10-Security
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10210-Security
06-User profile commands
06-User profile commands 38.45 KB
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices.
# (IRF-incapable devices.) Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Inbound:
      CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes)
      Policy: p1
    Outbound:
    User user_1:
      Authentication type: 802.1X
      Network attributes:
        Interface    : WLAN-BSS1/0/5
        MAC address  : 0000-1111-2222
      Failed action list:
        Inbound: Policy p1
        Inbound: CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes)
    User user_2:
      Authentication type: Portal
      Network attributes:
        IP address   : 172.16.187.16
        VPN          : N/A
        Service VLAN : 100
# Display configuration and online user information for all user profiles on IRF member device 1.
<Sysname> display user-profile slot 1
  User-Profile: aaa
    Inbound:
      Policy: p1
    Outbound:
    User user_1:
      Network attributes:
      Failed action list:
        Inbound: Policy p1
    User user_2:
      Network attributes:
        VPN          : N/A
        Service VLAN : 100
  User-Profile: bbb
    Inbound:
      CIR 512 (kbps), CBS 1062 (Bytes), EBS 0 (Bytes)
      Policy: p3
    User user_4:
    Network attributes:
      IP address   : 172.16.187.166
      VPN          : N/A
      Service VLAN : 100
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
Policy
Policy name.
User user_1
Username of a user account with which a user profile is associated.
If no user is online, User - is displayed.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     PPP—PPP authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
user-profile
Use user-profile to create a user profile and enter user profile view.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profile exists.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. A user profile name can only contain English letters, digits, and underscores (_), and it must start with an English letter. The name must be unique.
You can use the command to enter the view of an existing user profile.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
