01-Fundamentals
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5228P01)-6W10201-Fundamentals
Table of Contents
Related Documents
01-Text
01-Text 2.63 MB
Using the CLI 1
CLI views· 1
Entering system view from user view·· 2
Returning to the upper-level view from any view·· 2
Returning to user view·· 2
Accessing the CLI online help· 2
Using the undo form of a command· 3
Entering a command· 3
Editing a command line· 3
Entering a text or string type value for an argument 4
Entering an interface type· 5
Abbreviating commands· 5
Configuring and using command aliases· 5
Configuring and using command hotkeys· 6
Enabling redisplaying entered-but-not-submitted commands· 8
Understanding command-line error messages· 8
Using the command history feature· 8
Command buffering rules· 9
Repeating commands in the command history buffer for a line· 9
Controlling the CLI output 10
Pausing between screens of output 10
Numbering each output line from a display command· 10
Filtering the output from a display command· 11
Saving the output from a display command to a file· 13
Viewing and managing the output from a display command effectively· 14
Saving the running configuration· 15
Configuring RBAC· 16
Overview·· 16
Permission assignment 16
User role assignment 18
Configuration task list 19
Creating a user role· 19
Configuring user role rules· 20
Configuration restrictions and guidelines· 20
Configuration procedure· 20
Configuring a feature group· 21
Configuring resource access policies· 21
Configuring the user role interface policy· 22
Configuring the user role VLAN policy· 22
Assigning user roles· 22
Enabling the default user role feature· 23
Assigning user roles to remote AAA authentication users· 23
Assigning user roles to local AAA authentication users· 23
Assigning user roles to non-AAA authentication users on user lines· 24
Configuring temporary user role authorization· 24
Configuration restrictions and guidelines· 24
Configuring user role authentication· 26
Obtaining temporary user role authorization· 26
Displaying and maintaining RBAC settings· 26
RBAC configuration examples· 27
RBAC configuration example for local AAA authentication users· 27
RBAC configuration example for RADIUS authentication users· 29
RBAC temporary user role authorization configuration example (HWTACACS authentication) 31
RBAC temporary user role authorization configuration example (RADIUS authentication) 35
Troubleshooting RBAC·· 38
Local users have more access permissions than intended· 38
Login attempts by RADIUS users always fail 38
Login overview· 39
Using the console port for the first device access· 41
Configuring CLI login· 42
CLI overview·· 42
User lines· 42
Login authentication modes· 43
User roles· 43
Configuring local console login· 43
Disabling authentication for console login· 44
Configuring password authentication for console login· 44
Configuring scheme authentication for console login· 45
Configuring common console line settings· 45
Configuring Telnet login· 47
Configuring the device as a Telnet server 47
Using the device to log in to a Telnet server 51
Configuring SSH login· 52
Configuring the device as an SSH server 52
Using the device to log in to an SSH server 53
Displaying and maintaining CLI login· 54
Configuring Web login· 55
Configuring HTTP login· 55
Configuring HTTPS login· 56
Displaying and maintaining Web login· 58
Web login configuration examples· 58
HTTP login configuration example· 58
HTTPS login configuration example· 59
Accessing the device through SNMP· 62
Configuring RESTful access· 63
Configuring RESTful access over HTTP· 63
Configuring RESTful access over HTTPS· 63
Controlling user access to the device· 65
Controlling Telnet/SSH logins· 65
Configuration procedures· 65
Configuration example· 65
Controlling Web logins· 66
Configuring source IP-based Web login control 66
Logging off online Web users· 67
Configuration example· 67
Controlling SNMP access· 67
Configuration procedure· 67
Configuration example· 69
Configuring command authorization· 69
Configuration procedure· 69
Configuration example· 70
Configuring command accounting· 72
Configuration procedure· 72
Configuration example· 73
Configuring FTP· 75
Using the device as an FTP server 75
Configuring basic parameters· 75
Configuring authentication and authorization· 76
Manually releasing FTP connections· 77
Displaying and maintaining the FTP server 77
FTP server configuration example· 77
FTP server configuration example (on an IRF fabric) 78
Using the device as an FTP client 80
Establishing an FTP connection· 80
Managing directories on the FTP server 81
Working with files on the FTP server 81
Changing to another user account 82
Maintaining and troubleshooting the FTP connection· 82
Terminating the FTP connection· 83
Displaying command help information· 83
Displaying and maintaining the FTP client 83
FTP client configuration example· 84
FTP client configuration example (on an IRF fabric) 85
Configuring TFTP· 87
Configuring the device as an IPv4 TFTP client 87
Configuring the device as an IPv6 TFTP client 87
Managing file systems· 89
Overview·· 89
File systems· 89
Directories· 90
Files· 90
Specifying a directory name or file name· 91
Command and hardware compatibility· 91
File system management restrictions and guidelines· 92
Formatting a file system·· 92
Managing directories· 92
Displaying directory information· 92
Displaying the working directory· 93
Changing the working directory· 93
Creating a directory· 93
Renaming a directory· 93
Archiving or extracting directories· 93
Deleting a directory· 94
Setting the operation mode for directories· 94
Managing files· 94
Displaying file information· 94
Displaying the contents of a text file· 94
Renaming a file· 95
Copying a file· 95
Moving a file· 95
Compressing or decompressing a file· 95
Archiving or extracting files· 95
Deleting or restoring a file· 96
Deleting files from the recycle bin· 96
Calculating the file digest 96
Setting the operation mode for files· 96
Managing configuration files· 98
Overview·· 98
Configuration types· 98
Next-startup configuration file redundancy· 98
Configuration file formats· 99
Startup configuration file selection· 99
Configuration file content organization and format 99
Compatibility information· 99
Enabling configuration encryption· 99
Comparing configurations for their differences· 100
Saving the running configuration· 100
Restrictions and guidelines· 100
Using different methods to save the running configuration· 101
Configuring configuration rollback· 102
Configuration task list 102
Setting configuration archive parameters· 102
Enabling automatic configuration archiving· 103
Manually archiving the running configuration· 104
Rolling back configuration· 104
Specifying a next-startup configuration file· 105
Backing up the main next-startup configuration file to a TFTP server 105
Restoring the main next-startup configuration file from a TFTP server 106
Deleting a next-startup configuration file· 106
Displaying and maintaining configuration files· 107
Upgrading software· 108
Overview·· 108
Software types· 108
Software file naming conventions· 108
Comware image redundancy and loading procedure· 108
System startup process· 109
Command and hardware compatibility· 110
Upgrade methods· 110
Preparing for the upgrade· 111
Upgrade task list 111
Preloading the Boot ROM image to Boot ROM·· 111
Specifying startup images and completing the upgrade· 112
IRF-incapable devices· 112
IRF-capable devices· 113
Restoring or downgrading the Boot ROM image· 114
Displaying and maintaining software image settings· 114
Software upgrade example (IRF-incapable devices) 114
Network requirements· 114
Configuration procedure· 114
Software upgrade example (IRF-capable devices) 115
Network requirements· 115
Configuration procedure· 115
Managing the device· 117
Device management task list 117
Configuring the device name· 117
Configuring the system time· 117
Enabling displaying the copyright statement 119
Configuring banners· 119
Banner types· 119
Banner input methods· 120
Configuration procedure· 120
Rebooting the device· 121
Rebooting devices immediately at the CLI 121
Scheduling a device reboot 121
Scheduling a task· 122
Configuration restrictions and guidelines· 122
Configuration procedure· 122
Schedule configuration example· 124
Disabling password recovery capability· 129
Setting the port status detection timer 129
Monitoring CPU usage· 130
Setting memory alarm thresholds· 130
Configuring the temperature alarm thresholds· 132
Verifying and diagnosing transceiver modules· 132
Verifying transceiver modules· 132
Diagnosing transceiver modules· 133
Restoring the factory-default configuration· 133
Displaying and maintaining device management configuration· 134
Using Tcl 135
Using Tcl to configure the device· 135
Executing Comware commands in Tcl configuration view·· 135
Using Python· 137
Overview·· 137
Entering the Python shell 137
Executing a Python script 137
Python usage example· 137
Comware V7 extended Python API 139
Importing and using the Comware V7 extended Python API 139
Comware V7 extended Python API functions· 139
CLI class· 139
Transfer class· 141
API get_self_slot 142
API get_standby_slot 142
API get_slot_range· 143
Managing licenses· 144
Overview·· 144
License types· 144
License pool 144
Compatibility information· 145
Feature and hardware compatibility· 145
Command and hardware compatibility· 145
Restrictions and guidelines· 146
General restrictions and guidelines· 146
Licenses for different device types· 146
License file safety· 146
Licensing procedure summary· 147
Registering licenses· 147
Registering licenses for the first time· 147
Registering upgrade licenses· 150
Installing an activation file· 153
Transferring a license· 153
Compressing the license storage· 154
Displaying and maintaining licenses· 154
Using automatic configuration· 155
Overview·· 155
Automatic configuration task list 155
Configuring the file server 156
Preparing the files for automatic configuration· 156
Host name file· 156
Configuration files· 156
Script files· 157
Configuring the DHCP server 157
Configuration guidelines· 157
Configuring the DHCP server when an HTTP file server is used· 158
Configuring the DHCP server when a TFTP file server is used· 158
Configuring the DNS server 159
Configuring the gateway· 159
Preparing the interface used for automatic configuration· 159
Starting and completing automatic configuration· 159
Automatic configuration examples· 160
Automatic configuration using TFTP server 160
Automatic configuration using HTTP server and Tcl script 161
Automatic configuration using HTTP server and Python script 163
Index· 165
Using the CLI
At the command-line interface (CLI), you can enter text commands to configure, manage, and monitor the device. The following text is displayed when you access the CLI:
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
<Sysname>
You can use different methods to log in to the CLI, including through the console port, Telnet, and SSH. For more information about login methods, see "Login overview."
CLI views
Commands are grouped in different views by feature. To use a command, you must enter its view.
CLI views are hierarchically organized, as shown in Figure 1. Each view has a unique prompt, from which you can identify where you are and what you can do. For example, the prompt [Sysname-vlan100] shows that you are in VLAN 100 view and can configure attributes for that VLAN.
Figure 1 CLI views
You are placed in user view immediately after you log in to the CLI. The user view prompt is <Device-name>, where Device-name indicates the device name. The device name is Sysname by default. You can change it by using the sysname command.
In user view, you can perform the following tasks:
·     Perform basic operations including display, debug, file management, FTP, Telnet, clock setting, and reboot.
·     Enter system view. The system view prompt is [Device-name].
In system view, you can perform the following tasks:
·     Configure global settings (such as the daylight saving time, banners, and hotkeys) and some features.
·     Enter different feature views.
For example, you can perform the following tasks:
?     Enter interface view to configure interface parameters.
?     Enter VLAN view to add ports to the VLAN.
?     Enter user line view to configure login user attributes.
A feature view might have child views.
To display all commands available in a view, enter a question mark (?) at the view prompt.
Enter system view.
Return to the upper-level view from any view.
Executing the quit command in user view terminates your connection to the device.
In public key view, use the peer-public-key end command to return to system view.
To return directly to user view from any other view, use the return command or press Ctrl+Z.
Return directly to user view.
return
The CLI online help is context sensitive. Enter a question mark at any prompt or in any position of a command to display all available options.
To access the CLI online help, use one of the following methods:
·     Enter a question mark at a view prompt to display the first keyword of every command available in the view. For example:
<Sysname> ?
User view commands:
  archive           Archive configuration
  backup            Backup operation
  boot-loader       Software image file management
·     Enter a space and a question mark after a command keyword to display all available, subsequent keywords and arguments.
?     If the question mark is in the place of a keyword, the CLI displays all possible keywords, each with a brief description. For example:
<Sysname> terminal ?
  debugging  Enable to display debugging logs on the current terminal
  logging    Display logs on the current terminal
  monitor    Enable to display logs on the current terminal
?     If the question mark is in the place of an argument, the CLI displays the description for the argument. For example:
[Sysname] interface vlan-interface ?
  <1-4094>  Vlan-interface interface number
[Sysname] interface vlan-interface 1 ?
  <cr>
<1-4094> is the value range for the argument. <cr> indicates that the command is complete and you can press Enter to execute the command.
·     Enter an incomplete keyword string followed by a question mark to display all keywords starting with that string. The CLI also displays the descriptions for the keywords. For example:
<Sysname> b?
  bootrom      Update/read/backup/restore bootrom
<Sysname> display ftp?
  ftp         FTP module
  ftp-server  FTP server information
  ftp-user    FTP user information
Most configuration commands have an undo form for the following tasks:
·     Canceling a configuration.
·     Restoring the default.
·     Disabling a feature.
For example, the info-center enable command enables the information center. The undo info-center enable command disables the information center.
Entering a command
When you enter a command, you can perform the following tasks:
·     Use keys or hotkeys to edit the command line.
·     Use abbreviated keywords or keyword aliases.
To edit a command line, use the keys listed in Table 1 or the hotkeys listed in Table 4. When you are finished, you can press Enter to execute the command.
Table 1 Command line editing keys
Keys
Function
Common keys
If the edit buffer is not full, pressing a common key inserts a character at the cursor and moves the cursor to the right. The edit buffer can store up to 511 characters. Unless the buffer is full, all common characters that you enter before pressing Enter are saved in the edit buffer.
Backspace
Deletes the character to the left of the cursor and moves the cursor back one character.
Left arrow key (←)
Moves the cursor one character to the left.
Right arrow key (→)
Moves the cursor one character to the right.
Up arrow key (↑)
Displays the previous command in the command history buffer.
Down arrow key (↓)
Displays the next command in the command history buffer.
Tab
If you press Tab after entering part of a keyword, the system automatically completes the keyword.
·     If a unique match is found, the system displays the complete keyword.
·     If there is more than one match, press Tab multiple times to pick the keyword you want to enter.
·     If there is no match, the system does not modify what you entered but displays it again in the next line.
The total length of a command line cannot exceed 512 characters, including spaces and special characters.
The device supports the following special commands:
·     #–Used by the system in a configuration file as separators for adjacent sections.
·     version–Used by the system in a configuration file to indicate the software version information. For example, version 7.1.064, ESS 5103.
These commands are special because of the following reasons:
·     These commands are not intended for you to use at the CLI.
·     You can enter these commands in any view, or enter any values for them. For example, you can enter # abc or version abc. However, the settings do not take effect.
·     The device does not provide any online help information for these commands.
A text type argument value can contain printable characters other than the question mark (?).
A string type argument value can contain any printable characters except for the following characters:
·     Question mark (?).
·     Quotation mark (").
·     Backward slash (\).
·     Space.
A specific argument might have more requirements. For more information, see the relevant command reference.
To enter a printable character, you can enter the character or its ASCII code (in the range of 32 to 126).
You can enter an interface type in one of the following formats:
·     Full spelling of the interface type.
·     An abbreviation that uniquely identifies the interface type.
·     Acronym of the interface type.
For a command line, all interface types are case insensitive. Table 2 shows the full spellings and acronyms of interface types.
For example, to use the interface command to enter the view of interface GigabitEthernet 1/0/1, you can enter the command line in the following formats:
·     interface gigabitethernet 1/0/1
·     interface g 1/0/1
·     interface ge 1/0/1
·     interface gigabitethernet1/0/1
·     interface g1/0/1
·     interface ge1/0/1
Table 2 Full spellings and acronyms of interface types
Full spelling
Acronym
Bridge-Aggregation
BAGG
CMTunnel
CMTunnel
Dialer
Dia
GigabitEthernet
GE
LoopBack
Loop
M-GigabitEthernet
MGE
NULL
NULL
Ten-GigabitEthernet
XGE
Tunnel
Tun
Virtual-Template
VT
Vlan-interface
Vlan-int
You can enter a command line quickly by entering incomplete keywords that uniquely identify the complete command. In user view, for example, commands starting with an s include startup saved-configuration and system-view. To enter the command system-view, you need to type only sy. To enter the command startup saved-configuration, type st s.
You can also press Tab to complete an incomplete keyword.
You can configure an alias for a command or the starting keywords of commands. Then, you can use the alias to execute the command or commands. If the command or commands have undo forms, you can also use the alias to execute the undo command or commands.
For example, if you configure the alias siprt for display ip routing-table, you can enter siprt to execute the display ip routing-table command. If you configure the alias ship for display ip, you can use ship to execute all commands starting with display ip:
·     Enter ship routing-table to execute the display ip routing-table command.
·     Enter ship interface to execute the display ip interface command.
After you successfully execute a command by using an alias, the system saves the command, instead of the alias, to the running configuration.
The command string represented by an alias can include up to nine parameters. Each parameter starts with the dollar sign ($) and a sequence number in the range of 1 to 9. For example, you can configure the alias shinc for the display $1 | include $2 command. Then, you can enter shinc hotkey CTRL_C to execute the display hotkey | include CTRL_C command.
To use an alias for a command that has parameters, you must specify a value for each parameter. If you fail to do so, the system informs you that the command is incomplete and displays the command string represented by the alias.
The device has a set of system-defined command aliases, as listed in Table 3.
Table 3 System-defined command aliases
Command alias
Command or command keyword
access-list
acl
end
return
erase
delete
exit
hostname
sysname
logging
info-center
no
undo
show
display
write
save
To configure a command alias:
Step
Remarks
N/A
2.     Configure a command alias.
alias alias command
By default, the device has a set of command aliases, as listed in Table 3.
3.     (Optional.) Display command aliases.
display alias [ alias ]
This command is available in any view.
The system defines the hotkeys shown in Table 4 and provides five configurable command hotkeys. Pressing a command hotkey is the same as entering a command.
If a hotkey is also defined by the terminal software you are using to interact with the device, the terminal software definition takes effect.
To configure a command hotkey:
Step
Remarks
N/A
2.     Assign a command to a hotkey.
hotkey { ctrl_g | ctrl_l | ctrl_o | ctrl_t | ctrl_u } command
The following are the defaults:
·     Ctrl+G is assigned the display current-configuration command.
·     Ctrl+L is assigned the display ip routing-table command.
·     Ctrl+O is assigned the undo debugging all command.
·     No command is assigned to Ctrl+T or Ctrl+U.
3.     (Optional.) Display hotkeys.
display hotkey
Table 4 System-reserved hotkeys
Hotkey
Function
Ctrl+A
Moves the cursor to the beginning of a line.
Ctrl+B
Ctrl+C
Stops the current command.
Ctrl+D
Deletes the character at the cursor.
Ctrl+E
Moves the cursor to the end of a line.
Ctrl+F
Ctrl+H
Deletes the character to the left of the cursor.
Ctrl+K
Aborts the connection request.
Ctrl+N
Displays the next command in the history buffer.
Ctrl+P
Displays the previous command in the history buffer.
Ctrl+R
Redisplays the current line.
Ctrl+V
Pastes text from the clipboard.
Ctrl+W
Deletes the word to the left of the cursor.
Ctrl+X
Deletes all characters to the left of the cursor.
Ctrl+Y
Deletes all characters from the cursor to the end of the line.
Ctrl+Z
Returns to user view.
Ctrl+]
Terminates the current connection.
Esc+B
Moves the cursor back one word.
Esc+D
Deletes all characters from the cursor to the end of the word.
Esc+F
Moves the cursor forward one word.
Esc+N
Moves the cursor down one line. You can use this hotkey before pressing Enter.
Esc+P
Moves the cursor up one line. You can use this hotkey before pressing Enter.
Esc+<
Moves the cursor to the beginning of the clipboard.
Esc+>
Moves the cursor to the end of the clipboard.
Your input might be interrupted by system information output. If redisplaying entered-but-not-submitted commands is enabled, the system redisplays your input after finishing the output. You can then continue entering the command line.
To enable redisplaying entered-but-not-submitted commands:
Step
Remarks
N/A
2.     Enable redisplaying entered-but-not-submitted commands.
info-center synchronous
By default, the system does not redisplay entered-but-not-submitted commands.
For more information about this command, see Network Management and Monitoring Command Reference.
After you press Enter to submit a command, the command line interpreter examines the command syntax.
·     If the command passes syntax check, the CLI executes the command.
·     If the command fails syntax check, the CLI displays an error message.
Table 5 Common command-line error messages
Error message
Cause
% Unrecognized command found at '^' position.
The keyword in the marked position is invalid.
% Incomplete command found at '^' position.
One or more required keywords or arguments are missing.
% Ambiguous command found at '^' position.
The entered character sequence matches more than one command.
% Too many parameters.
The entered character sequence contains excessive keywords or arguments.
% Wrong parameter found at '^' position.
The argument in the marked position is invalid.
The system automatically saves commands successfully executed by a login user to the following two command history buffers:
·     Command history buffer for the user line.
·     Command history buffer for all user lines.
Table 6 Comparison between the two types of command history buffers
Item
Command history buffer for a user line
What kind of commands are saved in the buffer?
Commands successfully executed by the current user of the user line.
Commands successfully executed by all login users.
Cleared when the user logs out?
Yes.
No.
How to view buffered commands?
Use the display history-command command.
Use the display history-command all command.
How to recall a buffered command?
·     (Method 1.) Use the up or down arrow key (↑ or ↓) to navigate to the command in the buffer and press Enter.
·     (Method 2.) Use the repeat command. For more information, see "Repeating commands in the command history buffer for a line."
You cannot recall buffered commands.
How to set the buffer size?
Use the history-command max-size size-value command in user line view to set the buffer size.
By default, the buffer can store up to 10 commands.
You cannot set the buffer size.
By default, the buffer can store up to 1024 commands.
How to disable the buffer?
Setting the buffer size to 0 disables the buffer.
You cannot disable the buffer.
The system follows these rules when buffering commands:
·     If you use incomplete keywords when entering a command, the system buffers the command in the exact form that you use.
·     If you use an alias when entering a command, the system transforms the alias to the represented command or command keywords before buffering the command.
·     If you enter a command in the same format multiple times in succession, the system buffers the command only once. If you enter a command in different formats multiple times, the system buffers each command format. For example, display cu and display current-configuration are buffered as two entries but successive repetitions of display cu create only one entry.
·     To buffer a new command when a buffer is full, the system deletes the oldest command entry in the buffer.
You can recall and execute commands in the command history buffer for the current CLI session multiple times.
To repeat commands in the command history buffer for the current CLI session:
Remarks
Repeat commands in the command history buffer for the current CLI session.
repeat [ number ] [ count times ] [ delay seconds ]
This command executes commands in the order they were executed.
The system waits for your interaction when it repeats an interactive command.
This section describes the CLI output control features that help you identify the desired output.
By default, the system automatically pauses after displaying a maximum of 24 lines if the output is too long to fit on one screen. You can change the limit by using the screen-length screen-length command. For more information about this command, see Fundamentals Command Reference.
At a pause, the system displays ----more----. You can use the keys described in "Output controlling keys" to display more information or stop the display.
You can also disable pausing between screens of output for the current session. Then, all output is displayed at one time and the screen is refreshed continuously until the final screen is displayed.
Keys
Function
Space
Displays the next screen.
Enter
Displays the next line.
Ctrl+C
Stops the display and cancels the command execution.
<PageUp>
Displays the previous page.
<PageDown>
Displays the next page.
Disabling pausing between screens of output
To disable pausing between screens of output, execute the following command in user view:
Remarks
Disable pausing between screens of output for the current session.
screen-length disable
By default, a session uses the screen-length screen-length command settings in user line view.
This command is a one-time command and takes effect only for the current session.
You can use the | by-linenum option to prefix each display command output line with a number for easy identification.
Each line number is displayed as a 5-character string and might be followed by a colon (:) or hyphen (-). If you specify both | by-linenum and | begin regular-expression for a display command, a hyphen is displayed for all lines that do not match the regular expression.
To number each output line from a display command:
Number each output line from a display command.
display command | by-linenum
For example:
# Display information about VLAN 999, numbering each output line.
<Sysname> display vlan 999 | by-linenum
    1:  VLAN ID: 999
    2:  VLAN type: Static
    3:  Route interface: Configured
    4:  IPv4 address: 192.168.2.1
    5:  IPv4 subnet mask: 255.255.255.0
    6:  Description: For LAN Access
    7:  Name: VLAN 0999
    8:  Tagged ports:   None
    9:  Untagged ports:
   10:      GigabitEthernet1/0/1
You can use the | { begin | exclude | include } regular-expression option to filter the display command output.
·     begin—Displays the first line matching the specified regular expression and all subsequent lines.
·     exclude—Displays all lines not matching the specified regular expression.
·     include—Displays all lines matching the specified regular expression.
·     regular-expression—A case-sensitive string of 1 to 256 characters, which can contain the special characters described in Table 7.
The required filtering time increases with the complexity of the regular expression. To abort the filtering process, press Ctrl+C.
Table 7 Special characters supported in a regular expression
Characters
Meaning
Matches the beginning of a line.
"^u" matches all lines beginning with "u". A line beginning with "Au" is not matched.
Matches the end of a line.
"u$" matches all lines ending with "u". A line ending with "uA" is not matched.
. (period)
Matches any single character.
".s" matches "as" and "bs".
Matches the preceding character or string zero, one, or multiple times.
"zo*" matches "z" and "zoo", and "(zo)*" matches "zo" and "zozo".
Matches the preceding character or string one or multiple times.
"zo+" matches "zo" and "zoo", but not "z".
Matches the preceding or succeeding string.
"def|int" matches a line containing "def" or "int".
Matches the string in the parentheses, usually used together with the plus sign (+) or asterisk sign (*).
"(123A)" matches "123A".
"408(12)+" matches "40812" and "408121212", but not "408".
\N
Matches the preceding strings in parentheses, with the Nth string repeated once.
"(string)\1" matches a string containing "stringstring".
"(string1)(string2)\2" matches a string containing "string1string2string2".
"(string1)(string2)\1\2" matches a string containing " string1string2string1string2".
Matches a single character in the brackets.
"[16A]" matches a string containing 1, 6, or A; "[1-36A]" matches a string containing 1, 2, 3, 6, or A (- is a hyphen).
To match the character "]", put it immediately after "[", for example, []abc]. There is no such limit on "[".
Matches a single character that is not in the brackets.
"[^16A]" matches a string that contains one or more characters except for 1, 6, or A, such as "abc". A match can also contain 1, 6, or A (such as "m16"), but it cannot contain these three characters only (such as 1, 16, or 16A).
{n}
Matches the preceding character n times. The number n must be a nonnegative integer.
"o{2}" matches "food", but not "Bob".
{n,}
Matches the preceding character n times or more. The number n must be a nonnegative integer.
"o{2,}" matches "foooood", but not "Bob".
{n,m}
Matches the preceding character n to m times or more. The numbers n and m must be nonnegative integers and n cannot be greater than m.
" o{1,3}" matches "fod", "food", and "foooood", but not "fd".
Matches a string that starts with the pattern following \<. A string that contains the pattern is also a match if the characters preceding the pattern are not digits, letters, or underscores.
"\<do" matches "domain" and "doa".
Matches a string that ends with the pattern preceding \>. A string that contains the pattern is also a match if the characters following the pattern are not digits, letters, or underscores.
"do\>" matches "undo" and "cdo".
\b
Matches a word that starts with the pattern following \b or ends with the pattern preceding \b.
"er\b" matches "never", but not "verb" or "erase".
"\ber" matches "erase", but not "verb" or "never".
\B
Matches a word that contains the pattern but does not start or end with the pattern.
"er\B" matches "verb", but not "never" or "erase".
\w
Same as [A-Za-z0-9_], matches a digit, letter, or underscore.
"v\w" matches "vlan" and "service".
\W
Same as [^A-Za-z0-9_], matches a character that is not a digit, letter, or underscore.
"\Wa" matches "-a", but not "2a" or "ba".
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
"\\" matches a string containing "\", "\^" matches a string containing "^", and "\\b" matches a string containing "\b".
For example:
# Use | begin line for the display current-configuration command to match the first line of output that contains line to the last line of output.
<Sysname> display current-configuration | begin line
line con 0
 user-role network-admin
line vty 0 31
 authentication-mode scheme
 user-role network-operator
 ssh server enable
return
# Use | exclude Static for the display ip routing-table command to filter out static routes and display only the static routes.
<Sysname> display ip routing-table | exclude Static
Destinations : 13       Routes : 13
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
# Use | include wlan for the display current-configuration command to filter in entries that contain wlan.
<Sysname> display current-configuration | include wlan
wlan global-configuration
wlan ap-group default-group
A display command shows certain configuration and operation information of the device. Its output might vary over time or with user configuration or operation. You can save the output to a file for future retrieval or troubleshooting.
Use one of the following methods to save the output from a display command:
·     Save the output to a separate file. Use this method if you want to use one file for a single display command.
·     Append the output to the end of a file. Use this method if you want to use one file for multiple display commands.
To save the output from a display command to a file, use one of the following commands in any view:
Save the output from a display command to a separate file.
display command > filename
Append the output from a display command to the end of a file.
display command >> filename
For example:
# Save the VLAN 1 settings to a separate file named vlan.txt.
<Sysname> display vlan 1 > vlan.txt
# Verify that the VLAN 1 settings are saved to file vlan.txt.
<Sysname> more vlan.txt
VLAN ID: 1
 VLAN type: Static
 Description: VLAN 0001
 Tagged ports:   None
 Untagged ports:
    GigabitEthernet1/0/2
# Append the VLAN 999 settings to the end of file vlan.txt.
<Sysname> display vlan 999 >> vlan.txt
# Verify that the VLAN 999 settings are appended to the end of file vlan.txt.
VLAN ID: 1
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 999
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
You can use the following methods in combination to filter and manage the output from a display command:
·     Numbering each output line from a display command
·     Filtering the output from a display command
·     Saving the output from a display command to a file
To use multiple measures to view and manage the output from a display command effectively, execute the following command in any view:
View and manage the output from a display command effectively.
display command [ | [ by-linenum ] { begin | exclude | include } regular-expression ] [ > filename | >> filename ]
For example:
# Save the running configuration to a separate file named test.txt, with each line numbered.
<Sysname> display current-configuration | by-linenum > test.txt
# Append lines including snmp in the running configuration to the file test.txt.
<Sysname> display current-configuration | include snmp >> test.txt
# Display the first line that begins with user-group in the running configuration and all the following lines.
<Sysname> display current-configuration | by-linenum begin user-group
  114:  user-group system
  115-  #
  116-  return
// The colon (:) following a line number indicates that the line contains the string user-group. The hyphen (-) following a line number indicates that the line does not contain the string user-group.
To make your configuration take effect after a reboot, save the running configuration to a configuration file by using the save command in any view. This command saves all commands that have been successfully executed, except for the one-time commands. Typical one-time commands include display commands used for displaying information and reset commands used for clearing information.
For more information about the save command, see Fundamentals Command Reference.
Configuring RBAC
Overview
Role-based access control (RBAC) controls user access to items and system resources based on user roles. In this chapter, items include commands, Web pages, XML elements, and MIB nodes, and system resources include interfaces and VLANs.
RBAC assigns access permissions to user roles that are created for different job functions. Users are given permission to access a set of items and resources based on the users' user roles. Because user roles are persistent, in contrast to users, separating permissions from users enables easy permission authorization management. You only need to change the user role permissions, remove user roles, or assign new user roles in case of user changes. For example, you can change the user role permissions or assign new user roles to change the job responsibilities of a user.
Use the following methods to assign permissions to a user role:
·     Define a set of rules to determine accessible or inaccessible items for the user role. (See "User role rules.")
·     Configure resource access policies to specify which interfaces and VLANs are accessible to the user role. (See "Resource access policies.")
To use a command related to a system resource, a user role must have access to both the command and the resource.
For example, a user role has access to the qos apply policy command and access only to interface GigabitEthernet 1/0/1. When the user role is assigned, you can enter the interface view and use the qos apply policy command on the interface. However, you cannot enter the view of any other interfaces or use the command on any other interfaces. If the user role has access to all interfaces but does not have access to the qos apply policy command, you cannot use the command on any interfaces.
Any user role has access to the system-view, quit, and exit commands.
User role rules
User role rules permit or deny access to commands, Web pages, XML elements, or MIB nodes. You can define the following types of rules for different access control granularities:
·     Command rule—Controls access to a command or a set of commands that match a regular expression.
·     Feature rule—Controls access to the commands of a feature by command type.
·     Feature group rule—Controls access to the commands of features in a feature group by command type.
·     Web menu rule—Controls access to Web pages used for configuring the device. These Web pages are called Web menus.
·     XML element rule—Controls access to XML elements used for configuring the device.
·     OID rule—Controls SNMP access to a MIB node and its child nodes. An OID is a dotted numeric string that uniquely identifies the path from the root node to a leaf node.
The commands, Web menus, XML elements, and MIB nodes are controlled based on the following types:
·     Read—Commands, Web menus, XML elements, or MIB nodes that display configuration and maintenance information. For example, the display commands and the dir command.
·     Write—Commands, Web menus, XML elements, or MIB nodes that configure the features in the system. For example, the info-center enable command and the debugging command.
·     Execute—Commands, Web menus, XML elements, or MIB nodes that execute specific functions. For example, the ping command and the ftp command.
A user role can access the set of permitted commands, Web pages, XML elements, and MIB nodes specified in the user role rules. The user role rules include predefined (identified by sys-n) and user-defined user role rules. For more information about the user role rule priority, see "Configuring user role rules."
Resource access policies control access of a user role to system resources and include the following types:
·     Interface policy—Controls access to interfaces.
·     VLAN policy—Controls access to VLANs.
Resource access policies do not control access to the interface or VLAN options in the display commands. You can specify these options in the display commands if the options are permitted by any user role rule.
The system provides predefined user roles. These user roles have access to all system resources (interfaces and VLANs). However, their access permissions differ, as shown in Table 8.
Among all of the predefined user roles, only network-admin and level-15 can perform the following tasks:
·     Access the RBAC feature.
·     Change the settings in user line view, including the user-role, authentication-mode, protocol inbound, and set authentication password commands.
·     Create SNMP communities, users, and groups by using the snmp-agent community, snmp-agent usm-user, and snmp-agent group commands, respectively.
·     Create, modify, and delete local users and local user groups. The other user roles can only modify their own passwords if they have permissions to configure local users and local user groups.
The access permissions of the level-0 to level-14 user roles can be modified through user role rules and resource access policies. However, you cannot make changes on the predefined access permissions of these user roles. For example, you cannot change the access permission of these user roles to the display history-command all command.
Table 8 Predefined roles and permissions matrix
User role name
Permissions
Accesses all features and resources in the system, except for the display security-logfile summary, info-center security-logfile directory, and security-logfile save commands.
·     Accesses the display commands for features and resources in the system. To display all accessible commands of the user role, use the display role command.
·     Enables local authentication login users to change their own passwords.
·     Accesses the command used for entering XML view.
·     Accesses all read-type Web menu items.
·     Accesses all read-type XML elements.
·     Accesses all read-type MIB nodes.
level-n (n = 0 to 15)
·     level-0—Has access to diagnostic commands, including ping, tracert, ssh2, telnet, and super. Level-0 access rights are configurable.
·     level-1—Has access to the display commands of all features and resources in the system except for display history-command all. The level-1 user role also has all access rights of the level-0 user role. Level-1 access rights are configurable.
·     level-2 to level-8, and level-10 to level-14—Have no access rights by default. Access rights are configurable.
·     level-9—Has access to most of the features and resources in the system. If you are logged in with a local user account that has a level-9 user role, you can change the password in the local user account. The following are the major features and commands that the level-9 user role cannot access:
?     RBAC non-debugging commands.
?     Local users.
?     File management.
?     Device management.
?     The display history-command all command.
·     level-15—Has the same rights as network-admin.
security-audit
Security log manager. The user role has the following access rights to security log files:
·     Accesses the commands for displaying and maintaining security log files (for example, the dir, display security-logfile summary, and more commands).
·     Accesses the commands for managing security log files and security log file system (for example, the info-center security-logfile directory, mkdir, and security-logfile save commands).
For more information about security log management, see Network Management and Monitoring Configuration Guide. For more information about file system management, see "Managing file systems."
IMPORTANT IMPORTANT:
Only the security-audit user role has access to security log files. You cannot assign the security-audit user role to non-AAA authentication users.
guest-manager
Accesses only guest-related web pages, and has no access to commands.
You assign access rights to a user by assigning a minimum of one user role. The user can use the collection of items and resources accessible to all user roles assigned to the user. For example, you can access all interfaces to use the qos apply policy command if you are assigned the following user roles:
·     User role A denies access to the qos apply policy command and permits access only to interface GigabitEthernet 1/0/1.
·     User role B permits access to the qos apply policy command and all interfaces.
Depending on the authentication method, user role assignment has the following methods:
·     AAA authorization—If scheme authentication is used, the AAA module handles user role assignment.
?     If the user passes local authorization, the device assigns the user roles specified in the local user account.
?     If the user passes remote authorization, the remote AAA server assigns the user roles specified on the server. The AAA server can be a RADIUS or HWTACACS server.
·     Non-AAA authorization—When the user accesses the device without authentication or by passing password authentication on a user line, the device assigns user roles specified on the user line. This method also applies to SSH clients that use publickey or password-publickey authentication. User roles assigned to these SSH clients are specified in their respective device management user accounts.
For more information about AAA and SSH, see Security Configuration Guide. For more information about user lines, see "Login overview" and "Configuring CLI login."
Tasks at a glance
(Required.) Creating a user role
(Required.) Configuring user role rules
(Optional.) Configuring a feature group
(Required.) Configuring resource access policies:
·     Configuring the user role interface policy
·     Configuring the user role VLAN policy
(Optional.) Assigning user roles
(Optional.) Configuring temporary user role authorization
In addition to the predefined user roles, you can create a maximum of 64 custom user roles for granular access control.
To create a user role:
Step
Remarks
N/A
2.     Create a user role and enter user role view.
role name role-name
By default, the system has the following predefined user roles:
·     network-admin.
·     network-operator.
·     level-n (where n equals an integer in the range of 0 to 15).
·     security-audit.
·     guest-manager.
Among these user roles, only the permissions and descriptions of the level-0 to level-14 user roles are configurable.
3.     (Optional.) Configure a description for the user role.
By default, a user role does not have a description.
You can configure user role rules to permit or deny the access of a user role to specific commands, Web pages, XML elements, and MIB nodes.
When you configure RBAC user role rules, follow these restrictions and guidelines:
·     You can configure a maximum of 256 user-defined rules for a user role. The total number of user-defined user role rules cannot exceed 1024.
·     Any rule modification, addition, or removal for a user role takes effect only on users who are logged in with the user role after the change.
The following guidelines apply to non-OID rules:
·     If two user-defined rules of the same type conflict, the rule with the higher ID takes effect. For example, a user role can use the tracert command but not the ping command if the user role contains rules configured by using the following commands:
?     rule 1 permit command ping
?     rule 2 permit command tracert
?     rule 3 deny command ping
·     If a predefined user role rule and a user-defined user role rule conflict, the user-defined user role rule takes effect.
The following guidelines apply to OID rules:
·     The system compares an OID with the OIDs specified in user role rules, and it uses the longest match principle to select a rule for the OID. For example, a user role cannot access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
?     rule 1 permit read write oid 1.3.6
?     rule 2 deny read write oid 1.3.6.1.4.1
?     rule 3 permit read write oid 1.3.6.1.4
·     If the same OID is specified in multiple rules, the rule with the higher ID takes effect. For example, a user role can access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
?     rule 3 permit read write oid 1.3.6.1.4.1
To configure rules for a user role:
Step
Remarks
N/A
2.     Enter user role view.
role name role-name
N/A
3.     Configure rules for the user role.
·     Configure a command rule:
rule number { deny | permit } command command-string
·     Configure a feature rule:
rule number { deny | permit } { execute | read | write } * feature [ feature-name ]
·     Configure a feature group rule:
rule number { deny | permit } { execute | read | write } * feature-group feature-group-name
·     Configure a Web menu rule:
rule number { deny | permit } { execute | read | write } * web-menu [ web-string ]
·     Configure an XML element rule:
rule number { deny | permit } { execute | read | write } * xml-element [ xml-string ]
·     Configure an OID rule:
rule number { deny | permit } { execute | read | write } * oid oid-string
By default, a user-defined user role does not have any rules or access to any commands, Web pages, XML elements, or MIB nodes.
Repeat this step to add a maximum of 256 rules to the user role.
When you configure feature rules, you can specify only features available in the system. Enter feature names the same as the feature names are displayed, including the case.
Use feature groups to bulk assign command access permissions to sets of features. In addition to the predefined feature groups, you can create a maximum of 64 custom feature groups and assign a feature to multiple feature groups.
To configure a feature group:
Step
Remarks
N/A
2.     Create a feature group and enter feature group view.
role feature-group name feature-group-name
By default, the system has the following predefined feature groups:
·     L2—Includes all Layer 2 commands.
·     L3—Includes all Layer 3 commands.
These two groups are not user configurable.
3.     Add a feature to the feature group.
feature feature-name
By default, a feature group does not have any features.
Repeat this step to add multiple features to the feature group.
You can specify only features available in the system. Enter feature names the same as the feature names are displayed, including the case.
Every user role has one interface policy and VLAN policy. By default, these policies permit a user role to access all interfaces and VLANs. You can configure the policies of a user-defined user role or a predefined level-n user role to limit its access to interfaces and VLANs. The policy configuration takes effect only on users who are logged in with the user role after the configuration.
Step
Remarks
N/A
role name role-name
N/A
3.     Enter user role interface policy view.
interface policy deny
By default, the interface policy of the user role permits access to all interfaces.
This command denies the access of the user role to any interfaces if the permit interface command is not configured.
4.     (Optional.) Specify a list of interfaces accessible to the user role.
permit interface interface-list
By default, no accessible interfaces are configured in user role interface policy view.
Repeat this step to add multiple accessible interfaces.
Step
Remarks
N/A
role name role-name
N/A
3.     Enter user role VLAN policy view.
vlan policy deny
By default, the VLAN policy of the user role permits access to all VLANs.
This command denies the access of the user role to any VLANs if the permit vlan command is not configured.
4.     (Optional.) Specify a list of VLANs accessible to the user role.
permit vlan vlan-id-list
By default, no accessible VLANs are configured in user role VLAN policy view.
Repeat this step to add multiple accessible VLANs.
To control user access to the system, you must assign a minimum of one user role. Make sure a minimum of one user role among the user roles assigned by the server exists on the device. User role assignment procedure varies for remote AAA authentication users, local AAA authentication users, and non-AAA authentication users (see "User role assignment"). For more information about AAA authentication, see Security Configuration Guide.
The default user role feature assigns the default user role to AAA-authenticated users if the authentication server does not assign any user roles to the users. These users are allowed to access the system with the default user role.
You can specify any user role existing in the system as the default user role.
To enable the default user role feature for AAA authentication users:
Step
Remarks
N/A
2.     Enable the default user role feature.
role default-role enable [ role-name ]
By default, the default user role feature is disabled.
If you do not specify a user role, the default user role is network-operator.
If the no authorization method is used for local users, you must enable the default user role feature.
For remote AAA authentication users, user roles are configured on the remote authentication server. For information about configuring user roles for RADIUS users, see the RADIUS server documentation. For HWTACACS users, the role configuration must use the roles="role-1 role-2 … role-n" format, where user roles are space separated. For example, configure roles="level-0 level-1 level-2" to assign level-0, level-1, and level-2 to an HWTACACS user.
If the AAA server assigns the security-audit user role and other user roles to the same user, only the security-audit user role takes effect.
Configure user roles for local AAA authentication users in their local user accounts. Every local user has a default user role. If this default user role is not suitable, remove it.
If a local user is the only user with the security-audit user role, the user cannot be deleted.
The security-audit user role is mutually exclusive with other user roles.
·     When you assign the security-audit user role to a local user, the system requests confirmation to remove all the other user roles from the user.
·     When you assign the other user roles to a local user who has the security-audit user role, the system requests confirmation to remove the security-audit role from the user.
To assign a user role to a local user:
Step
Remarks
N/A
2.     Create a local user and enter local user view.
local-user user-name class { manage | network }
N/A
3.     Authorize the user to have a user role.
authorization-attribute user-role role-name
Repeat this step to assign a maximum of 64 user roles to the user.
By default, the network-operator user role is assigned to local users created by a network-admin or level-15 user.
Specify user roles for the following two types of login users on the user lines:
·     Users who use password authentication or no authentication.
·     SSH clients that use publickey or password-publickey authentication. User roles assigned to these SSH clients are specified in their respective device management user accounts.
For more information about user lines, see "Login overview" and "Configuring CLI login." For more information about SSH, see Security Configuration Guide.
To assign a user role to non-AAA authentication users on a user line:
Step
Remarks
N/A
2.     Enter user line view or user line class view.
·     Enter user line view:
line { first-num1 [ last-num1 ] | { console | vty } first-num2 [ last-num2 ] }
·     Enter user line class view:
line class { console | vty }
For information about the priority order and application scope of the settings in user line view and user line class view, see "Configuring CLI login."
3.     Specify a user role on the user line.
user-role role-name
Repeat this step to specify a maximum of 64 user roles on a user line.
By default, the network-admin user role is specified on the console user line, and the network-operator user role is specified on any other user line.
The device cannot assign the security-audit user role to non-AAA authentication users.
Temporary user role authorization allows you to obtain another user role without reconnecting to the device. This feature is useful when you want to use a user role temporarily to configure a feature.
Temporary user role authorization is effective only on the current login. This feature does not change the user role settings in the user account that you have been logged in with. The next time you are logged in with the user account, the original user role settings take effect.
When you configure temporary user role authorization, follow these guidelines:
·     To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. Table 9 describes the available authentication modes and configuration requirements.
·     If HWTACACS authentication is used, the following rules apply:
?     The device uses the entered username and password to request role authentication, and it sends the username to the server in the username or username@domain-name format. Whether the domain name is included in the username depends on the user-name-format command in the HWTACACS scheme.
?     To obtain a level-n user role, the user account on the server must have the target user role level or a level higher than the target user role. A user account that obtains the level-n user role can obtain any user role among level-0 through level-n.
?     To obtain a non-level-n user role, make sure the user account on the server meets the following requirements:
-     The account has a user privilege level.
-     The HWTACACS custom attribute is configured for the account in the form of allowed-roles="role". The variable role represents the target user role.
·     If RADIUS authentication is used, the following rules apply:
?     The device does not use the username you enter to request user role authentication. It uses a username in the $enabn$ format. The variable n represents a user role level, and a domain name is not included in the username. You can always pass user role authentication when the password is correct.
?     To obtain a level-n user role, you must create a user account for the level-n user role in the $enabn$ format on the RADIUS server. The variable n represents the target user role level. For example, to obtain the authorization of the level-3 user role, you can enter any username. The device uses the username $enab3$ to request user role authentication from the server.
?     To obtain a non-level-n user role, you must perform the following tasks:
-     Create the user account $enab0$ on the server.
-     Configure the cisco-av-pair attribute for the account in the form of allowed-roles="role". The variable role represents the target user role.
·     The device selects an authentication domain for user role authentication in the following order:
a.     The ISP domain included in the entered username.
b.     The default ISP domain.
·     If you execute the quit command after obtaining user role authorization, you are logged out of the device.
Table 9 User role authentication modes
Keywords
Authentication mode
local
Local password authentication only (local-only)
The device uses the locally configured password for authentication.
If no local password is configured for a user role in this mode, a console user can obtain the user role by either entering a string or not entering anything.
scheme
Remote AAA authentication through HWTACACS or RADIUS (remote-only)
The device sends the username and password to the HWTACACS or RADIUS server for remote authentication.
To use this mode, you must perform the following configuration tasks:
·     Configure the required HWTACACS or RADIUS scheme, and configure the ISP domain to use the scheme for the user. For more information, see Security Configuration Guide.
·     Add the user account and password on the HWTACACS or RADIUS server.
local scheme
Local password authentication first, and then remote AAA authentication (local-then-remote)
Local password authentication is performed first.
If no local password is configured for the user role in this mode, the device performs remote AAA authentication for console and VTY users.
scheme local
Remote AAA authentication first, and then local password authentication (remote-then-local)
Remote AAA authentication is performed first.
Local password authentication is performed in either of the following situations:
·     The HWTACACS or RADIUS server does not respond.
·     The remote AAA configuration on the device is invalid.
Step
Remarks
N/A
2.     Set an authentication mode.
super authentication-mode { local | scheme } *
By default, local-only authentication applies.
3.     (Optional.) Specify the default target user role for temporary user role authorization.
super default role role-name
By default, the default target user role is network-admin.
4.     Set a local authentication password for a user role.
super password [ role role-name ] [ { hash | simple } string ]
Use this step for local password authentication.
By default, no password is configured.
If you do not specify the role role-name option, the command sets a password for the default target user role.
Obtaining temporary user role authorization
Perform the following task in user view:
Remarks
Obtain the temporary authorization to use a user role.
super [ role-name ]
If you do not specify the role-name argument, you obtain the default target user role for temporary user role authorization.
The operation fails after three consecutive unsuccessful password attempts.
The user role must have the permission to execute the super command to obtain temporary user role authorization.
Displaying and maintaining RBAC settings
Display user role information.
display role [ name role-name ]
Display user role feature information.
display role feature [ name feature-name | verbose ]
Display user role feature group information.
display role feature-group [ name feature-group-name ] [ verbose ]
RBAC configuration examples
RBAC configuration example for local AAA authentication users
As shown in Figure 2, the AC performs local AAA authentication for the Telnet user. The Telnet user has the username user1@bbb and is assigned the user role role1.
Configure role1 to have the following permissions:
·     Can execute the read commands of all features.
·     Cannot configure any VLANs except VLANs 10 to 20.
Figure 2 Network diagram
# Assign an IP address to VLAN-interface 2 (the interface connected to the Telnet user).
<AC> system-view
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[AC-Vlan-interface2] quit
# Enable Telnet server.
[AC] telnet server enable
# Enable scheme authentication on the user lines for Telnet users.
[AC] line vty 0 4
[AC-line-vty0-4] authentication-mode scheme
[AC-line-vty0-4] quit
# Enable local authentication and authorization for the ISP domain bbb.
[AC] domain bbb
[AC-isp-bbb] authentication login local
[AC-isp-bbb] authorization login local
[AC-isp-bbb] quit
# Create the user role role1.
[AC] role name role1
# Configure rule 1 to permit the user role to access the read commands of all features.
[AC-role-role1] rule 1 permit read feature
# Configure rule 2 to permit the user role to create VLANs and access commands in VLAN view.
[AC-role-role1] rule 2 permit command system-view ; vlan *
# Change the VLAN policy to permit the user role to configure only VLANs 10 to 20.
[AC-role-role1] vlan policy deny
[AC-role-role1-vlanpolicy] permit vlan 10 to 20
[AC-role-role1-vlanpolicy] quit
[AC-role-role1] quit
# Create a device management user named user1 and enter local user view.
[AC] local-user user1 class manage
# Set a plaintext password aabbcc for the user.
[AC-luser-manage-user1] password simple aabbcc
# Set the service type to Telnet.
[AC-luser-manage-user1] service-type telnet
# Assign role1 to the user.
[AC-luser-manage-user1] authorization-attribute user-role role1
# Remove the default user role network-operator from the user. This operation ensures that the user has only the permissions of role1.
[AC-luser-manage-user1] undo authorization-attribute user-role network-operator
[AC-luser-manage-user1] quit
# Telnet to the AC, and enter the username and password to access the AC. (Details not shown.)
# Verify that you can create VLANs 10 to 20. This example uses VLAN 10.
<AC> system-view
[AC] vlan 10
[AC-vlan10] quit
# Verify that you cannot create any VLANs other than VLANs 10 to 20. This example uses VLAN 30.
[AC] vlan 30
Permission denied.
# Verify that you can use all read commands of all features. This example uses display clock.
[AC] display clock
09:31:56 UTC Sun 01/01/2017
[AC] quit
# Verify that you cannot use the write or execute commands of any feature.
<AC> debugging role all
Permission denied.
<AC> ping 192.168.1.58
Permission denied.
RBAC configuration example for RADIUS authentication users
As shown in Figure 3, the AC uses the FreeRADIUS server to provide AAA service for login users, including the Telnet user. The Telnet user uses the username hello@bbb and is assigned the user role role2.
The user role role2 has the following permissions:
·     Can use all commands in ISP domain view.
·     Can use the read and write commands of the arp and radius features.
·     Cannot access the read commands of the acl feature.
·     Can configure only VLANs 1 to 20.
The AC and the FreeRADIUS server use the shared key expert and authentication port 1812. The AC delivers usernames with their domain names to the server.
Figure 3 Network diagram
Make sure the settings on the AC and the RADIUS server match.
1.     Configure the AC:
# Assign VLAN-interface 2 an IP address from the same subnet as the Telnet user.
<AC> system-view
# Assign VLAN-interface 3 an IP address from the same subnet as the RADIUS server.
[AC] interface vlan-interface 3
[AC-Vlan-interface3] ip address 10.1.1.2 255.255.255.0
[AC-Vlan-interface3] quit
[AC] line vty 0 4
# Create the RADIUS scheme rad and enter RADIUS scheme view.
[AC] radius scheme rad
# Specify the primary server address 10.1.1.1 and the service port 1812 in the scheme.
[AC-radius-rad] primary authentication 10.1.1.1 1812
# Set the shared key to expert in the scheme for the AC to authenticate to the server.
[AC-radius-rad] key authentication simple expert
[AC-radius-rad] quit
# Specify the scheme rad as the authentication and authorization schemes for the ISP domain bbb.
IMPORTANT:
Because RADIUS user authorization information is piggybacked in authentication responses, the authentication and authorization methods must use the same RADIUS scheme.
[AC] domain bbb
[AC-isp-bbb] authentication login radius-scheme rad
[AC-isp-bbb] authorization login radius-scheme rad
[AC-isp-bbb] quit
# Create feature group fgroup1.
[AC] role feature-group name fgroup1
# Add the arp and radius features to the feature group.
[AC-featuregrp-fgroup1] feature arp
[AC-featuregrp-fgroup1] feature radius
[AC-featuregrp-fgroup1] quit
# Create the user role role2.
[AC] role name role2
# Configure rule 1 to permit the user role to use all commands available in ISP domain view.
[AC-role-role2] rule 1 permit command system-view ; domain *
# Configure rule 2 to permit the user role to use the read and write commands of all features in fgroup1.
[AC-role-role2] rule 2 permit read write feature-group fgroup1
# Configure rule 3 to disable access to the read commands of the acl feature.
[AC-role-role2] rule 3 deny read feature acl
# Configure rule 4 to permit the user role to create VLANs and use all commands available in VLAN view.
[AC-role-role2] rule 4 permit command system-view ; vlan *
# Configure rule 5 to permit the user role to enter interface view and use all commands available in interface view.
[AC-role-role2] rule 5 permit command system-view ; interface *
# Configure the user role VLAN policy to disable configuration of any VLANs except VLANs 1 to 20.
[AC-role-role2] vlan policy deny
[AC-role-role2-vlanpolicy] permit vlan 1 to 20
[AC-role-role2-vlanpolicy] quit
2.     Configure the RADIUS server:
# Add either of the user role attributes to the dictionary file of the FreeRADIUS server.
Cisco-AVPair = "shell:roles=\"role2\""
Cisco-AVPair = "shell:roles*\"role2\""
# Configure the settings required for the FreeRADIUS server to communicate with the AC. (Details not shown.)
# Verify that you can use all commands available in ISP domain view.
<AC> system-view
[AC] domain abc
[AC-isp-abc] authentication login radius-scheme abc
[AC-isp-abc] quit
# Verify that you can use all read and write commands of the radius and arp features. This example uses radius.
[AC-radius-rad] primary authentication 2.2.2.2
[AC-radius-rad] display radius scheme rad
Output of the RADIUS scheme is omitted.
# Verify that you cannot configure any VLANs except VLANs 1 to 20. This example uses VLAN 10 and VLAN 30.
[AC] vlan 10
[AC-vlan10] quit
[AC] vlan 30
Permission denied.
RBAC temporary user role authorization configuration example (HWTACACS authentication)
Network requirements
As shown in Figure 4, the AC uses local authentication for login users, including the Telnet user. The Telnet user uses the username test@bbb and is assigned the user role level-0.
Configure the remote-then-local authentication mode for temporary user role authorization. The AC uses the HWTACACS server to provide authentication for changing the user role among level-0 through level-3 or changing the user role to network-admin. If the AAA configuration is invalid or the HWTACACS server does not respond, the AC performs local authentication.
Figure 4 Network diagram
Configuration procedure
<AC> system-view
# Assign an IP address to VLAN-interface 3 (the interface connected to the HWTACACS server).
[AC] line vty 0 4
# Enable remote-then-local authentication for temporary user role authorization.
[AC] super authentication-mode scheme local
# Create the HWTACACS scheme hwtac and enter HWTACACS scheme view.
[AC] hwtacacs scheme hwtac
# Specify the primary authentication server address 10.1.1.1 and the service port 49 in the scheme.
[AC-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[AC-hwtacacs-hwtac] key authentication simple expert
# Exclude ISP domain names from the usernames sent to the HWTACACS server.
[AC-hwtacacs-hwtac] user-name-format without-domain
[AC-hwtacacs-hwtac] quit
# Create ISP domain bbb and enter ISP domain view.
[AC] domain bbb
# Configure ISP domain bbb to use local authentication for login users.
# Configure ISP domain bbb to use local authorization for login users.
# Apply the HWTACACS scheme hwtac to the ISP domain for user role authentication.
[AC-isp-bbb] authentication super hwtacacs-scheme hwtac
[AC-isp-bbb] quit
# Create a device management user named test and enter local user view.
[AC] local-user test class manage
# Set the user service type to Telnet.
[AC-luser-manage-test] service-type telnet
# Set the user password to aabbcc.
[AC-luser-manage-test] password simple aabbcc
# Assign level-0 to the user.
[AC-luser-manage-test] authorization-attribute user-role level-0
# Remove the default user role network-operator.
[AC-luser-manage-test] undo authorization-attribute user-role network-operator
[AC-luser-manage-test] quit
# Set the local authentication password to 654321 for the user role level-3.
[AC] super password role level-3 simple 654321
[AC] quit
# Set the local authentication password to 654321 for the user role network-admin.
[AC] super password role network-admin simple 654321
[AC] quit
2.     Configure the HWTACACS server:
This example uses ACSv4.0.
a.     Access the User Setup page.
b.     Add a user account test. (Details not shown.)
c.     In the Advanced TACACS+ Settings area, configure the following parameters:
-     Select Level 3 for the Max Privilege for any AAA Client option.
If the target user role is only network-admin for temporary user role authorization, you can select any level for the option.
-     Select the Use separate password option, and specify enabpass as the password.
Figure 5 Configuring advanced TACACS+ settings
d.     Select Shell (exec) and Custom attributes, and enter allowed-roles="network-admin" in the Custom attributes field.
Use a blank space to separate the allowed roles.
Figure 6 Configuring custom attributes for the Telnet user
1.     Telnet to the AC, and enter the username test@bbb and password aabbcc to access the AC. Verify that you have access to diagnostic commands.
C:\> telnet 192.168.1.70
Trying 192.168.1.70 ...
Press CTRL+K to abort
Connected to 192.168.1.59 ...
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.  *
* Without the owner's prior written consent,                                   *
* no decompiling or reverse-engineering shall be allowed.                      *
login: test@bbb
Password:
<AC> ?
User view commands:
  ping         Ping function
  quit         Exit from current command view
  ssh2         Establish a secure shell client connection
  super        Switch to a user role
  system-view  Enter the System View
  telnet       Establish a telnet connection
  tracert      Tracert function
<AC>
2.     Verify that you can obtain the level-3 user role:
# Use the super password to obtain the level-3 user role. When the system prompts for a username and password, enter the username test@bbb and password enabpass.
<AC> super level-3
Username: test@bbb
Password:
The following output shows that you have obtained the level-3 user role.
User privilege role is level-3, and only those commands that authorized to the role can be used.
# If the ACS server does not respond, enter the local authentication password 654321 at the prompt.
Invalid configuration or no response from the authentication server.
Change authentication mode to local.
Password:
The output shows that you have obtained the level-3 user role.
3.     Use the method in step 2 to verify that you can obtain the level-0, level-1, level-2, and network-admin user roles. (Details not shown.)
RBAC temporary user role authorization configuration example (RADIUS authentication)
As shown in Figure 7, the AC uses local authentication for login users, including the Telnet user. The Telnet user uses the username test@bbb and is assigned the user role level-0.
Configure the remote-then-local authentication mode for temporary user role authorization. The AC uses the RADIUS server to provide authentication for the network-admin user role. If the AAA configuration is invalid or the RADIUS server does not respond, the AC performs local authentication.
Figure 7 Network diagram
<AC> system-view
# Assign an IP address to VLAN-interface 3 (the interface connected to the RADIUS server).
[AC] line vty 0 4
# Create RADIUS scheme radius and enter RADIUS scheme view.
[AC] radius scheme radius
# Specify the primary authentication server address 10.1.1.1, and set the shared key to expert in the scheme for secure communication between the AC and the server.
[AC-radius-radius] primary authentication 10.1.1.1 key simple expert
# Exclude ISP domain names from the usernames sent to the RADIUS server.
[AC-radius-radius] user-name-format without-domain
[AC-radius-radius] quit
[AC] domain bbb
# Apply RADIUS scheme radius to the ISP domain for user role authentication.
[AC-isp-bbb] authentication super radius-scheme radius
[AC-isp-bbb] quit
# Set the local authentication password to abcdef654321 for the user role network-admin.
[AC] super password role network-admin simple abcdef654321
[AC] quit
This example uses ACSv4.2.
a.     Add a user account named $enab0$ and set the password to 123456. (Details not shown.)
b.     Access the Cisco IOS/PIX 6.x RADIUS Attributes page.
c.     Configure the cisco-av-pair attribute, as shown in Figure 8.
Figure 8 Configuring the cisco-av-pair attribute
login: test@bbb
Password:
<AC> ?
User view commands:
  ping         Ping function
<AC>
2.     Verify that you can obtain the network-admin user role:
# Use the super password to obtain the network-admin user role. When the system prompts for a username and password, enter the username test@bbb and password 123456.
<AC> super network-admin
Username: test@bbb
Password:
The following output shows that you have obtained the network-admin user role.
User privilege role is network-admin, and only those commands that authorized to the role can be used.
# If the ACS server does not respond, enter the local authentication password abcdef654321 at the prompt.
Password:
The output shows that you have obtained the network-admin user role.
Troubleshooting RBAC
This section describes several typical RBAC issues and their solutions.
Local users have more access permissions than intended
Symptom
A local user can use more commands than should be permitted by the assigned user roles.
Analysis
The local user might have been assigned to user roles without your knowledge. For example, the local user is automatically assigned the default user role when you create the user.
Solution
To resolve the issue:
1.     Use the display local-user command to examine the local user accounts for undesirable user roles, and remove them.
2.     If the issue persists, contact H3C Support.
Login attempts by RADIUS users always fail
Symptom
Attempts by a RADIUS user to log in to the network access device always fail, even though the following conditions exist:
·     The network access device and the RADIUS server can communicate with one another.
·     All AAA settings are correct.
Analysis
RBAC requires that a login user have a minimum of one user role. If the RADIUS server does not authorize the login user to use any user roles, the user cannot log in to the device.
Solution
1.     Use one of the following methods:
?     Configure the role default-role enable command. A RADIUS user can log in with the default user role when no user role is assigned by the RADIUS server.
?     Add the user role authorization attributes on the RADIUS server.
Login overview
The first time you access the WX1800H series wireless controller after the controller starts up with the factory-default configuration, you can use the following methods:
·     Log in to the CLI through the console port without providing username or password.
·     Log in to the Web interface by using the username admin and password admin.
The first time you access the other types of devices after the devices start up with the factory-default configuration, you can use the following methods:
·     Log in to the CLI by using Telnet and entering the username admin and password admin.
After login, you are assigned the network-admin user role. To improve device security, change the factory-default authentication settings immediately after you log in to the device for the first time.
Table 10 describes the login methods supported by the device, the default settings of login methods, and the minimum configuration requirements.
Table 10 Login methods at a glance
Login method
Default settings and minimum configuration requirements
Login configuration
CLI login:
·     Local console login
By default, console login is enabled and does not require authentication. The user role is network-admin. To improve device security, configure password or scheme authentication for the console line immediately after you log in to the device for the first time.
Configuring local console login
·     Telnet login
By default, Telnet login is disabled.
To enable Telnet login, perform the following tasks:
·     Enable the Telnet server feature.
·     Assign an IP address to a Layer 3 interface and make sure the interface and the Telnet client can reach each other.
·     Configure an authentication mode for VTY login users.
·     Assign a user role to VTY login users.
Configuring Telnet login
·     SSH login
By default, SSH login is disabled.
To enable SSH login, perform the following tasks:
·     Enable the SSH server feature and configure SSH attributes.
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the SSH client can reach each other.
·     Configure scheme authentication for VTY login users.
Configuring SSH login
Web login
By default, Web login is disabled.
To enable Web login, perform the following tasks:
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the Web user's host can reach each other.
·     Configure a local user account for Web login and assign a user role to the account.
·     Assign HTTP or HTTPS service to the user.
Configuring Web login
SNMP access
By default, SNMP access is disabled.
To enable SNMP access, perform the following tasks:
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the NMS can reach each other.
·     Configure SNMP basic parameters.
Accessing the device through SNMP
RESTful access
By default, RESTful access is disabled.
To enable RESTful access, perform the following tasks:
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the RESTful access user's host can reach each other.
·     Enable RESTful access over HTTP or RESTful access over HTTPS.
·     Configure a local user account for RESTful access and assign a user role to the account.
Configuring RESTful access over HTTP
Using the console port for the first device access
The first time you access the device, you can log in to the CLI through the console port.
To log in through the console port, prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
To log in through the console port:
1.     Connect the DB-9 female connector of the console cable to the serial port of the PC.
2.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 9 Connecting a terminal to the console port
3.     If the PC is off, turn on the PC.
4.     On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
?     Bits per second—9600 bps.
?     Flow control—None.
?     Parity—None.
?     Stop bits—1.
?     Data bits—8.
5.     Power on the device and press Enter as prompted.
The default user view prompt appears. You can enter commands to configure or manage the device. To get help, enter ?.
The device supports the following CLI login methods: using the console port, Telnet, or SSH.
To prevent illegal access to the CLI and control user behavior, you can perform the following tasks as required:
·     Configure login authentication.
·     Assign user roles.
·     Configure command authorization and command accounting.
·     Use ACLs to filter unauthorized logins.
This chapter describes how to configure and use CLI login methods, including login authentication, user roles, and common user line settings. For more information about command authorization, command accounting, and unauthorized access filtering, see "Controlling user access to the device."
CLI overview
User lines
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
The device supports the user lines listed in Table 11. Different user lines require different login methods.
Table 11 CLI login method and user line matrix
User line
Login method
Console line
Console port.
Virtual type terminal (VTY) line
Telnet or SSH.
User line numbering
Every user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence of console and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. User lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods, as shown in Table 11. When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, four VTY lines (0 to 3) are configured, of which VTY 0 and VTY 3 are idle. When a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
Login authentication modes
You can configure login authentication to prevent illegal access to the device CLI.
The device supports the following login authentication modes:
·     None—Disables authentication. This mode allows access without authentication and is insecure.
·     Password—Requires password authentication. A user must provide the correct password at login.
·     Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
Different login authentication modes require different user line configurations, as shown in Table 12.
Table 12 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.     Set the authentication mode to password.
2.     Set a password.
Scheme
1.     Set the authentication mode to scheme.
2.     Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·     In none or password authentication mode, the device assigns the user roles specified for the user line.
·     In scheme authentication mode, the device uses the following rules to assign user roles:
?     For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
?     For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
You can connect a terminal to the console port of the device to log in and manage the device, as shown in Figure 10. For the login procedure, see "Using the console port for the first device access."
Figure 10 Logging in through the console port
To configure console login, perform the following tasks:
Tasks at a glance
(Required.) Perform one of the following tasks:
·     Disabling authentication for console login
·     Configuring password authentication for console login
·     Configuring scheme authentication for console login
(Optional.) Configuring common console line settings
Console login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
N/A
2.     Enter console line view or class view.
·     Enter console line view:
line console first-number [ last-number ]
·     Enter console line class view:
line class console
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
A setting in user line class view does not take effect for current online users. It takes effect only for new login users.
3.     Disable authentication.
authentication-mode none
Authentication is disabled for the console line by default.
4.     Assign a user role.
user-role role-name
By default, a console line user is assigned the network-admin user role.
After you finish this configuration task, a user can log in through the console port without authentication.
Step
Remarks
N/A
line class console
3.     Enable password authentication.
authentication-mode password
4.     Set a password.
set authentication password { hash | simple } password
By default, no password is set.
5.     Assign a user role.
user-role role-name
After you finish this configuration task, a user must provide the configured password when logging in through the console port.
Step
Remarks
N/A
line class console
3.     Enable scheme authentication.
To use scheme authentication, you must also perform the following tasks:
·     Configure login authentication methods in ISP domain view.
·     For remote authentication, configure a RADIUS, HWTACACS, or LDAP scheme.
·     For local authentication, create a local user account and configure the relevant attributes.
After you finish this configuration task, a user must provide the configured username and password when logging in through the console port.
Some common settings for a console line take effect immediately and can interrupt the current session. Use a login method different from console login to log in to the device before you change console line settings.
After you change console line settings, adjust the settings on the configuration terminal accordingly for successful login.
To configure common settings for a console line:
Step
Remarks
N/A
line class console
3.     Set the transmission rate.
speed speed-value
By default, the transmission rate is 9600 bps.
This command is not available in console line class view.
4.     Specify the parity.
By default, a user line does not use parity.
5.     Specify the number of stop bits for a character.
stopbits { 1 | 1.5 | 2 }
The default is 1.
Stop bits indicate the end of a character. The more the stop bits, the slower the transmission.
6.     Specify the number of data bits for a character.
databits { 5 | 6 | 7 | 8 }
The default is 8.
Configure this command depending on the character coding type. For example, set the number of data bits to 7 for standard ASCII characters. Set the number of data bits to 8 for extended ASCII characters.
Keywords 5 and 6 are not available in the current software version.
7.     Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
8.     Specify the escape key.
escape-key { character | default }
By default, pressing Ctrl+C terminates a command.
9.     Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
10.     Configure the flow control mode.
11.     Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports two terminal display types: ANSI and VT100. H3C recommends that you specify VT100 type on both the device and the configuration terminal. If either side uses the ANSI type, a display problem might occur when a command line has more than 80 characters. For example, a cursor positioning error might occur.
12.     Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends up to 24 lines to the terminal at a time when pausing between screens of output is enabled.
To disable pausing between screens of output, set the value to 0.
13.     Set the size for the command history buffer.
history-command max-size value
By default, the buffer saves up to 10 history commands.
14.     Set the session idle timeout.
The default is 10 minutes.
If there is no interaction between the device and the user within the idle timeout, the system automatically terminates the user connection on the user line.
If you set the idle timeout to 0, the session will not be aged out.
15.     Specify the command to be automatically executed for login users on the lines.
auto-execute command command
By default, no command is specified for a user line to be automatically executed.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
16.     Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
By default, Telnet login is disabled on the device. To configure Telnet login, you must first log in to the device through any other method.
Configuring the device as a Telnet server
Tasks at a glance
(Required.) Enabling Telnet server
·     Disabling authentication for Telnet login
·     Configuring password authentication for Telnet login
·     Configuring scheme authentication for Telnet login
(Optional.) Configuring common Telnet server settings
(Optional.) Configuring common VTY line settings
Telnet login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
N/A
2.     Enable the Telnet server.
By default, the Telnet server is disabled.
Step
Remarks
N/A
2.     Enter VTY line view or class view.
·     Enter VTY line view:
line vty first-number [ last-number ]
·     Enter VTY line class view:
line class
vty
Password authentication is enabled for VTY lines by default.
In VTY line view, this command is associated with the protocol inbound command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
4.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user is assigned the network-operator user role.
Step
Remarks
N/A
line class
vty
4.     Set a password.
5.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user is assigned the network-operator user role .
Step
Remarks
N/A
line class
vty
Step
Remarks
N/A
2.     Specify the Telnet service port number.
·     In an IPv4 network:
·     In an IPv6 network:
telnet server
ipv6 port port-number
By default, the Telnet service port number is 23.
3.     Set the DSCP value for outgoing Telnet packets.
·     For a Telnet server running IPv4:
telnet server dscp dscp-value
·     For a Telnet server running IPv6:
By default, the DSCP value is 48.
The DSCP value is carried in the ToS or Traffic class field of an IP or IPv6 packet to indicate the transmission priority of the packet.
4.     Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
The default maximum number is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command and performing the incurred task, the system automatically disconnects the Telnet session. Typically, you configure the auto-execute command telnet X.X.X.X command on the device so the device redirects a Telnet user to the host at X.X.X.X. The connection to the current device is closed when the user terminates the Telnet connection to X.X.X.X.
To configure common settings for VTY lines:
Step
Remarks
N/A
line class
vty
3.     Enable the terminal service.
shell
By default, terminal service is enabled.
4.     Specify the supported protocols.
By default, Telnet and SSH are supported.
A protocol change does not take effect for current online users. It takes effect only for new login users.
In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
5.     Specify the shortcut key for terminating a task.
The default setting is Ctrl+C.
6.     Set the user line locking key.
lock-key key-string
7.     Specify the terminal display type.
The default terminal display type is ANSI.
8.     Set the maximum number of lines of command output to send to the terminal at a time.
9.     Set the size for the command history buffer.
The default size is 10 history commands.
10.     Set the session idle timeout.
The default idle timeout is 10 minutes for all user lines.
If there is no interaction between the device and the user within the idle timeout, the system automatically terminates the session on the user line.
If you do not want sessions to be aged out, set the idle timeout to 0.
11.     Specify the command to be automatically executed for login users on the user lines.
By default, no command is specified for auto execution.
Before you configure this command and save the configuration, make sure you can access the CLI through a different user line.
Using the device to log in to a Telnet server
You can use the device as a Telnet client to log in to a Telnet server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 11 Telnetting from the device to a Telnet server
To use the device to log in to a Telnet server:
Step
Remarks
N/A
2.     (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.     Exit to user view.
N/A
4.     Use the device to log in to a Telnet server.
·     Log in to an IPv4 Telnet server:
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ]
·     Log in to an IPv6 Telnet server:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] [ dscp dscp-value ]
N/A
SSH offers a secure method to remote login. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
By default, SSH login is disabled on the device. To configure SSH login, you must first log in to the device through any other method.
Configuring the device as an SSH server
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
To configure the device as an SSH server:
Step
Remarks
N/A
2.     Create local key pairs.
public-key local create { dsa | ecdsa secp256r1 | rsa }
By default, no local key pairs are created.
3.     Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
4.     (Optional.) Create an SSH user and specify the authentication mode.
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
By default, no SSH user is configured on the device.
5.     Enter VTY line view or class view.
line class
vty
6.     Enable scheme authentication.
7.     (Optional.) Specify the protocols for the user lines to support.
By default, both Telnet and SSH are supported.
8.     (Optional.) Set the maximum number of concurrent SSH users.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
9.     Exit to system view.
N/A
10.     (Optional.) Configure common settings for VTY lines.
See "Configuring common VTY line settings."
N/A
Using the device to log in to an SSH server
You can use the device as an SSH client to log in to an SSH server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 12 Logging in to an SSH server from the device
Perform the following tasks in user view:
Log in to an IPv4 SSH server.
ssh2 server
Log in to an IPv6 SSH server.
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Displaying and maintaining CLI login
Remarks
Display online CLI users.
display users [ all ]
N/A
Display user line information.
display line [ num1 | { console | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Release a user line.
free line { num1 | { console | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { console | vty } num2 }
The device provides a built-in Web server that supports HTTP 1.0, HTTP 1.1, and HTTPS. You can use a Web browser to log in to and configure the device.
HTTPS uses SSL to ensure the integrity and security of data exchanged between the client and the server, and is more secure than HTTP. You can define a certificate-based access control policy to allow only legal clients to access the Web interface.
Web login is disabled by default. To configure Web login, you must first log in through the console port.
Configuring HTTP login
Step
Remarks
1.     (Optional.) Specify a fixed verification code for Web login.
web captcha verification-code
By default, no fixed verification code is configured. A Web user must enter the verification code displayed on the login page at login.
2.     Enter system view.
N/A
3.     Enable the HTTP service.
ip http enable
By default, the HTTP service is disabled.
4.     (Optional.) Specify the HTTP service port number.
ip http port port-number
The default HTTP service port number is 80.
5.     (Optional.) Set the idle timeout for Web connections.
web idle-timeout minutes
By default, the Web connection idle timeout timer is 10 minutes.
6.     (Optional.) Specify the maximum number of online HTTP users.
aaa session-limit http max-sessions
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTP users, no additional HTTP users can log in until the number drops below the new limit.
7.     (Optional.) Enable Web operation logging.
webui log enable
By default, Web operation logging is disabled.
8.     Create a local user and enter local user view.
By default, no local user is configured.
9.     Configure a password for the local user.
A password is saved in hashed form.
By default, no password is configured for a local user. The local user can pass authentication after entering the correct username and passing attribute checks.
For security purposes, configure a password for the local user.
10.     Assign a user role to the local user.
The default user role is network-operator for a Web user.
11.     Specify the HTTP service for the local user.
service-type http
By default, no service type is specified for a local user.
Configuring HTTPS login
The device supports the following HTTPS login modes:
·     Simplified mode—The device uses a self-signed certificate (a certificate that is generated and signed by the device itself) and the default SSL settings. The device operates in simplified mode after you enable HTTPS service on the device.
·     Secure mode—The device uses a certificate signed by a CA and a set of user-defined security protection settings to ensure security. For the device to operate in secure mode, you must perform the following tasks:
?     Enable HTTPS service on the device.
?     Specify an SSL server policy for the service.
?     Configure PKI domain-related parameters.
Simplified mode is simple to configure but has potential security risks. Secure mode is more complicated to configure but provides higher security.
For more information about SSL and PKI, see Security Configuration Guide.
To configure HTTPS login:
Step
Remarks
N/A
3.     (Optional.) Apply an SSL server policy to control HTTPS access.
By default, no SSL server policy is applied. The HTTP service uses a self-signed certificate.
Disabling the HTTPS service removes the SSL service policy application. To enable the HTTPS service again, you must reconfigure this command again.
If the HTTPS service has been enabled, any changes to the associated SSL server policy do not take effect. For the changes to take effect, you must disable HTTP and HTTPS, and then apply the policy and enable HTTP and HTTPS again.
4.     Enable the HTTPS service.
ip https enable
By default, HTTPS is disabled.
Enabling the HTTPS service triggers the SSL handshake negotiation process.
·     If the device has a local certificate, the SSL handshake negotiation succeeds and the HTTPS service starts up.
·     If the device does not have a local certificate, the certificate application process starts. Because the certificate application process takes a long time, the SSL handshake negotiation might fail and the HTTPS service might not be started. To solve the problem, execute this command again until the HTTPS service is enabled.
5.     (Optional.) Apply a certificate-based access control policy to control HTTPS access.
By default, no certificate-based access control policy is applied for HTTPS access control.
For clients to log in through HTTPS, you must configure the client-verify enable command and a minimum of one permit rule in the associated SSL server policy.
For more information about certificate-based access control policies, see the chapter on PKI in Security Configuration Guide.
6.     (Optional.) Specify the HTTPS service port number.
ip https port port-number
The default HTTPS service port number is 443.
7.     (Optional.) Set the HTTPS login authentication mode.
By default, manual authentication mode is used for HTTPS login.
8.     (Optional.) Set the idle timeout for Web connections.
9.     (Optional.) Specify the maximum number of online HTTPS users.
aaa session-limit https max-sessions
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTPS users, no additional HTTPS users can log in until the number drops below the new limit.
10.     (Optional.) Enable Web operation logging.
webui log enable
11.     Create a local user and enter local user view.
12.     Configure a password for the local user.
The password is saved in hashed form.
13.     Assign a user role to the local user.
14.     Specify the HTTPS service for the local user.
service-type https
Displaying and maintaining Web login
Execute display commands in any view and the free web users command in user view.
Display online Web users.
display web users
Display Web interface navigation tree information.
display web menu [ chinese ]
Display HTTP service configuration and status information.
display ip http
Display HTTPS service configuration and status information.
display ip https
Log off online Web users.
Web login configuration examples
HTTP login configuration example
As shown in Figure 13, the PC and the AC can communicate over the IP network.
Configure the AC to allow the PC to log in by using HTTP.
Figure 13 Network diagram
# Create VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] quit
# Create VLAN-interface 100 and assign IP address 192.168.100.99/24 to the interface.
[Sysname-Vlan-interface100] ip address 192.168.100.99 24
[Sysname-Vlan-interface100] quit
# Create a local user named admin. Set the password to admin, the service type to HTTP, and the user role to network-admin.
[Sysname] local-user admin
[Sysname-luser-manage-admin] service-type http
[Sysname-luser-manage-admin] authorization-attribute user-role network-admin
[Sysname-luser-manage-admin] password simple admin
[Sysname-luser-manage-admin] quit
# Enable HTTP.
[Sysname] ip http enable
1.     On the PC, run the IE browser and enter the IP address of the device in the address bar.
The Web login page appears, as shown in Figure 14.
Figure 14 Web login page
2.     Enter the username and password. Select English and click Login.
After you pass authentication, the homepage appears and you can configure the AC.
HTTPS login configuration example
As shown in Figure 15, the host, AC, and CA can communicate over the IP network.
Perform the following tasks to allow only authorized users to access the AC's Web interface:
·     Configure the AC as the HTTPS server and request a certificate for the AC.
·     Configure the host as the HTTPS client and request a certificate for the host.
Figure 15 Network diagram
In this example, the CA runs Windows Server and has the SCEP add-on installed.
1.     Configure the AC (HTTPS server):
# Create PKI entity en and set entity parameters.
[Sysname] pki entity en
[Sysname-pki-entity-en] common-name http-server1
[Sysname-pki-entity-en] fqdn ssl.security.com
[Sysname-pki-entity-en] quit
# Create PKI domain 1 and set domain parameters.
[Sysname] pki domain 1
[Sysname-pki-domain-1] ca identifier new-ca
[Sysname-pki-domain-1] certificate request url http://10.1.2.2/certsrv/mscep/mscep.dll
[Sysname-pki-domain-1] certificate request from ra
[Sysname-pki-domain-1] certificate request entity en
# Configure the PKI domain to use the 1024-bit long RSA key pair hostkey for both signing and encryption.
[Sysname-pki-domain-1] public-key rsa general name hostkey length 1024
[Sysname-pki-domain-1] quit
# Create RSA local key pairs.
[Sysname] public-key local create rsa
# Retrieve the CA certificate.
[Sysname] pki retrieve-certificate domain 1 ca
# Configure the AC to request a local certificate through SCEP.
[Sysname] pki request-certificate domain 1
# Create SSL server policy myssl. Specify PKI domain 1 for the SSL server policy, and enable certificate-based SSL client authentication.
[Sysname] ssl server-policy myssl
[Sysname-ssl-server-policy-myssl] pki-domain 1
[Sysname-ssl-server-policy-myssl] client-verify enable
[Sysname-ssl-server-policy-myssl] quit
# Create certificate attribute group mygroup1. Configure a certificate attribute rule that matches statements with the string of new-ca in the distinguished name of the subject name.
[Sysname] pki certificate attribute-group mygroup1
[Sysname-pki-cert-attribute-group-mygroup1] attribute 1 issuer-name dn ctn new-ca
[Sysname-pki-cert-attribute-group-mygroup1] quit
# Create certificate-based access control policy myacp. Configure a certificate access control rule that uses the matching criteria in certificate attribute group mygroup1.
[Sysname] pki certificate access-control-policy myacp
[Sysname-pki-cert-acp-myacp] rule 1 permit mygroup1
[Sysname-pki-cert-acp-myacp] quit
# Associate SSL server policy myssl with the HTTPS service.
[Sysname] ip https ssl-server-policy myssl
# Use certificate-based access control policy myacp to control HTTPS access.
[Sysname] ip https certificate access-control-policy myacp
# Enable the HTTPS service.
[Sysname] ip https enable
# Create local user usera. Set the password to 123, the service type to HTTPS, and the user role to network-admin.
[Sysname] local-user usera
[Sysname-luser-usera] password simple 123
[Sysname-luser-usera] service-type https
[Sysname-luser-usera] authorization-attribute user-role network-admin
2.     Configure the host (HTTPS client):
# On the host, run the IE browser and enter http://10.1.2.2/certsrv in the address bar.
# Request a certificate for the host as prompted.
1.     On the host, enter https://10.1.1.1 in the browser's address bar, and select the certificate issued by new-ca.
2.     When the Web login page appears, enter the username usera and password 123 to log in to the Web interface.
For more information about PKI and SSL configuration commands and the public-key local create rsa command, see Security Command Reference.
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to manage and monitor the device.
Figure 16 SNMP access diagram
The device supports SNMPv1, SNMPv2c, and SNMPv3, and can cooperate with various network management software products. However, the device and the NMS must use the same SNMP version.
By default, SNMP access is disabled. To configure SNMP access, you must first log in to the device through any other method.
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
·     Send RESTful requests to the device to pass authentication.
·     Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
RESTful access is disabled by default. To configure RESTful access, you must first log in through the console port.
Step
Remarks
N/A
2.     Enable RESTful access over HTTP.
restful http enable
By default, RESTful access over HTTP is disabled.
3.     Create a local user and enter local user view.
4.     Configure a password for the local user.
5.     (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful access user.
6.     Specify the HTTP service for the local user.
service-type http
Configuring RESTful access over HTTPS
Step
Remarks
N/A
2.     Enable RESTful access over HTTPS.
restful https enable
By default, RESTful access over HTTPS is disabled.
6.     Specify the HTTPS service for the local user.
service-type https
Use ACLs to prevent unauthorized access, and configure command authorization and accounting to monitor and control user behavior. For more information about ACLs, see ACL and QoS Configuration Guide.
Controlling Telnet/SSH logins
Use different types of ACLs to filter Telnet and SSH logins by different match criteria:
·     Basic ACL (2000 to 2999)—Source IP address.
·     Advanced ACL (3000 to 3999)—Source IP address and destination IP address.
·     Ethernet frame header ACL (4000 to 4999)—Source MAC address.
If an applied ACL does not exist or does not have any rules, no user login restriction is applied. If the ACL exists and has rules, only users permitted by the ACL can access the device through Telnet or SSH.
Configuration procedures
To control Telnet logins:
Step
Remarks
N/A
2.     Apply an ACL to filter Telnet logins.
·     telnet server acl acl-number
·     telnet server ipv6 acl [ ipv6 ] acl-number
By default, no ACL is used to filter Telnet logins.
To control SSH logins:
Step
Remarks
N/A
2.     Apply an ACL to filter SSH logins.
·     ssh server acl acl-number
·     ssh server ipv6 acl [ ipv6 ] acl-number
By default, no ACL is used to filter SSH logins.
For more information about these two commands, see Security Command Reference.
Configuration example
As shown in Figure 17, the AC is a Telnet server.
Configure the AC to permit only Telnet packets sourced from Host A and Host B.
Figure 17 Network diagram
# Configure an ACL to permit packets sourced from Host A and Host B.
[Sysname] acl basic 2000 match-order config
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
Controlling Web logins
Use a basic ACL (2000 to 2999) to filter HTTP/HTTPS traffic by source IP address. Only Web users whose IP addresses are permitted by the ACL can access the device. If the ACL does not exist or does not have any rules, no user login restriction is applied.
You can also log off suspicious Web users.
Configuring source IP-based Web login control
Web login requests contain usernames and passwords. For security purposes, the device always uses HTTPS to transfer Web login requests. Only users that are permitted by the following ACLs can access the device through HTTP:
·     ACL applied to the HTTPS service.
·     ACL applied to the HTTP service.
To configure source IP-based Web login control:
Step
Remarks
N/A
2.     Apply a basic ACL for Web access control.
·     ip http acl { acl-number | name acl-name }
·     ip https acl { acl-number | name acl-name }
By default, no ACL is applied to the HTTP or HTTPS service.
Logging off online Web users
To log off online Web users, execute the following command in user view:
free web-users { all | user-id user-id | user-name user-name }
As shown in Figure 18, the AC is an HTTP server.
Configure the AC to provide HTTP service only to Host B.
Figure 18 Network diagram
# Create an ACL and configure rule 1 to permit packets sourced from Host B.
[Sysname] acl basic 2030 match-order config
[Sysname-acl-ipv4-basic-2030] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2030] quit
# Apply the ACL to the HTTP service so only a Web user on Host B can access the AC.
[Sysname] ip http acl 2030
Controlling SNMP access
Use a basic ACL (2000 to 2999) to control SNMP access by source IP address. To access the requested MIB view, an NMS must use a source IP address permitted by the ACL. If the ACL does not exist or does not have any rules, no user login restriction is applied.
To control SNMPv1 or SNMPv2c access:
Step
Remarks
N/A
2.     Configure the SNMP access right.
·     (Method 1.) Create an SNMP community and specify ACLs for the community:
?     In VACM mode:
snmp-agent community { read | write } [ simple | cipher ] community-name [ mib-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
?     In RBAC mode:
snmp-agent community [ simple | cipher ] community-name user-role role-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·     (Method 2.) Create an SNMPv1/v2c group and add a user to the group, specifying ACLs for the group and user:
a.     snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
b.     snmp-agent usm-user { v1 | v2c } user-name group-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
To control SNMPv3 access:
Step
Remarks
N/A
2.     Create an SNMPv3 group, specifying ACLs for the group.
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
N/A
3.     Create an SNMPv3 user, specifying ACLs for the user.
·     In VACM mode:
snmp-agent usm-user v3 user-name group-name [ remote { ipv4-address | ipv6 ipv6-address } ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·     In RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ipv4-address | ipv6 ipv6-address } ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
As shown in Figure 19, the AC is running SNMP.
Configure the AC to allow Host A and Host B to access the AC through SNMP.
Figure 19 Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
# Associate the ACL with the SNMP community and the SNMP group.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
Configuring command authorization
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands.
After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
The command authorization method can be different from the user login authorization method.
This section provides the procedure for configuring command authorization. To make the command authorization feature take effect, you must configure a command authorization method in ISP domain view. For more information, see Security Configuration Guide.
To configure command authorization:
Step
Remarks
N/A
2.     Enter user line view or user line class view.
·     Enter user line view:
line { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
·     Enter user line class view:
line class { console
| vty }
Authentication is disabled for console lines, and password authentication is enabled for VTY lines by default.
By default, scheme authentication is enabled.
4.     Enable command authorization.
By default, command authorization is disabled, and the commands available for a user only depend on the user role.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
As shown in Figure 20, a user needs to log in to the AC to manage the AC from Host A.
Configure the AC to perform the following operations:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     Use local authorization if the HWTACACS server is not available.
Figure 20 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the AC and the HWTACACS server can reach each other. Make sure the AC and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
# Enable scheme authentication for user lines VTY 0 through VTY 4.
[Sysname] line vty 0 4
[Sysname-line-vty0-4] authentication-mode scheme
# Enable command authorization for the user lines.
[Sysname-line-vty0-4] command authorization
[Sysname-line-vty0-4] quit
# Create HWTACACS scheme tac.
[Sysname] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[Sysname-hwtacacs-tac] primary authentication 192.168.2.20 49
[Sysname-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[Sysname-hwtacacs-tac] key authentication simple expert
[Sysname-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Sysname-hwtacacs-tac] user-name-format without-domain
[Sysname-hwtacacs-tac] quit
# Configure the system-defined domain system.
[Sysname] domain system
# Use HWTACACS scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[Sysname-isp-system] authentication login hwtacacs-scheme tac local
[Sysname-isp-system] authorization command hwtacacs-scheme tac local
[Sysname-isp-system] quit
# Create the local user monitor. Set the simple password to 123, the service type to Telnet, and the default user role to level-1.
[Sysname] local-user monitor
[Sysname-luser-manage-monitor] password simple 123
[Sysname-luser-manage-monitor] service-type telnet
[Sysname-luser-manage-monitor] authorization-attribute user-role level-1
Configuring command accounting
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
This section provides only the procedure for configuring command accounting. To make the command accounting feature take effect, you must configure a command accounting method in ISP domain view. For more information, see Security Configuration Guide.
To configure command accounting:
Step
Remarks
N/A
| vty }
4.     Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
As shown in Figure 21, users need to log in to the AC to manage the AC.
Configure the AC to send commands executed by users to the HWTACACS server to monitor and control user operations on the AC.
Figure 21 Network diagram
# Enable command accounting for user line Console 0.
[Sysname] line console 0
[Sysname-line-console0] command accounting
[Sysname-line-console0] quit
# Enable command accounting for user lines VTY 0 through VTY 4.
[Sysname-line-vty0-4] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[Sysname-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[Sysname-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain system to use the HWTACACS scheme for command accounting.
[Sysname-isp-system] accounting command hwtacacs-scheme tac
Configuring FTP
File Transfer Protocol (FTP) is an application layer protocol for transferring files from one host to another over an IP network. It uses TCP port 20 to transfer data and TCP port 21 to transfer control commands. For more information about FTP, see RFC 959.
FTP is based on the client/server model. The AC can act as the FTP server or FTP client. Make sure the FTP server and the FTP client can reach each other before establishing the FTP connection.
Figure 22 FTP application scenario
FTP supports the following transfer modes:
·     Binary mode—Used to non-text files, such as .app, .bin, and .btm files.
·     ASCII mode—Used to transfer text files, such as .txt, .bat, and .cfg files.
When the device acts as the FTP client, you can set the transfer mode (binary by default). When the device acts as the FTP server, the transfer mode is determined by the FTP client.
FTP can operate in either of the following modes:
·     Active mode (PORT)—The FTP server initiates the TCP connection. This mode is not suitable when the FTP client is behind a firewall, for example, when the FTP client resides in a private network.
·     Passive mode (PASV)—The FTP client initiates the TCP connection. This mode is not suitable when the server does not allow the client to use a random unprivileged port greater than 1024.
FTP operation mode varies depending on the FTP client program.
Using the device as an FTP server
To use the device as an FTP server, you must enable the FTP server and configure authentication and authorization on the device. Other commands are optional.
Configuring basic parameters
Step
Remarks
N/A
2.     Enable the FTP server.
ftp server enable
By default, the FTP server is disabled.
3.     (Optional.) Use an ACL to control access to the FTP server.
ftp server acl { acl-number | ipv6 acl-number6 }
By default, no ACL is used for access control.
4.     (Optional.) Associate an SSL server policy with the FTP server to ensure data security.
ftp server ssl-server-policy policy-name
By default, no SSL server policy is associated with the FTP server.
5.     (Optional.) Configure the idle-timeout interval.
ftp timeout minutes
The default idle-timeout interval is 30 minutes.
If no data is transferred between the FTP server and FTP client within the idle-timeout interval, the connection is terminated.
6.     (Optional.) Set the DSCP value for outgoing FTP packets.
·     For an IPv4 FTP server:
ftp server dscp dscp-value
·     For an IPv6 FTP server:
ftp server ipv6 dscp dscp-value
By default, the DSCP value is 0.
7.     (Optional.) Set the maximum number of concurrent FTP users.
aaa session-limit ftp max-sessions
Changing this setting does not affect users who are currently online. If the new list is less than the number of online FTP users, no additional FTP users can log in until the number drops below the new limit.
Configuring authentication and authorization
Perform this task on the FTP server to authenticate FTP clients and set the authorized directories that authenticated clients can access.
The following authentication modes are available:
·     Local authentication—The device looks up the client's username and password in the local user account database. If a match is found, authentication succeeds.
·     Remote authentication—The device sends the client's username and password to a remote authentication server for authentication. The user account is configured on the remote authentication server rather than the device.
The following authorization modes are available:
·     Local authorization—The device assigns authorized directories to FTP clients based on the locally configured authorization attributes.
·     Remote authorization—A remote authorization server assigns authorized directories on the device to FTP clients.
For information about configuring authentication and authorization, see Security Configuration Guide.
Manually releasing FTP connections
Manually release FTP connections.
·     Release the FTP connection established by using a specific user account:
free ftp user username
·     Release the FTP connection to a specific IP address:
free ftp user-ip [ ipv6 ] client-address [ port port-num ]
Displaying and maintaining the FTP server
Display FTP server configuration and status information.
display ftp-server
Display detailed information about online FTP users.
display ftp-user
FTP server configuration example
Network requirements
·     Configure the AC as an FTP server.
·     Create a local user account with the username abc and password 123456 on the FTP server.
·     Use the user account to log in to the FTP server from the FTP client.
·     Upload the file temp.bin from the FTP client to the FTP server.
·     Download the configuration file startup.cfg from the FTP server to the FTP client for backup.
Figure 23 Network diagram
1.     Configure IP addresses as shown in Figure 23. Make sure the AC and PC can reach each other. (Details not shown.)
2.     Configure the AC (FTP server):
# Create a local user with the username abc and password 123456.
[Sysname] local-user abc class manage
[Sysname-luser-abc] password simple 123456
# Assign the user role network-admin to the user. Set the working directory to the root directory of the flash memory.
[Sysname-luser-abc] authorization-attribute user-role network-admin work-directory flash:/
# Assign the service type FTP to the user.
[Sysname-luser-abc] service-type ftp
[Sysname-luser-abc] quit
# Enable the FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Examine the storage space for space insufficiency and delete unused files for more free space.
<Sysname> dir
Directory of flash:
     0      drw-           -  Jun 29 2016 18:30:38     logfile
     1      drw-           -  Jun 21 2016 14:51:38     diagfile
     2      drw-           -  Jun 21 2016 14:51:38     seclog
     3      -rw-        2943  Jul 02 2016 08:03:08     startup.cfg
     4      -rw-       63901  Jul 02 2016 08:03:08     startup.mdb
     5      -rw-         716  Jun 21 2016 14:58:02     hostkey
     6      -rw-         572  Jun 21 2016 14:58:02     serverkey
     7      -rw-     6541264  Aug 04 2016 20:40:49     backup.bin
473664 KB total (467080 KB free)
<Sysname> delete /unreserved flash:/backup.bin
3.     Perform FTP operations from the PC (FTP client):
# Log in to the FTP server at 1.2.1.1 using the username abc and password 123456.
c:\> ftp 1.2.1.1
Connected to 1.2.1.1.
220 FTP service ready.
User (1.2.1.1:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Use the ASCII mode to download the configuration file startup.cfg from the AC to the PC for backup.
ftp> ascii
200 TYPE is now ASCII
ftp> get startup.cfg back-startup.cfg
# Use the binary mode to upload the file temp.bin to the AC.
ftp> binary
200 TYPE is now 8-bit binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
FTP server configuration example (on an IRF fabric)
·     Configure the IRF fabric as an FTP server.
·     Download the configuration file config.cfg from the FTP server to the FTP client for backup.
Figure 24 Network diagram
1.     Configure IP addresses as shown in Figure 24. Make sure the IRF fabric and the PC can reach each other. (Details not shown.)
2.     Configure the FTP server:
# Examine the storage space on the member devices. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Assign the user role network-admin to the user. Set the working directory to the root directory of the CF card on the master. (To set the working directory to the root directory of the CF card on the subordinate member, replace cfa0:/ with slot2#cfa0:/.)
[Sysname-luser-abc] authorization-attribute user-role network-admin work-directory cfa0:/
[Sysname] quit
3.     Perform FTP operations from the FTP client:
# Log in to the FTP server at 1.1.1.1 using the username abc and password 123456.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
User(1.1.1.1:(none)):abc
Password:
230 User logged in.
# Use the ASCII mode to download the configuration file config.cfg from the FTP server to the PC for backup.
ftp> ascii
ftp> get config.cfg back-config.cfg
# Use the binary mode to upload the file temp.bin from the PC to the root directory of the CF card on the master.
ftp> binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
Using the device as an FTP client
Establishing an FTP connection
To access the FTP server, you must establish a connection from the FTP client to the FTP server.
To establish an IPv4 FTP connection:
Step
Remarks
N/A
2.     (Optional.) Specify a source IP address for outgoing FTP packets.
By default, no source IP address is specified. The device uses the primary IP address of the output interface as the source IP address.
3.     Return to user view.
N/A
4.     Log in to the FTP server.
·     (Method 1.) Log in to the FTP server from user view:
ftp ftp-server [ service-port ] [ dscp dscp-value | source { interface { interface-name | interface-type interface-number } | ip source-ip-address } ] *
·     (Method 2.) Log in to the FTP server from FTP client view:
a.     Enter FTP client view:
ftp
b.     Log in to the FTP server:
open server-address [ service-port ]
The source IP address specified in the ftp command takes precedence over the one set by the ftp client source command.
To establish an IPv6 FTP connection:
Step
Remarks
N/A
2.     (Optional.) Specify the source IPv6 address for FTP packets sent by the FTP client.
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
By default, no source IPv6 address is specified. The source address is automatically selected as defined in RFC 3484.
N/A
ftp ipv6 ftp-server [ service-port ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] * [ -i interface-type interface-number ]
ftp ipv6
The source IP address specified in the ftp ipv6 command takes precedence over the one set by the ftp client ipv6 source command.
Managing directories on the FTP server
Perform the following tasks in FTP client view:
Display directory and file information on the FTP server.
·     Display the detailed information of a directory or file on the FTP server:
dir [ remotefile [ localfile ] ]
·     Display the name of a directory or file on the FTP server:
ls [ remotefile [ localfile ] ]
Change the working directory on the FTP server.
cd { directory | .. | / }
Return to the upper level directory on the FTP server.
cdup
Display the working directory that is being accessed.
pwd
Create a directory on the FTP server.
mkdir directory
Delete a directory from the remote FTP server.
rmdir directory
Working with files on the FTP server
After you log in to the server, you can upload a file to or download a file from the authorized directory by following these steps:
1.     Use the dir or ls command to display the directory and location of the file on the FTP server.
2.     Delete unused files to get more free storage space.
3.     Set the file transfer mode to ASCII for text files or to binary for non-text files.
4.     Use the lcd command to change the local working directory of the FTP client. You can upload the file or save the downloaded file in this directory.
5.     Upload or download the file.
To work with files on an FTP server, execute the following commands in FTP client view:
Remarks
Display directory or file information on the FTP server.
N/A
Delete the specified file on the FTP server permanently.
delete remotefile
N/A
Set the file transfer mode.
·     Set the file transfer mode to ASCII:
ascii
·     Set the file transfer mode to binary:
binary
The default file transfer mode is binary.
Set the FTP operation mode to passive.
passive
The default mode is passive.
Display or change the local working directory of the FTP client.
lcd [ directory | / ]
N/A
Upload a file to the FTP server.
put localfile [ remotefile ]
N/A
Download a file from the FTP server.
get remotefile [ localfile ]
N/A
Add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
N/A
Specify the retransmit marker.
restart marker
Use this command together with the put, get, or append command.
Update the local file.
newer remotefile
N/A
Get the missing part of a file.
reget remotefile [ localfile ]
N/A
Rename the file.
rename [ oldfilename [ newfilename ] ]
N/A
Changing to another user account
After you log in to the FTP server, you can initiate an FTP authentication to change to a new account. By changing to a new account, you can get a different privilege without re-establishing the FTP connection.
For successful account change, you must enter the new username and password correctly. A wrong username or password can cause the FTP connection to be disconnected.
To change to another user account, execute the following command in user view:
Initiate an FTP authentication on the current FTP connection.
user username [ password ]
Maintaining and troubleshooting the FTP connection
Remarks
Display FTP commands on the FTP server.
rhelp
N/A
Display FTP commands help information on the FTP server.
rhelp protocol-command
N/A
Display FTP server status.
rstatus
N/A
Display detailed information about a directory or file on the FTP server.
rstatus remotefile
N/A
Display FTP connection status.
status
N/A
Display the system information of the FTP server.
system
N/A
Enable or disable FTP operation information display.
verbose
By default, this function is enabled.
Enable or disable FTP client debugging.
debug
By default, FTP client debugging is disabled.
Clear the reply information in the buffer.
reset
N/A
Terminating the FTP connection
Execute one of the following commands in FTP client view:
Terminate the connection to the FTP server without exiting FTP client view.
·     disconnect
·     close
Terminate the connection to the FTP server and return to user view.
·     bye
·     quit
Displaying command help information
Display command help information.
·     help [ command-name ]
·     ? [ command-name ]
Displaying and maintaining the FTP client
Execute the display command in any view.
Display source IP address information on the FTP client.
display ftp client source
FTP client configuration example
As shown in Figure 25, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
·     Use the AC as an FTP client to log in to the FTP server.
·     Download the file temp.bin from the PC to the AC.
·     Upload the configuration file startup.cfg from the AC to the PC for backup.
Figure 25 Network diagram
# Configure IP addresses as shown in Figure 25. Make sure the AC and PC can reach each other. (Details not shown.)
# Examine the storage space on the AC. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Log in to the FTP server at 10.1.1.1 using the username abc and password 123456.
<Sysname> ftp 10.1.1.1
Press CTRL+C to abort.
Connected to 10.1.1.1 (10.1.1.1).
User (10.1.1.1:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the file temp.bin from the PC to the AC.
ftp> get temp.bin
local: temp.bin remote: temp.bin
150 Connecting to port 47457
226 File successfully transferred
23951480 bytes received in 95.399 seconds (251.0 kbyte/s)
# Use the ASCII mode to upload the configuration file startup.cfg from the AC to the PC for backup.
ftp> ascii
ftp> put startup.cfg back-startup.cfg
local: startup.cfg remote: back-startup.cfg
150 Connecting to port 47461
3494 bytes sent in 5.646 seconds (618.00 kbyte/s)
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
FTP client configuration example (on an IRF fabric)
As shown in Figure 26, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
·     Use the IRF fabric as an FTP client to log in to the FTP server.
·     Download the file temp.bin from the FTP server to the FTP client.
·     Upload the configuration file config.cfg from the FTP client to the FTP server for backup.
Figure 26 Network diagram
# Configure IP addresses as shown in Figure 26. Make sure the IRF fabric and PC can reach each other. (Details not shown.)
Password:
ftp>
ftp> binary
# Download the file temp.bin from the PC to the root directory of the CF card on the master device.
ftp> get temp.bin
# Download the file temp.bin from the PC to the root directory of the CF card on the subordinate member (with member ID of 2).
ftp> get temp.bin slot2#cfa0:/temp.bin
# Use the ASCII mode to upload the configuration file config.cfg from the IRF fabric to the PC for backup.
ftp> ascii
ftp> put config.cfg back-config.cfg
local: config.cfg remote: back-config.cfg
ftp> bye
221 Logout.
<Sysname>
Configuring TFTP
Trivial File Transfer Protocol (TFTP) is a simplified version of FTP for file transfer over secure reliable networks. TFTP uses UDP port 69 for data transmission. In contrast to TCP-based FTP, TFTP does not require authentication or complex message exchanges, and is easier to deploy. TFTP is suited for reliable network environments.
The device can only operate as a TFTP client. You can upload a file from the device to the TFTP server or download a file from the TFTP server to the device. If you download a file with a file name that exists in the target directory, the device deletes the existing file and saves the new one. If file download fails due to network disconnection or other reasons, the original file cannot be restored. Therefore, use a nonexistent file name instead.
Figure 27 TFTP application scenario
Configuring the device as an IPv4 TFTP client
Step
Remarks
N/A
2.     (Optional.) Use an ACL to control the client's access to TFTP servers.
tftp-server acl acl-number
3.     Specify the source IP address for TFTP packets sent by the TFTP client.
4.     Return to user view.
N/A
5.     Download or upload a file in an IPv4 network.
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] *
The source IP address specified in this command takes precedence over the one set by the tftp client source command.
Use this command in user view.
Configuring the device as an IPv6 TFTP client
Step
Remarks
N/A
tftp-server ipv6 acl acl-number
3.     Specify the source IPv6 address for TFTP packets sent by the TFTP client.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ip-address }
N/A
5.     Download or upload a file in an IPv6 network.
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] *
The source IP address specified in this command takes precedence over the one set by the tftp client ipv6 source command.
Managing file systems
Overview
File systems
Each storage medium on the device has a file system.
The following matrix shows the supported storage medium types:
Hardware series
Model
Fixed storage medium types
Hot swappable storage medium types
WX1800H series
WX1804H
WX1810H
Flash memory
USB disk
WX1820H
WX1840H
Flash memory
SD card
USB disk
WX3800H series
WX3820H
WX3840H
CF card
Not supported
WX5800H series
WX5860H
CF card
Not supported
File system location
To identify a file system that is located on a subordinate member of an IRF fabric, you must specify the file system location in the slotn# format. The n argument represents the IRF member ID of a member device. For example, the location is slot2# for a file system that resides on member device 2.
File system naming conventions
The file system on the flash memory has the following parts:
·     (Optional.) File system location. For more information, see "File system location".
·     Storage medium type flash.
·     Colon (:).
The name of a file system on the CF card, SD card, or USB disk has the following parts:
·     Storage medium type, cf, sd, or usb.
·     Sequence number, a lower-case English letter such as a, b, or c.
·     Number 0.
·     Colon (:).
For example, the file system on the USB disk is named  usba0:.
IMPORTANT
IMPORTANT:
File system names are case sensitive and must be entered in lower case.
Default file system
You are working with the default file system by default after you log in. To specify a file or directory on the default file system, you do not need to specify the file system name. For example, you do not need to specify any location information if you want to save the running configuration to the root directory of the default file system.
Directories
Directories in a file system are structured in a tree form.
Root directory
The root directory is represented by a forwarding slash (/). For example, flash:/ represents the root directory of the flash memory.
Working directory
The working directory is also called the current directory.
On standalone devices that support the flash memory, the default working directory is the root directory of the flash memory.
On standalone devices that support the CF card, the default working directory is the root directory of the CF card.
On an IRF fabric that supports the flash memory, the default working directory is the root directory of the flash memory on the master device.
On an IRF fabric that supports the CF card, the default working directory is the root directory of the CF card on the master device.
Directory naming conventions
When you specify a name for a directory, follow these conventions:
·     A directory name can contain letters, digits, and special characters except for asterisks (*), vertical bars (|), forward slashes (/), backward slashes (\), question marks (?), left angle brackets (<), right angle brackets (>), quotation marks ("), and colons (:).
·     A directory whose name starts with a dot character (.) is a hidden directory. To prevent the system from hiding a directory, make sure the directory name does not start with a dot character.
Commonly used directories
The device has some factory-default directories. The system automatically creates directories during operation. These directories include:
·     diagfile—Stores diagnostic information files.
·     license—Stores license files.
·     logfile—Stores log files.
·     seclog—Stores security log files.
·     versionInfo—Stores software version information files.
Files
File naming conventions
When you specify a name for a file, follow these conventions:
·     A file name can contain letters, digits, and special characters except for asterisks (*), vertical bars (|), forward slashes (/), backward slashes (\), question marks (?), left angle brackets (<), right angle brackets (>), quotation marks ("), and colons (:).
·     A file whose name starts with a dot character (.) is a hidden file. To prevent the system from hiding a file, make sure the file name does not start with a dot character.
Common file types
The device is shipped with some files. The system automatically creates files during operation. The types of these files include:
·     .ipe file—Compressed software image package file.
·     .bin file—Software image file.
·     .cfg file—Configuration file.
·     .mdb file—Binary configuration file.
·     .log file—Log file.
Hidden files and directories
Some system files and directories are hidden. For correct system operation and full functionality, do not modify or delete hidden files or directories.
Specifying a directory name or file name
To specify a directory, you can use the absolute path or a relative path. For example, the working directory is flash:/. To specify the test2 directory in Figure 28, you can use the following methods:
·     flash:/test/test1/test2 (absolute path)
·     flash:/test/test1/test2/ (absolute path)
·     test/test1/test2 (relative path)
·     test/test1/test2/ (relative path)
Figure 28 Sample directory hierarchy
Specifying a file name
To specify a file, use the following methods:
·     Enter the absolute path of the file and the file name in the format of filesystem/directory1/directory2/…/directoryn/filename, where directoryn is the directory in which the file resides.
·     Enter the relative path of the file and the file name.
For example, the working directory is flash:/. The samplefile.cfg file is in the test2 directory shown in Figure 28. To specify the file, you can use the following methods:
·     flash:/test/test1/test2/samplefile.cfg
·     test/test1/test2/samplefile.cfg
Command and hardware compatibility
The WX1800H series access controllers do not support the slot keyword or the slot-number argument.
File system management restrictions and guidelines
To avoid file system corruption, do not perform the following tasks during file system management:
·     Installing or removing storage media.
·     Performing master/subordinate switchover on the IRF fabric.
If you remove a storage medium while a directory or file on the medium is being accessed, the device might not recognize the medium when you reinstall it. To reinstall this kind of storage medium, perform one of the following tasks:
·     If you were accessing a directory on the storage medium, change the working directory.
·     If you were accessing a file on the storage medium, close the file.
Make sure a USB disk is not write protected before an operation that requires the write right on the disk.
You cannot access a file system that is being formatted or repaired. To access a file system after it is formatted or repaired, use one of the following methods:
·     Use the absolute path to specify a file or directory. For example, use the dir flash:/ command to display the files and directories in the file system on the flash memory.
·     Use the cd command to change the working directory to the root directory of the file system before accessing a file or directory in the file system. For example, to display the files and directories in the root directory of the file system on the flash memory, perform the following tasks:
a.     Use the cd flash:/ command to change the working directory to the root directory of the file system.
b.     Execute the dir command.
Before managing file systems, directories, and files, make sure you know the possible impacts.
Formatting a file system
CAUTION
CAUTION:
Formatting a file system permanently deletes all files and directories in the file system. You cannot restore the deleted files or directories.
You can format a file system only when no other users are accessing the file system.
Perform this task in user view.
Format a file system.
format filesystem
Displaying directory information
Display directory or file information.
dir [ /all ] [ file | directory | /all-filesystems ]
Displaying the working directory
Display the working directory.
pwd
Changing the working directory
Change the working directory.
cd { directory | .. }
Creating a directory
Create a directory.
mkdir directory
Renaming a directory
Rename a directory.
rename source-directory dest-directory
Archiving or extracting directories
When you archive or extract directories or display archived directories, files in the directories are also archived, extracted, or displayed.
Archive directories.
tar create [ gz ] archive-file dest-file [ verbose ] source source-directory &<1-5>
Extract directories.
tar extract archive-file file [ verbose ] [ screen | to directory ]
Display archived directories.
tar list archive-file file
Deleting a directory
To delete a directory, you must delete all files and subdirectories in the directory. To delete a file, use the delete command. To delete a subdirectory, use the rmdir command.
Deleting a directory permanently deletes all its files in the recycle bin, if any.
Delete a directory.
rmdir directory
Setting the operation mode for directories
The device supports the following directory operation modes:
·     alert—The system prompts for confirmation when your operation might cause problems such as data loss. This mode provides an opportunity to cancel a disruptive operation.
·     quiet—The system does not prompt for confirmation.
To set the operation mode for directories:
Step
Remarks
N/A
2.     Set the operation mode for directories.
file prompt { alert | quiet }
The default mode is alert.
This command also sets the operation mode for files.
Managing files
You can create a file by copying a file, downloading a file, or using the save command. For more information about downloading a file, see "Configuring FTP" and "Configuring TFTP." For more information about the save command, see Fundamentals Command Reference.
Displaying file information
Displaying the contents of a text file
Display the contents of a text file.
more file
Renaming a file
Rename a file.
rename source-file dest-file
Copying a file
Copy a file.
copy source-file { dest-file | dest-directory } [ source interface interface-type interface-number ]
Moving a file
Move a file.
Compressing or decompressing a file
Compress a file.
gzip file
Decompress a file.
gunzip file
Archiving or extracting files
Archive files.
tar create [ gz ] archive-file dest-file [ verbose ] source source-file &<1-5>
Extract files.
Display the names of archived files.
Deleting or restoring a file
You can delete a file permanently or move it to the recycle bin. A file moved to the recycle bin can be restored, but a permanently deleted file cannot.
Files in the recycle bin occupy storage space. To save storage space, periodically empty the recycle bin by using the reset recycle-bin command.
Delete a file by moving it to the recycle bin.
delete file
Restore a file from the recycle bin.
undelete file
Delete a file permanently.
delete /unreserved file
IMPORTANT:
Do not use the delete command to delete files from the recycle bin. To delete files from the recycle bin, use the reset recycle-bin command.
Deleting files from the recycle bin
Each file system has a recycle bin of its own.
A recycle bin is a folder named .trash in the root directory of a file system.
To view which files or directories are in a recycle bin, use either of the following methods:
·     Access the file system and execute the dir/all .trash command.
·     Execute the cd .trash command to enter the recycle bin folder, and then execute the dir command.
To delete files from a recycle bin, perform the following task in user view:
Delete files from the recycle bin.
reset recycle-bin [ /force ]
Calculating the file digest
File digests are used to verify file integrity.
Use the following commands in user view:
Calculate the digest of a file by using the SHA-256 algorithm.
sha256sum file
Calculate the digest of a file by using the MD5 algorithm.
md5sum file
Setting the operation mode for files
The device supports the following file operation modes:
·     alert—The system prompts for confirmation when your operation might cause problems such as file corruption or data loss. This mode provides an opportunity to cancel a disruptive operation.
To set the operation mode for files:
Step
Remarks
N/A
2.     Set the operation mode for files.
This command also sets the operation mode for directories.
Managing configuration files
Overview
You can manage configuration files from the CLI or the Boot ROM menu. The following information explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
Factory defaults
The device is shipped with some basic settings called factory defaults. These default settings ensure that the device can start up and run correctly when it does not have a startup configuration file or when the configuration file is corrupt.
Factory defaults vary by device models and might differ from the initial default settings for the commands.
To display the factory defaults, use the display default-configuration command.
Startup configuration
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
If no next-startup configuration files exist, the device starts up with the factory defaults.
You can display the startup configuration by using one of the following methods:
·     Execute the display startup command. To display detailed file contents, use the more command.
·     Execute the display current-configuration command before changing the configuration after the device reboots.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
Next-startup configuration file redundancy
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to load the startup configuration in the following order:
1.     The main next-startup configuration file.
2.     The backup next-startup configuration file if the main next-startup configuration file does not exist or is corrupt.
3.     The factory defaults if the backup configuration file is unavailable.
Configuration file formats
Configuration files you specify for saving configuration must use the .cfg extension. A .cfg configuration file is a human-readable text file. When you save configuration to a .cfg file, the device automatically saves the configuration to an .mdb user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
Startup configuration file selection
At startup, the device uses the following procedure to identify the configuration file to load:
1.     The device searches for a valid .cfg next-startup configuration file.
2.     If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3.     If a matching .mdb file is found, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
Configuration file content organization and format
IMPORTANT:
To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load at startup, use a configuration file created on the device. If you edit the configuration file, make sure all edits are compliant with the requirements.
A configuration file must meet the following requirements:
·     All commands are saved in their complete form.
·     Commands are sorted in sections by different command views, including system view, interface view, protocol view, and user line view.
·     Two adjacent sections are separated by a pound sign (#).
·     The configuration file ends with the word return.
Compatibility information
Enabling configuration encryption
Configuration encryption enables the device to encrypt a startup configuration file automatically when it saves the running configuration. All H3C devices running Comware 7 software use the same private key or public key to encrypt configuration files.
Only H3C devices running Comware 7 software can decrypt the encrypted configuration files.
To enable configuration encryption:
Step
Remarks
N/A
2.     Enable configuration encryption.
configuration encrypt { private-key | public-key }
By default, configuration encryption is disabled. Configuration is saved unencrypted.
Comparing configurations for their differences
You can compare configuration files or compare a configuration file with the running configuration for their differences.
If you specify the next-startup configuration for a comparison, the system selects the next-startup configuration file to be compared with in the following order:
2.     The backup next-startup configuration file if the main next-startup configuration file is unavailable. For example, the configuration file does not exist or is corrupt.
If both the main and backup next-startup configuration files are unavailable, the system displays a message indicating that no next-startup configuration files exist.
To compare configurations for their differences in any view:
Display the differences that a configuration file, the running configuration, or the next-startup configuration has as compared with the specified source configuration file.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
Display the differences that a configuration file or the next-startup configuration has as compared with the running configuration.
display diff current-configuration { configfile file-name-d | startup-configuration }
Display the differences that a configuration file has as compared with the next-startup configuration.
display diff startup-configuration configfile file-name-d
Display the differences that the running configuration has as compared with the next-startup configuration.
·     Method 1:
display diff startup-configuration current-configuration
·     Method 2:
display current-configuration diff
Saving the running configuration
When an IRF member device splits from the IRF fabric, its settings are retained in memory but removed from the running configuration on the IRF fabric. Saving the running configuration before the IRF fabric recovers will remove the member device's settings from the next-startup configuration file.
If you have saved the running configuration before the member device rejoins the IRF fabric, perform the following steps to restore the member device settings to the next-startup configuration file:
1.     Resolve the split issue.
2.     Reboot the member device to rejoin the IRF fabric.
3.     After the member device rejoins the IRF fabric, execute the display current-configuration command to verify that the member device's settings have been restored from memory to the running configuration.
4.     Save the running configuration to the next-startup configuration file on the IRF fabric.
IMPORTANT
IMPORTANT:
To ensure a successful configuration restoration, make sure the IRF fabric has not rebooted after the member device left.
Using different methods to save the running configuration
When you save the running configuration to a configuration file, you can specify the file as a next-startup configuration file.
If you are specifying the file as a next-startup configuration file, use one of the following methods to save the configuration:
·     Fast mode—Use the save command without the safely keyword. In this mode, the device directly overwrites the target next-startup configuration file. If a reboot or power failure occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots (see "Specifying a next-startup configuration file").
·     Safe mode—Use the save command with the safely keyword. Safe mode is slower than fast mode, but more secure. In safe mode, the system saves the configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot or power failure occurs during the save operation, the next-startup configuration file is still retained.
Use the safe mode if the power source is not reliable or you are remotely configuring the device.
To save the running configuration, perform one of the following tasks in any view:
Remarks
Save the running configuration to a configuration file without specifying the file as a next-startup configuration file.
Support for the all keyword depends on the device model. For more information, see Fundamentals Command Reference.
Save the running configuration to a configuration file and specify the file as a next-startup configuration file.
save [ safely ] [ backup | main ] [ force ] [ changed ]
Make sure you save the configuration to a file in the root directory of a storage medium.
In an IRF fabric, this command saves the configuration to all IRF member devices.
As a best practice, specify the safely keyword for reliable configuration saving.
If you specify only the safely keyword, the command saves the configuration to the main startup configuration file.
If the force keyword is specified, the command saves the configuration to the existing next-startup configuration file.
If the force keyword is not specified, the command allows you to specify a new next-startup configuration file.
Configuring configuration rollback
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback feature. This feature helps you revert to a previous configuration state or adapt the running configuration to different network environments.
The configuration rollback feature compares the running configuration against the specified replacement configuration file and handles configuration differences as follows:
·     If a command in the running configuration is not in the replacement file, the rollback feature executes the undo form of the command.
·     If a command in the replacement file is not in the running configuration, the rollback feature adds the command to the running configuration.
·     If a command has different settings in the running configuration and the configuration file, the rollback feature replaces the running command setting with the setting in the configuration file.
To facilitate configuration rollback, the configuration archive feature was developed. This feature enables the system to save the running configuration automatically at regular intervals.
Configuration task list
Tasks at a glance
(Required.) Setting configuration archive parameters
(Required.) Perform one of the following tasks:
·     Enabling automatic configuration archiving
·     Manually archiving the running configuration
(Required.) Rolling back configuration
Before archiving the running configuration, either manually or automatically, you must set a file directory and file name prefix for configuration archives.
Configuration archives are named in the format of prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
If you change the file directory or file name prefix, or reboot the device, the following events occur:
·     The old configuration archives change to common configuration files.
·     The configuration archive counter is reset.
·     The display archive configuration command no longer displays the old configuration archives.
·     The serial number for new configuration archives starts at 1.
After the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
Configuration guidelines
In an IRF fabric, the configuration archive feature saves the running configuration only on the master device. To make sure the system can archive the running configuration after a master/subordinate switchover, create the directory on all IRF members.
To set configuration archive parameters:
Step
Remarks
N/A
2.     Set the directory and file name prefix for archiving the running configuration.
archive configuration location directory filename-prefix filename-prefix
For IRF-capable devices, do not include member ID information in the directory name.
By default, no path or file name prefix is set for configuration archives, and the system does not regularly save configuration.
IMPORTANT IMPORTANT:
The undo form of this command performs the following operations:
·     Disables both manual and automatic configuration archiving.
·     Restores the default settings for the archive configuration interval and archive configuration max commands.
·     Clears the configuration archive information displayed by using the display archive configuration command.
3.     (Optional.) Set the maximum number of configuration archives.
archive configuration max file-number
The default number is 5.
Change the setting depending on the amount of storage available on the device.
Make sure you have set an archive path and file name prefix before performing this task.
To enable automatic configuration archiving:
Step
Remarks
N/A
2.     Enable automatic configuration archiving and set the archiving interval.
archive configuration interval minutes
By default, automatic configuration archiving is disabled.
To display configuration archive names and their archiving time, use the display archive configuration command.
To save system resources, disable automatic configuration archiving and manually archive the configuration if the configuration will not be changed very often. You can also manually archive configuration before performing complicated configuration tasks. Then, you can use the archive for configuration recovery if the configuration attempt fails.
Perform the following task in user view:
Manually archive the running configuration.
To avoid a rollback failure, follow these guidelines:
·     Make sure the replacement configuration file is created by using the configuration archive feature or the save command on the local device.
·     If the configuration file is not created on the local device, make sure the command lines in the configuration file are fully compatible with the local device.
·     The replacement configuration file is not encrypted.
To perform a configuration rollback:
Step
Remarks
N/A
2.     Roll the running configuration back to the configuration defined by a configuration file.
The specified configuration file must not be encrypted.
The configuration rollback feature might fail to reconfigure some commands in the running configuration for one of the following reasons:
·     A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback feature cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
·     A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
·     The commands in different views are dependent on each other.
·     Commands or command settings that the device does not support cannot be added to the running configuration.
If configuration rollback fails for some command lines, the system outputs a rollback failure message. To identify those command lines, use the display diff current-configuration configfile file-name-d command, with the replacement file specified for the file-name-d argument. The command lines that have failed to roll back are displayed as configuration differences between the running configuration and the replacement configuration file.
CAUTION:
In an IRF fabric, the undo startup saved-configuration command can cause an IRF split after the IRF fabric or an IRF member reboots.
You can specify a .cfg file as a next-startup configuration file when you execute the save [ safely ] [ backup | main ] [ force ] command.
Alternatively, you can execute the startup saved-configuration cfgfile [ backup | main ] command to specify a .cfg configuration file as the main or backup next-startup configuration file.
When you perform this task, follow these restrictions and guidelines:
·     On an IRF-incapable device, make sure the specified configuration file is valid and has been saved to the root directory of a storage medium.
·     On an IRF fabric, make sure the specified configuration file is valid and has been saved to the root directory of the storage medium on each member device.
·     As a best practice, specify different files as the main and backup next-startup configuration files.
·     The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file.
To specify a next-startup configuration file, perform the following task in user view:
Remarks
Specify a next-startup configuration file.
By default, no next-startup configuration files are specified.
If you do not specify the backup or main keyword, this command specifies the configuration file as the main next-startup configuration file.
Use the display startup command and the display saved-configuration command in any view to verify the configuration.
Backing up the main next-startup configuration file to a TFTP server
Before performing this task, make sure the following requirements are met:
·     The server is reachable.
·     The server is enabled with TFTP service.
·     You have read and write permissions to the server.
To back up the main next-startup configuration file to a TFTP server:
Step
Remarks
1.     (Optional.) Verify that a next-startup configuration file has been specified in user view.
display startup
If no next-startup configuration file has been specified, the backup operation will fail.
2.     Back up the next-startup configuration file to a TFTP server in user view.
backup startup-configuration to { ipv4-server | ipv6 ipv6-server } [ dest-filename ]
N/A
Restoring the main next-startup configuration file from a TFTP server
Perform this task to download a configuration file to the device from a TFTP server and specify the file as the main next-startup configuration file.
Before restoring the next-startup configuration file, make sure the following requirements are met:
To restore the main next-startup configuration file from a TFTP server:
Step
1.     Restore the main next-startup configuration file from a TFTP server in user view.
restore startup-configuration from { ipv4-server | ipv6 ipv6-server } src-filename
2.     (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file.
display startup
Deleting a next-startup configuration file
CAUTION:
This task permanently deletes a next-startup configuration file from all member devices. Before performing this task, back up the file as needed. (IRF-capable devices.)
This task permanently deletes a next-startup configuration file from the device. Before performing this task, back up the file as needed. (IRF-incapable devices.)
Delete a next-startup configuration file if one of the following events occurs:
·     After you upgrade system software, the file no longer matches the new system software.
·     The file is corrupt or not fully compatible with the device.
If both the main and backup next-startup configuration files are deleted, the device uses the factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
Remarks
Delete a next-startup configuration file.
If you do not specify the backup or main keyword, this command deletes the main next-startup configuration file.
Displaying and maintaining configuration files
Display information about configuration rollback.
Display the running configuration.
display current-configuration [ configuration [ module-name ] | exclude-provision | interface [ interface-type [ interface-number ] ] ]
Display the factory defaults.
Display the differences between configurations.
·     display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
·     display diff current-configuration { configfile file-name-d | startup-configuration }
·     display diff startup-configuration { configfile file-name-d | current-configuration }
Display the contents of the configuration file for the next system startup.
Display the names of the configuration files for this startup and the next startup.
display startup
Display the valid configuration in the current view.
display this
Upgrading software
Overview
Software upgrade enables you to add new features and fix bugs. This chapter describes types of software and methods to upgrade software from the CLI. For a comparison of all software upgrade methods, see "Upgrade methods."
Software types
The following software types are available:
·     Boot ROM image—Contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the device cannot start up correctly. For easy software compatibility management, the Boot ROM image is packaged in the .bin Boot image file. The Boot ROM image is upgraded automatically when the Boot image is upgraded.
·     Comware image—Includes the following image subcategories:
?     Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, and file system management.
?     System image—A .bin file that contains the minimum feature modules required for device operation and some basic features, including device management, interface management, configuration management, and routing. To have advanced features, you must purchase feature images.
?     Feature image—A .bin file that contains advanced software features. Users purchase feature images as needed.
?     Patch image—A .bin file irregularly released for fixing bugs without rebooting the device. A patch image does not add new features or functions.
Comware images that have been loaded are called current Comware images. Comware images specified to load at the next startup are called startup Comware images.
Boot ROM image, boot image, and system image are required for the system to operate. These images might be released separately or as a whole in one .ipe package file. If an .ipe file is used, the system decompresses the file automatically, loads the .bin images and sets them as startup software images. Typically, the Boot ROM and startup Comware images for the device are released in an .ipe file.
Software file naming conventions
Software image file names use the chassis-comware version-image type-release format, for example, wx5510-cmw710-system-d5104.bin and wx5510-cmw710-boot-d5104.bin.
Comware image redundancy and loading procedure
You can specify one main list and one backup list of Comware images.
The system always attempts to start up with the main images. If any main image does not exist or is invalid, the system tries the backup images. Figure 29 shows the entire Comware image loading procedure.
In this procedure, both the main and backup image lists have feature and patch images. If an image list does not have feature or patch images, the system starts up with the boot and system images after they pass verification.
If both the main and backup boot images are nonexistent or invalid, access the Boot ROM menu during the system startup to upgrade software.
Figure 29 Comware image loading procedure
System startup process
Upon power-on, the Boot ROM image runs to initialize hardware, and then the startup software images run to start up the entire system, as shown in Figure 30.
Figure 30 System startup process
Upgrade methods
Upgrading method
Software types
Remarks
Upgrading from the CLI
·     Boot ROM image
·     Comware images (excluding patches)
This method is disruptive. You must reboot the entire device to complete the upgrade.
Upgrading from the Boot ROM menu
·     Boot ROM image
·     Comware images
Use this method when the device cannot start up correctly.
To use this method, first connect to the console port and power cycle the device. Then, press Ctrl+B at prompt to access the Boot ROM menu.
For more information about upgrading software from the Boot ROM menu, see the release notes for the software version.
Upgrade an IRF fabric from the CLI instead of the Boot ROM menu, if possible. The Boot ROM menu method increases the service downtime, because it requires that you upgrade the member devices one by one.
Preparing for the upgrade
1.     Use the display version command to verify the current Boot ROM image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
?     Software and hardware compatibility.
?     Version and size of the upgrade software.
?     Compatibility of the upgrade software with the current Boot ROM image and startup software image.
3.     Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image. For more information about licensing, see "Managing licenses."
4.     On an IRF-incapable or standalone device, use the dir command to verify that the device has sufficient storage space for the upgrade images. On an IRF fabric, use the dir command to verify that all IRF member devices have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
5.     On an IRF-incapable or standalone device, use FTP or TFTP to transfer the upgrade image file to the root directory of the file system. On an IRF fabric, use FTP or TFTP to transfer the upgrade image file to the root directory of the file system on the master device.
For more information about FTP and TFTP, see "Configuring FTP" or "Configuring TFTP."
Upgrade task list
Tasks at a glance
Remarks
(Optional.) Preloading the Boot ROM image to
If a Boot ROM upgrade is required, you can perform this task to shorten the subsequent upgrade time. This task helps avoid upgrade problems caused by unexpected electricity failure.
If you skip this task, the device upgrades the Boot ROM automatically when it upgrades the startup Comware images.
The Boot ROM image preloaded into the Boot ROM takes effect only after you reboot the device.
(Required.) Specifying startup images and completing the upgrade
Perform this task to upgrade a standalone device or an IRF fabric.
(Optional.) Restoring or downgrading the Boot ROM image
N/A
Preloading the Boot ROM image to Boot ROM
To preload the Boot ROM image to Boot ROM:
Step
Remarks
1.     (Optional.) Back up the current Boot ROM image in the Normal area of Boot ROM.
·     Back up the image to the Backup area of Boot ROM:
bootrom backup slot slot-number-list
[ all | part ]
·     Back up the image to the file system:
bootrom read slot slot-number-list
[ all | part ]
Use either command to back up the Boot ROM image for a future version rollback or image restoration.
2.     Load the upgrade Boot ROM image to the Normal area of Boot ROM.
bootrom update file file-url slot slot-number-list [ all | part ]
Specify the downloaded software image file for the file-url argument.
The new Boot ROM image takes effect at a reboot.
To specify startup images and complete the upgrade:
Step
Remarks
1.     Specify main or backup startup images.
·     Use an .ipe file for upgrade:
boot-loader file
ipe-filename { backup | main }
·     Use .bin files for upgrade:
boot-loader file boot
boot-package system system-package [ feature feature-package&<1-30> ] { backup | main }
Upgrade files must be saved in the root directory of the file system.
To avoid configuration failure, make sure no other users are configuring or managing the device.
2.     Save the running configuration.
save
This step ensures that any configuration you have made can survive a reboot.
This step also ensures that the device loads the binary configuration file at reboot. Loading a binary configuration file is faster than loading a text configuration file. For more information about configuration file formats, see "Managing configuration files."
3.     Reboot the device.
reboot
At startup, the device reads the preloaded Boot ROM image to RAM, and loads the startup images.
4.     (Optional.) Verify the software image settings.
display boot-loader
Verify that the current software images are the same as the startup software images.
IRF-capable devices
To specify startup image files and complete the upgrade:
Step
Remarks
1.     Specify main or backup startup images for the master device.
boot-loader file
ipe-filename { all | slot slot-number } { backup | main }
boot-package system system-package [ feature feature-package&<1-30> ] { all | slot slot-number } { backup | main }
Upgrade files must be saved in the root directory of the file system on an IRF member device.
2.     Specify main startup images for each subordinate device.
·     Method 1 Use an .ipe file for upgrade:
boot-loader file ipe-filename { all | slot slot-number } { backup | main }
·     Method 2 Use .bin files for upgrade:
boot-loader file boot boot-package system system-package [ feature feature-package&<1-30> ] { all | slot slot-number } { backup | main }
·     Method 3:
boot-loader update { all | slot slot-number }
Skip this step if you have only one device.
When you use the boot-loader update command, make sure you understand the following requirements and upgrade results:
·     The boot-loader update command uses the main or backup startup image list for synchronization, instead of the current software images list.
?     The main images list is used if the master device started up with the main startup images.
?     The backup image list is used if the master device started up with the backup startup images.
·     Startup image synchronization will fail if any software image being synchronized is corrupted or is not available.
3.     Save the running configuration.
save
4.     Reboot the IRF fabric.
reboot
At startup, each device reads the preloaded Boot ROM image to RAM, and loads the startup images.
5.     (Optional.) Verify the software image settings.
display boot-loader [ slot slot-number ]
To restore or downgrade the Boot ROM image, make sure you have used the bootrom backup command or the bootrom read command to back up the image to the Backup area of Boot ROM or the file system. The bootrom read command creates two Boot ROM image files on the file system: basicbtm.bin for the basic segment and extendbtm.bin for the extended section.
Before performing a downgrade, also verify software compatibility.
Perform the following task in user view to restore or downgrade the Boot ROM image:
Step
Remarks
1.     Replace the Boot ROM image in the Normal area of Boot ROM.
bootrom restore slot slot-number-list [ all | part ]
N/A
2.     Reboot the device.
reboot
At startup, the system runs the new Boot ROM image to complete the restoration or downgrade.
Displaying and maintaining software image settings
Display current software images and startup software images.
Software upgrade example (IRF-incapable devices)
As shown in Figure 31, use file startup-a2105.ipe to upgrade software images for the AC.
Figure 31 Network diagram
Configuration procedure
# Configure IP addresses and routes. Make sure the AC and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the AC and the TFTP server. (Details not shown.)
# Display information about the current software images.
<Sysname> display version
# Back up the current software images.
<Sysname> copy boot.bin boot_backup.bin
<Sysname> copy system.bin system_backup.bin
# Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin backup
# Use TFTP to download the image file startup-a2105.ipe from the TFTP server to the root directory of a file system. The flash memory is used in this example.
<Sysname> tftp 2.2.2.2 get startup-a2105.ipe
# Specify startup-a2105.ipe as the main startup image file.
<Sysname> boot-loader file flash:/startup-a2105.ipe main
# Verify the startup image settings.
<Sysname> display boot-loader
# Reboot the device to complete the upgrade.
<Sysname> reboot
# Verify that the device is running the correct software.
Software upgrade example (IRF-capable devices)
Network requirements
As shown in Figure 32, use file startup-a2105.ipe to upgrade software images for the IRF fabric.
Figure 32 Network diagram
# Configure IP addresses and routes. Make sure the IRF fabric and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the IRF fabric and the TFTP server. (Details not shown.)
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for both member devices.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin slot 1 backup
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin slot 2 backup
# Download image file startup-a2105.ipe from the TFTP server to the root directory of a file system on the master device. The CF card is used in this example.
# Specify startup-a2105.ipe as the main startup image file for both member devices.
<Sysname> boot-loader file cfa0:/startup-a2105.ipe slot 1 main
<Sysname> boot-loader file cfa0:/startup-a2105.ipe slot 2 main
# Reboot the IRF fabric to complete the upgrade.
<Sysname> reboot
# Verify that the IRF fabric is running the correct software.
Managing the device
This chapter describes how to configure basic device parameters and manage the device.
You can perform the configuration tasks in this chapter in any order.
Device management task list
Tasks at a glance
(Required.) Configuring the device name
(Required.) Configuring the system time
(Optional.) Enabling displaying the copyright statement
(Optional.) Configuring banners
(Optional.) Rebooting the device
(Optional.) Scheduling a task
(Optional.) Disabling password recovery capability
(Optional.) Setting the port status detection timer
(Optional.) Monitoring CPU usage
(Required.) Setting memory alarm thresholds
(Required.) Configuring the temperature alarm thresholds
(Required.) Verifying and diagnosing transceiver modules
(Optional.) Restoring the factory-default configuration
A device name (also called hostname) identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
To configure the device name:
Step
Remarks
N/A
2.     Configure the device name.
sysname sysname
The default device name is H3C.
Correct system time is essential to network management and communication. Configure the system time correctly before you run the device on the network.
The device can use the locally set system time, or obtain the UTC time from an NTP source and calculate the system time.
·     When using the locally set system time, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
·     After obtaining the UTC time from an NTP source, the device uses the UTC time, time zone, and daylight saving time to calculate the system time. Then, the device periodically synchronizes its UTC time and recalculates the system time. For more information about NTP, see Network Management and Monitoring Configuration Guide.
The system time calculated by using the UTC time from an NTP time source is more precise.
To configure the device to use the local system time:
Step
Remarks
N/A
2.     Specify the system time source.
clock protocol none
By default, the device uses the NTP time source.
If you execute the clock protocol command multiple times, the most recent configuration takes effect.
N/A
4.     Set the local system time.
clock datetime time date
N/A
5.     Enter system view.
N/A
6.     Set the time zone.
By default, the system uses the UTC time zone.
This setting must be consistent with the time zone of the place where the device resides.
After a time zone change, the device recalculates the system time. To view the system time, use the display clock command.
7.     (Optional.) Set the daylight saving time.
By default, the daylight saving time is not set.
The settings must be consistent with the daylight saving time parameters of the place where the device resides.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
To configure the device to obtain the UTC time from a time source and calculate the system time:
Step
Remarks
N/A
clock protocol ntp
3.     Set the time zone.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
4.     (Optional.) Set the daylight saving time.
This feature enables the device to display the copyright statement in the following situations:
·     When a Telnet or SSH user logs in.
·     When a console user quits user view. This is because the device automatically tries to restart the user session.
The following is a sample copyright statement:
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
To enable displaying the copyright statement:
Step
Remarks
N/A
2.     Enable displaying the copyright statement.
copyright-info enable
Configuring banners
Banners are messages that the system displays when a user logs in.
Banner types
The system supports the following banners:
·     Legal banner—Appears after the copyright or license statement. To continue login, the user must enter Y or press Enter. To quit the process, the user must enter N. Y and N are case insensitive.
·     Message of the Day (MOTD) banner—Appears after the legal banner and before the login banner.
·     Login banner—Appears only when password or scheme authentication is configured.
·     Shell banner—Appears for a user when the user accesses user view.
Banner input methods
You can configure a banner by using one of the following methods:
·     Input the entire command line in a single line.
The entire command line, including the command keywords, the banner, and the delimiters, can have up to 511 characters. The delimiters for the banner can be any printable character but must be the same. You cannot press Enter before you input the end delimiter.
For example, you can configure the shell banner "Have a nice day." as follows:
<System> system-view
[System] header shell %Have a nice day.%
·     Input the command line in multiple lines.
The banner and the delimiters can have up to 2002 characters. The banner can contain carriage returns. A carriage return is counted as two characters.
To input a banner configuration command line in multiple lines, use one of the following methods:
?     Press Enter after the final command keyword, type the banner, and end the final line with the delimiter character %.
For example, you can configure the banner "Have a nice day." as follows:
Have a nice day.%
?     After you type the final command keyword, type any printable character as the start delimiter for the banner and press Enter. Then, type the banner and end the final line with the same delimiter.
[System] header shell A
Please input banner content, and quit with the character 'A'.
Have a nice day.A
?     After you type the final command keyword, type the start delimiter and part of the banner. Make sure the final character of the final string is different from the start delimiter. Then, press Enter, type the rest of the banner, and end the final line with the same delimiter.
[System] header shell AHave a nice day.
A
To configure banners:
Step
Remarks
N/A
2.     Configure the legal banner.
header legal text
By default, no legal banner is configured.
3.     Configure the MOTD banner.
header motd text
By default, no MOTD banner is configured.
4.     Configure the login banner.
header login text
By default, no login banner is configured.
5.     Configure the shell banner.
header shell text
By default, no shell banner is configured.
CAUTION:
·     A device reboot might interrupt network services.
·     To avoid configuration loss, use the save command to save the running configuration before a reboot. For more information about the save command, see Fundamentals Command Reference.
·     Before a reboot, use the display startup and display boot-loader commands to verify that the startup configuration file and startup software images are correctly specified. If a startup configuration file or software image problem exists, the device cannot start up correctly. For more information about the two display commands, see Fundamentals Command Reference.
The following device reboot methods are available:
·     Schedule a reboot at the CLI, so the device automatically reboots at the specified time or after the specified period of time.
·     Immediately reboot the device at the CLI.
During the reboot process, the device performs the following operations:
a.     Resets all of its chips.
b.     Uses the Boot ROM to verify the startup software package, decompress the package, and load the images.
c.     Initializes the system.
·     Power off and then power on the device. This method might cause data loss, and is the least-preferred method.
Using the CLI, you can reboot the device from a remote host.
For data security, the device does not reboot while it is performing file operations.
Rebooting devices immediately at the CLI
Execute the following command in user view:
Reboot an IRF member device or all IRF member devices.
Scheduling a device reboot
When you schedule a reboot, follow these guidelines:
·     The device supports only one device reboot schedule. If you configure the scheduler reboot at or scheduler reboot delay command multiple times or configure both commands, the most recent configuration takes effect.
·     The automatic reboot configuration takes effect on all member devices. It will be canceled if a master/subordinate switchover occurs.
To schedule a reboot, execute one of the following commands in user view:
Remarks
Specify the reboot date and time.
By default, no reboot date or time is specified.
Specify the reboot delay time.
scheduler reboot delay time
By default, no reboot delay time is specified.
Scheduling a task
You can schedule the device to automatically execute a command or a set of commands without administrative interference.
You can configure a periodic schedule or a non-periodic schedule. A non-periodic schedule is not saved to the configuration file and is lost when the device reboots. A periodic schedule is saved to the startup configuration file and is automatically executed periodically.
When you schedule a task, follow these restrictions and guidelines:
·     To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
·     Make sure all commands in a schedule are compliant to the command syntax. The system does not check the syntax when you assign a command to a job.
·     A schedule cannot contain any one of these commands: telnet, ftp, ssh2, and monitor process.
·     A schedule does not support user interaction. If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
·     A schedule is executed in the background, and no output (except for logs, traps, and debug information) is displayed for the schedule.
To configure a non-periodic schedule for the device:
Step
Remarks
N/A
2.     Create a job.
scheduler job job-name
By default, no job exists.
3.     Assign a command to the job.
command id command
By default, no command is assigned to a job.
A command with a smaller ID is executed first.
4.     Exit to system view.
N/A
5.     Create a schedule.
By default, no schedule exists.
6.     Assign a job to a schedule.
job job-name
By default, no job is assigned to a schedule.
You can assign multiple jobs to a schedule. The jobs will be executed concurrently.
7.     Assign user roles to the schedule.
user-role role-name
By default, a schedule has the user role of the schedule creator.
You can assign up to 64 user roles to a schedule. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule.
The security-audit role is mutually exclusive with any other user roles. Assigning the security-audit role removes existing user role assignments. Assigning any other user roles removes the security-audit role assignment.
8.     Specify an execution time table for the non-periodic schedule.
·     Specify the execution date and time:
time at time date
·     Specify the execution days and time:
·     Specify the execution delay time:
time once delay time
By default, no execution time is specified for a schedule.
Executing commands clock datetime, clock summer-time, and clock timezone does not change the execution time table that is already configured for a schedule.
To configure a periodic schedule for the device:
Step
Remarks
N/A
2.     Create a job.
command id command
A job with a smaller ID is executed first.
N/A
job job-name
user-role role-name
8.     Specify an execution time table for the periodic schedule.
·     Execute the schedule at an interval from the specified time on:
·     Execute the schedule at the specified time on every specified day in a month or week:
time repeating [ at time [date ] ] interval interval-time
Schedule configuration example
As shown in Figure 33, the PC accesses the AC through the AP. The AC acts as the DHCP server to assign IP addresses to the AP and PC. The AP is connected to the AC through Radio 1.
To save energy, configure the AC to perform the following operations:
·     Enable Radio 1 at 8:00 a.m. every day.
·     Disable Radio 1 at 20:00 every day.
Figure 33 Network diagram
Scheduling procedure
This section describes only the scheduling procedure. For information about wireless access configuration, see WLAN Configuration Guide.
# Enter system view.
<AC> system-view
# Configure a job for disabling Radio 1.
[AC] scheduler job radio_disable
[AC-job-radio_disable] command 1 system-view
[AC-job-radio_disable] command 2 wlan ap ap1 model WA536-WW
[AC-job-radio_disable] command 3 radio 1
[AC-job-radio_disable] command 4 radio disable
[AC-job-radio_disable] quit
# Configure a periodic schedule for disabling Radio 1 at 20:00 every day.
[AC] scheduler schedule stop_radio
[AC-schedule-stop_radio] job radio_disable
[AC-schedule-stop_radio] time repeating at 20:00
[AC-schedule-stop_radio] quit
# Configure a job for enabling Radio 1.
[AC] scheduler job radio_enable
[AC-job-radio_enable] command 1 system-view
[AC-job-radio_enable] command 2 wlan ap ap1 model WA536-WW
[AC-job-radio_enable] command 3 radio 1
[AC-job-radio_enable] command 4 radio enable
[AC-job-radio_enable] quit
# Configure a periodic schedule for enabling Radio 1 at 8:00 a.m. every day.
[AC] scheduler schedule start_radio
[AC-schedule-start_radio] job radio_enable
[AC-schedule-start_radio] time repeating at 8:00
[AC-schedule-start_radio] quit
 Verifying the scheduling
# Display information about the AP. Verify that the value of the Admin State field is up from 8:00 to 20:00 and down outside of the time range.
[AC] display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup Type                   : NULL
Online time                   : 0 days 2 hours 18 minutes 10 seconds
System up time                : 0 days 2 hours 19 minutes 11 seconds
Model                         : WA536-WW
Region code                   : HK
Region code lock              : Disable
Serial ID                     : 219801A1NQB117012935
MAC address                   : 586a-b1fb-e2c0
IP address                    : 100.1.0.1
H/W version                   : Ver.C
S/W version                   : V700R001B64D003
Boot version                  : 7.01
USB state                     : N/A
Power Level                   : Middle
PowerInfo                     : N/A
Description                   : Not configured
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
Discovery type                : Unknown
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 3159
Received control packets      : 3159
Echo requests                 : 0
Lost echo responses           : 0
Average echo delay            : 0
Last reboot reason            : N/A
Latest IP address             : N/A
Tunnel down reason            : N/A
Connection count              : 1
Backup Ipv4                   : Not configured
Backup Ipv6                   : Not configured
Tunnel encryption             : Disabled
LED mode                      : Normal
Remote configuration          : Disabled
Radio 1:
    Basic BSSID               : 586a-b1fb-e2c0
    Admin state               : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Secondary channel offset  : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 149
    Channel usage(%)          : 0
    Max power                 : 20 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise floor               : -102 dBm
Protection mode           : cts-to-self
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    HT protection mode        : No protection
Radio 2:
    Basic BSSID               : N/A
    Admin state               : Down
    Active band-width         : 20/40/80MHz
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 100(auto)
    Max power                 : 25 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : 0 dBm
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
Radio 3:
    Basic BSSID               : N/A
    Admin state               : Down
    Radio type                : 802.11n(2.4GHz)
    Channel band-width        : 20MHz
    Active band-width         : 20MHz
    Secondary channel offset  : SCN
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 1(auto)
    Max power                 : 13 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : 0 dBm
Password recovery capability controls console user access to the device configuration and SDRAM from Boot ROM menus. For more information about Boot ROM menus, see the release notes.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure a new password.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To disable password recovery capability:
Step
Remarks
N/A
2.     Disable password recovery capability.
undo password-recovery enable
By default, password recovery capability is enabled.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
To set the port status detection timer:
Step
Remarks
N/A
2.     Set the port status detection timer.
shutdown-interval time
The default setting is 30 seconds.
When monitoring the CPU usage, the device performs the following operations:
·     Samples CPU usage at an interval of 1 minute, and compares the sample with the CPU usage threshold. If the sample is greater, the device sends a trap.
·     Samples and saves CPU usage at a configurable interval if CPU usage tracking is enabled.
To monitor CPU usage:
Step
Remarks
N/A
2.     Enable CPU usage tracking.
monitor cpu-usage enable [ slot slot-number ]
By default, CPU usage tracking is enabled.
3.     Set the sampling interval for CPU usage tracking.
monitor cpu-usage interval interval-value [ slot slot-number ]
By default, the sampling interval for CPU usage tracking is 1 minute.
4.     Set the CPU usage threshold.
monitor cpu-usage threshold cpu-threshold [ slot slot-number ]
By default, the CPU usage threshold is 99%.
5.     Exit to user view.
N/A
6.     Display CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number ]
This command is available in any view.
7.     Display CPU usage monitoring settings.
display cpu-usage configuration [ slot slot-number ]
8.     Display the historical CPU usage statistics in a coordinate system.
display cpu-usage history [ job job-id ] [ slot slot-number ]
To monitor memory usage, the device performs the following operations:
·     Samples memory usage at an interval of 1 minute, and compares the sample with the memory usage threshold. If the sample is greater, the device sends a trap.
·     Monitors the amount of free memory space in real time. If the amount of free memory space exceeds a free-memory threshold, the system generates an alarm notification and sends it to affected service modules or processes. If the amount of free memory space drops below a free-memory threshold, the system generates an alarm-removed notification and sends it to affected service modules or processes.
As shown in Table 13 and Figure 34, the system supports the following free-memory thresholds:
·     Normal state threshold.
·     Minor alarm threshold.
·     Severe alarm threshold.
·     Critical alarm threshold.
Table 13 Memory alarm notifications and memory alarm-removed notifications
Notification
Triggering condition
Remarks
Minor alarm notification
The amount of free memory space decreases to or below the minor alarm threshold for the first time.
After generating and sending a minor alarm notification, the system does not generate and send any additional minor alarm notifications until the first minor alarm is removed.
Severe alarm notification
The amount of free memory space decreases to or below the severe alarm threshold for the first time.
After generating and sending a severe alarm notification, the system does not generate and send any additional severe alarm notifications until the first severe alarm is removed.
Critical alarm notification
The amount of free memory space decreases to or below the critical alarm threshold for the first time.
After generating and sending a critical alarm notification, the system does not generate and send any additional critical alarm notifications until the first critical alarm is removed.
Critical alarm-removed notification
The amount of free memory space increases to or above the severe alarm threshold.
N/A
Severe alarm-removed notification
The amount of free memory space increases to or above the minor alarm threshold.
N/A
Minor alarm-removed notification
The amount of free memory space increases to or above the normal state threshold.
N/A
Figure 34 Memory alarm notifications and alarm-removed notifications
To set memory alarm thresholds:
Step
Remarks
N/A
2.     Set the memory usage threshold.
memory-threshold [ slot slot-number ] usage memory-threshold
By default, the memory usage threshold is 100%.
3.     Set the free-memory thresholds.
memory-threshold [ slot slot-number ] minor minor-value severe severe-value critical critical-value normal normal-value
For information about the default settings, see Fundamentals Command Reference.
The device monitors its temperature based on the following thresholds:
·     Low-temperature threshold.
·     High-temperature warning threshold.
·     High-temperature alarming threshold.
When the temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
To configure the temperature alarm thresholds:
Step
Remarks
N/A
2.     Configure the temperature alarm thresholds.
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
The defaults vary by temperature sensor model. To view the defaults, use the undo temperature-limit command to restore the defaults and then execute the display environment command.
The high-temperature alarming threshold must be higher than the high-temperature warning threshold. The high-temperature warning threshold must be higher than the low-temperature threshold.
The following matrix shows the feature and hardware compatibility:
Hardware series
Model
Feature compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
WX1840H
Yes
WX3800H series
WX3820H
WX3840H
Yes
WX5800H series
WX5860H
Yes
Verifying transceiver modules
You can use one of the following methods to verify the genuineness of a transceiver module:
·     Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance, and vendor name.
·     Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration, including the serial number, manufacturing date, and vendor name. The data is written to the storage component during debugging or testing.
Install only transceiver modules that are from H3C. If you install a transceiver module that is not from H3C, the device will generate a log message to prompt you to replace the module. For more information about log messages, see information center configuration in Network Management and Monitoring Configuration Guide.
To verify transceiver modules, execute the following commands in any view:
Remarks
Display the key parameters of transceiver modules.
N/A
Display the electrical label information of transceiver modules.
This command cannot display information for some transceiver modules.
Diagnosing transceiver modules
The device provides the alarming and digital diagnosis functions for transceiver modules. When a transceiver module fails or is not operating correctly, you can perform the following tasks:
·     Check the alarms that exist on the transceiver module to identify the fault source.
·     Examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules, execute the following commands in any view:
Remarks
Display transceiver alarms.
N/A
Display the current values of the digital diagnosis parameters on transceiver modules.
This command cannot display information about some transceiver modules.
CAUTION
CAUTION:
This task is disruptive. Use this task only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
To restore the factory-default configuration for the device, execute the following command in user view:
Remarks
Restore the factory-default configuration for the device.
restore factory-default
This command takes effect after a device reboot.
Displaying and maintaining device management configuration
Execute display commands in any view. Execute the reset command in user view.
Display the system time, date, local time zone, and daylight saving time.
display clock
Display the copyright statement.
display copyright
Display historical CPU usage statistics in a chart.
Display hardware information.
display device [ cf-card ] [ slot slot-number | verbose ]
Display electronic label information for the device.
Display or save device diagnostic information.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
Display device temperature information.
Display the operating states of fans.
display fan [ slot slot-number [ fan-id ] ]
Display memory usage statistics.
display memory [ summary ] [ slot slot-number ]
Display memory alarm thresholds and statistics.
display memory-threshold [ slot slot-number ]
Display power supply information.
display power [ power-id ]
Display job configuration information.
Display job execution log information.
display scheduler logfile
Display the automatic reboot schedule.
display scheduler reboot
Display schedule information.
Display system stability and status information.
display system stable state
Display system version information.
display version
Clear job execution log information.
reset scheduler logfile
Using Tcl
Comware V7 provides a built-in tool command language (Tcl) interpreter. From user view, you can use the tclsh command to enter Tcl configuration view to execute the following commands:
·     All Tcl 8.5 commands.
·     Comware commands.
The Tcl configuration view is equivalent to the user view. You can use Comware commands in Tcl configuration view in the same way they are used in user view. For example, you can perform the following tasks:
?     Use the system-view command to enter system view to configure features.
?     Use the quit command to return to the upper-level view.
Using Tcl to configure the device
When you use Tcl to configure the device, follow these guidelines and restrictions:
·     You can apply Tcl environment variables to Comware commands.
·     No online help information is provided for Tcl commands.
·     You cannot press Tab to complete an abbreviated Tcl command.
·     Make sure the Tcl commands can be executed correctly. If a problem occurs when the Tcl commands are being executed, you can disable the process if you log in through Telnet or SSH. If you log in from the console port, you must restart the device. H3C recommends that you log in through Telnet or SSH.
To use Tcl to configure the device:
Enter Tcl configuration view from user view.
tclsh
Execute a Tcl command.
Tcl command
Return from Tcl configuration view to user view.
tclquit
·     The tclquit command has the same effect as the quit command in Tcl configuration view.
·     If you have used a Comware command to enter a subview under Tcl configuration view, you can only use the quit command, instead of the tclquit command, to return to the upper-level view.
Executing Comware commands in Tcl configuration view
Follow these restrictions and guidelines when you execute Comware commands in Tcl configuration view:
·     For Comware commands, you can enter ? to obtain online help or press Tab to complete an abbreviated command. For more information, see "Using the CLI."
·     The cli command is a Tcl command, so you cannot enter ? to obtain online help or press Tab to complete an abbreviated command.
·     Successfully executed Comware commands are saved to command history buffers. You can use the upper arrow or lower arrow key to obtain executed commands.
·     To execute multiple Comware commands in one operation:
?     Enter multiple Comware commands separated by semi-colons to execute the commands in the order they are entered. For example, wlan ap ap1 model WA536-WW ; radio 1.
?     Specify multiple Comware commands for the cli command, quote them, and separate them by a space and a semicolon. For example, cli " wlan ap ap1 model WA536-WW ; radio 1".
?     Specify one Comware command for each cli command and separate them by a space and a semicolon. For example, cli wlan ap ap1 model WA536-WW ; cli radio 1.
To execute Comware commands in Tcl configuration view:
Step
Remarks
1.     Enter Tcl configuration view
tclsh
N/A
2.     Execute Comware commands directly.
Use either method.
If you execute a Comware command directly, a Tcl command is executed when the Tcl command conflicts with the Comware command.
If you execute a Comware command by using the cli command, the Comware command is executed when it conflicts with a Tcl command.
3.     Execute Comware commands by using the cli command.
cli command
Using Python
Overview
Comware V7 provides a built-in Python interpreter that supports the following items:
·     Python 2.7 commands.
·     Python 2.7 standard API.
·     Comware V7 extended API. For more information about the Comware V7 extended API, see "Comware V7 extended Python API."
·     Python scripts. You can use a Python script to configure the system.
Entering the Python shell
To use Python commands and APIs, you must enter the Python shell.
Enter the Python shell from user view.
python
Executing a Python script
Execute a Python script in user view.
Execute a Python script.
python filename
Python usage example
Use a Python script to perform the following tasks:
·     Download configuration files main.cfg and backup.cfg to the device.
·     Configure the files as the main and backup configuration files for the next startup.
Figure 35 Network diagram
Usage procedure
# Use a text editor on the PC to edit Python script test.py as follows:
#!usr/bin/python
import comware
comware.Transfer('tftp', '192.168.1.26', 'main.cfg', 'flash:/main.cfg')
comware.Transfer('tftp', '192.168.1.26', 'backup.cfg', 'flash:/backup.cfg')
comware.CLI('startup saved-configuration flash:/main.cfg main ;startup saved-configuration flash:/backup.cfg backup')
# Use TFTP to download the script to the device.
<Sysname> tftp 192.168.1.26 get test.py
# Execute the script.
<Sysname> python flash:/test.py
<Sysname> startup saved-configuration flash:/main.cfg main
Please wait...... Done.
<Sysname> startup saved-configuration flash:/backup.cfg backup
# Display startup configuration files.
<Sysname> display startup
 Current startup saved-configuration file: flash:/startup.cfg
 Next main startup saved-configuration file: flash:/main.cfg
 Next backup startup saved-configuration file: flash:/backup.cfg
The Comware V7 extended Python API is compatible with the Python syntax.
The WX1800H series access controllers do not support the slot-number arguments.
Importing and using the Comware V7 extended Python API
To use the Comware V7 extended Python API, you must import the API to Python.
Use either of the following methods to import and use the Comware V7 extended Python API:
·     Use import comware to import the entire API and use comware.API to execute an API.
For example, to use the extended API Transfer to download file test.cfg from TFTP server 192.168.1.26:
<Sysname> python
Python 2.7.3 (default)
[GCC 4.4.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import comware
>>> comware.Transfer('tftp', '192.168.1.26', 'test.cfg', 'flash:/test.cfg', user='', password='')
<comware.Transfer object at 0xb7eab0e0>
·     Use from comware import API to import an API and use API to execute the API.
<Sysname> python
>>> from comware import Transfer
<comware.Transfer object at 0xb7e5e0e0>
Comware V7 extended Python API functions
CLI class
CLI
Use CLI to execute Comware V7 CLI commands and create CLI objects.
CLI(command=‘’, do_print=True)
command: Specifies the commands to be executed. To enter multiple commands, use a space and a semicolon (;) as the delimiter. To enter a command in a view other than user view, you must first enter the commands used to enter the view. For example, you must enter ’system-view ;local-user test class manage’ to execute the local-user test class manage command.
do_print: Specifies whether to output the execution result:
·     True—Outputs the execution result. This value is the default.
·     False—Does not output the execution result.
This API supports only Comware commands. It does not support Linux, Python, or Tcl commands.
Returns
CLI objects
# Add a local user with the username test.
<Sysname> python
>>> import comware
>>> comware.CLI('system-view ;local-user test class manage')
Sample output
New local user added.
<comware.CLI object at 0xb7f680a0>
get_output
Use get_output to get the output from executed commands.
CLI.get_output()
Returns
Output from executed commands
# Add a local user and get the output from the command.
<Sysname> python
>>> import comware
>>> c = comware.CLI('system-view ;local-user test class manage', False)
>>> c.get_output()
Sample output
['<Sysname>system-view', 'System View: return to User View with Ctrl+Z.', '[Sysname]local-user test class manage', 'New local user added.']
Transfer class
Transfer
Use Transfer to download a file from a server.
Transfer(protocol=‘’, host=‘’, source=‘’, dest=‘’, vrf=‘’,login_timeout=10, user=‘’, password=‘’)
protocol: Specifies the protocol used to download a file:
·     ftp—Uses FTP.
·     tftp—Uses TFTP.
·     http—Uses HTTP.
host: Specifies the IP address of the remote server.
source: Specifies the name of the file to be downloaded from the remote server.
dest: Specifies a name for the downloaded file.
vrf: Specifies the VPN instance to which the remote server belongs. This argument is a case-sensitive string of 1 to 31 characters. If the server belongs to the public network, do not specify this argument. Support for this argument depends on the device model.
login_timeout: Specifies the timeout for the operation, in seconds. The default is 10.
user: Specifies the username for logging in to the server.
password: Specifies the login password.
Returns
Transfer object
# Download file test.cfg from TFTP server 192.168.1.26.
<Sysname> python
>>> import comware
Sample output
<comware.Transfer object at 0xb7f700e0>
get_error
Use get_error to get the error information from the download operation.
Transfer.get_error()
Returns
Error information (if there is no error information, None is returned)
# Download file test.cfg from TFTP server 1.1.1.1 and get the error information from the operation.
<Sysname> python
>>> import comware
>>> c = comware.Transfer('tftp', '1.1.1.1', 'test.cfg', 'flash:/test.cfg', user='', password='')
>>> c.get_error()
Sample output
“Couldn’t connect to server”
API get_self_slot
get_self_slot
Use get_self_slot to get the member ID of the master device.
get_self_slot()
Returns
A list object in the format of [-1,slot-number]. The slot-number indicates the member ID of the master device.
# Get the member ID of the master device.
<Sysname> python
>>> import comware
>>> comware.get_self_slot()
Sample output
[-1,1]
API get_standby_slot
get_standby_slot
Use get_standby_slot to get the member IDs of the subordinate devices.
get_standby_slot()
Returns
A list object in one of the following formats:
·     [ ]—The IRF fabric does not have a subordinate device.
·     [[-1,slot-number]]—The IRF fabric has only one subordinate device.
·     [[-1,slot-number1],[-1,slot-number2],...]—The IRF fabric has multiple subordinate devices.
The slot-number arguments indicate the member IDs of the subordinate devices.
# Get the member IDs of the subordinate devices.
<Sysname> python
>>> import comware
>>> comware.get_standby_slot()
Sample output
API get_slot_range
get_slot_range
Use get_slot_range to get the supported IRF member ID range.
get_slot_range()
Returns
A dictionary object in the format of {'MaxSlot': max-slot-number, 'MinSlot': min-slot-number }. The max-slot-number argument indicates the maximum member ID. The min-slot-number argument indicates the minimum member ID.
# Get the supported IRF member ID range.
<Sysname> python
>>> import comware
>>> comware. get_slot_range()
Sample output
{'MaxSlot': 4, 'MinSlot': 1}
Managing licenses
Overview
License-based features require a license to run on your device. To use a license-based feature, you must purchase a license or obtain a free trial license.
License types
The following types of licenses are available depending on validity period:
·     Permanent—A permanent license is always valid and never expires.
·     Days restricted—A license valid for a limited period in days, for example, 30 days.
Trial licenses are typically days restricted.
The following types of licenses are available depending on locking method:
·     Device locked—A license can be installed only on the DID-specific device. The license takes effect on any MPU in the device even after an MPU replacement. The device supports this locking method.
·     MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device.
License pool
The following matrix shows hardware compatibility with license pool:
Hardware series
Model
License pool compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
No
WX3800H series
WX3810H
WX3840H
Yes
WX5800H series
WX5860H
Yes
Understanding the license pool
An IRF fabric provides the license pool feature when the fabric meets the following requirements:
·     Member ACs are of the same model.
·     The ACs form the N + 1 or N + M backup mode.
·     Licenses are installed on the master ACs.
The license pool enables backup ACs to use the licenses of a master AC that goes down for a maximum of 30 days. In the N + 1 or N + M backup mode, you need to purchase licenses only for the mater ACs, which saves customer investment. For example, in a 3 + 1 backup structure, you need to purchase and install licenses only for the three mater ACs. When a master AC goes down, the backup AC takes over and uses the licenses of the master AC to provide services.
Calculating the total number of licensed APs in a license pool
The license pool capacity determines the number of APs that can be connected to the ACs. The number of APs allowed in the license pool are affected by the following factors:
·     Number of member devices supported in an IRF fabric. For information about hardware compatibility for IRF, see Table 14.
·     Number of licensed APs supported by each IRF member device in the IRF fabric.
Table 14 Hardware compatibility for IRF
Hardware series
Model
IRF compatibility
Maximum number of IRF member devices
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
No
N/A
WX3800H series
WX3810H
WX3840H
Yes
2
WX5800H series
WX5860H
Yes
4
The total number of licensed APs in a license pool is the sum of licensed APs supported by each IRF member device. For example, ACs A, B, C, D form an IRF fabric. The number of licensed APs on the ACs A, B, C, and D are a, b, c, and d, respectively.
The total number of licensed APs in the license pool = sum(a,b,c,d) = a + b + c + d.
Compatibility information
Feature and hardware compatibility
The following matrix shows hardware compatibility with license management:
Hardware series
Model
License management compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
No:
·     WX1804H
·     WX1810H
·     WX1820H
Yes: WX1840H
WX3800H series
WX3820H
WX3840H
Yes
WX5800H series
WX5860H
Yes
Command and hardware compatibility
WX1800H series access controllers do not support the slot keyword or the slot-number argument.
General restrictions and guidelines
When you manage licenses, follow the general restrictions and guidelines:
·     Make sure you have purchased an upgrade license for add-on nodes, add-on features, or time extension.
·     Use the display license feature command to identify license-based features and their licensing information.
·     After you execute the display license command, it will take certain time for the device to output detailed license information depending on the device load.
·     Make sure no one else is performing license management tasks on the device you are working with.
·     When installing a license, the system also searches the storage media for a matching feature package. When it finds a matching package, it stops searching and installs the package.
·     When uninstalling a license, the system checks whether the feature package for the license is running. If it is running, the system uninstalls the package automatically.
·     If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
Licenses for different device types
When you register and install licenses, follow the restrictions and guidelines:
·     License registration requires a license key, hardware SN, and DID. This information is device specific. A registered license takes effect on the entire device.
·     For a license-based feature to run correctly on an IRF fabric:
?     Install one license for the feature on each member in the fabric. The license takes effect on each member device, and it is effective even after the member device joins another IRF fabric.
?     Make sure the licenses installed on the members are the same.
License file safety
When you manage licenses, follow these restrictions and guidelines for license file safety:
·     Save and back up the obtained activation file in case of loss.
·     If you use FTP to transfer the .id file and the activation file, use the Binary mode.
·     Do not open and edit the .id file or activation file to avoid file corruption.
·     Do not modify the name of the .id file or activation file to avoid licensing error.
·     Do not delete or move files in the flash:/license directory on a device. The license management feature uses this directory for license management. An incorrect file operation can cause problems. For example, if you delete an activation file that is usable or in use, the related feature will not function correctly. If a file is missing or corrupted, copy the activation file to the directory to recover the license. If the state of the recovered license is In use, but not all licensed features can function, reboot the device. To verify the license state, use the display license command.
Licensing procedure summary
Tasks at a glance
Remarks
Registering licenses:
·     Registering licenses for the first time—Registers a license for a device that has never been activated.
·     Registering upgrade licenses—Registers a license for add-on nodes, add-on features, or time extension.
H3C website provides the license registration function.
Installing an activation file
N/A
Transferring a license
N/A
Compressing the license storage
N/A
Figure 36 describes the license registration and activation procedure.
Figure 36 Licensing procedure summary
1.     Visit the H3C website at http://www.h3c.com/en/Support/Online_Help/License_Service/. Select First-Time Registration.
Figure 37 Registering a license for the first time
2.     Select WLAN_H3C WLAN AC V7 from the Product category dropdown list, and click Submit.
Figure 38 Selecting a product category for activation file licensing
If you do not know the product category, enter the license key in the text box, and click Submit. The product category is automatically displayed.
3.     Enter the license, device, and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 39 Entering the information for activation file licensing
Table 15 Field description
Item
Remarks
License key
Enter the license key provided on the paper license.
Required.
H3C device S/N
Enter the device serial number, a string of 20 characters.
You can use the display license device-id command on the device to display the device serial number.
Required.
Device information file
Upload the device DID file.
You can use the display license device-id command on the device to display the file path and use FTP or TFTP to download the DID file to the device.
Required.
Customer company/organization
Enter the name of the company or organization that uses the device.
Required.
Company/organization
Enter your company or organization name.
Required.
First name
Enter your first name.
Required.
Last name
Enter your last name.
Optional.
Phone number
Enter your phone number.
Required.
Email address
Enter your email address.
H3C will send a copy of the activation file or key to your email box in addition to providing a link to the activation file on the registration result page.
Required.
Zip code
Enter the zip code of your region.
Optional.
Address
Enter your address.
Optional.
Project name
Enter the name of the project that uses the device.
Optional.
Verify code
Enter the code literally as is displayed on the image to the right of the text box.
Required.
4.     Click the .ak link to save the activation file when the registration success message appears. Unzip the file and follow the procedures described in "Installing an activation file" to activate the license on your device.
Figure 40 Registration success for activation file licensing
1.     Visit the H3C website at http://www.h3c.com/en/Support/Online_Help/License_Service/. Select Register Upgraded Licenses.
Figure 41 Registering an upgrade license
2.     Select WLAN_H3C WLAN AC V7 from the Product category dropdown list.
Figure 42 Selecting a product category for activation file licensing
3.     Enter the device information and click Submit.
Figure 43 Entering the device information for activation file licensing
Table 16 Field description
Item
Remarks
H3C device S/N
You can use the display license device-id command to display the device serial number.
Required.
You can use the display license device-id command to display the file path and use FTP or TFTP to download the DID file to the device.
Required.
4.     On the page that appears, enter the license, and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 44 Entering the information for license upgrade
Table 17 Configuration items
Item
Remarks
License key
Required.
Required.
Required.
First name
Required.
Last name
Optional.
Phone number
Required.
Email address
Required.
Zip code
Optional.
Address
Enter your address.
Optional.
Project name
Optional.
Verify code
Required.
5.     Click the .ak link to save the activation file when the registration success message appears. Unzip the file and follow the procedures described in "Installing an activation file" to activate the license on your device.
Figure 45 Registration success activation file licensing
Step
1.     Upload the activation file to the storage media of the device through FTP or TFTP.
N/A
2.     Enter system view.
3.     Install the activation file.
license activation-file install file-name slot slot-number
You can transfer a license from one device to another if its activation file has not expired. If the activation file has expired, the license is not transferrable.
To transfer a license:
Step
Remarks
1.     Enter system view on the source device.
N/A
2.     Uninstall an activation file.
license activation-file uninstall file-name slot slot-number
When an activation file is uninstalled, the system creates an Uninstall file. This file is required when you register the license for the target device.
The uninstallation action does not delete license data from the license storage area. To free storage space, you must compress the license storage (see "Compressing the license storage").
3.     Obtain the Uninstall key of the source device.
display license
N/A
4.     Use the Uninstall key to uninstall the license from the source device on the H3C website.
N/A
N/A
5.     Access the target device and display the SN string and the DID's .id file path.
N/A
6.     Use FTP or TFTP to transfer the .id file to the PC.
N/A
N/A
7.     Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and use the target device's SN and DID information and the source device's Uninstall key to generate a new activation file.
N/A
See "Registering licenses."
8.     Download the new activation file to the target device.
N/A
N/A
9.     Install the new activation file on the target device.
N/A
See "Installing an activation file."
CAUTION:
The DID changes each time the license storage is compressed. Before performing a compression, make sure all activation files generated based on the old DID have been installed. They cannot be installed after the compression.
If the license storage area is not sufficient for installing new licenses, compress the license storage. This action deletes expired licenses and uninstalled licenses.
To compress the license storage:
Step
2.     Compress the license storage.
license compress slot slot-number
Displaying and maintaining licenses
Display the SN and DID of the device.
display license device-id slot slot-number
Display detailed license information.
display license [ activation-file ] slot slot-number
Display brief feature license information.
Using automatic configuration
Overview
With the automatic configuration feature, the device can automatically obtain a set of configuration settings when it starts up without a configuration file. This feature simplifies network configuration and maintenance.
As shown in Figure 46, automatic configuration requires the following servers:
·     DHCP server.
·     File server (TFTP or HTTP server).
·     (Optional.) DNS server.
Figure 46 Automatic configuration network diagram
Automatic configuration task list
Tasks at a glance
(Required.) Configuring the file server
(Required.) Preparing the files for automatic configuration
(Required.) Configuring the DHCP server
(Optional.) Configuring the DNS server
(Optional.) Configuring the gateway
(Required.) Preparing the interface used for automatic configuration
(Required.) Starting and completing automatic configuration
For devices to obtain configuration information from a TFTP server, start TFTP service on the file server.
For devices to obtain configuration information from an HTTP server, start HTTP service on the file server.
The device can use a script file or configuration file for automatic configuration.
·     For devices to use configuration files for automatic configuration, you must create and save the configuration files to the file server as described in "Configuration files." If you do not configure the DHCP server to assign configuration file names, you must also create a host name file on the TFTP server.
·     For devices to use script files for automatic configuration, you must create and save the script files to the file server as described in "Script files."
Host name file
The host name file contains host name-IP address mappings and must be named network.cfg.
All mapping entries in the host name file must use the ip host host-name ip-address format. Each mapping entry must reside on a separate line. For example:
ip host host1 101.101.101.101
ip host host2 101.101.101.102
ip host client1 101.101.101.103
ip host client2 101.101.101.104
Configuration files
To prepare configuration files:
·     For devices that require different configurations, perform the following tasks:
?     Determine the name for each device's configuration file.
The configuration file names must use the extension .cfg. For simple file name identification, use configuration file names that do not contain spaces.
?     Use the file names to save the configuration files for the devices to the file server.
·     For devices that share all or some configurations, save the common configurations to a .cfg file on the file server.
·     If a TFTP file server is used, you can save a default configuration file named device.cfg on the server. This file contains only common configurations that devices use to start up. This file is assigned to a device only when the device does not have other configuration files to use.
During the automatic configuration process, a device first tries to obtain a configuration file dedicated for it. If no dedicated configuration file is found, the device tries to obtain the common configuration file. If no common configuration file is found when a TFTP file server is used, the device obtains and uses the default configuration file.
Script files
Script files can be used for automatic software upgrade and automatic configuration. The device supports Python scripts (.py files) and Tcl scripts (.tcl files). For more information about Python and Tcl scripts, see "Using Python" and "Using Tcl."
To prepare script files:
·     For devices that share all or some configurations, create a script file that contains the common configurations.
·     For the other devices, create a separate script file for each of them.
The DHCP server assigns the following items to devices that need to be automatically configured:
·     IP addresses.
·     Paths of the configuration files or scripts.
Configuration guidelines
When you configure the DHCP server, follow these guidelines:
·     For devices for which you have prepared different configuration files, perform the following tasks for each of the devices on the DHCP server:
?     Create a DHCP address pool.
?     Configure a static address binding.
?     Specify a configuration file or script file.
Because an address pool can use only one configuration file, you can specify only one static address binding for an address pool.
·     For devices for which you have prepared the same configuration file, use either of the following methods:
?     Method 1:
-     Create a DHCP address pool for the devices.
-     Configure a static address binding for each of the devices in the address pool.
-     Specify the configuration file for the devices.
?     Method 2:
-     Specify the subnet for dynamic allocation.
-     Specify the TFTP server.
·     If all devices on a subnet share the same configuration file or script file, perform the following tasks on the DHCP server:
?     Configure dynamic address allocation.
?     Specify the configuration file or script file for the devices.
The configuration file can contain only the common settings for the devices. You can provide a method for the device administrators to change the configurations after their devices start up.
Configuring the DHCP server when an HTTP file server is used
Step
Remarks
N/A
2.     Enable DHCP.
dhcp enable
By default, DHCP is disabled.
3.     Create a DHCP address pool and enter its view.
dhcp server ip-pool pool-name
By default, no DHCP address pool is created.
4.     Configure the address pool.
·     (Method 1.) Specify the primary subnet for the address pool:
network
network-address [ mask-length | mask mask ]
·     (Method 2.) Configure a static binding:
static-bind ip-address
ip-address [ mask-length | mask mask ] { client-identifier client-identifier | hardware-address hardware-address [ ethernet | token-ring ] }
Use either or both methods.
By default, no primary subnet or static binding is configured.
You can add multiple static bindings.
One IP address can be bound to only one client. To change the binding for a DHCP client, you must remove the binding and reconfigure a binding.
5.     Specify the URL of the configuration file or script file.
bootfile-name url
By default, no configuration or script file URL is specified.
Configuring the DHCP server when a TFTP file server is used
Step
Remarks
N/A
2.     Enable DHCP.
dhcp enable
network
5.     Specify a TFTP server.
·     (Method 1.) Specify the IP address of the TFTP server:
tftp-server ip-address
ip-address
·     (Method 2.) Specify the name of the TFTP server:
tftp-server domain-name
domain-name
By default, no TFTP server is specified.
If you specify a TFTP server by its name, a DNS server is required on the network.
6.     Specify the configuration file name.
bootfile-name bootfile-name
By default, no configuration file name is specified.
A DNS server is required in the following situations:
·     The TFTP server does not have a host name file. However, devices need to perform the following operations:
?     Use their IP addresses to obtain their host names.
?     Obtain configuration files named in the host name.cfg format from the TFTP server.
·     The DHCP server assigns the TFTP server domain name through the DHCP reply message. Devices must use the domain name to obtain the IP address of the TFTP server.
If the devices to be automatically configured and the servers for automatic configuration reside in different network segments, you must perform the following tasks:
·     Deploy a gateway and make sure the devices can communicate with the servers.
·     Configure the DHCP relay agent feature on the gateway.
The device uses the following steps to select the interface for automatic configuration:
1.     Identifies the status of the management Ethernet interface at Layer 2. If the status is up, the device uses the management Ethernet interface.
2.     Identifies the status of Layer 2 Ethernet interfaces. If one or more Layer 2 Ethernet interfaces are in up state, the device uses the VLAN interface of the default VLAN.
3.     Sorts all Layer 3 Ethernet interfaces in up state first in lexicographical order of interface types and then in ascending order of interface numbers. Uses the interface with the smallest interface number among the interfaces of the first interface type.
4.     If no Layer 3 Ethernet interfaces are in up state, the device waits 30 seconds and goes to step 1 to try again.
For fast automatic device configuration, connect only the management Ethernet interface on each device to the network.
1.     Power on the devices to be automatically configured.
If a device does not find a next-start configuration file locally, it starts the automatic configuration process to obtain a configuration file.
?     If the device obtains a configuration file and executes the file successfully, the automatic configuration process ends.
?     If one attempt fails, the device tries again until the maximum number of attempts is reached. To stop the process, press Ctrl+C or Ctrl+D.
If the device fails to obtain a configuration file, the device starts up without loading any configuration.
2.     Use the save command to save the running configuration.
The device does not save the obtained configuration file locally. If you do not save the running configuration, the device must use the automatic configuration feature again after a reboot.
Automatic configuration examples
Automatic configuration using TFTP server
Network requirements
As shown in Figure 47, the AC does not have a configuration file.
Configure the servers so the AC can obtain a configuration file to complete the following configuration tasks:
·     Enable the administrator of the AC to Telnet to and manage the AC.
·     Require the administrator to enter the correct username and password at login.
Figure 47 Network diagram
Configuration procedure
1.     Configure the DHCP server:
# Enable DHCP.
[RouterA] dhcp enable
# Configure address pool 1 to assign IP addresses on the 192.168.1.0/24 subnet to clients. Specify the TFTP server and configuration file name for the clients.
[RouterA] dhcp server ip-pool 1
[RouterA-dhcp-pool-1] network 192.168.1.0 24
[RouterA-dhcp-pool-1] tftp-server ip-address 192.168.1.40
[RouterA-dhcp-pool-1] bootfile-name device.cfg
2.     Configure the TFTP server:
# On the TFTP server, create the device.cfg configuration file.
telnet server enable
local-user user
password simple abcabc
service-type telnet
user-interface vty 0 4
authentication-mode scheme
user-role network-admin
interface gigabitethernet 1/0/1
port link-mode route
ip address dhcp-alloc
return
# Start TFTP service software. (Details not shown.)
1.     Power on the AC.
2.     After the AC starts up, display assigned IP addresses on Router A.
<RouterA> display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
192.168.1.2      0030-3030-632e-3239-  Dec 12 17:41:15 2013  Auto(C)
                 3035-2e36-3736-622d-
                 4574-6830-2f30-2f32
3.     Telnet to 192.168.1.2 from Router A.
<RouterA> telnet 192.168.1.2
4.     Enter the user username and abcabc password as prompted. (Details not shown.)
You are logged in to the AC.
Automatic configuration using HTTP server and Tcl script
As shown in Figure 48, the AC does not have a configuration file.
Configure the servers so the AC can obtain a Tcl script to complete the following configuration tasks:
·     Enable the administrator to Telnet to the AC to manage the AC.
Figure 48 Network diagram
# Enable DHCP.
# Specify the URL of the script file for the AC.
[RouterA-dhcp-pool-1] bootfile-name http://192.168.1.40/device.tcl
2.     Configure the HTTP server:
# Create the device.tcl configuration file on the HTTP server.
return
local-user user
service-type telnet
return
# Start HTTP service software and enable HTTP service. (Details not shown.)
1.     Power on the AC.
                 Hardware address
                 4574-6830-2f30-2f32
Automatic configuration using HTTP server and Python script
As shown in Figure 49, the AC does not have a configuration file.
Configure the servers so the AC can obtain a Python script to complete the following configuration tasks:
Figure 49 Network diagram
# Enable DHCP.
# Configure address pool 1 to assign IP addresses on the subnet 192.168.1.0/24 to clients.
[RouterA-dhcp-pool-1] bootfile-name http://192.168.1.40/device.py
# Create the device.py configuration file on the HTTP server.
#!usr/bin/python
import comware
comware.CLI(‘system-view ;telnet server enable ;local-user user ;password simple abcabc ;service-type telnet ;quit ;user-interface vty 0 4 ;authentication-mode scheme ;user-role network-admin ;quit ;interface gigabitethernet 1/0/1 ;port link-mode route ;ip address dhcp-alloc ;return’)
1.     Power on the AC.
                 Hardware address
                 4574-6830-2f30-2f32
A
AAA
RBAC AAA authorization, 18
RBAC default user role, 23
RBAC local AAA authentication user configuration, 27
RBAC non-AAA authorization, 18
RBAC user role local AAA authentication, 23
RBAC user role non-AAA authentication, 24
RBAC user role remote AAA authentication, 23
abbreviating CLI command, 5
accessing
CLI online help, 2
login management SNMP device access, 62
accounting
login management command accounting, 72, 73
login management user device access control, 65
ACL
login management command authorization, 69, 70
login management login control (Telnet), 65
login management login control (Telnet, SSH), 65
login management SNMP access control, 67, 69
activation file
license management installation, 153
active
FTP active (PORT) operating mode, 75
alias (CLI command), 5
API
extended Python API, 139
extended Python API functions, 139
archiving
configuration archive, 102
configuration archive parameters, 102
configuration archiving (automatic), 103
file, 93, 95
running configuration (manual), 104
argument (CLI string/text type), 4
ASCII transfer mode, 75
assigning
login management CLI user line assignment, 42
RBAC local AAA authentication user role, 23
RBAC non-AAA authentication user role, 24
RBAC permission assignment, 16
RBAC remote AAA authentication user role, 23
RBAC user role, 22
RBAC user role assignment, 18
authenticating
FTP basic server authentication, 76
login management CLI console authentication, 44
login management CLI console password authentication, 44
login management CLI console scheme authentication, 45
login management CLI none authentication mode, 43
login management CLI password authentication mode, 43
login management CLI scheme authentication mode, 43
login management Telnet login authentication disable, 48
login management Telnet login password authentication, 48
login management Telnet login scheme authentication, 49
RBAC RADIUS authentication user configuration, 29
RBAC temporary user role authorization (HWTACACS authentication), 31
RBAC temporary user role authorization (RADIUS authentication), 35
RBAC user role authentication, 26
authorizing
FTP basic server authorization, 76
RBAC temporary user role authorization, 24
auto
automatic configuration archiving, 103
configuration. See automatic configuration
DHCP server, 157
DHCP server configuration restrictions (server-based), 157
DNS server, 159
file preparation, 156
file server configuration, 156
gateway configuration, 159
HTTP server+Python script, 163
HTTP server+Tcl script, 161
start, 159
B
backing up
main next-startup configuration file, 105
software upgrade backup image set, 108
banner
configuration, 119, 120
legal type, 119
login type, 119
MOTD type, 119
multiple-line input method, 120
shell type, 119
single-line input method, 120
binary transfer mode, 75
boot loader
software upgrade startup image file specification (IRF-capable devices), 113
software upgrade startup image file specification (IRF-incapable devices), 112
startup image specification, 112
Boot ROM
Boot ROM image preload, 111
software upgrade image downgrade, 114
software upgrade image preload to Boot ROM (IRF-incapable devices), 111
software upgrade image restore, 114
software upgrade image type, 108, 108
software upgrade methods, 110
software upgrade preparation, 111
software upgrade system startup, 109
buffering
CLI command history buffering rules, 9
CLI history buffered commands, 9
C
calculating
AP number, 145
file digest, 96
changing
file system current working directory, 93
FTP user account, 82
CLI
command abbreviation, 5
command alias configuration, 5
command alias use, 5
command entry, 3
command history buffered commands, 9
command history function use, 8
command hotkey configuration, 6
command hotkey use, 6
command line editing, 3
command redisplay, 8
command-line error message, 8
console common line settings, 45
console port login, 41
device reboot (CLI), 121
device reboot (scheduled), 121
display command output filtering, 11
display command output line numbering, 10
display command output management, 14
display command output save to file, 13
display command output viewing, 14
interface type value, 5
local console port login, 43
login authentication modes, 43
login configuration, 42
login display, 54
login maintain, 54
login management overview, 39
online help access, 2
output control, 10
output control keys, 10
running configuration save, 15
software upgrade, 108
string/text type argument value, 4
system view entry from user view, 2
undo command form, 3
upper-level view return, 2
use, 1
user lines, 42
user roles, 43
user view return, 2
view hierarchy, 1
client
FTP client configuration, 84, 85
IPv4 TFTP client configuration, 87
IPv6 TFTP client configuration, 87
command
CLI command abbreviation, 5
CLI command alias configuration, 5
CLI command alias use, 5
CLI command entry, 3
CLI command history buffered commands, 9
CLI command history function use, 8
CLI command hotkey configuration, 6
CLI command hotkey use, 6
CLI command line editing, 3
CLI command redisplay, 8
CLI interface type value, 5
CLI string/text type argument value, 4
CLI undo command form, 3
line interface. Use CLI
Tcl, 135
comparing
configuration difference, 100
completing
software upgrade, 112
software upgrade (IRF-capable devices), 113
software upgrade (IRF-incapable devices), 112
compressing
file, 95
license management storage, 154
Comware
software upgrade Boot image type, 108
software upgrade feature image, 108
software upgrade image loading, 108
software upgrade image redundancy, 108
software upgrade patch image, 108
software upgrade system image type, 108
configuration file
compatibility information, 99
configuration comparison, 100
configuration difference displaying, 100
configuration rollback, 102
content organization, 99
device configuration types, 98
displaying, 107
encryption enable, 99
file formats, 99
format, 99
main next-startup configuration file backup, 105
main next-startup configuration file restoration, 106
management, 98
next-startup file delete, 106
next-startup file redundancy, 98
rollback, 104
running configuration archiving (manual), 104
running configuration save, 100, 101
startup file selection, 99
configuring
automatic configuration, 155, 160, 160, 161
automatic configuration (HTTP server+Python script), 163
automatic configuration DHCP server, 157
automatic configuration DNS server, 159
CLI command alias, 5
CLI command hotkey, 6
device as IPv4 TFTP client, 87
device as IPv6 TFTP client, 87
device banner, 119, 120
device management, 117, 117
device name, 117
device system time, 117
device temperature alarm threshold, 132
FTP, 75
FTP basic server parameters, 75
FTP client, 84, 85
FTP server, 77, 78
FTP server authentication, 76
FTP server authorization, 76
login management CLI console common line settings, 45
login management CLI local console port login, 43
login management RESTful access (HTTP), 63
login management RESTful access (HTTPS), 63
login management SNMP access control, 69
login management SSH device as server login, 52
login management SSH login, 52
login management Telnet common VTY line settings, 50
login management Telnet device as server, 47
login management Web login, 55, 58, 63
login management Web login (HTTP), 55, 58
login management Web login (HTTPS), 56, 59
login management Web login control (source IP-based), 66
RBAC, 16, 19, 27
RBAC feature group, 21
RBAC for RADIUS authentication user, 29
RBAC local AAA authentication user, 27
RBAC resource access policies, 21
RBAC user role interface policy, 22
RBAC user role rules, 20
RBAC user role VLAN policy, 22
TFTP, 87
console
login management console port login, 41
content
configuration file organization, 99
controlling
CLI output, 10
CLI output control keys, 10
login management login (Telnet), 65
login management logins (Telnet, SSH), 65
login management SNMP access, 67
login management user device access, 65
login management Web login, 67
login management Web logins, 66
RBAC configuration, 16, 19
copying
file, 95
copyright statement display, 119
creating
file system directory, 93, 93
RBAC user role, 19
change, 93
display, 93
D
days-restricted license, 144
decompressing
file, 95
default
device factory-default configuration restore, 133
deleting
file, 96
next-startup configuration file, 106
recycle bin file, 96
detecting
device port status detection timer, 129
device
automatic configuration, 155, 155, 160, 160
automatic configuration (HTTP server+Tcl script), 161
automatic configuration file preparation, 156
automatic configuration start, 159
CLI display command output filtering, 11
CLI display command output line numbering, 10
CLI display command output management, 14
CLI display command output save to file, 13
CLI display command output viewing, 14
CLI output control, 10, 10
CLI running configuration save, 15
CLI system view entry from user view, 2
CLI upper-level view return, 2
CLI use, 1
CLI user view return, 2
factory default configuration, 98
file system management, 89
file system storage media format, 92
FTP basic server parameters configuration, 75
FTP client, 80
FTP client connection establishment, 80
FTP command help information display, 83
FTP configuration, 75
FTP connection termination, 83
FTP connection troubleshooting, 82
FTP server, 75
FTP server configuration, 77, 78
FTP server connection release (manual), 77
FTP server directory management, 81
FTP server files, 81
FTP user account change, 82
license management, 144
license management (device locked), 144
license management installation (activation file), 153
license management registration, 147
license management storage compression, 154
license management transfer, 153
license registration for first time, 147
login management SSH device as server login configuration, 52
login management SSH server device login, 53
login management Telnet server device login, 51
RBAC configuration, 16, 19, 27
RBAC feature group configuration, 21
RBAC temporary user role authorization, 24, 26
RBAC user role assignment, 18, 22
RBAC user role creation, 19
RBAC user role rule configuration, 20
running configuration, 98
software upgrade parent device tasks, 111
startup configuration, 98
TFTP configuration, 87
upgrade license registration, 150
device management
banner configuration, 119, 120
banner input methods, 120
banner types, 119
configuration, 117, 117
configuration display, 134
configuration maintain, 134
CPU usage monitoring, 130
device name configuration, 117
device reboot, 121
license pool management, 144
memory alarm thresholds, 130
password recovery capability disable, 129
system time configuration, 117
task scheduling, 122, 124
task scheduling restrictions, 122
transceiver module diagnosis, 132, 133
transceiver module verification, 132, 132
DHCP
diagnosing
device transceiver modules, 132, 133
digest
file system file digest calculation, 96
directory
file system current working directory change, 93
file system current working directory display, 93
file system directory creation, 93, 93
file system directory information display, 92
file system directory management, 92
file system directory removal, 94
disabling
CLI output screen pausing, 10
device password recovery capability, 129
login management Telnet login authentication, 48
displaying
configuration files, 107
device copyright statement, 119
device management configuration, 134
file system directory information, 92
file system file information, 94
file system text file content, 94
FTP client, 83
FTP command help information, 83
FTP server, 77
license, 154
login management CLI login, 54
login management Web login, 58
RBAC settings, 26
software upgrade image settings, 114
DNS
downgrading
software upgrade Boot ROM image, 114
DSCP
login management Telnet packet DSCP value, 49
E
editing CLI command line, 3
enabling
configuration encryption, 99
device copyright statement display, 119
login management Telnet server, 48
entering
CLI command, 3
CLI entered-but-not-submitted command redisplay, 8
CLI interface type, 5
CLI system view from user view, 2
error
CLI command line error message, 8
establishing
FTP client connection, 80
extracting
file, 93, 95
F
factory default device configuration, 98
fast saving running configuration, 100, 101
feature
file
archiving, 93, 95
automatic configuration file server configuration, 156
compression, 95
configuration file content, 99
configuration file format, 99
configuration file formats, 99
configuration file management, 98
copying, 95
decompression, 95
deletion, 96
device configuration startup file selection, 99
extracting, 93, 95
file system management, 94
information display, 94
license management license registration for first time, 147
moving, 95
next-startup configuration file redundancy, 98
recycle bin file deletion, 96
renaming, 95
restoration, 96
software upgrade file naming, 108
system. See file system
text content display, 94
file system
file archiving, 93, 95
file compression, 95
file copy, 95
file decompression, 95
file deletion, 96
file extracting, 93, 95
file information display, 94
file management, 94
file move, 95
file rename, 95
file restoration, 96
file/folder operation mode, 94, 96
management, 89
text file content display, 94
File Transfer Protocol. Use FTP
filtering
CLI display command output, 11
format
configuration file, 99, 99
formatting
file system storage media, 92
FTP
client display, 83
configuration, 75
connection maintenance, 82
device as client, 80
device as server, 75
local server authentication, 76
local server authorization, 76
remote server authentication, 76
remote server authorization, 76
server display, 77
server files, 81
troubleshooting connection, 82
G
gateway
automatic configuration, 159
group
H
history
CLI history function, 8
hotkey (CLI command), 6
HTTP
login management RESTful access, 63
login management Web login (HTTPS), 59
login management Web login configuration, 55, 58, 63
HTTPS
login management RESTful access, 63, 63
login management Web login, 56, 59
HWTACACS
RBAC temporary user role authorization, 31
I
identifying
login management CLI user line, 42
software upgrade Boot ROM image downgrade, 114
software upgrade Boot ROM image restore, 114
software upgrade Boot ROM image type, 108
software upgrade Comware Boot image type, 108
software upgrade Comware image loading, 108
software upgrade Comware image redundancy, 108
software upgrade Comware image type, 108
software upgrade Comware system image type, 108
Import
extended Pythond API, 139
installing
activation file, 153
interface, 39, See also line
RBAC interface access policy, 17
IP
IPv4
IPv6
IRF
Boot ROM image preload, 111, 111
FTP client configuration, 85
FTP server configuration, 78
software upgrade completion (IRF-capable devices), 113
K
key
L
legal banner type, 119
license
AP number calculation, 145
license management
device locked license, 144
feature use, 144
license display, 154
MPU locked license, 144
permanent license, 144
procedure, 147
registering license for first time, 147
registering upgrade license, 150
registration, 147
restrictions, 146
transfer, 153
license pool
line
login management CLI user line identification, 42
login management Telnet VTY common line settings, 50
local
logging in
login management CLI login authentication modes, 43
login management CLI login configuration, 42
login management CLI user lines, 42
login management CLI user roles, 43
logging off
login management online Web user, 67
login
device banner login type, 119
login management
CLI configuration, 42
CLI login display, 54
CLI login maintain, 54
CLI user lines, 42
CLI user roles, 43
console port access, 41
overview, 39
RESTful access configuration (HTTP), 63
RESTful access configuration (HTTPS), 63
SSH login, 52
Telnet server enable, 48
Web login configuration (HTTP), 55, 58
Web login configuration (HTTPS), 56, 59
Web login control, 66, 67
Web login display, 58
Web login maintain, 58
Web user logoff, 67
M
main
software upgrade image set, 108
maintaining
FTP connection, 82
RBAC settings, 26
managing
CLI display command output, 14
configuration files, 98
device. See device management
file system, 89
file system directories, 92
file system files, 94
FTP server directories, 81
manual
FTP server connection release, 77
memory
device CPU usage monitoring, 130
device memory alarm thresholds, 130
message
message-of-the-day (MOTD) banner type, 119
method
device banner multiple-line input, 120
device banner single-line input, 120
MIB
mode
file system file/folder alert operation mode, 94, 96
file system file/folder quiet operation mode, 94, 96
FTP ASCII transfer mode, 75
FTP binary transfer mode, 75
FTP passive (PASV) operating mode, 75
login management none CLI authentication, 43
login management password CLI authentication, 43
login management scheme CLI authentication, 43
module
device transceiver module diagnosis, 132, 133
device transceiver module verification, 132, 132
monitoring
device CPU usage, 130
moving
file, 95
MPU
license management (MPU locked), 144
multiple-line banner input method, 120
N
naming
file rename, 95
software upgrade files, 108
network
automatic configuration gateway, 159
device as FTP client, 80
device as FTP server, 75
device banner configuration, 119
device banner input methods, 120
device banner types, 119
device management task scheduling, 122, 124
device password recovery capability disable, 129
device reboot, 121
device system time configuration, 117
file system file management, 94
login management Telnet server enable, 48
login management Web login control, 66, 67
login management Web user logoff, 67
network management
CLI use, 1
extended Python API import, 139
extended Python API use, 139
Python, 137
software upgrade (IRF-capable devices), 115
software upgrade (IRF-incapable devices), 114
Tcl usage, 135
using Python, 137
next-startup configuration file, 98, 106
NMS
non-AAA authentication (RBAC), 24
non-AAA authorization (RBAC), 18
none
login management CLI authentication mode, 43
numbering
CLI display command output lines, 10
O
obtaining
RBAC temporary user role authorization, 26
online
CLI online help access, 2
outputting
CLI display command output view, 14
CLI display comment output to file, 13
P
parameter
passive
password
patch
software upgrade Comware patch image, 108
pausing between CLI output screens, 10
permanent license, 144, 144
permitting
policy
RBAC user role assignment, 22
RBAC VLAN access policy, 17
pool
port
device status detection timer, 129
preloading
Boot ROM image, 111
software upgrade image to Boot ROM (IRF-incapable devices), 111
preparing
software upgrade, 111
procedure
accessing CLI online help, 2
archiving file, 93, 95
archiving running configuration (manual), 104
assigning RBAC local AAA authentication user role, 23
assigning RBAC non-AAA authentication user role, 24
assigning RBAC remote AAA authentication user role, 23
assigning RBAC user role, 22
backing up main next-startup configuration file, 105
calculating AP number, 145
calculating file digest, 96
changing current working directory, 93
changing FTP user accounts, 82
completing software upgrade, 112
completing software upgrade (IRF-capable devices), 113
completing software upgrade (IRF-incapable devices), 112
compressing file, 95
compressing license storage, 154
configuring automatic configuration, 155, 160, 161
configuring automatic configuration (HTTP server+Python script), 163
configuring automatic configuration DHCP server, 157
configuring automatic configuration DNS server, 159
configuring automatic configuration gateway, 159
configuring CLI command alias, 5
configuring CLI command hotkey, 6
configuring configuration rollback, 102
configuring device as IPv4 TFTP client, 87
configuring device as IPv6 TFTP client, 87
configuring device banner, 119, 120
configuring device management, 117
configuring device name, 117
configuring device system time, 117
configuring device temperature alarm threshold, 132
configuring FTP basic server parameters, 75
configuring FTP client, 84, 85
configuring FTP server, 77, 78
configuring FTP server local authentication, 76
configuring FTP server local authorization, 76
configuring FTP server remote authentication, 76
configuring FTP server remote authorization, 76
configuring login management CLI console common line settings, 45
configuring login management CLI console password authentication, 44
configuring login management CLI console scheme authentication, 45
configuring login management CLI local console port login, 43
configuring login management command accounting, 72, 73
configuring login management command authorization, 69, 70
configuring login management RESTful access (HTTP), 63
configuring login management RESTful access (HTTPS), 63
configuring login management SNMP access control, 69
configuring login management SSH device as server login, 52
configuring login management SSH login, 52
configuring login management Telnet device as server, 47
configuring login management Telnet login password authentication, 48
configuring login management Telnet login scheme authentication, 49
configuring login management Telnet VTY common line settings, 50
configuring login management Web login (HTTP), 55, 58
configuring login management Web login (HTTPS), 56, 59
configuring RBAC, 19, 27
configuring RBAC feature group, 21
configuring RBAC for RADIUS authentication user, 29
configuring RBAC local AAA authentication user, 27
configuring RBAC resource access policies, 21
configuring RBAC temporary user role authorization, 24
configuring RBAC temporary user role authorization (HWTACACS authentication), 31
configuring RBAC temporary user role authorization (RADIUS authentication), 35
configuring RBAC user role authentication, 26
configuring RBAC user role interface policy, 22
configuring RBAC user role rules, 20
configuring RBAC user role VLAN policy, 22
controlling CLI output, 10, 10
controlling login management login (Telnet), 65
controlling login management logins (Telnet, SSH), 65
controlling login management SNMP access, 67
controlling login management Web login, 67
controlling login management Web login (source IP-based), 66
controlling login management Web logins, 66
copying file, 95
creating directory, 93, 93
creating RBAC user role, 19
decompressing file, 95
deleting file, 96
deleting file from recycle bin, 96
deleting next-startup configuration file, 106
diagnosing device transceiver module, 132, 133
disabling CLI console authentication, 44
disabling CLI output screen pausing, 10
disabling device password recovery capability, 129
disabling login management Telnet login authentication, 48
displaying configuration files, 107
displaying current working directory, 93
displaying device management configuration, 134
displaying directory information, 92
displaying file information, 94
displaying FTP client, 83
displaying FTP command help information, 83
displaying FTP server, 77
displaying license, 154
displaying login management CLI login, 54
displaying login management Web login, 58
displaying RBAC settings, 26
displaying software upgrade image settings, 114
displaying text file content, 94
downgrading software upgrade Boot ROM image, 114
enabling CLI redisplay of entered-but-not-submitted command, 8
enabling configuration archiving (automatic), 103
enabling configuration encryption, 99
enabling device copyright statement display, 119
enabling login management Telnet server, 48
enabling RBAC default user role, 23
entering CLI command, 3
entering CLI interface type value, 5
entering CLI string/text type argument value, 4
entering CLI system view from user view, 2
entering Python shell, 137
establishing FTP client connection, 80
executing Comware commands in Tcl configuration view, 135
executing Python script, 137
extracting file, 93, 95
filtering CLI display command output, 11
first time license registration, 147
formatting file system storage media, 92
installing activation file, 153
logging in to login management SSH server (device), 53
logging in to login management Telnet server (device), 51
logging off online Web user, 67
maintaining device management configuration, 134
maintaining FTP connection, 82
maintaining login management CLI login, 54
maintaining login management Web login, 58
maintaining RBAC settings, 26
managing CLI display command output, 14
managing file system directories, 92
managing file system files, 94
managing FTP server directories, 81
monitoring device CPU usage, 130
moving file, 95
numbering CLI display command output lines, 10
obtaining RBAC temporary user role authorization, 26
preloading Boot ROM image, 111
preloading software upgrade image to Boot ROM (IRF-incapable devices), 111
preparing automatic configuration files, 156
preparing for software upgrade, 111
rebooting device, 121
rebooting device (CLI), 121
rebooting device (scheduled), 121
registering license, 147
registering upgrade license, 150, 150
releasing FTP server connection manually, 77
removing directory, 94
renaming file, 95
restoring device factory-default configuration, 133
restoring file, 96
restoring main next-startup configuration file, 106
restoring software upgrade Boot ROM image, 114
returning CLI user view, 2
returning to CLI upper-level view, 2
rolling back configuration, 104
saving CLI display command output to file, 13
saving CLI running configuration, 15
scheduling device management task, 122, 124
setting configuration archive parameters, 102
setting device memory alarm thresholds, 130
setting device port status detection timer, 129
setting file/folder operation mode, 94, 96
setting login management Telnet packet DSCP value, 49
specifying next-startup configuration file, 105
specifying software upgrade startup image file (IRF-capable devices), 113
specifying software upgrade startup image file (IRF-incapable devices), 112
specifying startup image, 112
terminating FTP connection, 83
transferring license, 153
troubleshooting FTP connection, 82
troubleshooting RBAC local user access permissions, 38
troubleshooting RBAC login attempts by RADIUS users fail, 38
understanding CLI command-line error message, 8
upgrading software (IRF-capable devices), 115
upgrading software (IRF-incapable devices), 114
using CLI command alias, 5
using CLI command history buffered commands, 9
using CLI command history function, 8
using CLI command hotkey, 6
using CLI undo command form, 3
using Python, 137
using Tcl to configure the device, 135
verifying device transceiver module, 132, 132
viewing CLI display command output, 14
working with FTP server files, 81
Python
Comware V7, 137
extended API, 139
extended API functions, 139
script, 137
shell, 137
using, 137
R
RADIUS
RBAC temporary user role authorization, 35
RBAC
predefined user roles, 17
resource access policies, 17, 21
rule configuration restrictions, 20
settings display, 26
settings maintain, 26
temporary user role authorization configuration, 24
temporary user role authorization configuration restrictions, 24
troubleshoot, 38
troubleshoot local user access permissions, 38
troubleshoot login attempts by RADIUS users fail, 38
user role rules, 16
rebooting
device, 121
device (CLI), 121
recycle bin
file deletion, 96
redundancy
registering
first time registration, 147
license, 147
remote
RBAC user role AAA authentication, 23
removing
file system directory, 94
renaming
file, 95
repeating
resource
RESTful
login configuration (HTTP), 63
login configuration (HTTPS), 63
restoring
file, 96
restrictions
automatic configuration DHCP server configuration (server-based), 157
license management, 146
RBAC rule configuration, 20
RBAC temporary user role authorization configuration, 24
returning
CLI user view, 2
role
RBAC predefined user roles, 17
role-based access control. Use RBAC
rolling back
configuration, 102, 104
routing
TFTP configuration, 87, 87
rule
RBAC command rule, 16
RBAC feature execute rule, 16
RBAC feature group rule, 16
RBAC feature read rule, 16
RBAC feature write rule, 16
RBAC OID rule, 16
RBAC Web menu rule, 16
RBAC XML element rule, 16
archiving, 102
CLI save, 15
device, 98
rollback, 102
saving (fast mode), 100, 101
saving (safe mode), 100, 101
S
safe saving running configuration, 100, 101
saving
scheduling
scheme
script
Python, 137
scripting
security
server
setting
shell
device banner type, 119
Python, 137
single-line banner input method, 120
SNMP
login management device access, 62
SNMPv1
SNMPv2
SNMPv3
software
upgrade. See software upgrade
software upgrade
CLI method, 108
completion, 112
completion (IRF-incapable devices), 112
Comware feature image, 108
configuration (IRF-capable devices), 115
configuration (IRF-incapable devices), 114
file naming, 108
image settings display, 114
methods, 110
overview, 108
system startup, 109
specifying
SSH
login control, 65
starting
starting up
next-startup configuration file, 105, 106
software upgrade configuration (IRF-capable devices), 115
software upgrade configuration (IRF-incapable devices), 114
startup
device configuration), 98
storage
storage media
format, 92
string type argument value (CLI), 4
system
software upgrade Comware feature image, 108
software upgrade startup process, 109
system administration
CLI use, 1
CLI view hierarchy, 1
configuration file encryption, 99
configuration file next-startup file delete, 106
configuration rollback, 102, 104
device banner configuration, 119, 120
device reboot, 121
executing Comware commands, 135
next-startup configuration file specification, 105
Python, 137
Python script execute, 137
Python shell, 137
software upgrade completion, 112
software upgrade completion (IRF-incapable devices), 112
Tcl usage, 135
using Python, 137
Using Tcl, 135
T
task
Tcl
configuring the device, 135
use, 135
TCP
Telnet
device as server configuration, 47
login control, 65, 65
server enable, 48
temperature
terminating
FTP connection, 83
text type argument value (CLI), 4
TFTP, 87, See also FTP
configuration, 87
IPv4 client configuration, 87
IPv6 client configuration, 87
threshold
device temperature threshold alarm, 132
time
timer
device port status detection, 129
tool command language. Use Tcl
transceiver
device module diagnosis, 132, 133
device module verification, 132, 132
transferring
license, 153
Trivial File Transfer Protocol. Use TFTP
troubleshooting
FTP connection, 82
RBAC, 38
U
undo command form (CLI), 3
upgrading
software. See software upgrade
user
interface, 39, See also user line
interface login management Telnet VTY common line settings, 50
user access
RBAC user role rules, 16
using
CLI, 1
Extended Python API, 139, 139
Python, 137
Tcl, 135
V
verifying
device transceiver modules, 132, 132
viewing
VLAN
W
Web
login control configuration (source IP-based), 66
login display, 58
login maintain, 58
login management user logoff, 67
user access control, 66, 67
working with
