12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10012-Network Management and Monitoring Configuration Guide
12-GOLD configuration
12-GOLD configuration 49.11 KB
Configuring GOLD
Generic Online Diagnostics (GOLD) performs the following tasks:
·     Runs diagnostic tests on a device to inspect device ports, RAM, chip, connectivity, forwarding paths, and control paths for hardware faults.
·     Reports the problems to the system.
GOLD diagnostics are divided into the following categories:
·     Boot-up diagnostics—Test device cards during boot-up or when the cards are inserted or removed. The device does not support boot-up diagnostics.
·     Monitoring diagnostics—Run diagnostic tests periodically when the system is in operation and record test results. Monitoring diagnostics execute only non-disruptive tests.
·     On-demand diagnostics—Enable you to manually start or stop diagnostic tests during system operation.
Each kind of diagnostics runs its diagnostic tests. The parameters of a diagnostic test include test name, type, description, attribute (disruptive or non-disruptive), default status, and execution interval.
Support for the diagnostic tests and default values for a test's parameters depend on the device model. You can modify part of the parameters by using the commands provided by this document.
The diagnostic tests are released with the system software image of the device. All enabled diagnostic tests run in the background. You can use the display commands to view test results and logs to verify hardware faults.
Configuring monitoring diagnostics
The system automatically executes monitoring diagnostic tests that are enabled by default after the device starts. Use the diagnostic monitor enable command to enable monitoring diagnostic tests that are disabled by default.
Use the diagnostic monitor interval command to configure an execution interval for each test. The interval you set must be no smaller than the minimum interval for each test. You can view the minimum interval for a test by using the display diagnostic content command.
To configure monitoring diagnostics:
Step
Remarks
N/A
1.     Enable monitoring diagnostics.
diagnostic monitor enable slot slot-number-list [ test test-name ]
The default enabling status varies by monitoring diagnostic test. To view the status of diagnostic tests, use the display diagnostic content command.
2.     Set the execution interval.
diagnostic monitor interval slot slot-number-list [ test test-name ] time time
The default execution interval varies by monitoring diagnostic test. To view the execution interval of diagnostic tests, use the display diagnostic content command.
Configuring on-demand diagnostics
The diagnostic ondemand commands are effective only during the current system operation. These commands are restored to the default after you restart the device.
You can stop an on-demand diagnostic test by using any of the following commands:
·     Use the diagnostic ondemand stop command to immediately stop the test.
·     Use the diagnostic ondemand repeating command to configure the number of executions for the test.
·     Use the diagnostic ondemand failure command to configure the maximum number of failed tests before the system stops the test.
To configure on-demand diagnostics:
Remarks
Configure the number of executions.
diagnostic ondemand repeating repeating-number
The default value for the repeating-number argument is 1.
This command only applies to diagnostic tests to be enabled.
Configure the number of failed tests.
diagnostic ondemand failure failure-number
By default, the maximum number of failed tests is not specified.
Configure a number no larger than the configured repeating-number argument.
Enable on-demand diagnostics.
diagnostic ondemand start slot slot-number-list test { non-disruptive | test-name } [ para parameters ]
The system runs the tests according to the default configuration if you do not perform the first two configurations.
(Optional.) Stop on-demand diagnostics.
diagnostic ondemand stop slot slot-number-list test { non-disruptive | test-name }
You can manually stop all on-demand diagnostic tests.
Simulating test results
Test simulation verifies GOLD frame functionality. When you use the diagnostic simulation commands to simulate a diagnostic test, only part of the test code is executed to generate a test result. Test simulation does not trigger hardware correcting actions such as device restart and master/subordinate switchover.
Only monitoring diagnostics and on-demand diagnostics support test simulation.
To simulate a test:
Remarks
Simulate a test.
diagnostic simulation slot slot-number-list test test-name { failure | random-failure | success }
By default, the system runs a test instead of simulating it.
Configuring the log buffer size
GOLD saves test results in the form of logs. You can use the display diagnostic event-log command to view the logs.
To configure the GOLD log buffer size:
Remarks
N/A
2.     Configure the maximum number of GOLD logs that can be saved.
diagnostic event-log size number
By default, GOLD saves 512 log entries at most.
When the number of logs exceeds the configured log buffer size, the system deletes the oldest entries.
Displaying and maintaining GOLD
Display test content.
display diagnostic content [ slot slot-number ] [ verbose ]
Display GOLD logs.
display diagnostic event-log [ error | info ]
Display configurations of on-demand diagnostics.
display diagnostic ondemand configuration
Display test results.
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ]
Display statistics for packet-related tests.
display diagnostic result [ slot slot-number [ test test-name ] ] statistics
Display configurations for simulated tests.
display diagnostic simulation [ slot slot-number ]
Clear GOLD logs.
reset diagnostic event-log
Clear test results.
reset diagnostic result [ slot slot-number [ test test-name ] ]
GOLD configuration example
Network requirements
Enable monitoring diagnostic test HGMonitor on IRF member device 1, and set its execution interval to 1 minute.
Configuration procedure
# View the default status and execution interval of the test.
<Sysname> display diagnostic content slot 1 verbose
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Slot 1 :
Test name        : HGMonitor
Test attributes  : **M*PI
Test interval    : 00:00:10
Min interval     : 00:00:10
Correct-action   : -NA-
Description       : A Real-time test, disabled by default that checks link status between ports.
exec             : -NA-
# Enable test HGMonitor on IRF member device 1.
[Sysname] diagnostic monitor enable slot 1 test HGMonitor
# Set the execution interval to 1 minute.
[Sysname] diagnostic monitor interval slot 1 test HGMonitor time 0:1:0
# View the test configuration.
[Sysname] display diagnostic content slot 1 verbose
Slot 1 :
Test attributes  : **M*PA
Test interval    : 00:01:00
exec             : -NA-
# View the test result.
[Sysname] display diagnostic result slot 1 verbose
Slot 1 :
  Total run count          : 1247
  Total failure count      : 0
  Consecutive failure count: 0
  Last execution time      : Tue Dec 25 18:09:21 2012
  First failure time       : -NA-
  Last failure time        : -NA-
  Last pass time           : Tue Dec 25 18:09:21 2012
  Last execution result    : Success
  Last failure reason      : -NA-
  Next execution time      : Tue Dec 25 18:10:21 2012
  Port link status : Normal
