09-ACL and QoS Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-R757X-GL-6W10009-ACL and QoS Command Reference
04-Data buffer commands
04-Data buffer commands 34.15 KB
burst-mode enable
Use burst-mode enable to enable the Burst feature for a card.
Use undo burst-mode enable to disable the Burst feature for a card.
In standalone mode:
burst-mode enable slot slot-number
undo burst-mode enable slot slot-number
In IRF mode:
burst-mode enable chassis chassis-number slot slot-number
undo burst-mode enable chassis chassis-number slot slot-number
The Burst feature is disabled.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
PEXs in an IRF 3.1 system do not support the Burst feature.
# (In standalone mode.) Enable the Burst feature for slot 1.
[Sysname] burst-mode enable slot 1
# (In IRF mode.) Enable the Burst feature for slot 1 in chassis 1.
[Sysname] burst-mode enable chassis 1 slot 1
