11-Layer 3—IP Routing Command Reference
07-Policy-based routing commands
Chapters Download  (100.59 KB)
apply access-vpn
Use apply access-vpn to specify the forwarding tables that can be used for the matching packets.
Use undo apply access-vpn to remove the specified forwarding tables.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
undo apply access-vpn { public | vpn-instance [ vpn-instance-name&<1-4> ] }
The device forwards matching packets by using the forwarding table for the network from which the packets are received.
Policy node view
context-admin
public: Specifies the forwarding table for the public network.
vpn-instance: Specifies the forwarding table for the specified MPLS L3VPN instances.
vpn-instance-name&<1-4>: Specifies a space-separated list of up to four VPN instance names. A VPN instance name is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
Use this command only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
If you specify the vpn-instance keyword without specifying any VPN instances when you execute the undo form of this command, all the VPN instances are removed from the policy node.
After all the forwarding tables on the policy node are removed, the default forwarding behavior restores.
# Specify the VPN 1 and VPN 2 forwarding tables on node 10. In this example, VPN 1 and VPN 2 already exist.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1 vpn2
# Specify the public network forwarding table on node 10.
[Sysname-pbr-policy1-10] apply access-vpn public
apply remark-vpn
apply continue
Use apply continue to compare packets with the next policy node upon failure on the current node.
Use undo apply continue to restore the default.
apply continue
undo apply continue
PBR does not compare packets with the next policy node upon failure on the current node.
Policy node view
context-admin
This command takes effect only when the match mode of the node is permit.
This command applies when the following clauses are not configured or become invalid:
·           apply access-vpn
·           apply next-hop
·           apply output-interface
·           apply default-next-hop
·           apply default-output-interface
For example, the command applies when the specified next hop is unreachable, ,the packets cannot be forwarded in the specified VPN instance, or the specified output interface is down.
# Compare with the next policy node upon failure on the current node.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply continue
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ip-address&<1-4> ]
No default next hop is set.
Policy node view
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
inbound-vpn: Specifies the VPN instance where the inbound interface belongs.
ip-address: Specifies the IP address of a default next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-4>: Indicates that you can specify up to four default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply loadshare
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply default-output-interface [ { interface-type interface-number }&<1-4> ]
No default output interface is set.
Policy node view
context-admin
&<1-4>: Indicates that you can specify up to four interfaces, each of which can be associated with a track entry.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and non-broadcast multi-access (NBMA) interfaces such as Ethernet and virtual-template interfaces. In NBMA networks, packets are sent in unicast.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
# Specify GigabitEthernet 1/2/5/1 as the default output interface for IP packets.
[Sysname-pbr-aa-11] apply default-output-interface gigabitethernet 1/2/5/1
apply loadshare
apply ip-df
Use apply ip-df to set the Don't Fragment (DF) bit in the IP header of matching packets.
Use undo apply ip-df to restore the default.
apply ip-df df-value
undo apply ip-df
The DF bit is not set.
Policy node view
context-admin
df-value: Sets the DF bit in the IP header of matching packets. The value can be 0 or 1.
Setting the DF bit to 0 allows packet fragmentation.
Setting the DF bit to 1 prohibits packet fragmentation.
# Set the DF bit in the IP header of matching packets to 0.
[Sysname-pbr-aa-11] apply ip-df 0
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops, output interfaces, default next hops, or default output interfaces.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
undo apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in primary/backup mode.
Policy node view
context-admin
default-next-hop: Enables load sharing among multiple default next hops.
default-output-interface: Enables load sharing among multiple default output interfaces.
next-hop: Enables load sharing among multiple next hops.
output-interface: Enables load sharing among multiple output interfaces.
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in either primary/backup or load sharing mode. For example:
·           Primary/backup mode—The first configured output interface is used. When the primary output interface fails, the first configured backup output interface takes over.
·           Load sharing mode—Multiple output interfaces load share traffic on a per-packet basis in turn, according to the configuration order.
Multiple next hops load share traffic according to their weights. By default, all next hops have the same weight and traffic is load balanced among them.
# Enable load sharing among multiple next hops.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
# Enable load sharing among multiple output interfaces.
[Sysname-pbr-aa-11] apply output-interface gigabitethernet 1/2/5/1 gigabitethernet 1/2/5/2
[Sysname-pbr-aa-11] apply loadshare output-interface
# Enable load sharing among multiple default next hops.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare default-next-hop
# Enable load sharing among multiple default output interfaces.
[Sysname-pbr-aa-11] apply default-output-interface gigabitethernet 1/2/5/1 gigabitethernet 1/2/5/2
[Sysname-pbr-aa-11] apply loadshare default-output-interface
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ] }&<1-4>
undo apply next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ip-address&<1-4> ]
No next hop is set.
Policy node view
context-admin
ip-address: Specifies the IP address of a next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
weight weight-value: Specifies a load sharing weight for the next hop, in the range of 1 to 100. The default is 10. If you specify weights 1, 1, and 2 for three next hops, they share 1/4, 1/4, and 1/2 of the whole traffic, respectively.
&<1-4>: Indicates that you can specify up to four next hops, each of which can be associated with a track entry.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply output-interface [ { interface-type interface-number }&<1-4> ]
No output interface is set.
Policy node view
context-admin
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify GigabitEthernet 1/2/5/1 as the output interface for IP packets.
apply loadshare
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
context-admin
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply remark-vpn
Use apply remark-vpn to enable VPN remark action.
Use undo apply remark-vpn to restore the default.
apply remark-vpn
VPN remark action is not configured.
Policy node view
context-admin
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
# Forward packets that match ACL 3000 based on the forwarding table of VPN instance vpn1 and perform VPN remark action on the successfully forwarded packets.
[Sysname] policy-based-route aaa permit node 10
[Sysname-pbr-aaa-10] if-match acl 3000
[Sysname-pbr-aaa-10] apply access-vpn vpn-instance vpn1
[Sysname-pbr-aaa-10] apply remark-vpn
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
context-admin
context-operator
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
context-admin
context-operator
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information on the global active MPU.
# Display PBR configuration and statistics on GigabitEthernet 1/2/5/1.
<Sysname> display ip policy-based-route interface gigabitethernet 1/2/5/1
Policy based routing information for interface GigabitEthernet1/2/5/1(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply output-interface GigabitEthernet1/2/5/2 track 1 (down)
    apply output-interface GigabitEthernet1/2/5/3 track 2 (inactive)
  Matched: 0
Total matched: 0
Policy based routing information for interface GigabitEthernet1/2/5/1:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit(no resource):
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
Policy based routing information for interface XXXX(failed)
PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·          For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·          For a physical interface, specify its slot number.
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·          not support—The device does not support the match criteria configured on the node.
·          no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
apply output-interface  track 1 (down)
Specifies an output interface and its associated track entry for permitted packets.
This field displays the interface status in brackets.
·          up—The interface is up.
·          down—The interface is down at network layer.
·          inactive—The card that hosts the interface is not in position.
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matched
Total number of successful matches on all nodes.
reset ip policy-based-route statistics
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ chassis chassis-number slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays local PBR configuration and statistics for the active MPU.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays local PBR configuration and statistics for the global active MPU.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matched: 0
Total matched
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
context-admin
context-operator
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy Name              Interface Name
aaa                      GigabitEthernet 1/2/5/1
Table 5 Command output
Interface Name
Interface where the policy is applied.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
context-admin
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
if-match app-group
Use if-match app-group to set application group match criteria.
Use undo if-match app-group to delete application group match criteria.
if-match app-group app-group-name&<1-6>
undo if-match app-group [ app-group-name&<1-6> ]
No application group match criteria are set.
Policy node view
context-admin
app-group-name&<1-6>: Specifies up to six application groups by their names. An application group name is a case-insensitive string of 1 to 63 characters that can include letters, digits, underscores (_), and hyphens (-). The application group name cannot be Invalid, other, or any application group name predefined by the system.
The application match criteria apply only to interface PBR.
If you specify an application group, the undo if-match app-group command deletes the application group match criterion.
If you do not specify an application group, the undo if-match app-group command deletes all application group match criteria.
# Specify the application group test as a match criterion.
[Sysname-pbr-aa-11] if-match app-group test
if-match object-group
Use if-match object-group to set service object group match criteria.
Use undo if-match object-group to delete service object group match criteria.
if-match object-group service object-group-name&<1-6>
undo if-match object-group service [ object-group-name&<1-6> ]
No service object group match criteria are set.
Policy node view
context-admin
object-group-name&<1-6>: Specifies up to six service object groups by their names. A service object group name is a case-insensitive string of 1 to 31 characters that can include letters, digits, underscores (_), and hyphens (-).
If you specify a service object group, the undo if-match object-group command deletes the service object group match criterion.
If you do not specify a service object group, the undo if-match object-group command deletes all service object group match criteria.
# Specify the service object group test as a match criterion.
[Sysname-pbr-aa-11] if-match object-group service test
if-match packet-length
Use if-match packet-length to set a packet length match criterion.
Use undo if-match packet-length to restore the default.
if-match packet-length min-len max-len
No packet length match criterion is set.
Policy node view
context-admin
min-len: Specifies the minimum IP packet length in the range of 1 to 65535 bytes.
max-len: Specifies the maximum IP packet length in the range of 1 to 65535 bytes. The maximum length must be no less than the minimum length.
Use this command to set a criterion to match the total length of data packets.
The packet length range includes boundary values. For example, if you set the min-len and max-len arguments to 100 and 200, respectively, packets with lengths of 100 bytes and 200 bytes are also matched.
# Match packets with a length from 100 to 200 bytes.
[Sysname-pbr-aa-11] if-match packet-length 100 200
ip local policy-based-route
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
context-admin
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
policy-based-route
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
context-admin
# Apply policy aaa to GigabitEthernet 1/2/5/1.
[Sysname] interface gigabitethernet 1/2/5/1
[Sysname-GigabitEthernet1/2/5/1] ip policy-based-route aaa
policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
context-admin
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
·           If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·           If a match mode is specified, the command deletes all nodes configured with the match mode.
·           If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
context-admin
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
