05-Layer 3 - IP Routing Configuration Examples
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7178-6W10005-Layer 3 - IP Routing Configuration Examples
02-H3C_S7500E-XS_BGP_Route_Selection_Configuration_Examples
H3C S7500E-XS BGP Route Selection Configuration Examples
H3C_彩色.emf
Introduction
This document provides examples for configuring BGP route selection based on route attributes.
This document assumes that you have basic knowledge of BGP and routing policy.
Example: Configuring route selection based on the AS_PATH attribute
Network requirements
As shown in Figure 1, all devices run BGP. Configure a routing policy on Device B and Device C to meet the following requirements:
·     Traffic from AS 100 to AS 200 is preferentially forwarded by Device D.
·     Traffic from AS 100 to AS 300 is preferentially forwarded by Device E.
·     Traffic from AS 100 to AS 400 is preferentially forwarded by Device D.
Figure 1 Network diagram
Requirements analysis
For devices in AS 100 to select the optimal route based on AS numbers, increase the local preference for routes whose AS_PATH attributes end with the specified AS number.
·     Configure a routing policy on Device B to set the local preference to 300 for routes whose AS_PATH attributes end with AS number 200 or 400.
·     Configure a routing policy on Device C to set the local preference to 200 for routes whose AS_PATH attributes end with AS number 300.
To filter routes based on AS numbers, use an AS path list.
Software version used
This configuration example was created and verified on S7500EXS-CMW710-R7178.
Configuration procedures
Configuring IP addresses for interfaces
# Configure an IP address for the interface VLAN-interface 12 on Device A.
[DeviceA] interface Vlan-interface 12
[DeviceA-Vlan-interface12] ip address 12.12.12.1 24
[DeviceA-Vlan-interface12] quit
# Configure IP addresses for other interfaces as shown in Figure 1. (Details not shown.)
Configuring BGP connections
# On Device A, enable the default BGP instance, set the AS number to 100, and specify 12.12.12.2 and 13.13.13.3 as BGP peers.
[DeviceA] bgp 100
[DeviceA-bgp] router-id 1.1.1.1
[DeviceA-bgp] peer 12.12.12.2 as-number 100
[DeviceA-bgp] peer 13.13.13.3 as-number 100
[DeviceA-bgp] address-family ipv4 unicast
[DeviceA-bgp-ipv4] peer 12.12.12.2 enable
[DeviceA-bgp-ipv4] peer 13.13.13.3 enable
[DeviceA-bgp-ipv4] quit
[DeviceA-bgp] quit
# On Device B, enable the default BGP instance, set the AS number to 100, specify 12.12.12.1 and 24.24.24.4 as BGP peers, and redistribute direct routes.
[DeviceB] bgp 100
[DeviceB-bgp] router-id 2.2.2.2
[DeviceB-bgp] peer 12.12.12.1 as-number 100
[DeviceB-bgp] peer 24.24.24.4 as-number 200
[DeviceB-bgp] address-family ipv4 unicast
[DeviceB-bgp-ipv4] peer 12.12.12.1 enable
[DeviceB-bgp-ipv4] peer 24.24.24.4 enable
[DeviceB-bgp-ipv4] import-route direct
[DeviceB-bgp-ipv4] quit
[DeviceB-bgp] quit
# On Device C, enable the default BGP instance, set the AS number to 100, specify 13.13.13.1 and 35.35.35.5 as BGP peers, and redistribute direct routes.
[DeviceC] bgp 100
[DeviceC-bgp] router-id 3.3.3.3
[DeviceC-bgp] peer 13.13.13.1 as-number 100
[DeviceC-bgp] peer 35.35.35.5 as-number 300
[DeviceC-bgp] address-family ipv4 unicast
[DeviceC-bgp-ipv4] peer 13.13.13.1 enable
[DeviceC-bgp-ipv4] peer 35.35.35.5 enable
[DeviceC-bgp-ipv4] import-route direct
[DeviceC-bgp-ipv4] quit
[DeviceC-bgp] quit
# On Device D, enable the default BGP instance, set the AS number to 200, specify 24.24.24.2 and 46.46.46.6 as BGP peers, and advertise the route 4.4.4.4/32.
[DeviceD] bgp 200
[DeviceD-bgp] router-id 4.4.4.4
[DeviceD-bgp] peer 24.24.24.2 as-number 100
[DeviceD-bgp] peer 46.46.46.6 as-number 400
[DeviceD-bgp] address-family ipv4 unicast
[DeviceD-bgp-ipv4] peer 24.24.24.2 enable
[DeviceD-bgp-ipv4] peer 46.46.46.6 enable
[DeviceD-bgp-ipv4] network 4.4.4.4 32
[DeviceD-bgp-ipv4] quit
[DeviceD-bgp] quit
# On Device E, enable the default BGP instance, set the AS number to 300, specify 35.35.35.3 and 56.56.56.6 as BGP peers, and advertise the route 5.5.5.5/32.
[DeviceE] bgp 300
[DeviceE-bgp] router-id 5.5.5.5
[DeviceE-bgp] peer 35.35.35.3 as-number 100
[DeviceE-bgp] peer 56.56.56.6 as-number 400
[DeviceE-bgp] address-family ipv4 unicast
[DeviceE-bgp-ipv4] peer 35.35.35.3 enable
[DeviceE-bgp-ipv4] peer 56.56.56.6 enable
[DeviceE-bgp-ipv4] network 5.5.5.5 32
[DeviceE-bgp-ipv4] quit
[DeviceE-bgp] quit
# On Device F, enable the default BGP instance, set the AS number to 400, specify 46.46.46.4 and 56.56.56.5 as BGP peers, and advertise the route 6.6.6.6/32.
[DeviceF] bgp 400
[DeviceF-bgp] router-id 6.6.6.6
[DeviceF-bgp] peer 46.46.46.4 as-number 200
[DeviceF-bgp] peer 56.56.56.5 as-number 300
[DeviceF-bgp] address-family ipv4 unicast
[DeviceF-bgp-ipv4] peer 46.46.46.4 enable
[DeviceF-bgp-ipv4] peer 56.56.56.5 enable
[DeviceF-bgp-ipv4] network 6.6.6.6 32
[DeviceF-bgp-ipv4] quit
[DeviceF-bgp] quit
# Display the BGP routing table on Device A. The output shows the routes advertised by Device D, Device E, and Device F, and the AS_PATH attributes of the routes.
[DeviceA] display bgp routing-table ipv4
Total number of routes: 12
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >i 2.2.2.2/32         12.12.12.2      0          100        0       ?
* >i 3.3.3.3/32         13.13.13.3      0          100        0       ?
* >i 4.4.4.4/32         24.24.24.4      0          100        0       200i
*  i                    35.35.35.5                 100        0       300 400
        200i
* >i 5.5.5.5/32         35.35.35.5      0          100        0       300i
*  i                    24.24.24.4                 100        0       200 400
        300i
* >i 6.6.6.6/32         24.24.24.4                 100        0       200 400i
*  i                    35.35.35.5                 100        0       300 400i
* >i 12.12.12.0/24      12.12.12.2      0          100        0       ?
* >i 13.13.13.0/24      13.13.13.3      0          100        0       ?
* >i 24.24.24.0/24      12.12.12.2      0          100        0       ?
* >i 35.35.35.0/24      13.13.13.3      0          100        0       ?
Configuring routing policies
# Create routing policy aspath on Device B, and set the local preference to 300 for routes whose AS_PATH attributes end with AS number 200 or 400.
[DeviceB] ip as-path 1 permit 200$
[DeviceB] ip as-path 1 permit 400$
[DeviceB] route-policy aspath permit node 10
[DeviceB-route-policy-aspath-10] if-match as-path 1
[DeviceB-route-policy-aspath-10] apply local-preference 300
[DeviceB-route-policy-aspath-10] quit
# Apply routing policy aspath to routes from the peer 24.24.24.4.
[DeviceB] bgp 100
[DeviceB-bgp-ipv4] peer 24.24.24.4 route-policy aspath import
# Create routing policy aspath on Device C, and set the local preference to 200 for routes whose AS_PATH attributes end with AS number 300.
[DeviceC] ip as-path 1 permit 300$
[DeviceC] route-policy aspath permit node 20
[DeviceC-route-policy-aspath-20] if-match as-path 1
[DeviceC-route-policy-aspath-20] apply local-preference 200
[DeviceC-route-policy-aspath-20] quit
# Apply routing policy aspath to routes from the peer 35.35.35.5.
[DeviceC] bgp 100
[DeviceC-bgp-ipv4] peer 35.35.35.5 route-policy aspath import
# Display the BGP routing table on Device A. The output shows the following:
·     The local preference of routes whose AS_PATH attributes end with AS number 200 or 400 changes to 300.
·     The local preference of routes whose AS_PATH attributes end with AS number 300 changes to 200.
Total number of routes: 11
* >i 4.4.4.4/32         24.24.24.4      0          300        0       200i
* >i 5.5.5.5/32         35.35.35.5      0          200        0       300i
* >i 6.6.6.6/32         24.24.24.4                 300        0       200 400i
# Verify that packets from Device A to 6.6.6.6 are forwarded by Device D.
[DeviceA] tracert 6.6.6.6
traceroute to 6.6.6.6 (6.6.6.6), 30 hops at most, 52 bytes each packet, press CT
RL_C to break
 1  12.12.12.2 (12.12.12.2)  2.417 ms  1.887 ms  1.773 ms
 2  24.24.24.4 (24.24.24.4)  4.057 ms  2.293 ms  2.739 ms
 3  6.6.6.6 (6.6.6.6)  5.145 ms  4.205 ms  4.402 ms
Configuration files
·     Device A:
vlan 12
vlan 13
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Vlan-interface12
 ip address 12.12.12.1 255.255.255.0
interface Vlan-interface13
 ip address 13.13.13.1 255.255.255.0
bgp 100
 router-id 1.1.1.1
·     Device B:
vlan 12
vlan 24
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 12.12.12.2 255.255.255.0
interface Vlan-interface24
 ip address 24.24.24.2 255.255.255.0
bgp 100
 router-id 2.2.2.2
  import-route direct
 if-match as-path 1
·     Device C:
vlan 13
vlan 35
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 13.13.13.3 255.255.255.0
interface Vlan-interface35
 ip address 35.35.35.3 255.255.255.0
bgp 100
 router-id 3.3.3.3
  import-route direct
 if-match as-path 1
·     Device D:
vlan 24
vlan 46
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 24.24.24.4 255.255.255.0
interface Vlan-interface46
 ip address 46.46.46.4 255.255.255.0
bgp 200
 router-id 4.4.4.4
  network 4.4.4.4 255.255.255.255
·     Device E:
vlan 35
vlan 56
interface LoopBack0
 ip address 5.5.5.5 255.255.255.255
 ip address 35.35.35.5 255.255.255.0
interface Vlan-interface56
 ip address 56.56.56.5 255.255.255.0
bgp 300
 router-id 5.5.5.5
  network 5.5.5.5 255.255.255.255
·     Device F:
vlan 46
vlan 56
interface LoopBack0
 ip address 6.6.6.6 255.255.255.255
 ip address 46.46.46.6 255.255.255.0
 ip address 56.56.56.6 255.255.255.0
bgp 400
 router-id 6.6.6.6
  network 6.6.6.6 255.255.255.255
Example: Configuring route selection based on the MED attribute
As shown in Figure 2, all devices run BGP. EBGP runs between Device A and Device B, and between Device A and Device C. IBGP runs between Device B and Device C.
Configure a routing policy to ensure that traffic from AS 100 to AS 200 is preferentially forwarded by Device C. Before you configure the routing policy, the traffic is preferentially forwarded by Device B.
Figure 2 Network diagram
To ensure that the traffic is preferentially forwarded by Device C, configure a routing policy on Device B to change the MED value for the route to Device A. Make sure the MED value is not the default MED value 0.
Configuring basic BGP
# Configure IP addresses for other interfaces as shown in Figure 2. (Details not shown.)
[DeviceA] bgp 100
[DeviceA-bgp] peer 12.12.12.2 as-number 200
[DeviceA-bgp] peer 13.13.13.3 as-number 200
[DeviceA-bgp] quit
# On Device B, enable the default BGP instance, set the AS number to 200, and specify 12.12.12.1 and 3.3.3.3 as BGP peers.
[DeviceB] bgp 200
[DeviceB-bgp] peer 3.3.3.3 as-number 200
[DeviceB-bgp] peer 3.3.3.3 connect-interface LoopBack0
[DeviceB-bgp-ipv4] peer 3.3.3.3 enable
[DeviceB-bgp-ipv4] network 23.23.23.0 24
[DeviceB-bgp] quit
# Configure a static route to 3.3.3.3/32 on Device B.
[DeviceB] ip route-static 3.3.3.3 32 23.23.23.3
# On Device C, enable the default BGP instance, set the AS number to 200, and specify 13.13.13.1 and 2.2.2.2 as BGP peers.
[DeviceC] bgp 200
[DeviceC-bgp] peer 2.2.2.2 as-number 200
[DeviceC-bgp] peer 2.2.2.2 connect-interface LoopBack0
[DeviceC-bgp-ipv4] peer 2.2.2.2 enable
[DeviceC-bgp-ipv4] network 23.23.23.0 24
[DeviceC-bgp] quit
# Configure a static route to 2.2.2.2/32 on Device C.
[DeviceC] ip route-static 2.2.2.2 32 23.23.23.2
# Display the BGP routing table on Device A. The output shows that the route with the next hop 12.12.12.2 becomes the optimal route to the network 23.23.23.0/24.
 Total number of routes: 2
* >e 23.23.23.0/24      12.12.12.2      0                     0       200i
*  e                    13.13.13.3      0                     0       200i
Configuring a routing policy
# Create routing policy 10 on Device B and set the cost to 100.
[DeviceB] route-policy 10 permit node 10
[DeviceB-route-policy-10-10] apply cost 100
[DeviceB-route-policy-10-10] quit
# Apply routing policy 10 to routes to the peer 12.12.12.1.
[DeviceB] bgp 200
[DeviceB-bgp-ipv4] peer 12.12.12.1 route-policy 10 export
[DeviceB-bgp] quit
# Display the BGP routing table on Device A. The output shows that the MED value for the route with the next hop 12.12.12.2 changes to 100, and the route with the next hop 13.13.13.3 becomes the optimal route.
* >e 23.23.23.0/24      13.13.13.3      0                     0       200i
*  e                    12.12.12.2      100                   0       200i
Configuration files
·     Device A:
vlan 12
vlan 13
interface LoopBack0
bgp 100
 router-id 1.1.1.1
·     Device B:
vlan 12
vlan 23
interface LoopBack0
interface Vlan-interface23
 ip address 23.23.23.2 255.255.255.0
bgp 200
 router-id 2.2.2.2
  network 23.23.23.0 255.255.255.0
  peer 3.3.3.3 enable
 apply cost 100
·     Device C:
vlan 13
vlan 23
interface LoopBack0
 ip address 23.23.23.3 255.255.255.0
bgp 200
 router-id 3.3.3.3
  peer 2.2.2.2 enable
Related documentation
·     H3C S7500E-XS Switch Series Layer 3IP Routing Command Reference-Release 7178
·     H3C S7500E-XS Switch Series Layer 3IP Routing Configuration Guide-Release 7178
