12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-R757X-GL-6W10012-Network Management and Monitoring Configuration Guide
15-VCF fabric configuration
15-VCF fabric configuration 217.20 KB
Configuring VCF fabric
Overview
IT infrastructure which contains clouds, networks, and terminal devices is undergoing a deep transform. The IT infrastructure is migrating to the cloud with the aims of implementing the elastic expansion of computing resources and providing IT services on demand. In this context, H3C developed the Virtual Converged Framework (VCF) solution. This solution breaks the boundaries between the network, cloud management, and terminal platforms and transforms the IT infrastructure to a converged framework to accommodate all applications. It also implements automatic network provisioning and deployment.
VCF fabric topology
In a VCF fabric, a device has one of the following roles:
·     Spine node—Connects to leaf nodes.
·     Leaf node—As shown in Figure 1, a leaf node connects to a server in a typical data center network. A shown in Figure 2, a leaf node connects to an access node in a typical campus network.
·     Access node—As shown in Figure 2, an access node connects to an upstream leaf node and downstream terminal devices in a typical campus network. Cascading of access nodes is supported.
·     Border node—Located at the border of a VCF fabric to provide access to the external network.
Spine nodes and leaf nodes form a large Layer 2 network, which can be a VLAN, a VXLAN with centralized IP gateways, or a VXLAN with distributed IP gateways. For more information about centralized IP gateways and distributed IP gateways, see VXLAN Configuration Guide.
Figure 1 VCF fabric topology for a data center network
Figure 2 VCF fabric topology for a campus network
Neutron concepts and components
Neutron is a component in OpenStack architecture. It provides networking services for VMs, manages virtual network resources (including networks, subnets, DHCP, virtual routers), and creates an isolated virtual network for each tenant. Neutron provides a unified network resource model, based on which VCF fabric is implemented.
The following are basic concepts in Neutron:
·     Network—A virtual object that can be created. It provides an independent network for each tenant in a multitenant environment. A network is equivalent to a switch with virtual ports which can be dynamically created and deleted.
·     Subnet—An address pool that contains a group of IP addresses. Two different subnets communicate with each other through a router.
·     Port—A connection port. A router or a VM connects to a network through a port.
·     Router—A virtual router that can be created and deleted. It performs routing selection and data forwarding.
Neutron has the following components:
·     Neutron server—Includes the daemon process neutron-server and multiple plug-ins (neutron-*-plugin). The Neutron server provides an API and forwards the API calls to the configured plugin. The plug-in maintains configuration data and relationships between routers, networks, subnets, and ports in the Neutron database.
·     Plugin agent (neutron-*-agent)—Processes data packets on virtual networks. The choice of plug-in agents depends on Neutron plug-ins. A plug-in agent interacts with the Neutron server and the configured Neutron plug-in through a message queue.
·     DHCP agent (neutron-dhcp-agent)—Provides DHCP services for tenant networks.
·     L3 agent (neutron-l3-agent)—Provides Layer 3 forwarding services to enable inter-tenant communication and external network access.
Neutron deployment
Neutron needs to be deployed on servers and network devices.
The following table shows Neutron deployment on a server.
Node
Neutron components
Controller node
·     Neutron server
·     Neutron DB
·     Message server (such as RabbitMQ server)
·     H3C ML2 Driver (For more information about H3C ML2 Driver, see H3C Neutron ML2 Driver Installation Guide.)
Network node
·     neutron-openvswitch-agent
·     neutron-dhcp-agent
Compute node
·     LLDP
The following table shows Neutron deployments on a network device.
Network type
Network device
Neutron components
Centralized gateway deployment
Spine
·     neutron-l2-agent
·     neutron-l3-agent
Leaf
neutron-l2-agent
Distributed gateway deployment
Spine
N/A
Leaf
·     neutron-l2-agent
·     neutron-l3-agent
Figure 3 Example of Neutron deployment for centralized gateway deployment
Figure 4 Example of Neutron deployment for distributed gateway deployment
Restrictions and guidelines: VCF fabric configuration
All VCF fabric commands are supported only on the default MDC.
Automated VCF fabric provisioning and deployment
VCF provides the following features to ease deployment:
·     Automatic topology discovery.
·     Automated underlay network provisioning.
·     Automated overlay network deployment.
Topology discovery
In a VCF fabric, each device uses LLDP to collect local topology information from directly-connected peer devices. The local topology information includes connection interfaces, roles, MAC addresses, and management interface addresses of the peer devices.
If multiple spine nodes exist in a VCF fabric, a master spine node is specified to collect the topology for the entire network.
An underlay network is a physical Layer 3 network. An overlay network is a virtual network built on top of the underlay network. The main stream overlay technology is VXLAN. For more information about VXLAN, see VXLAN Configuration Guide.
Automated underlay network provisioning sets up a Layer 3 underlay network for users. It is implemented by automatically executing configurations (such as IRF configuration and Layer 3 reachability configurations) in user-defined template files.
Provisioning prerequisites
Before you start automated underlay network provisioning, complete the following tasks:
1.     Finish the underlay network planning (such as IP address assignment, reliability design, and routing deployment) based on user requirements.
¡     In a data center network, the device obtains an IP address through a management Ethernet interface after starting up without loading configuration.
¡     In a campus network, the device obtains an IP address through VLAN-interface 1 after starting up without loading configuration.
2.     Install and configure the Director server.
This step is required if you want to use the Director server to automatically create template files.
3.     Configure the DHCP server, the TFTP server, and the NTP server.
4.     Upload the template files to the TFTP server.
Template files for different roles in the VCF fabric are the basis of automatic provisioning. A template file name ends in .template. The Director server automatically creates template files for different device roles in the network topology. The following are available template types:
¡     Template for a leaf node in a VLAN.
¡     Template for a leaf node in a VXLAN with a centralized gateway.
¡     Template for a leaf node in a VXLAN with distributed gateways.
¡     Template for a spine node in a VLAN.
¡     Template for a spine node in a VXLAN with a centralized gateway.
¡     Template for a spine node in a VXLAN with distributed gateways.
Process of automated underlay network provisioning
The device finishes automated underlay network provisioning as follows:
1.     Starts up without loading configuration.
2.     Obtains an IP address, the IP address of the TFTP server, and a template file name from the DHCP server.
3.     Downloads tag file device_tag.csv from the TFTP server and compares its SN code with the SN code in the tag file.
¡     If the two SN codes are the same, the device uses the device role and system description in the tag file.
¡     If the two SN codes are different, the device does not use the device role and system description.
4.     Determines the name of the template file to download based on the following information:
¡     The device role in the tag file or the default device role.
¡     The template file name obtained from the DHCP server.
For example, template file dist_leaf.template is for a leaf node in a VXLAN network with distributed IP gateways.
5.     Downloads the template file from the TFTP server.
6.     Parses the template file and performs the following operations:
¡     Deploys static configurations that are independent from the VCF fabric topology.
¡     Deploys dynamic configurations according to the VCF fabric topology.
-     In a data center network, the device usually uses a management Ethernet interface to connect to the fabric management network. Only links between leaf nodes and servers are automatically aggregated.
-     In a campus network, the device uses VLAN-interface 1 to connect to the fabric management network. Links between two access nodes cascaded through GigabitEthernet interfaces and links between leaf nodes and access nodes are automatically aggregated. For links between spine nodes and leaf nodes, the trunk permit vlan command is automatically executed.
·     On a data center network, if the template file contains software version information, the device first compares the software version with the current software version. If the two versions are inconsistent, the device downloads the new software version to perform software upgrade. After restarting, the device executes the configurations in the template file.
·     After all configurations in the template file are executed, the device does not save the configurations automatically if the template file does not contain IRF configuration. In this condition, you can use the save command to save the configurations to a configuration file.
·     For two directly connected devices with the same role to form an IRF fabric automatically, connect their IRF physical interfaces before automated underlay network provisioning.
Template file
A template file contains the following:
·     System-predefined variables—The variable names cannot be edited, and the variable values are set by the VCF topology discovery feature.
·     User-defined variables—The variable names and values are defined by the user. These variables include the username and password used to establish a connection with the Neutron server, network type, and so on. The following are examples of user-defined variables:
#USERDEF
_underlayIPRange = 10.100.0.0/16
_master_spine_mac = 1122-3344-5566
_backup_spine_mac = aabb-ccdd-eeff
_username = aaa
_password = aaa
_rbacUserRole = network-admin
_neutron_username = openstack
_neutron_password = 12345678
_neutron_ip = 172.16.1.136
_loghost_ip = 172.16.1.136
_network_type = centralized-vxlan
·     Static configurations—Static configurations are independent from the VCF fabric topology and can be directly executed. The following are examples of static configurations:
#STATICCFG
 clock timezone beijing add 08:00:00
 lldp global enable
 stp global enable
·     Dynamic configurations—Dynamic configurations are dependent on the VCF fabric topology. The device first obtains the topology information and then executes dynamic configurations. The following are examples of dynamic configurations:
interface $$_underlayIntfDown
 port link-mode route
 ip address unnumbered interface LoopBack0
 ospf 1 area 0.0.0.0
 ospf network-type p2p
 lldp management-address arp-learning
 lldp tlv-enable basic-tlv management-address-tlv interface LoopBack0
Automated overlay network deployment covers VXLAN deployment and EVPN deployment.
Automated overlay network deployment is mainly implemented through the following features of Neutron:
·     Layer 2 agent (L2 agent)—Responds to OpenStack events such as network creation, subnet creation, and port creation. It deploys Layer 2 networking to provide Layer 2 connectivity within a virtual network and Layer 2 isolation between different virtual networks.
·     Layer 3 agent (L3 agent)—Responds to OpenStack events such as virtual router creation, interface creation, and gateway configuration. It deploys the IP gateways to provide Layer 3 forwarding services for VMs.
For the device to correctly communicate with the Neutron server through the RabbitMQ server, you need to configure the RabbitMQ server parameters. The parameters include the IP address of the RabbitMQ server, the username and password to log in to the RabbitMQ server, and the listening port.
Typically, the device completes both automated underlay network provisioning and automated overlay network deployment by downloading and executing the template file. You do not need to manually configure the device by using commands. If the device needs to complete only automated overlay network deployment, you can use related commands in "Enabling VCF fabric topology discovery" and "Configuring automated overlay network deployment." No template file is required.
VCF fabric configuration task list
Tasks at a glance
(Required.) Enabling VCF fabric topology discovery
(Optional.) Configuring automated underlay network provisioning
(Optional.) Configuring automated overlay network deployment
VCF fabric topology discovery can be automatically enabled by executing configurations in the template file or be manually enabled at the CLI. The device uses LLDP to collect topology data of directly-connected devices. Make sure you have enabled LLDP on the device before you manually enable VCF fabric topology discovery.
Configuration procedure
Step
Remarks
N/A
2.     Enable LLDP globally.
lldp global enable
By default, LLDP is disabled globally.
3.     Enable VCF fabric topology discovery.
vcf-fabric topology enable
By default, VCF fabric topology discovery is disabled.
When you configure automated underlay network provisioning, follow these restrictions and guidelines:
·     Automated underlay network configuration can be automatically completed after the device starts up. If you need to change the automated underlay network provision on a running device, you can download the new template file through TFTP. Then, execute the vcf-fabric underlay autoconfigure command to manually specify the template file on the device.
·     As a best practice, do not modify the network type or the device role while the device is running. If it is necessary to do so, make sure you understand the impacts on the network and services.
·     If you change the role of the device, the new role takes effect after the device restarts up.
·     User-defined MDCs do not have a role by default. You can use the vcf-fabric role { access | leaf | spine } command to specify the role for the MDCs. Automated underlay network provisioning is not supported by user-defined MDCs. The Director server can identify the role of user-defined MDCs in the VCF fabric and deploy configuration to the MDCs through NETCONF.
Step
Remarks
N/A
2.     (Optional.) Specify the role of the device in the VCF fabric.
By default, the role of the device in the VCF fabric is spine.
3.     Specify the template file for automated underlay network provisioning.
vcf-fabric underlay autoconfigure template
By default, no template file is specified for automated underlay network provisioning.
4.     (Optional.) Pause automated underlay network provisioning.
vcf-fabric underlay pause
By default, automated underlay network provisioning is not paused.
5.     (Optional.) Configure the device as a master spine node.
vcf-fabric spine-role master
By default, the device is not a master spine node.
6.     (Optional.) Enable Neutron and enter Neutron view.
neutron
By default, Neutron is disabled.
7.     (Optional.) Specify the network type.
network-type { centralized-vxlan | distributed-vxlan | vlan }
By default, the network type is VLAN.
When you configure automated overlay network deployment, follow these restrictions and guidelines:
·     If the network type is VLAN or VXLAN with a centralized IP gateway, perform this task on both the spine node and the leaf nodes.
·     If the network type is VXLAN with distributed IP gateways, perform this task on all leaf nodes.
·     Make sure the RabbitMQ server settings on the device are the same as those on the controller node. If the durable attribute of RabbitMQ queues is set on the Neutron server, you must enable creation of RabbitMQ durable queues on the device so that RabbitMQ queues can be correctly created.
·     When you set the RabbitMQ server parameters or remove the settings, make sure the routes between the device and the RabbitMQ servers are reachable. Otherwise, the CLI does not respond until the TCP connections between the device and the RabbitMQ servers are terminated.
·     Multiple virtual hosts might exist on a RabbitMQ server. Each virtual host can independently provide RabbitMQ services for the device. For the device to correctly communicate with the Neutron server, specify the same virtual host on the device and the Neutron server.
·     As a best practice, do not perform any of the following tasks while the device is communicating with a RabbitMQ server:
¡     Change the source IPv4 address for the device to communicate with RabbitMQ servers.
¡     Bring up or shut down a port connected to a RabbitMQ server.
If you do so, it will take the CLI a long time to respond to the l2agent enable, undo l2agent enable, l3agent enable, or undo l3agent enable command.
Step
Remarks
N/A
2.     Enable Neutron and enter Neutron view.
neutron
3.     Specify the IPv4 address, port number, and MPLS L3VPN instance of a RabbitMQ server.
rabbit host ip ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
By default, no IPv4 address or MPLS L3VPN instance of a RabbitMQ server is specified, and the port number of a RabbitMQ server is 5672.
4.     Specify the source IPv4 address for the device to communicate with RabbitMQ servers.
rabbit source-ip ipv4-address [ vpn-instance vpn-instance-name ]
By default, no source IPv4 address is specified for the device to communicate with RabbitMQ servers. The device automatically selects a source IPv4 address through the routing protocol to communicate with RabbitMQ servers.
5.     (Optional.) Enable creation of RabbitMQ durable queues.
rabbit durable-queue enable
By default, RabbitMQ non-durable queues are created.
6.     Configure the username used by the device to establish a connection with the RabbitMQ server.
rabbit user username
By default, the device uses username guest to establish a connection with the RabbitMQ server.
7.     Configure the password used by the device to establish a connection with the RabbitMQ server.
rabbit password { cipher | plain } string
By default, the device uses plaintext password guest to establish a connection with the RabbitMQ server.
8.     Specify a virtual host to provide RabbitMQ services.
rabbit virtual-host hostname
By default, the virtual host / provides RabbitMQ services for the device.
9.     Specify the username and password used by the device to deploy configurations through RESTful.
restful user username password { cipher | plain } password
By default, no username or password is configured for the device to deploy configurations through RESTful.
10.     (Optional.) Enable the Layer 2 agent.
l2agent enable
By default, the Layer 2 agent is disabled.
11.     (Optional.) Enable the Layer 3 agent.
l3agent enable
By default, the Layer 3 agent is disabled.
12.     (Optional.) Configure export targets for a tenant VPN instance.
vpn-target target export-extcommunity
By default, no export targets are configured for a tenant VPN instance.
13.     (Optional.) Configure import route targets for a tenant VPN instance.
vpn-target target import-extcommunity
By default, no import route targets are configured for a tenant VPN instance.
14.     (Optional.) Specify the IPv4 address of the border gateway.
gateway ip ipv4-address
By default, the IPv4 address of the border gateway is not specified.
15.     (Optional.) Configure the device as a border node.
border enable
By default, the device is not a border node.
16.     (Optional.) Enable local proxy ARP.
proxy-arp enable
By default, local proxy ARP is disabled.
17.     (Optional.) Configure the MAC address of VSI interfaces.
vsi-mac mac-address
By default, no MAC address is configured for VSI interfaces.
Displaying and maintaining VCF fabric
Display the role of the device in the VCF fabric.
display vcf-fabric role
Display VCF fabric topology information.
display vcf-fabric topology
Display information about automated underlay network provisioning.
display vcf-fabric underlay autoconfigure
Display the supported version and the current version of the template file for automated VCF fabric provisioning.
display vcf-fabric underlay template-version
Automated VCF fabric configuration example
Network requirements
As shown in Figure 5, Devices A, B, and C all connect to the TFTP server and the DHCP server through management Ethernet interfaces. VM 1 resides on Compute node 1. VM 2 resides on the Compute node 2. The controller node runs OpenStack Kilo version and Ubuntu14.04 LTS operating system.
Configure a VCF fabric to meet the following requirements:
·     The VCF fabric is a VXLAN network deployed on spine node Device A and leaf nodes Device B and Device C to provide connectivity between VM 1 and VM 2. Device A acts as a centralized VXLAN IP gateway.
·     Devices A, B, and C complete automated underlay network provisioning by using template files after they start up.
·     Devices A, B, and C complete automated overlay network deployment after the controller is configured.
·     The DHCP server dynamically assigns IP addresses on subnet 10.11.113.0/24.
Figure 5 Network diagram
Configuring the DHCP server
1.     Configure a DHCP address pool to dynamically assign IP addresses on subnet 10.11.113.0/24 to the devices.
2.     Specify 10.11.113.19/24 as the IP address of the TFTP server.
3.     Specify a template file (a file with the file extension .template) as the boot file.
Creating template files
Create template files and upload them to the TFTP server.
Typically, a template file includes the following contents:
·     System-predefined variables—Internally used by the system. User-defined variables cannot be the same as system-predefined variables.
·     User-defined variables—Defined by the user. User-defined variables include the following:
¡     Basic settings: Local username and password, user role, and so on.
¡     Neutron server settings: IP address of the Neutron server, the username and password for establishing a connection with the Neutron server, and so on.
·     Software images for upgrade and the URL to download the software images.
·     Configuration commands—Include commands independent from the topology (such as LLDP, NTP, and SNMP) and commands dependent on the topology (such as interfaces and Neutron settings).
Configuring the TFTP server
Place the template files on the TFTP server. In this example, both spine node and leaf node exist on the VXLAN network, so two template files (vxlan_spine.template and vxlan_leaf.template) are required.
Powering up Device A, Device B, and Device C
After starting up without loading configuration, Device A, Device B, and Device C each automatically download a template file to finish automated underlay network deployment. In this example, Device A downloads the template file vxlan_spine.template, and Device B and Device C download the template file vxlan_leaf.template.
Configuring the controller node
1.     Install OpenStack Neutron related components:
a.     Install Neutron, Image, Dashboard, Networking, and RabbitMQ.
b.     Install H3C ML2 Driver. For more information, see H3C Neutron ML2 Driver Installation Guide.
c.     Configure LLDP.
2.     Configure the network as a VXLAN network:
Edit the /etc/neutron/plugin/ml2/ml2_conf.ini file as follows:
a.     Add the h3c_vxlan type driver to the type driver list.
type_drivers = h3c_vxlan
b.     Add h3c to the mechanism driver list.
mechanism_driver = openvswitch, h3c
c.     Specify h3c_vxlan as the default tenant network type.
tenant_network_types=h3c_vxlan
d.     Add the [ml2_type_h3c_vxlan] section, and specify a VXLAN ID range in the format of vxlan-id1:vxlan-id2. The value range for VXLAN IDs is 0 to 16777215.
vni_ranges = 10000:60000
3.     Configure the database:
Before you configure the database, make sure you have configured the Neutron server.
[openstack@localhost ~]$ sudo h3c_config db_sync
4.     Restart the Neutron server:
[root@localhost ~]# service neutron-server restart
Configuring the compute nodes
Perform the following tasks on both Compute node 1 and Compute node 2.
1.     Install the OpenStack Nova related components, openvswitch, and neutron-ovs-agent.
2.     Create an OVS bridge named br-vlan and add interface Ethernet 0 (connected to the VCF fabric) to the bridge.
# ovs-vsctl add-br br-vlan
# ovs-vsctl add-port br-vlan eth0
3.     Modify the bridge mapping on the OVS agent:
# Edit the /etc/neutron/plugins/ml2/openvswitch_agent.ini file as follows:
[ovs]
bridge_mappings = vlanphy:br-vlan
4.     Restart the neutron-openvswitch-agent.
# service neutron-openvswitch-agent restart
Verifying the OpenStack environment
Perform the following tasks on the OpenStack dashboard.
1.     Create a network named Network.
2.     Create subnets:
# Create a subnet named subnet-1 and assign network address range 10.10.1.0/24 to the subnet. (Details not shown.)
# Create a subnet named subnet-2, and assign network address range 10.1.1.0/24 to the subnet. (Details not shown.)
In this example, VM 1 and VM 2 obtain IP addresses from the DHCP server. You must enable DHCP for the subnets.
3.     Create a router named router. Bind a port on the router with subnet subnet-1 and then bind another port with subnet subnet-2. (Details not shown.)
4.     Create VMs:
# Create VM 1 and VM 2 on Compute node 1 and Compute node 2, respectively. (Details not shown.)
In this example, VM 1 and VM 2 obtain IP addresses 10.10.1.3/24 and 10.1.1.3/24 from the DHCP server, respectively.
1.     Verify the collected topology of the underlay network.
# Display VCF fabric topology information on Device A.
[DeviceA] display vcf-fabric topology
                                  Topology Information
* indicates the master spine role among all spines
SpineIP          Interface                        Link LeafIP              Status
*10.11.113.51   GigabitEthernet1/0/1           Up   10.11.113.52        Deploying
                  GigabitEthernet1/0/2           Down --                       --
                  GigabitEthernet1/0/3           Down --                       --
                  GigabitEthernet1/0/4           Down --                       --
                  GigabitEthernet1/0/5           Up   10.11.113.53        Deploying
                  GigabitEthernet1/0/6           Down --                       --
                  GigabitEthernet1/0/7           Down --                       --
                  GigabitEthernet1/0/8           Down --                       --
2.     Verify the automated configuration for the underlay network.
# Display information about automated underlay network provisioning on Device A.
[DeviceA] display vcf-fabric underlay autoconfigure
success command:
          system
          system
          lldp global enable
          system
          stp global enable
          system
          ospf 1
          graceful-restart ietf
          area 0.0.0.0
          system
          interface LoopBack0
          system
          ip vpn-instance global
          route-distinguisher 1:1
          vpn-target 1:1 import-extcommunity
          system
          l2vpn enable
          system
          vxlan tunnel arp-learning disable
          system
          ntp-service enable
          ntp-service unicast-peer 10.11.113.136
          system
          netconf soap http enable
          netconf soap https enable
          restful http enable
          restful https enable
          system
          ip http enable
          ip https enable
          system
          telnet server enable
          system
          info-center loghost 10.11.113.136
          system
          local-user aaa
          password ******
          service-type telnet http https
          service-type ssh
          system
          line vty 0 63
          authentication-mode scheme
          system
          bgp 100
          graceful-restart
          address-family l2vpn evpn
          undo policy vpn-target
          system
          system
          neutron
          rabbit user openstack
          rabbit password ******
          rabbit host ip 10.11.113.136
          restful user aaa password ******
          network-type centralized-vxlan
          vpn-target 1:1 export-extcommunity
          l2agent enable
          l3agent enable
          system
          snmp-agent
          snmp-agent community read public
          snmp-agent community write private
          snmp-agent sys-info version all
        #interface up-down:
Loopback0 IP Allocation:
        DEV_MAC           LOOPBACK_IP      MANAGE_IP         STATE
        a43c-adae-0400    10.100.16.17     10.11.113.53      up
        a43c-9aa7-0100    10.100.16.15     10.11.113.51      up
        a43c-a469-0300    10.100.16.16     10.11.113.52      up
IRF Allocation:
        Self Bridge Mac: a43c-9aa7-0100
        IRF Status: No
        Member List: [1]
bgp configure peer:
        10.100.16.17
        10.100.16.16
3.     Verify the automated deployment for the overlay network.
# Display the running configuration for the current VSI on Device A.
[DeviceA] display current-configuration configuration vsi
vsi vxlan10071
 gateway vsi-interface 8190
 vxlan 10071
 evpn encapsulation vxlan
  route-distinguisher auto
  vpn-target auto export-extcommunity
  vpn-target auto import-extcommunity
return
[DeviceA] display current-configuration interface Vsi-interface
interface Vsi-interface8190
 ip binding vpn-instance neutron-1024
 ip address 11.1.1.1 255.255.255.0 sub
 ip address 10.10.1.1 255.255.255.0 sub
return
[DeviceA] display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  neutron-1024                    1024:1024              2016/03/12 00:25:59
4.     Verify the connectivity between VM 1 and VM 2.
# Ping VM 2 on Compute node 2 from VM 1 on Compute node 1.
$ ping 10.1.1.3
Ping 10.1.1.3 (10.1.1.3): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.3: icmp_seq=0 ttl=254 time=10.000 ms
56 bytes from 10.1.1.3: icmp_seq=1 ttl=254 time=4.000 ms
56 bytes from 10.1.1.3: icmp_seq=2 ttl=254 time=4.000 ms
56 bytes from 10.1.1.3: icmp_seq=3 ttl=254 time=3.000 ms
56 bytes from 10.1.1.3: icmp_seq=4 ttl=254 time=3.000 ms
--- Ping statistics for 10.1.1.3 ---
