04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-R757X-GL-6W10004-Layer 2 - LAN Switching Command Reference
08-VLAN mapping commands
08-VLAN mapping commands 47.86 KB
display vlan mapping
Use display vlan mapping to display VLAN mapping information.
display vlan mapping [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays VLAN mapping information on all interfaces.
# Display VLAN mapping information on all interfaces.
<Sysname> display vlan mapping
Interface Ten-GigabitEthernet1/0/2:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  1024-4094     N/A           100                      N/A
Outer VLAN
Original outer VLAN.
This field indicates the original VLAN for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
This field displays N/A for zero-to-two VLAN mapping.
Inner VLAN
Original inner VLAN.
This field displays N/A for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
Translated outer VLAN.
This field indicates the translated VLAN for one-to-one VLAN mapping and many-to-one VLAN mapping.
This field indicates the SVLAN to be added for zero-to-two VLAN mapping.
Translated inner VLAN.
This field displays N/A for one-to-one VLAN mapping and many-to-one VLAN mapping.
This field indicates the CVLAN to be added for zero-to-two VLAN mapping.
vlan mapping
vlan mapping
Use vlan mapping to configure VLAN mapping on an interface.
Use undo vlan mapping to cancel the VLAN mapping configuration.
vlan mapping { vlan-id translated-vlan vlan-id | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id }
undo vlan mapping { vlan-id translated-vlan vlan-id | all | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id }
No VLAN mapping is configured on an interface.
vlan-id translated-vlan vlan-id: Specifies the original VLAN and translated VLAN for a one-to-one VLAN mapping. The value range for the vlan-id argument is 1 to 4094. The original VLAN and the translated VLAN cannot be the same.
uni range vlan-range-list translated-vlan vlan-id: Specifies the original VLAN ranges and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-range-list argument specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. The value range for the vlan-id argument is 1 to 4094. Different VLAN ranges cannot overlap. Any of the original VLANs cannot be the same as the translated VLAN.
uni single vlan-id-list translated-vlan vlan-id: Specifies the original VLANs and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-id-list argument specifies a space-separated list of up to eight VLAN IDs, each of which is in the range of 1 to 4094. The value range for the vlan-id argument is 1 to 4094. Any of the original VLANs cannot be the same as the translated VLAN.
nni: Configures the network-side port to use the original VLAN tags of the many-to-one mapping to replace the VLAN tags of the packets destined for the user network.
nest range vlan-range-list nested-vlan vlan-id: Specifies the CVLAN ranges and the SVLAN for a one-to-two VLAN mapping. The vlan-range-list argument specifies a space-separated list of up to eight CVLAN items. Each item specifies a CVLAN ID or a range of CVLAN IDs in the format of vlan-id1 to vlan-id2. The value range for CVLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. Different CVLAN ranges cannot overlap. The vlan-id argument specifies the SVLAN ID in the range of 1 to 4094.
nest single vlan-id-list nested-vlan vlan-id: Specifies the CVLANs and the SVLAN for a one-to-two VLAN mapping. The vlan-id-list argument specifies a space-separated list of up to eight CVLAN IDs, each of which is in the range of 1 to 4094. The vlan-id argument specifies the SVLAN ID in the range of 1 to 4094.
tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id: Specifies the original outer VLAN ID, original inner VLAN ID, translated outer VLAN ID, and translated inner VLAN ID for a two-to-two VLAN mapping. The value ranges for the outer-vlan-id argument and the inner-vlan-id argument are both 1 to 4094.
all: Deletes all VLAN mapping configurations from the interface.
VLAN mapping takes effect only on VLAN-tagged packets received on an interface.
The original and translated VLANs in VLAN mappings on an interface must meet the following requirements:
·     Different types of VLAN mapping entries cannot include the same original VLANs or translated VLANs.
·     Different one-to-one or two-to-two VLAN mapping entries cannot include the same translated VLANs. If you configure multiple one-to-one or two-to-two VLAN mapping entries for the same original VLANs, the most recent configuration takes effect.
When you configure many-to-one VLAN mappings, following these restrictions and guidelines:
·     For many-to-one VLAN mapping to take effect, configure many-to-one VLAN mapping in pairs on both the customer side and the network side.
·     An interface cannot be configured as the customer-side port and network-side port of many-to-one VLAN mapping at the same time.
·     After you configure an interface as the network-side interface of many-to-one VLAN mapping, do not configure the other types of VLAN mapping on the interface.
·     To ensure correct traffic forwarding from the service provider network to the customer network, do not configure many-to-one VLAN mappings together with uRPF. For more information about uRPF, see Security Configuration Guide.
The configuration restrictions between QinQ and VLAN mappings are as follows:
·     Before you enable or disable QinQ on a port, you must remove all VLAN mappings on the port.
·     You cannot configure two-to-two VLAN mappings on a QinQ-enabled port.
If you use both transparent VLANs and VLAN mappings on an interface, the transparent VLANs cannot be the following VLANs:
·     Original or translated VLANs of one-to-one, many-to-one, and one-to-two VLAN mappings.
·     Original or translated outer VLANs of two-to-two VLAN mappings.
The MTU of an interface is 1500 bytes by default. After a VLAN tag is added to a packet, the packet length is added by 4 bytes. As a best practice, set the MTU to a minimum of 1504 bytes for ports on the forwarding path of the packet on the service provider network.
# Configure a one-to-one VLAN mapping on Ten-GigabitEthernet 1/0/1 to map VLAN 1 to VLAN 101.
[Sysname-Ten-GigabitEthernet1/0/1] vlan mapping 1 translated-vlan 101
# Configure many-to-one VLAN mappings on the customer-side port (Ten-GigabitEthernet 1/0/2) to map VLANs 1 through 50 and VLAN 80 to VLAN 101. Configure the network-side port (Ten-GigabitEthernet 1/0/3) to use the original VLAN tags of the many-to-one mappings to replace the VLAN tags of the packets destined for the user network.
[Sysname-Ten-GigabitEthernet1/0/2] vlan mapping uni range 1 to 50 translated-vlan 101
[Sysname-Ten-GigabitEthernet1/0/2] vlan mapping uni single 80 translated-vlan 101
[Sysname-Ten-GigabitEthernet1/0/2] quit
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] vlan mapping nni
# Configure one-to-two VLAN mappings on Ten-GigabitEthernet 1/0/4 to add SVLAN tag 101 to packets carrying VLAN tags 1 through 10 and VLAN tag 80.
[Sysname] interface ten-gigabitethernet 1/0/4
[Sysname-Ten-GigabitEthernet1/0/4] vlan mapping nest range 1 to 10 nested-vlan 101
[Sysname-Ten-GigabitEthernet1/0/4] vlan mapping nest single 80 nested-vlan 101
# Configure a two-to-two VLAN mapping on Ten-GigabitEthernet 1/0/5 to map SVLAN 101 and CVLAN 1 to SVLAN 201 and CVLAN 10.
[Sysname] interface ten-gigabitethernet 1/0/5
[Sysname-Ten-GigabitEthernet1/0/5] vlan mapping tunnel 101 1 translated-vlan 201 10
vlan mapping untagged
Use vlan mapping untagged to configure zero-to-two VLAN mapping on an interface.
Use undo vlan mapping untagged to remove the zero-to-two VLAN mapping configuration.
vlan mapping untagged nested-outer-vlan outer-vlan-id nested-inner-vlan inner-vlan-id
No zero-to-two VLAN mapping is configured on an interface.
nested-outer-vlan outer-vlan-id: Specifies the SVLAN ID in the range of 1 to 4094.
nested-inner-vlan inner-vlan-id: Specifies the CVLAN ID in the range of 1 to 4094.
Before you modify a zero-to-two VLAN mapping, first execute the undo vlan mapping untagged command to remove the previous configuration.
As a best practice, set the MTU to a minimum of 1504 bytes for ports on the forwarding path of the double-tagged packet in the service provider network.
# Configure a zero-to-two VLAN mapping on Ten-GigabitEthernet 1/0/1 to add SVLAN 200 and CVLAN 100 to untagged packets.
[Sysname-Ten-GigabitEthernet1/0/1] vlan mapping untagged nested-outer-vlan 200 nested-inner-vlan 100
