07-Layer 3 - IP Routing
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10207-Layer 3 - IP Routing
01-Basic IP routing commands
01-Basic IP routing commands 153.49 KB
address-family ipv4
Use address-family ipv4 to create a RIB IPv4 address family and enter RIB IPv4 address family view.
Use undo address-family ipv4 to remove a RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family is created.
RIB view
# Create a RIB IPv4 address family and enter RIB IPv4 address family view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create a RIB IPv6 address family and enter RIB IPv6 address family view.
Use undo address-family ipv6 to remove a RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family is created.
RIB view
# Create a RIB IPv6 address family and enter RIB IPv6 address family view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table
Use display ip routing-table to display routing table information.
display ip routing-table [ verbose ]
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
         Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    GE1/0/1
192.168.1.0/24      Direct 0    0            192.168.1.40    Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.40    Vlan11
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.40    Vlan11
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that installed the route. The following route types are available:
·     DirectDirect route.
·     StaticStatic route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destination: 0.0.0.0/32
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h34m37s
       Cost: 0               Preference: 0
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active NoAdv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x10000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1000c        OrigNextHop: 127.0.0.1
      Label: NULL           RealNextHop: 127.0.0.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: InLoopBack0
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A              VpnPeerId: N/A
       Dscp: N/A
Destination: 1.1.1.0/24
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
      NibID: 0x10000003          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 192.168.47.4
      Label: NULL           RealNextHop: 192.168.47.4
  Tunnel ID: Invalid          Interface: GigabitEthernet1/0/1
       Dscp: N/A
Destinations
Routes
Number of routes.
Destination
Protocol
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Route tag.
Route state:
·     Active—Active unicast route.
·     Adv—Route that can be advertised.
·     Inactive—Inactive route.
·     NoAdv—Route that the router must not advertise.
·     Vrrp—Routes generated by VRRP. The device does not support this state in the current software version.
·     Nat—Routes generated by NAT.
·     TunE—Tunnel.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN that the route belongs to.
TableID
ID of the routing table.
OrigAs
Original AS number. The device does not support this field in the current software version.
NibID
ID of the next hop.
LastAs
Last AS number. The device does not support this field in the current software version.
AttrID
Attribute ID.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
BkTunnel ID
Backup tunnel ID.
BkInterface
Backup output interface.
FtnIndex
Index of the FTN entry.
TrafficIndex
Traffic index in the range of 1 to 64.
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. The device does not support this field in the current software version.
VpnPeerId
VPN peer ID of the route, in the range of 1 to 134217727. The device does not support this field in the current software version.
Dscp
DSCP priority of the route, in the range of 0 to 63.
Summary count
Number of routes.
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table acl acl-number [ verbose ]
acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   GE1/0/1
192.168.1.0/32      Direct 0    0            192.168.1.111   GE1/0/1
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   GE1/0/1
For command output, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 04h20m37s
      Flags: 0x10080        OrigNextHop: 192.168.1.111
      Label: NULL           RealNextHop: 192.168.1.111
       Dscp: N/A
Destination: 192.168.1.0/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 192.168.1.111
       Dscp: N/A
Destination: 192.168.1.111/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x10004        OrigNextHop: 127.0.0.1
       Dscp: N/A
Destination: 192.168.1.255/32
   Protocol: Direct
 Process ID: 0
       Dscp: N/A
For command output, see Table 2.
display ip routing-table ip-address
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table ip-address [ mask | mask-length ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask: Specifies the IP address mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
longer-match: Displays the route entry with the longest mask.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
·     display ip routing-table ip-address
¡     The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡     The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
·     display ip routing-table ip-address mask
¡     The system ANDs the entered destination IP address with the entered subnet mask.
¡     The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
·     display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest mask length is displayed.
·     display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask not greater than the entered subnet mask, the entry with the longest mask length is displayed.
·     display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the most specific route to the destination address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 1
# Display brief information about the most specific route to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 6
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1         GE1/0/2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         GE1/0/1
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
display ip routing-table prefix-list
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         GE1/0/2
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Routes Matched by Prefix list : test
Summary count : 1
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 1.1.1.2
      Label: NULL           RealNextHop: 1.1.1.2
  Tunnel ID: Invalid          Interface: GigabitEthernet1/0/2
  Connector: N/A
display ip routing-table protocol
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol. It can be direct or static.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 13
Direct Routing Table Status : <Active>
Summary count : 13
2.2.2.0/32          Direct 0    0            2.2.2.1         Vlan2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.255/32        Direct 0    0            2.2.2.1         Vlan2
192.168.80.0/24     Direct 0    0            192.168.80.10   GE1/0/1
192.168.80.0/32     Direct 0    0            192.168.80.10   GE1/0/1
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   GE1/0/1
Direct Routing Table Status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 2
Static Routing Table Status : <Active>
Summary count : 0
Static Routing Table Status : <Inactive>
Summary count : 2
1.2.3.0/24          Static 60   0            1.2.4.5        Vlan10
3.0.0.0/8           Static 60   0            2.2.2.2        GE1/0/1
display ip routing-table statistics
Use display ip routing-table statistics to display IPv4 route statistics.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      route       active      added       deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
Total      15          15          35          20
Proto
route
Number of routes installed by the protocol.
active
Number of active routes.
added
Number of routes added to the routing table after the router started up or the routing table was cleared most recently.
deleted
Number of routes marked as deleted, which will be cleared after a period.
Total
Total number of routes.
display ip routing-table summary
Use display ip routing-table summary to display brief routing table information.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 4
Max Active Route: 3072
Remain Active Route: 3058
Max ECMP
Maximum number of ECMP routes supported by the system.
Max Active Route
Maximum number of supported routes.
Remain Active Route
Number of the remaining inactive routes.
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
nib-id: Specifies a NIB by its ID in the range of 1 to FFFFFFFF.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name, which can be direct or static.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
   TopoNthp: Invalid
      NibID: 0x20000001        Sequence: 1
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
   TopoNthp: Invalid
Table 5 Command output
NibID
ID of the next hop.
Sequence
Sequence number of the next hop.
Type of the next hop.
Flushed
Indicates whether the route with the next hop has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
VPN to which the next hop belongs. The device does not support this field in the current software version.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface address.
TopoNthp
Topology to which the next hop belongs. 0 represents the base topology. The device does not support this field in the current software version.
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
   TopoNthp: Invalid
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0
   TopoNthp: Invalid
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
     Weight: 0
Table 6 Command output
Policy
Tunnel policy name. The device does not support this field in the current software version.
x nexthop (s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN name. The device does not support this field in the current software version.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
LocalAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. base represents the base topology. The device does not support this field in the current software version.
Weight
Weight of the ECMP route. The route is not an ECMP route if its weight is 0.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
   TopoNthp: Invalid
   TopoNthp: Invalid
Table 7 Command output
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
TopoNthp
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
 1 nexthop(s):
     Weight: 0
 1 nexthop(s):
     Weight: 0
Table 8 Command output
x nexthop(s)
PrefixIndex
Vrf
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
Topology
Topology name. The device does not support this field in the current software version.
Weight
display ipv6 routing-table
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ verbose ]
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Destination: FF00::/8                                    Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
Table 9 Command output
Destinations
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Preference
Protocol
Cost
Cost of the route.
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h23m02s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x20000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10004        OrigNextHop: ::1
      Label: NULL           RealNextHop: ::1
       Dscp: N/A
Destination: 12::/96
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m47s
      NibID: 0x20000003          LastAs: 0
      Flags: 0x10080        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: GigabitEthernet2/0/2
       Dscp: N/A
Destination: 12::1/128
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m45s
       Dscp: N/A
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000002          LastAs: 0
      Flags: 0x10084        OrigNextHop: ::
       Dscp: N/A
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000001          LastAs: 0
      Flags: 0x10014        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: NULL0
       Dscp: N/A
Table 10 Command output
Destination
Protocol
SubProtID
Age
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route state:
·     TunE—Tunnel.
OrigTblID
OrigVrf
Original VPN that the route belongs to. The device does not support this field in the current software version.
TableID
OrigAs
NibID
ID of the next hop.
LastAs
AttrID
Attribute ID.
Neighbor
Flags
Flags of the route.
OrigNextHop
RealNextHop
BkLabel
Backup label.
BkNexthop
Backup next hop.
BkTunnel ID
Backup tunnel ID.
BkInterface
FtnIndex
TrafficIndex
Connector
VpnPeerId
ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid. The device does not support this field in the current software version.
Dscp
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid.
Summary count
Number of routes.
display ipv6 routing-table acl
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table acl acl-number [ verbose ]
acl6-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : GE2/0/2                                     Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
For command output, see Table 9.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h29m12s
  Connector: N/A
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m57s
  Connector: N/A
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m55s
  Connector: N/A
   Protocol: Direct
 Process ID: 0
  Connector: N/A
   Protocol: Direct
 Process ID: 0
  Connector: N/A
For command output, see Table 10.
display ipv6 routing-table ipv6-address
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the route entry with the longest prefix.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
·     display ipv6 routing-table ipv6-address
¡     The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡     The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
·     display ipv6 routing-table ipv6-address prefix-length
¡     The system ANDs the entered destination IPv6 address with the entered prefix length.
¡     The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
·     display ipv6 routing-table ipv6-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest prefix length is displayed.
·     display ipv6 routing-table ipv6-address prefix-length longer-match
If the two operations yield the same result for multiple entries with a prefix length not greater than the entered prefix length, the entry with the longest prefix length is displayed.
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the most specific route to the destination IPv6 address 10::1 and prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 00h01m14s
       Cost: 0               Preference: 255
    TableID: 0x1                 OrigAs: 0
      NibID: 0x26000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2:2::3:4
      Flags: 0x10060        OrigNextHop: 2:2::3:4
      Label: NULL           RealNextHop: 2:2::3:4
  Connector: N/A
display ipv6 routing-table prefix-list
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h57m19s
  Connector: N/A
display ipv6 routing-table protocol
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Static Routing table Status : <Active>
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
Interface  : GE1/0/2                                     Cost      : 0
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Static Routing table Status : <Inactive>
Summary count : 0
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route statistics.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
Total      8           8           8           0
Table 11 Command output
Proto
route
active
added
deleted
Total
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 4
Table 12 Command output
Max ECMP
Max Active Route
Remain Active Route
display max-ecmp-num
Use display max-ecmp-num to display the maximum number of ECMP routes.
The following matrix shows the command and hardware compatibility:
Hardware series
Model
Command compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
Yes
WX2500H series
WX2510H
WX2540H
WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
Yes:
·     WX3010H
·     WX3010H-L
·     WX3024H
·     WX3024H-L
No: WX3010H-X
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
No
WX5500E series
WX5510E
WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
No
Access controller modules
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
No
# Display the maximum number of ECMP routes.
<Sysname> display max-ecmp-num
  Max-ECMP-Num in use: 6
  Max-ECMP-Num at the next reboot: 10
Table 13 Command output
Max-ECMP-Num in use
Maximum number of current ECMP routes in use.
Maximum number of ECMP routes at the next reboot of the device.
display rib nib
Use display rib nib to display next hop information in the RIB.
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
   TopoNthp: 0
      NibID: 0x10000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
   TopoNthp: 0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
   TopoNthp: 0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
   TopoNthp: 0
   Instance: abc
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
   TopoNthp: 0
     RefCnt: 6              FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
     Weight: 0
   TopoNthp: 0
     RefCnt: 13             FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
     Weight: 0
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
   TopoNthp: 0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: GE0/1/3          LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025               Topology: base
     Weight: 0
For command output, see Table 5 and Table 6.
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
   TopoNthp: 0
   TopoNthp: 0
Table 14 Command output
NibID
ID of the NIB.
Sequence
Type of the NIB.
Flushed
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface IP address.
TopoNthp
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
     RefCnt: 2              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
     RefCnt: 5              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
Table 15 Command output
x nexthop(s)
PrefixIndex
Vrf
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
Topology
Weight
RefCnt
FlushRefCnt
Flag
Version
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
max-ecmp-num
Use max-ecmp-num to set the maximum number of ECMP routes.
max-ecmp-num number
The maximum number of ECMP routes is 4.
number: Specifies the maximum number of ECMP routes. The value range for the number argument is 1 to 4.
Hardware series
Model
WX1800H series
WX1804H
WX1810H
WX1820H
Yes
WX2500H series
WX2510H
WX2540H
WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
Yes:
·     WX3010H
·     WX3010H-L
·     WX3024H
·     WX3024H-L
No: WX3010H-X
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
No
WX5500E series
WX5510E
WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
No
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20 LSUM1WCMX20RT
LSQM1WCMX40 LSUM1WCMX40RT
LSUM1WCME0
No
# Set the maximum number of ECMP routes to 4.
[Sysname] max-ecmp-num 4
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
After reboot, the maximum number of ECMP routes is 4.
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
protocol protocol lifetime seconds
undo protocol protocol lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 480 seconds.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
# Set the maximum lifetime for direct routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol direct lifetime 60
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol { protocol | all }
protocol: Clears route statistics for a routing protocol. It can be direct or static.
all: Clears route statistics for all IPv4 routing protocols.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol { protocol | all }
protocol: Clears route statistics for an IPv6 routing protocol. It can be direct or static.
all: Clears route statistics for all IPv6 routing protocols.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
