- 08-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-VPLS configuration
- 11-MPLS OAM configuration
- 12-MCE configuration
| 10-VPLS configuration | 481.03 KB |
Restrictions and guidelines for VPLS
Configuring an Ethernet service instance
Configuring a BGP auto-discovery LDP PW
Binding an Ethernet service instance to a VSI
Configuring static PW redundancy
Configuring MAC address learning
Enabling SNMP notifications for L2VPN PW
Displaying and maintaining VPLS
Static PW configuration example
BGP auto-discovery LDP PW configuration example
H-VPLS using MPLS access configuration example
Ethernet service instance and VSI binding configuration example
H-VPLS UPE dual homing configuration example
Configuring VPLS
Overview
Virtual Private LAN Service (VPLS) delivers a point-to-multipoint L2VPN service over an MPLS or IP backbone. The provider backbone emulates a switch to connect all geographically dispersed sites of each customer network. The backbone is transparent to the customer sites. The sites can communicate with each other as if they were on the same LAN.
Basic VPLS architecture
Figure 1 Basic VPLS architecture
As shown in Figure 1, the VPLS architecture mainly includes the following components:
· CE—A customer edge device is directly connected to the service provider network.
· PE—A provider edge device connects one or more CEs to the service provider network. A PE implements VPN access by mapping and forwarding packets between private networks and public network tunnels. A PE can be a UPE or NPE in a hierarchical VPLS.
· AC—An attachment circuit, physical or virtual, connects a CE and a PE, such as an Ethernet link or a VLAN.
· PW—A pseudowire is a bidirectional virtual connection between two PEs. An MPLS PW consists of two unidirectional MPLS LSPs in opposite directions.
· Tunnel—A tunnel can be an LSP tunnel, an MPLS TE tunnel, or a GRE tunnel. It carries one or more PWs over an IP/MPLS backbone. If a PW is carried on an LSP or MPLS TE tunnel, each packet on the PW contains two labels. The inner label is the PW label, which identifies the PW and ensures that the packet is forwarded to the correct VSI. The outer label is the public LSP or MPLS TE tunnel label, which ensures that the packet is correctly forwarded to the remote PE.
· VPLS instance—A customer network might contain multiple geographically dispersed sites (such as site 1 and site 3 in Figure 1.) The service provider uses VPLS to connect all the sites to create a single Layer 2 VPN, which is referred to as a VPLS instance. Sites in different VPLS instances cannot communicate with each other at Layer 2.
· VSI—A virtual switch instance provides Layer 2 switching services for a VPLS instance on a PE. A VSI acts as a virtual switch that has all the functions of a conventional Ethernet switch, including source MAC address learning, MAC address aging, and flooding. VPLS uses VSIs to forward Layer 2 data packets in VPLS instances.
VPLS implementation
Creating a PW
PEs use PWs to forward packets among VPN sites. PWs include static PWs, LDP PWs, BGP PWs, and BGP auto-discovery LDP PWs.
· Static PW
To create a static PW, specify the address of the remote PE, the incoming label, and the outgoing label.
· LDP PW
To create an LDP PW, specify the address of the remote PE, and use LDP to advertise the PW-label binding to the remote PE. After the two PEs receive the PW-label binding from each other, they establish an LDP PW. The FEC type in the LDP message is PWid FEC Element that includes the PW ID field (FEC 128). The PW ID identifies the PW bound to the PW label.
· BGP PW
To create a BGP PW, configure BGP to advertise label block information to the remote PE. After the two PEs receive label block information from each other, they use the label block information to calculate the incoming and outgoing labels and create the BGP PW. A PE also uses the received label block information to automatically find the remote PE.
· BGP auto-discovery LDP PW
To create a BGP auto-discovery LDP PW, configure BGP to automatically find the remote PE, and use LDP to advertise the PW-label binding to the remote PE. After the two PEs receive the PW-label binding from each other, they establish a BGP auto-discovery LDP PW.
The information advertised by BGP includes the ID (for example, LSR ID) and VPLS ID of the advertising PE. The receiving PE compares the received VPLS ID with its own VPLS ID. If the two VPLS IDs are identical, the two PEs use LDP to establish a PW. If not, the PEs do not establish a PW. The FEC type in the LDP message is Generalized PWid FEC Element (FEC 129), which contains the VPLS ID, Source Attachment Individual Identifier (SAII), and Target Attachment Individual Identifier (TAII). The SAII is the LSR ID of the advertising PE. The TAII identifies the remote PE and is advertised by the remote PE. VPLS ID+SAII+TAII uniquely identifies a PW in a VPLS instance.
MAC address learning, aging, and withdrawal
VPLS provides reachability through source MAC learning. A PE maintains a MAC address table for each VSI.
As shown in Figure 2, a PE learns source MAC addresses in the following ways:
· Learning the source MAC addresses of directly connected sites.
If the source MAC address of a packet from a CE does not exist in the MAC address table, the PE learns the source MAC address of the AC connected to the CE.
· Learning the source MAC addresses of remote sites connected through PWs.
A VSI regards a PW as a logical Ethernet interface. If the source MAC address of a packet from a PW does not exist in the MAC address table, the PE learns the source MAC address on the PW of the VSI.
Figure 2 Source MAC address learning on a PE
The MAC address table uses an aging timer for each dynamic MAC address entry. If no packet is received from a MAC address before the aging timer expires, VPLS deletes the MAC address.
When an AC or a PW goes down, the PE deletes MAC addresses on the AC or PW. Then it sends an LDP address withdrawal message to notify all other PEs in the VPLS instance to delete those MAC addresses.
Unicast traffic forwarding and flooding
After a PE receives a unicast packet from an AC, the PE searches the MAC address table of the VSI bound to the AC for packet forwarding.
· If a match is found, the PE forwards the packet according to the matching entry. If the outgoing interface in the entry is a PW, the PE inserts the PW label to the packet, and adds the public tunnel header to the packet. It then forwards the packet to the remote PE over the PW. If the outgoing interface in the entry is a local interface, the PE directly forwards the packet to the local interface.
· If no match is found, the PE floods the packet to all other ACs and PWs in the VSI.
After a PE receives a unicast packet from a PW, the PE searches the MAC address table of the VSI bound to the PW for packet forwarding.
· If a match is found, the PE forwards the packet through the outgoing interface in the matching entry.
· If no match is found, the PE floods the packet to all ACs in the VSI.
Multicast and broadcast traffic forwarding and flooding
After a PE receives a multicast or broadcast packet from an AC, the PE floods the packet to all other ACs and the PWs in the VSI bound to the AC.
After a PE receives a multicast or broadcast packet from a PW, the PE floods the packet to all ACs in the VSI bound to the PW.
PW full mesh and split horizon
A Layer 2 network requires a loop prevention protocol such as STP to avoid loops. However, a loop prevention protocol on PEs brings management and maintenance difficulties. Therefore, VPLS uses the following methods to prevent loops:
· Full mesh—Every two PEs in a VPLS instance must establish a PW. The PWs form a full mesh among PEs in the VPLS instance.
· Split horizon—A PE does not forward packets received from a PW to any other PWs in the same VSI but only forwards those packets to ACs.
PW redundancy
PW redundancy provides redundant links between PEs so that the customer networks can communicate when the path over one PW fails. As shown in Figure 3, PE 1 establishes two PWs (one primary and one backup). The CEs communicate through the primary PW. When the primary PW fails, PE 1 brings up the backup PW and forwards packets from CE 1 to CE 2 through the backup PW. When CE 2 receives the packets, it updates its MAC address table, so that packets from CE 2 to CE 1 also travel through the backup PW. Only static PWs and LDP PWs support PW redundancy.
VPLS determines whether the primary PW fails according to the LDP session status or the BFD result. The backup PW is used when one of the following conditions exists:
· The public tunnel of the primary PW is deleted, or BFD detects that the public tunnel has failed.
· The primary PW is deleted because the LDP session between PEs goes down, or BFD detects that the primary PW has failed.
· A manual PW switchover is performed.
A PW can be in either of the following states:
· Active—The PW is in active state and can forward packets.
· Standby—The PW is in standby state and cannot forward packets.
For LDP PWs, PEs use LDP to negotiate the states of the primary and backup PWs. In master/slave mode of PW redundancy, one PE of a PW operates as the master node and the other PE operates as the slave node. The master PE determines the PW state and then uses LDP to advertise the PW state to the slave PE. The slave PE uses the same PW state as the master PE based on the information received from the master PE. In this way, the master and slave PEs for the set of redundant PWs can use the same active PW to forward user packets.
H-VPLS
VPLS requires a full mesh of PWs among all PEs in a VPLS instance. In a large-scale network, however, a full mesh of PWs causes very high PW signaling overhead and brings difficulties for network management and expansion. Hierarchical VPLS (H-VPLS) reduces the number of PWs by dividing a VPLS network into a backbone domain and edge domains.
Only static PWs and LDP PWs support H-VPLS.
In H-VPLS:
· An edge domain provides access for a user network to the backbone domain.
· The Network Provider Edge (NPE) devices are fully meshed in the backbone domain. A PW between NPEs is referred to as an N-PW.
· A User facing-Provider Edge (UPE) device only establishes a PW with the neighboring NPE. A PW between a UPE and an NPE is referred to as a U-PW.
H-VPLS access modes
H-VPLS supports the following access modes: MPLS access and Ethernet access.
Figure 4 H-VPLS using MPLS access
As shown in Figure 4, the edge domain is an MPLS network. The UPE creates a U-PW with NPE 1. The UPE does not create PWs to any remote PEs. After receiving a packet from a CE, the UPE adds the label assigned to the U-PW into the packet and forwards the packet to NPE 1 through a public tunnel. NPE 1 maps the packet to the VSI that corresponds to the PW label, and searches the MAC address table of the VSI to forward the packet.
NOTE: A U-PW created on the NPE must have split horizon disabled because the NPE needs to forward packets between U-PW and N-PW. |
Figure 5 H-VPLS using Ethernet access
As shown in Figure 5, the edge domain is an Ethernet network. The UPE and NPE 1 establish a point-to-point Ethernet QinQ connection in between. After the UPE receives a packet from a CE, it adds an outer VLAN tag into the packet and forwards the packet to NPE 1. NPE 1 regards the outer VLAN tag as the service provider VLAN tag. It maps the packet to the VSI that corresponds to the VLAN tag and then searches the MAC address table of the VSI to forward the packet.
UPE dual homing and PW redundancy
To provide U-PW redundancy for a UPE, you can connect the UPE to two NPEs. Even if a U-PW fails, all customer sites connected to the UPE maintain the connectivity.
In the H-VPLS using MPLS access as shown in Figure 6, the UPE is connected to two NPEs through primary and backup U-PWs. The UPE uses the primary U-PW to forward traffic. When the primary U-PW fails, the UPE uses the backup U-PW to forward traffic.
Figure 6 UPE dual homing and redundancy in H-VPLS using MPLS access
Follow these guidelines when you configure VPLS:
· On a PE, the customer-facing interfaces do not support STP. Make sure the interfaces do not form loops. For more information about STP, see Layer 2—LAN Switching Configuration Guide.
· Interfaces that have Ethernet service instances bound to VSIs do not support the multicast feature.
· VPLS is mutually exclusive with EVI and VXLAN. For more information about EVI and VXLAN, see EVI Configuration Guide and VXLAN Configuration Guide.
VPLS configuration task list
To configure a VPLS network, perform the following tasks:
· Configure an IGP to ensure IP connectivity within the backbone.
· Configure basic MPLS, LDP, GRE, or MPLS TE to establish public tunnels on the backbone network.
· Configure VPLS on PEs. For example, configure a VSI, establish a PW, and associate an AC and a VSI.
This chapter describes only VPLS configurations on a PE. For information about other configurations, see relevant configuration guides.
To configure VPLS on a PE, perform the following tasks:
Tasks at a glance |
Remarks |
(Required.) Enabling L2VPN |
N/A |
(Required.) Configuring an Ethernet service instance |
N/A |
(Required.) Configuring a VSI |
N/A |
· (Optional.) Configuring a PW class · (Required.) Choose either of the following tasks to configure a PW: |
Choose a PW configuration method depending on the VPLS implementation. |
(Required.) Binding an Ethernet service instance to a VSI |
In an H-VPLS using MPLS access, do not perform this task on the access NPEs of the UPEs. |
(Optional.) Configuring PW redundancy: |
N/A |
(Required.) Configuring MAC address learning |
N/A |
(Optional.) Enabling SNMP notifications for L2VPN PW |
N/A |
Enabling L2VPN
Before you enable L2VPN, perform the following tasks:
· Configure an LSR ID for the PE with the mpls lsr-id command.
· Enable MPLS with the mpls enable command on the backbone interface of the PE.
To enable L2VPN:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable L2VPN. |
l2vpn enable |
By default, L2VPN is disabled. |
An AC can only be an Ethernet service instance on a Layer 2 Ethernet or Layer 2 aggregate interface. It forwards packets that are received on the interface and meet the match criteria of the Ethernet service instance to the bound VSI. If the match criterion is VLAN ID, the VLAN is unique on a per-interface basis rather than on a per-device basis.
NOTE: When VLANs are globally unique, packets with the same VLAN ID are forwarded by the same VSI regardless of the receiving interfaces. If VLANs are unique on a per interface basis, packets with the same VLAN ID from different interfaces can be forwarded by different VSIs. |
When the PE is connected to a CE through a Layer 2 Ethernet or Layer 2 aggregate interface, configure an Ethernet service instance on the interface to match packets from the AC.
To configure an Ethernet service instance:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
· Enter Layer 2 Ethernet interface view: · Enter Layer 2 aggregate interface view: |
N/A |
3. Create an Ethernet service instance and enter Ethernet service instance view. |
service-instance instance-id |
By default, no Ethernet service instances exist. |
4. Configure a packet match criterion for the Ethernet service instance. |
· encapsulation s-vid vlan-id [ only-tagged ] · encapsulation { default | tagged | untagged } |
By default, no packet match criterion is configured for the Ethernet service instance. |
Configuring a VSI
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a VSI and enter VSI view. |
vsi vsi-name |
By default, no VSIs exist. |
3. (Optional.) Configure a description for the VSI. |
description text |
By default, no description is configured for a VSI. |
4. (Optional.) Set the default PW ID for the VSI. |
default-pw-id default-pw-id |
By default, no default PW ID is configured for the VSI. |
5. Set an MTU for the VSI. |
mtu size |
By default, the MTU of a VSI is 1500 bytes. |
6. (Optional.) Enable the VSI. |
undo shutdown |
By default, a VSI is enabled. |
Configuring a PW
In a PW class, you can configure PW attributes such as the PW data encapsulation type, and whether to enable control word. To simplify PW configuration, you can configure PWs with the same attributes by referencing the same PW class.
To configure a PW class:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a PW class and enter PW class view. |
pw-class class-name |
By default, no PW classes exist. |
3. (Optional.) Enable control word. |
control-word enable |
By default, control word is disabled. |
4. (Optional.) Specify the PW data encapsulation type. |
pw-type { ethernet | vlan } [ force-for-vpls ] |
By default, the PW data encapsulation type is VLAN. |
Configuring a static PW
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VSI view. |
vsi vsi-name |
N/A |
3. Specify static signaling for PWs, and enter VSI static view. |
pwsignaling static |
By default, no PW signaling protocol is specified. |
4. Configure a static PW, and enter VSI static PW view. |
peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no static PWs exist. If both the default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command. You must specify the no-split-horizon keyword to disable split horizon when you configure an NPE to establish a U-PW with a UPE. |
Configuring an LDP PW
Before you configure an LDP PW, enable global and interface MPLS LDP on the PE. For information about MPLS LDP configuration, see "Configuring LDP."
To configure an LDP PW:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Specify LDP signaling for PWs, and enter VSI LDP signaling view. |
pwsignaling ldp |
4. Configure an LDP PW, and enter VSI LDP PW view. |
peer ip-address [ pw-id pw-id ] [ no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no LDP PWs exist. If both the default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command. You must specify the no-split-horizon keyword to disable split horizon when you configure an NPE to establish a U-PW with a UPE. |
Configuring a BGP PW
To configure a BGP PW, perform the following configurations on PEs:
· Configure BGP to advertise VPLS label block information.
· Create a BGP PW.
Configuring BGP to advertise VPLS label block information
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable BGP instance and enter BGP instance view. |
bgp as-number [ instance instance-name ] [ multi-session-thread ] |
By default, BGP is disabled. |
3. Configure the remote PE as a BGP peer. |
peer { group-name | ip-address [ mask-length ] } as-number as-number |
By default, no BGP peers exist. |
4. Create the BGP L2VPN address family and enter BGP L2VPN address family view. |
address-family l2vpn |
By default, no BGP L2VPN address family exists. |
5. Enable BGP to exchange L2VPN information with the specified peer or peer group. |
peer { group-name | ip-address [ mask-length ] } enable |
By default, BGP cannot exchange L2VPN information with any peer or peer group. |
6. Enable BGP to exchange label block information with the specified peer or peer group. |
peer { group-name | ip-address [ mask-length ] } signaling |
By default, BGP can exchange label block information with a BGP L2VPN peer or peer group. |
7. (Optional.) Permit the local AS number to appear in routes from the specified peer or peer group and specify the appearance times. |
peer { group-name | ip-address [ mask-length ] } allow-as-loop [ number ] |
By default, the local AS number is not allowed in routes from a peer or peer group. |
8. (Optional.) Enable route target-based filtering of incoming BGP L2VPN information. |
policy vpn-target |
By default, route target-based filtering of incoming BGP L2VPN information is enabled. |
9. (Optional.) Configure the router as an RR and specify a peer or peer group as its client. |
peer { group-name | ip-address [ mask-length ] } reflect-client |
By default, no RR or client is configured. |
10. (Optional.) Enable L2VPN information reflection between clients. |
reflect between-clients |
By default, L2VPN information reflection is enabled between clients. |
11. (Optional.) Configure the cluster ID of the RR. |
reflector cluster-id { cluster-id | ip-address } |
By default, an RR uses its own router ID as the cluster ID. |
12. (Optional.) Configure the filtering of reflected L2VPN information. |
rr-filter ext-comm-list-number |
By default, the RR does not filter reflected L2VPN information. |
13. (Optional.) Return to user view. |
return |
N/A |
14. (Optional.) Soft-reset L2VPN BGP sessions. |
refresh bgp [ instance instance-name ] { ip-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn |
N/A |
15. (Optional.) Reset L2VPN BGP sessions. |
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } l2vpn |
N/A |
For more information about the peer as-number, peer enable, peer allow-as-loop, peer reflect-client, reflect between-clients, reflector cluster-id, refresh bgp l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
Creating a BGP PW
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Configure the VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view. |
auto-discovery bgp |
By default, a VSI does not automatically discover neighbors through BGP. |
4. Configure an RD for the auto-discovery VSI. |
route-distinguisher route-distinguisher |
By default, no RD is configured for the auto-discovery VSI. |
5. Configure route targets for the auto-discovery VSI. |
vpn-target vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] |
By default, no route targets are configured for the auto-discovery VSI. |
6. (Optional.) Specify a PW class for the auto-discovery VSI. |
By default, no PW class is specified. |
7. (Optional.) Specify a tunnel policy for the auto-discovery VSI. |
tunnel-policy tunnel-policy-name |
By default, no tunnel policy is specified. |
8. Use BGP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI BGP signaling view. |
signaling-protocol bgp |
By default, no signaling protocol is specified. |
9. Create a local site. |
site site-id [ range range-value ] [ default-offset default-offset ] |
By default, no local sites exist. |
Before you perform this configuration, enable MPLS LDP on interfaces and globally. For more information, see "Configuring LDP."
To configure a BGP auto-discovery LDP PW, perform the following configurations on PEs:
· Configure BGP to advertise VPLS PE information.
· Use LDP to create a PW.
Configuring BGP to advertise VPLS PE information
Step |
Command |
Remarks |
system-view |
N/A |
5. Enable BGP to exchange VPLS PE information with the specified peer or peer group. |
By default, BGP cannot exchange VPLS PE information with a peer or peer group. |
6. Enable BGP to exchange VPLS PE information with the specified peer or peer group. |
peer { group-name | ip-address [ mask-length ] } auto-discovery [ non-standard ] |
By default, BGP can exchange VPLS PE information with a BGP L2VPN peer or peer group by using RFC 6074 MP_REACH_NLRI. |
policy vpn-target |
return |
N/A |
N/A |
N/A |
Creating a BGP auto-discovery LDP PW
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
8. Use LDP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI LDP signaling view. |
signaling-protocol ldp |
9. Configure a VPLS ID for the VSI. |
vpls-id vpls-id |
By default, no VPLS ID is configured. |
On a Layer 2 Ethernet interface, Layer 2 aggregate interface, or a member port of a Layer 2 aggregate interface, you can create an Ethernet service instance and bind it to a VSI. The Ethernet service instance matches packets received on that interface. The matching packets are then forwarded based on the MAC address table of the VSI. An Ethernet service instance can match all packets, tagged packets, or untagged packets.
IMPORTANT: The Ethernet service instance on a member port of a Layer 2 aggregate interface cannot come up until you remove the port from the aggregation group. |
When you bind an Ethernet service instance to a VSI, you can associate Track with the Ethernet service instance. Then, the Ethernet service instance is up only when one or more of the associated track entries are positive.
To bind an Ethernet service instance to a VSI:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
4. Bind the Ethernet service instance to a VSI. |
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ] |
By default, an Ethernet service instance is not bound to any VSI. |
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
By default, no PW signaling protocol is specified for the VSI. |
4. (Optional.) Specify the switchover mode and set the wait time for the switchover. |
revertive { wtr wtr-time | never } |
By default, the switchover mode is revertive and the switchover wait time is 0 seconds. |
5. Configure a static PW and enter VSI static PW view. |
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value ] [ no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no static PWs exist. |
6. Configure a backup static PW and enter VSI static backup PW view. |
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no backup static PW exists. If both the default PW ID in the default-pw-id command and a PW ID in the backup-peer command are configured, the PW ID in the backup-peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the backup-peer command. |
7. Return to user view. |
return |
N/A |
8. Manually switch traffic of the PW to its backup PW. |
l2vpn switchover peer ip-address pw-id pw-id |
N/A |
Configuring LDP PW redundancy
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
pwsignaling ldp |
4. (Optional.) Use the master/slave PW redundancy mode and configure the local PE as the master node. |
pw-redundancy master |
By default, the PW redundancy mode is master/slave and the local PE operates as the slave node. Do not configure this command on the local PE if the remote PE does not support the master/slave PW redundancy mode. |
5. (Optional.) Specify the switchover mode and set the wait time for the switchover. |
6. Configure an LDP PW and enter VSI LDP PW view. |
peer ip-address [ pw-id pw-id ] [ ignore-standby-state | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no LDP PWs exist. For the local PE to ignore the PW active/standby states received from the remote PE, specify the ignore-standby-state keyword. |
7. Configure a backup LDP PW and enter VSI LDP backup PW view. |
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no backup LDP PW exists. If both the default PW ID in the default-pw-id command and a PW ID in the backup-peer command are configured, the PW ID in the backup-peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the backup-peer command. |
8. Return to user view. |
return |
N/A |
9. Manually switch traffic of the PW to its backup PW. |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Enable MAC address learning for the VSI. |
mac-learning enable |
By default, MAC address learning is enabled for a VSI. |
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW switchovers, or PW status changes occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To enable SNMP notifications for L2VPN PW:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable SNMP notifications for L2VPN PW. |
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] * |
By default, SNMP notifications for L2VPN PW are disabled. |
Task |
Command |
Display LDP PW label information. |
display l2vpn ldp [ peer ip-address [ pw-id pw-id | vpls-id vpls-id ] | vsi vsi-name ] [ verbose ] |
(In standalone mode.) Display L2VPN forwarding information. |
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ slot slot-number ] [ verbose ] |
(In IRF mode.) Display L2VPN forwarding information. |
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ chassis chassis-number slot slot-number ] [ verbose ] |
Display MAC address table information for one or all VSIs. |
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ] |
Display L2VPN PW information. |
display l2vpn pw [ vsi vsi-name ] [ protocol { bgp | ldp | static } ] [ verbose ] |
Display PW class information. |
display l2vpn pw-class [ class-name ] [ verbose ] |
Display Ethernet service instance information. |
display l2vpn service-instance [ interface interface-type interface-number [ service-instance instance-id ] ] [ verbose ] |
Display VSI information. |
display l2vpn vsi [ name vsi-name ] [ verbose ] |
Display information about automatically discovered VPLS PEs. |
display l2vpn auto-discovery [ peer ip-address ] [ vsi vsi-name ] |
Display VPLS label block information. |
display l2vpn bgp [ instance instance-name ] [ peer ip-address | local ] [ vsi vsi-name ] [ verbose ] |
Display BGP L2VPN peer group information. |
display bgp [ instance instance-name ] group l2vpn [ group-name group-name ] |
Display VPLS PE information discovered by BGP. |
display bgp [ instance instance-name ] l2vpn auto-discovery [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ pe-address ip-address [ advertise-info ] ] | statistics ] |
Display VPLS label block information discovered by BGP. |
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ] |
Display BGP L2VPN peer information. |
display bgp [ instance instance-name ] peer l2vpn [ ip-address mask-length | group-name group-name log-info | ip-address { log-info | verbose } | verbose ] |
Display BGP L2VPN update group information. |
display bgp [ instance instance-name ] update-group l2vpn [ ip-address ] |
Clear MAC address entries for one or all VSIs. |
reset l2vpn mac-address [ vsi vsi-name ] |
reset bgp { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } l2vpn |
For more information about the display bgp group l2vpn, display bgp peer l2vpn, display bgp update-group l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
VPLS configuration examples
Network requirements
Configure a VSI on each PE, and establish static PWs between the PEs to interconnect the CEs.
Configure an Ethernet service instance on GigabitEthernet 1/0/1 to match packets with an outer VLAN ID of 100 on each PE. Bind the Ethernet service instance to the VSI to forward the matching packets through the VSI.
Figure 7 Network diagram
Configuration procedure
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI. For more information, see Layer 2—LAN Switching Configuration Guide.
This task includes the following configurations:
· Establish static PWs: enable L2VPN, create static PWs, and specify labels.
1. Configure PE 1:
# Configure an LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure VLAN-interface 20 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface vlan-interface 20
[PE1-Vlan-interface20] ip address 20.1.1.1 24
[PE1-Vlan-interface20] mpls enable
[PE1-Vlan-interface20] mpls ldp enable
[PE1-Vlan-interface20] quit
# Configure VLAN-interface 30 (the interface connected to PE 3), and enable LDP on the interface.
[PE1] interface vlan-interface 30
[PE1-Vlan-interface30] ip address 30.1.1.1 24
[PE1-Vlan-interface30] mpls enable
[PE1-Vlan-interface30] mpls ldp enable
[PE1-Vlan-interface30] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Create a VSI, specify the peer PEs, and establish static PWs to the peer PEs.
[PE1] vsi svc
[PE1-vsi-svc] pwsignaling static
[PE1-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 100 out-label 100
[PE1-vsi-svc-static-2.2.2.9-3] quit
[PE1-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 200 out-label 200
[PE1-vsi-svc-static-3.3.3.9-3] quit
[PE1-vsi-svc-static] quit
[PE1-vsi-svc] quit
# Create Ethernet service instance 10 on GigabitEthernet 1/0/1 to match packets with an outer VLAN ID of 100, and bind the Ethernet service instance to VSI svc.
[PE1-GigabitEthernet1/0/1] service-instance 10
[PE1-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[PE1-GigabitEthernet1/0/1-srv10] xconnect vsi svc
2. Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure VLAN-interface 20 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface vlan-interface 20
[PE2-Vlan-interface20] ip address 20.1.1.2 24
[PE2-Vlan-interface20] mpls enable
[PE2-Vlan-interface20] mpls ldp enable
[PE2-Vlan-interface20] quit
# Configure VLAN-interface 40 (the interface connected to PE 3), and enable LDP on the interface.
[PE2] interface vlan-interface 40
[PE2-Vlan-interface40] ip address 40.1.1.2 24
[PE2-Vlan-interface40] mpls enable
[PE2-Vlan-interface40] mpls ldp enable
[PE2-Vlan-interface40] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
[PE2] vsi svc
[PE2-vsi-svc] pwsignaling static
[PE2-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 100 out-label 100
[PE2-vsi-svc-static-1.1.1.9-3] quit
[PE2-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 300 out-label 300
[PE2-vsi-svc-static-3.3.3.9-3] quit
[PE2-vsi-svc-static] quit
[PE2-vsi-svc] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] service-instance 10
[PE2-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[PE2-GigabitEthernet1/0/1-srv10] xconnect vsi svc
3. Configure PE 3:
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 3.3.3.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 3.3.3.9
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure VLAN-interface 30 (the interface connected to PE 1), and enable LDP on the interface.
[PE3] interface vlan-interface 30
[PE3-Vlan-interface30] ip address 30.1.1.3 24
[PE3-Vlan-interface30] mpls enable
[PE3-Vlan-interface30] mpls ldp enable
[PE3-Vlan-interface30] quit
# Configure VLAN-interface 40 (the interface connected to PE 2), and enable LDP on the interface.
[PE3] interface vlan-interface 40
[PE3-Vlan-interface40] ip address 40.1.1.3 24
[PE3-Vlan-interface40] mpls enable
[PE3-Vlan-interface40] mpls ldp enable
[PE3-Vlan-interface40] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE3-ospf-1] quit
[PE3] vsi svc
[PE3-vsi-svc] pwsignaling static
[PE3-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 200 out-label 200
[PE3-vsi-svc-static-1.1.1.9-3] quit
[PE3-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 300 out-label 300
[PE3-vsi-svc-static-2.2.2.9-3] quit
[PE3-vsi-svc-static] quit
[PE3-vsi-svc] quit
[PE3] interface gigabitethernet 1/0/1
[PE3-GigabitEthernet1/0/1] service-instance 10
[PE3-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[PE3-GigabitEthernet1/0/1-srv10] xconnect vsi svc
# Verify that two static PWs in up state have been established on PE 1.
[PE1] display l2vpn pw verbose
VSI Name: svc
Peer: 2.2.2.9 PW ID: 3
Signaling Protocol : Static
Link ID : 8 PW State : Up
In Label : 100 Out Label: 100
MTU : 1500
PW Attributes : Main
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x160000001
Tunnel NHLFE IDs : 1027
Peer: 3.3.3.9 PW ID: 3
Link ID : 9 PW State : Up
In Label : 200 Out Label: 200
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x260000002
Tunnel NHLFE IDs : 1028
Configure a VSI on each PE, and establish LDP PWs between the PEs to interconnect the CEs.
Figure 8 Network diagram
1. Configure an IGP and public tunnels on each PE. (Details not shown.)
2. Configure PE 1:
# Configure basic MPLS.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] pwsignaling ldp
[PE1-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE1-vsi-aaa-ldp-2.2.2.9-500] quit
[PE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-aaa-ldp-3.3.3.9-500] quit
[PE1-vsi-aaa-ldp] quit
[PE1-vsi-aaa] quit
# Create Ethernet service instance 10 on GigabitEthernet 1/0/1 to match packets with an outer VLAN ID of 100, and bind the Ethernet service instance to VSI aaa.
[PE1-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
3. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] pwsignaling ldp
[PE2-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE2-vsi-aaa-ldp-1.1.1.9-500] quit
[PE2-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE2-vsi-aaa-ldp-3.3.3.9-500] quit
[PE2-vsi-aaa-ldp] quit
[PE2-vsi-aaa] quit
[PE2-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
4. Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] pwsignaling ldp
[PE3-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE3-vsi-aaa-ldp-1.1.1.9-500] quit
[PE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE3-vsi-aaa-ldp-2.2.2.9-500] quit
[PE3-vsi-aaa-ldp] quit
[PE3-vsi-aaa] quit
[PE3-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
# Verify that two LDP PWs in up state have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 PW ID: 500
Signaling Protocol : LDP
In Label : 1279 Out Label: 1279
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x260000000
Peer: 3.3.3.9 PW ID: 500
In Label : 1278 Out Label: 1277
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x360000001
Tunnel NHLFE IDs : 1029
BGP PW configuration example
Configure a VSI on each PE, and establish BGP PWs between the PEs to interconnect CEs.
Figure 9 Network diagram
2. Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Establish IBGP connections to PE 2 and PE 3, and use BGP to advertise VPLS label block information.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] auto-discovery bgp
[PE1-vsi-aaa-auto] route-distinguisher 1:1
[PE1-vsi-aaa-auto] vpn-target 1:1
[PE1-vsi-aaa-auto] signaling-protocol bgp
[PE1-vsi-aaa-auto-bgp] site 1 range 10 default-offset 0
[PE1-vsi-aaa-auto-bgp] quit
[PE1-vsi-aaa-auto] quit
[PE1-vsi-aaa] quit
3. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS label block information.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] auto-discovery bgp
[PE2-vsi-aaa-auto] route-distinguisher 1:1
[PE2-vsi-aaa-auto] vpn-target 1:1
[PE2-vsi-aaa-auto] signaling-protocol bgp
[PE2-vsi-aaa-auto-bgp] site 2 range 10 default-offset 0
[PE2-vsi-aaa-auto-bgp] quit
[PE2-vsi-aaa-auto] quit
[PE2-vsi-aaa] quit
4. Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS label block information.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.9 as-number 100
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn
[PE3-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE3-bgp-default-l2vpn] quit
[PE3-bgp-default] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] auto-discovery bgp
[PE3-vsi-aaa-auto] route-distinguisher 1:1
[PE3-vsi-aaa-auto] vpn-target 1:1
[PE3-vsi-aaa-auto] signaling-protocol bgp
[PE3-vsi-aaa-auto-bgp] site 3 range 10 default-offset 0
[PE3-vsi-aaa-auto-bgp] quit
[PE3-vsi-aaa-auto] quit
[PE3-vsi-aaa] quit
# Verify that two BGP PWs have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 Remote Site: 2
Signaling Protocol : BGP
In Label : 1295 Out Label: 1025
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x800000160000001
Peer: 3.3.3.9 Remote Site: 3
Link ID : 10 PW State : Up
In Label : 1296 Out Label: 1025
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x800000060000000
Tunnel NHLFE IDs : 1026
# Display VPLS label block information received from PE 2 and PE 3 on PE 1.
[PE1] display l2vpn bgp verbose
VSI Name: aaa
Remote Site ID : 2
Offset : 0
RD : 1:1
PW State : Up
Encapsulation : BGP-VPLS
MTU : 1500
Nexthop : 2.2.2.9
Local VC Label : 1295
Remote VC Label : 1025
Link ID : 9
Local Label Block : 1293/10/0
Remote Label Block : 1024/10/0
Export Route Target: 1:1
Remote Site ID : 3
Offset : 0
RD : 1:1
PW State : Up
MTU : 1500
Nexthop : 3.3.3.9
Local VC Label : 1296
Link ID : 10
Configure a VSI on each PE. Use BGP to discover remote PEs and use LDP to create PWs among PEs so CEs in different sites of VPN 1 can communicate with each other.
Figure 10 Network diagram
2. Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS PE information.
[PE1] bgp 100
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa-auto] signaling-protocol ldp
[PE1-vsi-aaa-auto-ldp] vpls-id 100:100
[PE1-vsi-aaa-auto-ldp] quit
[PE1-vsi-aaa] quit
3. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS PE information.
[PE2] bgp 100
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa-auto] signaling-protocol ldp
[PE2-vsi-aaa-auto-ldp] vpls-id 100:100
[PE2-vsi-aaa-auto-ldp] quit
[PE2-vsi-aaa] quit
4. Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] bgp 100
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa-auto] signaling-protocol ldp
[PE3-vsi-aaa-auto-ldp] vpls-id 100:100
[PE3-vsi-aaa-auto-ldp] quit
[PE3-vsi-aaa] quit
# Verify that two PWs have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 VPLS ID: 100:100
In Label : 1555 Out Label: 1555
MTU : 1500
VCCV CC : -
VCCV BFD : -
Peer: 3.3.3.9 VPLS ID: 100:100
In Label : 1554 Out Label: 1416
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel NHLFE IDs : 1030
# Display LDP PW label information on PE 1.
[PE1] display l2vpn ldp verbose
VSI Name: aaa
PW State: Up
PW Status Communication: Notification method
PW ID FEC (Local/Remote):
Local AII : (1.1.1.9, 2.2.2.9)
Remote AII : (2.2.2.9, 1.1.1.9)
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1555/1555
Control Word: Disabled/Disabled
VCCV CV Type: -/-
VCCV CC Type: -/-
MTU : 1500/1500
PW Status : PW forwarding/PW forwarding
VSI Name: aaa
PW State: Up
Local AII : (1.1.1.9, 3.3.3.9)
Remote AII : (3.3.3.9, 1.1.1.9)
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1554/1416
VCCV CV Type: -/-
VCCV CC Type: -/-
MTU : 1500/1500
Configure an H-VPLS network using MPLS access to avoid full-mesh PW configuration. The H-VPLS uses LDP as the PW signaling protocol.
Figure 11 Network diagram
2. Configure UPE:
<UPE> system-view
[UPE] interface loopback 0
[UPE-LoopBack0] ip address 1.1.1.9 32
[UPE-LoopBack0] quit
[UPE] mpls lsr-id 1.1.1.9
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure VSI aaa to use LDP to establish a U-PW to NPE 1.
[UPE] vsi aaa
[UPE-vsi-aaa] pwsignaling ldp
[UPE-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.9-500] quit
[UPE-vsi-aaa-ldp] quit
[UPE-vsi-aaa] quit
[UPE] interface gigabitethernet 1/0/1
[UPE-GigabitEthernet1/0/1] service-instance 10
[UPE-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[UPE-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
3. Configure NPE 1:
<NPE1> system-view
[NPE1] interface loopback 0
[NPE1-LoopBack0] ip address 2.2.2.9 32
[NPE1-LoopBack0] quit
[NPE1] mpls lsr-id 2.2.2.9
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, establish a U-PW to the UPE, and establish N-PWs to NPE 2 and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa] pwsignaling ldp
[NPE1-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.9-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE1-vsi-aaa-ldp] quit
[NPE1-vsi-aaa] quit
4. Configure NPE 2:
<NPE2> system-view
[NPE2] interface loopback 0
[NPE2-LoopBack0] ip address 3.3.3.9 32
[NPE2-LoopBack0] quit
[NPE2] mpls lsr-id 3.3.3.9
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignal ldp
[NPE2-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE2-vsi-aaa-ldp] quit
[NPE2-vsi-aaa] quit
[NPE2] interface gigabitethernet 1/0/1
[NPE2-GigabitEthernet1/0/1] service-instance 10
[NPE2-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[NPE2-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
[NPE2-GigabitEthernet1/0/1-srv10] quit
[NPE2-GigabitEthernet1/0/1] quit
5. Configure NPE 3:
<NPE3> system-view
[NPE3] interface loopback 0
[NPE3-LoopBack0] ip address 4.4.4.9 32
[NPE3-LoopBack0] quit
[NPE3] mpls lsr-id 4.4.4.9
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignal ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE3-vsi-aaa-ldp] quit
[NPE3-vsi-aaa] quit
[NPE3] interface gigabitethernet 1/0/1
[NPE3-GigabitEthernet1/0/1] service-instance 10
[NPE3-GigabitEthernet1/0/1-srv10] encapsulation s-vid 100
[NPE3-GigabitEthernet1/0/1-srv10] xconnect vsi aaa
[NPE3-GigabitEthernet1/0/1-srv10] quit
[NPE3-GigabitEthernet1/0/1] quit
# Verify that PWs in up state have been established on each PE.
[UPE] display l2vpn pw verbose
VSI Name: aaa
In Label : 1277 Out Label: 1277
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x460000000
[NPE1] display l2vpn pw verbose
VSI Name: aaa
Peer: 1.1.1.9 PW ID: 500
MTU : 1500
PW Attributes : Main, No-split-horizon
VCCV CC : -
VCCV BFD : -
In Label : 1276 Out Label: 1275
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x560000001
Tunnel NHLFE IDs : 1031
Peer: 4.4.4.9 PW ID: 500
In Label : 1278 Out Label: 1279
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x570000001
Tunnel NHLFE IDs : 1032
[NPE2] display l2vpn pw verbose
VSI Name: aaa
In Label : 1275 Out Label: 1276
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x660000000
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x670000000
[NPE3] display l2vpn pw verbose
VSI Name: aaa
In Label : 1279 Out Label: 1278
MTU : 1500
VCCV CC : -
VCCV BFD : -
MTU : 1500
VCCV CC : -
VCCV BFD : -
As shown in Figure 12, CE 1, CE 2, and CE 3 access PE 1, PE 2, and PE 3 in VLAN mode.
Configure an Ethernet service instance on GigabitEthernet 1/0/1 of each PE to match packets with VLAN ID 100. Bind the Ethernet service instance to the VSI to forward the matching packets through the VSI.
2. Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] vsi aaa
[PE1-vsi-aaa] quit
# Create Ethernet service instance 1000 on GigabitEthernet 1/0/1 (the interface connected to CE 1), and bind the Ethernet service instance to VSI aaa.
[PE1-GigabitEthernet1/0/1] service-instance 1000
[PE1-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[PE1-GigabitEthernet1/0/1-srv1000] xconnect vsi aaa
[PE1-GigabitEthernet1/0/1-srv1000] quit
3. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] vsi aaa
[PE2-vsi-aaa] pwsignal ldp
[PE2-vsi-aaa] quit
# Create Ethernet service instance 1000 on GigabitEthernet 1/0/1 (the interface connected to CE 2), and bind the Ethernet service instance to VSI aaa.
[PE2-GigabitEthernet1/0/1] service-instance 1000
[PE2-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[PE2-GigabitEthernet1/0/1-srv1000] xconnect vsi aaa
[PE2-GigabitEthernet1/0/1-srv1000] quit
[PE2-GigabitEthernet1/0/1] quit
4. Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] vsi aaa
[PE3-vsi-aaa] pwsignal ldp
[PE3-vsi-aaa] quit
# Create Ethernet service instance 1000 on GigabitEthernet 1/0/1 (the interface connected to CE 3), and bind the Ethernet service instance to VSI aaa.
[PE3-GigabitEthernet1/0/1] service-instance 1000
[PE3-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[PE3-GigabitEthernet1/0/1-srv1000] xconnect vsi aaa
[PE3-GigabitEthernet1/0/1-srv1000] quit
[PE3-GigabitEthernet1/0/1] quit
VSI Name: aaa
In Label : 1275 Out Label: 1272
MTU : 1500
VCCV CC : -
VCCV BFD : -
In Label : 1274 Out Label: 1274
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x760000001
Tunnel NHLFE IDs : 1033
[PE2] display l2vpn pw verbose
VSI Name: aaa
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x760000000
In Label : 1273 Out Label: 1271
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x860000001
Tunnel NHLFE IDs : 1034
[PE3] display l2vpn pw verbose
VSI Name: aaa
In Label : 1272 Out Label: 1275
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x960000000
In Label : 1271 Out Label: 1273
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0xa60000001
Tunnel NHLFE IDs : 1035
To improve reliability of the H-VPLS network, the UPE establishes a U-PW with NPE 1 and NPE 2. The U-PW between UPE and NPE 1 is the primary PW and that between UPE and NPE 2 is the backup PW. The backup PW works only when the primary PW fails.
Figure 13 Network diagram
2. Configure UPE:
<UPE> system-view
[UPE-LoopBack0] ip address 1.1.1.1 32
[UPE] mpls lsr-id 1.1.1.1
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish the primary PW to NPE 1 and the backup PW to NPE 2.
[UPE] vsi aaa
[UPE-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.2-500] backup-peer 3.3.3.3 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.2-500-backup] quit
[UPE-vsi-aaa-ldp-2.2.2.2-500] quit
[UPE-vsi-aaa] quit
[UPE-GigabitEthernet1/0/1] service-instance 1000
[UPE-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
[UPE-GigabitEthernet1/0/1-srv1000] xconnect vsi aaa
[UPE-GigabitEthernet1/0/1-srv1000] quit
# Create Ethernet service instance 1000 on GigabitEthernet 1/0/2 (the interface connected to CE 2), and bind the Ethernet service instance to VSI aaa.
[UPE] interface gigabitethernet 1/0/2
[UPE-GigabitEthernet1/0/2] service-instance 1000
[UPE-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 11
[UPE-GigabitEthernet1/0/2-srv1000] xconnect vsi aaa
[UPE-GigabitEthernet1/0/2-srv1000] quit
3. Configure NPE 1:
<NPE1> system-view
[NPE1-LoopBack0] ip address 2.2.2.2 32
[NPE1] mpls lsr-id 2.2.2.2
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 2, and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE1-vsi-aaa] quit
4. Configure NPE 2:
<NPE2> system-view
[NPE2-LoopBack0] ip address 3.3.3.3 32
[NPE2] mpls lsr-id 3.3.3.3
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 1, and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignaling ldp
[NPE2-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE2-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE2-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE2-vsi-aaa] quit
5. Configure NPE 3:
<NPE3> system-view
[NPE3-LoopBack0] ip address 4.4.4.4 32
[NPE3] mpls lsr-id 4.4.4.4
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignaling ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE3-vsi-aaa] quit
[NPE3-GigabitEthernet1/0/1] service-instance 1000
[NPE3-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
[NPE3-GigabitEthernet1/0/1-srv1000] xconnect vsi aaa
[NPE3-GigabitEthernet1/0/1-srv1000] quit
VSI Name: aaa
Peer: 2.2.2.2 PW ID: 500
In Label : 1151 Out Label: 1279
Wait to Restore Time: 0 sec
MTU : 1500
VCCV CC : -
VCCV BFD : -
Peer: 3.3.3.3 PW ID: 500
Link ID : 8 PW State : Blocked
In Label : 1150 Out Label: 1279
MTU : 1500
PW Attributes : Backup
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x360000003
Tunnel NHLFE IDs : 1025
VSI Name: aaa
Peer: 1.1.1.1 PW ID: 500
In Label : 1279 Out Label: 1151
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x60000000
In Label : 1280 Out Label: 1290
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x160000005
Peer: 4.4.4.4 PW ID: 500
MTU : 1500
VCCV CC : -
VCCV BFD : -
VSI Name: aaa
In Label : 1279 Out Label: 1150
MTU : 1500
VCCV CC : -
VCCV BFD : -
In Label : 1290 Out Label: 1280
MTU : 1500
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x160000008
In Label : 1278 Out Label: 1278
MTU : 1500
VCCV CC : -
VCCV BFD : -
VSI Name: aaa
MTU : 1500
VCCV CC : -
VCCV BFD : -
MTU : 1500
VCCV CC : -
VCCV BFD : -
