01-H3C_IRF_Configuration_Examples | 321.32 KB |
H3C IRF Configuration Examples
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
General restrictions and guidelines
Example: Setting up a LACP MAD-enabled two-chassis IRF fabric
Verifying the link backup function of multichassis aggregations
Verifying the link backup function of IRF connections
Example: Setting up a LACP MAD-enabled four-chassis IRF fabric
Example: Upgrading a two-chassis IRF fabric to a four-chassis IRF fabric (BFD MAD)
Adding two chassis to a two-chassis IRF fabric
Merging two two-chassis IRF fabrics
Introduction
This document provides examples for deploying two-chassis IRF fabrics and four-chassis IRF fabrics.
This document assumes that you have basic knowledge of H3C IRF.
When you set up and configure an IRF fabric, follow these restrictions and guidelines:
Item |
Restrictions and guidelines |
Hardware |
An H3C S7500E-X switch can form an IRF fabric only with devices in the same series. |
Fabric size |
An H3C S7500E-X IRF fabric supports a maximum of four chassis. |
IRF port binding restrictions |
Candidate IRF physical interfaces: · 10-GE ports. · 40-GE ports. · 100-GE fiber ports. Port grouping rules on interface modules: · The 10-GE ports on all SF and EC interface modules except LSQM2TGS16SF0 and LSQM2TGS16SF0 are grouped by port number in order, starting from 1. Each group contains four ports. · The 10-GE ports on the LSQM2TGS16SF0 and LSQM2TGS16SF0 interface module are divided into the following groups: ? Ports 1, 2, 15, and 16. ? Ports 3 through 5. ? Ports 6 through 8. ? Ports 9 through 11. ? Ports 12 through 14. · The breakout interfaces of a 40-GE port are in a group. Restrictions on grouped 10-GE ports: · You must use all or none of the ports for IRF links. The ports can be bound to different IRF ports. · Before you bind one 10-GE port to an IRF port or remove it from the IRF port, you must shut down all the ports in the group. If any of the ports are in up state, the bind or remove action will fail. · Bring up the ports after you complete the operations. Restrictions on 40-GE ports: · You can use a 40-GE port for IRF links, or use the 10-GE breakout interfaces of a 40-GE port for IRF links. To split a 40-GE port, use the using tengige command. · When you use the 10-GE breakout interfaces of a 40-GE port for IRF links, follow these restrictions and guidelines: ? You must use all or none of the four 10-GE breakout interfaces for IRF links. The four breakout interfaces can be bound to different IRF ports. ? Before you bind one 10-GE breakout interface to an IRF port or remove it from the IRF port, you must shut down all the 10-GE breakout interfaces. If any of the breakout interfaces are in up state, the bind or remove action will fail. ? Bring up the breakout interfaces after you complete the operations. · Port split and combination (the using fortygige command) require a card reboot. As a best practice to avoid topology change, complete the port split or combination operations before you add the device to an IRF fabric. When you perform these operations on an IRF fabric, make sure you understand the impact on the IRF fabric topology. |
Connection |
For two neighboring IRF members, you must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other. When you bind physical interfaces to IRF ports, you must make sure the bindings are consistent with the physical connections. |
MAD |
· The switch supports LACP MAD, BFD MAD, ARP MAD, and ND MAD. · Configure a minimum of one MAD mechanism for the IRF fabric. ? Do not configure LACP MAD together with ARP MAD or ND MAD, because they handle collisions differently. ? Do not configure BFD MAD together with ARP MAD or ND MAD. BFD MAD is mutually exclusive with the spanning tree feature, but ARP MAD and ND MAD require the spanning tree feature. At the same time, BFD MAD handles collisions differently than ARP MAD and ND MAD. |
Software version and feature configuration |
The following settings must be the same across all chassis: · Software version. · Setting for the system-working-mode command. · Setting for the maximum number of ECMP routes. |
Bridge MAC requirements |
When you merge two IRF fabrics, you must make sure their IRF bridge MAC addresses are unique. |
Licensing |
Licenses installed for each feature are the same across all member chassis. |
As shown in Figure 1:
· Set up a two-chassis IRF fabric at the core layer of the network.
· Use multichassis link aggregations to connect the IRF fabric to the access switches and the upstream egress routers.
· Use LACP MAD to detect IRF split.
· Run OSPF between the IRF fabric and the egress routers.
Figure 1 LACP MAD-enabled two-chassis IRF fabric
Table 1 VLAN and IP address assignment
Device |
VLAN interface |
IP address |
Router A |
VLAN-interface 30 |
172.24.2.2/24 |
Router A |
VLAN-interface 40 |
172.24.40.2/24 |
Router A |
VLAN-interface 50 |
172.24.1.2/24 |
Router B |
VLAN-interface 30 |
172.24.2.3/24 |
Router B |
VLAN-interface 41 |
172.24.41.3/24 |
Router B |
VLAN-interface 50 |
172.24.4.2/24 |
IRF fabric |
VLAN-interface 10 |
172.24.10.254/24 |
IRF fabric |
VLAN-interface 20 |
172.24.20.254/24 |
IRF fabric |
VLAN-interface 40 |
172.24.40.254/24 |
IRF fabric |
VLAN-interface 41 |
172.24.41.254/24 |
Analysis
For LACP MAD to run correctly, ensure that the intermediate device supports extended LACPDUs for LACP MAD.
To avoid single points of failure, use multichassis link aggregations to connect the IRF fabric to the downstream and upstream devices.
You do not need to run LACP MAD on all link aggregations. You can detect IRF split effectively by running LACP MAD on one dynamic link aggregation.
Software versions used
This configuration example was created and verified on S7500E-X-CMW710-R7536P05.
When you configure LACP MAD on a link aggregation, follow these restrictions and guidelines:
· The link aggregation must use dynamic aggregation mode.
· The link aggregation must have a minimum of one member link from each member chassis.
· If the intermediate device is also an IRF fabric, you must assign the two IRF fabrics different domain IDs for correct split detection.
Procedures
Setting up the IRF fabric
1. Configure Device A:
# Assign member ID 1 to Device A.
[DeviceA] irf member 1
# Bind Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to IRF-port 2.
[DeviceA] irf-port 2
[DeviceA-irf-port2] port group interface ten-gigabitethernet 3/0/1
[DeviceA-irf-port2] port group interface ten-gigabitethernet 3/0/2
[DeviceA-irf-port2] quit
# Save the running configuration to the main next-startup configuration file before changing the operating mode to IRF.
IMPORTANT: The mode change requires a system reboot, which causes all unsaved settings to be lost. |
[DeviceA] save
# Enable IRF mode.
[DeviceA] chassis convert mode irf
The device will switch to IRF mode and reboot.
You are recommended to save the current running configuration and specify the co
nfiguration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file cfa0:/
irf.cfg to make it available in stack mode? [Y/N]:y
Now rebooting, please wait...
2. Configure Device B:
# Assign member ID 2 to Device B.
[DeviceB] irf member 2
# Bind Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to IRF-port 1.
[DeviceB] irf-port 1
[DeviceB-irf-port1] port group interface ten-gigabitethernet 3/0/1
[DeviceB-irf-port1] port group interface ten-gigabitethernet 3/0/2
[DeviceB-irf-port1] quit
# Save the configuration.
[DeviceB] save
# Connect IRF-port 2 on Device A to IRF-port 1 on Device B, as shown in Figure 1.
# Enable IRF mode.
[DeviceB] chassis convert mode irf
Configuring software features
This example provides only basic software feature configuration.
Configuring the IRF fabric
After the IRF fabric is formed, the master's system name becomes the fabric's system name. You can configure software features on the fabric as you do on a standalone device.
1. Configure link aggregations:
# Create a Layer 2 dynamic aggregate interface Bridge-Aggregation 1. Enable LACP MAD on the aggregate interface.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 0]:
The assigned domain ID is: 0
MAD LACP only enable on dynamic aggregation interface.
[DeviceA-Bridge-Aggregation1] quit
# Assign the downlink ports that connect to SW 1 to the aggregation group of Bridge-Aggregation 1.
[DeviceA] interface ten-gigabitethernet 1/3/0/3
[DeviceA-Ten-GigabitEthernet1/3/0/3] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet1/3/0/3] quit
[DeviceA] interface ten-gigabitethernet 2/3/0/3
[DeviceA-Ten-GigabitEthernet2/3/0/3] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet2/3/0/3] quit
# Create Bridge-Aggregation 2. Assign the downlink ports that connect to SW 2 to the aggregation group.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] quit
[DeviceA] interface ten-gigabitethernet 1/3/0/4
[DeviceA-Ten-GigabitEthernet1/3/0/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/3/0/4] quit
[DeviceA] interface ten-gigabitethernet 2/3/0/4
[DeviceA-Ten-GigabitEthernet2/3/0/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet2/3/0/4] quit
# Create Bridge-Aggregation 1023. Assign the uplink ports that connect to Router A to Bridge-Aggregation 1023.
[DeviceA] interface bridge-aggregation 1023
[DeviceA-Bridge-Aggregation1023] quit
[DeviceA] interface ten-gigabitethernet 1/3/0/7
[DeviceA-Ten-GigabitEthernet1/3/0/7] port link-aggregation group 1023
[DeviceA-Ten-GigabitEthernet1/3/0/7] quit
[DeviceA] interface ten-gigabitethernet 2/3/0/7
[DeviceA-Ten-GigabitEthernet2/3/0/7] port link-aggregation group 1023
[DeviceA-Ten-GigabitEthernet2/3/0/7] quit
# Create Bridge-Aggregation 1024. Assign the uplink ports that connect to Router B to Bridge-Aggregation 1024.
[DeviceA] interface bridge-aggregation 1024
[DeviceA-Bridge-Aggregation1024] quit
[DeviceA] interface ten-gigabitethernet 1/3/0/8
[DeviceA-Ten-GigabitEthernet1/3/0/8] port link-aggregation group 1024
[DeviceA-Ten-GigabitEthernet1/3/0/8] quit
[DeviceA] interface ten-gigabitethernet 2/3/0/8
[DeviceA-Ten-GigabitEthernet2/3/0/8] port link-aggregation group 1024
[DeviceA-Ten-GigabitEthernet2/3/0/8] quit
2. Configure VLANs, ports, and IP addresses:
# Create VLAN 10, assign an IP address to VLAN-interface 10, and assign Bridge-Aggregation 1 to VLAN 10.
[DeviceA]vlan 10
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 172.24.10.254 24
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] undo port trunk permit vlan 1
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10
# Create VLAN 20, assign an IP address to VLAN-interface 20, and assign Bridge-Aggregation 2 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ip address 172.24.20.254 24
[DeviceA-Vlan-interface20] quit
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] undo port trunk permit vlan 1
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
# Create VLAN 40, assign an IP address to VLAN-interface 40, and assign Bridge-Aggregation 1023 to VLAN 40.
[DeviceA] vlan 40
[DeviceA-vlan40] quit
[DeviceA] interface vlan-interface 40
[DeviceA-Vlan-interface40] ip address 172.24.40.254 24
[DeviceA-Vlan-interface40] quit
[DeviceA-Bridge-Aggregation1023] port access vlan 40
# Create VLAN 41, assign an IP address to VLAN-interface 41, and assign Bridge-Aggregation 1024 to VLAN 41.
[DeviceA] vlan 41
[DeviceA-vlan41] quit
[DeviceA] interface vlan-interface 41
[DeviceA-Vlan-interface41] ip address 172.24.41.254 24
[DeviceA-Vlan-interface41] quit
[DeviceA-Bridge-Aggregation1024] port access vlan 41
3. Configure OSPF between the IRF fabric and the egress routers.
[DeviceA] ospf
[DeviceA-ospf-1] import-route direct
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 172.24.40.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 172.24.41.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
Configuring SW 1
1. Configure a link aggregation:
# Create Bridge-Aggregation 1 and enable the dynamic aggregation mode. You must enable the dynamic aggregation mode because this link aggregation will be used for LACP MAD.
<SW1> system-view
[SW1] interface bridge-aggregation 1
[SW1-Bridge-Aggregation1] link-aggregation mode dynamic
[SW1-Bridge-Aggregation1] quit
# Assign the uplink ports that connect to the IRF fabric to Bridge-Aggregation 1.
[SW1] interface ten-gigabitethernet 4/0/1
[SW1-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[SW1-Ten-GigabitEthernet4/0/1] quit
[SW1] interface ten-gigabitethernet 4/0/2
[SW1-Ten-GigabitEthernet4/0/2] port link-aggregation group 1
[SW1-Ten-GigabitEthernet4/0/2] quit
# Create all VLANs.
[SW1] vlan all
# Configure VLAN settings on the uplink aggregate interface that connects to the IRF fabric.
[SW1-Bridge-Aggregation1] port link-type trunk
[SW1-Bridge-Aggregation1] undo port trunk permit vlan 1
[SW1-Bridge-Aggregation1] port trunk permit vlan 10
# Configure VLAN settings on the port that connects to Server Group 1.
[SW1] interface gigabitethernet 3/0/1
[SW1-GigabitEthernet3/0/1] port link-type trunk
[SW1-GigabitEthernet3/0/1] port trunk permit vlan all
[SW1-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SW1-GigabitEthernet3/0/1] quit
Configuring SW 2
# Create Bridge-Aggregation 1.
<SW2>system-view
[SW2] interface bridge-aggregation 1
[SW2-Bridge-Aggregation1] quit
[SW2] interface ten-gigabitethernet 4/0/1
[SW2-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[SW2-Ten-GigabitEthernet4/0/1] quit
[SW2] interface ten-gigabitethernet 4/0/2
[SW2-Ten-GigabitEthernet4/0/2] port link-aggregation group 1
[SW2-Ten-GigabitEthernet4/0/2] quit
# Create all VLANs.
[SW2] vlan all
[SW2-Bridge-Aggregation1] port link-type trunk
[SW2-Bridge-Aggregation1] undo port trunk permit vlan 1
[SW2-Bridge-Aggregation1] port trunk permit vlan 20
# Configure VLAN settings on the port that connects to Server Group 2.
[SW2] interface gigabitethernet 3/0/1
[SW2-GigabitEthernet3/0/1] port link-type trunk
[SW2-GigabitEthernet3/0/1] port trunk permit vlan all
[SW2-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SW2-GigabitEthernet3/0/1] quit
Configuring Router A
In this example, the egress router configuration only includes the connection to the IRF fabric.
# Create Bridge-Aggregation 1. Assign the downlink ports that connect to the IRF fabric to Bridge-Aggregation 1.
[RouterA] interface bridge-aggregation 1
[RouterA-Bridge-Aggregation1] quit
[RouterA] interface ten-gigabitethernet 4/0/1
[RouterA-Ten-GigabitEthernet4/0/1] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[RouterA-Ten-GigabitEthernet4/0/1] quit
[RouterA] interface ten-gigabitethernet 2/0/1
[RouterA-Ten-GigabitEthernet2/0/1] port link-mode bridge
[RouterA-Ten-GigabitEthernet2/0/1] port link-aggregation group 1
[RouterA-Ten-GigabitEthernet2/0/1] quit
# Create Bridge-Aggregation 2. Assign the ports that connect to Router B to Bridge-Aggregation 2.
[RouterA] interface bridge-aggregation 2
[RouterA-Bridge-Aggregation2] quit
[RouterA] interface ten-gigabitethernet 4/0/2
[RouterA-Ten-GigabitEthernet4/0/2] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/2] port link-aggregation group 2
[RouterA-Ten-GigabitEthernet4/0/2] quit
[RouterA] interface ten-gigabitethernet 2/0/2
[RouterA-Ten-GigabitEthernet2/0/2] port link-mode bridge
[RouterA-Ten-GigabitEthernet2/0/2] port link-aggregation group 2
[RouterA-Ten-GigabitEthernet2/0/2] quit
# Create VLAN 40, assign an IP address to VLAN-interface 40, and assign Bridge-Aggregation 1 to VLAN 40.
[RouterA] vlan 40
[RouterA-vlan40] quit
[RouterA] interface vlan-interface 40
[RouterA-vlan-interface40] ip address 172.24.40.2 24
[RouterA-vlan-interface40] quit
[RouterA-Bridge-Aggregation1] port access vlan 40
# Create VLAN 30, assign an IP address to VLAN-interface 30, and assign Bridge-Aggregation 2 to VLAN 30.
[RouterA] vlan 30
[RouterA-vlan30] quit
[RouterA] interface vlan-interface 30
[RouterA-vlan-interface30] ip address 172.24.2.2 24
[RouterA-vlan-interface30] quit
[RouterA-Bridge-Aggregation2] port link-type access
[RouterA-Bridge-Aggregation2] port access vlan 30
# Create VLAN 50, assign an IP address to VLAN-interface 50, and assign Ten-GigabitEthernet 4/0/3 to VLAN 50.
[RouterA] vlan 50
[RouterA-vlan50] quit
[RouterA] interface vlan-interface 50
[RouterA-vlan-interface50] ip address 172.24.1.2 24
[RouterA-vlan-interface50] quit
[RouterA] interface ten-gigabitethernet 4/0/3
[RouterA-Ten-GigabitEthernet4/0/3] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/3] port access vlan 50
[RouterA-Ten-GigabitEthernet4/0/3] quit
3. Configure OSPF between Router A and the IRF fabric.
[RouterA] ospf
[RouterA-ospf-1] import-route direct
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 172.24.40.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 172.24.2.0 0.0.0.255
[RouterA-ospf-1] quit
Configuring Router B
<RouterB> system-view
[RouterB] interface bridge-aggregation 1
[RouterB-Bridge-Aggregation1] quit
[RouterB] interface ten-gigabitethernet 4/0/1
[RouterB-Ten-GigabitEthernet4/0/1] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[RouterB-Ten-GigabitEthernet4/0/1] quit
[RouterB] interface ten-gigabitethernet 2/0/1
[RouterB-Ten-GigabitEthernet2/0/1] port link-mode bridge
[RouterB-Ten-GigabitEthernet2/0/1] port link-aggregation group 1
[RouterB-Ten-GigabitEthernet2/0/1] quit
# Create Bridge-Aggregation 2. Assign the ports that connect to Router A to Bridge-Aggregation 2.
[RouterB] interface bridge-aggregation 2
[RouterB-Bridge-Aggregation2] quit
[RouterB] interface ten-gigabitethernet 4/0/2
[RouterB-Ten-GigabitEthernet4/0/2] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/2] port link-aggregation group 2
[RouterB-Ten-GigabitEthernet4/0/2] quit
[RouterB] interface ten-gigabitethernet 2/0/2
[RouterB-Ten-GigabitEthernet2/0/2] port link-mode bridge
[RouterB-Ten-GigabitEthernet2/0/2] port link-aggregation group 2
[RouterB-Ten-GigabitEthernet2/0/2] quit
# Create VLAN 41, assign an IP address to VLAN-interface 41, and assign Bridge-Aggregation 1 to VLAN 41.
[RouterB] vlan 41
[RouterB-vlan41] quit
[RouterB] interface vlan-interface 41
[RouterB-vlan-interface41] ip address 172.24.41.3 24
[RouterB-vlan-interface41] quit
[RouterB-Bridge-Aggregation1] port access vlan 41
[RouterB] vlan 30
[RouterB-vlan30] quit
[RouterB] interface vlan-interface 30
[RouterB-vlan-interface30] ip address 172.24.2.3 24
[RouterB-vlan-interface30] quit
[RouterB-Bridge-Aggregation2] port link-type access
[RouterB-Bridge-Aggregation2] port access vlan 30
[RouterB] vlan 50
[RouterB-vlan50] quit
[RouterB] interface vlan-interface 50
[RouterB-vlan-interface50] ip address 172.24.4.3 24
[RouterB-vlan-interface50] quit
[RouterB] interface ten-gigabitethernet 4/0/3
[RouterB-Ten-GigabitEthernet4/0/3] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/3] port access vlan 50
[RouterB-Ten-GigabitEthernet4/0/3] quit
3. Configure OSPF between Router B and the IRF fabric.
[RouterB] ospf
[RouterB-ospf-1] import-route direct
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 172.24.41.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 172.24.2.0 0.0.0.255
[RouterB-ospf-1] quit
Verify the IRF function, multichassis link aggregation configuration, and the IRF link redundancy backup function.
Verifying the IRF function
# Execute the display irf command in any view.
[DeviceA] display irf
MemberID Slot Role Priority CPU-Mac Description
*+1 0 Master 1 0210-fc01-0000 ---
2 0 Standby 1 0210-fc02-0000 ---
The Bridge MAC of the IRF is: 3822-d60f-2800
Auto upgrade : yes
Mac persistent : always
Domain ID : 0
Auto merge : yes
The command output shows that the member chassis have formed an IRF fabric.
# Shut down Ten-GigabitEthernet 1/3/0/8, the port connected to the egress router.
[DeviceA-Ten-GigabitEthernet1/3/0/8] shutdown
# Ping an IP address on the public network from a PC in Server Group 1.
C:\Users>ping 202.108.22.5 -t
Pinging 202.108.22.5 with 32 bytes of data:
Reply from 202.108.22.5: bytes=32 time=1ms TTL=122
Reply from 202.108.22.5: bytes=32 time=13ms TTL=122
Reply from 202.108.22.5: bytes=32 time<1ms TTL=122
Request timed out.
Request timed out.
Request timed out.
The output shows that the address can be pinged after transient traffic disruption.
# Bring up Ten-GigabitEthernet 1/3/0/8 and shut down Ten-GigabitEthernet 2/3/0/8.
[DeviceA-Ten-GigabitEthernet1/3/0/8] undo shutdown
[DeviceA-Ten-GigabitEthernet2/3/0/8] shutdown
# Ping the IP address on the public network from the PC.
Request timed out.
Request timed out.
Request timed out.
Verify that the IRF fabric is integrated and can forward traffic across member chassis after one IRF connection cable is removed.
Configuration files
· IRF fabric:
irf mac-address persistent always
irf auto-update enable
irf auto-merge enable
undo irf link-delay
irf member 1 priority 1
irf member 2 priority 1
ospf 1
import-route direct
area 0.0.0.0
vlan 10
vlan 20
vlan 40
vlan 41
irf-port 1/2
port group interface Ten-GigabitEthernet1/3/0/1 mode enhanced
port group interface Ten-GigabitEthernet1/3/0/2 mode enhanced
irf-port 2/1
port group interface Ten-GigabitEthernet2/3/0/1 mode enhanced
port group interface Ten-GigabitEthernet2/3/0/2 mode enhanced
mad enable
port access vlan 40
port access vlan 41
ip address 172.24.10.254 255.255.255.0
ip address 172.24.20.254 255.255.255.0
ip address 172.24.40.254 255.255.255.0
interface Ten-GigabitEthernet 1/3/0/3
interface Ten-GigabitEthernet 1/3/0/4
interface Ten-GigabitEthernet 1/3/0/7
port access vlan 40
interface Ten-GigabitEthernet 1/3/0/8
port access vlan 41
interface Ten-GigabitEthernet 2/3/0/3
interface Ten-GigabitEthernet 2/3/0/4
interface Ten-GigabitEthernet 2/3/0/7
port access vlan 40
interface Ten-GigabitEthernet 2/3/0/8
port access vlan 41
· SW 1:
vlan 10
port trunk permit vlan 2 to 4094
interface Ten-GigabitEthernet 4/0/1
interface Ten-GigabitEthernet 4/0/2
· SW 2:
vlan 20
· Router A:
ospf 1
import-route direct
area 0.0.0.0
vlan 30
vlan 40
vlan 50
port access vlan 40
port access vlan 30
ip address 172.24.2.2 255.255.255.0
ip address 172.24.40.2 255.255.255.0
ip address 172.24.1.2 255.255.255.0
interface Ten-GigabitEthernet 2/0/1
port access vlan 40
interface Ten-GigabitEthernet 2/0/2
port access vlan 30
port access vlan 40
port access vlan 30
interface Ten-GigabitEthernet 4/0/3
port access vlan 50
· Router B:
ospf 1
import-route direct
area 0.0.0.0
vlan 30
vlan 41
vlan 50
port access vlan 41
port access vlan 30
ip address 172.24.2.3 255.255.255.0
ip address 172.24.41.3 255.255.255.0
ip address 172.24.4.3 255.255.255.0
port access vlan 41
port access vlan 30
port access vlan 41
port access vlan 30
port access vlan 50
As shown in Figure 2:
· Set up a four-chassis IRF fabric at the core layer of the network.
· Use multichassis link aggregations to connect the IRF fabric to the distribution layer switches and the upstream egress router.
· Run OSPF between the IRF fabric and the egress router.
Figure 2 LACP MAD-enabled four-chassis IRF fabric
Table 2 through Table 4 show the VLAN and IP address assignment, IRF port bindings, and network topology scheme.
Table 2 VLAN and IP address assignment
Device |
VLAN interface |
IP address |
Router A |
VLAN-interface 41 |
172.24.41.2/24 |
Router A |
VLAN-interface 50 |
172.24.1.2/24 |
IRF fabric |
VLAN-interface 41 |
172.24.41.254/24 |
IRF fabric |
VLAN-interface 10 |
172.24.10.254/24 |
IRF fabric |
VLAN-interface 20 |
172.24.20.254/24 |
IRF fabric |
IRF fabric |
VLAN-interface N |
172.24.N.254/24 |
Device |
IRF port |
Neighboring IRF port |
IRF physical interfaces |
Device A |
IRF-port 1/1 |
IRF-port 4/2 |
XGE 1/2/0/4 |
Device A |
IRF-port 1/2 |
IRF-port 2/1 |
XGE 1/2/0/1 |
Device B |
IRF-port 2/1 |
IRF-port 1/2 |
XGE 2/4/0/2 |
Device B |
IRF-port 2/2 |
IRF-port 3/1 |
XGE 2/3/0/30 |
Device C |
IRF-port 3/1 |
IRF-port 2/2 |
XGE 3/3/0/15 |
Device C |
IRF-port 3/2 |
IRF-port 4/1 |
XGE 3/12/0/1 |
Device D |
IRF-port 4/1 |
IRF-port 3/2 |
XGE 4/6/0/4 |
Device D |
IRF-port 4/2 |
IRF-port 1/1 |
XGE 4/6/0/2 |
Device |
Neighboring device |
Port |
VLAN |
Aggregate interface |
IRF fabric |
SW 1 |
XGE 1/3/0/3 XGE 2/3/0/3 XGE 3/3/0/3 XGE 4/3/0/3 |
VLAN 10 |
Bridge-Aggregation 1 (LACP MAD) |
IRF fabric |
SW 2 |
XGE 1/3/0/4 XGE 2/3/0/4 XGE 3/3/0/4 XGE 4/3/0/4 |
VLAN 20 |
Bridge-Aggregation 2 |
IRF fabric |
Router A |
XGE 1/3/0/8 XGE 2/3/0/8 XGE 3/3/0/8 XGE 4/3/0/8 |
VLAN 41 |
Bridge-Aggregation 1024 |
SW 1 |
Server Group 1 |
GE 3/0/1 |
VLAN 10 |
N/A |
SW 1 |
IRF fabric |
XGE 2/0/21 XGE 2/0/22 XGE 2/0/23 XGE 2/0/24 |
VLAN 10 |
SW 2 |
Server Group 2 |
GE 3/0/1 |
VLAN 20 |
N/A |
SW 2 |
IRF fabric |
VLAN 20 |
Bridge-Aggregation 1 |
Router A |
IRF fabric |
XGE 2/0/1 XGE 2/0/2 XGE 2/0/3 XGE 2/0/4 |
VLAN 41 |
Router A |
Public network |
XGE 4/0/3 |
VLAN 50 |
N/A |
Analysis
Procedures
# Bind Ten-GigabitEthernet 2/0/4 to IRF-port 1.
[DeviceA] irf-port 1
[DeviceA-irf-port1] port group interface ten-gigabitethernet 2/0/4
[DeviceA-irf-port1] quit
# Bind Ten-GigabitEthernet 2/0/1 to IRF-port 2.
[DeviceA-irf-port2] port group interface ten-gigabitethernet 2/0/1
# Save the running configuration.
[DeviceA] save
Please input the file name(*.cfg)[cfa0:/irf.cfg]
cfa0:/irf.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait.....................................
# Enable IRF mode.
Device A reboots to form a one-chassis IRF fabric.
# Bind Ten-GigabitEthernet 4/0/2 to IRF-port 1.
[DeviceB-irf-port1] port group interface ten-gigabitethernet 4/0/2
# Bind Ten-GigabitEthernet 3/0/30 to IRF-port 2.
[DeviceB] irf-port 2
[DeviceB-irf-port2] port group interface ten-gigabitethernet 3/0/30
[DeviceB-irf-port2] quit
[DeviceB] save
# Connect Device B to Device A, as shown in Figure 2.
# Enable IRF mode.
Device B reboots to join the IRF fabric. A two-chassis IRF fabric is formed.
3. Configure Device C:
# Assign member ID 3 to Device C.
<DeviceC> system-view
[DeviceC] irf member 3
# Bind Ten-GigabitEthernet 3/0/15 to IRF-port 1.
[DeviceC] irf-port 1
[DeviceC-irf-port1] port group interface ten-gigabitethernet 3/0/15
[DeviceC-irf-port1] quit
# Bind Ten-GigabitEthernet 12/0/1 to IRF-port 2.
[DeviceC] irf-port 2
[DeviceC-irf-port2] port group interface ten-gigabitethernet 12/0/1
[DeviceC-irf-port2] quit
[DeviceC] save
# Connect Device C to Device B, as shown in Figure 2.
# Enable IRF mode.
[DeviceC] chassis convert mode irf
Device C reboots to join the IRF fabric. A three-chassis IRF fabric is formed.
4. Configure Device D:
# Assign member ID 4 to Device D.
<DeviceD> system-view
[DeviceD] irf member 4
# Bind Ten-GigabitEthernet 6/0/4 to IRF-port 1.
[DeviceD] irf-port 1
[DeviceD-irf-port1] port group interface ten-gigabitethernet 6/0/4
[DeviceD-irf-port1] quit
# Bind Ten-GigabitEthernet 6/0/2 to IRF-port 2.
[DeviceD] irf-port 2
[DeviceD-irf-port2] port group interface ten-gigabitethernet 6/0/2
[DeviceD-irf-port2] quit
[DeviceD] save
# Connect Device D to Device C and Device A, as shown in Figure 2.
# Enable IRF mode.
[DeviceD] chassis convert mode irf
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
[DeviceA] interface range ten-gigabitethernet 1/3/0/3 ten-gigabitethernet 2/3/0/3 ten-gigabitethernet 3/3/0/3 ten-gigabitethernet 4/3/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
[DeviceA] interface ten-gigabitethernet 1/3/0/4 ten-gigabitethernet 2/3/0/4 ten-gigabitethernet 3/3/0/4 ten-gigabitethernet 4/3/0/4
[DeviceA-if-range] port link-aggregation group 2
# Create Bridge-Aggregation 1024. Assign the uplink ports that connect to Router A to the aggregation group.
[DeviceA] interface range ten-gigabitethernet 1/3/0/8 ten-gigabitethernet 2/3/0/8 ten-gigabitethernet 3/3/0/8 ten-gigabitethernet 4/3/0/8
[DeviceA-if-range] port link-aggregation group 1024
[DeviceA] vlan 10
[DeviceA] vlan 20
[DeviceA] vlan 41
3. Configure OSPF between the IRF fabric and Router A.
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] ip address 172.24.254.1 255.255.255.255
[DeviceA-LoopBack0] quit
[DeviceA] ospf 1 router-id 172.24.254.1
Configuring SW 1
# Create Bridge-Aggregation 1, and enable the dynamic aggregation mode. You must enable the dynamic aggregation mode because this link aggregation will be used for LACP MAD.
<SW1> system-view
# Assign uplink ports to Bridge-Aggregation 1.
[SW1] interface range ten-gigabitethernet 2/0/21 to ten-gigabitethernet 2/0/24
[SW1-if-range] port link-aggregation group 1
[SW1-if-range] quit
# Create all VLANs.
[SW1] vlan all
# Configure the aggregate interface that connects to the IRF fabric.
# Configure the port that connects to Server Group 1.
Configuring SW 2
<SW2> system-view
[SW2] interface range ten-gigabitethernet 2/0/21 to ten-gigabitethernet 2/0/24
[SW2-if-range] port link-aggregation group 1
[SW2-if-range] quit
# Create all VLANs.
[SW2] vlan all
1. Configure link aggregation:
# Assign the downlink ports that connect to the IRF fabric to Bridge-Aggregation 1.
[RouterA] interface range ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/4
[RouterA-if-range] port link-aggregation group 1
[RouterA-if-range] quit
[RouterA] vlan 41
[RouterA-vlan41] quit
[RouterA] interface vlan-interface 41
[RouterA-vlan-interface41] ip address 172.24.41.2 24
[RouterA-vlan-interface41] quit
[RouterA-Bridge-Aggregation1] port access vlan 41
[RouterA] vlan 50
[RouterA-LoopBack0] ip addresss 172.24.254.2 255.255.255.255
[RouterA-LoopBack0] quit
[RouterA] ospf 1 router-id 172.24.254.2
[RouterA-ospf-1-area-0.0.0.0] network 172.24.41.0 0.0.0.255
Verify the IRF and multichassis link aggregation configuration.
# Execute the display irf topology command.
<DeviceA> display irf topology
Topology Info
IRF-Port1 IRF-Port2
Switch Link neighbor Link neighbor Belong To
1 UP 4 UP 2 0210-fc01-0000
4 UP 3 UP 1 0210-fc01-0000
3 UP 2 UP 4 0210-fc01-0000
2 UP 1 UP 3 0210-fc01-0000
The output shows that all the IRF links are in UP state. The four-chassis IRF fabric is established.
# Shut down Ten-GigabitEthernet 1/3/0/8, the port connected to Router A.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Configuration files
· IRF fabric:
undo irf auto-merge enable
undo irf link-delay
irf member 3 priority 1
irf member 4 priority 1
import-route direct
area 0.0.0.0
vlan 10
vlan 20
vlan 13
vlan 41
irf-port 1/1
port group interface Ten-GigabitEthernet1/2/0/4 mode enhanced
irf-port 1/2
port group interface Ten-GigabitEthernet1/2/0/1 mode enhanced
irf-port 2/1
port group interface Ten-GigabitEthernet2/4/0/2 mode enhanced
irf-port 2/2
port group interface Ten-GigabitEthernet2/3/0/30 mode enhanced
irf-port 3/1
port group interface Ten-GigabitEthernet3/3/0/15 mode enhanced
irf-port 3/2
port group interface Ten-GigabitEthernet3/12/0/1 mode enhanced
irf-port 4/1
port group interface Ten-GigabitEthernet4/6/0/4 mode enhanced
irf-port 4/2
port group interface Ten-GigabitEthernet4/6/0/2 mode enhanced
mad enable
port access vlan 41
port access vlan 41
port access vlan 41
interface Ten-GigabitEthernet 3/3/0/3
interface Ten-GigabitEthernet 3/3/0/4
interface Ten-GigabitEthernet 3/3/0/8
port access vlan 41
interface Ten-GigabitEthernet 4/3/0/3
interface Ten-GigabitEthernet 4/3/0/4
interface Ten-GigabitEthernet 4/3/0/8
port access vlan 41
· SW 1:
vlan 10
interface Ten-GigabitEthernet 2/0/21
interface Ten-GigabitEthernet 2/0/22
interface Ten-GigabitEthernet 2/0/23
interface Ten-GigabitEthernet 2/0/24
· SW 2:
vlan 20
· Router A:
import-route direct
area 0.0.0.0
vlan 41
vlan 50
port access vlan 41
ip address 172.24.254.2 255.255.255.255
port access vlan 41
port access vlan 41
interface Ten-GigabitEthernet 2/0/3
port access vlan 41
interface Ten-GigabitEthernet 2/0/4
port access vlan 41
interface Ten-GigabitEthernet 2/0/12
port access vlan 50
Upgrade a two-chassis IRF fabric (see Figure 3) to a four-chassis IRF fabric (see Figure 5) by performing one of the following tasks:
· Merge two two-chassis IRF fabrics.
· Add two chassis to the existing two-chassis IRF fabric.
Configure BFD MAD on the four-chassis IRF fabric, and set up a BFD MAD link between the intermediate device and each member device.
Figure 3 Two-chassis IRF fabric
Figure 4 Upgrading the two-chassis IRF fabric to a four-chassis IRF fabric
Figure 5 BFD MAD-enabled four-chassis IRF fabric
Table 5 Network topology (partial)
Device |
Port |
VLAN |
IRF fabric |
Layer 2 switch |
XGE 1/3/0/1 XGE 2/3/0/1 XGE 3/3/0/1 XGE 4/3/0/1 |
VLAN 13 (BFD MAD VLAN) |
Layer 2 switch |
IRF fabric |
XGE 1/0/41 XGE 1/0/42 XGE 1/0/43 XGE 1/0/44 |
VLAN 13 |
For more information about the VLAN and IP assignment, port bindings, and network topology scheme, see Table 2, Table 3, and Table 4.
Analysis
Because each IRF member must have a unique member ID on the IRF fabric, you must verify that the member ID assignment schemes of the two IRF fabrics do not conflict. If the schemes conflict, renumber the member devices in one IRF fabric to ensure that the two IRF fabrics can merge.
If a downstream or upstream device can process extended LACPDUs for LACP MAD, you can use LACP MAD for IRF split detection. If none of the upstream or downstream devices can process extended LACPDUs, you can use BFD MAD instead.
You can deploy BFD MAD by using the following methods:
· Connect all member chassis with dedicated BFD MAD links into a full mesh topology. This method is suitable for two-chassis IRF fabrics.
· Set up a dedicated BFD MAD link with an intermediate device for each IRF member chassis. This method is suitable for three- or four-chassis IRF fabrics because it uses fewer physical ports than the previous method.
The intermediate device forwards BFD MAD packets transparently. You must assign all BFD MAD links to the VLAN used for BFD MAD.
When you configure BFD MAD, follow these restrictions and guidelines:
Category |
VLAN |
· Do not enable BFD MAD on VLAN-interface 1. · Do not use the BFD MAD VLAN for any purpose other than configuring BFD MAD. No Layer 2 or Layer 3 features, including ARP and LACP, can work on the BFD MAD-enabled VLAN interface or any port in the VLAN. If you configure any other feature on the VLAN, neither the configured feature nor the BFD MAD feature can work correctly. · If an intermediate device is used, assign the ports of BFD MAD links to the BFD MAD VLAN on the device. · The IRF fabrics in a network must use different BFD MAD VLANs. |
MAD IP address |
· To avoid problems, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. For example, an IP address configured with the ip address command or a VRRP virtual IP address can cause problems. · All MAD IP addresses on the BFD MAD-enabled VLAN interface must be on the same subnet. |
Feature compatibility |
· Disable the spanning tree feature on any port in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature. · Do not bind a BFD MAD-enabled VLAN interface to a VPN instance. The MAD feature is mutually exclusive with VPN. |
Procedures
Use one of the following methods to upgrade a two-chassis IRF fabric to a four-chassis IRF fabric:
· Adding two chassis to a two-chassis IRF fabric
· Merging two two-chassis IRF fabrics
1. Configure the IRF fabric:
# Bind Ten-GigabitEthernet 1/2/0/4 to IRF-port 1/1.
[DeviceA] interface ten-gigabitethernet 1/2/0/4
[DeviceA-Ten-GigabitEthernet1/2/0/4] shutdown
[DeviceA-Ten-GigabitEthernet1/2/0/4] quit
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface ten-gigabitethernet 1/2/0/4
[DeviceA-irf-port1/1] quit
[DeviceA-Ten-GigabitEthernet1/2/0/4] undo shutdown
# Bind Ten-GigabitEthernet 2/3/0/30 to IRF-port 2/2.
[DeviceA] interface ten-gigabitethernet 2/3/0/30
[DeviceA-Ten-GigabitEthernet2/3/0/30] shutdown
[DeviceA-Ten-GigabitEthernet2/3/0/30] quit
[DeviceA] irf-port 2/2
[DeviceA-irf-port2/2] port group interface ten-gigabitethernet 2/3/0/30
[DeviceA-irf-port2/2] quit
[DeviceA-Ten-GigabitEthernet2/3/0/30] undo shutdown
[DeviceA] save
# Activate the IRF port configuration.
[DeviceA] irf-port-configuration active
2. Configure IRF on Device C:
[DeviceC] save
# Connect Device C to Device B, as shown in Figure 5.
# Enable IRF mode.
3. Configure IRF on Device D:
[DeviceD] save
# Connect Device D to Device A and Device C, as shown in Figure 5.
# Enable IRF mode.
1. Configure the IRF fabric that has Device A and Device B:
[DeviceA] save
2. Configure the IRF fabric that has Device C and Device D:
# Change the member IDs to 3 and 4 for Device C and Device D, respectively.
[DeviceC] irf member 1 remember 3
Renumbering the member ID may result in configuration change or loss. Continue?[
Y/N]y
[DeviceC] irf member 2 remember 4
Y/N]y
# Save the running configuration and reboot the IRF fabric.
[DeviceC] quit
<DeviceC> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Please input the file name(*.cfg)[ cfa0:/irf.cfg]
# Bind Ten-GigabitEthernet 3/3/0/15 to IRF-port 3/1.
[DeviceC] interface ten-gigabitethernet 3/3/0/15
[DeviceC-Ten-GigabitEthernet3/3/0/15] shutdown
[DeviceC-Ten-GigabitEthernet3/3/0/15] quit
[DeviceC] irf-port 3/1
[DeviceC-irf-port3/1] port group interface ten-gigabitethernet 3/3/0/15
[DeviceC-irf-port3/1] quit
[DeviceC-Ten-GigabitEthernet3/3/0/15] undo shutdown
# Bind Ten-GigabitEthernet 4/6/0/2 to IRF-port 4/2.
[DeviceC] interface ten-gigabitethernet 4/6/0/2
[DeviceC-Ten-GigabitEthernet4/6/0/2] shutdown
[DeviceC-Ten-GigabitEthernet4/6/0/2] quit
[DeviceC] irf-port 4/2
[DeviceC-irf-port4/2] port group interface ten-gigabitethernet4/6/0/2
[DeviceC-irf-port4/2] quit
[DeviceC-Ten-GigabitEthernet4/6/0/2] undo shutdown
[DeviceC] save
# Connect Device C to Device B, and connect Device A to Device D, as shown in Figure 5.
The two IRF fabrics perform master election. The one that lost the master election reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
NOTE: In this example, the feature settings on the original IRF fabrics were cleared. In practice, you do not need to reconfigure all settings you have configured, such as IP addresses. |
# Assign the downlink ports that connect to SW 1 to Bridge-Aggregation 1.
# Assign the downlink ports that connect to SW 2 to Bridge-Aggregation 2.
[DeviceA] interface range ten-gigabitethernet 1/3/0/4 ten-gigabitethernet 2/3/0/4 ten-gigabitethernet 3/3/0/4 ten-gigabitethernet 4/3/0/4
2. Configure BFD MAD:
# Create VLAN 13, and enable BFD MAD on VLAN-interface 13.
[DeviceA] vlan 13
[DeviceA-vlan13] quit
[DeviceA] interface Vlan-interface 13
[DeviceA-Vlan-interface13] mad bfd enable
# Configure a MAD IP address for each member device on VLAN-interface 13.
[DeviceA-Vlan-interface13] mad ip address 172.1.1.1 24 member 1
[DeviceA-Vlan-interface13] mad ip address 172.1.1.2 24 member 2
[DeviceA-Vlan-interface13] mad ip address 172.1.1.3 24 member 3
[DeviceA-Vlan-interface13] mad ip address 172.1.1.4 24 member 4
[DeviceA-Vlan-interface13] undo shutdown
[DeviceA-Vlan-interface13] quit
# Assign the ports that connect to the Layer 2 switch to VLAN 13. Disable the spanning tree feature on the ports.
[DeviceA] interface range ten-gigabitethernet 1/3/0/1 ten-gigabitethernet 2/3/0/1 ten-gigabitethernet 3/3/0/1 ten-gigabitethernet 4/3/0/1
[DeviceA-if-range] undo stp enable
[DeviceA-if-range] port access vlan 13
3. Configure VLANs, ports, and IP addresses:
[DeviceA] vlan 10
[DeviceA] vlan 20
[DeviceA] vlan 41
4. Configure OSPF between the IRF fabric and Router A.
Configuring SW 1
<SW1> system-view
[SW1-if-range] quit
# Create all VLANs.
[SW1] vlan all
# Configure VLAN settings on Bridge-Aggregation 1.
# Configure VLAN settings for the port that connects to Server Group 1.
Configuring SW 2
<SW2> system-view
[SW2-if-range] quit
# Create all VLANs.
[SW2] vlan all
# Configure the port that connects to Server Group 2.
Configring the Layer 2 switch
# Create VLAN 13.
<L2Switch> system-view
[L2Switch] vlan 13
[L2Switch-vlan13] quit
# Assign the ports used for BFD MAD to VLAN 13.
[L2Switch] interface range ten-gigabitethernet 1/0/41 to ten-gigabitethernet 1/0/44
[L2Switch-if-range] port access vlan 13
[L2Switch-if-range] quit
[RouterA] vlan 41
# Create VLAN 50, assign an IP address to VLAN-interface 50, and assign Ten-GigabitEthernet4/0/3 to VLAN 50.
[RouterA] vlan 50
3. Configure OSPF between the router and the IRF fabric.
[RouterA-LoopBack0] ip address 172.24.254.2 255.255.255.255
Topology Info
IRF-Port1 IRF-Port2
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Configuration files
· IRF fabric:
undo irf link-delay
import-route direct
area 0.0.0.0
vlan 10
vlan 20
vlan 13
vlan 41
irf-port 1/1
irf-port 1/2
irf-port 2/1
irf-port 2/2
irf-port 3/1
irf-port 3/2
irf-port 4/1
irf-port 4/2
mad enable
port access vlan 41
interface vlan-interface13
mad bfd enable
mad ip address 1.1.1.4 255.255.255.0 member 1
mad ip address 1.1.1.1 255.255.255.0 member 2
mad ip address 1.1.1.2 255.255.255.0 member 3
mad ip address 1.1.1.3 255.255.255.0 member 4
interface Ten-GigabitEthernet 1/3/0/1
port access vlan 13
undo stp enable
port access vlan 41
interface Ten-GigabitEthernet 2/3/0/1
port access vlan 13
undo stp enable
port access vlan 41
interface Ten-GigabitEthernet 3/3/0/1
port access vlan 13
undo stp enable
port access vlan 41
interface Ten-GigabitEthernet 4/3/0/1
port access vlan 13
undo stp enable
port access vlan 41
· SW 1:
vlan 10
· SW 2:
vlan 20
interface Ten-GigabitEthernet 2/0/41
port access vlan 13
interface Ten-GigabitEthernet 2/0/42
port access vlan 13
interface Ten-GigabitEthernet 2/0/43
port access vlan 13
interface Ten-GigabitEthernet 2/0/44
port access vlan 13
· Router A:
import-route direct
area 0.0.0.0
vlan 41
vlan 50
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 50
Related documentation
· H3C S7500E-X Switch Series Virtual Technologies Command Reference-R7536P05
· H3C S7500E-X Switch Series Virtual Technologies Configuration Guide-R7536P05
