07-IP Multicast Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R7523P01-6W10007-IP Multicast Configuration Guide
05-Multicast routing and forwarding configuration
Configuring multicast routing and forwarding
Overview
The following tables are involved in multicast routing and forwarding:
·     Multicast routing table of each multicast routing protocol, such as the PIM routing table.
·     General multicast routing table that summarizes multicast routing information generated by different multicast routing protocols. The multicast routing information from multicast sources to multicast groups are stored in a set of (S, G) routing entries.
·     Multicast forwarding table that guides multicast forwarding. The optimal routing entries in the multicast routing table are added to the multicast forwarding table.
RPF check mechanism
A multicast routing protocol uses reverse path forwarding (RPF) check to ensure the multicast data delivery along the correct path and to avoid data loops.
RPF check process
A multicast router performs the RPF check on a multicast packet as follows:
1.     The router chooses an optimal route back to the packet source separately from the unicast, MBGP, and static multicast routing tables.
The term "packet source" means different things in different situations:
¡     For a packet that travels along the SPT, the packet source is the multicast source.
¡     For a packet that travels along the RPT, the packet source is the RP.
¡     For a bootstrap message originated from the BSR, the packet source is the BSR.
For more information about the concepts of SPT, RPT, source-side RPT, RP, and BSR, see "Configuring PIM."
2.     The router selects one of the three optimal routes as the RPF route as follows:
¡     If the router uses the longest prefix match principle, the route with the highest subnet mask becomes the RPF route. If the routes have the same mask, the route with the highest route preference becomes the RPF route. If the routes have the same route preference, the unicast route becomes the RPF route.
For more information about the route preference, see Layer 3—IP Routing Configuration Guide.
¡     If the router does not use the longest prefix match principle, the route with the highest route preference becomes the RPF route. If the routes have the same preference, the unicast route becomes the RPF route.
The RPF route contains the RPF interface and RPF neighbor information.
¡     If the RPF route is a unicast route or MBGP route, the outgoing interface is the RPF interface and the next hop is the RPF neighbor.
¡     If the RPF route is a static multicast route, the RPF interface and RPF neighbor are specified in the route.
3.     The router checks whether the packet arrived at the RPF interface. If yes, the RPF check succeeds and the packet is forwarded. If not, the RPF check fails and the packet is discarded.
RPF check implementation in multicast
Implementing an RPF check on each received multicast packet brings a big burden to the router. The use of a multicast forwarding table is the solution to this issue. When the router creates a multicast forwarding entry for an (S, G) packet, it sets the RPF interface of the packet as the incoming interface of the (S, G) entry. After the router receives another (S, G) packet, it looks up the multicast forwarding table for a matching (S, G) entry:
·     If no match is found, the router first determines the RPF route back to the packet source and the RPF interface. Then, it creates a forwarding entry with the RPF interface as the incoming interface and makes the following judgments:
¡     If the receiving interface is the RPF interface, the RPF check succeeds and the router forwards the packet out of all the outgoing interfaces.
¡     If the receiving interface is not the RPF interface, the RPF check fails and the router discards the packet.
·     If a match is found and the matching forwarding entry contains the receiving interface, the router forwards the packet out of all the outgoing interfaces.
·     If a match is found but the matching forwarding entry does not contain the receiving interface, the router determines the RPF route back to the packet source. Then, the router performs one of the following actions:
¡     If the RPF interface is the incoming interface, it means that the forwarding entry is correct but the packet traveled along a wrong path. The packet fails the RPF check, and the router discards the packet.
¡     If the RPF interface is not the incoming interface, it means that the forwarding entry has expired. The router replaces the incoming interface with the RPF interface and matches the receiving interface against the RPF interface. If the receiving interface is the RPF interface, the router forwards the packet out of all outgoing interfaces. Otherwise, it discards the packet.
RPF check process
Figure 1 RPF check process
As shown in Figure 1, assume that unicast routes are available on the network, MBGP is not configured, and no static multicast routes have been configured on Device C. Multicast packets travel along the SPT from the multicast source to the receivers. The multicast forwarding table on Device C contains the (S, G) entry, with Ten-GigabitEthernet 1/1/2 as the incoming interface.
·     If a multicast packet arrives at Device C on Ten-GigabitEthernet 1/1/2, the receiving interface is the incoming interface of the (S, G) entry. Device C forwards the packet out of all outgoing interfaces.
·     If a multicast packet arrives at Device C on Ten-GigabitEthernet 1/1/1, the receiving interface is not the incoming interface of the (S, G) entry. Device C searches its unicast routing table and finds that the outgoing interface to the source (the RPF interface) is Ten-GigabitEthernet 1/1/2. In this case, the (S, G) entry is correct, but the packet traveled along a wrong path. The packet fails the RPF check, and Device C discards the packet.
Static multicast routes
Depending on the application environment, a static multicast route can change an RPF route or create an RPF route.
Changing an RPF route
Typically, the topology structure of a multicast network is the same as that of a unicast network, and multicast traffic follows the same transmission path as unicast traffic does. You can configure a static multicast route for a multicast source to change the RPF route. As a result, the router creates a transmission path for multicast traffic that is different from the transmission path for unicast traffic.
Figure 2 Changing an RPF route
As shown in Figure 2, when no static multicast route is configured, Device C's RPF neighbor on the path back to the source is Device A. The multicast data from the source travels through Device A to Device C. You can configure a static multicast route on Device C and specify Device B as Device C's RPF neighbor on the path back to the source. The multicast data from the source travels along the path: Device A to Device B and then to Device C.
Creating an RPF route
When a unicast route is blocked, multicast forwarding might be stopped due to lack of an RPF route. You can configure a static multicast route to create an RPF route. In this way, a multicast routing entry is created to guide multicast forwarding.
Figure 3 Creating an RPF route
As shown in Figure 3, the RIP domain and the OSPF domain are unicast isolated from each other. For the receiver hosts in the OSPF domain to receive multicast packets from the multicast source in the RIP domain, you must configure Device C and Device D as follows:
·     On Device C, configure a static multicast route for the multicast source and specify Device B as the RPF neighbor.
·     On Device D, configure a static multicast route for the multicast source and specify Device C as the RPF neighbor.
A static multicast route is effective only on the multicast router on which it is configured, and will not be advertised throughout the network or redistributed to other routers.
Multicast forwarding across unicast subnets
Routers forward the multicast data from a multicast source hop by hop along the forwarding tree, but some routers might not support multicast protocols in a network. When the multicast data is forwarded to a router that does not support IP multicast, the forwarding path is blocked. In this case, you can enable multicast forwarding across two unicast subnets by establishing a tunnel between the routers at the edges of the two unicast subnets.
Figure 4 Multicast data transmission through a tunnel
As shown in Figure 4, a tunnel is established between the multicast routers Device A and Device B. Device A encapsulates the multicast data in unicast IP packets, and forwards them to Device B across the tunnel through unicast routers. Then, Device B strips off the unicast IP header and continues to forward the multicast data to the receiver.
To use this tunnel only for multicast traffic, configure the tunnel as the outgoing interface only for multicast routes.
Configuration task list
Tasks at a glance
(Required.) Enabling IP multicast routing
(Optional.) Configuring multicast routing and forwarding:
·     (Optional.) Configuring static multicast routes
·     (Optional.) Specifying the longest prefix match principle
·     (Optional.) Configuring multicast load splitting
·     (Optional.) Configuring a multicast forwarding boundary
·     (Optional.) Enabling multicast forwarding between sub-VLANs of a super VLAN
The device can route and forward multicast data only through the primary IP addresses of interfaces, rather than their secondary addresses or unnumbered IP addresses. For more information about primary and secondary IP addresses, and IP unnumbered, see Layer 3—IP Services Configuration Guide.
Enable IP multicast routing before you configure any Layer 3 multicast functionality on the public network or VPN instance.
To enable IP multicast routing:
Step
Remarks
N/A
2.     Enable IP multicast routing and enter MRIB view.
By default, IP multicast routing is disabled.
Before you configure multicast routing and forwarding, complete the following tasks:
·     Configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
·     Enable PIM-DM or PIM-SM.
To configure a static multicast route for a given multicast source, you can specify an RPF interface or an RPF neighbor for the multicast traffic from that source.
To configure a static multicast route:
Step
Remarks
N/A
2.     Configure a static multicast route.
By default, no static multicast routes exist.
3.     (Optional.) Delete static multicast routes.
·     Delete a specific static multicast route:
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
·     Delete all static multicast routes:
N/A
You can enable the device to use the longest prefix match principle for RPF route selection. For more information about RPF route selection, see "RPF check process."
To specify the longest prefix match principle:
Step
Remarks
N/A
2.     Enter MRIB view.
N/A
3.     Specify the longest prefix match principle.
longest-match
By default, the route preference principle is used.
You can enable the device to split multiple data flows on a per-source basis or on a per-source-and-group basis. This optimizes the traffic delivery.
To configure multicast load splitting:
Step
Remarks
N/A
2.     Enter MRIB view.
N/A
3.     Configure multicast load splitting.
load-splitting { source | source-group | ucmp }
By default, multicast load splitting is disabled.
This command does not take effect on BIDIR-PIM.
You can configure an interface as a multicast forwarding boundary for a multicast group range. The interface cannot receive or forward multicast packets for the group range.
TIP:
You do not need to enable IP multicast routing before this configuration.
To configure a multicast forwarding boundary:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure the interface as a multicast forwarding boundary for a multicast group range.
By default, an interface is not a multicast forwarding boundary.
A super VLAN is associated with multiple sub-VLANs. Sub-VLANs are isolated with each other at Layer 2. For information about the super VLAN and sub-VLANs, see Layer 2—LAN Switching Configuration Guide.
To enable multicast forwarding between sub-VLANs that are associated with a super VLAN:
Step
Remarks
N/A
2.     Enter VLAN interface view.
N/A
3.     Enable multicast forwarding between sub-VLANs that are associated with a super VLAN.
multicast forwarding supervlan community
By default, multicast data cannot be forwarded between sub-VLANs that are associated with a super VLAN.
4.     Clear all multicast forwarding entries with the super VLAN interface as the incoming interface.
N/A
Displaying and maintaining multicast routing and forwarding
CAUTION:
The reset commands might cause multicast data transmission failures.
Display information about the interfaces maintained by the MRIB.
Display multicast boundary information.
Display multicast fast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ source-address | group-address ] * [ slot slot-number ]
Display DF information.
display multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
Display statistics for multicast forwarding events.
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
Display multicast forwarding entries.
Display information about the DF list in the multicast forwarding table.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
Display multicast routing entries.
Display static multicast routing entries.
Display RPF information for a multicast source.
Clear multicast fast forwarding entries.
reset multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { source-address | group-address } * | all } [ slot slot-number ]
Clear statistics for multicast forwarding events.
Clear multicast forwarding entries.
Clear multicast routing entries.
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number } * | all }
·     When you clear a multicast routing entry, the associated multicast forwarding entry is also cleared.
·     When you clear a multicast forwarding entry, the associated multicast routing entry is also cleared.
Configuration examples
Network requirements
As shown in Figure 5:
·     PIM-DM runs on the network.
·     All switches on the network support multicast.
·     Switch A, Switch B and Switch C run OSPF.
·     Typically, the receiver host can receive the multicast data from Source through the path: Switch A to Switch B, which is the same as the unicast route.
Configure the switches so that the multicast data from Source travels to the receiver through the path: Switch A to Switch C to Switch B. This is different from the unicast route.
Figure 5 Network diagram
Configuration procedure
1.     Assign an IP address and subnet mask for each interface, as shown in Figure 5. (Details not shown.)
2.     Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3.     Enable IP multicast routing, and enable IGMP and PIM-DM:
# On Switch B, enable IP multicast routing.
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 100.
[SwitchB-Vlan-interface100] igmp enable
# Enable PIM-DM on other interfaces.
[SwitchB-Vlan-interface101] pim dm
[SwitchB-Vlan-interface102] pim dm
# On Switch A, enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable PIM-DM on each interface.
[SwitchA-Vlan-interface200] pim dm
[SwitchA-Vlan-interface102] pim dm
# Enable IP multicast routing and PIM-DM on Switch C in the same way Switch A is configured. (Details not shown.)
4.     Display RPF information for Source on Switch B.
[SwitchB] display multicast rpf-info 50.1.1.100
 RPF information about source 50.1.1.100:
     RPF interface: Vlan-interface102, RPF neighbor: 30.1.1.2
     Referenced route/mask: 50.1.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
The output shows that the current RPF route on Switch B is contributed by a unicast routing protocol and the RPF neighbor is Switch A.
5.     Configure a static multicast route on Switch B and specify Switch C as its RPF neighbor on the route to Source.
[SwitchB] ip rpf-route-static 50.1.1.100 24 20.1.1.2
# Display RPF information for Source on Switch B.
     RPF interface: Vlan-interface101, RPF neighbor: 20.1.1.2
     Referenced route type: multicast static
·     The RPF route on Switch B is the configured static multicast route.
·     The RPF neighbor of Switch B is Switch C.
As shown in Figure 6:
·     All switches on the network support IP multicast.
·     Switch B and Switch C run OSPF, and have no unicast routes to Switch A.
·     Typically, the receiver host receives the multicast data from Source 1 in the OSPF domain.
Configure the switches so that the receiver host receives multicast data from Source 2, which is outside the OSPF domain.
Figure 6 Network diagram
1.     Assign an IP address and subnet mask for each interface, as shown in Figure 6. (Details not shown.)
2.     Configure OSPF on Switch B and Switch C. (Details not shown.)
# On Switch C, enable IP multicast routing.
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC-Vlan-interface100] igmp enable
# Enable PIM-DM on VLAN-interface 101.
[SwitchC] interface vlan-interface 101
[SwitchC-Vlan-interface101] pim dm
[SwitchC-Vlan-interface101] quit
[SwitchA-mrib] quit
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] pim dm
[SwitchA-Vlan-interface300] quit
# Enable IP multicast routing and PIM-DM on Switch B in the same way Switch A is configured. (Details not shown.)
4.     Display RPF information for Source 2 on Switch B and Switch C.
[SwitchC] display multicast rpf-info 50.1.1.100
No output is displayed because no RPF routes to Source 2 exist on Switch B or Switch C.
5.     Configure a static multicast route:
# Configure a static multicast route on Switch B and specify Switch A as its RPF neighbor on the route to Source 2.
[SwitchB] ip rpf-route-static 50.1.1.100 24 30.1.1.2
# Configure a static multicast route on Switch C and specify Switch B as its RPF neighbor on the route to Source 2.
[SwitchC] ip rpf-route-static 10.1.1.100 24 20.1.1.2
# Display RPF information for Source 2 on Switch B.
# Display RPF information for Source 2 on Switch C.
The output shows that the RPF routes to Source 2 exist on Switch B and Switch C. The routes are the configured static routes.
Multicast forwarding over a GRE tunnel
As shown in Figure 7:
·     Multicast routing and PIM-DM are enabled on Switch A and Switch C.
·     Switch B does not support multicast.
·     Switch A, Switch B, and Switch C run OSPF.
Configure the switches so that the receiver host can receive the multicast data from Source.
Figure 7 Network diagram
1.     Assign an IP address and subnet mask for each interface, as shown in Figure 7. (Details not shown.)
2.     Configure OSPF on all the switches. (Details not shown.)
3.     Configure a GRE tunnel:
# On Switch A, create service loopback group 1, and specify the unicast tunnel service for the group.
[SwitchA] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet1/1/3 to service loopback group 1. (Ten-GigabitEthernet1/1/3 does not belong to VLAN 100 or VLAN 101.)
[SwitchA] interface ten-gigabitethernet 1/1/3
[SwitchA-Ten-GigabitEthernet1/1/3] port service-loopback group 1
[SwitchA-Ten-GigabitEthernet1/1/3] quit
# Create a GRE tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[SwitchA] interface tunnel 1 mode gre
# Assign an IP address to interface Tunnel 1, and specify its source and destination addresses.
[SwitchA-Tunnel1] ip address 50.1.1.1 24
[SwitchA-Tunnel1] source 20.1.1.1
[SwitchA-Tunnel1] destination 30.1.1.2
[SwitchA-Tunnel1] quit
# On Switch C, create service loopback group 1, and specify the unicast tunnel service for the group.
[SwitchC] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet1/1/3 to service loopback group 1. Ten-GigabitEthernet1/1/3 does not belong to VLAN 200 or VLAN 102.
[SwitchC] interface ten-gigabitethernet 1/1/3
[SwitchC-Ten-GigabitEthernet1/1/3] port service-loopback group 1
[SwitchC-Ten-GigabitEthernet1/1/3] quit
[SwitchC] interface tunnel 1 mode gre
# Assign an IP address for interface Tunnel 1, and specify its source and destination addresses.
[SwitchC-Tunnel1] ip address 50.1.1.2 24
[SwitchC-Tunnel1] source 30.1.1.2
[SwitchC-Tunnel1] destination 20.1.1.1
[SwitchC-Tunnel1] quit
4.     Enable IP multicast routing, PIM-DM, and IGMP:
# On Switch A, enable multicast routing.
[SwitchA-mrib] quit
[SwitchA-Vlan-interface100] pim dm
[SwitchA-Vlan-interface101] pim dm
[SwitchA-Tunnel1] pim dm
# On Switch C, enable multicast routing.
[SwitchC-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 200.
# Enable PIM-DM on VLAN-interface 102.
[SwitchC-Vlan-interface102] pim dm
# Enable PIM-DM on Tunnel 1.
[SwitchC-Tunnel1] pim dm
5.     On Switch C, configure a static multicast route to Source and specify Switch A as the RPF neighbor.
[SwitchC] ip rpf-route-static 50.1.1.0 24 50.1.1.1
# Send an IGMP report from Receiver to join multicast group 225.1.1.1. (Details not shown.)
# Send multicast data from Source to multicast group 225.1.1.1. (Details not shown.)
# Display PIM routing entries on Switch C.
[SwitchC] display pim routing-table
 (*, 225.1.1.1)
     Protocol: pim-dm, Flag: WC
     UpTime: 00:04:25
     Upstream interface: NULL
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface200
             Protocol: igmp, UpTime: 00:04:25, Expires: -
 (10.1.1.100, 225.1.1.1)
     Protocol: pim-dm, Flag: ACT
     UpTime: 00:06:14
     Upstream interface: Tunnel1
         Upstream neighbor: 50.1.1.1
         RPF prime neighbor: 50.1.1.1
             Protocol: pim-dm, UpTime: 00:04:25, Expires: -
The output shows that Switch A is the RPF neighbor of Switch C and the multicast data from Switch A is delivered over the GRE tunnel to Switch C.
Troubleshooting multicast routing and forwarding
Static multicast route failure
Symptom
No dynamic routing protocol is enabled on the routers, and the physical status and link layer status of interfaces are both up, but the static multicast route fails.
Solution
To resolve the problem:
1.     Use the display multicast routing-table static command to display information about static multicast routes. Verify that the static multicast route has been correctly configured and that the route entry exists in the static multicast routing table.
2.     Check the type of the interface that connects the static multicast route to the RPF neighbor. If the interface is not a point-to-point interface, be sure to specify the address for the RPF neighbor.
3.     If the problem persists, contact H3C Support.
