12-Network Management and Monitoring
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10212-Network Management and Monitoring
07-EAA commands
07-EAA commands 106.95 KB
EAA commands
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
action cli
Use action cli to add a CLI action to a monitor policy.
Use undo action to remove an action.
undo action number
Monitor policies do not contain any actions.
CLI-defined policy view
number: Specifies an action ID in the range of 0 to 231.
cli command-line: Specifies the command line to be executed when the event occurs. You can enter abbreviated forms of command keywords, but you must make sure the forms can uniquely identify the command keywords. For example, you can enter dis cu for the display current-configuration command.
You can configure a series of actions to be executed in response to the event specified in a monitor policy. If two actions have the same ID, the most recent one takes effect.
EAA executes the actions in ascending order of action IDs. When you add actions to a policy, you must make sure the execution order is correct.
To execute a command in a view other than user view, you must define actions required for accessing the target view before defining the command execution action. In addition, you must number the actions in the order they should be executed, starting with entering system view.
For example, to shut down an interface, you must create the following actions in order:
1.     Action to enter system view.
2.     Action to enter interface view.
3.     Action to shut down the interface.
When you define an action, you may choose to specify a value or specify a variable name for an argument. For more information about using EAA environment variables, see "rtm environment."
# Configure the CLI-defined policy test to shut down GigabitEthernet 1/0/1 when the policy is triggered.
[Sysname] rtm cli-policy test
[Sysname-rtm-test] action 1 cli system-view
[Sysname-rtm-test] action 2 cli interface gigabitethernet 1/0/1
[Sysname-rtm-test] action 3 cli shutdown
action reboot
Use action reboot to add a reboot action to a monitor policy.
action number reboot [slot slot-number ]
undo action number
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command reboots the IRF fabric.
The reboot action configured with this command reboots devices or cards without saving the running configuration. If you want to save the running configuration, use the action cli command to configure reboot actions.
# Configure an action for the CLI-defined policy test to reboot IRF member device 1.
[Sysname-rtm-test] action 3 reboot slot 1
action switchover
Use action switchover to add an active/standby switchover action to a monitor policy.
action number switchover
undo action number
This command does not trigger an active/standby switchover when the device is not in redundancy state.
EAA executes the actions in ascending order of action IDs. You must make sure the execution order is correct when you add actions to a policy.
# Configure an action for the CLI-defined policy test to perform an active/standby switchover.
[Sysname-rtm-test] action 3 switchover
action syslog
Use action syslog to add a Syslog action to a monitor policy.
action number syslog priority level facility local-number msg msg-body
undo action number
priority level: Specifies the log severity level in the range of 0 to 7. A lower value represents a higher severity level.
facility local-number: Specifies a logging facility by its facility number in the range of local0 to local7. Facility numbers are used by a log host to identify log creation facilities for filtering log messages.
msg msg-body: Configures the log message body.
EAA sends log messages to the information center. You can configure the information center to output these messages to certain destinations. For more information about the information center, see "Configuring the information center."
# Configure an action for the CLI-defined policy test to send a log message "hello" with a severity of 7 from the facility device local3.
[Sysname-rtm-test] action 3 syslog priority 7 facility local3 msg hello
commit
Use commit to enable a CLI-defined monitor policy.
commit
No CLI-defined policies are enabled.
You must execute this command for a CLI-defined policy to take effect.
After changing the settings in a policy that has been enabled, you must re-execute this command for the changes to take effect.
# Enable the CLI-defined policy test.
[Sysname-rtm-test] commit
display rtm environment
Use display rtm environment to display user-defined EAA environment variables and their values.
var-name: Specifies a user-defined EAA environment variable by its name. If you do not specify a variable, this command displays all user-defined EAA environment variables.
# Display all user-defined EAA environment variables.
<Sysname> display rtm environment
Name             Value
config_cmd       interface m1/0/1
save_cmd         save main force
show_run_cmd     display current-configuration
display rtm policy
Use display rtm policy to display monitor policies.
active: Displays policies that are running.
policy-name: Specifies a policy by its name. If you do not specify a policy, the command displays all monitor policies that are running or have been created.
verbose: Displays detailed information about monitor policies.
To display the running configuration of CLI-defined monitor policies, execute the display current-configuration command in any view or execute the display this command in CLI-defined monitor policy view.
# Display all running monitor policies.
<Sysname> display rtm policy active
JID   Type  Event      TimeActive           PolicyName
507   TCL   INTERFACE  Aug 29 14:55:55 2013 test
# Display all monitor policies that have been created.
Total number: 1
Type  Event      TimeRegistered       PolicyName
CLI              Aug 29 14:54:50 2013 test
# Display detailed information about all monitor policies.
<Sysname> display rtm policy registered verbose
  Total number: 1
   Policy Name: test
   Policy Type: CLI
    Event Type:
TimeRegistered: Aug 29 14:54:50 2013
     User-role: network-operator
JID
Job ID. This field is available for the display rtm policy active command.
PolicyName
Monitor policy name.
Policy Type
Policy creation method:
·     TCL—The policy was configured by using Tcl.
·     CLI—The policy was configured from the CLI.
Event
Event Type
Event type, including CLI, hotplug, interface, process, SNMP, SNMP-Notification, Syslog, and track.
TimeActive
Time when the policy started to execute.
TimeRegistered
Time when the policy was created.
Total number
Total number of policies.
User-role
User roles for executing the monitor policy. To execute the monitor policy, an administrator must have at least one of the displayed user roles.
event cli
Use event cli to configure a CLI event for a CLI-defined monitor policy.
Use undo event to delete the event in a CLI-defined monitor policy.
undo event
No CLI events are configured.
async [ skip ]: Enables or disables the system to execute the command that triggers the policy. If you specify the skip keyword, the system executes the actions in the policy without executing the command that triggers the policy. If you do not specify the skip keyword, the system executes both the actions in the policy and the command entered at the CLI.
sync: Enables the system to execute the command that triggers the event only if the policy has been executed successfully.
execute: Triggers the policy when a matching command is entered.
help: Triggers the policy when a question mark (?) is entered at a matching command line.
tab: Triggers the policy when the Tab key is pressed to complete a parameter in a matching command line.
pattern regular-exp: Specifies a regular expression for matching commands that trigger the policy. For more information about using regular expressions, see Fundamentals Configuration Guide.
Use CLI event monitor policies to monitor operations performed at the CLI.
You can configure only one event for a monitor policy. If the monitor policy already contains an event, the new event replaces the old event.
# Configure a CLI-defined policy to monitor execution of commands that contain the dis inter brief string. Enable the system to execute the actions in the policy without executing the command that triggers the policy.
<Sysname>system-view
[Sysname-rmt-test] event cli async skip mode execute pattern dis inter brief
# Configure a CLI-defined policy to monitor the use of the Tab key at command lines that contain the dis inter brief string. Enable the system to execute the actions in the policy and display the complete parameter when Tab is pressed at a policy-matching command line.
[Sysname-rmt-test] event cli async mode tab pattern dis inter brief
# Configure a CLI-defined policy to monitor the use of the question mark (?) at command lines that contain the dis inter brief string. Enable the system to execute a policy-matching command line only if the actions in the policy are executed successfully when a question mark is entered at the command line.
[Sysname-rmt-test] event cli sync mode help pattern dis inter brief
event interface
Use event interface to configure an interface event for a CLI-defined monitor policy.
event interface interface-type interface-number monitor-obj monitor-obj start-op start-op start-val start-val restart-op restart-op restart-val restart-val [ interval interval ]
undo event
No interface events are configured.
monitor-obj monitor-obj: Specifies the traffic statistic to be monitored on the interface. For keywords available for the monitor-obj argument, see Table 2.
start-op start-op: Specifies the operator for comparing the monitored traffic statistic with the start threshold. The start threshold is crossed if the comparison result meets the condition. For keywords available for the start-op argument, see Table 3.
start-val start-val: Specifies the start threshold to be compared with the monitored traffic statistic. The value range is 0 to 4294967295.
restart-op restart-op: Specifies the operator for comparing the monitored traffic statistic with the restart threshold. The restart threshold is crossed if the comparison result meets the condition. For keywords available for the restart-op argument, see Table 3.
restart-val restart-val: Specifies the restart threshold to be compared with the monitored traffic statistic. The value range is 0 to 4294967295.
interval interval: Specifies the interval to sample the monitored traffic statistic for a comparison. The value range is 1 to 4294967295 seconds. The default is 300 seconds.
Table 2 Monitored objects
Monitored traffic statistic
input-drops
Number of discarded incoming packets.
input-errors
Number of incoming error packets.
output-drops
Number of discarded outgoing packets.
output-errors
Number of outgoing error packets.
rcv-bps
Receive rate, in bps.
rcv-broadcasts
Number of incoming broadcasts.
rcv-pps
Receive rate, in packets per second.
tx-bps
Transmit rate, in bps.
tx-pps
Transmit rate, in packets per second.
Table 3 Comparison operators
Comparison operator
eq
Equal to.
ge
Greater than or equal to.
gt
Greater than.
le
Less than or equal to.
lt
Less than.
ne
Not equal to.
Use interface event monitor policies to monitor traffic statistics on an interface.
EAA executes an interface event policy when the monitored interface traffic statistic crosses the start threshold in the following situations:
·     The statistic crosses the start threshold for the first time.
·     The statistic crosses the start threshold each time after it crosses the restart threshold.
The following is the interface event monitor process of EAA:
1.     Compares the traffic statistic sample with the start threshold at sampling intervals until the start threshold is crossed.
2.     Executes the policy.
3.     Compares the traffic statistic sample with the restart threshold at sampling intervals until the restart threshold is crossed.
4.     Compares the traffic statistic sample with the start threshold at sampling intervals until the start threshold is crossed.
5.     Executes the policy again.
This process cycles for the monitor policy to be executed and re-executed.
# Configure a CLI-defined policy to monitor the incoming error packet statistic on GigabitEthernet 1/0/1 every 60 seconds. Set the start threshold to 1000 and the restart threshold to 50. Enable EAA to execute the policy when the statistic exceeds 1000 for the first time. Enable EAA to re-execute the policy if the statistic exceeds 1000 each time after the statistic has dropped below 50.
[Sysname-rtm-test] event interface gigabitethernet 1/0/1 monitor-obj input-errors start-op gt start-val 1000 restart-op lt restart-val 50 interval 60
event process
Use event process to configure a process event for a CLI-defined monitor policy.
undo event
No process events are configured.
exception: Monitors the specified process for exceptional events. EAA executes the policy when an exception occurs to the monitored process.
restart: Monitors the specified process for restart events. EAA executes the policy when the monitored process restarts.
shutdown: Monitors the specified process for shutdown events. EAA executes the policy when the monitored process is shut down.
start: Monitors the specified process for start events. EAA executes the policy when the monitored process starts.
name process-name: Specifies a user-mode process by its name. The process can be one that is running or not running. If you do not specify a name, this command monitors all use-mode processes.
instance instance-id: Specifies a process instance ID in the range of 0 to 4294967295. The instance ID can be one that has not been created yet. If you specify an instance, EAA only monitors the process instance. If you do not specify an instance, EAA monitors all instances of the process.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command applies to the IRF fabric.
Use process event monitor policies to monitor process state changes. These changes can result from manual operations or automatic system operations.
# Configure a CLI-defined policy to monitor all instances of the process snmpd for restart events.
[Sysname-rtm-test] event process restart name snmpd
event snmp oid
Use event snmp oid to configure an SNMP event for a CLI-defined monitor policy.
undo event
No SNMP events are configured.
oid oid: Specifies the OID of the monitored MIB variable, a string of 1 to 256 characters.
monitor-obj { get | next }: Specifies the SNMP operation used for sampling variable values. The get keyword represents the SNMP get operation, and the next keyword represents the SNMP getNext operation.
start-op start-op: Specifies the operator for comparing the sampled value with the start threshold. The start threshold is crossed if the comparison result meets the condition. For keywords available for the start-op argument, see Table 3.
start-val start-val: Specifies the start threshold to be compared with the sampled value. The start-val argument can be any data type supported by SNMP, including numerals and character strings. The CLI online help system displays the value range as character strings of 1 to 512 characters. If the threshold value contains spaces, you must enclose the value in quotation marks (" ").
restart-op op: Specifies the operator for comparing the sampled value with the restart threshold. The restart threshold is crossed if the comparison result meets the condition. For keywords available for the start-op argument, see Table 3.
restart-op restart-val: Specifies the restart threshold to be compared with the sampled value. The restart-val argument can be any data type supported by SNMP, including numerals and character strings. The CLI online help system displays the value range as character strings of 1 to 512 characters. If the threshold value contains spaces, you must enclose the value in quotation marks (" ").
interval interval: Specifies the sampling interval in the range of 1 to 4294967295 seconds. The default is 300 seconds.
Use SNMP event monitor policy to monitor value changes of MIB variables.
EAA executes an SNMP event policy when the monitored MIB variable's value crosses the start threshold in the following situations:
·     The monitored variable's value crosses the start threshold for the first time.
·     The monitored variable's value crosses the start threshold each time after it crosses the restart threshold.
The following is the SNMP event monitor process of EAA:
1.     Compares the variable sample with the start threshold at sampling intervals until the start threshold is crossed.
3.     Compares the variable sample with the restart threshold at sampling intervals until the restart threshold is crossed.
4.     Compares the variable sample with the start threshold at sampling intervals until the start threshold is crossed.
# Configure a CLI-defined policy to get the value of the MIB variable 1.3.6.4.9.9.42.1.2.1.6.4 every five seconds. Set the start threshold to 1 and the restart threshold to 2. Enable EAA to execute the policy when the value changes to 1 for the first time. Enable EAA to re-execute the policy if the value changes to 1 each time after the value has changed to 2.
[Sysname] rtm cli-policy snmp
[Sysname-rtm-snmp] event snmp oid 1.3.6.4.9.9.42.1.2.1.6.4 monitor-obj get start-op eq start-val 1 restart-op eq restart-val 2 interval 5
event snmp-notification
Use event snmp-notification to configure an SNMP-Notification event for a CLI-defined policy.
Use undo event to remove the event in a CLI-defined policy.
undo event
No SNMP-Notification events are configured.
oid-val oid-val: Specifies the threshold to be compared with the sampled value. The oid-val argument can be any data type supported by SNMP, including numerals and character strings. The CLI online help system displays the value range as character strings of 1 to 512 characters. If the threshold value contains spaces, you must enclose the value in quotation marks (" ").
op op: Specifies the operator for comparing the sampled value with the threshold. The policy is executed if the comparison result meets the condition. For keywords available for the start-op argument, see Table 3.
drop: Drops the notification if the comparison result meets the condition. If this keyword is not specified, the system sends the notification.
Use SNMP-Notification event monitor policies to monitor variables in SNMP notifications.
EAA executes an SNMP-Notification event monitor policy when the value of the monitored variable in an SNMP notification meets the specified condition.
# Configure a CLI-defined policy to monitor SNMP notifications that contain the variable OID 1.3.6.1.4.1.318.2.8.3. Enable the system to drop an SNMP notification and execute the policy if the variable in the notification contains the "UPS:Returned from battery backup power" string.
[Sysname] rtm cli-policy snmp-notification
[Sysname-rtm-snmp-notification] event snmp-notification oid 1.3.6.1.4.1.318.2.8.3 oid-val “UPS:Returned from battery backup power” op eq drop
event syslog
Use event syslog to configure a Syslog event for a CLI-defined monitor policy.
event syslog priority level msg msg occurs times period period
undo event
No log event is configured.
priority level: Specifies the lowest severity level for matching log messages. The level argument can be an integer in the range of 0 to 7, or the word all, which represents any severity level from 0 to 7. A lower number represents higher priority level. For example, specify a severity level of 3 to match log messages from level 3 to level 0.
msg msg: Specifies a regular expression to match the message body, a string of 1 to 255 characters. The log message must use the H3C format. For more information about log message formats, see "Configuring the information center."
occurs times period period: Executes the policy if the number of log matches over an interval exceeds the limit. The times argument specifies the maximum number of log matches in the range of 1 to 32. The period argument specifies an interval in the range of 1 to 4294967295 seconds.
Use Syslog event monitor policies to monitor log messages.
EAA executes a Syslog event monitor policy when the number of matching logs over an interval reaches the limit.
EAA does not count log messages generated by the RTM module when it counts log matches.
# Configure a CLI-defined policy to monitor Syslog messages for level 3 to level 0 messages that contain the down string. Enable the policy to execute when five log matches are found within 6 seconds.
[Sysname] rtm cli-policy syslog
[Sysname-rtm-syslog] event syslog priority 3 msg down occurs 5 period 6
event track
Use event track to configure a track event for a CLI-defined monitor policy.
undo event
A CLI-defined policy does not contain a track event.
track-list: Specifies a space-separated list of up to 16 track items. Each item specifies a track entry number or a range of track entry numbers in the form of track-entry-number to track-entry-number. The value range for the track-entry-number argument is 1 to 1024.
state { negative | positive }: Monitors state change of the track entries.
·     negative: Triggers the policy when the states of the track entries change from Positive to Negative.
·     positive: Triggers the policy when the state of the track entries change from Negative to Positive.
suppress-time suppress-time: Sets a suppress time in the range of 1 to 4294967295, in seconds. The default value is 0.
Use track event monitor policies to monitor state change of track entries. If you specify one track entry for a policy, EAA triggers the policy when the state of the track entry changes from Positive to Negative or from Negative to Positive. If you specify multiple track entries for a policy, EAA triggers the policy only when the state of all the track entries changes from Positive (Negative) to Negative (Positive).
If you set a suppress time, the timer starts when the policy is triggered. The system does not process the messages that report the track entry state change from Positive (Negative) to Negative (Positive) until the timer times out.
For example, to automatically disconnect the sessions between the local device and its down link BGP peers when the sessions between the local device and its uplink BGP peers are disconnected, you can configure a track event monitor policy as follows:
·     Configure a track event for the policy and specify track entries to monitor the links between the local device and its uplink BGP peers.
·     Add CLI action peer ignore to the policy to disable BGP session establishment between the local device and its downlink BGP peers.
You can configure only one event entry for a monitor policy. If the monitor policy already contains an event entry, the new event entry replaces the old event entry.
# Create CLI-defined monitor policy test. Configure a track event that occurs when the states of track entry 1 to track entry 8 change from Positive to Negative. Set the suppress time to 180 seconds.
[Sysname-rtm-test] event track 1 to 8 state negative suppress-time 180
rtm cli-policy
Use rtm cli-policy to create a CLI-defined EAA monitor policy and enter its view.
Use undo rtm cli-policy to delete a CLI-defined monitor policy.
rtm cli-policy policy-name
undo rtm cli-policy policy-name
No CLI-defined monitor policy exists.
policy-name: Specifies the name of a CLI-defined monitor policy, a case-sensitive string of 1 to 63 characters.
You must create a CLI-defined monitor policy before you can use the CLI to configure settings in the policy.
You can assign the same policy name to a CLI-defined policy and a Tcl-defined policy, but you cannot assign the same name to policies that are the same type.
For a CLI-defined monitor policy to take effect, you must execute the commit command after you complete configuring the policy.
# Create a CLI-defined policy and enter its view.
commit
rtm environment
Use rtm environment to configure an EAA environment variable.
Use undo rtm environment to delete a user-defined EAA environment variable.
undo rtm environment var-name
The system provides the variables in Table 4. You cannot create, delete, or modify these system-defined variables.
Table 4 System-defined EAA environment variables by event type
Variable name
Any event:
_event_id
Event ID.
_event_type
Event type.
_event_type_string
Event type description.
_event_time
Time when the event occurs.
_event_severity
Severity level of an event.
CLI:
_cmd
Commands that are matched.
Syslog:
_syslog_pattern
Log message content.
Interface:
_ifname
Interface name.
SNMP:
_oid
OID of the MIB variable where an SNMP operation is performed.
_oid_value
Value of the MIB variable.
SNMP-Notification:
_oid
OID that is included in the SNMP notification.
Process:
_process_name
Process name.
var-name: Specifies an environment variable name, a string of 1 to 63 characters. A user-defined EAA environment variable name can contain digits, letters, and the underscore sign (_), but its leading character cannot be the underscore sign.
var-value: Specifies the variable value.
When you define an action, you can enter a variable name with a leading dollar sign ($variable_name) instead of entering a value for an argument. EAA will replace the variable name with the variable value when it performs the action.
For an action argument, you can specify a list of variable names in the form of $variable_name1$variable_name2...$variable_nameN.
# Create an environment variable: set its name to if and set its value to interface.
[Sysname] rtm environment if interface
rtm scheduler suspend
Use rtm scheduler suspend to suspend monitor policies.
Use undo rtm scheduler suspend to resume monitor policies.
This command disables all CLI-defined and Tcl-defined monitor policies except for the monitor policies that are running.
To revise the Tcl script of a policy, you must suspend all monitor policies first, and then resume the policies after you finish revising the script. The system cannot execute a Tcl-defined policy if you edit its Tcl script without suspending all monitor policies.
# Suspend monitor policies.
[Sysname] rtm scheduler suspend
rtm tcl-policy
Use rtm tcl-policy to create a Tcl-defined policy and bind it to a Tcl script file.
Use undo rtm tcl-policy to delete a Tcl policy.
undo rtm tcl-policy policy-name
No Tcl policies exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 63 characters.
tcl-filename: Specifies a .tcl script file name. The file name is case sensitive. You must make sure the file is available on a storage medium of the device.
Use this command to configure a monitor policy in Tcl.
This command both creates and enables the specified Tcl-defined monitor policy. To revise the Tcl script of a Tcl-defined policy, you must suspend all monitor policies first, and then resume the policies after you finish revising the script. The system cannot execute a Tcl-defined policy if you edit its Tcl script without suspending all monitor policies.
To bind a Tcl-defined policy to a different Tcl script file:
1.     Delete the Tcl policy.
2.     Create the Tcl policy again, and then bind it to the new Tcl script file.
You can assign the same policy name to a CLI-defined policy and a Tcl-defined policy. However, you cannot assign the same name to policies that are the same type.
# Create a Tcl policy and bind it to a Tcl script file.
[Sysname] rtm tcl-policy test test.tcl
running-time
Use running-time to configure the runtime of a CLI-defined policy.
Use undo running-time to restore the default.
running-time time
undo running-time
The runtime of a CLI-defined policy is 20 seconds.
time: Specifies the runtime of the CLI-defined policy, in the range of 0 to 31536000 seconds. If you specify 0, the policy can run forever until it is manually interrupted.
Policy runtime limits the amount of time that the monitor policy can run from the time it is triggered. When the runtime is reached, the system stops executing the policy even if the execution is not finished.
This setting prevents an incorrectly defined policy from running permanently to occupy resources.
# Set the runtime to 60 seconds for the CLI-defined policy test.
[Sysname-rtm-test] running-time 60
user-role
Use user-role to assign a user role to a CLI-defined policy.
Use undo user-role to remove a user role from a CLI-defined policy.
user-role role-name
undo user-role role-name
A monitor policy contains user roles that its creator had at the time of policy creation.
role-name: Specifies a user role, a string of 1 to 63 characters.
For EAA to execute an action in a monitor policy, you must assign the policy the user role that has access to the action-specific commands and resources. If EAA lacks access to an action-specific command or resource, EAA does not perform the action and all the subsequent actions.
For example, a monitor policy has four actions numbered from 1 to 4. The policy has user roles that are required for performing actions 1, 3, and 4, but it does not have the user role required for performing action 2. When the policy is triggered, EAA executes only action 1.
A monitor policy supports a maximum of 64 valid user roles. User roles added after this limit is reached do not take effect.
You cannot assign a monitor policy user roles that have higher privilege than the user roles you are logged in with.
# Assign user roles to a CLI-defined policy.
[Sysname-rtm-test] user-role admin
