01-Fundamentals Configuration Examples
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7178-6W10001-Fundamentals Configuration Examples
01-H3C_S7500E-XS_RBAC_Configuration_Examples
01-H3C_S7500E-XS_RBAC_Configuration_Examples 382.16 KB
H3C S7500E-XS RBAC Configuration Examples
H3C_彩色.emf
Introduction· 1
Prerequisites 1
Example: Configuring Telnet user to have access to read and write commands of specific features 1
Network requirements 1
Requirements analysis 1
Software version used· 2
Configuration restrictions and guidelines 2
Configuration procedures 2
Verifying the configuration· 3
Configuration files 5
Example: Assigning access permissions to Telnet user through RADIUS server 6
Network requirements 6
Requirements analysis 6
Software version used· 7
Configuration restrictions and guidelines 7
Configuration procedures 7
Configuring the switch· 7
Configuring the RADIUS server 9
Verifying the configuration· 11
Configuration files 12
Example: Configuring Telnet user to have access to specific commands in specific VPNs 14
Network requirements 14
Requirements analysis 14
Software version used· 14
Configuration restrictions and guidelines 15
Configuration procedures 15
Configuring the switch· 15
Configuring the RADIUS server 17
Verifying the configuration· 18
Configuration files 19
Example: Changing user access permissions by assigning new user roles 20
Network requirements 20
Requirements analysis 21
Software version used· 21
Configuration restrictions and guidelines 21
Configuration procedures 22
Assigning user role role1 to the Telnet users 22
Verifying the access permissions of user role role1· 24
Assigning user role role2 to Telnet user 1· 25
Verifying the configuration· 25
Configuration files 26
Example: Configuring temporary user role authorization· 27
Network requirements 27
Requirements analysis 28
Software version used· 28
Configuration restrictions and guidelines 28
Configuration procedures 29
Verifying the configuration· 30
Configuration files 33
Example: Assigning ACL and QoS access permissions to Telnet users 34
Network requirements 34
Requirements analysis 35
Software version used· 35
Configuration restrictions and guidelines 35
Configuration procedures 36
Configuring the core switch· 36
Configuring the RADIUS server 38
Verifying the configuration· 40
Configuration files 42
Related documentation· 44
Introduction
This document provides role-based access control (RBAC) examples to control access permissions of login users.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of RBAC.
As shown in Figure 1, configure the switch to meet the following requirements:
·     The Telnet user is authenticated on the switch in ISP domain bbb.
·     The Telnet user is allowed to execute the read and write commands of the ospf and filesystem features after the user passes authentication.
Add a user account named telnetuser on the switch for the Telnet user, and set the user password to aabbcc.
Figure 1 Network diagram
To meet the network requirements, you must perform the following tasks:
·     Create a user role and configure rules for it. This allows the user role to have access permission to the required commands.
·     Assign the user role to the Telnet user, so the Telnet user can obtain the required access permissions.
·     Remove the default user role from the Telnet user, so the user can only have the access permissions of the configured user role.
This configuration example was created and verified on S7500EXS-CMW710-R7178.
When you configure RBAC for local AAA users, follow these restrictions and guidelines:
·     An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
·     You can create multiple rules for a user role. Each rule is uniquely identified by the rule number. A user role can access all commands permitted by the user role rules.
·     If two user-defined rules conflict, the rule with the higher number takes effect. For example, the user role can use the tracert command but not the ping command if the user role contains rules configured by using the following commands:
?     rule 1 permit command ping
?     rule 2 permit command tracert
?     rule 3 deny command ping
1.     Configure VLAN settings:
# Create VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] quit
# Assign Ten-GigabitEthernet 1/1/4 (the interface connected to the Telnet user) to VLAN 2.
[Sysname] interface ten-gigabitethernet 1/1/4
[Sysname-Ten-GigabitEthernet1/1/4] port access vlan 2
[Sysname-Ten-GigabitEthernet1/1/4] quit
# Assign an IP address to VLAN-interface 2.
[Sysname-Vlan-interface2] ip address 192.168.1.50 24
[Sysname-Vlan-interface2] quit
2.     Configure the user login authentication method:
# Enable Telnet server.
# Enable scheme authentication on user lines VTY 0 through VTY 63.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode scheme
[Sysname-line-vty0-63] quit
3.     Configure the authentication domain:
# Create ISP domain bbb and enter ISP domain view.
[Sysname] domain bbb
# Configure the authentication and authorization methods as local for login users in the domain.
[Sysname-isp-bbb] authentication login local
[Sysname-isp-bbb] authorization login local
[Sysname-isp-bbb] quit
4.     Configure device management user telnetuser:
# Create device management user telnetuser and enter local user view.
[Sysname] local-user telnetuser class manage
# Set the user password to aabbcc in plain text.
[Sysname-luser-manage-telnetuser] password simple aabbcc
# Specify the service type as Telnet.
[Sysname-luser-manage-telnetuser] service-type telnet
[Sysname-luser-manage-telnetuser] quit
5.     Configure user role role1:
# Create user role role1 and enter user role view.
[Sysname] role name role1
# Configure rule 1 to permit the user role to access the read and write commands of the ospf feature.
[Sysname-role-role1] rule 1 permit read write feature ospf
# Configure rule 2 to permit the user role to access the read and write commands of the filesystem feature.
[Sysname-role-role1] rule 2 permit read write feature filesystem
[Sysname-role-role1] quit
6.     Assign user role role1 to device management user telnetuser:
# Enter the view of the device management user.
# Assign user role role1 to the user.
[Sysname-luser-manage-telnetuser] authorization-attribute user-role role1
# Remove the default user role network-operator from the user.
[Sysname-luser-manage-telnetuser] undo authorization-attribute user-role network-operator
1.     Display information about user role role1.
[Sysname] display role name role1
Role: role1
  Description:
  VLAN policy: permit (default)
  Interface policy: permit (default)
  VPN instance policy: permit (default)
  Rule    Perm   Type  Scope         Entity
  1       permit RW-   feature       ospf
  2       permit RW-   feature       filesystem
  R:Read W:Write X:Execute
2.     Verify that you can Telnet to the switch.
C:\Documents and Settings\user> telnet 192.168.1.50
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
login: telnetuser@bbb
Password:
<Sysname>
3.     Verify that you have the access permissions of user role role1:
# Verify that you can execute the write commands of the ospf feature. For example, configure OSPF.
[Sysname] ospf 1
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[Sysname-ospf-1-area-0.0.0.0] quit
[Sysname-ospf-1] quit
# Verify that you can execute the read commands of the ospf feature.
[Sysname] display ospf
          OSPF Process 1 with Router ID 192.168.1.50
                  OSPF Protocol Information
 RouterID: 192.168.1.50   Router type:
 Route tag: 0
 Ext-community type: Domain ID 0x5, Route Type 0x306, Router ID 0x107
 Domain ID: 0.0.0.0
 Opaque capable
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5 50 200
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF calculation count: 0
 RFC 1583 compatible
 Graceful restart interval: 120
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 0   NSSA area count: 0
 ExChange/Loading neighbors: 0
# Verify that you can execute the read and write commands of the filesystem feature. For example, specify the source IP address for outgoing FTP packets as 192.168.0.60.
[Sysname] ftp client source ip 192.168.0.60
[Sysname] quit
# Verify that you cannot use the execute commands of the filesystem feature. For example, enter FTP client view.
<Sysname> ftp
Permission denied.
Configuration files
interface Vlan-interface2
 ip address 192.168.1.50 255.255.255.0
interface Ten-GigabitEthernet1/1/4
 port access vlan 2
line vty 0 63
domain bbb
role name role1
 password hash $h$6$kZw1rKFsAY4lhgUz$+teVLy8gmKN4Mr00VWgXQTB8ai94gKHlrys5OkytGf4
kT+nz5X1ZGASjc282CYAR6A1upH2jbmRoTcfDzZ9Gmw==
 service-type telnet
As shown in Figure 2, IMC is the RADIUS server, and the switch uses the RADIUS server to authenticate the Telnet user.
The server assigns the following access permissions to the Telnet user after the user passes authentication:
·     Can execute all commands available in ISP domain view.
·     Can execute the read and write commands of the ARP and RADIUS features.
·     Can create VLANs and execute all commands available in VLAN view.
·     Cannot access any VLANs except VLANs 10 to 20.
·     Can enter interface view and execute all commands available in interface view.
·     Cannot access any interfaces except Ten-GigabitEthernet 1/1/1 to Ten-GigabitEthernet 1/1/3.
Add a user account named telnetuser@bbb on the server for the Telnet user, and specify a password for the account.
Figure 2 Network diagram
·     Add the ARP and RADIUS features to a feature group, so you can manage the features in a centralized manner.
·     Create a user role and configure user role rules and resource access policies on the switch, so the user role can have the required access permissions.
·     Specify the user role in the Telnet user account on the server, so the server can assign the user role to the Telnet user after the user passes authentication.
This configuration example was created and verified on the following product versions:
·     S7500EXS-CMW710-R7178.
·     IMC PLAT 7.0 (E0202).
·     IMC UAM 7.0 (E0202).
When you configure RBAC for remote AAA users, follow these guidelines:
·     Because RADIUS user authorization information is piggybacked in authentication responses, the authentication and authorization methods must use the same RADIUS scheme.
# Create VLAN 2.
[Sysname] vlan 2
# Create VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
# Assign Ten-GigabitEthernet 1/1/3 (the interface connected to the RADIUS server) to VLAN 3.
[Sysname] interface ten-gigabitethernet 1/1/3
[Sysname-Ten-GigabitEthernet1/1/3] port access vlan 3
[Sysname-Ten-GigabitEthernet1/1/3] quit
# Assign an IP address to VLAN-interface 3.
[Sysname] interface Vlan-interface 3
[Sysname-Vlan-interface3] ip address 10.1.1.2 24
[Sysname-Vlan-interface3] quit
3.     Configure RADIUS scheme rad:
# Create RADIUS scheme rad and enter RADIUS scheme view.
[Sysname] radius scheme rad
# Specify the primary RADIUS authentication server at 10.1.1.1.
[Sysname-radius-rad] primary authentication 10.1.1.1
# Specify the primary RADIUS accounting server at 10.1.1.1.
[Sysname-radius-rad] primary accounting 10.1.1.1
# Set the authentication shared key to aabbcc in plain text for secure RADIUS communication.
[Sysname-radius-rad] key authentication simple aabbcc
# Set the accounting shared key to aabbcc in plain text for secure RADIUS communication.
[Sysname-radius-rad] key accounting simple aabbcc
[Sysname-radius-rad] quit
4.     Configure ISP domain bbb:
# Configure authentication, authorization, and accounting methods for the login users in the ISP domain.
[Sysname-isp-bbb] authentication login radius-scheme rad
[Sysname-isp-bbb] authorization login radius-scheme rad
[Sysname-isp-bbb] accounting login radius-scheme rad
5.     Configure feature group fgroup1:
# Create feature group fgroup1 and enter feature group view.
[Sysname] role feature-group name fgroup1
# Assign the ARP and RADIUS features to the feature group.
[Sysname-featuregrp-fgroup1] feature arp
[Sysname-featuregrp-fgroup1] feature radius
[Sysname-featuregrp-fgroup1] quit
6.     Configure user role role1:
# Configure rule 1 to permit the user role to access all commands in ISP domain view.
[Sysname-role-role1] rule 1 permit command system-view ; domain *
# Configure rule 2 to permit the user role to access all read and write commands of the features in feature group fgroup1.
[Sysname-role-role1] rule 2 permit read write feature-group fgroup1
# Configure rule 3 to permit the user role to create VLANs.
[Sysname-role-role1] rule 3 permit command system-view ; vlan *
# Configure rule 4 to permit the user role to enter interface view and execute all commands available in interface view.
[Sysname-role-role1] rule 4 permit command system-view ; interface *
# Enter user role VLAN policy view, and permit the user role to access only VLANs 10 through 20.
[Sysname-role-role1] vlan policy deny
[Sysname-role-role1-vlanpolicy] permit vlan 10 to 20
[Sysname-role-role1-vlanpolicy] quit
# Enter user role interface policy view, and permit the user role to access only interfaces Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/3.
[Sysname-role-role1] interface policy deny
[Sysname-role-role1-ifpolicy] permit interface ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/3
[Sysname-role-role1-ifpolicy] quit
1.     Add the switch to IMC as an access device:
a.     Click the User tab.
b.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c.     Click Add.
The Add Access Device page appears.
d.     In the Access Configuration area, configure the following parameters, as shown in Figure 3:
-     Enter 1812 in the Authentication Port field, and enter 1813 in the Accounting Port field.
-     Enter aabbcc in the Shared Key and Confirm Shared Key fields.
-     Select Device Management Service from the Service Type list.
-     Select H3C(General) from the Access Device Type list.
-     Use the default values for other parameters.
Figure 3 Adding an access device
e.     In the Device List area, click Select or Add Manually to add the switch (10.1.1.2) to IMC as an access device.
f.     Click OK.
2.     Add a device management user:
b.     From the navigation tree, select Access User > Device User.
c.     Click Add.
The Add Device User page appears.
d.     In the Basic Information of Device User area, configure the following parameters, as shown in Figure 4:
-     Enter telnetuser@bbb in the Account Name field.
-     Enter a password in the User Password and Confirm Password fields.
-     Select Telnet from the Service Type list.
-     Enter role1 in the Role Name field.
Figure 4 Adding a device management user
e.     In the IP Address List of Managed Devices area, click Add to specify the IP address subnet in the range of 10.1.1.0 to 10.1.1.10.
f.     Click OK.
Role: role1
  Description:
  VLAN policy: deny
  Permitted VLANs: 10 to 20
  Interface policy: deny
  Permitted interfaces: Ten-GigabitEthernet1/1/1 to Ten-GigabitEthernet1/1/3
  2       permit RW-   feature-group fgroup1
Password:
<Sysname>
# Verify that you can execute all commands available in ISP domain view.
[Sysname] domain abc
[Sysname-isp-abc] authentication login radius-scheme abc
[Sysname-isp-abc] quit
# Verify that you can execute the read and write commands of the ARP and RADIUS features. For example, configure a RADIUS scheme.
[Sysname-radius-rad] primary authentication 2.2.2.2
[Sysname-radius-rad] display radius scheme rad
# Verify that you can access only VLANs 10 to 20. For example, create VLANs 10 and 30.
[Sysname] vlan 10
[Sysname-vlan10] quit
[Sysname] vlan 30
Permission denied.
# Verify that you can access interfaces Ten-GigabitEthernet 1/1/1 to Ten-GigabitEthernet 1/1/3. For example, configure Ten-GigabitEthernet 1/1/1.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] speed auto
[Sysname-Ten-GigabitEthernet1/1/1] quit
# Verify that you cannot access any interface except Ten-GigabitEthernet 1/1/1 to Ten-GigabitEthernet 1/1/3. For example, enter the view of Ten-GigabitEthernet 1/1/6.
[Sysname] interface ten-gigabitethernet 1/1/6
Permission denied.
Configuration files
vlan 2 to 3
interface Vlan-interface3
interface Ten-GigabitEthernet1/1/3
 port access vlan 3
 port access vlan 2
line vty 0 63
radius scheme rad
 key authentication cipher $c$3$JzDegvL0G5KZIcJhzscTHLA4WasBVh0UOw==
 key accounting cipher $c$3$CdejNYYxvjW0Y+Zydi4rZgBwjYb4h6LKmg==
domain bbb
 feature arp
 feature radius
 role name role1
 vlan policy deny
  permit interface Ten-GigabitEthernet1/1/1 to Ten-GigabitEthernet1/1/3
As shown in Figure 5, IMC is the RADIUS server, and the switch uses the RADIUS server to authenticate the Telnet user.
The server authorizes the following access permissions to the Telnet user after the user passes authentication:
·     Can execute all commands available in the predefined feature group L3.
·     Can execute all commands that start with the display keyword.
·     Can access only VPN instances vpn1, vpn2, and vpn3.
Figure 5 Network diagram
When you configure RBAC for remote AAA users, follow these restrictions and guidelines:
# Create VLAN 2.
[Sysname] vlan 2
# Create VLAN 3.
[Sysname] vlan 3
[Sysname] interface vlan-interface 3
# Specify the authentication, authorization, and accounting methods for the login users in the ISP domain.
# Configure rule 1 to permit the user role to access all commands in the L3 feature group.
[Sysname-role-role1] rule 1 permit execute read write feature-group L3
# Configure rule 2 to permit the user role to access all commands that start with the display keyword.
[Sysname-role-role1] rule 2 permit command display *
# Enter user role VPN instance policy view, and configure the user role to have access only to VPN instances vpn1, vpn2, and vpn3.
[Sysname-role-role1] vpn policy deny
[Sysname-role-role1-vpnpolicy] permit vpn-instance vpn1 vpn2 vpn3
[Sysname-role-role1-vpnpolicy] quit
c.     Click Add.
d.     In the Access Configuration area, configure the following parameters, as shown in Figure 6:
Figure 6 Adding an access device
f.     Click OK.
c.     Click Add.
d.     In the Basic Information of Device User area, configure the following parameters, as shown in Figure 7:
Figure 7 Adding a device management user
f.     Click OK.
Role: role1
  Description:
  VPN instance policy: deny
  Permitted VPN instances: vpn1, vpn2, vpn3
  1       permit RWX   feature-group L3
2.     Use the display role feature-group command to display the features in feature group L3. (Details not shown.)
3.     Verify that you can Telnet to the switch.
Password:
<Sysname>
4.     Verify that you have the access permissions of user role role1:
# Verify that you can execute all commands available in the L3 feature group. For example, create VPN instance vpn1 and configure a RD for the VPN instance.
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
[Sysname-vpn-instance-vpn1] display this
return
# Verify that you cannot access any VPN instance except vpn1, vpn2, and vpn3. For example, create VPN instance vpn5.
[Sysname] ip vpn-instance vpn5
Permission denied.
Configuration files
vlan 2 to 3
port access vlan 3
port access vlan 2
line vty 0 63
radius scheme rad
domain bbb
role name role1
 rule 1 permit read write execute feature-group L3
 vpn-instance policy deny
  permit vpn-instance vpn2
  permit vpn-instance vpn3
As shown in Figure 8, add two user accounts telnetuser1 and telnetuser2 on the switch for Telnet user 1 and Telnet user 2, respectively. Set both the users' passwords to aabbcc in plain text.
Configure the switch to meet the following requirements:
·     The Telnet users are authenticated on the switch in ISP domain bbb.
·     User role role1 is assigned to the Telnet users after they pass authentication.
User role role1 has the following access permissions:
·     Can create VLANs.
·     Can access only VLANs 10 to 15.
·     Can access only interface Ten-GigabitEthernet 1/1/1.
Telnet user 1 requires adding the following access permissions:
·     Can access VLANs 16 to 20.
·     Can access interfaces Ten-GigabitEthernet 1/1/2 to Ten-GigabitEthernet 1/1/3.
Figure 8 Network diagram
·     Create a user role and configure user role rules and resource access policies, so the user role can have the additional access permissions of Telnet user 1.
·     Assign the user role to Telnet user 1, so the user can have the additional access permissions at the next login.
When you assign another user role to a user, follow these restrictions and guidelines:
·     You can assign multiple user roles to a user. The user can use the collection of items and resources accessible to any user role assigned to it.
·     If you assign a new user role to a user when the user is online, the assignment does not take effect on the user at the current login. The user obtains the user role the next time it logs in to the switch.
# Create VLAN 2.
[Sysname] vlan 2
# Assign interfaces Ten-GigabitEthernet 1/1/3 and Ten-GigabitEthernet 1/1/4 (the interfaces connected to the Telnet users) to VLAN 2.
[Sysname-Ten-GigabitEthernet1/1/3] port access vlan 2
3.     Configure ISP domain bbb:
# Configure the authentication and authorization methods for the login users in the ISP domain.
4.     Configure device management users telnetuser1 and telnetuser2:
# Create device management user telnetuser1 and enter local user view.
[Sysname] local-user telnetuser1 class manage
# Set the password to aabbcc in plain text.
[Sysname-luser-manage-telnetuser1] password simple aabbcc
[Sysname-luser-manage-telnetuser1] service-type telnet
[Sysname-luser-manage-telnetuser1] quit
# Create device management user telnetuser2 and enter local user view.
[Sysname] local-user telnetuser2 class manage
[Sysname-luser-manage-telnetuser2] password simple aabbcc
[Sysname-luser-manage-telnetuser2] service-type telnet
[Sysname-luser-manage-telnetuser2] quit
# Configure rule 1 to permit the user role to access all commands that start with the display keyword.
[Sysname-role-role1] rule 1 permit command display *
# Configure rule 2 to permit the user role to access VLAN view.
[Sysname-role-role1] rule 2 permit command system-view ; vlan *
# Configure rule 3 to permit the user role to enter interface view and execute all commands available in interface view.
[Sysname-role-role1] rule 3 permit command system-view ; interface *
# Enter user role VLAN policy view, and allow the user role to access only VLANs 10 to 15.
[Sysname-role-role1-vlanpolicy] permit vlan 10 to 15
# Enter user role interface policy view, and allow the user role to access only interface Ten-GigabitEthernet 1/1/1.
6.     Authorize user role role1 to the device management users:
# Enter the view of telnetuser1.
# Assign user role role1 to telnetuser1.
[Sysname-luser-manage-telnetuser1] authorization-attribute user-role role1
# Remove the default user role network-operator from telnetuser1.
[Sysname-luser-manage-telnetuser1] undo authorization-attribute user-role network-operator
# Enter the view of telnetuser2.
# Assign user role role1 to telnetuser2.
[Sysname-luser-manage-telnetuser2] authorization-attribute user-role role1
# Remove the default user role network-operator from telnetuser2.
[Sysname-luser-manage-telnetuser2] undo authorization-attribute user-role network-operator
Role: role1
  Description:
  VLAN policy: deny
  Permitted VLANs: 10 to 15
2.     Verify that you can Telnet to the switch. This example uses user account telnetuser1@bbb.
login: telnetuser1@bbb
Password:
<Sysname>
# Verify that you can configure VLANs 10 to 15. For example, create VLAN 15.
[Sysname] vlan 15
[Sysname-vlan15] quit
# Verify that you cannot access any other VLAN except VLANs 10 to 15. For example, create VLAN 20.
[Sysname] vlan 20
Permission denied.
# Verify that you can access interface Ten-GigabitEthernet 1/1/1.
1.     Configure user role role2:
# Create user role role2 and enter user role view.
[Sysname] role name role2
# Configure rule 1 to permit the user role to enter interface view and execute all commands available in interface view.
[Sysname-role-role2] rule 1 permit command system-view ; interface *
# Enter user role VLAN policy view, and allow the user role to access only VLANs 16 to 20.
[Sysname-role-role2] vlan policy deny
[Sysname-role-role2-vlanpolicy] permit vlan 16 to 20
[Sysname-role-role2-vlanpolicy] quit
# Enter user role interface policy view, and allow the user role to access only interfaces Ten-GigabitEthernet 1/1/2 to Ten-GigabitEthernet 1/1/3.
[Sysname-role-role2] interface policy deny
[Sysname-role-role2-ifpolicy] permit interface ten-gigabitethernet 1/1/2 to ten-gigabitethernet 1/1/3
[Sysname-role-role2-ifpolicy] quit
[Sysname-role-role2] quit
2.     Authorize user role role2 to telnetuser1:
# Assign user role role2 to telnetuser1.
[Sysname-luser-manage-telnetuser1] authorization-attribute user-role role2
1.     Display information about user role role2.
[Sysname] display role name role2
Role: role2
  Description:
  VLAN policy: deny
  Permitted VLANs: 16 to 20
  Permitted interfaces: Ten-GigabitEthernet1/1/2 to Ten-GigabitEthernet1/1/3
Password:
<Sysname>
3.     Verify that you have the access permissions of user role role2:
# Verify that you can access VLANs 16 to 20. For example, create VLAN 16.
[Sysname] vlan 16
[Sysname-vlan16] quit
# Verify that you can access interfaces Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3. For example, configure Ten-GigabitEthernet 1/1/2.
[Sysname] interface ten-gigabitethernet 1/1/2
[Sysname-Ten-GigabitEthernet1/1/2] speed auto
[Sysname-Ten-GigabitEthernet1/1/2] quit
# Verify that you cannot access any other interface except interfaces Ten-GigabitEthernet 1/1/1 to Ten-GigabitEthernet 1/1/3. For example, enter the view of Ten-GigabitEthernet 1/1/5.
[Sysname] interface ten-gigabitethernet 1/1/5
Permission denied.
Configuration files
vlan 2
port access vlan 2
port access vlan 2
line vty 0 63
domain bbb
role name role1
 vlan policy deny
role name role2
 vlan policy deny
  permit interface Ten-GigabitEthernet1/1/2 to Ten-GigabitEthernet1/1/3
 service-type telnet
 password hash TPcgyTQJZShe$h$6$vaSj2xKc8yFiNdfQ$Jzb3PXo2lt4jk KSZqJUVhjP634Wol/
Qx8TLU748IHoeui0w5n/XRzpNqbNnpxikym39gGJCwYw==
 service-type telnet
As shown in Figure 9, the switch performs local AAA authentication for the Telnet user. It assigns user role role1 to the Telnet user after the user passes authentication.
The switch performs local-only authentication for the Telnet user to obtain user role role2 or network-operator for temporary authorization.
·     Can execute all commands available in the L3 feature group.
·     Can execute all commands that start with the super keyword.
·     Can access all interfaces, VLANs, and VPNs.
User role role2 has the following access permissions:
·     Can execute all commands available in the L2 feature group.
Add a user account named telnetuser on the switch for the Telnet user, set the password to aabbcc in plain text.
Figure 9 Network diagram
·     Create user roles role1 and role2, and configure user role rules and resource access policies, so the user roles can have the required access permissions.
·     Assign user role role1 to the Telnet user, so the user can obtain the user role after it passes authentication.
·     Configure user role authentication settings for role2 and network-operator, so the Telnet user can obtain the user roles for temporary authorization.
·     For security purposes, configure different authentication passwords for user roles role2 and network-operator.
When you configure temporary user role authorization, follow these restrictions and guidelines:
·     Temporary user role authorization is effective only on the current login. This feature does not change the user role settings in the user account that you have been logged in with. The next time you are logged in with the user account, the original user role settings take effect.
# Create VLAN 2.
[Sysname] vlan 2
# Configure rule 1 to permit the user role to access all commands of the L3 feature group.
# Configure rule 3 to permit the user role to access all commands that start with the super keyword.
[Sysname-role-role1] rule 3 permit command super *
6.     Configure user role role2:
# Configure rule 1 to permit the user role to access all commands of the L2 feature group.
[Sysname-role-role2] rule 1 permit execute read write feature-group L2
7.     Authorize user role role1 to device management user telnetuser:
# Authorize user role role1 to the user.
8.     Configure temporary user role authorization:
# Enable local-only authentication for temporary user role authorization.
[Sysname] super authentication-mode local
# Set the local authentication password to 123456TESTplat&! in plain text for user role role2.
[Sysname] super password role role2 simple 123456TESTplat&!
# Set the local authentication password to 987654TESTplat&! in plain text for user role network-operator.
[Sysname] super password role network-operator simple 987654TESTplat&!
1.     Verify that the user roles are correctly configured:
# Display information about user role role1.
Role: role1
  Description:
# Display information about user role role2.
Role: role2
  Description:
  1       permit RWX   feature-group L2
# Display information about user role network-operator.
[Sysname] display role name network-operator
Role: network-operator
  Description: Predefined network operator role has access to all read commands
on the Sysname
  sys-1   permit       command       display *
  sys-2   permit       command       xml
  sys-3   deny         command       display history-command all
  sys-4   deny         command       display exception *
  sys-5   deny         command       display cpu-usage configuration
  sys-6   deny         command       display kernel exception *
  sys-7   deny         command       display kernel deadloop *
  sys-8   deny         command       display kernel starvation *
  sys-9   deny         command       display kernel reboot *
  sys-10  deny         command       display memory trace *
  sys-11  deny         command       display kernel memory *
  sys-12  permit       command       system-view ; local-user *
  sys-13  permit       command       system-view ; switchto mdc *
  sys-14  permit R--   xml-element   -
  sys-15  deny         command       display security-logfile summary
  sys-16  deny         command       system-view ; info-center securi
                                     ty-logfile directory *
  sys-17  deny         command       security-logfile save
2.     Use the display role feature-group command to display the features in the L2 and L3 feature groups. (Details not shown.)
Password:
<Sysname>
# Verify that you can access all commands in the L3 feature group. For example, create VPN vpn1.
# Verify that you can use all commands that start with the display keyword. For example, display the system time and date.
[Sysname] display clock
09:31:56 UTC Wed 01/01/2014
[Sysname] quit
5.     Verify that you can obtain the authorization of user role role2 without reconnecting to the switch:
# Obtain user role role2.
<Sysname> super role2
Password:
User privilege role is role2, and only those commands that authorized to the role can be used.
<Sysname>
# Verify that you can use all commands in the L2 feature group. For example, create VLAN 10.
[Sysname] vlan 10
[Sysname] quit
# Verify that you cannot use the commands of any features except the features in the L2 feature group. For example, obtain user role network-operator for temporary authorization.
<Sysname> super network-operator
Permission denied.
# Verify that you cannot use the commands that start with the display keyword. For example, display the system date and time.
<Sysname> display clock
Permission denied.
6.     Disconnect from the switch, and Telnet to the switch again.
Password:
<Sysname>
7.     Verify that you can obtain user role network-operator.
Password:
User privilege role is network-operator, and only those commands that authorized
<Sysname>
Configuration files
vlan 2
port access vlan 2
line vty 0 63
 super password role role2 hash $h$6$D0kjHFktkktzgR5g$e673xFnIcKytCj6EDAw+pvwgh3
/ung3WNWHnrUTnXT862B+s7PaLfKTdil8ef71RBOvuJvPAZHjiLjrMPyWHQw==
 super password role network-operator hash $h$6$3s5KMmscn9hJ6gPx$IcxbNjUc8u4yxwR
m87b/Jki8BoPAxw/s5bEcPQjQj/cbbXwTVcnQGL91WOd7ssO2rX/wKzfyzAO5VhBTn9Q4zQ==
domain bbb
role name role1
role name role2
 rule 1 permit read write execute feature-group L2
 service-type telnet
As shown in Figure 10, the core switch is an S7500E-XS switch, and IMC is the RADIUS server. Users in Department A are in VLANs 100 to 199, and users in Department B are in VLANs 200 to 299. Users in the two departments cannot reach each other at Layer 2.
Add Telnet user accounts admin-departA@bbb and admin-departB@bbb on the RADIUS server for the network administrators in Department A and Department B, respectively.
The core switch uses the RADIUS server to authenticate the network administrators in ISP domain bbb.
The server authorizes the following access permissions to admin-departA after it passes authentication:
·     Can access all commands of the ACL and QoS features.
·     Cannot access any interface and VPN.
·     Can access only VLANs 100 to 199.
The server authorizes the following access permissions to admin-departB after it passes authentication:
·     Can access only VLANs 200 to 299.
Figure 10 Network diagram
·     Create a user role and configure user role rules and resource access policies on the core switch for each administrator, so the user roles can have the required access permissions.
·     Specify the correct user role in each Telnet user account on the server, so the server can assign the correct user role to each administrator.
# Create VLAN 2.
[Sysname] vlan 2
# Assign Ten-GigabitEthernet 1/1/4 (the interface connected to the Telnet users) to VLAN 2.
# Create VLAN 3.
[Sysname] vlan 3
[Sysname-Vlan-interface3] ip address 20.1.1.2 24
5.     Configure user role departA-resource:
# Create user role departA-resource and enter user role view.
[Sysname] role name departA-resource
# Configure rule 1 to permit the user role to access all commands of the QoS feature.
[Sysname-role-departA-resource] rule 1 permit read write execute feature qos
# Configure rule 2 to permit the user role to access all commands of the ACL feature.
[Sysname-role-departA-resource] rule 2 permit read write execute feature acl
# Enter user role VLAN policy view, and permit the user role to access only VLANs 100 to 199.
[Sysname-role-departA-resource] vlan policy deny
[Sysname-role-departA-resource-vlanpolicy] permit vlan 100 to 199
[Sysname-role-departA-resource-vlanpolicy] quit
# Deny the user role to access any interface and VPN.
[Sysname-role-departA-resource] interface policy deny
[Sysname-role-departA-resource-ifpolicy] quit
[Sysname-role-departA-resource] vpn policy deny
[Sysname-role-departA-resource-vpnpolicy] quit
[Sysname-role-departA-resource] quit
6.     Configure user role departB-resource:
# Create user role departB-resource and enter user role view.
[Sysname] role name departB-resource
[Sysname-role-departB-resource] rule 1 permit read write execute feature qos
[Sysname-role-departB-resource] rule 2 permit read write execute feature acl
# Enter user role VLAN policy view, and permit the user role to access only VLANs 200 to 299.
[Sysname-role-departB-resource] vlan policy deny
[Sysname-role-departB-resource-vlanpolicy] permit vlan 200 to 299
[Sysname-role-departB-resource-vlanpolicy] quit
[Sysname-role-departB-resource] interface policy deny
[Sysname-role-departB-resource-ifpolicy] quit
[Sysname-role-departB-resource] vpn policy deny
[Sysname-role-departB-resource-vpnpolicy] quit
[Sysname-role-departB-resource] quit
1.     Add the core switch to IMC as an access device:
c.     Click Add.
d.     In the Access Configuration area, configure the following parameters, as shown in Figure 11:
Figure 11 Adding an access device
e.     In the Device List area, click Select or Add Manually to add the core switch (20.1.1.2) to IMC as an access device.
f.     Click OK.
c.     Click Add.
d.     In the Basic Information of Device User area, configure the following parameters, as shown in Figure 12:
-     Enter admin-departA@bbb in the Account Name field.
-     Enter departA-resource in the Role Name field.
Figure 12 Adding a device management user
e.     In the IP Address List of Managed Devices area, click Add to specify the IP address subnet in the range of 20.1.1.0 to 20.1.1.10.
f.     Click OK.
The device user list displays the added user.
g.     Click Add.
h.     In the Basic Information of Device User area, configure the following parameters, as shown in Figure 13:
-     Enter admin-departB@bbb in the Account Name field.
-     Enter departB-resource in the Role Name field.
Figure 13 Adding a device management user
i.     In the IP Address List of Managed Devices area, click Add to specify the IP address subnet in the range of 20.1.1.0 to 20.1.1.10.
j.     Click OK.
# Display information about user role departA-resource.
[Sysname] display role name departA-resource
Role: departA-resource
  Description:
  VLAN policy: deny
  Permitted VLANs: 100 to 199
  1       permit RWX   feature       qos
  2       permit RWX   feature       acl
# Display information about user role departB-resource.
[Sysname] display role name departB-resource
Role: departB-resource
  Description:
  VLAN policy: deny
  Permitted VLANs: 200 to 299
2.     Verify that you can Telnet to the core switch by using account admin-departA@bbb from Department A:
login: admin-departA@bbb
Password:
<Sysname>
3.     Verify that you have the access permission of user role departA-resource:
a.     Verify that you can use all commands of the QoS and ACL features:
# Create IPv4 advanced ACL 3000 and enter ACL view.
[Sysname] acl number 3000
# Create an IPv4 advanced ACL rule to permit outbound FTP packets.
[Sysname-acl-adv-3000] rule permit tcp destination-port eq ftp-data
[Sysname-acl-adv-3000] quit
# Create traffic class 1 and enter traffic class view.
[Sysname] traffic classifier 1
# Define a match criterion for traffic class 1 to match the advanced ACL 3000.
[Sysname-classifier-1] if-match acl 3000
[Sysname-classifier-1] quit
# Create traffic behavior 1 and enter traffic behavior view.
[Sysname] traffic behavior 1
# Set the CIR of the CAR action to 2000 kbps.
[Sysname-behavior-1] car cir 2000
[Sysname-behavior-1] quit
# Create QoS policy 1, and associate traffic class 1 with traffic behavior 1 in the QoS policy.
[Sysname] qos policy 1
[Sysname-qospolicy-1] classifier 1 behavior 1
[Sysname-qospolicy-1] quit
b.     Verify that you can access VLANs 100 through 199. For example, apply QoS policy 1 to the incoming traffic of VLANs 100 through 107.
[Sysname] qos vlan-policy 1 vlan 100 to 107 inbound
c.     Verify that you cannot access any other VLANs except VLANs 100 through 199. For example, apply QoS policy 1 to the incoming traffic of VLANs 200 through 207.
[Sysname] qos vlan-policy 1 vlan 200 to 207 inbound
Permission denied.
4.     Verify that you can Telnet to the core switch by using account admin-departB@bbb from Department B. (Details not shown.)
5.     Verify that you have the access permission of user role departB-resource:
# Create IPv4 advanced ACL 3001 and enter ACL view.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination-port eq ftp-data
[Sysname-acl-adv-3001] quit
# Create traffic class 2 and enter traffic class view.
[Sysname] traffic classifier 2
# Define a match criterion for traffic class 2 to match the advanced ACL 3001.
[Sysname-classifier-2] if-match acl 3001
[Sysname-classifier-2] quit
# Create traffic behavior 2 and enter traffic behavior view.
[Sysname] traffic behavior 2
[Sysname-behavior-2] car cir 2000
[Sysname-behavior-2] quit
# Create QoS policy 2, and associate traffic class 2 with traffic behavior 2 in the QoS policy.
[Sysname] qos policy 2
[Sysname-qospolicy-2] classifier 2 behavior 2
[Sysname-qospolicy-2] quit
b.     Verify that you can access VLANs 200 through 299. For example, apply QoS policy 2 to the incoming traffic of VLANs 200 through 207.
[Sysname] qos vlan-policy 2 vlan 200 to 207 inbound
c.     Verify that you cannot access any other VLANs except VLANs 200 through 299. For example, apply QoS policy 2 to the incoming traffic of VLANs 100 through 107.
[Sysname] qos vlan-policy 2 vlan 100 to 107 inbound
Permission denied.
Configuration files
vlan 2 to 3
 ip address 20.1.1.2 255.255.255.0
port access vlan 3
port access vlan 2
line vty 0 63
radius scheme rad
domain bbb
 vlan policy deny
 vlan policy deny
·     H3C S7500E-XS Switch Series Fundamentals Command Reference-Release 7178
·     H3C S7500E-XS Switch Series Fundamentals Configuration Guide-Release 7178
