00-Preface
Chapters Download (81.38 KB)
This command reference describes the commands for configuring routing protocols, including basic IP routing, static routing, RIP, OSPF, IS-IS, BGP, policy-based routing, IPv6 static routing, IPv6 policy-based routing, RIPng, OSPFv3, IPv6 IS-IS, and routing policies.
· Audience.
· Conventions.
· Network planners.
· Network administrators.
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
Convention |
Boldface |
Convention |
NOTE: |
Convention |
Represents an access point. |
We appreciate your comments.
