- 10-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L2VPN commands
- 09-MPLS L3VPN commands
- 10-L2VPN access to L3VPN or IP backbone commands
- 11-MPLS OAM commands
- 12-MPLS protection switching commands
- 13-MCE commands
- 14-VPLS commands
00-Preface | 81.27 KB |
Preface
This command reference describes the commands for configuring MPLS features, including basic MPLS, MPLS TE, MPLS L3VPN, and MPLS L2VPN.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the MSR 5600 routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
