01-Fundamentals Configuration Examples
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration ExamplesH3C S7500X Switch Series Configuration Examples-Release7536P05-6W10001-Fundamentals Configuration Examples
05-H3C_ISSU_Examples
05-H3C_ISSU_Examples 90.16 KB
H3C ISSU Examples
H3C_彩色.emf
Introduction
This document provides compatible and incompatible ISSU configuration examples.
Before performing an ISSU, use the display version comp-matirx command to view the ISSU method in the Upgrade Way field. Table 1 shows a matrix of ISSU types and ISSU methods.
Table 1 Matrix of ISSU types and ISSU methods
ISSU type
ISSU method displayed in Upgrade Way
Compatible
·     Service Upgrade
·     File Upgrade
·     Reboot
Incompatible
Incompatible upgrade
This document assumes that you have basic knowledge of ISSU.
Hardware requirements
·     Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
·     Do not perform an ISSU during hardware upgrade or failure.
Upgrade restrictions
·     Read the software release notes to identify support of the device for ISSU.
·     Use the display device command to verify that no member devices are in Fault state.
·     Use the display mdc command to verify that all MDCs are in active state.
·     Use the dir command to verify that the available storage space on each member device is at least two times the size of the new image. If the storage space is not sufficient, delete unused files by using the delete /unreserved file-url command.
Feature restrictions
For service continuity during ISSU, configure the following feature settings:
Feature
Setting requirements
GR or NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
·     Use link-delay to set the physical state change suppression interval to 0 on Ethernet interfaces, so the interfaces report physical state changes to the CPU in time.
·     Enable link-aggregation traffic redirection to avoid link-aggregation traffic loss.
·     Configure the irf mac-address persistent always command.
·     To perform an incompatible upgrade for an IRF fabric, disable IRF MAD before the upgrade. After the upgrade, enable IRF MAD again.
Operation restrictions
·     In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·     Do not perform any of the following tasks during an ISSU:
¡     Reboot, add, or remove cards.
¡     Execute commands that are irrelevant to the ISSU.
¡     Modify, delete, or rename image files.
Example: Performing a compatible ISSU
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. Perform a compatible ISSU on the IRF to upgrade startup images from R7150 to R7536P05.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on S7500X-CMW710-R7536P05.
Procedures
# Download the new image file new.ipe from the TFTP server to the root directory of a file system on the master. The .ipe file includes boot image file boot-R7536P05.bin and system image file system-R7536P05.bin.
<Master> tftp 2.2.2.2 get new.ipe
<Sysname> tftp 2.2.2.2 get feature1-r0202.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
# Display current software images.
<Master> display boot-loader
Software images on chassis 1 slot 0:
Current software images:
  flash:/BOOT-R7150.bin
  flash:/SYSTEM-R7150.bin
Main startup software images:
Backup startup software images:
Software images on chassis 1 slot 1:
Software images on chassis 2 slot 0:
Software images on chassis 2 slot 1:
# Display version compatibility information and identify the ISSU method.
<Master> display version comp-matrix file ipe flash:/new.ipe
Verifying image file.......Done.
Verifying the file flash:/S10500-CMW710-BOOT-E7532.bin on chassis 1 slot 0.....Done.
Identifying the upgrade methods...........Done.
Boot image: boot-R7536P05.bin
  Version:
  7.1.70-R7536P05
System image: system-R7536P05.bin
  Version:
  7.1.70-R7536P05
  Version compatibility list:
  7.1.45-R7150
  7.1.70-R7536P05
  Version dependency boot list:
  7.1.70-R7536P05
  Chassis   Slot              Upgrade Way
  1         0                 Reboot
  1         1                 Reboot
  2         0                 Reboot
  2         1                 Reboot
The output shows the two versions are compatible and a reboot upgrade is recommended.
# Disable automatic rollback.
[Sysname] issu rollback-timer 0
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
# Enable the IRF bridge MAC address to be permanent.
[Sysname] irf mac-address persistent always
# Set the physical state change suppression interval to 0 on the Ethernet interfaces.
[Sysname] interface gigabitethernet1/3/0/1
[Sysname-GigabitEthernet1/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet1/3/0/1] quit
[Sysname] interface gigabitethernet2/3/0/1
[Sysname-GigabitEthernet2/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet2/3/0/1] quit
[Sysname] quit
# Upgrade the subordinate.
<Master> issu load file ipe flash:/new.ipe chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Verifying the file flash:/boot-R7536P05.bin on Chassis 1 slot 0...Done.
Verifying the file flash:/system-R7536P05.bin on Chassis 1 slot 0...Done.
Copying file flash:/boot-R7536P05.bin to chassis2#slot0#flash:/boot-R7536P05.bin......Done.
Copying file flash:/system-R7536P05.bin to chassis2#slot0#flash:/system-R7536P05.bin......Done.
Verifying the file flash:/boot-R7536P05.bin on Chassis 2 slot 0...Done.
Verifying the file flash:/system-R7536P05.bin on Chassis 2 slot 0...Done.
Copying file flash:/boot-R7536P05.bin to chassis2#slot1#flash:/boot-R7536P05.bin......Done.
Copying file flash:/system-R7536P05.bin to chassis2#slot1#flash:/system-R7536P05.bin......Done.
Verifying the file flash:/boot-R7536P05.bin on Chassis 2 slot 1...Done.
Verifying the file flash:/system-R7536P05.bin on Chassis 2 slot 1...Done.
  Running Version             New Version
  Release 7150                Release 7536P05
  2         0                 Reboot
  2         1                 Reboot
Upgrading software images to compatible versions. Continue? [Y/N]: y
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is finished on the subordinate.
<Master> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
  chassis 2
Current upgrading chassis: None
Current version list:
  boot: 7.1.070, Release 7536P05
  system: 7.1.070, Release 7536P05
# Perform a master/subordinate switchover.
<Master> issu run switchover
  Chassis   Slot              Switchover Way
  1         0                 Active standby process switchover
# Verify that the switchover has completed.
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 2
// The Switchover ISSU state indicates the switchover has completed.
# Upgrade the original master.
<Master> issu commit chassis 1
Copying file flash:/boot-R7536P05.bin to chassis1#slot1#flash:/boot-R7536P05.bin......Done.
Verifying the file flash:/boot-R7536P05.bin on Chassis 1 slot 1...Done.
Copying file flash:/system-R7536P05.bin to chassis1#slot1#flash:/system-R7536P05.bin......Done.
Verifying the file flash:/system-R7536P05.bin on Chassis 1 slot 1...Done.
flash:/S10500-CMW710-SYSTEM-R7536P05.bin
  1         0                 Reboot
  1         1                 Reboot
# View ISSU state.
ISSU state: Init
Work state: Normal
Upgraded chassis: None
// The Init state indicates that the ISSU has completed.
# Verify that startup images have been upgraded to R7536P05.
<Master> display install active
Active packages on chassis 1 slot 0:
Active packages on chassis 1 slot 1:
  flash://boot-R7536P05.bin
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
Configuration files
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 1
 irf mode normal
interface GigabitEthernet1/3/0/1
 port link-mode bridge
interface GigabitEthernet2/3/0/1
Example: Performing an incompatible ISSU
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. Perform an incompatible ISSU on the IRF to upgrade startup images from R7150 to R7536P05.
Figure 2 Network diagram
Procedures
100 43.8M  100 42.8M    0     0   159k      0  0:04:34  0:04:34 --:--:--  165k
Verifying image file........Done.
  Version:
  7.1.70-R7536P05
  Version:
  7.1.70-R7536P05
  7.1.70-R7536P05
  7.1.70-R7536P05
Incompatible upgrade.
The output shows the two versions are incompatible and a reboot is needed to complete upgrade.
[Sysname] quit
  2         0                 Reboot
  2         1                 Reboot
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded chassis:
  chassis 2
# Perform a master/subordinate switchover to complete upgrade.
  1         1                 Active standby process switchover
# View ISSU state.
ISSU state: Init
Work state: Normal
Configuration files
 undo irf link-delay
 irf mode normal
Related documentation
·     H3C S7500X Switch Series Fundamentals Command Reference-R7536P05
·     H3C S7500X Switch Series Fundamentals Configuration Guide-R7536P05
