11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesH3C S7500E-X Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-X Switch Series Configuration Examples-Release7536P05-6W10011-Network Management and Monitoring Configuration Examples
02-H3C_NTP_Configuration_Examples
02-H3C_NTP_Configuration_Examples 228.07 KB
H3C NTP Configuration Examples
H3C_彩色.emf
Introduction· 1
Prerequisites· 1
Example: Configuring the NTP client/server mode· 1
Network configuration· 1
Software versions used· 1
Procedures· 1
Configuring Switch A· 1
Configuring Switch B· 2
Configuring Switch C· 2
Verifying the configuration· 2
Configuration files· 3
Example: Configuring the NTP broadcast mode· 3
Network configuration· 3
Software versions used· 4
Procedures· 4
Configuring Switch C· 4
Configuring Switch A, Switch B, Switch D, and Switch E· 4
Verifying the configuration· 5
Configuration files· 5
Example: Configuring the NTP multicast mode· 6
Network configuration· 6
Software versions used· 7
Procedures· 7
Configuring Switch C· 7
Configuring Switch D·· 7
Configuring Switch B· 7
Configuring Switch A· 8
Verifying the configuration· 8
Configuration files· 9
Example: Configuring NTP client/server mode with authentication· 10
Network configuration· 10
Software versions used· 10
Procedures· 10
Configuring Switch A· 10
Configuring Switch B· 11
Configuring Switch C· 11
Verifying the configuration· 11
Configuration files· 12
Example: Configuring SNTP· 13
Network configuration· 13
Software versions used· 13
Procedures· 13
Configuring Switch A· 13
Configuring Switch B· 14
Configuring Switch C· 14
Verifying the configuration· 14
Configuration files· 14
Example: Configuring the IPv6 NTP client/server mode· 15
Network configuration· 15
Software versions used· 15
Procedures· 15
Configuring Switch A· 15
Configuring Switch B· 16
Configuring Switch C· 16
Verifying the configuration· 16
Configuration files· 17
Example: Configuring the IPv6 NTP multicast mode· 17
Network configuration· 17
Software versions used· 18
Procedures· 18
Configuring Switch C· 18
Configuring Switch D·· 18
Configuring Switch B· 19
Configuring Switch A· 19
Verifying the configuration· 20
Configuration files· 20
Example: Configuring the NTP broadcast mode with authentication· 21
Network configuration· 21
Software versions used· 22
Procedures· 22
Configure Switch C· 22
Configure Switch A, Switch B, Switch D, and Switch E· 22
Verifying the configuration· 22
Configuration files· 23
Related documentation· 24
Introduction
This document provides NTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of NTP.
As shown in Figure 1, configure the NTP client/server mode so all devices can be synchronized to Switch A, the NTP server.
Figure 1 Network diagram
This configuration example was created and verified on S7500E-X-CMW710-R7536P05.
Procedures
# Assign an IP address to VLAN-interface 2.
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] ip address 1.0.1.11 24
# Enable the NTP service.
[SwitchA] ntp-service enable
# Specify the local clock as the reference source, with the stratum level 2.
[SwitchA] ntp-service refclock-master 2
# Assign an IP address to VLAN-interface 2. (Details not shown.)
[SwitchB] ntp-service enable
# Specify Switch A as the NTP server of Switch B so that Switch B is synchronized to Switch A.
[SwitchB] ntp-service unicast-server 1.0.1.11
[SwitchC] ntp-service enable
# Specify Switch A as the NTP server of Switch C so that Switch C is synchronized to Switch A.
[SwitchC] ntp-service unicast-server 1.0.1.11
# Verify that Switch B has synchronized to Switch A, and the clock stratum level is 3 on Switch B and 2 on Switch A.
[SwitchB] display ntp-service status
 Clock status: synchronized
 Clock stratum: 3
 System peer: 1.0.1.11
 Local mode: client
 Reference clock ID: 1.0.1.11
 Leap indicator: 00
 Clock jitter: 0.003479 s
 Stability: 0.000 pps
 Clock precision: 2^-15
 Root delay: 1.95313 ms
 Root dispersion: 28.38135 ms
 Reference time: d5ed8cd5.577006ea  Wed, Sep 25 2013 16:24:53.341
# Verify that an IPv4 NTP association has been established between Switch B and Switch A.
[SwitchB] display ntp-service sessions
        source          reference       stra reach poll  now offset  delay disper
[12345]1.0.1.11        127.127.1.0        2   255   64   38 -10.22 1.9531 3.3416
 Total sessions: 1
Configuration files
·     Switch A:
interface Vlan-interface2
 ip address 1.0.1.11 255.255.255.0
 ntp-service enable
·     Switch B:
 ip address 1.0.1.12 255.255.255.0
 ntp-service enable
·     Switch C:
 ip address 1.0.1.13 255.255.255.0
 ntp-service enable
As shown in Figure 2, configure the NTP broadcast mode so all devices on the same network segment can be synchronized to Switch C, the NTP server.
Figure 2 Network diagram
Procedures
[SwitchC] ntp-service refclock-master 2
[SwitchC] interface Vlan-interface 2
[SwitchC-Vlan-interface2] ip address 3.0.1.31 24
# Configure Switch C to operate in broadcast server mode and send broadcast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service broadcast-server
The configuration procedure is the same for Switch A, Switch B, Switch D, and Switch E. The following procedure uses Switch A as an example.
# Enable the NTP service on Switch A.
# Configure Switch A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ntp-service broadcast-client
# Verify that Switch A has synchronized to Switch C, and the clock stratum level is 3 on Switch A and 2 on Switch C.
[SwitchA-Vlan-interface2] display ntp-service status
 Clock stratum: 3
 System peer: 3.0.1.31
 Local mode: bclient
 Reference clock ID: 3.0.1.31
 Leap indicator: 00
 Clock jitter: 0.000061 s
 Clock precision: 2^-14
 Root delay: 0.00000 ms
 Root dispersion: 7951.43127 ms
 Reference time: d5ee8d88.2faabed0  Thu, Sep 26 2013 10:40:08.186
# Verify that an IPv4 NTP association has been established between Switch A and Switch C.
[SwitchA-Vlan-interface2] display ntp-service sessions
 [1234]3.0.1.31        127.127.1.0        2   254   64   82 -2.190 0.0000 7937.5
 Total sessions: 1
Configuration files
·     Switch C:
 ip address 3.0.1.31 255.255.255.0
 ntp-service enable
·     Switch A:
 ip address 3.0.1.33 255.255.255.0
 ntp-service enable
·     Switch B:
 ip address 3.0.1.30 255.255.255.0
 ntp-service enable
·     Switch D:
 ip address 3.0.1.32 255.255.255.0
 ntp-service enable
·     Switch E:
 ip address 3.0.1.34 255.255.255.0
 ntp-service enable
As shown in Figure 3, configure the NTP multicast mode so all devices on different network segments can be synchronized to Switch C, the NTP server.
Figure 3 Network diagram
Procedures
# Configure Switch C to operate in multicast server mode and send multicast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service multicast-server
<SwitchD> system-view
[SwitchD] ntp-service enable
[SwitchD] interface Vlan-interface 2
[SwitchD-Vlan-interface2] ip address 3.0.1.32 24
# Configure Switch D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD-Vlan-interface2] ntp-service multicast-client
# Configure Switch B to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service multicast-client
Because Switch A and Switch C are on different subnets, you must enable the multicast functions on Switch B before Switch A can receive multicast messages from Switch C.
# Enable IP multicast routing and IGMP.
[SwitchB] multicast routing
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port Ten-GigabitEthernet 1/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] ip address 1.0.1.10 24
[SwitchB-Vlan-interface3] igmp enable
[SwitchB-Vlan-interface3] igmp static-group 224.0.1.1
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] interface Ten-GigabitEthernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
# Assign an IP address to VLAN-interface 3.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] ip address 1.0.1.11 24
# Configure Switch A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service multicast-client
[SwitchA-Vlan-interface3] display ntp-service status
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 Root delay: 1.69373 ms
 Root dispersion: 1950.18005 ms
 Reference time: d5ee9b15.2f3a684d  Thu, Sep 26 2013 11:37:57.184
Configuration files
·     Switch A:
 ntp-service enable
interface Vlan-interface3
·     Switch B:
ntp-service enable
multicast routing
igmp-snooping
 pim dm
 ip address 1.0.1.10 255.255.255.0
 igmp enable
 port access vlan 3
·     Switch C:
 ntp-service enable
·     Switch D:
 ntp-service enable
As shown in Figure 4, configure the NTP client/server mode so all devices can be synchronized to Switch A, the NTP server. Configure NTP authentication on Switch A, Switch B, and Switch C.
Figure 4 Network diagram
Procedures
# Enable NTP authentication on Switch A.
[SwitchA] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[SwitchA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[SwitchA] ntp-service reliable authentication-keyid 42
# Enable NTP authentication on Switch B.
[SwitchB] ntp-service authentication enable
[SwitchB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[SwitchB] ntp-service reliable authentication-keyid 42
# Specify Switch A as the NTP server of Switch B, and associate the server with key 42.
[SwitchB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
# Enable NTP authentication on Switch C.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[SwitchC] ntp-service reliable authentication-keyid 42
# Specify Switch A as the NTP server of Switch C, and associate the server with key 42.
[SwitchC] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
 Clock stratum: 3
 Local mode: client
 Leap indicator: 00
 Clock jitter: 0.005096 s
 Clock precision: 2^-10
 Root delay: 0.00655 ms
 Root dispersion: 1.15869 ms
 Reference time: d0c62687.ab1bba7d  Mon, Sep 30 2013 16:06:26.764
 [1245]1.0.1.11        127.127.1.0        2     1   64  519   -0.0 0.0065    0.0
 Total sessions : 1
Configuration files
·     Switch A:
 ntp-service enable
 ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$4j3SKCgQWBK3Un41B9U0JXzJX9i7IuNoSqi
·     Switch B:
 ntp-service enable
 ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$22eIc8l796cpudZqiaAZ2SLzIfrgzFTVYn8X
·     Switch C:
 ntp-service enable
 ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$XJzVmJ1TJbWyYAXpPXxF7JiEOZag8CehibM8
As shown in Figure 5, configure SNTP so all devices can be synchronized to Switch A, the NTP server.
Figure 5 Network diagram
Procedures
# Enable the SNTP service.
[SwitchB] sntp enable
# Specify Switch A as the NTP server for Switch B.
[SwitchB] sntp unicast-server 1.0.1.11
[SwitchC] sntp enable
# Specify Switch A as the NTP server for Switch C.
[SwitchC] sntp unicast-server 1.0.1.11
# Verify that an SNTP association has been established between Switch B and Switch A, and Switch B has synchronized to Switch A.
[SwitchB] display sntp sessions
SNTP server     Stratum   Version    Last receive time
1.0.1.11        2         4          Thu, Sep 26 2013 17:25:09.121 (Synced)
Configuration files
·     Switch A:
 ntp-service enable
·     Switch B:
 sntp enable
·     Switch C:
 sntp enable
As shown in Figure 1, configure the IPv6 NTP client/server mode so all devices can synchronize to Switch A, the NTP server.
Figure 6 Network diagram
Procedures
# Assign an IPv6 address to VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 3000::34 64
# Assign an IPv6 address to VLAN-interface 2. (Details not shown.)
[SwitchB] ntp-service unicast-server 3000::34
[SwitchC] ntp-service unicast-server 3000::34
The following example uses Switch B to describe configuration verification.
 Clock stratum: 3
 System peer: 3000::34
 Local mode: client
 Reference clock ID: 95.197.17.40
 Leap indicator: 00
# Verify that an IPv6 NTP association has been established between Switch B and Switch A.
[SwitchB] display ntp-service ipv6 sessions
 Source: [12345] 3000::34
 Reference: 127.127.1.0           Clock stratum: 2
 Reachabilities: 3                Poll interval: 64
 Last receive time: 62            Offset: 0.1272
 Roundtrip delay: 1.8158          Dispersion: 188.47
 Total sessions: 1
Configuration files
·     Switch A:
 ipv6 address 3000::34/64
 ntp-service enable
·     Switch B:
 ipv6 address 3000::35/64
 ntp-service enable
 ntp-service ipv6 unicast-server 3000::34
·     Switch C:
 ipv6 address 3000::36/64
 ntp-service enable
As shown in Figure 3, configure the IPv6 NTP multicast mode so all devices on different network segments can synchronize to Switch C, the NTP server.
Figure 7 Network diagram
Procedures
Configure routing protocols so that all devices can reach each other. (Details not shown.)
[SwitchC-Vlan-interface2] ipv6 address 3000::2 64
# Configure Switch C to operate in IPv6 multicast server mode and send multicast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service ipv6 multicast-server ff24::1
# Configure Switch D to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
[SwitchD-Vlan-interface2] quit
# Assign an IP address to VLAN-interface 2 and VLAN-interface 3. (Details not shown.)
# Configure Switch B to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
Because Switch A and Switch C are on different subnets, you must enable IPv6 multicast functions on Switch B before Switch A can receive multicast messages from Switch C.
# Enable IPv6 multicast functions.
[SwitchB] ipv6 multicast routing
[SwitchB-mrib6] quit
[SwitchB-Vlan-interface2] ipv6 pim dm
[SwitchB] vlan 3
[SwitchB-Vlan-interface3] mld enable
[SwitchB-Vlan-interface3] mld static-group ff24::1
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
[SwitchB-Ten-GigabitEthernet1/0/1] mld-snooping static-group ff24::1 vlan 3
# Assign an IP address to VLAN-interface 3. (Details not shown.)
# Configure Switch A to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service ipv6 multicast-client ff24::1
[SwitchA-Vlan-interface3] quit
The following example uses Switch A to describe configuration verification.
[SwitchA] display ntp-service status
 Clock stratum: 3
 System peer: 3000::2
 Local mode: bclient
 Reference clock ID: 165.84.121.65
 Leap indicator: 00
Configuration files
·     Switch A:
 ntp-service enable
 ipv6 address 2000::1/64
·     Switch B:
ntp-service enable
mld-snooping
 ipv6 address 3000::1/64
 ipv6 pim dm
 ipv6 address 2000::2/64
 mld enable
 port access vlan 3
·     Switch C:
 ntp-service enable
 ipv6 address 3000::2/64
·     Switch D:
 ntp-service enable
 ipv6 address 3000::3/64
As shown in Figure 4, configure NTP broadcast mode so all devices can synchronize to Switch C, the NTP server. Configure NTP authentication on Switch A, Switch B, and Switch C.
Figure 8 Network diagram
Procedures
Configure Switch C
# Specify the local clock as the reference source, with the stratum level 2 on Switch C.
# Enable NTP authentication on Switch C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Specify the key as a trusted key.
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and associate key 88 with Switch C.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
# Enable NTP authentication on Switch A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Specify the key as a trusted key.
[SwitchA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchA] ntp-service reliable authentication-keyid 88
# Configure Switch A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ip address 3.0.1.33 24
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 Clock jitter: 0.000092 s
 Root delay: 2.42615 ms
 Root dispersion: 1950.98877 ms
 Reference time: d5eed631.2f498d71  Thu, Sep 26 2013 15:50:09.184
Configuration files
·     Switch A, Switch B, Switch D, and Switch E:
 ntp-service enable
 ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$pU6KvpS80MadhM2zM
CCSR07HX4qEbJhHvQ==
·     Switch C:
 ntp-service enable
 ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$iJudDKiqCVO+gOaG53
63/fz4M3dQvHo2Fw==
 ntp-service refclock-master 3
·     H3C S7500E-X Switch Series Network Management and Monitoring Configuration Guide-R7536P05
·     H3C S7500E-X Switch Series Network Management and Monitoring Command Reference-R7536P05
