08-ACL and QoS Configuration Examples
HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S10500 Switch Series Configuration Examples-Release7536P05-6W10008-ACL and QoS Configuration Examples
06-H3C_S10500_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples
H3C Congestion Avoidance and Queue Scheduling Configuration Examples
H3C_彩色.emf
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
·     Voice trafficTransmitted in VLAN 6 and carries 802.1p priority 6.
·     Video trafficTransmitted in VLAN 4 and carries 802.1p priority 4.
·     Data trafficTransmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
·     The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
·     WRED drop is used when serious congestion occurs.
Figure 1 Network diagram
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
·     To assign different types of traffic to different queues, configure the incoming interface to trust the 802.1p priority in packets.
·     To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
·     To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Table 1 Drop parameters
Traffic type
Packet color
Lower limit
Upper limit
Drop probability
Voice
Yellow
1000
1500
3%
Red
500
1000
30%
Video
Yellow
1000
1500
2%
Red
500
1000
20%
Data
Yellow
1000
1500
1%
Red
500
1000
10%
Software versions used
This configuration example was created and verified on S10500-CMW710-R7536P05.
Procedures
1.     Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 2/0/1
[Device-Ten-GigabitEthernet2/0/1] port link-type trunk
[Device-Ten-GigabitEthernet2/0/1] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet2/0/1] quit
[Device] interface gigabitethernet 3/0/1
[Device-GigabitEthernet3/0/1] port link-type trunk
[Device-GigabitEthernet3/0/1] port trunk permit vlan 2 4 6
[Device-GigabitEthernet3/0/1] quit
[Device] interface gigabitethernet 3/0/2
[Device-GigabitEthernet3/0/2] port link-type trunk
[Device-GigabitEthernet3/0/2] port trunk permit vlan 2 4 6
[Device-GigabitEthernet3/0/2] quit
2.     Configure interface Ten-GigabitEthernet 2/0/1 to trust the 802.1p priority in packets.
[Device-Ten-GigabitEthernet2/0/1] qos trust dot1p
3.     Configure WRR on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2:
# Enable weighted-based WRR on GigabitEthernet 3/0/1.
[Device-GigabitEthernet3/0/1] qos wrr weight
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device-GigabitEthernet3/0/1] display qos map-table dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-GigabitEthernet3/0/1] qos wrr 1 group 1 weight 2
[Device-GigabitEthernet3/0/1] qos wrr 4 group 1 weight 2
[Device-GigabitEthernet3/0/1] qos wrr 6 group 1 weight 1
# Enable weighted-based WRR on GigabitEthernet 3/0/2.
[Device-GigabitEthernet3/0/2] qos wrr weight
[Device-GigabitEthernet3/0/2] qos wrr 1 group 1 weight 2
[Device-GigabitEthernet3/0/2] qos wrr 4 group 1 weight 2
[Device-GigabitEthernet3/0/2] qos wrr 6 group 1 weight 1
4.     Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device-GigabitEthernet3/0/1] qos wred apply droppolicy
[Device-GigabitEthernet3/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device] display qos queue wrr interface
Interface: display qos queue wrr interface
Interface: GigabitEthernet3/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
Interface: GigabitEthernet1/3/0/2
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
# Display the WRED information for interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device] display qos wred interface
 Current WRED configuration:
 Applied WRED table name: droppolicy
Interface: GigabitEthernet3/0/2
# Display the WRED table configuration.
[Device] display qos wred table
Table name: droppolicy
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     1000  1500  1      500   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     1000  1500  2      500   1000  20     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     1000  1500  3      500   1000  30     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface GigabitEthernet3/0/1
 port link-mode bridge
 port trunk permit vlan 1 to 2 4 6
 qos wrr weight
 qos wrr af1 group 1 weight 2
 qos wrr af4 group 1 weight 2
 qos wrr cs6 group 1 weight 1
interface GigabitEthernet3/0/2
 qos wrr weight
interface Ten-GigabitEthernet2/0/1
return
Related documentation
·     H3C S10500  Switch Series ACL and QoS Configuration Guide-R7536P05
·     H3C S10500  Switch Series ACL and QoS Command Reference-R7536P05
