| 00-Preface | 83.54 KB |
Preface
This command reference describes Layer 2—LAN switching configuration commands.
· Hardware and software compatibility matrix
· Audience
Table 1 Hardware and software compatibility matrix
Model |
Product version |
WX1800H series |
· WX1804H · WX1810H · WX1820H |
· WX1804H-CMW710-E5208P03 · WX1810H-CMW710-E5215P01 · WX1820H-CMW710-E5208P03 |
WX2500H series |
· WX2510H · WX2540H · WX2560H |
· WX2510H-CMW710-R5215P01 · WX2540H-CMW710-R5215P01 · WX2560H-CMW710-R5215P01 |
WX3000H series |
· WX3010H · WX3010H-L · WX3010H-X · WX3024H · WX3024H-L |
· WX3010H-CMW710-R5215P01 · WX3010HL-CMW710-R5215P01 · WX3010HX-CMW710-R5215P01 · WX3024H-CMW710-R5215P01 · WX3024HL-CMW710-R5215P01 |
WX3500H series |
· WX3508H · WX3510H · WX3520H · WX3540H |
· WX3508H-CMW710-R5215P01 · WX3510H-CMW710-R5215P01 · WX3520H-CMW710-R5215P01 · WX3540H-CMW710-R5215P01 |
WX5500E series |
· WX5510E · WX5540E |
· WX5510E-CMW710-R5215P01 · WX5540E-CMW710-R5215P01 |
WX5500H series |
· WX5540H · WX5560H · WX5580H |
· WX5540H-CMW710-R5215P01 · WX5560H-CMW710-R5215P01 · WX5580H-CMW710-R5215P01 |
Access controller modules |
· EWPXM1MAC0F · EWPXM1WCME0 · EWPXM2WCMD0F · LSQM1WCMX20 · LSQM1WCMX40 · LSUM1WCME0 · LSUM1WCMX20RT · LSUM1WCMX40RT |
· WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 |
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
You can email your comments about product documentation to info@h3c.com.
We appreciate your comments.
