07-Layer 3—IP Services Command Reference
HomeSupportRoutersH3C MSR5600 Router Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command References(V7)-R0707-6W30107-Layer 3—IP Services Command Reference
08-Multi-CPU packet distribution commands
08-Multi-CPU packet distribution commands 28.05 KB
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow | per-packet }
The device uses the flow-based policy.
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. This policy takes the first-in first-out rule.
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
