10-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS5130 SeriesConfigure & DeployConfiguration GuidesH3C S5130-HI Configuration Guides-R1118P02[R1122]-6W10210-Network Management and Monitoring Configuration Guide
14-NETCONF configuration
14-NETCONF configuration 192.81 KB
Configuring NETCONF· 1
Overview·· 1
NETCONF structure· 1
NETCONF message format 2
How to use NETCONF· 3
Protocols and standards· 3
FIPS compliance· 4
NETCONF configuration task list 4
Enabling NETCONF over SOAP· 4
Enabling NETCONF over SSH·· 5
Enabling NETCONF logging· 5
Establishing a NETCONF session· 5
Setting the NETCONF session idle timeout time· 5
Entering XML view·· 6
Exchanging capabilities· 6
Subscribing to event notifications· 6
Subscription procedure· 7
Example for subscribing to event notifications· 8
Locking/unlocking the configuration· 9
Locking the configuration· 9
Unlocking the configuration· 9
Example for locking the configuration· 10
Performing service operations· 11
Performing the get/get-bulk operation· 11
Performing the get-config/get-bulk-config operation· 12
Performing the edit-config operation· 13
All-module configuration data retrieval example· 13
Syslog configuration data retrieval example· 15
Example for retrieving a data entry for the interface table· 16
Example for changing the value of a parameter 17
Saving, rolling back, and loading the configuration· 18
Saving the configuration· 18
Rolling back the configuration based on a configuration file· 18
Rolling back the configuration based on a rollback point 19
Loading the configuration· 23
Example for saving the configuration· 23
Filtering data· 24
Example for filtering data with regular expression match· 27
Example for filtering data by conditional match· 28
Performing CLI operations through NETCONF· 29
Configuration procedure· 29
CLI operation example· 30
Retrieving NETCONF session information· 31
Terminating another NETCONF session· 32
Configuration procedure· 32
Configuration example· 32
Returning to the CLI 33
Appendix· 34
Appendix A Supported NETCONF operations· 34
Configuring NETCONF
Overview
Network Configuration Protocol (NETCONF) is an XML-based network management protocol with filtering capabilities. It provides programmable mechanisms to manage and configure network devices. Through NETCONF, you can configure device parameters, retrieve parameter values, and get statistics information.
In NETCONF messages, each data item is contained in a fixed element. This enables different devices of the same vendor to provide the same access method and the same result presentation method. For the devices of different vendors, XML mapping in NETCONF messages can achieve the same effect. For a network environment containing different devices regardless of vendors, you can develop a NETCONF-based NMS system to configure and manage devices in a simple and effective way.
NETCONF structure
NETCONF has four layers: content layer, operations layer, RPC layer, and transport protocol layer.
Table 1 NETCONF layers and XML layers
NETCONF layer
XML layer
Content
Configuration data, status data, and statistics information
The content layer contains a set of managed objects, which can be configuration data, status data, and statistics information. For information about the operable data, see the NETCONF XML API reference for the switch.
Operations
<get>,<get-config>,<edit-config>…
The operations layer defines a set of base operations invoked as RPC methods with XML-encoded parameters. NETCONF base operations include data retrieval operations, configuration operations, lock operations, and session operations. For the device supported operations, see "Appendix A Supported NETCONF operations."
RPC
<rpc>,<rpc-reply>
The RPC layer provides a simple, transport-independent framing mechanism for encoding RPCs. The <rpc> and <rpc-reply> elements are used to enclose NETCONF requests and responses (data at the operations layer and the content layer).
Transport Protocol
·     In non-FIPS mode:
Console/Telnet/SSH/HTTP/ HTTPS/TLS
·     In FIPS mode:
Console/SSH/HTTPS/TLS
The transport protocol layer provides reliable, connection-oriented, serial data links.
In non-FIPS mode, you can log in through Telnet, SSH, or the console port to perform NETCONF operations at the CLI. You can also log in through HTTP or HTTPS to perform NETCONF operations or perform NETCONF-over-SOAP operations.
In FIPS mode, all login methods are the same as in non-FIPS mode except that you cannot use HTTP or Telnet.
NETCONF
IMPORTANT
IMPORTANT:
When configuring NETCONF in XML view, you must add end mark ]]>]]> at the end of an XML message. Otherwise, the device cannot identify the message. Examples in this chapter do not have this end mark. Do add the end mark in actual operations.
All NETCONF messages are XML-based and comply with RFC 4741. Any incoming NETCONF messages must pass XML Schema check before it can be processed. If a NETCONF message fails XML Schema check, the device sends an error message to the client.
For information about the NETCONF operations supported by the device and the operable data, see the NETCONF XML API reference for the switch.
The following example shows a NETCONF message for getting all parameters of all interfaces on the device:
<?xml version="1.0" encoding="utf-8"?>
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
                 <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
NETCONF over SOAP
All NETCONF-over-SOAP messages are XML-based and comply with RFC 4741. NETCONF messages are contained in the <Body> element of SOAP messages. NETCONF-over-SOAP messages also comply with the following rules:
·     SOAP messages must use the SOAP Envelope namespaces.
·     SOAP messages must use the SOAP Encoding namespaces.
·     SOAP messages cannot contain the following information:
?     DTD reference.
?     XML processing instructions.
The following example shows a NETCONF-over-SOAP message for getting all parameters of all interfaces on the device:
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
  <env:Header>
    <auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
      <auth:AuthInfo>800207F0120020C</auth:AuthInfo>
    </auth:Authentication>
  </env:Header>
  <env:Body>
      <get-bulk>
            <Ifmgr>
              <Interfaces>
                     <Interface/>
              </Interfaces>
            </Ifmgr>
          </top>
        </filter>
      </get-bulk>
    </rpc>
  </env:Body>
</env:Envelope>
How to use NETCONF
You can use NETCONF to manage and configure the device by using the methods in Table 2.
Table 2 NETCONF methods for configuring the device
Configuration tool
Login method
Remarks
CLI
·     Console port
·     SSH
·     Telnet
To implement NETCONF operations, copy valid NETCONF messages to the CLI in XML view.
This method is suitable for R&D and test purposes.
Custom configuration tool
N/A
To use this method, you must enable NETCONF over SOAP.
By default, the device cannot interpret custom configuration tools' URLs. For the device to interpret these URLs, you must encode the NETCONF messages sent from a custom configuration tool in SOAP.
·     RFC 3339, Date and Time on the Internet: Timestamps
·     RFC 4741, NETCONF Configuration Protocol
·     RFC 4742, Using the NETCONF Configuration Protocol over Secure SHell (SSH)
·     RFC 4743, Using NETCONF over the Simple Object Access Protocol (SOAP)
·     RFC 5277, NETCONF Event Notifications
·     RFC 5381, Experience of Implementing NETCONF over SOAP
·     RFC 5539, NETCONF over Transport Layer Security (TLS)
·     RFC 6241, Network Configuration Protocol
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode (see Security Configuration Guide) and non-FIPS mode.
Task at a glance
(Optional.) Enabling NETCONF over SOAP
(Optional.) Enabling NETCONF over SSH
(Optional.) Enabling NETCONF logging
(Required.) Establishing a NETCONF session
(Optional.) Subscribing to event notifications
(Optional.) Locking/unlocking the configuration
(Optional.) Performing the get/get-bulk operation
(Optional.) Performing the get-config/get-bulk-config operation
(Optional.) Performing the edit-config operation
(Optional.) Saving, rolling back, and loading the configuration
(Optional.) Filtering data
(Optional.) Performing CLI operations through NETCONF
(Optional.) Retrieving NETCONF session information
(Optional.) Terminating another NETCONF session
(Optional.) Returning to the CLI
NETCONF over SOAP encapsulates NETCONF messages into SOAP messages and transmits the SOAP messages over HTTP or HTTPS. You can use a custom user interface to establish a NETCONF over SOAP session to the device and perform NETCONF operations.
To enable NETCONF over SOAP:
Step
Remarks
N/A
2.     Enable NETCONF over SOAP.
·     Enable NETCONF over SOAP over HTTP (not available in FIPS mode):
netconf soap http enable
·     Enable NETCONF over SOAP over HTTPS:
netconf soap https enable
By default, NETCONF over SOAP is disabled.
This feature allows users to use a client to perform NETCONF operations on the device through a NETCONF-over-SSH connection.
To enable NETCONF over SSH:
Step
Remark
N/A
2.     Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
3.     Specify a port to listen for NETCONF-over-SSH connections.
netconf ssh server port port number
By default, port 830 listens for NETCONF-over-SSH connections.
NETCONF logging generates logs for different NETCONF operation sources and NETCONF operations.
To enable NETCONF logging:
Step
Remarks
N/A
2.     Enable NETCONF logging.
netconf log source { all | { agent | soap | web } * } { { protocol-operation { all | { action | config | get | set | session | syntax | others } * } } | verbose }
By default, NETCONF logging is disabled.
After a NETCONF session is established, the device automatically sends its capabilities to the client. You must send the capabilities of the client to the device before you can perform any other NETCONF operations.
The device supports a maximum of 32 NETCONF sessions. If the upper limit is reached, new NETCONF users cannot access the device.
If no NETCONF packets are exchanged on a NETCONF session within the NETCONF session idle timeout time, the device tears down the session.
To set the NETCONF session idle timeout time:
Step
Remarks
N/A
2.     Set the NETCONF session idle timeout time.
netconf { soap | agent } idle-timeout minute
By default, the NETCONF session idle timeout time is as follows:
·     10 minutes for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
·     0 minutes for SSH sessions, Telnet sessions, and NETCONF over SSH sessions. The sessions never time out.
Entering XML view
Remarks
Enter XML view.
xml
Available in user view.
After you enter XML view, the client and the device exchange their capabilities before you can perform subsequent operations. The device automatically advertises its NETCONF capabilities to the client in a hello message as follows:
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities><capability>urn:ietf:params:netconf:base:1.1</capability><capability>urn:ietf:params:netconf:writable-running</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.1</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:h3c:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>]]>]]>
The <capabilities> parameter represents the capabilities supported by the device.
The <session-id> parameter represents the unique ID assigned to the current session.
After receiving the hello message from the device, copy the following message to notify the device of the capabilities (user-configurable) supported by the client:
  <capabilities>
    <capability>
     capability-set
   </capability>
 </capabilities>
</hello>
Use a pair of <capability> and </capability> tags to enclose each capability set.
After you subscribe to event notifications, the device sends event notifications to the NETCONF client when a subscribed event takes place on the device. The notifications include the code, group, severity, start time, and description of the events.
A subscription takes effect only on the current session. If the session is terminated, the subscription is automatically canceled.
You can send multiple subscription messages to subscribe to notification of multiple events.
# Copy the following message to the client to complete the subscription:
    <create-subscription  xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
         <stream>NETCONF</stream>
         <filter>
             <event xmlns="http://www.h3c.com/netconf/event:1.0">
                 <Code>code</Code>
                 <Group>group</Group>
                 <Severity>severity</Severity>
             </event>
         </filter>
         <startTime>start-time</startTime>
         <stopTime>stop-time</stopTime>
     </create-subscription>
</rpc>
The <stream> parameter represents the event stream type supported by the device. Only NETCONF is supported.
The <event> parameter represents an event to which you have subscribed.
The <code> parameter represents a mnemonic symbol.
The <group> parameter represents the module name.
The <severity> parameter represents the severity level of the event.
The <start-time> parameter represents the start time of the subscription.
The <stop-time> parameter represents the end time of the subscription.
After receiving the subscription request from the client, the device returns a response in the following format if the subscription is successful:
<rpc-reply message-id="100" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
    <ok/>
</rpc-reply>
If the subscription fails, the device returns an error message in the following format:
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<rpc-error>
   <error-type>error-type</error-type>
   <error-tag>error-tag</error-tag>
   <error-severity>error-severity</error-severity>
   <error-message xml:lang="en">error-message</error-message>
</rpc-error>
</rpc-reply>
For more information about error messages, see RFC 4741.
Network requirements
Configure a client to subscribe to all events with no time limitation. After the subscription is successful, all events on the device are sent to the client before the session between the device and client is terminated.
# Enter XML view.
<Sysname> xml
# Notify the device of the NETCONF capabilities supported on the client.
    <capabilities>
        <capability>
            urn:ietf:params:netconf:base:1.0
        </capability>
    </capabilities>
</hello>
# Subscribe to all events with no time limitation.
    <create-subscription xmlns ="urn:ietf:params:xml:ns:netconf:notification:1.0">
</rpc>
# If the client receives the following response, the subscription is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
    <ok/>
</rpc-reply>
# When another client (192.168.100.130) logs in to the device, the device sends a notification to the client that has subscribed to all events:
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
    <eventTime>2011-01-04T12:30:52</eventTime>
        <Group>SHELL</Group>
        <Code>SHELL_LOGIN</Code>
        <Slot>6</Slot>
        <Severity>Notification</Severity>
        <context>VTY logged in from 192.168.100.130.</context>
    </event>
</notification>
The device supports multiple users to simultaneously manage and monitor the device using NETCONF. During device configuration and maintenance or network troubleshooting, a user can lock the configuration to prevent other users from changing it. After that, only the user holding the lock can change the configuration, and other users can only read the configuration.
In addition, only the user holding the lock can release the lock. After the lock is released, other users can change the current configuration or lock the configuration. If the session of the user that holds the lock is terminated, the system automatically releases the lock.
# Copy the following text to the client to lock the configuration:
    <lock>
      <target>
        <running/>
      </target>
    </lock>
  </rpc>
After receiving the lock request, the device returns a response in the following format if the lock operation is successful:
     <ok/>
</rpc-reply>
# Copy the following text to the client to unlock the configuration:
    <unlock>
      <target>
        <running/>
      </target>
    </unlock>
  </rpc>
After receiving the unlock request, the device returns a response in the following format if the unlock operation is successful:
      <ok/>
</rpc-reply>
Lock the device configuration so that other users cannot change the device configuration.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Lock the configuration.
    <lock>
      <target>
        <running/>
      </target>
    </lock>
  </rpc>
If the client receives the following response, the lock operation is successful:
      <ok/>
</rpc-reply>
If another client sends a lock request, the device returns the following response:
<rpc-error>
  <error-type>protocol</error-type>
  <error-tag>lock-denied</error-tag>
  <error-severity>error</error-severity>
  <error-message xml:lang="en">Lock failed because the NETCONF lock is held by another session.</error-message>
  <error-info>
  </error-info>
  </rpc-error>
</rpc-reply>
The output shows that the lock operation failed because the client with session ID 1 held the lock, and only the client holding the lock can release the lock.
You can use NETCONF to perform service operations on the device, such as retrieving and modifying the specified information. The basic operations include get, get-bulk, get-config, get-bulk-config, and edit-config, which are used to retrieve all data, retrieve configuration data, and edit the data of the specified module. For more information, see the NETCONF XML API reference for the switch.
The get operation is used to retrieve device configuration and state information that match the conditions. In some cases, this operation leads to inefficiency.
The get-bulk operation is used to retrieve a number of data entries starting from the data entry next to the one with the specified index. One data entry contains a device configuration entry and a state information entry. The data entry quantity is defined by the count attribute, and the index is specified by the index attribute. The returned output does not include the index information. If you do not specify the index attribute, the index value starts with 1 by default.
If either of the following conditions occurs, the get-bulk operation retrieves all the rest data entries starting from the data entry next to the one with the specified index:
·     You do not specify the count attribute.
·     The number of matched data entries is less than the value of the count attribute.
# Copy the following text to the client to perform the get operation:
  <getoperation>
    <filter>
      <top xmlns=" http://www.h3c.com/netconf/data:1.0">
          Specify the module, submodule, table name, and column name
      </top>
    </filter>
  </getoperation>
</rpc>
Where, the <getoperation> parameter can be <get> or <get-bulk>. The <filter> element is used to filter data, and it can contain module name, submodule name, table name, and column name.
·     If the module name and the submodule name are not provided, the operation retrieves the data for all modules and submodules. If a module name or a submodule name is provided, the operation retrieves the data for the specified module or submodule.
·     If the table name is not provided, the operation retrieves the data for all tables. If a table name is provided, the operation retrieves the data for the specified table.
·     If only the index column is provided, the operation retrieves the data for all columns. If the index column and other columns are provided, the operation retrieves the data for the index column and the specified columns.
The <get> and <get-bulk> messages are similar. A <get-bulk> message carries the count and index attributes. The following is a <get-bulk> message example:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get-bulk>
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:base="http://www.h3c.com/netconf/base:1.0">
        <Syslog>
            <Logs xc:count="5">
                   <Log>
                      <Index>10</Index>
                    </Log>
             </Logs>
        </Syslog>
      </top>
    </filter>
  </get-bulk>
</rpc>
Where, the count attribute complies with the following rules:
·     The count attribute can be placed in the module node and table node. In other nodes, it cannot be resolved.
·     When the count attribute is placed in the module node, a descendant node inherits this count attribute if the descendant node does not contain the count attribute.
After receiving the get-bulk request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0"?>
  <data>
     Device state and configuration data
  </data>
</rpc-reply>
The get-config and get-bulk-config operations are used to retrieve all non-default settings, which are configured by means of CLI and MIB. The <get-config> and <get-bulk-config> messages can contain the <filter> element for filtering data.
The <get-config> and <get-bulk-config> messages are similar. The following is a <get-config> message example:
  <get-config>
    <source>
      <running/>
    </source>
    <filter>
      <top xmlns="http://www.h3c.com/netconf/config:1.0">
          Specify the module name, submodule name, table name, and column name
      </top>
    </filter>
  </get-config>
</rpc>
After receiving the get-config request, the device returns a response in the following format if the operation is successful:
  <data>
    All data matching the specified filter
  </data>
</rpc-reply>
The edit-config operation supports the following operation attributes: merge, create, replace, remove, delete, default-operation, error-option, test-option, and incremental. For more information about these attributes, see "Appendix A Supported NETCONF operations."
# Copy the following text to perform the <edit-config> operation:
  <edit-config>
    <target><running></running></target>
<error-option>
   Default operation when an error occurs
</error-option>
    <config>
      </top>
    </config>
  </edit-config>
</rpc>
After receiving the edit-config request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0">
  <ok/>
</rpc-reply>
# Perform the get operation to verify that the current value of the parameter is the same as the value specified through the edit-config operation. (Details not shown.)
Retrieve configuration data for all modules.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Retrieve configuration data for all modules.
  <get-config>
    <source>
      <running/>
    </source>
  </get-config>
</rpc>
If the client receives the following text, the get-config operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
    <data>
            <Ifmgr>
                <Interfaces>
                    <Interface>
                        <IfIndex>1307</IfIndex>
                        <Shutdown>1</Shutdown>
                    </Interface>
                    <Interface>
                        <IfIndex>1308</IfIndex>
                    </Interface>
                    <Interface>
                        <IfIndex>1309</IfIndex>
                    </Interface>
                    <Interface>
                        <IfIndex>1311</IfIndex>
                            <VlanType>2</VlanType>
                    </Interface>
                    <Interface>
                        <IfIndex>1313</IfIndex>
                    </Interface>
                </Interfaces>
            </Ifmgr>
            <Syslog>
                <LogBuffer>
                    <BufferSize>120</BufferSize>
                </LogBuffer>
            </Syslog>
            <System>
                <Device>
                    <SysName>H3C</SysName>
                    <TimeZone>
                        <Zone>+11:44</Zone>
                        <ZoneName>beijing</ZoneName>
                    </TimeZone>
                </Device>
            </System>
        </top>
    </data>
</rpc-reply>
Retrieve configuration data for the Syslog module.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Retrieve configuration data for the Syslog module.
  <get-config>
    <source>
      <running/>
    </source>
        <Syslog/>
      </top>
    </filter>
  </get-config>
</rpc>
    <data>
            <Syslog>
                    <LogBuffer>
                    </LogBuffer>
            </Syslog>
        </top>
    </data>
</rpc-reply>
Retrieve a data entry for the interface table.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>urn:ietf:params:netconf:base:1.0</capability>
    </capabilities>
</hello>
# Retrieve a data entry for the interface table.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0">
    <get-bulk>
            <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:web="http://www.h3c.com/netconf/base:1.0">
                <Ifmgr>
                    <Interfaces web:count="1">
                    </Interfaces>
                </Ifmgr>
            </top>
        </filter>
    </get-bulk>
</rpc>
If the client receives the following text, the get-bulk operation is successful:
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <IfIndex>3</IfIndex>
            <Name>GigabitEthernet1/0/2</Name>
            <AbbreviatedName>GE1/0/2</AbbreviatedName>
            <PortIndex>3</PortIndex>
            <ifTypeExt>22</ifTypeExt>
            <ifType>6</ifType>
            <Description>GigabitEthernet 1/0/2 Interface</Description>
            <AdminStatus>2</AdminStatus>
            <OperStatus>2</OperStatus>
            <ConfigSpeed>0</ConfigSpeed>
            <ActualSpeed>100000</ActualSpeed>
            <ConfigDuplex>3</ConfigDuplex>
            <ActualDuplex>1</ActualDuplex>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
Change the log buffer size for the Syslog module to 512.
# Enter XML view.
<Sysname> xml
    <capabilities>
    </capabilities>
</hello>
# Change the log buffer size for the Syslog module to 512.
<edit-config>
    <target>
        <running/>
    </target>
    <config>
        <top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
            <Syslog>
                <LogBuffer>
                    <BufferSize>512</BufferSize>
                </LogBuffer>
            </Syslog>
        </top>
    </config>
</edit-config>
</rpc>
If the client receives the following text, the edit-config operation is successful:
    <ok/>
</rpc-reply>
Use NETCONF to save, roll back, or load the configuration.
# Copy the following text to the client to save the device configuration to the specified file:
<save>
 <file>Specify the configuration file name</file>
</save>
</rpc>
The name of the specified configuration file must start with the storage media name and end with the .cfg extension. The total length of the save path and file name must be no more than 191 characters. If the text includes the file column, you must specify the file name. The specified file will be used as the next-startup configuration file. If the text does not include the file column, the configuration is automatically saved to the default main next-startup configuration file.
After receiving the save request, the device returns a response in the following format if the save operation is successful:
      <ok/>
</rpc-reply>
# Copy the following text to the client to roll back the configuration:
<rollback>
</rollback>
</rpc>
After receiving the rollback request, the device returns a response in the following format if the rollback operation is successful:
      <ok/>
</rpc-reply>
You can roll back the running configuration based on a rollback point when one of the following situations occurs:
·     A NETCONF client sends a rollback request.
·     A NETCONF client stays idle longer than the rollback idle timeout time.
·     A NETCONF client is disconnected from the device.
To roll back the configuration based on a rollback point, perform the following tasks:
1.     Lock the system.
Multiple users might simultaneously use NETCONF to configure the device. As a best practice, lock the system before rolling back the configuration to prevent other users from modifying the running configuration.
2.     Mark the beginning of a rollback operation. For more information, see "Performing the save-point/begin operation."
3.     Configure the device. For more information, see "Performing the edit-config operation."
4.     Configure the rollback point. For more information, see "Performing the save-point/commit operation."
You can repeat this step to configure multiple rollback points.
5.     Roll back the configuration based on the rollback point. For more information, see "Performing the save-point/rollback operation."
The configuration can also be rolled back automatically when the NETCONF session idle time exceeds the rollback idle timeout time.
6.     End the rollback configuration. For more information, see "Performing the save-point/end operation."
7.     Release the lock.
# Copy the following text to the client to start the rollback configuration based on a rollback point:
      <save-point>
        <begin>
          <confirm-timeout>100</confirm-timeout>
       </begin>
      </save-point>
</rpc>
The <confirm-timeout> parameter specifies the rollback idle timeout time in the range of 1 to 65536 seconds (the default is 600 seconds). This parameter is optional.
After receiving the begin request, the device returns a response in the following format if the begin operation succeeds:
  <data>
    <save-point>
       <commit>
          <commit-id>1</commit-id>
       </commit>
    </save-point>
  </data>
</rpc-reply>
The system supports a maximum of 50 rollback points. When the limit is reached, you must specify the force attribute to overwrite the earliest rollback point.
# Copy the following text to the client to configure the rollback point:
  <save-point>
    <commit>
      <label>SUPPORT VLAN<label>
      <comment>vlan 1 to 100 and interfaces. Each vlan used for different custom as follows: ……</comment>
</commit>
  </save-point>
</rpc>
The <label> and <comment> parameters are optional.
After receiving the commit request, the device returns a response in the following format if the commit operation is successful:
  <data>
    <save-point>
       <commit>
          <commit-id>2</commit-id>
       </commit>
    </save-point>
  </data>
</rpc-reply>
  <save-point>
    <rollback>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </rollback>
  </save-point>
</rpc>
The <commit-id/> parameter uniquely identifies a rollback point.
The <commit-index/> parameters specifies 50 most recently configured rollback points. The value of 0 indicates the most recently configured one and 49 indicates the earliest configured one.
The <commit-label/> parameter exclusively specifies a label for a rollback point. The label is not required for a rollback point.
Specify one of these parameters to roll back the specified configuration. If no parameter is specified, this operation roll backs configuration based on the most recently configured rollback point.
  <ok></ok>
</rpc-reply>
# Copy the following text to the client to end the rollback configuration:
  <save-point>
    <end/>
  </save-point>
</rpc>
After receiving the end request, the device returns a response in the following format if the end operation is successful:
   <ok/>
</rpc-reply>
Performing the save-point/get-commits operation
# Copy the following text to the client to get the rollback point configuration records:
  <save-point>
    <get-commits>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </get-commits>
  </save-point>
</rpc>
Specify one of the <commit-id>, <commit-index>, and <commit-label> parameters to get the specified rollback point configuration records. If no parameter is specified, this operation gets records for all rollback point configuration. The following text is a <save-point>/<get-commits> request example:
  <save-point>
    <get-commits>
      <commit-label>SUPPORT VLAN</commit-label>
    </get-commits>
  </save-point>
</rpc>
After receiving the get commits request, the device returns a response in the following format if the get commits operation is successful:
   <data>
      <save-point>
         <commit-information>
           <CommitID>2</CommitID>
           <TimeStamp>Thu Oct 30 11:30:28 1980</TimeStamp>
           <UserName>test</UserName>
           <Label>SUPPORT VLAN</Label>
         </commit-information>
    </save-point>
  </data>
</rpc-reply>
Performing the save-point/get-commit-information operation
# Copy the following text to the client to get the system configuration data corresponding to a rollback point:
  <save-point>
    <get-commit-information>
         <commit-id/>
         <commit-index/>
         <commit-label/>
    <compare-information>
         <commit-id/>
         <commit-index/>
         <commit-label/>
    </compare-information
    </get-commit-information>
  </save-point>
</rpc>
Specify one of the <commit-id>, <commit-index>, and <commit-label> parameters to get the configuration data corresponding to the specified rollback point. The <compare-information> parameter is optional. If no parameter is specified, this operation gets the configuration data corresponding to the most recently configured rollback point. The following text is a <save-point>/< get-commit-information> request example:
  <save-point>
  </save-point>
</rpc>
After receiving the get-commit-information request, the device returns a response in the following format if the get-commit-information operation is successful:
   <data>
     <save-point>
           <content>
              interface vlan 1
           </content>
     </save-point>
   </data>
</rpc-reply>
After you perform the load operation, the loaded settings are merged into the current configuration:
·     New settings are directly loaded.
·     Settings that already exist in the current configuration are replaced by those loaded from the configuration file.
# Copy the following text to the client to load a configuration file for the device:
  <load>
  </load>
</rpc>
After receiving the load request, the device returns a response in the following format if the load operation is successful:
      <ok/>
</rpc-reply>
Save the current configuration to configuration file my_config.cfg.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Save the configuration of the device to configuration file my_config.cfg.
    <save>
   <file>my_config.cfg</file>
</save>
</rpc>
If the client receives the following response, the save operation is successful:
      <ok/>
</rpc-reply>
Filtering data
You can define a filter with the <filter> element to filter information when you perform a get, get-bulk, get-config, or get-bulk-config operation. Data filtering mechanisms include full match, regular expression match, conditional match, and table-based match.
·     Full match
You can specify an element value in an XML message to implement full match. If multiple element values are provided, the system returns the data that matches all the specified values.
# Copy the following text to the client to retrieve the configuration data of all interfaces in UP state:
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <AdminStatus>1</AdminStatus>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
You can also specify an attribute name that is the same as a column name of the current table at the row to implement full match. The system returns only configuration data that matches this attribute name. The XML message equivalent to the above element-value-based full match is as follows:
  <get>
      <top xmlns="http://www.h3c.com/netconf/data:1.0"xmlns:data=" http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
            <Interface data:AdminStatus="1"/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
The above examples show that both element-value-based full match and attribute-name-based full match can retrieve the same index and column information for all interfaces in up state.
·     Regular expression match
To implement a complex data filtering with characters, you can add a regExp attribute for a specific element.
# Copy the following text to the client to retrieve the descriptions of interfaces, of which all the characters must be upper-case letters from A to Z:
<rpc message-id="1-0" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0">
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description h3c:regExp="[A-Z]*"/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
·     Conditional match
To implement a complex data filtering with digits and character strings, you can add a match attribute for a specific element. Table 3 lists the conditional match operators.
Table 3 Conditional match operators
Operation
Operator
Remarks
More than
match="more:value"
More than the specified value. The supported data types include date, digit, and character string.
Less than
match="less:value"
Less than the specified value. The supported data types include date, digit, and character string.
Not less than
match="notLess:value"
Not less than the specified value. The supported data types include date, digit, and character string.
Not more than
match="notMore:value"
Not more than the specified value. The supported data types include date, digit, and character string.
Equal
match="equal:value"
Equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Not equal
match="notEqual:value"
Not equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Include
match="include:string"
Includes the specified string. The supported data types include only character string.
Not include
match="exclude:string"
Excludes the specified string. The supported data types include only character string.
Start with
match="startWith:string"
Starts with the specified string. The supported data types include character string and OID.
End with
match="endWith:string"
Ends with the specified string. The supported data types include only character string.
# Copy the following text to the client to retrieve extension information about the entity of which the CPU usage is more than 50%:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0">
  <get>
        <Device>
          <ExtPhysicalEntities>
            <Entity>
                <CpuUsage h3c:match="more:50"></CpuUsage>
            </Entity>
          </ExtPhysicalEntities>
        </Device>
      </top>
    </filter>
  </get>
</rpc>
·     Table-based match
You can specify a match criterion for the row attribute filter to implement a table-based match, for example, IP address filtering. For the table-based match to take effect, you must use this filtering method before full match, regular expression match, and conditional match.
Table-based match applies only to multi-instance tables with namespace http://www.h3c.com/netconf/base:1.0. Support for the table-based match varies by table. For more information, see NETCONF XML API documents.
# Copy the following text to the client to retrieve the longest data with IP address 1.1.1.0 and mask length 24 from the IPv4 routing table:
  <get>
        <Route>
         <Ipv4Routes>
           <RouteEntry h3c:filter="IP 1.1.1.0 MaskLen 24 longer"/>
         </Ipv4Routes>
        </Route>
      </top>
    </filter>
  </get>
</rpc>
Retrieve all data including colons in the Description column of the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Retrieve all data including colons in the Description column of the Interfaces table under the Ifmgr module.
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
                <Description  reg:regExp=":"/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
If the client receives the following text, the operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" message-id="100">
    <data>
            <Ifmgr>
                <Interfaces>
                    <Interface>
                        <IfIndex>2681</IfIndex>
                        <Description>GigabitEthernet1/0/1 Interface</Description>
                    </Interface>
                    <Interface>
                        <IfIndex>2682</IfIndex>
                        <Description>GigabitEthernet1/0/2 Interface</Description>
                    </Interface>
                    <Interface>
                        <IfIndex>2683</IfIndex>
                        <Description>GigabitEthernet1/0/3 Interface</Description>
                    </Interface>
                    <Interface>
                        <IfIndex>2684</IfIndex>
                        <Description>GigabitEthernet1/0/4 Interface</Description>
                    </Interface>
                 <Interface>
            </Ifmgr>
        </top>
    </data>
</rpc-reply>
Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
                <IfIndex nc:match="more:5000"/>
                <Name/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
    <data>
            <Ifmgr>
                <Interfaces>
                    <Interface>
                        <IfIndex>7241</IfIndex>
                        <Name>NULL0</Name>
                    </Interface>
                </Interfaces>
            </Ifmgr>
        </top>
    </data>
</rpc-reply>
You can enclose command lines in XML messages to configure the device.
# Copy the following text to the client to execute the commands:
      <CLI>
        <Execution>
          Commands
        </Execution>
      </CLI>
</rpc>
The <Execution> element can contain multiple commands, with one command on one line.
After receiving the CLI operation request, the device returns a response in the following format if the CLI operation is successful:
  <CLI>
    <Execution>
      <![CDATA[Responses to the commands]]>
    </Execution>
  </CLI>
</rpc-reply>
Configuration requirements
Send the display vlan command to the device.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Copy the following text to the client to execute the display vlan command:
      <CLI>
        <Execution>
          display vlan
        </Execution>
      </CLI>
</rpc>
  <CLI>
    <Execution><![CDATA[
<Sysname>display vlan
 Total VLANs: 1
 The VLANs include:
 1(default)
   </Execution>
  </CLI>
</rpc-reply>
You can use the get-sessions operation to retrieve NETCONF session information of the device.
# Copy the following message to the client to retrieve NETCONF session information from the device:
    <get-sessions/>
</rpc>
After receiving the get-sessions request, the device returns a response in the following format if the get-sessions operation is successful:
  <get-sessions>
    <Session>
      <SessionID>Configuration session ID </SessionID>
      <Line>line information</Line>
      <UserName>Name of the user creating the session</UserName>
      <Since>Time when the session was created</Since>
      <LockHeld>Whether the session holds a lock</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
For example, to get NETCONF session information:
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Copy the following message to the client to get the current NETCONF session information on the device:
    <get-sessions/>
</rpc>
If the client receives a message as follows, the operation is successful:
    <get-sessions>
        <Session>
            <SessionID>1</SessionID>
            <Line>vty0</Line>
            <UserName></UserName>
            <Since>2013-01-05T00:24:57</Since>
            <LockHeld>false</LockHeld>
        </Session>
    </get-sessions>
</rpc-reply>
The output shows an existing NETCONF session with session ID as 1. The login user type is vty0, the login time is 2013-01-05T00:24:57, and the user does not hold the lock of the configuration.
NETCONF allows one client to terminate the NETCONF session of another client. The client whose session is terminated returns to user view.
# Copy the following message to the client to terminate the specified NETCONF session:
     <kill-session>
      <session-id>
        Specified session-ID
      </session-id>
     </kill-session>
   </rpc>
After receiving the kill-session request, the device returns a response in the following format if the kill-session operation is successful:
      <ok/>
</rpc-reply>
The user whose session's ID is 1 terminates the session with session ID 2.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Terminate the session with session ID 2.
     <kill-session>
       <session-id>2</session-id>
     </kill-session>
   </rpc>
If the client receives the following text, the NETCONF session with session ID 2 has been terminated, and the client with session ID 2 has returned from XML view to user view:
    <ok/>
</rpc-reply>
To return from XML view to the CLI, send the following close-session request:
        <close-session/>
   </rpc>
When the device receives the close-session request, it sends the following response and returns to CLI's user view:
   <ok/>
</rpc-reply>
Appendix
Table 4 lists the NETCONF operations available with Comware V7.
Table 4 NETCONF operations
Operation
XML example
get
Retrieves device configuration and state information.
To retrieve device configuration and state information for the Syslog module:
  <get>
        <Syslog>
        </Syslog>
      </top>
    </filter>
  </get>
</rpc>
get-config
Retrieves the non-default configuration data. If non-default configuration data does not exist, the device returns a response with empty data.
To retrieve non-default configuration data for the interface table:
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
                   <Interfaces>
                                      <Interface/>
                   </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
get-bulk
Retrieves a number of data entries (including device configuration and state information) starting from the data entry next to the one with the specified index.
To retrieve device configuration and state information for all interface:
  <get-bulk>
        <Ifmgr>
          <Interfaces xc:count="5" xmlns:xc=" http://www.h3c.com/netconf/base:1.0">
                 <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
get-bulk-config
Retrieves a number of non-default configuration data entries starting from the data entry next to the one with the specified index.
To retrieve non-default configuration for all interfaces:
  <get-bulk-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk-config>
</rpc>
edit-config:
incremental
Adds configuration data to a column without affecting the original data.
The incremental attribute applies to a list column such as the vlan permitlist column.
You can use the incremental attribute for edit-config operations except for the replace operation.
Support for the incremental attribute varies by module. For more information, see NETCONF XML API documents.
To add VLANs 1 through 10 to an untagged VLAN list that has untagged VLANs 12 through 15:
xmlns:h3c=" http://www.h3c.com/netconf/base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
        <VLAN xc:operation="merge">
          <HybridInterfaces>
            <Interface>
              <IfIndex>262</IfIndex>
              <UntaggedVlanList  h3c: incremental="true">1-10</Description>
               </Interface>
          </HybridInterfaces>
        </VLAN>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: merge
Changes the running configuration.
To use the merge attribute in the edit-config operation, you must specify the operation target (on a specified level):
·     If the specified target exists, the operation directly changes the configuration for the target.
·     If the specified target does not exist, the operation creates and configures the target.
·     If the specified target does not exist and it cannot be created, an error message is returned.
To change the buffer size to 120:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"  xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
      <top xmlns="http://www.h3c.com/netconf/config:1.0"><Syslog xmlns="http://www.h3c.com/netconf/config:1.0" xc:operation="merge">
    <LogBuffer>
    </LogBuffer>
</Syslog>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: create
Creates a specified target. To use the create attribute in the edit-config operation, you must specify the operation target.
·     If the table supports target creation and the specified target does not exist, the operation creates and then configures the target.
·     If the specified target exists, a data-exist error message is returned.
The XML data format is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to create.
edit-config: replace
Replaces the specified target.
·     If the specified target exists, the operation replaces the configuration of the target with the configuration carried in the message.
·     If the specified target does not exist but is allowed to be created, create the target and then apply the configuration of the target.
·     If the specified target does not exist and is not allowed to be created, the operation is not conducted and an invalid-value error message is returned.
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to replace.
edit-config: remove
Removes the specified configuration.
·     If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself.
·     If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target.
·     If the specified target does not exist, or the XML message does not specify any target, a success message is returned.
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to remove.
edit-config: delete
Deletes the specified configuration.
·     If the specified target does not exist, an error message is returned, showing that the target does not exist.
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to delete.
edit-config: default-operation
Modifies the current configuration of the device using the default operation method.
If you do not specify an operation attribute for an edit-config message, NETCONF uses one of the following default operation attributes: merge, create, delete, and replace. Your setting of the value for the <default-operation> element takes effect only once. If you do not specify an operation attribute and the default operation method for an <edit-config> message, merge is always applied.
·     merge—The default value for the <default-operation> element.
·     replace—Value used when the operation attribute is not specified and the default operation method is specified as replace.
·     none—Value used when the operation attribute is not specified and the default operation method is specified as none. If this value is specified, the edit-config operation is used only for schema verification rather than issuing a configuration. If the schema verification is passed, a successful message is returned. Otherwise, an error message is returned.
To issue an empty operation for schema verification purposes:
  <edit-config>
    <target>
      <running/>
    </target>
    <default-operation>none</default-operation>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Index>262</Index>
              <Description>222222</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: error-option
Determines the action to take in case of a configuration error.
The error-option element has one of the following values:
·     stop-on-error—Stops the operation on error and returns an error message. This is the default error-option value.
·     continue-on-error—Continues the operation on error and returns an error message.
·     rollback-on-error—Rolls back the configuration. This value is not supported by the current software version, and it is reserved for future use.
To issue the configuration for two interfaces with the error-option element value as continue-on-error:
  <edit-config>
    <target>
      <running/>
    </target>   <error-option>continue-on-error</error-option>
        <Ifmgr xc:operation="merge">
          <Interfaces>
            <Interface>
              <Index>262</Index>
              <Description>222</Description>
                <ConfigSpeed>1024</ConfigSpeed>
                <ConfigDuplex>1</ConfigDuplex>
            </Interface>
            <Interface>
              <Index>263</Index>
              <Description>333</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: test-option
Determines whether to issue a configuration item in the edit-configure operation. The test-option element has one of the following values:
·     test-then-set—Performs a validation test before attempting to set. If the validation test fails, the edit-config operation is not performed. This is the default test-option value.
·     set—Directly performs the set operation without the validation test.
·     test-only—Performs only a validation test without attempting to set. If the validation test succeeds, a successful message is returned. Otherwise, an error message is returned.
To issue the configuration for an interface for test purposes:
  <edit-config>
    <target>
      <running/>
</target>
<test-option>test-only</test-option>
          <Interfaces>
            <Interface>
              <Index>262</Index>
                <ConfigSpeed>100</ConfigSpeed>
               </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
action
Issues actions that are not for configuring data, for example, reset action.
To clear statistics information for all interfaces:
  <action>
    <top xmlns="http://www.h3c.com/netconf/action:1.0">
      <Ifmgr>
            <ClearAllIfStatistics>
                <Clear>
                </Clear>
        </ClearAllIfStatistics>
      </Ifmgr>
    </top>
  </action>
</rpc>
lock
Locks the configuration data that can be changed by the edit-config operation. Other settings are not limited by the lock operation.
This lock operation locks only the settings made through NETCONF sessions, rather than those through other protocols, for example, SNMP.
To lock the configuration:
 <lock>
    <target>
        <running/>
    </target>
</lock>
</rpc>
unlock
Unlocks the configuration, so NETCONF sessions can change device configuration.
When a NETCONF session is terminated, the related locked configuration is also unlocked.
To unlock the configuration:
<unlock>
    <target>
        <running/>
    </target>
</unlock>
</rpc>
get-sessions
Retrieves information about all NETCONF sessions in the system.
To retrieve information about all NETCONF sessions in the system:
<get-sessions/>
</rpc>
close-session
Terminates the NETCONF session for the current user, to unlock the configuration and release the resources (for example, memory) of this session. This operation logs the current user off the XML view.
To terminate the NETCONF session for the current user:
<close-session/>
</rpc>
kill-session
Terminates the NETCONF session for another user. This operation cannot terminate the NETCONF session for the current user.
To terminate the NETCONF session with session-id 1:
<kill-session>
  </kill-session>
</rpc>
CLI
Executes CLI operations. A request message encloses commands in the <CLI> element, and a response message encloses the command output in the <CLI> element.
NETCONF supports the following views:
·     Execution—User view.
·     Configuration—System view.
To execute a command in other views, specify the command for entering the specified view, and then the desired command.
To execute the display this command in system view:
  <CLI>
        <Configuration>display this</Configuration>
  </CLI>
</rpc>
save
Saves the running configuration. You can use the <file> element to specify a file for saving the configuration. If the <file> element does not exist, the running configuration is automatically saved to the main next-startup configuration file.
To save the running configuration to file test.cfg:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"> <save>
    <file>test.cfg</file>
  </save>
</rpc>
load
Loads the configuration. After the device finishes the load operation, the configuration in the specified file is merged into the current configuration of the device.
To merge the configuration in file a1.cfg to the current configuration of the device:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"> <load>
    <file>a1.cfg</file>
  </load>
</rpc>
rollback
Rolls back the configuration. To do so, you must specify the configuration file in the <file> element. After the device finishes the rollback operation, the current device configuration is totally replaced with the configuration in the specified configuration file.
To roll back the current configuration to the configuration in file 1A.cfg:
<rollback>
    <file>1A.cfg</file>
</rollback>
</rpc>
