11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7178-6W10011-Network Management and Monitoring Configuration Examples
01-H3C S7500E-XS_NQA_Configuration_Examples
01-H3C S7500E-XS_NQA_Configuration_Examples 290.84 KB
H3C S7500E-XS NQA Configuration Examples
H3C_彩色.emf
Introduction· 1
Prerequisites 1
General configuration restrictions and guidelines 1
Example: Configuring an NQA ICMP echo operation· 1
Network requirements 1
Software version used· 1
Configuration restrictions and guidelines 2
Configuration procedures 2
Verifying the configuration· 2
Configuration files 3
Example: Configuring an NQA DHCP operation· 3
Network requirements 3
Software version used· 4
Configuration restrictions and guidelines 4
Configuration procedures 4
Verifying the configuration· 4
Configuration files 5
Example: Configuring an NQA DNS operation· 5
Network requirements 5
Software version used· 5
Configuration restrictions and guidelines 5
Configuration procedures 6
Verifying the configuration· 6
Configuration files 7
Example: Configuring an NQA FTP operation· 7
Network requirements 7
Software version used· 7
Configuration restrictions and guidelines 7
Configuration procedures 7
Verifying the configuration· 8
Configuration files 9
Example: Configuring an NQA HTTP operation· 9
Network requirements 9
Software version used· 9
Configuration restrictions and guidelines 9
Configuration procedures 9
Verifying the configuration· 10
Configuration files 10
Example: Configuring an NQA UDP jitter operation· 11
Network requirements 11
Software version used· 11
Configuration restrictions and guidelines 11
Configuration procedures 11
Configuring Device B· 11
Configuring Device A·· 11
Verifying the configuration· 12
Configuration files 13
Example: Configuring an NQA SNMP operation· 14
Network requirements 14
Software version used· 14
Configuration restrictions and guidelines 14
Configuration procedures 15
Configuring Device B· 15
Configuring Device A·· 15
Verifying the configuration· 15
Configuration files 16
Example: Configuring an NQA TCP operation· 16
Network requirements 16
Software version used· 16
Configuration restrictions and guidelines 16
Configuration procedures 17
Configuring Device B· 17
Configuring Device A·· 17
Verifying the configuration· 17
Configuration files 18
Example: Configuring an NQA UDP echo operation· 18
Network requirements 18
Software version used· 18
Configuration restrictions and guidelines 19
Configuration procedures 19
Configuring Device B· 19
Configuring Device A·· 19
Verifying the configuration· 19
Configuration files 20
Example: Configuring an NQA voice operation· 20
Network requirements 20
Software version used· 21
Configuration restrictions and guidelines 21
Configuration procedures 21
Configuring Device B· 21
Configuring Device A·· 21
Verifying the configuration· 21
Configuration files 23
Example: Configuring an NQA DLSw operation· 24
Network requirements 24
Software version used· 24
Configuration restrictions and guidelines 24
Configuration procedures 24
Verifying the configuration· 24
Configuration files 25
Related documentation· 25
Introduction
This document provides NQA configuration examples.
This document assumes that you have basic knowledge of H3C NQA.
The ICMP echo operation is not supported in IPv6 networks. To test the reachability of an IPv6 address, use the ping ipv6 command.
As shown in Figure 1, configure an NQA ICMP echo operation to test the roundtrip time between Device A and Device D through Device B.
Figure 1 Network diagram
This configuration example was created and verified on S7500EXS-CMW710-R7178.
When you configure an NQA ICMP echo operation, follow these restrictions and guidelines:
·     Make sure the devices can reach each other before you start the NQA operation.
·     You cannot modify the operation configuration for a running NQA operation.
# Create an NQA ICMP echo operation.
[DeviceA] nqa entry admin test
[DeviceA-nqa-admin-test] type icmp-echo
# Specify the destination IP address of ICMP echo requests as 60.1.1.1.
[DeviceA-nqa-admin-test-icmp-echo] destination ip 60.1.1.1
# Specify the next hop of ICMP echo requests as 10.1.1.2.
[DeviceA-nqa-admin-test-icmp-echo] next-hop 10.1.1.2
# Configure the ICMP echo operation to perform 10 probes.
[DeviceA-nqa-admin-test-icmp-echo] probe count 10
# Specify the probe timeout time as 500 milliseconds for the ICMP echo operation.
[DeviceA-nqa-admin-test-icmp-echo] probe timeout 500
# Configure the ICMP echo operation to repeat at an interval of 5000 milliseconds.
[DeviceA-nqa-admin-test-icmp-echo] frequency 5000
# Enable saving history records.
[DeviceA-nqa-admin-test-icmp-echo] history-record enable
# Configure the maximum number of history records that can be saved as 10.
[DeviceA-nqa-admin-test-icmp-echo] history-record number 10
[DeviceA-nqa-admin-test-icmp-echo] quit
# Start the ICMP echo operation.
[DeviceA] nqa schedule admin test start-time now lifetime forever
# After the ICMP echo operation runs for a time period, stop the operation.
[DeviceA] undo nqa schedule admin test
# Display the most recent result of the ICMP echo operation.
[DeviceA] display nqa result admin test
NQA entry (admin admin, tag test) test results:
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 2/5/3
    Square-Sum of round trip time: 96
    Last succeeded probe time: 2014-03-23 15:00:01.2
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
# Display the history records of the ICMP echo operation.
[DeviceA] display nqa history admin test
NQA entry (admin admin, tag test) history records:
  Index      Response     Status           Time
  370        3            Succeeded        2014-03-23 15:00:01.2
  369        3            Succeeded        2014-03-23 15:00:01.2
  368        3            Succeeded        2014-03-23 15:00:01.2
  367        5            Succeeded        2014-03-23 15:00:01.2
  366        3            Succeeded        2014-03-23 15:00:01.2
  365        3            Succeeded        2014-03-23 15:00:01.2
  364        3            Succeeded        2014-03-23 15:00:01.1
  363        2            Succeeded        2014-03-23 15:00:01.1
  362        3            Succeeded        2014-03-23 15:00:01.1
  361        2            Succeeded        2014-03-23 15:00:01.1
The output shows that the packets sent by Device A can reach Device D through Device B. No packet loss occurs during the operation. The minimum, maximum, and average round-trip times are 2, 5, and 3 milliseconds, respectively.
Configuration files
 type icmp-echo
  frequency 5000
  next-hop 10.1.1.2
  probe count 10
  probe timeout 500
As shown in Figure 2, configure an NQA DHCP operation to test the time required for Device A to obtain an IP address from the DHCP server (Device B).
Figure 2 Network diagram
When you configure an NQA DHCP operation, follow these restrictions and guidelines:
·     Complete the DHCP server configuration before you start the DHCP operation.
·     Make sure the devices can reach each other before you start the operation.
# Create an NQA DHCP operation.
[DeviceA-nqa-admin-test] type dhcp
# Specify the DHCP server IP address 10.1.1.2 as the destination address.
[DeviceA-nqa-admin-test-dhcp] destination ip 10.1.1.2
# Enable the saving of history records.
[DeviceA-nqa-admin-test-dhcp] history-record enable
[DeviceA-nqa-admin-test-dhcp] quit
# Start the DHCP operation.
# After the operation runs for a time period, stop the operation.
# Display the most recent result of the DHCP operation.
  NQA entry(admin admin, tag test) test results:
      Send operation times: 1              Receive response times: 1
      Min/Max/Average round trip time: 624/624/624
      Square-Sum of round trip time: 389376
      Last succeeded probe time: 2014-03-24 09:56:03.2
    Extend results:
      Packet lost in test: 0%
# Display the history records of the DHCP operation.
  NQA entry(admin admin, tag test) history record(s):
    1          624          Succeeded        2014-03-24 09:56:03.2
The output shows that it took Device A 624 milliseconds to obtain an IP address from the DHCP server.
Configuration files
 type dhcp
As shown in Figure 3, configure an NQA DNS operation to test whether Device A can perform address resolution through the DNS server and test the resolution time.
Figure 3 Network diagram
When you configure an NQA DNS operation, follow these restrictions and guidelines:
# Create an NQA DNS operation.
[DeviceA-nqa-admin-test] type dns
# Specify the IP address of the DNS server 10.2.2.2 as the destination address.
[DeviceA-nqa-admin-test-dns] destination ip 10.2.2.2
# Specify the domain name to be translated as host.com.
[DeviceA-nqa-admin-test-dns] resolve-target host.com
[DeviceA-nqa-admin-test-dns] history-record enable
[DeviceA-nqa-admin-test-dns] quit
# Start the DNS operation.
# After the DNS operation runs for a time period, stop the operation.
# Display the most recent result of the DNS operation.
      Min/Max/Average round trip time: 62/62/62
      Square-Sum of round trip time: 3844
      Last succeeded probe time: 2014-03-24 10:49:37.3
    Extended results:
# Display the history records of the DNS operation.
    1          62           Succeeded        2014-03-24 10:49:37.3
The output shows that it took Device A 62 milliseconds to translate the domain name host.com into an IP address.
Configuration files
 type dns
As shown in Figure 4, configure an NQA FTP operation to test the file transmission time between Device A and the FTP server. The login username and password are admin and systemtest, respectively.
Figure 4 Network diagram
When you configure an NQA FTP operation, follow these restrictions and guidelines:
·     When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
·     Take the network bandwidth into consideration when you set the file size and the probe timeout.
# Create an NQA FTP operation.
[DeviceA-nqa-admin-test] type ftp
# Specify the URL of the FTP server.
[DeviceA-nqa-admin-test-ftp] url ftp://10.2.2.2
# Specify 10.1.1.1 as the source IP address.
[DeviceA-nqa-admin-test-ftp] source ip 10.1.1.1
# Specify the FTP operation type as put.
[DeviceA-nqa-admin-test-ftp] operation put
# Specify the file to be uploaded as config.txt.
[DeviceA-nqa-admin-test-ftp] filename config.txt
# Specify the username for the FTP operation as admin.
[DeviceA-nqa-admin-test-ftp] username admin
# Specify the password for the FTP operation as systemtest.
[DeviceA-nqa-admin-test-ftp] password simple systemtest
[DeviceA-nqa-admin-test-ftp] history-record enable
[DeviceA-nqa-admin-test-ftp] quit
# Start the FTP operation.
# After the FTP operation runs for a time period, stop the operation.
# Display the most recent result of the FTP operation.
      Min/Max/Average round trip time: 173/173/173
      Square-Sum of round trip time: 29929
      Last succeeded probe time: 2014-03-25 10:07:28.6
    Extend results:
      Failures due to disconnect: 0
      Failures due to no connection: 0
# Display the history records of the FTP operation.
    1           173          Succeeded        2014-03-25 10:07:28.6
The output shows that it took Device A 173 milliseconds to upload a file to the FTP server.
Configuration files
 type ftp
  filename config.txt
  operation put
  password cipher $c$3$BP255atzDilAfIPwfh+RMHqmP5LTiKWpVf/hpBs=
  source ip 10.1.1.1
  url ftp://10.2.2.2
  username admin
As shown in Figure 5, configure an NQA HTTP operation on the NQA client to test the time required to obtain data from the HTTP server.
Figure 5 Network diagram
When you configure an NQA HTTP operation, follow these restrictions and guidelines:
# Create an NQA HTTP operation.
[DeviceA-nqa-admin-test] type http
# Specify the URL of the HTTP server.
[DeviceA-nqa-admin-test-http] url http://10.2.2.2/index.htm
[DeviceA-nqa-admin-test-http] history-record enable
[DeviceA-nqa-admin-test-http] quit
# Start the HTTP operation.
# After the HTTP operation runs for a time period, stop the operation.
# Display the most recent result of the HTTP operation.
      Min/Max/Average round trip time: 64/64/64
      Square-Sum of round trip time: 4096
      Last succeeded probe time: 2014-03-25 11:12:47.9
    Extend results:
# Display the history records of the HTTP operation.
    1          64           Succeeded        2014-03-25 11:12:47.9
The output shows that it took Device A 64 milliseconds to obtain data from the HTTP server.
Configuration files
 type http
As shown in Figure 6, configure a UDP jitter operation to test the jitter, delay, and round-trip time between Device A and Device B.
Figure 6 Network diagram
When you configure an NQA UDP jitter operation, follow these restrictions and guidelines:
·     Configure Device B as the NQA server before you start the NQA UDP jitter operation.
# Enable the NQA server.
[DeviceB] nqa server enable
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 9000.
[DeviceB] nqa server udp-echo 10.2.2.2 9000
# Create a UDP jitter operation.
[DeviceA-nqa-admin-test] type udp-jitter
# Configure 10.2.2.2 as the destination IP address and port 9000 as the destination port.
[DeviceA-nqa-admin-test-udp-jitter] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-jitter] destination port 9000
# Configure the operation to repeat at an interval of 1000 milliseconds.
[DeviceA-nqa-admin-test-udp-jitter] frequency 1000
[DeviceA-nqa-admin-test-udp-jitter] quit
# Start the UDP jitter operation.
# Stop the UDP jitter operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the UDP jitter operation.
    Min/Max/Average round trip time: 1/1/1
    Square-Sum of round trip time: 10
    Last packet received time: 2014-07-30 09:46:36.9
  Extended results:
    Packets out of sequence: 0
    Packets arrived late: 0
  UDP-jitter results:
   RTT number: 10
    Min positive SD: 1                     Min positive DS: 0
    Max positive SD: 1                     Max positive DS: 0
    Positive SD number: 1                  Positive DS number: 0
    Positive SD sum: 1                     Positive DS sum: 0
    Positive SD average: 1                 Positive DS average: 0
    Positive SD square-sum: 1              Positive DS square-sum: 0
    Min negative SD: 0                     Min negative DS: 0
    Max negative SD: 0                     Max negative DS: 0
    Negative SD number: 0                  Negative DS number: 0
    Negative SD sum: 0                     Negative DS sum: 0
    Negative SD average: 0                 Negative DS average: 0
    Negative SD square-sum: 0              Negative DS square-sum: 0
  One way results:
    Max SD delay: 0                        Max DS delay: 0
    Min SD delay: 0                        Min DS delay: 0
    Number of SD delay: 0                  Number of DS delay: 0
    Sum of SD delay: 0                     Sum of DS delay: 0
    Square-Sum of SD delay: 0              Square-Sum of DS delay: 0
    SD lost packets: 0                     DS lost packets: 0
    Lost packets for unknown reason: 0
# Display the statistics of the UDP jitter operation.
[DeviceA] display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2014-07-30 09:46:22.7
    Life time: 14 seconds
    Send operation times: 150            Receive response times: 150
    Min/Max/Average round trip time: 1/4/1
    Square-Sum of round trip time: 165
  Extended results:
  UDP-jitter results:
   RTT number: 150
    Min positive SD: 1                     Min positive DS: 1
    Max positive SD: 6                     Max positive DS: 1
    Positive SD number: 11                 Positive DS number: 5
    Positive SD sum: 16                    Positive DS sum: 5
    Positive SD average: 1                 Positive DS average: 1
    Positive SD square-sum: 46             Positive DS square-sum: 5
    Min negative SD: 5                     Min negative DS: 1
    Max negative SD: 5                     Max negative DS: 1
    Negative SD number: 1                  Negative DS number: 1
    Negative SD sum: 5                     Negative DS sum: 1
    Negative SD average: 5                 Negative DS average: 1
    Negative SD square-sum: 25             Negative DS square-sum: 1
  One way results:
Configuration files
·     Device B:
 nqa server enable
·     Device A:
 type udp-jitter
  frequency 1000
As shown in Figure 7, configure an SNMP operation to test the time the NQA client uses to get a response from the SNMP agent.
Figure 7 Network diagram
When you configure an NQA SNMP operation, follow these restrictions and guidelines:
·     Configure Device B as the SNMP agent before you start the NQA SNMP operation.
# Set the SNMP version to all.
[DeviceB] snmp-agent sys-info version all
# Set the read community to public.
[DeviceB] snmp-agent community read public
# Set the write community to private.
[DeviceB] snmp-agent community write private
# Create an SNMP operation.
[DeviceA-nqa-admin-test] type snmp
# Configure 10.2.2.2 as the destination IP address of the SNMP operation.
[DeviceA-nqa-admin-test-snmp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-snmp] history-record enable
[DeviceA-nqa-admin-test-snmp] quit
# Start the SNMP operation.
# Stop the SNMP operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the SNMP operation.
    Last succeeded probe time: 2014-07-30 10:07:28.2
  Extended results:
# Display the history records of the SNMP operation.
NQA entry (admin admin, tag test) history record(s):
1          1            Succeeded        2014-07-30 10:07:28.2
Configuration files
·     Device B:
 snmp-agent
 snmp-agent local-engineid 800063A20300E0FC123456
·     Device A:
 type snmp
As shown in Figure 8, configure a TCP operation to test the time required for Device A and Device B to establish a TCP connection.
Figure 8 Network diagram
When you configure an NQA TCP operation, follow these restrictions and guidelines:
·     Configure Device B as the NQA server before you start the NQA TCP operation.
# Configure a listening service to listen on the IP address 10.2.2.2 and TCP port 9000.
[DeviceB] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP operation.
[DeviceA-nqa-admin-test] type tcp
[DeviceA-nqa-admin-test-tcp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-tcp] destination port 9000
[DeviceA-nqa-admin-test-tcp] history-record enable
[DeviceA-nqa-admin-test-tcp] quit
# Start the TCP operation.
# Stop the TCP operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the TCP operation.
    Last succeeded probe time: 2014-07-30 10:37:29.5
  Extended results:
# Display the history records of the TCP operation.
2          1            Succeeded        2014-07-30 10:37:29.5
Configuration files
·     Device B:
 nqa server enable
·     Device A:
 type tcp
As shown in Figure 9, configure a UDP echo operation to test the round-trip time between Device A and Device B. The destination port number is 8000.
Figure 9 Network diagram
When you configure an NQA UDP echo operation, follow these restrictions and guidelines:
·     Configure Device B as the NQA server before you start the NQA UDP echo operation.
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 8000.
[DeviceB] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo operation.
[DeviceA-nqa-admin-test] type udp-echo
# Configure 10.2.2.2 as the destination IP address and port 8000 as the destination port.
[DeviceA-nqa-admin-test-udp-echo] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-udp-echo] destination port 8000
[DeviceA-nqa-admin-test-udp-echo] history-record enable
[DeviceA-nqa-admin-test-udp-echo] quit
# Start the UDP echo operation.
# Stop the UDP echo operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the UDP echo operation.
    Last succeeded probe time: 2014-07-30 11:10:35.2
  Extended results:
# Display the history records of the UDP echo operation.
1          1            Succeeded        2014-07-30 11:10:35.2
Configuration files
·     Device B:
 nqa server enable
·     Device A:
 type udp-echo
As shown in Figure 10, configure a voice operation to test the jitter, delay, MOS, and ICPIF between Device A and Device B.
Figure 10 Network diagram
When you configure an NQA voice operation, follow these restrictions and guidelines:
·     Configure Device B as the NQA server before you start the NQA voice operation.
# Configure a listening service to listen on IP address 10.2.2.2 and UDP port 9000.
# Create a voice operation.
[DeviceA-nqa-admin-test] type voice
[DeviceA-nqa-admin-test-voice] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-voice] destination port 9000
[DeviceA-nqa-admin-test-voice] quit
# Start the voice operation.
# Stop the voice operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the voice operation.
    Send operation times: 157            Receive response times: 157
    Min/Max/Average round trip time: 1/3/1
    Last packet received time: 2014-07-30 14:27:52.8
  Extended results:
  Voice results:
   RTT number: 157
    Min positive SD: 2                     Min positive DS: 1
    Max positive SD: 4                     Max positive DS: 1
    Positive SD number: 2                  Positive DS number: 5
    Positive SD sum: 6                     Positive DS sum: 5
    Positive SD average: 3                 Positive DS average: 1
    Positive SD square-sum: 20             Positive DS square-sum: 5
    Min negative SD: 2                     Min negative DS: 1
    Max negative SD: 4                     Max negative DS: 1
    Negative SD number: 2                  Negative DS number: 6
    Negative SD sum: 6                     Negative DS sum: 6
    Negative SD average: 3                 Negative DS average: 1
    Negative SD square-sum: 20             Negative DS square-sum: 6
  One way results:
  Voice scores:
    MOS value: 0.00                        ICPIF value: 0
# Display the statistics of the voice operation.
  NO. : 1
    Start time: 2014-07-30 14:30:30.0
    Life time: 204 seconds
    Send operation times: 4000           Receive response times: 4000
    Min/Max/Average round trip time: 1/32/1
    Square-Sum of round trip time: 12853
  Extended results:
  Voice results:
   RTT number: 4000
    Max positive SD: 32                    Max positive DS: 1
    Positive SD number: 76                 Positive DS number: 72
    Positive SD sum: 567                   Positive DS sum: 72
    Positive SD average: 7                 Positive DS average: 1
    Positive SD square-sum: 9011           Positive DS square-sum: 72
    Min negative SD: 1                     Min negative DS: 1
    Max negative SD: 20                    Max negative DS: 1
    Negative SD number: 87                 Negative DS number: 67
    Negative SD sum: 569                   Negative DS sum: 67
    Negative SD average: 7                 Negative DS average: 1
    Negative SD square-sum: 6715           Negative DS square-sum: 67
  One way results:
  Voice scores:
    Max MOS value: 4.40                    Min MOS value: 4.40
Max ICPIF value: 0                     Min ICPIF value: 0
Configuration files
·     Device B:
 nqa server enable
·     Device A:
 type voice
As shown in Figure 11, configure a DLSw operation to test the response time of the DLSw device.
Figure 11 Network diagram
When you configure an NQA DLSw operation, follow these restrictions and guidelines:
# Create a DLSw operation.
[DeviceA-nqa-admin-test] type dlsw
# Configure 10.2.2.2 as the destination IP address.
[DeviceA-nqa-admin-test-dlsw] destination ip 10.2.2.2
[DeviceA-nqa-admin-test-dlsw] history-record enable
[DeviceA-nqa-admin-test-dlsw] quit
# Start the DLSw operation.
# Stop the DLSw operation after the operation runs for a time period, for example, 30 seconds.
# Display the most recent result of the DLSw operation.
    Min/Max/Average round trip time: 19/19/19
    Square-Sum of round trip time: 361
    Last succeeded probe time: 2014-07-22 10:40:27.7
  Extended results:
# Display the history records of the DLSw operation.
  1          19           Succeeded        2014-07-22 10:40:27.7
Configuration files
 type dlsw
·     H3C S7500E-XS Switch Series Network Management and Monitoring Configuration Guide-Release 7178
·     H3C S7500E-XS Switch Series Network Management and Monitoring Command Reference-Release 7178
