12-Security Command Reference
HomeSupportRoutersH3C MSR5600 Router Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command References(V7)-R0707-6W30112-Security Command Reference
06-User profile commands
06-User profile commands 39.05 KB
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
In standalone mode:
display user-profile [ name profile-name ] [ slot slot-number ]
In IRF mode:
display user-profile [ name profile-name ] [ chassis chassis-number slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays user profile configuration and online user information on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays user profile configuration and online user information for all cards. (In IRF mode.)
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Inbound:
      CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
      Policy: p1
    Outbound:
    User user_1:
      Authentication type: Portal
      Network attributes:
        Interface    : GigabitEthernet1/0/1
        MAC address  : 0000-1111-2222
      Failed action list:
        Inbound: Policy p1
        Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
PIR
Peak information rate, in kbps.
Policy
Policy name.
User user_1
Username of a user account with which a user profile is associated.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     PPP—PPP authentication.
·     IPoE—IPoE authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. A user profile name can only contain English letters, digits, and underscores (_), and it must start with an English letter. The name must be unique.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
