06-IP Multicast Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7536P05-6W10006-IP Multicast Configuration Examples
02-H3C_IGMP_Snooping_Configuration_Examples
02-H3C_IGMP_Snooping_Configuration_Examples 143.17 KB
H3C IGMP Snooping Configuration Examples
H3C_彩色.emf
Introduction
This document introduces IGMP snooping configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of IGMP snooping.
Example: Configuring multicast group policies
As shown in Figure 1:
·     Router A runs IGMP and acts as the IGMP querier.
·     Switch A runs IGMP snooping.
Configure multicast group policies on Switch A to meet the following requirements:
·     Host A receives only the multicast data addressed to multicast group 224.1.1.1.
·     Host B and Host C receive only the multicast data addressed to multicast group 225.1.1.1.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     IGMPv2 snooping cannot process IGMPv3 messages. It floods IGMPv3 messages in the VLAN to which the IGMPv3 messages belong. To avoid this problem, specify IGMP snooping version 3 for VLAN 100.
·     To prevent hosts in VLAN 100 from receiving multicast data addressed to other groups, enable dropping unknown multicast data in VLAN 100.
·     To configure a multicast group policy, specify a basic ACL and create ACL rules to define the groups that you want the hosts to join.
Software versions used
This configuration example was created and verified on S7500E-CMW710-R7536P05.
When you configure multicast group polices, follow these restrictions and guidelines:
·     You must globally enable IGMP snooping in system view before you enable IGMP snooping for a VLAN in VLAN view.
·     You can configure multicast group policies for all ports in IGMP-snooping view or for the current port in interface view. The configuration made in interface view takes priority over the configuration made in IGMP-snooping view.
Procedures
1.     Assign an IP address and subnet mask to each interface on the routers in the PIM-DM domain. (Details not shown.)
2.     Configure a unicast routing protocol on the routers in the PIM-DM domain. (Details not shown.)
3.     Enable multicast routing globally on the routers in the PIM-DM domain. (Details not shown.)
4.     Enable PIM-DM for the interfaces that connect the routers in the PIM-DM domain. (Details not shown.)
5.     Configure Router A:
# Enable IP multicast routing globally.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable IGMPv3 on Ten-GigabitEthernet 3/0/1.
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] igmp enable
[RouterA-Ten-GigabitEthernet3/0/1] igmp version 3
[RouterA-Ten-GigabitEthernet3/0/1] quit
6.     Configure Switch A:
# Enable IGMP snooping globally.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Create VLAN 100, and assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/4 to VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] port ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/4
# Enable IGMPv3 snooping and enable dropping unknown multicast data for VLAN 100.
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] igmp-snooping version 3
[SwitchA-vlan100] igmp-snooping drop-unknown
[SwitchA-vlan100] quit
# Configure a multicast group policy for VLAN 100 on Ten-GigabitEthernet 3/0/2 so that Host A can join only multicast group 224.1.1.1.
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 224.1.1.1 0
[SwitchA] interface ten-gigabitethernet 3/0/2
[SwitchA-Ten-GigabitEthernet3/0/2] igmp-snooping group-policy 2000 vlan 100
[SwitchA-Ten-GigabitEthernet3/0/2] quit
# Configure a multicast group policy globally for VLAN 100 so that Host B and Host C can join only multicast group 225.1.1.1.
[SwitchA] acl basic 2001
[SwitchA-acl-ipv4-basic-2001] rule permit source 225.1.1.1 0
[SwitchA-acl-ipv4-basic-2001] quit
[SwitchA-igmp-snooping] group-policy 2001 vlan 100
# Send IGMP reports from Host A, Host B, and Host C to join multicast groups 224.1.1.1, 224.2.2.2, and 225.1.1.1. (Details not shown.)
# Send multicast data from the source to the three groups. (Details not shown.)
# Display dynamic IGMP snooping forwarding entries for VLAN 100 on Switch A.
[SwitchA] display igmp-snooping group vlan 100
Total 2 entries.
VLAN 100: Total 2 entries.
  (0.0.0.0, 224.1.1.1)
    Host slots (1 in total):
      3
    Host ports (1 in total):
      XGE3/0/2
  (0.0.0.0, 225.1.1.1)
      3
    Host ports (2 in total):
      XGE3/0/3
      XGE3/0/4
·     Host A has joined multicast group 224.1.1.1 through Ten-GigabitEthernet 3/0/2, and it does not join multicast groups 224.2.2.2 and 225.1.1.1.
·     Host B and Host C have joined multicast group 225.1.1.1 through Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4, respectively. They do not join multicast groups 224.1.1.1 and 224.2.2.2.
Multicast group policies have taken effect.
Configuration files
·     Router A:
interface Ten-GigabitEthernet3/0/1
 port link-mode route
 igmp enable
 igmp version 3
multicast routing
·     Switch A:
igmp-snooping
vlan 100
 port link-mode bridge
 port access vlan 100
interface Ten-GigabitEthernet3/0/2
interface Ten-GigabitEthernet3/0/3
interface Ten-GigabitEthernet3/0/4
acl basic 2000
 rule 0 permit source 224.1.1.1 0
acl basic 2001
 rule 0 permit source 225.1.1.1 0
Example: Configuring static ports
As shown in Figure 2:
·     All switches in VLAN 100 run IGMP snooping.
·     Router A runs IGMPv2 and acts as the IGMP querier.
·     STP runs in VLAN 100. The path of Switch A—Switch B is blocked to avoid loops.
Configure IGMP snooping static ports to meet the following requirements:
·     Multicast data uninterruptedly flows to the receiver hosts after a link switchover occurs between Switch A and Switch B.
·     Host A, Host B, and Host C permanently receive the multicast data addressed to multicast group 224.1.1.1.
Figure 2 Network diagram
Analysis
·     By default, when a link switchover occurs, multicast data can flow along the new link after a minimum of one IGMP query-response cycle. Multicast delivery is interrupted during this process.
Configure Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 on Switch A, Ten-GigabitEthernet 3/0/4 on Switch B, and Ten-GigabitEthernet 3/0/2 on Switch C as static router ports. Then, multicast data will be forwarded to these ports.
·     Configure Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 on Switch B, and Ten-GigabitEthernet 3/0/3 on Switch C as static member ports of multicast group 224.1.1.1. Then, multicast data for the group will always be forwarded out of these ports, and Host A, Host B, and Host C can always receive the data.
Procedures
2.     Configure OSPF on the routers in the PIM-DM domain. (Details not shown.)
# Enable IP multicast routing.
[RouterA-mrib] quit
# Enable IGMP on Ten-GigabitEthernet 3/0/1.
# Create VLAN 100, assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/3 to this VLAN, and enable IGMP snooping for this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
# Configure Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 as static router ports.
[SwitchA-Ten-GigabitEthernet3/0/2] igmp-snooping static-router-port vlan 100
[SwitchA] interface Ten-GigabitEthernet 3/0/3
[SwitchA-Ten-GigabitEthernet3/0/3] igmp-snooping static-router-port vlan 100
[SwitchA-Ten-GigabitEthernet3/0/3] quit
7.     Configure Switch B:
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
# Create VLAN 100, assign Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/4 to this VLAN, and enable IGMP snooping for this VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/4
[SwitchB-vlan100] igmp-snooping enable
[SwitchB-vlan100] quit
# Configure Ten-GigabitEthernet 3/0/4 as a static router port.
[SwitchB] interface ten-gigabitethernet 3/0/4
[SwitchB-Ten-GigabitEthernet3/0/4] igmp-snooping static-router-port vlan 100
[SwitchB-Ten-GigabitEthernet3/0/4] quit
# Configure Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 as static member ports for multicast group 224.1.1.1 in VLAN 100.
[SwitchB] interface ten-gigabitethernet 3/0/2
[SwitchB-Ten-GigabitEthernet3/0/2] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchB-Ten-GigabitEthernet3/0/2] quit
[SwitchB] interface ten-gigabitethernet 3/0/3
[SwitchB-Ten-GigabitEthernet3/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchB-Ten-GigabitEthernet3/0/3] quit
8.     Configure Switch C:
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
# Create VLAN 100, assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/4 to this VLAN, and enable IGMP snooping for this VLAN.
[SwitchC] vlan 100
[SwitchC-vlan100] port ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/4
[SwitchC-vlan100] igmp-snooping enable
[SwitchC-vlan100] quit
# Configure Ten-GigabitEthernet 3/0/2 as a static router port in VLAN 100.
[SwitchC] interface ten-gigabitethernet 3/0/2
[SwitchC-Ten-GigabitEthernet3/0/2] igmp-snooping static-router-port vlan 100
[SwitchC-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet 3/0/3 as a static member port of multicast group 224.1.1.1 in VLAN 100.
[SwitchC] interface ten-gigabitethernet 3/0/3
[SwitchC-Ten-GigabitEthernet3/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchC-Ten-GigabitEthernet3/0/3] quit
# Display static router port information for VLAN 100 on Switch A.
[SwitchA] display igmp-snooping static-router-port vlan 100
VLAN 100:
  Router slots (1 in total):
    3
  Router ports (2 in total):
    XGE3/0/2
    XGE3/0/3
The output shows that Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 on Switch A have become static router ports in VLAN 100.
# Display static router port information for VLAN 100 on Switch B.
[SwitchB] display igmp-snooping static-router-port vlan 100
VLAN 100:
    3
  Router ports (1 in total):
   XGE3/0/4
The output shows that Ten-GigabitEthernet 3/0/4 on Switch B has become a static router port in VLAN 100.
# Display static IGMP snooping forwarding entries for VLAN 100 on Switch B.
[SwitchB] display igmp-snooping static-group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
      3
      XGE3/0/2
      XGE3/0/3
The output shows that Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 on Switch B have become static member ports of multicast group 224.1.1.1 in VLAN 100.
# Display static router port information for VLAN 100 on Switch C.
[SwitchC] display igmp-snooping static-router-port vlan 100
VLAN 100:
    3
    XGE3/0/2
The output shows that Ten-GigabitEthernet 3/0/2 on Switch C has become a static router port in VLAN 100.
# Display static IGMP snooping forwarding entries for VLAN 100 on Switch C.
[SwitchC] display igmp-snooping static-group vlan 100
Total 1 entries.
      3
      XGE3/0/3
The output shows that Ten-GigabitEthernet 3/0/3 on Switch C has become a static group member of multicast group 224.1.1.1.
Configuration files
·     Router A:
 igmp enable
 igmp version 3
multicast routing
·     Switch A:
igmp-snooping
vlan 100
·     Switch B:
igmp-snooping
vlan 100
·     Switch C:
igmp-snooping
vlan 100
Related documentation
·     H3C S7500E Switch Series IP Multicast Command Reference-R7536P05
·     H3C S7500E Switch Series IP Multicast Configuration Guide-R7536P05
