an IRF member device. If you do not specify this option, the command clears IPv6 RIB statistics.
reset system internal ipv6 route-static nib log
Use reset system internal ipv6 route-static nib log to clear IPv6 static route NIB logs.
Probe view
reset system internal ipv6 routing-table statistics protocol
Use reset system internal ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset system internal ipv6 routing-table statistics protocol { protocol | all } standby slot slot-number
Probe view
protocol: Clears statistics about IPv6 routes installed by a protocol. The protocol argument specifies a routing protocol, which can be direct or static.
all: Clears all IPv6 route statistics.
standby slot slot-number: Clears backup IPv6 route statistics for an IRF member device.
Hardware series |
Model |
WX1800H series |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
reset system internal lipc dump buffer
Use reset system internal lipc dump buffer to clear the LIPC dumping buffer.
reset system internal lipc dump buffer [ lip lip ]
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 65535. If you do not specify a remote node, the command clear the LIPC dumping buffer for the node where the global active MPU resides.
reset system internal mac-address statistics
Use reset system internal mac-address statistics to clear MAC address table statistics.
reset system internal mac-address statistics slot slot-number
Probe view
reset system internal mbuf relay statistics
Use reset system internal mbuf relay statistics to clear MBUF Relay statistics.
reset system internal mbuf relay statistics slot slot-number [ vcpu vcpu-number [ rcv receiver-id ] ]
Probe view
vcpu vcpu-number: Specifies a vCPU by its number. If you do not specify a vCPU, this command clears MBUF Relay statistics for all vCPUs on the card.
The following matrix shows the value ranges for the vcpu vcpu-number option:
Hardware series |
Model |
Value range |
WX1800H series |
0 |
WX2500 series |
0 |
WX3000H series |
0 |
WX3500H series |
· 0 to 7 for the WX3508H · 0 to 15 for the WX3510H/WX3520H/WX3520H-F/WX3540H |
WX5500E series |
WX5510E WX5540E |
0 to 31 |
WX5500H series |
0 to 31 |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX20RT LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX40RT |
0 to 31 |
rcv received-id: Specifies the MBUF Relay receiver by its ID. The value is in the range of 0 to 127. If you do not specify an MBUF Relay receiver, this command clears MBUF Relay statistics for all the receivers on the CPU.
reset system internal multicast record
Use reset system internal multicast record to clear operation records for multicast entries.
Probe view
reset system internal nat statistics
Use reset system internal nat statistics to clear NAT statistics.
reset system internal nat statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command clears NAT statistics for all member devices.
reset system internal nd statistics
Use reset system internal nd statistics to clear ND statistics.
reset system internal nd statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears ND statistics for all member devices.
reset system internal portal ap-statistics
Use reset system internal portal ap-statistics to clear statistics for portal-related messages between the AC and APs in local forwarding mode.
Probe view
reset system internal portal statistics
Use reset system internal portal statistics to clear dynamic statistics for the portal process.
Probe view
reset system internal ppp statistics
Use reset system internal ppp statistics to clear PPP statistics.
reset system internal ppp statistics { aggregation | all | interface-event } [ slot slot-number ]
Probe view
aggregation: Clears PPP aggregation statistics.
all: Clears all PPP statistics.
interface-event: Clears PPP interface event statistics.
slot slot-number: Specifies an IRF member device by its ID.
You can use this command on both the master and backup devices.
reset system internal pppoe-server statistics
Use reset system internal pppoe-server statistics to clear PPPoE server statistics.
reset system internal pppoe-server statistics aggregation [ slot slot-number ]
Probe view
aggregation: Clears PPPoE server aggregation statistics.
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
No |
WX3000H series |
WX3010H-X WX3010H-L WX3024H-L |
No |
WX3500H series |
No |
WX5000E series |
WX5510E WX5540E |
No |
WX5500H series |
No |
Yes |
You can use this command on both the master and the backup devices.
reset system internal rib log
Use reset system internal rib log to clear RIB logs.
reset system internal rib [ event ] log [ standby slot slot-number ]
Probe view
event: Clears logs about RIB route changes.
standby slot slot-number: Clears backup RIB logs for an IRF member device. If you do not specify this option, the command clears RIB logs.
reset system internal rib nib log
Use reset system internal rib nib log to clear next hop logs.
reset system internal rib nib log [ standby slot slot-number ]
Probe view
standby slot slot-number: Clears backup next hop logs for an IRF member device. If you do not specify this option, the command clears next hop logs.
reset system internal rib summary
Use reset system internal rib summary to clear RIB statistics.
reset system internal rib summary [ standby slot slot-number ]
Probe view
standby slot slot-number: Clears backup RIB statistics of an IRF member device. If you do not specify this option, the command clears RIB statistics.
reset system internal route-static nib log
Use reset system internal route-static nib log to clear static route NIB logs.
Probe view
reset system internal session alg statistics
Use reset system internal session alg statistics to clear ALG statistics about abnormal packets.
reset system internal session alg statistics [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears ALG statistics about abnormal packets for all member devices.
reset system internal session statistics
Use reset system internal session statistics to clear abnormal packet statistics for sessions.
reset system internal session statistics { ipv4 | ipv6 } [ slot slot-number ]
Probe view
ipv4: Clears abnormal packet statistics for IPv4 sessions.
ipv6: Clears abnormal packet statistics for IPv6 sessions.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears abnormal packet statistics for all member devices.
reset system internal tcp-proxy statistics
Use reset system internal tcp-proxy statistics to clear TCP proxy statistics for IPv4 and IPv6 connections.
Probe view
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
WX5500H series |
No |
No |
Use reset system internal tcp-proxy statistics to clear TCP proxy statistics for IPv4 and IPv6 TCP connections.
Probe view
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20RT LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20 LSUM1WCMX40RT |
reset system internal wlan history bandwidth
Use reset system internal wlan history bandwidth to clear history radio bandwidth configuration.
reset system internal wlan history bandwidth ap { all | { name ap-name | id ap-id } radio radio-id }
Probe view
reset system internal wlan history radiostate
Use reset system internal wlan history radiostate to clear the radio state debugging history.
reset system internal wlan history radiostate ap { id ap-id | name ap-name } radio radio-id
Probe view
reset system internal wlan history-error
Use reset system internal wlan history-error to clear history records about message processing failures of APMGR.
reset system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ] [ slot slot-number ]
Probe view
radio-id radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by device model. If you do not specify a radio, this command clears history records about message processing failures of APMGR for all radios.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears history records about message processing failures of APMGR on the current device.
reset system internal wlan response-timeout event
Use reset system internal wlan response-timeout event to clear information about response-timeout events.
Probe view
Use this command to make room for new response-timeout event information.
rrm calibrate-power step
Use rrm calibrate-power step to set the power adjustment step.
Use undo rrm calibrate-power step to restore the default.
rrm calibrate-power step { down | up } value
undo rrm calibrate-power step { down | up }
The power adjustment step is 3 dBm.
Probe view
down: Specifies a power decrement step.
up: Specifies a power increment step.
value: Specifies a power adjustment step in the range of 1 to 8 dBm.
S
Use system internal session alg statistics acl acl-number enable to enable ALG abnormal statistics collection.
Use undo system internal session alg statistics to disable ALG abnormal statistics collection.
system internal session alg statistics acl acl-number enable [ slot slot-number ]
ALG abnormal statistics collection is disabled.
Probe view
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables ALG abnormal statistics collection on all member devices.
This command enables the device to collect ALG statistics about abnormal packets that match the specified ACL.
The undo form of this command will clear the collected ALG statistics about abnormal packets.
T
Use tcp-proxy statistics to turn on or off counters for TCP proxy.
tcp-proxy statistics { off | on }
Counters are turned off for TCP proxy.
Probe view
off: Turns off counters for TCP proxy.
on: Turns on counters for TCP proxy.
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
The TCP proxy counters collect information about the numbers of API calls, input and output TCP packets, error packets, and FSM packets.
Use tcp-proxy statistics to turn on or off the counters for TCP proxy.
Probe view
off: Turns off the counters for TCP proxy.
on: Turns on the counters for TCP proxy.
Hardware series |
Model |
WX1800H series |
Yes |
WX2500H series |
Yes |
WX3000H series |
WX3500H |
Yes |
WX5500E series |
WX5510E WX5540E |
WX5500H series |
No |
No |
V
view
Use view to display the contents of a file in the /proc/, /sys/, or /var/ directory.
view file-path [ slot slot-number ]
Probe view
file-path: Specifies a file by its path, which is case sensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays the file contents for the master device.
The specified file path cannot contain file links. A file link is similar to a file shortcut and points to a file or directory. You can access a file or directory through a file link.
W
wips fix-channel-scan
Use wips fix-channel-scan to enable WIPS to scan the specified channel.
Use undo wips fix-channel-scan to disable WIPS from scanning the specified channel.
wips fix-channel-scan ap id ap-id radio radio-id channel channel-number
undo wips fix-channel-scan ap id id radio id
WIPS is disabled from scanning the specified channel.
Probe view
channel-number: Specifies a channel by its number in the range of 1 to 255.
This command enables WIPS to scan only the specified channel. However, devices on adjacent channels might be detected because of channel overlapping.
wlan ap-execute exec-console enable
Use wlan ap-execute exec-console enable to enable the execution console for an online AP.
Use wlan ap-execute exec-console disable to disable the execution console for an online AP.
wlan ap-execute ap-name exec-console { disable | enable }
When an AP comes online, the execution console is automatically disabled. When the AP goes offline, the execution console is automatically enabled.
Probe view
When the execution console of an AP is disabled, users cannot log in to the AP through the console port or through Telnet. This command does not affect logged-in users.
wlan ap-link-test
Use wlan ap-link-test to test the CAPWAP tunnel performance.
wlan ap-link-test { ipv4-address | ipv6-address } [ destination port-number | source port-number | packet-length value | { burst | continuous } rate rate time time ] *
Probe view
ipv4-address: Specifies an AP by its IPv4 address.
ipv6-address: Specifies an AP by its IPv6 address.
destination port-number: Specifies the destination UDP port in the range of 1 to 65535. The default destination UDP port is 5246.
source port-number: Specifies the source UDP port in the range of 1 to 65535. The default source UDP port is 5246.
packet-length value: Specifies the tested packet length in bytes. The value range for the value argument is 66 to 2048. The default value is 128.
burst: Enables the burst packet-sending mode, which means that fragmented packets are sent at a one-time attempt every 1 second.
continuous: Enables the continuous packet-sending mode, which means that fragmented packets are sent every 10 milliseconds within a second. If all fragmented packets are sent within a second, the device does not send packets until the next second starts.
rate rate: Specifies the packet transmit rate in packets per second. The value range for the rate argument is 1 to 10000.
time time: Specifies the test duration in seconds. The value range for the time argument is 1 to 100.
wlan image-load model
Use wlan image-load model to specify the AP models for software version assignment from the AC.
Use undo wlan image-load model to remove the configuration.
wlan image-load model { model }&<1-8>
undo wlan image-load model { model }&<1-8>
No AP models are specified for software version assignment from the AC. The AC can assign a software version to all AP models.
Probe view
{ model }&<1-8>: Specifies the AP models. &<1-8> indicates that you can specify a maximum of eight AP models.
This command limits the AP models to which the AC assigns a software version. It must work with the software upgrade feature. When software upgrade is enabled, the AC examines the software version of an AP during CAPWAP tunnel establishment. If the AP uses a different software version from the software version stored in the APDB, the AC assigns the corresponding software version to the AP based on the AP model specified in this command.
For more information about AP software upgrade, see WLAN Configuration Guide.
This command takes effect only on offline APs.
wlan image-load simultaneous
Use wlan image-load simultaneous to set the maximum number of concurrent software version assignment tasks on each thread of the AC.
wlan image-load simultaneous count
Each thread of the AC can simultaneously process a maximum of eight software version assignment tasks.
Probe view
count: Specifies the maximum number of concurrent software version assignment tasks on each thread of the AC. The value range is 1 to 64.
wlan system internal ap adjust reboot enable
Use wlan system internal ap adjust reboot enable to enable reboot adjustment.
Use undo wlan system internal ap adjust reboot enable to disable reboot adjustment.
Reboot adjustment is enabled.
Probe view
The AC matches the radio information received from an online AP against the local radio information. If the reboot adjustment is enabled, the AC restarts the AP after 10 consecutive match failures. If the reboot adjustment is disabled, the AC does not restart the AP and continues the matching.
wlan system internal offline-restrain
Use wlan system internal offline-restrain to enable AP logoff suppression for an AP.
Use undo wlan system internal offline-restrain to disable AP logoff suppression for an AP.
wlan system internal offline-restrain ap ap-name
undo wlan system internal offline-restrain ap ap-name
AP logoff suppression is disabled.
Probe view
ap ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
To locate problems easily, use the AP logoff suppression feature to control the state machine of an AP.
· When this feature is enabled, the AP's state machine is always Run. After you execute the wlan system internal offline-restrain command, the system prompts you to determine whether to always retransmit packets. If you enter Y, the AC always sends request packets to the AP. If you enter N, the AC stops retransmitting packets when the AC request transmission attempt limit is reached.
· When this feature is disabled, the AP's state machine turns to Idle after it goes offline.
Requests sent by the AC to an AP include the following types:
· Image Data Request.
· Configuration Update Request.
· Reset Request.
· Data Transfer Request.
· IEEE 802.11 WLAN Configuration Request.
· Station Configuration Request.
wlan system internal reboot-restrain
Use wlan system internal reboot-restrain to enable automatic AP reboot suppression for an AP.
Use undo wlan system internal reboot-restrain to disable automatic AP reboot suppression for an AP.
wlan system internal reboot-restrain ap ap-name
undo wlan system internal reboot-restrain ap ap-name
Automatic AP reboot suppression is disabled for an AP.
Probe view
An AP will automatically restart after it has been offline for 10 minutes. To suppress the automatic reboot of the AP, use this command.
wlan virtual ap add
Use wlan virtual ap add to create virtual APs.
wlan virtual ap add { ipv4 ac-ip-address ap-ip-start | ipv6 ac-ipv6-address ap-ipv6-start } bssid bssid-start [ count count step ap-ip-step bssid-step ] [ port port-start step port-step ] [ slot slot-number ]
Probe view
ipv4: Specifies AP IPv4 addresses.
ac-ip-address: Specifies an AC IPv4 address.
ap-ip-start: Specifies the start AP IPv4 address.
ipv6: Specifies AP IPv6 addresses.
ac-ipv6-address: Specifies an AC IPv6 address.
ap-ipv6-start: Specifies the start AP IPv6 address.
bssid bssid-start: Specifies the start BSSID.
step ap-ip-step bssid-step: Specifies steps by which AP IP addresses and BSSIDs increase. The value ranges for the ap-ip-step and bssid-step arguments are both 1 to 255.
port port-start: Specifies port numbers used to establish CAPWAP tunnels for virtual APs. The port-start argument specifies the start port number in the range of 1024 to 65535. If you do not specify this option, the command sets the start port number to 1024.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command creates virtual APs on all member devices.
wlan virtual ap delete
Use wlan virtual ap delete to delete virtual APs.
wlan virtual ap delete { all | bssid bssid } [ slot slot-number ]
Probe view
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command deletes virtual APs from all member devices.
wlan virtual client add
Use wlan virtual client add to create virtual clients.
Probe view
mac client-mac-start: Specifies the start client MAC address.
ipv4: Specifies client IPv4 addresses.
client-ip-start: Specifies the start client IPv4 address.
ipv6: Specifies client IPv6 addresses.
client-ipv6-start: Specifies the start client IPv6 address.
count count: Specifies the number of clients to be created for each virtual AP. The value range for the count argument is 1 to 124. If you do not specify this option, the command creates one virtual client for each virtual AP.
step client-mac-step client-ip-step: Specifies steps by which client MAC addresses and IP addresses increase. The value ranges for the client-mac-step and client-ip-step arguments are both 1 to 256. If you do not specify this option, the command sets both steps to 1.
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094.
bssid: Specifies virtual APs by BSSIDs for the virtual clients.
all: Specifies all APs. If you specify this keyword, the command creates virtual clients at the specified step for each AP in turn.
offset offset-value: Specifies a BSSID offset in the range of 0 to 511. If you do not specify this option, the command creates virtual clients for a BSSID without offsets.
service-template service-template-name: Specifies a service template by its name. The service-template-name argument is a case-insensitive string of 1 to 63 characters.
non-wmm: Specifies non-WMM clients. If you do not specify this keyword, the command creates WMM clients.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command creates virtual clients on all member devices.
Use the wlan virtual ap add command to create virtual APs before you execute this command.
wlan virtual client delete
Use wlan virtual client delete to delete virtual clients.
Probe view
mac mac-address: Specifies a virtual client by its MAC address.
offset offset-value: Specifies a BSSID offset in the range of 0 to 511. If you do not specify this option, the command delete virtual clients for a BSSID without offsets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command deletes virtual clients from all member devices.
