08-ACL and QoS Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7536P05-6W10008-ACL and QoS Configuration Examples
05-H3C_GTS_and_Rate_Limiting_Configuration_Examples
H3C GTS and Rate Limiting Configuration Examples
H3C_彩色.emf
Introduction
This document provides GTS and rate limiting configuration examples.
This document assumes that you have basic knowledge of GTS and rate limiting.
Example: Configuring GTS and rate limiting
As shown in Figure 1, the 15-Mbps dedicated line transmits the FTP traffic, business-specific application traffic, and IP voice traffic between the headquarters and branch of a company.
The following traffic policing settings have been configured on the edge device (Device B) of the headquarters:
·     CIR of 10 Mbps for IP voice traffic.
·     CIR of 3 Mbps for business-specific application traffic.
·     CIR of 7 Mbps for FTP traffic.
Configure traffic shaping on the edge device (Device A) of the branch to buffer excess traffic of each traffic type.
Configure rate limiting on Device A to limit the outgoing traffic rate to 15 Mbps.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To implement GTS, first determine the queue that transmits a type of traffic. In this example, the priorities of these types of traffic are not provided. You need to use priority marking to manually assign packets to different queues.
·     You can manually assign packets to queues by marking DSCP values, 802.1p priority values, or local precedence values. To keep the contents of packets unchanged, mark local precedence values for packets.
Software versions used
This configuration example was created and verified on S7500E-CMW710-R7536P05.
Procedures
Before configuring GTS and rate limiting, make sure there is network connectivity between the branch and headquarters.
This section does not describe the configurations for enabling network connectivity.
Configuring priority marking
1.     Create three traffic classes to match the three traffic types:
# Configure basic IPv4 ACL 2000 to match IP voice traffic (traffic from subnet 192.168.3.0/24).
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 192.168.3.0 0.0.0.255
# Create a class named voice, and use ACL 2000 as the match criterion.
[DeviceA] traffic classifier voice
[DeviceA-classifier-voice] if-match acl 2000
[DeviceA-classifier-voice] quit
# Configure basic IPv4 ACL 2001 to match application traffic (traffic from subnet 192.168.2.0/24).
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 192.168.2.0 0.0.0.255
# Create a class named service, and use ACL 2001 as the match criterion.
[DeviceA] traffic classifier service
[DeviceA-classifier-service] if-match acl 2001
[DeviceA-classifier-service] quit
# Configure advanced IPv4 ACL 3000 to match FTP traffic (traffic from subnet 192.168.1.0/24 and with destination port number 20).
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule permit tcp destination-port eq 20 source 192.168.1.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3000] quit
# Create a class named ftp, and use ACL 3000 as the match criterion.
[DeviceA] traffic classifier ftp
[DeviceA-classifier-ftp] if-match acl 3000
[DeviceA-classifier-ftp] quit
2.     Create three traffic behaviors:
# Create a behavior named voice, and configure the behavior to mark packets with local precedence 6 (corresponding to queue 6).
[DeviceA] traffic behavior voice
[DeviceA-behavior-voice] remark local-precedence 6
[DeviceA-behavior-voice] quit
# Create a behavior named service, and configure the behavior to mark packets with local precedence 4 (corresponding to queue 4).
[DeviceA] traffic behavior service
[DeviceA-behavior-service] remark local-precedence 4
[DeviceA-behavior-service] quit
# Create a behavior named ftp, and configure the behavior to mark packets with local precedence 2 (corresponding to queue 2).
[DeviceA] traffic behavior ftp
[DeviceA-behavior-ftp] remark local-precedence 2
[DeviceA-behavior-ftp] quit
3.     Configure and apply a QoS policy:
# Create a QoS policy named shaping, and associate the three classes with their respective behaviors in the QoS policy.
[DeviceA] qos policy shaping
[DeviceA-qospolicy-shaping] classifier voice behavior voice
[DeviceA-qospolicy-shaping] classifier service behavior service
[DeviceA-qospolicy-shaping] classifier ftp behavior ftp
[DeviceA-qospolicy-shaping] quit
# Apply the QoS policy shaping to the inbound direction of Ten-GigabitEthernet 1/0/2.
[DeviceA] interface Ten-GigabitEthernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] qos apply policy shaping inbound
[DeviceA-Ten-GigabitEthernet1/0/2] quit
Configuring GTS
# Configure GTS on Ten-GigabitEthernet 1/0/1 to set the CIR to 10 Mbps for queue 6 (IP voice traffic).
[DeviceA] interface Ten-GigabitEthernet 1/0/1
[DeviceA-Ten-GigabitEthernet1/0/1] qos gts queue 6 cir 10240
# Configure GTS on Ten-GigabitEthernet 1/0/1 to set the CIR to 3 Mbps for queue 4 (application traffic).
[DeviceA-Ten-GigabitEthernet1/0/1] qos gts queue 4 cir 3072
# Configure GTS on Ten-GigabitEthernet 1/0/1 to set the CIR to 7 Mbps for queue 2 (FTP traffic).
[DeviceA-Ten-GigabitEthernet1/0/1] qos gts queue 2 cir 7168
Configuring rate limiting
# Configure rate limiting on Ten-GigabitEthernet 1/0/1 to set the CIR to 15 Mbps for outgoing traffic.
[DeviceA-Ten-GigabitEthernet1/0/1] qos lr outbound cir 15360
# Verify the priority marking settings of Ten-GigabitEthernet 1/0/2.
<Device> display qos policy interface inbound
Interface: Ten-GigabitEthernet1/0/2
  Direction: Inbound
  Policy: shaping
   Classifier: voice
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: voice
      Marking:
        Remark local-precedence 6
   Classifier: service
     Operator: AND
     Rule(s) :
      If-match acl 2001
     Behavior: service
      Marking:
        Remark local-precedence 4
   Classifier: ftp
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: ftp
      Marking:
        Remark local-precedence 2
# Verify the GTS settings on Ten-GigabitEthernet 1/0/1.
<Device> display qos gts interface
 Rule: If-match queue 6
  CIR 10240 (kbps), CBS 640000 (Bytes)
 Rule: If-match queue 4
  CIR 3072 (kbps), CBS 192000 (Bytes)
 Rule: If-match queue 2
  CIR 7168 (kbps), CBS 448000 (Bytes)
# Verify the rate limiting settings on Ten-GigabitEthernet 1/0/1.
<Device> display qos lr interface
Direction: Outbound
 CIR 15360 (kbps),  CBS 960000 (Bytes)
Configuration files
acl basic 2000
 rule 0 permit source 192.168.3.0 0.0.0.255
acl basic 2001
 rule 0 permit source 192.168.2.0 0.0.0.255
acl advanced 3000
 rule 0 permit tcp source 192.168.1.0 0.0.0.255 destination-port eq ftp-data
traffic classifier ftp operator and
 if-match acl 3000
traffic classifier service operator and
 if-match acl 2001
traffic classifier voice operator and
 if-match acl 2000
qos policy shaping
 port link-mode bridge
 qos lr outbound cir 15360 cbs 960000
 qos gts queue 6 cir 10240 cbs 640000
 qos gts queue 4 cir 3072 cbs 192000
 qos gts queue 2 cir 7168 cbs 448000
return
Related documentation
·     H3C S7500E  Switch Series ACL and QoS Configuration Guide-R7536P05
·     H3C S7500E Switch Series ACL and QoS Command Reference-R7536P05
