| 09-Port isolation commands | 36.67 KB |
The following matrix shows the feature and hardware compatibility:
Hardware series |
Model |
Port isolation compatibility |
WX1800H series |
WX1804H WX1810H WX1820H |
No |
WX2500H series |
WX2510H WX2540H WX2560H |
No |
WX3000H series |
WX3010H WX3010H-X WX3024H WX3010H-L WX3024H-L |
Yes: · WX3010H · WX3010H-X · WX3024H No: · WX3010H-L · WX3024H-L |
WX3500H series |
WX3508H WX3510H WX3520H WX3540H |
No |
WX5500E series |
WX5510E WX5540E |
No |
WX5500H series |
WX5540H WX5560H WX5580H |
No |
Access controller modules |
EWPXM1MAC0F EWPXM1WCME0 EWPXM2WCMD0F LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
No |
display port-isolate group
Use display port-isolate group to display port isolation group information.
# Display port isolation group information.
<Sysname> display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
GigabitEthernet1/0/2
Group ID |
ID of the isolation group. |
Group members |
Isolated ports in the isolation group. No ports indicates that the isolation group contains no isolated ports. |
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to the isolation group.
Use undo port-isolate enable to remove a port from the isolation group.
port-isolate enable
The port is not assigned to the isolation group.
The device supports only one isolation group that is automatically created as isolation group 1. Use this command to assign ports to the isolation group.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the isolation group.
[Sysname-GigabitEthernet1/0/1] port-isolate enable
[Sysname-GigabitEthernet1/0/2] port-isolate enable
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to the isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
