Title | Size | Downloads |
LSQM1MPUS10C0 Card Manual-6PW103-book.pdf | 71.43 KB |
1 Card identifier
The card identifier LSQM1MPUS10C0 is in the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Flash |
2 GB |
BootROM |
8 MB |
NVRAM |
1 MB |
SDRAM (DDR3) |
4 GB |
Card size (H × W × D) |
45 × 399 × 355 mm (1.77 × 15.71 × 13.98 in) |
Power consumption |
93W to 182W |
Interfaces |
· 1 console port · 1 USB console port · 4 network management ports: 2 RJ-45 ports and 2 SFP fiber ports · 1 primary USB port |
Transmission rate |
· Console port: 9600 bps to 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · network management ports ( RJ-45 ): 10/100/1000 Mbps, half/full duplex · network management ports (SFP ): 1000 Mbps |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous EIA/TIA-232 cables · USB console port: 10 m (32.81 ft) over USB-AB cables · network management ports ( RJ-45 ): 100 m (328.08 ft) over Category 5 or higher twisted pair cables · network management ports (SFP ): see Table 3 |
Compatible device models |
S7510X/S7510X-PoE |
Software version |
Version 7536 and later |
NOTE: H3C recommends not using a USB extender cable to connect the USB port. |
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin |
10BASE-T/100BASE-TX/1000BASE-T |
Signal |
Function |
1 |
MX_0+ |
Transmits and receives data. |
2 |
MX_0- |
3 |
MX_1+ |
4 |
MX_2+ |
5 |
MX_2- |
6 |
MX_1- |
7 |
MX_3+ |
8 |
MX_3- |
Table 3 describes the SFP transceiver modules available for the SFP and SFP+ ports on the card.
Table 3 GE SFP transceiver modules available for the SFP and SFP+ ports
GE SFP transceiver module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125 μm multi-mode optical fiber (MMF) |
550 m (0.34 miles) |
62.5/125 μm MMF |
275 m (0.17 miles) |
SFP-GE-SX-MM850-D |
850 nm |
LC |
50/125 μm MMF |
62.5/125 μm MMF |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125 μm single-mode optical fiber (SMF) |
10 km (6.21 miles) |
50/125 μm MMF |
550 m (1804.46 ft) |
62.5/125 μm MMF |
SFP-GE-LX-SM1310-D |
1310 nm |
LC |
9/125 μm SMF |
50/125 μm MMF |
62.5/125 μm MMF |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
9/125 μm SMF |
40 km (24.86 miles) |
SFP-GE-LH40-SM1310-D |
1310 nm |
LC |
9/125 μm SMF |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
9/125 μm SMF |
SFP-GE-LH80-SM1550 |
1550 nm |
LC |
9/125 μm SMF |
80 km (49.71 miles) |
SFP-GE-LH80-SM1550-D |
1550nm |
LC |
9/125 μm SMF |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
9/125 μm SMF |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
RX: 1490 nm TX: 1310 nm |
LC |
9/125 μm SMF |
SFP-GE-LX-SM1490-BIDI |
RX: 1310 nm TX: 1490 nm |
LC |
9/125 μm SMF |
NOTE: · BIDI modules use different central wavelengths in transmit and receive directions, in order to implement bidirectional transmission of optical signals over the same fiber. · The BIDI modules must be used in pairs. For example, if you install the SFP-GE-LX-SM1310-BIDI in the local port, you must install the SFP-GE-LX-SM1490-BIDI in the peer port. |
3 Related documentation
For module installation, see H3C S7500X Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2017-2018 New H3C Technologies Co., Ltd.
