12-Network Management and Monitoring Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Command References-R7523P01-6W10012-Network Management and Monitoring Command Reference
18-VCF fabric commands
18-VCF fabric commands 38.04 KB
VCF fabric commands
display vcf-fabric topology
Use display vcf-fabric topology to display VCF fabric topology information.
You can execute this command only on the master spine node.
Before you display VCF fabric topology information, make sure VCF fabric topology discovery and automated underlay network provisioning are enabled.
# Display VCF fabric topology information.
<Sysname> display vcf-fabric topology
                                  Topology Information
* indicates the master spine role among all spines
SpineIP            Interface                      Link LeafIP              Status
*10.11.113.51     Ten-GigabitEthernet1/0/1     Up   10.11.113.52       Running
                    Ten-GigabitEthernet1/0/2      Down --                  --
                    Ten-GigabitEthernet1/0/3      Down --                  --
SpineIP
IPv4 address of the management Ethernet interface on the spine node. This field displays an asterisk (*) before the IP address if the device is the master spine node.
Interface through which the spine node connects to a leaf node.
If the device is a master spine node, all interfaces on the device are displayed.
Link
Physical link state of the interface.
LeafIP
IPv4 address of the interface through which a leaf node connects to the spine node.
Status
Status of automated underlay network provisioning on the leaf node.
This field displays two hyphens (--) if automated underlay network provisioning is not started.
This field displays Deploying if automated underlay network provisioning is in progress.
vcf-fabric underlay autoconfigure
vcf-fabric topology enable
display vcf-fabric underlay autoconfigure
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network provisioning.
Before you execute this command, make sure automated underlay network provisioning is enabled.
# Display information about automated underlay network provisioning.
<Sysname> display vcf-fabric underlay autoconfigure
Successfully configured commands:
         clock timezone beijing add 08:00:00
         lldp global enable
         sysname spine
         irf mac-address persistent always
         ospf 1
         graceful-restart ietf
         area 0.0.0.0
         interface LoopBack0
         l2vpn enable
         interface M-GigabitEthernet0/0/0
         undo lldp enable
         ntp-service enable
         ntp-service unicast-peer 10.11.113.143
         restful https enable
         netconf soap https enable
         ip https enable
         telnet server enable
         local-user aaa
         password simple aaa
         service-type telnet https
         line vty 0 63
         authentication-mode scheme
         bgp 100
         vcf topo enable
         neutron
         rabbit user openstack
         rabbit password plain 12345678
         rabbit host ip 10.11.113.143
         username aaa password plain aaa
         network-type vxlan-central
         l2agent enable
         l3agent enable
IRF configuration:
        Bridge MAC: 72bd-bf0e-0100
        IRF status: No
        Member ID list: ['2']
Loopback address assignment:
        IP address list: None
BGP peers:
         No peers
AggrID: 1023
         interface: Ten-GigabitEthernet1/0/1
         interface: Ten-GigabitEthernet1/0/2
Commands that have been successfully executed during automated underlay network provisioning.
IRF configuration
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device.
IP address assigned to the loopback interfaces.
BGP peers
Information about BGP peers of the device.
AggrID
Information about Layer 2 aggregation groups.
vcf-fabric role
Use vcf-fabric role to specify the role of the device.
Use undo vcf-fabric role to restore the default.
vcf-fabric role { access | leaf | spine }
No role is specified for the device.
Neutron view
access: Specifies the access node.
leaf: Specifies the leaf node.
spine: Specifies the spine node.
If you change the role of the device, the new role takes effect after the device restarts up.
# Specify the device as a spine node.
[Sysname] vcf-fabric role spine
vcf-fabric spine-role master
Use vcf-fabric spine-role master to specify the device as a master spine node.
Use undo vcf-fabric spine-role master to restore the default.
The device is not a master spine node.
You must execute this command on a spine node.
When multiple spines nodes exist in a VCF fabric, you must specify a device as the master spine node to collect the topology for the entire VCF fabric.
# Specify the device as a master spine.
[Sysname] vcf-fabric spine-role master
vcf-fabric role
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network provisioning.
Use undo vcf-fabric underlay autoconfigure to restore the default.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network provisioning.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file that ends with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
# Specify template file vxlan_spine.template for automated underlay network provisioning.
[Sysname] vcf-fabric underlay autoconfigure vxlan_spine.template
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network provisioning.
Use undo vcf-fabric underlay pause to continue automated underlay network provisioning.
Automated underlay network provisioning is not paused.
You can use this command to pause automated underlay network provisioning if the device is in the process of automated underlay network provisioning.
# Pause automated underlay network provisioning.
<sysname> system-view
[sysname] vcf-fabric underlay pause
