HomeSupportSwitchesS10500 SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release7178-6W10001-Fundamentals Configuration Guide
01-CLI configuration
01-CLI configuration 170.41 KB
Using the CLI
At the command-line interface (CLI), you can enter text commands to configure, manage, and monitor the device.
Figure 1 CLI example
You can use different methods to log in to the CLI, including through the console port, Telnet, and SSH. For more information about login methods, see "Login overview."
CLI views
Commands are grouped in different views by feature. To use a command, you must enter its view.
CLI views are hierarchically organized, as shown in Figure 2. Each view has a unique prompt, from which you can identify where you are and what you can do. For example, the prompt [Sysname-vlan100] shows that you are in VLAN 100 view and can configure attributes for that VLAN.
Figure 2 CLI views
You are placed in user view immediately after you log in to the CLI. The user view prompt is <Device-name>, where Device-name indicates the device name. The device name is Sysname by default. You can change it by using the sysname command.
In user view, you can perform the following tasks:
·           Perform basic operations including display, debug, file management, FTP, Telnet, clock setting, and reboot.
·           Enter system view. The system view prompt is [Device-name].
In system view, you can perform the following tasks:
·           Configure global settings and some features, such as the daylight saving time, banners, and hotkeys.
·           Enter different feature views.
For example, you can perform the following tasks:
¡  Enter interface view to configure interface parameters.
¡  Enter VLAN view to add ports to the VLAN.
¡  Enter user line view to configure login user attributes.
A feature view might have child views. For example, BGP view has child views IPv4 unicast instance view and BGP-VPN IPv4 unicast instance view.
To display all commands available in a view, enter a question mark (?) at the view prompt.
Entering system view from user view
Enter system view.
Returning to the upper-level view from any view
Return to the upper-level view from any view.
Executing the quit command in user view terminates your connection to the device.
In public key view, use the peer-public-key end command to return to system view.
Returning to user view
To return directly to user view from any other view, use the return command or press Ctrl+Z.
Return directly to user view.
return
Accessing the CLI online help
The CLI online help is context sensitive. Enter a question mark at any prompt or in any position of a command to display all available options.
To access the CLI online help, use one of the following methods:
·           Enter a question mark at a view prompt to display the first keyword of every command available in the view. For example:
<Sysname> ?
 User view commands:
  archive             Archive configuration
  backup              Backup the startup configuration file to a TFTP server
  bash
·           Enter a space and a question mark after a command keyword to display all available keywords and arguments at the position.
¡  If the question mark is in the place of a keyword, the CLI displays all possible keywords, each with a brief description. For example:
<Sysname> terminal ?
  debugging  Enable to display debugging logs on the current terminal
  logging    Display logs on the current terminal
  monitor    Enable to display logs on the current terminal
  tracing    Display traces on the current terminal
¡  If the question mark is in the place of an argument, the CLI displays the description for the argument. For example:
[Sysname] interface vlan-interface ?
  <1-4094>  Vlan-interface interface number
[Sysname] interface vlan-interface 1 ?
  <cr>
<1-4094> is the value range for the argument. <cr> indicates that the command is complete and you can press Enter to execute the command.
·           Enter an incomplete keyword string followed by a question mark to display all keywords starting with that string. For example:
<Sysname> f?
fabric
  fabric-mode
  file
  fips
  ftp
<Sysname> display ftp?
  client  FTP client information
Using the undo form of a command
Most configuration commands have an undo form for the following tasks:
·           Canceling a configuration.
·           Restoring the default.
·           Disabling a feature.
For example, the info-center enable command enables the information center. The undo info-center enable command disables the information center.
Entering a command
When you enter a command, you can perform the following tasks:
·           Use keys or hotkeys to edit the command line.
·           Use abbreviated keywords or keyword aliases.
Editing a command line
To edit a command line, use the keys listed in Table 1 or the hotkeys listed in Table 2. When you are finished, you can press Enter to execute the command.
Table 1 Command line editing keys
Keys
Function
Common keys
If the edit buffer is not full, pressing a common key inserts a character at the cursor and moves the cursor to the right. The edit buffer can store up to 511 characters. Unless the buffer is full, all common characters that you enter before pressing Enter are saved in the edit buffer.
Backspace
Deletes the character to the left of the cursor and moves the cursor back one character.
Left arrow key ()
Moves the cursor one character to the left.
Right arrow key ()
Moves the cursor one character to the right.
Up arrow key ()
Gets the previous command in the command history buffer.
Down arrow key ()
Gets the next command in the command history buffer.
Tab
If you press Tab after entering part of a keyword, the system automatically completes the keyword.
·           If a unique match is found, the system displays the complete keyword.
·           If there is more than one match, press Tab multiple times to pick the keyword you want to enter.
·           If there is no match, the system does not modify what you entered but displays it again in the next line.
The total length of a command line cannot exceed 512 characters, including spaces and special characters.
Entering a text or string type value for an argument
A text type argument value can contain printable characters except the question mark (?).
A string type argument value can contain any printable characters except for the following characters:
·           Question mark (?).
·           Quotation mark (").
·           Backward slash (\).
·           Space.
A specific argument might have more requirements. For more information, see the relevant command reference.
To enter a printable character, you can enter the character or its ASCII code in the range of 32 to 126.
Abbreviating commands
You can enter a command line quickly by entering incomplete keywords that uniquely identify the complete command. In user view, for example, commands starting with an s include startup saved-configuration and system-view. To enter the command system-view, you only need to type sy. To enter the command startup saved-configuration, type st s.
You can also press Tab to complete an incomplete keyword.
Configuring and using command keyword aliases
The command keyword alias feature allows you to replace the first keyword of a non-undo command or the second keyword of an undo command with your preferred keyword when you execute the command. For example, if you configure show as the alias for the display keyword, you can enter either show clock or display clock to execute the display clock command.
A command keyword can have only one alias.
Follow these guidelines when you use command keyword aliases:
·           After you successfully execute a command by using a keyword alias, the system saves the keyword, instead of its alias, to the running configuration.
·           If a string you entered for a command partially matches an alias and a keyword, the command indicated by the alias is executed. To execute the command indicated by the keyword, enter the complete keyword.
·           If a string you entered for a command partially matches multiple aliases, the system displays an error message.
·           If you enter a string that partially matches an alias and a keyword and press Tab, the keyword indicated by the alias is displayed. Pressing Tab again displays the keyword.
Configuration procedure
To configure a command keyword alias:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable the command keyword alias feature.
command-alias enable
By default, the command keyword alias feature is disabled.
3.      Configure a command keyword alias.
command-alias mapping cmdkey alias
By default, no command keyword alias is configured.
You must enter the cmdkey and alias arguments in their complete form.
4.      (Optional.) Display command keyword alias information.
display command-alias
This command is available in any view.
Configuring and using command hotkeys
The system defines the hotkeys shown in Table 2 and provides five configurable command hotkeys. Pressing a command hotkey is the same as entering a command.
If a hotkey is also defined by the terminal software you are using to interact with the device, the terminal software definition takes effect.
To configure a command hotkey:
Step
Remarks
N/A
2.      Assign a command to a hotkey.
hotkey { ctrl_G | ctrl_L | ctrl_O | ctrl_T | ctrl_U } command
The following are the defaults:
·           Ctrl+G is assigned the display current-configuration command.
·           Ctrl+L is assigned the display ip routing-table command.
·           Ctrl+O is assigned the undo debugging all command.
·           No command is assigned to Ctrl+T or Ctrl+U.
3.      (Optional.) Display hotkeys.
display hotkey
Table 2 System-reserved hotkeys
Hotkey
Function
Ctrl+A
Moves the cursor to the beginning of a line.
Ctrl+B
Ctrl+C
Stops the current command.
Ctrl+D
Deletes the character at the cursor.
Ctrl+E
Moves the cursor to the end of a line.
Ctrl+F
Ctrl+H
Deletes the character to the left of the cursor.
Ctrl+K
Aborts the connection request.
Ctrl+N
Displays the next command in the history buffer.
Ctrl+P
Displays the previous command in the history buffer.
Ctrl+R
Redisplays the current line.
Ctrl+V
Pastes text from the clipboard.
Ctrl+W
Deletes the word to the left of the cursor.
Ctrl+X
Deletes all characters to the left of the cursor.
Ctrl+Y
Deletes all characters from the cursor to the end of the line.
Ctrl+Z
Returns to user view.
Ctrl+]
Terminates the current connection.
Esc+B
Moves the cursor back one word.
Esc+D
Deletes all characters from the cursor to the end of the word.
Esc+F
Moves the cursor forward one word.
Enabling redisplaying entered-but-not-submitted commands
Your input might be interrupted by system information output. If redisplaying entered-but-not-submitted commands is enabled, the system redisplays your input after finishing the output. You can then continue entering the command line.
To enable redisplaying entered-but-not-submitted commands:
Step
Remarks
N/A
2.      Enable redisplaying entered-but-not-submitted commands.
info-center synchronous
By default, the system does not redisplay entered-but-not-submitted commands.
For more information about this command, see Network Management and Monitoring Command Reference.
Understanding command-line error messages
After you press Enter to submit a command, the command line interpreter examines the command syntax.
·           If the command passes syntax check, the CLI executes the command.
·           If the command fails syntax check, the CLI displays an error message.
Table 3 Common command-line error messages
Error message
Cause
% Unrecognized command found at '^' position.
The keyword in the marked position is invalid.
% Incomplete command found at '^' position.
One or more required keywords or arguments are missing.
% Ambiguous command found at '^' position.
The entered character sequence matches more than one command.
% Too many parameters.
The entered character sequence contains excessive keywords or arguments.
% Wrong parameter found at '^' position.
The argument in the marked position is invalid.
Using the command history feature
The system automatically saves commands successfully executed by a login user to the following two command history buffers:
·           Command history buffer for the user line.
·           Command history buffer for all user lines.
Table 4 Comparison between the two types of command history buffers
Item
Command history buffer for a user line
What kind of commands are saved in the buffer?
Commands successfully executed by the current user of the user line.
Commands successfully executed by all login users.
Cleared when the user logs out?
Yes.
No.
How to view buffered commands?
Use the display history-command command.
Use the display history-command all command.
How to recall a buffered command?
Navigate to the command in the buffer and press Enter.
You cannot recall buffered commands.
How to set the buffer size?
Use the history-command max-size size-value command in user line view to set the buffer size.
By default, the buffer can store up to 10 commands.
You cannot set the buffer size.
By default, the buffer can store up to 1024 commands.
How to disable the buffer?
Setting the buffer size to 0 disables the buffer.
You cannot disable the buffer.
Command buffering rules
The system follows these rules when buffering commands:
·           If you use incomplete keywords when entering a command, the system buffers the command in the exact form that you used.
·           If you use an alias when entering a command, the system transforms the alias to the represented command or command keywords before buffering the command.
·           If you enter a command in the same format multiple times in succession, the system buffers the command only once. If you enter a command in different formats multiple times, the system buffers each command format. For example, display cu and display current-configuration are buffered as two entries but successive repetitions of display cu create only one entry.
·           To buffer a new command when a buffer is full, the system deletes the oldest command entry in the buffer.
Controlling the CLI output
This section describes the CLI output control features that help you identify the desired output.
Pausing between screens of output
The system automatically pauses after displaying a screen if the output is too long to fit on one screen. You can use the keys described in "Output controlling keys" to display more information or stop the display.
By default, up to 24 lines can be displayed on a screen. You can change the limit by using the screen-length screen-length command. For more information about this command, see Fundamentals Command Reference.
You can also disable pausing between screens of output for the current session. Then, all output is displayed at one time and the screen is refreshed continuously until the final screen is displayed.
Keys
Function
Space
Displays the next screen.
Enter
Displays the next line.
Ctrl+C
Stops the display and cancels the command execution.
<PageUp>
Displays the previous page.
<PageDown>
Displays the next page.
Disabling pausing between screens of output
To disable pausing between screens of output, execute the following command in user view:
Remarks
Disable pausing between screens of output for the current session.
screen-length disable
By default, a session uses the screen-length screen-length command settings in user line view.
This command is a one-time command and takes effect only for the current session.
Numbering each output line from a display command
You can use the | by-linenum option to prefix each display command output line with a number for easy identification.
Each line number is displayed as a 5-character string and might be followed by a colon (:) or hyphen (-). If you specify both | by-linenum and | begin regular-expression for a display command, a hyphen is displayed for all lines that do not match the regular expression.
To number each output line from a display command:
Number each output line from a display command.
display command | by-linenum
For example:
# Display information about VLAN 999, numbering each output line.
<Sysname> display vlan 999 | by-linenum
    1:  VLAN ID: 999
    2:  VLAN type: Static
    3:  Route interface: Configured
    4:  IP address: 192.168.2.1
    5:  Subnet mask: 255.255.255.0
    6:  Description: For LAN Access
    7:  Name: VLAN 0999
    8:  Tagged ports:   None
    9:  Untagged ports:
   10:      GigabitEthernet1/0/1
Filtering the output from a display command
You can use the | { begin | exclude | include } regular-expression option to filter the display command output.
·           beginDisplays the first line matching the specified regular expression and all subsequent lines.
·           excludeDisplays all lines not matching the specified regular expression.
·           includeDisplays all lines matching the specified regular expression.
·           regular-expression—A case-sensitive string of 1 to 256 characters, which can contain the special characters described in Table 5.
The required filtering time increases with the complexity of the regular expression. To abort the filtering process, press Ctrl+C.
Table 5 Special characters supported in a regular expression
Characters
Meaning
Matches the beginning of a line.
"^u" matches all lines beginning with "u". A line beginning with "Au" is not matched.
Matches the end of a line.
"u$" matches all lines ending with "u". A line ending with "uA" is not matched.
. (period)
Matches any single character.
".s" matches "as" and "bs".
Matches the preceding character or string zero, one, or multiple times.
"zo*" matches "z" and "zoo", and "(zo)*" matches "zo" and "zozo".
Matches the preceding character or string one or multiple times.
"zo+" matches "zo" and "zoo", but not "z".
Matches the preceding or succeeding string.
"def|int" matches a line containing "def" or "int".
Matches the string in the parentheses, usually used together with the plus sign (+) or asterisk sign (*).
"(123A)" matches "123A".
"408(12)+" matches "40812" and "408121212", but not "408".
\N
Matches the preceding strings in parentheses, with the Nth string repeated once.
"(string)\1" matches a string containing "stringstring".
"(string1)(string2)\2" matches a string containing "string1string2string2".
"(string1)(string2)\1\2" matches a string containing " string1string2string1string2".
Matches a single character in the brackets.
"[16A]" matches a string containing 1, 6, or A; "[1-36A]" matches a string containing 1, 2, 3, 6, or A (- is a hyphen).
To match the character "]", put it immediately after "[", for example, []abc]. There is no such limit on "[".
Matches a single character that is not in the brackets.
"[^16A]" matches a string that contains one or more characters except for 1, 6, or A, such as "abc". A match can also contain 1, 6, or A (such as "m16"), but it cannot contain these three characters only (such as 1, 16, or 16A).
{n}
Matches the preceding character n times. The number n must be a nonnegative integer.
"o{2}" matches "food", but not "Bob".
{n,}
Matches the preceding character n times or more. The number n must be a nonnegative integer.
"o{2,}" matches "foooood", but not "Bob".
{n,m}
Matches the preceding character n to m times or more. The numbers n and m must be nonnegative integers and n cannot be greater than m.
" o{1,3}" matches "fod", "food", and "foooood", but not "fd".
Matches a string that starts with the pattern following \<. A string that contains the pattern is also a match if the characters preceding the pattern are not digits, letters, or underscores.
"\<do" matches "domain" and "doa".
Matches a string that ends with the pattern preceding \>. A string that contains the pattern is also a match if the characters following the pattern are not digits, letters, or underscores.
"do\>" matches "undo" and "cdo".
\b
Matches a word that starts with the pattern following \b or ends with the pattern preceding \b.
"er\b" matches "never", but not "verb" or "erase".
"\ber" matches "erase", but not "verb" or "never".
\B
Matches a word that contains the pattern but does not start or end with the pattern.
"er\B" matches "verb", but not "never" or "erase".
\w
Same as [A-Za-z0-9_], matches a digit, letter, or underscore.
"v\w" matches "vlan" and "service".
\W
Same as [^A-Za-z0-9_], matches a character that is not a digit, letter, or underscore.
"\Wa" matches "-a", but not "2a" or "ba".
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
"\\" matches a string containing "\", "\^" matches a string containing "^", and "\\b" matches a string containing "\b".
For example:
# Use | begin line for the display current-configuration command to match the first line of output that contains line to the last line of output.
<Sysname> display current-configuration | begin line
line aux 0
 user-role network-operator
line con 0
 user-role network-admin
line vty 0 63
 authentication-mode scheme
 ssh server enable
return
# Use | exclude Direct for the display ip routing-table command to filter out direct routes and display only the non-direct routes.
<Sysname> display ip routing-table | exclude Direct
         Destinations : 12       Routes : 12
2.2.2.0/24          OSPF   10   2            1.1.2.2         GE3/0/1
# Use | include snmp for the display current-configuration command to filter in entries that contain snmp.
<Sysname> display current-configuration | include snmp
snmp-agent
 snmp-agent community write private
 snmp-agent community read public
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.1.26 params securityname public
Saving the output from a display command to a file
A display command shows certain configuration and operation information of the device. Its output might vary over time or with user configuration or operation. You can save the output to a file for future retrieval or troubleshooting.
Use one of the following methods to save the output from a display command:
·           Save the output to a separate file. Use this method if you want to use one file for a single display command.
·           Append the output to the end of a file. Use this method if you want to use one file for multiple display commands.
To save the output from a display command to a file, use one of the following commands in any view:
Save the output from a display command to a separate file.
display command > filename
Append the output from a display command to the end of a file.
display command >> filename
For example:
# Save the VLAN 1 settings to a separate file named vlan.txt.
<Sysname> display vlan 1 > vlan.txt
# Verify that the VLAN 1 settings are saved to file vlan.txt.
<Sysname> more vlan.txt
VLAN ID: 1
 VLAN type: Static
 Description: VLAN 0001
 Tagged ports:   None
 Untagged ports:
    GigabitEthernet1/0/2
# Append the VLAN 999 settings to the end of file vlan.txt.
<Sysname> display vlan 999 >> vlan.txt
# Verify that the VLAN 999 settings are appended to the end of file vlan.txt.
VLAN ID: 1
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 999
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
Viewing and managing the output from a display command effectively
You can use the following methods in combination to filter and manage the output from a display command:
·           Numbering each output line from a display command
·           Filtering the output from a display command
·           Saving the output from a display command to a file
To use multiple measures to view and manage the output from a display command effectively, execute the following command in any view:
View and manage the output from a display command effectively.
display command [ | [ by-linenum ] { begin | exclude | include } regular-expression ] [ > filename | >> filename ]
For example:
# Save the running configuration to a separate file named test.txt, with each line numbered.
<Sysname> display current-configuration | by-linenum > test.txt
# Append lines including snmp in the running configuration to the file test.txt.
<Sysname> display current-configuration | include snmp >> test.txt
# Display the first line that begins with user-group in the running configuration and all the following lines.
<Sysname> display current-configuration | by-linenum begin user-group
  114:  user-group system
  115-  #
  116-  return
// The colon (:) following a line number indicates that the line contains the string user-group. The hyphen (-) following a line number indicates that the line does not contain the string user-group.
Saving the running configuration
To make your configuration take effect after a reboot, save the running configuration to a configuration file by using the save command in any view. This command saves all commands that have been successfully executed, except for the one-time commands. Typical one-time commands include display commands used for displaying information and reset commands used for clearing information.
For more information about the save command, see Fundamentals Command Reference.
